[mapguide-commits] r7977 - sandbox/jng/webtier_upgrade_v2/MgDev
svn_mapguide at osgeo.org
Sat Feb 8 21:34:44 PST 2014
Author: jng
Date: 2014-02-08 21:34:43 -0800 (Sat, 08 Feb 2014)
New Revision: 7977
sandbox/jng/webtier_upgrade_v2/MgDev/configure.in
FDO version update
Modified: sandbox/jng/webtier_upgrade_v2/MgDev/configure.in
--- sandbox/jng/webtier_upgrade_v2/MgDev/configure.in 2014-02-09 04:41:29 UTC (rev 7976)
+++ sandbox/jng/webtier_upgrade_v2/MgDev/configure.in 2014-02-09 05:34:43 UTC (rev 7977)
@@ -85,7 +85,7 @@
AC_SUBST(httpd_src)
dnl *******************************************************
-dnl FDO 3.8.1 Configuration
+dnl FDO 3.9.0 Configuration
dnl Include / lib paths
# custom Fdo path specification
@@ -96,9 +96,9 @@
[custom_inc=DEFAULT])
if test $custom_inc = "DEFAULT"; then
- map_fdo_include="/usr/local/fdo-3.8.1/include"
+ map_fdo_include="/usr/local/fdo-3.9.0/include"
if test -d $map_fdo_include; then
- AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-3.8.1/include])
+ AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-3.9.0/include])
else
AC_MSG_ERROR([the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option])
fi
@@ -118,9 +118,9 @@
[custom_lib=DEFAULT])
if test $custom_lib = "DEFAULT"; then
- map_fdo_lib="/usr/local/fdo-3.8.1/lib"
+ map_fdo_lib="/usr/local/fdo-3.9.0/lib"
if test -d $map_fdo_lib; then
- AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-3.8.1/lib])
+ AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-3.9.0/lib])
else
AC_MSG_ERROR([the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option])
fi
@@ -132,7 +132,7 @@
AC_MSG_ERROR([the specified FDO library path $custom_lib is not a valid directory])
fi
fi
-map_fdo_nls="/usr/local/fdo-3.8.1/nls/%N"
+map_fdo_nls="/usr/local/fdo-3.9.0/nls/%N"
AC_SUBST(map_fdo_include)
AC_SUBST(map_fdo_lib)
AC_SUBST(map_fdo_nls)
More information about the mapguide-commits
