[mapguide-commits] r8277 - branches/2.6/MgDev/Desktop/Samples
svn_mapguide at osgeo.org
Fri Jul 4 01:15:02 PDT 2014
Author: jng
Date: 2014-07-04 01:15:02 -0700 (Fri, 04 Jul 2014)
New Revision: 8277
branches/2.6/MgDev/Desktop/Samples/samples_readme.txt
Update mg-desktop samples readme
Modified: branches/2.6/MgDev/Desktop/Samples/samples_readme.txt
--- branches/2.6/MgDev/Desktop/Samples/samples_readme.txt 2014-07-04 08:13:36 UTC (rev 8276)
+++ branches/2.6/MgDev/Desktop/Samples/samples_readme.txt 2014-07-04 08:15:02 UTC (rev 8277)
@@ -3,11 +3,8 @@
The following samples all require the Sheboygan sample dataset. For these samples to build, copy your mg-desktop files (and its subfolders) into the Lib directory, you must use the correct build of mg-desktop for the version of VS you are using to open this solution file:
- - MgDesktopSamples.sln: mg-desktop .net Framework 2.0, VC9 build
- - MgDesktopSamples_VS2010.sln: mg-desktop .net Framework 4.0, VC10 build
+ - MgDesktopSamples.sln: mg-desktop .net Framework 4.5, VC11 build
-Basically, you can't use a .net 4.0 build of mg-desktop on a VS2008 solution
Note that in order to use mg-desktop, your main executable must have CPU architecture set to x86 (because these are .net wrappers to 32-bit unmanaged dlls). All the executable projects in this solution have their CPU architecture set to x86
BasicSample
More information about the mapguide-commits
