[mapguide-commits] r8280 - in sandbox/jng/convenience_apis: Common/MapGuideCommon/MapLayer Common/PlatformBase/MapLayer UnitTest/WebTier/DotNet/TestCommon/ExternalTests
svn_mapguide at osgeo.org
Fri Jul 4 03:14:44 PDT 2014
Author: jng
Date: 2014-07-04 03:14:44 -0700 (Fri, 04 Jul 2014)
New Revision: 8280
sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.cpp
sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.h
sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.cpp
sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.h
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/ConvenienceTests.cs
This submission adds and modifies some of the convenience APIs we've introduced to MgLayerBase:
- InsertFeatures/UpdateMatchingFeatures/DeleteFeatures have been modified to accept an MgTransaction parameter, if not null the relevant operation will execute under that transaction
- A new overload of UpdateFeatures() that accepts a MgTransaction parameter. The original UpdateFeatures() method will still internally use a transaction if supported. This overload you can choose to use transactions (if supported) or not (by passing a null MgTransaction).
- A new BeginTransaction() convenience method to start a new transaction for the layer's feature source
- A new GetSpatialContexts() convenience method
New .net tests have been added to the new APIs added and existing .net tests have been modified to reflect the API changes.
Modified: sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.cpp
--- sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.cpp 2014-07-04 08:45:30 UTC (rev 8279)
+++ sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.cpp 2014-07-04 10:14:44 UTC (rev 8280)
@@ -457,111 +457,102 @@
-MgFeatureReader* MgLayer::InsertFeatures(MgPropertyCollection* properties)
+MgTransaction* MgLayer::BeginTransaction()
+ Ptr<MgTransaction> ret;
+ MG_TRY()
+ Ptr<MgResourceIdentifier> resourceId = new MgResourceIdentifier(m_featureSourceId);
Ptr<MgFeatureService> featureService = dynamic_cast<MgFeatureService*>(
GetMap()->GetService(MgServiceType::FeatureService));
- Ptr<MgResourceIdentifier> resourceId = new MgResourceIdentifier(m_featureSourceId);
- Ptr<MgFeatureReader> ret;
- Ptr<MgTransaction> trans;
- MG_TRY()
+ ret = featureService->BeginTransaction(resourceId);
- if (UseTransaction(featureService, GetProviderName()))
- trans = featureService->BeginTransaction(resourceId);
+ MG_CATCH_AND_THROW(L"MgLayer.BeginTransaction")
- ret = featureService->InsertFeatures(resourceId, m_featureName, properties);
- if (NULL != trans.p)
- trans->Commit();
+ return ret.Detach();
- MG_CATCH(L"MgLayer.InsertFeatures")
+MgPropertyCollection* MgLayer::UpdateFeatures(MgFeatureCommandCollection* commands, MgTransaction* transaction)
+ Ptr<MgPropertyCollection> propCol;
- trans->Rollback();
+ MG_TRY()
- MG_THROW()
+ // Determine if the provider supports transactions.
+ Ptr<MgFeatureService> featureService = dynamic_cast<MgFeatureService*>(
+ GetMap()->GetService(MgServiceType::FeatureService));
- return ret.Detach();
+ propCol = featureService->UpdateFeatures(resourceId, commands, transaction);
+ MG_CATCH_AND_THROW(L"MgLayer.UpdateFeatures")
+ return propCol.Detach();
-MgFeatureReader* MgLayer::InsertFeatures(MgBatchPropertyCollection* properties)
+MgFeatureReader* MgLayer::InsertFeatures(MgPropertyCollection* properties, MgTransaction* transaction)
MG_TRY()
+ ret = featureService->InsertFeatures(resourceId, m_featureName, properties, transaction);
- trans->Commit();
+ MG_CATCH_AND_THROW(L"MgLayer.InsertFeatures")
+MgFeatureReader* MgLayer::InsertFeatures(MgBatchPropertyCollection* properties, MgTransaction* transaction)
- MG_THROW()
+ Ptr<MgFeatureReader> ret;
+ MG_TRY()
-INT32 MgLayer::UpdateMatchingFeatures(MgPropertyCollection* properties, CREFSTRING filter)
+INT32 MgLayer::UpdateMatchingFeatures(MgPropertyCollection* properties, CREFSTRING filter, MgTransaction* transaction)
INT32 updated = -1;
MG_TRY()
+ updated = featureService->UpdateMatchingFeatures(resourceId, m_featureName, properties, filter, transaction);
+ MG_CATCH_AND_THROW(L"MgLayer.UpdateMatchingFeatures")
- updated = featureService->UpdateMatchingFeatures(resourceId, m_featureName, properties, filter);
- trans->Commit();
- MG_CATCH(L"MgLayer.UpdateMatchingFeatures")
- MG_THROW()
return updated;
-INT32 MgLayer::DeleteFeatures(CREFSTRING filter)
+INT32 MgLayer::DeleteFeatures(CREFSTRING filter, MgTransaction* transaction)
INT32 deleted = -1;
MG_TRY()
+ deleted = featureService->DeleteFeatures(resourceId, m_featureName, filter, transaction);
- deleted = featureService->DeleteFeatures(resourceId, m_featureName, filter);
- trans->Commit();
+ MG_CATCH_AND_THROW(L"MgLayer.DeleteFeatures")
- MG_CATCH(L"MgLayer.DeleteFeatures")
- MG_THROW()
return deleted;
@@ -773,4 +764,19 @@
MG_CATCH_AND_THROW(L"MgLayer.GenerateLegendImage");
+MgSpatialContextReader* MgLayer::GetSpatialContexts(bool bActiveOnly)
+ Ptr<MgSpatialContextReader> ret;
+ MG_TRY()
+ Ptr<MgFeatureService> svcFeature = dynamic_cast<MgFeatureService*>(GetMap()->GetService(MgServiceType::FeatureService));
+ Ptr<MgResourceIdentifier> fsId = new MgResourceIdentifier(m_featureSourceId);
+ ret = svcFeature->GetSpatialContexts(fsId, bActiveOnly);
+ MG_CATCH_AND_THROW(L"MgLayer.GetSpatialContexts");
\ No newline at end of file
Modified: sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.h
--- sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.h 2014-07-04 08:45:30 UTC (rev 8279)
+++ sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.h 2014-07-04 10:14:44 UTC (rev 8280)
@@ -262,6 +262,97 @@
virtual MgPropertyCollection* UpdateFeatures(MgFeatureCommandCollection* commands);
+ /// \brief
+ /// Starts a transaction on the this layer. The FDO provider indicated by the layer's
+ /// Feature Source must support transactions.
+ /// \remarks
+ /// The XML returned by MgFeatureService::GetCapabilities says
+ /// whether a provider supports transactions. See \link ProviderCapabilities Provider Capabilities \endlink.
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// virtual MgTransaction BeginTransaction();
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \return
+ /// Returns an MgTransaction instance (or NULL).
+ /// \exception MgFeatureServiceException
+ /// \exception MgInvalidArgumentException
+ /// \exception MgInvalidOperationException
+ /// \exception MgFdoException
+ /// \since 3.0
+ virtual MgTransaction* BeginTransaction();
+ /// \brief
+ /// Executes the MgDeleteFeatures, MgInsertFeatures,
+ /// MgUpdateFeatures, MgLockFeatures or MgUnlockFeatures commands
+ /// contained in the given MgFeatureCommandCollection object.
+ /// \remarks
+ /// whether a provider supports SQL commands. See \link ProviderCapabilities Provider Capabilities \endlink.
+ /// virtual MgPropertyCollection UpdateFeatures(MgFeatureCommandCollection commands);
+ /// \param commands (MgFeatureCommandCollection)
+ /// A collection of feature commands to be
+ /// executed.
+ /// \param transaction (MgTransaction)
+ /// An optional transaction to execute this operation under
+ /// \return
+ /// Returns an MgPropertyCollection object. Each property in the
+ /// collection corresponds to a command in the
+ /// MgFeatureCommandCollection argument. The property name is the
+ /// index of the command in the feature command collection.
+ /// <ul>
+ /// <li>If the command is of type MgDeleteFeatures, the property
+ /// type is an MgPropertyType::Int32, and its value is the number
+ /// of features deleted.</li>
+ /// <li>If the command is of type MgInsertFeatures, the property
+ /// type is an MgPropertyType::Feature, and its value is a
+ /// MgFeatureReader object. The feature reader object contains
+ /// the set of properties inserted into the datastore by the
+ /// insert command.</li>
+ /// <li>If the command is of type MgUpdateFeatures, the property
+ /// type is MgPropertyType::Int32, and its value is the number of
+ /// features updated.</li>
+ /// <li>If the command is of type MgLockFeatures, the property
+ /// type is MgPropertyType::Feature, and its value is the number
+ /// of features locked.</li>
+ /// <li>If the command is of type MgUnLockFeatures, the property
+ /// features unlocked.</li>
+ /// </ul>
+ /// \since 3.0
+ virtual MgPropertyCollection* UpdateFeatures(MgFeatureCommandCollection* commands, MgTransaction* transaction);
/// \brief
/// Inserts a new feature into the specified feature class of the specified Feature Source
@@ -295,7 +386,7 @@
/// \since 3.0
- virtual MgFeatureReader* InsertFeatures(MgPropertyCollection* properties);
+ virtual MgFeatureReader* InsertFeatures(MgPropertyCollection* properties, MgTransaction* transaction);
/// \brief
@@ -331,7 +422,7 @@
/// \since 3.0
- virtual MgFeatureReader* InsertFeatures(MgBatchPropertyCollection* properties);
+ virtual MgFeatureReader* InsertFeatures(MgBatchPropertyCollection* properties, MgTransaction* transaction);
/// \brief
@@ -365,7 +456,7 @@
/// \since 3.0
- virtual INT32 UpdateMatchingFeatures(MgPropertyCollection* properties, CREFSTRING filter);
+ virtual INT32 UpdateMatchingFeatures(MgPropertyCollection* properties, CREFSTRING filter, MgTransaction* transaction);
/// \brief
@@ -397,7 +488,7 @@
/// \since 3.0
- virtual INT32 DeleteFeatures(CREFSTRING filter);
+ virtual INT32 DeleteFeatures(CREFSTRING filter, MgTransaction* transaction);
/// \brief
@@ -669,6 +760,40 @@
/// \since 3.0
MgByteReader* GenerateLegendImage(double scale, INT32 width, INT32 height, CREFSTRING format, INT32 geomType, INT32 themeCategory);
+ /// \brief
+ /// Gets all of the spatial contexts available in the layer or just the active one
+ /// \remarks
+ /// The \link FdoSpatialContextList_schema FdoSpatialContextList \endlink XML schema contains
+ /// a specification of the content of the spatial context
+ /// information returned in the MgSpatialContextReader object.
+ /// virtual MgSpatialContextReader GetSpatialContexts(bool bActiveOnly);
+ /// virtual MgSpatialContextReader GetSpatialContexts(boolean bActiveOnly);
+ /// \param bActiveOnly (boolean/bool)
+ /// This flag is obsolete and no longer used.
+ /// \return
+ /// Returns an MgSpatialContextReader object.
+ /// \since 3.0
+ virtual MgSpatialContextReader* GetSpatialContexts(bool bActiveOnly);
INTERNAL_API:
Modified: sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.cpp
--- sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.cpp 2014-07-04 08:45:30 UTC (rev 8279)
+++ sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.cpp 2014-07-04 10:14:44 UTC (rev 8280)
@@ -814,26 +814,44 @@
__LINE__, __WFILE__, NULL, L"", NULL);
-MgFeatureReader* MgLayerBase::InsertFeatures(MgPropertyCollection* properties)
+MgPropertyCollection* MgLayerBase::UpdateFeatures(MgFeatureCommandCollection* commands, MgTransaction* transaction)
+ throw new MgNotImplementedException(L"MgLayerBase.UpdateFeatures",
+ __LINE__, __WFILE__, NULL, L"", NULL);
+MgTransaction* MgLayerBase::BeginTransaction()
+ throw new MgNotImplementedException(L"MgLayerBase.BeginTransaction",
+MgFeatureReader* MgLayerBase::InsertFeatures(MgPropertyCollection* properties, MgTransaction* transaction)
throw new MgNotImplementedException(L"MgLayerBase.InsertFeatures",
-MgFeatureReader* MgLayerBase::InsertFeatures(MgBatchPropertyCollection* properties)
+MgFeatureReader* MgLayerBase::InsertFeatures(MgBatchPropertyCollection* properties, MgTransaction* transaction)
-INT32 MgLayerBase::UpdateMatchingFeatures(MgPropertyCollection* properties, CREFSTRING filter)
+INT32 MgLayerBase::UpdateMatchingFeatures(MgPropertyCollection* properties, CREFSTRING filter, MgTransaction* transaction)
throw new MgNotImplementedException(L"MgLayerBase.UpdateMatchingFeatures",
-INT32 MgLayerBase::DeleteFeatures(CREFSTRING filter)
+INT32 MgLayerBase::DeleteFeatures(CREFSTRING filter, MgTransaction* transaction)
throw new MgNotImplementedException(L"MgLayerBase.DeleteFeatures",
+MgSpatialContextReader* MgLayerBase::GetSpatialContexts(bool bActiveOnly)
+ throw new MgNotImplementedException(L"MgLayerBase.GetSpatialContexts",
Modified: sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.h
--- sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.h 2014-07-04 08:45:30 UTC (rev 8279)
+++ sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.h 2014-07-04 10:14:44 UTC (rev 8280)
@@ -908,6 +908,97 @@
/// \since 1.2
+ /// \brief
+ /// \remarks
+ /// \return
+ /// \since 3.0
+ /// \brief
+ /// \remarks
+ /// executed.
+ /// \return
+ /// <ul>
+ /// </ul>
+ /// \since 3.0
/// \brief
@@ -925,6 +1016,8 @@
/// \param properties (MgPropertyCollection)
/// The collection of property values to insert
/// \return
/// Returns a feature reader object that contains the set of properties
@@ -941,7 +1034,7 @@
/// \since 3.0
/// \brief
@@ -961,6 +1054,8 @@
/// \param properties (MgBatchPropertyCollection)
/// The collection of property values to insert. Each MgPropertyCollection within
/// this collection represents property values for a single feature to insert
/// \return
@@ -977,7 +1072,7 @@
/// \since 3.0
/// \brief
@@ -1001,6 +1096,8 @@
/// The property values to update matching features with
/// \param filter (String/string)
/// The FDO filter string that detemines what features will be updated
/// \return
/// Returns the number of features updated by this operation
@@ -1011,7 +1108,7 @@
/// \since 3.0
/// \brief
@@ -1033,6 +1130,8 @@
/// The FDO filter string that detemines what features will be deleted
/// \return
/// Returns the number of features deleted by this operation
@@ -1043,8 +1142,42 @@
/// \since 3.0
+ /// \brief
+ /// \remarks
+ /// \return
+ /// \since 3.0
INTERNAL_API:
static MdfModel::LayerDefinition* GetLayerDefinition(MgResourceService* svcResource, MgResourceIdentifier* resId);
Modified: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/ConvenienceTests.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/ConvenienceTests.cs 2014-07-04 08:45:30 UTC (rev 8279)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/ConvenienceTests.cs 2014-07-04 10:14:44 UTC (rev 8280)
@@ -57,161 +57,421 @@
public void Execute(IPlatformFactory factory, ITestLogger logger)
- MgFeatureService featSvc = (MgFeatureService)factory.CreateService(MgServiceType.FeatureService);
- var fsId = new MgResourceIdentifier("Library://UnitTests/Data/InsertFeatures.FeatureSource");
- string className = FeatureServiceTestUtil.CreateTestDataStore(fsId, "OSGeo.SDF", featSvc);
- var agfRw = new MgAgfReaderWriter();
- var wktRw = new MgWktReaderWriter();
+ var featSvc = (MgFeatureService)factory.CreateService(MgServiceType.FeatureService);
+ var resSvc = (MgResourceService)factory.CreateService(MgServiceType.ResourceService);
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/FeatureServiceInsertFeatures.FeatureSource");
+ try
+ string className = FeatureServiceTestUtil.CreateTestDataStore(fsId, "OSGeo.SDF", featSvc);
+ var agfRw = new MgAgfReaderWriter();
+ var wktRw = new MgWktReaderWriter();
- var props = new MgPropertyCollection();
- var nameP = new MgStringProperty("Name", "Test");
- var geom = wktRw.Read("POINT (1 1)");
- var agf = agfRw.Write(geom);
- var geomP = new MgGeometryProperty("Geometry", agf);
- props.Add(nameP);
- props.Add(geomP);
+ var props = new MgPropertyCollection();
+ var nameP = new MgStringProperty("Name", "Test");
+ var geom = wktRw.Read("POINT (1 1)");
+ var agf = agfRw.Write(geom);
+ var geomP = new MgGeometryProperty("Geometry", agf);
+ props.Add(nameP);
+ props.Add(geomP);
- var fr = featSvc.InsertFeatures(fsId, className, props);
- int count = 0;
- while (fr.ReadNext())
+ var fr = featSvc.InsertFeatures(fsId, className, props);
+ int count = 0;
+ while (fr.ReadNext())
+ count++;
+ fr.Close();
+ Assert.AreEqual(1, count);
+ finally
- count++;
+ resSvc.DeleteResource(fsId);
- fr.Close();
- Assert.AreEqual(1, count);
- public class FeatureServiceInsertFeaturesBatched : IExternalTest
+ public class FeatureServiceInsertFeaturesWithTransaction : IExternalTest
- var fsId = new MgResourceIdentifier("Library://UnitTests/Data/InsertFeaturesBatched.FeatureSource");
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/FeatureServiceInsertFeaturesWithTransaction.FeatureSource");
+ try
+ string className = FeatureServiceTestUtil.CreateTestDataStore(fsId, "OSGeo.SQLite", featSvc);
- var batchProps = new MgBatchPropertyCollection();
- for (int i = 0; i < 5; i++)
- var nameP = new MgStringProperty("Name", "Test" + (i + 1));
props.Add(nameP);
props.Add(geomP);
- batchProps.Add(props);
+ var trans = featSvc.BeginTransaction(fsId);
+ var fr = featSvc.InsertFeatures(fsId, className, props, trans);
+ int count = 0;
+ count++;
+ fr.Close();
+ trans.Rollback();
+ fr = featSvc.SelectFeatures(fsId, className, null);
+ count = 0;
+ count++;
+ fr.Close();
+ Assert.AreEqual(0, count);
- var fr = featSvc.InsertFeatures(fsId, className, batchProps);
- int count = 0;
+ finally
- count++;
- fr.Close();
- Assert.AreEqual(5, count);
- public class FeatureServiceUpdateFeatures : IExternalTest
+ public class FeatureServiceInsertFeaturesBatched : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/FeatureServiceInsertFeaturesBatched.FeatureSource");
+ try
- var fsId = new MgResourceIdentifier("Library://UnitTests/Data/UpdateFeatures.FeatureSource");
+ var batchProps = new MgBatchPropertyCollection();
+ for (int i = 0; i < 5; i++)
+ var nameP = new MgStringProperty("Name", "Test" + (i + 1));
+ props.Add(nameP);
+ props.Add(geomP);
+ batchProps.Add(props);
+ var fr = featSvc.InsertFeatures(fsId, className, batchProps);
+ int count = 0;
+ count++;
+ fr.Close();
+ Assert.AreEqual(5, count);
+ finally
- props.Add(nameP);
- props.Add(geomP);
- int count = 0;
+ public class FeatureServiceInsertFeaturesBatchedWithTransaction : IExternalTest
+ public void Execute(IPlatformFactory factory, ITestLogger logger)
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/FeatureServiceInsertFeaturesBatchedWithTransaction.FeatureSource");
+ try
- count++;
- fr.Close();
- var updateProps = new MgPropertyCollection();
- var newName = new MgStringProperty("Name", "Test3Updated");
- updateProps.Add(newName);
+ props.Add(nameP);
+ props.Add(geomP);
- int updated = featSvc.UpdateMatchingFeatures(fsId, className, updateProps, "Name = 'Test3'");
- Assert.AreEqual(1, updated);
+ var fr = featSvc.InsertFeatures(fsId, className, batchProps, trans);
+ int count = 0;
+ count++;
+ fr.Close();
+ trans.Rollback();
+ count = 0;
+ count++;
+ fr.Close();
+ finally
- public class FeatureServiceDeleteFeatures : IExternalTest
+ public class FeatureServiceUpdateFeatures : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/FeatureServiceUpdateFeatures.FeatureSource");
+ try
- var fsId = new MgResourceIdentifier("Library://UnitTests/Data/DeleteFeatures.FeatureSource");
+ props.Add(nameP);
+ props.Add(geomP);
+ int count = 0;
+ count++;
+ fr.Close();
+ var updateProps = new MgPropertyCollection();
+ var newName = new MgStringProperty("Name", "Test3Updated");
+ updateProps.Add(newName);
+ int updated = featSvc.UpdateMatchingFeatures(fsId, className, updateProps, "Name = 'Test3'");
+ Assert.AreEqual(1, updated);
+ finally
- props.Add(nameP);
- props.Add(geomP);
- int count = 0;
+ public class FeatureServiceUpdateFeaturesWithTransaction : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/FeatureServiceUpdateFeaturesWithTransaction.FeatureSource");
+ try
- count++;
+ props.Add(nameP);
+ props.Add(geomP);
+ int count = 0;
+ count++;
+ fr.Close();
+ int updated = featSvc.UpdateMatchingFeatures(fsId, className, updateProps, "Name = 'Test3'", trans);
+ trans.Rollback();
+ var query = new MgFeatureQueryOptions();
+ query.SetFilter("Name = 'Test3Updated'");
+ fr = featSvc.SelectFeatures(fsId, className, query);
+ count = 0;
+ count++;
+ fr.Close();
- fr.Close();
+ finally
- int deleted = featSvc.DeleteFeatures(fsId, className, "Name = 'Test3'");
- Assert.AreEqual(1, deleted);
+ public class FeatureServiceDeleteFeatures : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/FeatureServiceDeleteFeatures.FeatureSource");
+ try
- var query = new MgFeatureQueryOptions();
- fr = featSvc.SelectFeatures(fsId, className, query);
- count = 0;
+ props.Add(nameP);
+ props.Add(geomP);
+ int count = 0;
+ count++;
+ fr.Close();
+ int deleted = featSvc.DeleteFeatures(fsId, className, "Name = 'Test3'");
+ Assert.AreEqual(1, deleted);
+ count = 0;
+ count++;
+ fr.Close();
+ Assert.AreEqual(4, count);
+ query.SetFilter("Name = 'Test3'");
+ count = 0;
+ count++;
+ fr.Close();
+ finally
- count++;
- Assert.AreEqual(4, count);
- query.SetFilter("Name = 'Test3'");
- count = 0;
+ public class FeatureServiceDeleteFeaturesWithTransaction : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/FeatureServiceDeleteFeaturesWithTransaction.FeatureSource");
+ try
- count++;
+ props.Add(nameP);
+ props.Add(geomP);
+ int count = 0;
+ count++;
+ fr.Close();
+ int deleted = featSvc.DeleteFeatures(fsId, className, "Name = 'Test3'", trans);
+ count = 0;
+ count++;
+ fr.Close();
+ trans.Rollback();
+ count = 0;
+ count++;
+ fr.Close();
- fr.Close();
- Assert.AreEqual(0, count);
+ finally
@@ -221,116 +481,263 @@
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/LayerInsertFeatures.FeatureSource");
+ try
+ MgCoordinateSystemFactory csFactory = new MgCoordinateSystemFactory();
+ MgMapBase map = factory.CreateMap(csFactory.ConvertCoordinateSystemCodeToWkt("LL84"), new MgEnvelope(-180, -90, 180, 90), "TestMap");
+ MgLayerCollection layers = map.GetLayers();
- MgCoordinateSystemFactory csFactory = new MgCoordinateSystemFactory();
- MgMapBase map = factory.CreateMap(csFactory.ConvertCoordinateSystemCodeToWkt("LL84"), new MgEnvelope(-180,-90,180,90), "TestMap");
- MgLayerCollection layers = map.GetLayers();
+ string layerXml = string.Format(Properties.Resources.TestLayer, fsId.ToString(), className, "Geometry");
+ byte[] bytes = Encoding.UTF8.GetBytes(layerXml);
+ MgByteSource bs = new MgByteSource(bytes, bytes.Length);
+ MgByteReader br = bs.GetReader();
- string layerXml = string.Format(Properties.Resources.TestLayer, fsId.ToString(), className, "Geometry");
- byte[] bytes = Encoding.UTF8.GetBytes(layerXml);
- MgByteSource bs = new MgByteSource(bytes, bytes.Length);
- MgByteReader br = bs.GetReader();
+ var ldfId = new MgResourceIdentifier("Library://UnitTests/Layers/TestLayer.LayerDefinition");
+ resSvc.SetResource(ldfId, br, null);
- var ldfId = new MgResourceIdentifier("Library://UnitTests/Layers/TestLayer.LayerDefinition");
- resSvc.SetResource(ldfId, br, null);
+ MgLayerBase layer = factory.CreateLayer(ldfId);
+ layers.Insert(0, layer);
- MgLayerBase layer = factory.CreateLayer(ldfId);
- layers.Insert(0, layer);
+ props.Add(nameP);
+ props.Add(geomP);
- props.Add(nameP);
- props.Add(geomP);
+ var fr = layer.InsertFeatures(props, null);
+ int count = 0;
+ count++;
+ fr.Close();
- var fr = layer.InsertFeatures(props);
- int count = 0;
- count++;
+ fr = layer.SelectFeatures(query);
+ count = 0;
+ count++;
+ fr.Close();
- fr.Close();
- fr = layer.SelectFeatures(query);
- count = 0;
+ finally
- count++;
- fr.Close();
- public class LayerInsertFeaturesBatched : IExternalTest
+ public class LayerInsertFeaturesWithTransaction : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/LayerInsertFeaturesWithTransaction.FeatureSource");
+ try
- MgMapBase map = factory.CreateMap(csFactory.ConvertCoordinateSystemCodeToWkt("LL84"), new MgEnvelope(-180, -90, 180, 90), "TestMap");
props.Add(nameP);
props.Add(geomP);
+ var trans = layer.BeginTransaction();
+ var fr = layer.InsertFeatures(props, trans);
+ int count = 0;
+ count++;
+ fr.Close();
+ trans.Rollback();
+ count = 0;
+ count++;
+ fr.Close();
+ finally
- var fr = layer.InsertFeatures(batchProps);
- int count = 0;
+ public class LayerInsertFeaturesBatched : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/LayerInsertFeaturesBatched.FeatureSource");
+ try
- count++;
+ props.Add(nameP);
+ props.Add(geomP);
+ var fr = layer.InsertFeatures(batchProps, null);
+ int count = 0;
+ count++;
+ fr.Close();
+ count = 0;
+ count++;
+ fr.Close();
- fr.Close();
+ finally
- count = 0;
+ public class LayerInsertFeaturesBatchedWithTransaction : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/LayerInsertFeaturesBatchedWithTransaction.FeatureSource");
+ try
- count++;
+ props.Add(nameP);
+ props.Add(geomP);
+ var fr = layer.InsertFeatures(batchProps, trans);
+ int count = 0;
+ count++;
+ fr.Close();
+ trans.Rollback();
+ count = 0;
+ count++;
+ fr.Close();
- fr.Close();
+ finally
@@ -340,56 +747,140 @@
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/LayerUpdateFeatures.FeatureSource");
+ try
+ props.Add(nameP);
+ props.Add(geomP);
+ int count = 0;
+ count++;
+ fr.Close();
+ int updated = layer.UpdateMatchingFeatures(updateProps, "Name = 'Test3'", null);
+ finally
- props.Add(nameP);
- props.Add(geomP);
- int count = 0;
+ public class LayerUpdateFeaturesWithTransaction : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/LayerUpdateFeaturesWithTransaction.FeatureSource");
+ try
- count++;
- fr.Close();
- int updated = layer.UpdateMatchingFeatures(updateProps, "Name = 'Test3'");
+ props.Add(nameP);
+ props.Add(geomP);
+ int count = 0;
+ count++;
+ fr.Close();
+ int updated = layer.UpdateMatchingFeatures(updateProps, "Name = 'Test3'", trans);
+ trans.Rollback();
+ count = 0;
+ count++;
+ fr.Close();
+ finally
@@ -399,71 +890,161 @@
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/LayerDeleteFeatures.FeatureSource");
+ try
+ props.Add(nameP);
+ props.Add(geomP);
+ int count = 0;
+ count++;
+ fr.Close();
+ int deleted = layer.DeleteFeatures("Name = 'Test3'", null);
+ count = 0;
+ count++;
+ fr.Close();
+ count = 0;
+ count++;
+ fr.Close();
+ finally
- props.Add(nameP);
- props.Add(geomP);
- int count = 0;
+ public class LayerDeleteFeaturesWithTransaction : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/LayerDeleteFeaturesWithTransaction.FeatureSource");
+ try
- count++;
- fr.Close();
- int deleted = layer.DeleteFeatures("Name = 'Test3'");
- count = 0;
- count++;
+ props.Add(nameP);
+ props.Add(geomP);
+ int count = 0;
+ count++;
+ fr.Close();
+ int deleted = layer.DeleteFeatures("Name = 'Test3'", trans);
+ trans.Rollback();
+ count = 0;
+ count++;
+ fr.Close();
+ count = 0;
+ count++;
+ fr.Close();
- count = 0;
+ finally
- count++;
- fr.Close();
@@ -471,97 +1052,104 @@
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/TransformTest.FeatureSource");
+ try
+ //Create our test data store
+ MgFeatureSchema fs = new MgFeatureSchema("Default", "");
+ MgClassDefinition cls = new MgClassDefinition();
+ cls.SetName("Test");
- //Create our test data store
- MgFeatureSchema fs = new MgFeatureSchema("Default", "");
- MgClassDefinition cls = new MgClassDefinition();
- cls.SetName("Test");
- MgDataPropertyDefinition id = new MgDataPropertyDefinition("ID");
- id.SetAutoGeneration(true);
- id.SetDataType(MgPropertyType.Int32);
- MgGeometricPropertyDefinition geom = new MgGeometricPropertyDefinition("Geometry");
- geom.SetGeometryTypes(MgFeatureGeometricType.Point);
- geom.SetSpatialContextAssociation("Default");
+ MgDataPropertyDefinition id = new MgDataPropertyDefinition("ID");
+ id.SetAutoGeneration(true);
+ id.SetDataType(MgPropertyType.Int32);
- MgPropertyDefinitionCollection props = cls.GetProperties();
- MgPropertyDefinitionCollection idProps = cls.GetIdentityProperties();
+ MgGeometricPropertyDefinition geom = new MgGeometricPropertyDefinition("Geometry");
+ geom.SetGeometryTypes(MgFeatureGeometricType.Point);
+ geom.SetSpatialContextAssociation("Default");
- props.Add(id);
- props.Add(geom);
- idProps.Add(id);
+ MgPropertyDefinitionCollection props = cls.GetProperties();
+ MgPropertyDefinitionCollection idProps = cls.GetIdentityProperties();
- cls.SetDefaultGeometryPropertyName("Geometry");
- MgClassDefinitionCollection classes = fs.GetClasses();
- classes.Add(cls);
+ props.Add(id);
+ props.Add(geom);
+ idProps.Add(id);
- //We'll use a transform guaranteed to work. ArbitraryXY (unitA to unitB)
- //We just check that the transformed values are not the original, that way
- //we know that CS-Map did its job
- MgCoordinateSystemFactory csFact = new MgCoordinateSystemFactory();
- string srcWkt = csFact.ConvertCoordinateSystemCodeToWkt("XY-M");
- string dstWkt = csFact.ConvertCoordinateSystemCodeToWkt("XY-IN");
+ cls.SetDefaultGeometryPropertyName("Geometry");
+ MgClassDefinitionCollection classes = fs.GetClasses();
+ classes.Add(cls);
- MgGeometryFactory geomFact = new MgGeometryFactory();
- MgAgfReaderWriter agfRw = new MgAgfReaderWriter();
- MgFileFeatureSourceParams create = new MgFileFeatureSourceParams("OSGeo.SDF", "Default", srcWkt, fs);
- MgResourceIdentifier fsId = new MgResourceIdentifier("Library://UnitTests/Data/TransformTest.FeatureSource");
- featSvc.CreateFeatureSource(fsId, create);
+ //We'll use a transform guaranteed to work. ArbitraryXY (unitA to unitB)
+ //We just check that the transformed values are not the original, that way
+ //we know that CS-Map did its job
+ MgCoordinateSystemFactory csFact = new MgCoordinateSystemFactory();
+ string srcWkt = csFact.ConvertCoordinateSystemCodeToWkt("XY-M");
+ string dstWkt = csFact.ConvertCoordinateSystemCodeToWkt("XY-IN");
- //Populate data store with test points
+ MgGeometryFactory geomFact = new MgGeometryFactory();
+ MgAgfReaderWriter agfRw = new MgAgfReaderWriter();
+ MgFileFeatureSourceParams create = new MgFileFeatureSourceParams("OSGeo.SDF", "Default", srcWkt, fs);
+ featSvc.CreateFeatureSource(fsId, create);
- MgCoordinate coord1 = geomFact.CreateCoordinateXY(-37.1020, 144.0020);
- MgPoint pt1 = geomFact.CreatePoint(coord1);
- MgByteReader agf1 = agfRw.Write(pt1);
+ //Populate data store with test points
- MgPropertyCollection propVals = new MgPropertyCollection();
- MgGeometryProperty pGeom = new MgGeometryProperty("Geometry", agf1);
- propVals.Add(pGeom);
+ MgCoordinate coord1 = geomFact.CreateCoordinateXY(-37.1020, 144.0020);
+ MgPoint pt1 = geomFact.CreatePoint(coord1);
+ MgByteReader agf1 = agfRw.Write(pt1);
- MgFeatureReader fr = featSvc.InsertFeatures(fsId, "Default:Test", propVals);
- fr.Close();
+ MgPropertyCollection propVals = new MgPropertyCollection();
+ MgGeometryProperty pGeom = new MgGeometryProperty("Geometry", agf1);
+ propVals.Add(pGeom);
- MgCoordinate coord2 = geomFact.CreateCoordinateXY(-37.2020, 144.2020);
- MgPoint pt2 = geomFact.CreatePoint(coord2);
- MgByteReader agf2 = agfRw.Write(pt2);
+ MgFeatureReader fr = featSvc.InsertFeatures(fsId, "Default:Test", propVals);
+ fr.Close();
- pGeom.SetValue(agf2);
- fr = featSvc.InsertFeatures(fsId, "Default:Test", propVals);
- fr.Close();
+ MgCoordinate coord2 = geomFact.CreateCoordinateXY(-37.2020, 144.2020);
+ MgPoint pt2 = geomFact.CreatePoint(coord2);
+ MgByteReader agf2 = agfRw.Write(pt2);
- //Now select from this data store
- MgFeatureQueryOptions query = new MgFeatureQueryOptions();
- MgReader reader = featSvc.SelectFeatures(fsId, "Default:Test", query, dstWkt);
- Assert.IsTrue(reader.ReadNext());
- Assert.IsTrue(!reader.IsNull("Geometry"));
+ pGeom.SetValue(agf2);
+ fr = featSvc.InsertFeatures(fsId, "Default:Test", propVals);
+ fr.Close();
- MgByteReader txAgf1 = reader.GetGeometry("Geometry");
- MgGeometry txGeom1 = agfRw.Read(txAgf1);
- MgPoint txPt1 = (MgPoint)txGeom1;
- Assert.IsTrue(txPt1 != null);
- MgCoordinate txCoord1 = txPt1.GetCoordinate();
+ //Now select from this data store
+ MgFeatureQueryOptions query = new MgFeatureQueryOptions();
+ MgReader reader = featSvc.SelectFeatures(fsId, "Default:Test", query, dstWkt);
- //TODO: Maybe we should really check that it matches the expected transformed result
- Assert.IsTrue(txCoord1.GetX() != -37.1020);
- Assert.IsTrue(txCoord1.GetY() != 144.0020);
+ Assert.IsTrue(reader.ReadNext());
+ Assert.IsTrue(!reader.IsNull("Geometry"));
+ MgByteReader txAgf1 = reader.GetGeometry("Geometry");
+ MgGeometry txGeom1 = agfRw.Read(txAgf1);
+ MgPoint txPt1 = (MgPoint)txGeom1;
+ Assert.IsTrue(txPt1 != null);
+ MgCoordinate txCoord1 = txPt1.GetCoordinate();
- MgByteReader txAgf2 = reader.GetGeometry("Geometry");
- MgGeometry txGeom2 = agfRw.Read(txAgf2);
- MgPoint txPt2 = (MgPoint)txGeom2;
- Assert.IsTrue(txPt2 != null);
- MgCoordinate txCoord2 = txPt2.GetCoordinate();
+ //TODO: Maybe we should really check that it matches the expected transformed result
+ Assert.IsTrue(txCoord1.GetX() != -37.1020);
+ Assert.IsTrue(txCoord1.GetY() != 144.0020);
- Assert.IsTrue(txCoord2.GetX() != -37.2020);
- Assert.IsTrue(txCoord2.GetY() != 144.2020);
- reader.Close();
+ MgByteReader txAgf2 = reader.GetGeometry("Geometry");
+ MgGeometry txGeom2 = agfRw.Read(txAgf2);
+ MgPoint txPt2 = (MgPoint)txGeom2;
+ Assert.IsTrue(txPt2 != null);
+ MgCoordinate txCoord2 = txPt2.GetCoordinate();
+ Assert.IsTrue(txCoord2.GetX() != -37.2020);
+ Assert.IsTrue(txCoord2.GetY() != 144.2020);
+ reader.Close();
+ finally
@@ -571,110 +1159,167 @@
+ try
+ props.Add(id);
+ props.Add(geom);
+ idProps.Add(id);
- props.Add(id);
- props.Add(geom);
- idProps.Add(id);
+ classes.Add(cls);
- classes.Add(cls);
- MgMapBase map = factory.CreateMap(srcWkt, new MgEnvelope(-180, -90, 180, 90), "TestMap");
+ MgMapBase map = factory.CreateMap(srcWkt, new MgEnvelope(-180, -90, 180, 90), "TestMap");
- string layerXml = string.Format(Properties.Resources.TestLayer, fsId.ToString(), "Default:Test", "Geometry");
+ string layerXml = string.Format(Properties.Resources.TestLayer, fsId.ToString(), "Default:Test", "Geometry");
- MgFeatureReader fr = layer.InsertFeatures(propVals);
- fr.Close();
+ MgFeatureReader fr = layer.InsertFeatures(propVals, null);
+ fr.Close();
- fr = layer.InsertFeatures(propVals);
- fr.Close();
+ fr = layer.InsertFeatures(propVals, null);
+ fr.Close();
- MgReader reader = layer.SelectFeatures(query, dstWkt);
+ MgReader reader = layer.SelectFeatures(query, dstWkt);
- reader.Close();
+ reader.Close();
+ finally
+ public class LayerGetSpatialContexts : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/GetSpatialContexts.FeatureSource");
+ try
+ MgSpatialContextReader scReader = layer.GetSpatialContexts(false);
+ int count = 0;
+ try
+ while (scReader.ReadNext())
+ Assert.AreEqual("Default", scReader.GetName());
+ Assert.AreEqual(csFactory.ConvertCoordinateSystemCodeToWkt("LL84"), scReader.GetCoordinateSystemWkt());
+ count++;
+ finally
+ scReader.Close();
+ finally
More information about the mapguide-commits
