[mapguide-commits] r8290 - branches/2.6/MgDev/Web/src/mapviewernet
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Jul 9 05:34:36 PDT 2014
Author: jng
Date: 2014-07-09 05:34:36 -0700 (Wed, 09 Jul 2014)
New Revision: 8290
Removed:
   branches/2.6/MgDev/Web/src/mapviewernet/setselection.aspx
   branches/2.6/MgDev/Web/src/mapviewernet/mapframe.aspx
#2465: Remove setselection.aspx and don't plug in this script reference in mapframe.aspx
Modified: branches/2.6/MgDev/Web/src/mapviewernet/mapframe.aspx
--- branches/2.6/MgDev/Web/src/mapviewernet/mapframe.aspx	2014-07-09 12:33:53 UTC (rev 8289)
+++ branches/2.6/MgDev/Web/src/mapviewernet/mapframe.aspx	2014-07-09 12:34:36 UTC (rev 8290)
@@ -179,7 +179,6 @@
                         bgColor,
                         hlTgt,
                         hlTgtName,
-                        vpath + "setselection.aspx",
                         showSlider != 0? "true": "false",
                         locale,
                         scaleCreationCode,
Deleted: branches/2.6/MgDev/Web/src/mapviewernet/setselection.aspx
--- branches/2.6/MgDev/Web/src/mapviewernet/setselection.aspx	2014-07-09 12:33:53 UTC (rev 8289)
+++ branches/2.6/MgDev/Web/src/mapviewernet/setselection.aspx	2014-07-09 12:34:36 UTC (rev 8290)
@@ -1,127 +0,0 @@
-Copyright (C) 2004-2011 by Autodesk, Inc.
-This library is free software; you can redistribute it and/or
-modify it under the terms of version 2.1 of the GNU Lesser
-General Public License as published by the Free Software Foundation.
-This library is distributed in the hope that it will be useful,
-but WITHOUT ANY WARRANTY; without even the implied warranty of
-MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-Lesser General Public License for more details.
-You should have received a copy of the GNU Lesser General Public
-License along with this library; if not, write to the Free Software
-Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-<%@ Page language="c#" validateRequest="false" %>
-<%@ Import Namespace="System" %>
-<%@ Import Namespace="System.IO" %>
-<%@ Import Namespace="System.Collections.Specialized" %>
-<%@ Import Namespace="System.Text" %>
-<%@ Import Namespace="OSGeo.MapGuide" %>
-<!-- #Include File="common.aspx -->
-<script runat="server">
-String mapName = "";
-String sessionId = "";
-String selText = "";
-bool queryInfo = false;
-</script>
-    Response.Charset = "utf-8";
-    Response.ContentType = "text/xml";
-    GetRequestParameters();
-    try
-        InitializeWebTier();
-        MgUserInformation cred = new MgUserInformation(sessionId);
-        cred.SetClientIp(GetClientIp(Request));
-        cred.SetClientAgent(GetClientAgent());
-        //connect to the site and get an instance of the resoucre service
-        MgSiteConnection site = new MgSiteConnection();
-        site.Open(cred);
-        MgResourceService resourceSrvc = (MgResourceService)site.CreateService(MgServiceType.ResourceService);
-        //load the map runtime state
-        MgMap map = new MgMap();
-        map.Open(resourceSrvc, mapName);
-        // Create the selection set and save it
-        MgSelection sel = new MgSelection(map);
-        if (selText != null && selText.Length > 0)
-            sel.FromXml(selText);
-        sel.Save(resourceSrvc, mapName);
-        if (queryInfo)
-            //Query feature info for the feature in the selection set. This will return the current set
-            //along with property info
-            //There must be only one feature in the feature set
-            MgReadOnlyLayerCollection layers = sel.GetLayers();
-            if (layers == null || layers.GetCount() != 1)
-                Response.Write("Error: There must be exactly one feature in the set."); ///NOXLATE dbg report only
-                return;
-            MgLayer layer = (MgLayer) layers.GetItem(0);
-            String featureClassName = layer.GetFeatureClassName();
-            String filter = sel.GenerateFilter(layer, featureClassName);
-            MgFeatureService featureSrvc = (MgFeatureService)site.CreateService(MgServiceType.FeatureService);
-            MgFeatureQueryOptions query = new MgFeatureQueryOptions();
-            query.SetFilter(filter);
-            MgResourceIdentifier featureSource = new MgResourceIdentifier(layer.GetFeatureSourceId());
-            MgFeatureReader features = featureSrvc.SelectFeatures(featureSource, featureClassName, query);
-            int featCount = 0;
-            while (features.ReadNext())
-                if (featCount++ == 1)
-                    break;
-            features.Close();
-            if (featCount != 1)
-                return;
-            MgRenderingService renderingSrvc = (MgRenderingService)site.CreateService(MgServiceType.RenderingService);
-            MgStringCollection layerNames = new MgStringCollection();
-            layerNames.Add(layer.GetName());
-            MgFeatureInformation featInfo = renderingSrvc.QueryFeatures(map, layerNames, null, MgFeatureSpatialOperations.Intersects, selText, 1, 2);
-            Response.Write(featInfo.ToXml().ToString());
-    catch (MgException e)
-        Response.Write("\nSetSelection Exception: " + e.GetDetails());
-void GetRequestParameters()
-    if(Request.HttpMethod == "POST")
-        GetParameters(Request.Form);
-    else
-        GetParameters(Request.QueryString);
-void GetParameters(NameValueCollection parameters)
-    sessionId = ValidateSessionId(GetParameter(parameters, "SESSION"));
-    mapName = ValidateMapName(GetParameter(parameters, "MAPNAME"));
-    if(IsParameter(parameters, "QUERYINFO"))
-        queryInfo = GetIntParameter(parameters, "QUERYINFO") == 1;
-    selText = GetParameter(parameters, "SELECTION");
-</script>
More information about the mapguide-commits mailing list
