[mapguide-commits] r8292 - branches/2.6/MgDev/Web/src/mapviewerjava
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Jul 9 05:36:10 PDT 2014
Author: jng
Date: 2014-07-09 05:36:10 -0700 (Wed, 09 Jul 2014)
New Revision: 8292
Removed:
   branches/2.6/MgDev/Web/src/mapviewerjava/setselection.jsp
   branches/2.6/MgDev/Web/src/mapviewerjava/mapframe.jsp
#2465: Remove setselection.jsp and don't plug in this script reference in mapframe.jsp
Modified: branches/2.6/MgDev/Web/src/mapviewerjava/mapframe.jsp
--- branches/2.6/MgDev/Web/src/mapviewerjava/mapframe.jsp	2014-07-09 12:34:58 UTC (rev 8291)
+++ branches/2.6/MgDev/Web/src/mapviewerjava/mapframe.jsp	2014-07-09 12:36:10 UTC (rev 8292)
@@ -177,7 +177,6 @@
                     bgColor,
                     hlTgt,
                     hlTgtName,
-                    vpath + "setselection.jsp",
                     showSlider != 0? "true": "false",
                     locale,
                     scaleCreationCode,
Deleted: branches/2.6/MgDev/Web/src/mapviewerjava/setselection.jsp
--- branches/2.6/MgDev/Web/src/mapviewerjava/setselection.jsp	2014-07-09 12:34:58 UTC (rev 8291)
+++ branches/2.6/MgDev/Web/src/mapviewerjava/setselection.jsp	2014-07-09 12:36:10 UTC (rev 8292)
@@ -1,122 +0,0 @@
-  -Copyright (C) 2004-2011 by Autodesk, Inc.
-  -This library is free software; you can redistribute it and/or
-  -modify it under the terms of version 2.1 of the GNU Lesser
-  -General Public License as published by the Free Software Foundation.
-  -This library is distributed in the hope that it will be useful,
-  -but WITHOUT ANY WARRANTY; without even the implied warranty of
-  -MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-  -Lesser General Public License for more details.
-  -You should have received a copy of the GNU Lesser General Public
-  -License along with this library; if not, write to the Free Software
-  -Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-<%@ page contentType="text/html; charset=UTF-8" pageEncoding="UTF-8" %>
-<%@ page import="org.osgeo.mapguide.*" %>
-<%@ page import="java.util.*" %>
-<%@ page import="java.io.*" %>
-<%@ page import="java.text.*" %>
-<%@ page import="javax.servlet.jsp.*" %>
-<%@ page import="javax.servlet.http.*" %>
-<%@ include file="common.jsp" %>
-<%@ page isThreadSafe="false" %>
-String mapName = "";
-String sessionId = "";
-String selText = "";
-boolean queryInfo;
-response.setContentType("text/xml; charset=UTF-8");
-request.setCharacterEncoding("UTF-8");
-mapName = sessionId = selText = "";
-queryInfo = false;
-//fetch the parameters for this request
-GetRequestParameters(request);
-try
-    InitializeWebTier();
-    MgUserInformation cred = new MgUserInformation(sessionId);
-    cred.SetClientIp(GetClientIp(request));
-    cred.SetClientAgent(GetClientAgent());
-    //connect to the site and get an instance of the resource service
-    MgSiteConnection site = new MgSiteConnection();
-    site.Open(cred);
-    MgResourceService resourceSrvc = (MgResourceService)site.CreateService(MgServiceType.ResourceService);
-    //load the map runtime state
-    MgMap map = new MgMap();
-    map.Open(resourceSrvc, mapName);
-    // Create the selection set and save it
-    MgSelection sel = new MgSelection(map);
-    if(selText != null && selText.length() > 0)
-        sel.FromXml(selText);
-    sel.Save(resourceSrvc, mapName);
-    if(queryInfo) {
-        //Query feature info for the feature in the selection set. This will return the current set
-        //along with property info
-        //There must be only one feature in the feature set
-        MgReadOnlyLayerCollection layers = sel.GetLayers();
-        if(layers == null && layers.GetCount() != 1) {
-            response.getWriter().write("Error: There must be exactly one feature in the set."); ///NOXLATE dbg report only
-            return;
-        MgLayer layer = (MgLayer) layers.GetItem(0);
-        String featureClassName = layer.GetFeatureClassName();
-        String filter = sel.GenerateFilter(layer, featureClassName);
-        MgFeatureService featureSrvc = (MgFeatureService)site.CreateService(MgServiceType.FeatureService);
-        MgFeatureQueryOptions query = new MgFeatureQueryOptions();
-        query.SetFilter(filter);
-        MgResourceIdentifier featureSource = new MgResourceIdentifier(layer.GetFeatureSourceId());
-        MgFeatureReader features = featureSrvc.SelectFeatures(featureSource, featureClassName, query);
-        int featCount = 0;
-        while(features.ReadNext()) {
-            if(featCount++ == 1)
-                break;
-        features.Close();
-        if(featCount != 1) {
-            return;
-        MgRenderingService renderingSrvc = (MgRenderingService)site.CreateService(MgServiceType.RenderingService);
-        MgStringCollection layerNames = new MgStringCollection();
-        layerNames.Add(layer.GetName());
-        MgFeatureInformation featInfo = renderingSrvc.QueryFeatures(map, layerNames, null, MgFeatureSpatialOperations.Intersects, selText, 1, 2);
-        response.getWriter().write(featInfo.ToXml().ToString());
-catch(MgException e)
-    response.getWriter().write("\nClearSelection Exception: " + e.GetDetails());
-catch(Exception e)
-void GetRequestParameters(HttpServletRequest request)
-    sessionId = ValidateSessionId(GetParameter(request, "SESSION"));
-    mapName = ValidateMapName(GetParameter(request, "MAPNAME"));
-    queryInfo = (GetIntParameter(request, "QUERYINFO") == 1);
-    selText = GetParameter(request, "SELECTION");
More information about the mapguide-commits mailing list
