[mapguide-commits] r8299 - in branches/2.6/MgDev: Doc/devguide/source Doc/samples/dotnetsamples Doc/samples/dotnetsamples/working_with_feature_data Doc/samples/phpsamples Doc/samples/phpsamples/working_with_feature_data UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced
svn_mapguide at osgeo.org
Thu Jul 10 04:54:30 PDT 2014
Author: jng
Date: 2014-07-10 04:54:30 -0700 (Thu, 10 Jul 2014)
New Revision: 8299
branches/2.6/MgDev/Doc/devguide/source/revision_history.rst
branches/2.6/MgDev/Doc/devguide/source/working_with_feature_data.rst
branches/2.6/MgDev/Doc/samples/dotnetsamples/readme.txt
branches/2.6/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/queryfeatures.aspx
branches/2.6/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/selectfeatures.aspx
branches/2.6/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/task_pane.aspx
branches/2.6/MgDev/Doc/samples/phpsamples/readme.txt
branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/listselection.php
branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php
branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php
branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/task_pane.php
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml
branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml
#2466: Fix VotingDistricts layer in Sheboygan sample. The id used does not match the description of the feature. This submission fixes the Layer Definitions to use the correct ID.
Also, the developer's guide has been updated to use the correct district ID. Also the district number used in the example has been changed from 1 to 6 as going through each section of the samples sequentially produces more visible changes with district 6 instead of district 1.
Modified: branches/2.6/MgDev/Doc/devguide/source/revision_history.rst
--- branches/2.6/MgDev/Doc/devguide/source/revision_history.rst 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/Doc/devguide/source/revision_history.rst 2014-07-10 11:54:30 UTC (rev 8299)
@@ -10,6 +10,9 @@
| Version | Authors | Date | Summary of Changes |
+| 2.0.1 | Jackie Ng | Jul 2014 | Updated code sample in section "Working with Feature Data" |
+| | | | to reflect the updated Sheboygan sample data set |
| 2.0 | Jackie Ng | | First version of developer's guide in source form |
| | | | Added .net and Java code samples to match PHP examples |
Modified: branches/2.6/MgDev/Doc/devguide/source/working_with_feature_data.rst
--- branches/2.6/MgDev/Doc/devguide/source/working_with_feature_data.rst 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/Doc/devguide/source/working_with_feature_data.rst 2014-07-10 11:54:30 UTC (rev 8299)
@@ -328,7 +328,7 @@
``MgAgfReaderWriter::Read()`` method.
For example, the following sequence creates an ``MgGeometry`` object representing
-the boundaries of District 1 in the Sheboygan sample data.
+the boundaries of District 6 in the Sheboygan sample data.
**PHP**
@@ -336,11 +336,11 @@
.. code-block:: php
$districtQuery = new MgFeatureQueryOptions();
- $districtQuery->SetFilter("Autogenerated_SDF_ID = 1");
+ $districtQuery->SetFilter("ID = '1'");
$layer = $map->GetLayers()->GetItem('Districts');
$featureReader = $layer->SelectFeatures($districtQuery);
$featureReader->ReadNext();
- $districtGeometryData = $featureReader->GetGeometry('Data');
+ $districtGeometryData = $featureReader->GetGeometry($layer->GetFeatureGeometryName());
$agfReaderWriter = new MgAgfReaderWriter();
$districtGeometry = $agfReaderWriter->Read($districtGeometryData);
@@ -351,11 +351,11 @@
//This code fragment assumes you have imported the OSGeo.MapGuide namespace
MgFeatureQueryOptions districtQuery = new MgFeatureQueryOptions();
- districtQuery.SetFilter("Autogenerated_SDF_ID = 1");
+ districtQuery.SetFilter("ID = '1'");
MgLayer layer = (MgLayer)map.GetLayers().GetItem("Districts");
MgFeatureReader featureReader = layer.SelectFeatures(districtQuery);
featureReader.ReadNext();
- MgByteReader districtGeometryData = featureReader.GetGeometry("Data");
+ MgByteReader districtGeometryData = featureReader.GetGeometry(layer.GetFeatureGeometryName());
MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
MgGeometry districtGeometry = agfReaderWriter.Read(districtGeometryData);
@@ -370,7 +370,7 @@
@@ -467,7 +467,7 @@
selected features. See the Working With Feature Data sample, in the Developer's
Guide samples, for the complete version.
-It selects parcels within the boundaries of District 1 that are owned by
+It selects parcels within the boundaries of District 6 that are owned by
``SCHMITT``. This requires a spatial filter and a basic filter.
**PHP**
@@ -478,15 +478,15 @@
$map = new MgMap($siteConnection);
$map->Open($mapName);
- // Get the geometry for the boundaries of District 1
+ // Get the geometry for the boundaries of District 6
+ $districtQuery->SetFilter("ID = '6'");
$featureReader->Close();
// Convert the AGF binary data to MgGeometry.
@@ -511,7 +511,7 @@
// For each selected feature, display the address.
echo '<p>Properties owned by Schmitt ';
- echo 'in District 1</p><p>';
+ echo 'in District 6</p><p>';
while ($featureReader->ReadNext())
@@ -530,14 +530,14 @@
MgMap map = new MgMap(siteConnection);
map.Open(mapName);
+ districtQuery.SetFilter("ID = '6'");
featureReader.Close();
@@ -558,7 +558,7 @@
Response.Write("<p>Properties owned by Schmitt ");
- Response.Write("in District 1</p><p>");
+ Response.Write("in District 6</p><p>");
while (featureReader.ReadNext())
@@ -577,14 +577,14 @@
map.Open(mapName);
@@ -605,7 +605,7 @@
response.getWriter().write("<p>Properties owned by Schmitt ");
- response.getWriter().write("in District 1</p><p>");
+ response.getWriter().write("in District 6</p><p>");
@@ -1014,15 +1014,15 @@
@@ -1093,17 +1093,17 @@
map.Open(mapName);
MgLayerBase layer = map.GetLayers().GetItem("Districts");
MgByteReader districtGeometryData = null;
try {
- districtGeometryData = featureReader.GetGeometry("Data");
+ districtGeometryData = featureReader.GetGeometry(layer.GetFeatureGeometryName());
} finally { //Ensures the reader is closed regardless
Modified: branches/2.6/MgDev/Doc/samples/dotnetsamples/readme.txt
--- branches/2.6/MgDev/Doc/samples/dotnetsamples/readme.txt 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/Doc/samples/dotnetsamples/readme.txt 2014-07-10 11:54:30 UTC (rev 8299)
@@ -6,6 +6,9 @@
Notes
+You must use the Sheboygan sample data set that was released with MapGuide Open Source 2.6 or newer. This dataset has been updated and
+these samples have been updated to work against this version of the data set.
These samples assume that MapGuide Open Source is installed in the default location in
C:\Program Files\OSGeo\MapGuide
Modified: branches/2.6/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/queryfeatures.aspx
--- branches/2.6/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/queryfeatures.aspx 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/queryfeatures.aspx 2014-07-10 11:54:30 UTC (rev 8299)
@@ -62,17 +62,17 @@
map.Open(mapName);
try {
} finally { //Ensures this block is always run
@@ -98,7 +98,7 @@
try {
Modified: branches/2.6/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/selectfeatures.aspx
--- branches/2.6/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/selectfeatures.aspx 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/selectfeatures.aspx 2014-07-10 11:54:30 UTC (rev 8299)
@@ -62,17 +62,17 @@
map.Open(mapName);
try {
@@ -99,7 +99,7 @@
selection.AddFeatures(layer, featureReader, 0);
selectionXml = selection.ToXml();
- Response.Write("Selecting parcels owned by Schmitt in District 1");
+ Response.Write("Selecting parcels owned by Schmitt in District 6");
catch (MgException e)
Modified: branches/2.6/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/task_pane.aspx
--- branches/2.6/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/task_pane.aspx 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/Doc/samples/dotnetsamples/working_with_feature_data/task_pane.aspx 2014-07-10 11:54:30 UTC (rev 8299)
@@ -34,7 +34,7 @@
<script language="javascript">
function ZoomToDistrict()
- parent.parent.ZoomToView(-87.726134, 43.770338, 8000, true);
+ parent.parent.ZoomToView(-87.727698, 43.735028, 8000, true);
function listSelection()
@@ -57,12 +57,12 @@
<ul>
<li>
- <a href="#" onclick="ZoomToDistrict();" >Zoom to District 1</a>
- <br />Position the map to display parcels in District 1
+ <a href="#" onclick="ZoomToDistrict();" >Zoom to District 6</a>
+ <br />Position the map to display parcels in District 6
</li>
<li>
<a href="queryfeatures.aspx?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>" >Query features</a>
- <br />List properties in District 1 owned by Schmitt
+ <br />List properties in District 6 owned by Schmitt
<br/>
String fullPath = Server.MapPath("queryfeatures.aspx");
@@ -71,7 +71,7 @@
</li>
<li>
<a href="selectfeatures.aspx?SESSION=<%= sessionId %>&MAPNAME=<%= mapName %>" >Set active selection</a>
- <br />Select properties in District 1 owned by Schmitt
+ <br />Select properties in District 6 owned by Schmitt
<br/>
fullPath = Server.MapPath("selectfeatures.aspx");
Modified: branches/2.6/MgDev/Doc/samples/phpsamples/readme.txt
--- branches/2.6/MgDev/Doc/samples/phpsamples/readme.txt 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/Doc/samples/phpsamples/readme.txt 2014-07-10 11:54:30 UTC (rev 8299)
@@ -6,6 +6,9 @@
Notes
Modified: branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/listselection.php
--- branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/listselection.php 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/listselection.php 2014-07-10 11:54:30 UTC (rev 8299)
@@ -110,6 +110,7 @@
$val = $featureReader->GetString('NAME') . '<br /> ' . $featureReader->GetString('RPROPAD');
echo $val . '<br />';
+ $featureReader->Close();
Modified: branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php
--- branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php 2014-07-10 11:54:30 UTC (rev 8299)
@@ -53,16 +53,15 @@
+ $districtQuery->SetFilter("ID = '6'"); //ID property is string
- GetGeometry('Data');
@@ -88,13 +87,14 @@
$val = $featureReader->GetString('RPROPAD');
echo '</p>';
catch (MgException $e)
Modified: branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php
--- branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php 2014-07-10 11:54:30 UTC (rev 8299)
@@ -55,22 +55,15 @@
- // Use the layer's class definition to determine its identity property and geometry property name
- $clsDef = $layer->GetClassDefinition();
- $idProps = $clsDef->GetIdentityProperties();
- $idProp = $idProps->GetItem(0);
- $idName = $idProp->GetName();
- $geomName = $clsDef->GetDefaultGeometryPropertyName();
- $districtQuery->SetFilter("$idName = 1");
- $districtGeometryData = $featureReader->GetGeometry($geomName);
@@ -95,7 +88,7 @@
$selection->AddFeatures($layer, $featureReader, 0);
$selectionXml = $selection->ToXml();
- echo 'Selecting parcels owned by Schmitt in District 1';
+ echo 'Selecting parcels owned by Schmitt in District 6';
Modified: branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/task_pane.php
--- branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/task_pane.php 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/Doc/samples/phpsamples/working_with_feature_data/task_pane.php 2014-07-10 11:54:30 UTC (rev 8299)
@@ -24,7 +24,7 @@
@@ -48,12 +48,12 @@
<ul>
<li>
</li>
<li>
<a href="queryfeatures.php?SESSION=<?= $sessionId ?>&MAPNAME=<?= $mapName ?>" >Query features</a>
<br/>
<?php
$fileName = 'queryfeatures.php';
@@ -64,7 +64,7 @@
</li>
<li>
<a href="selectfeatures.php?SESSION=<?= $sessionId ?>&MAPNAME=<?= $mapName ?>" >Set active selection</a>
<br/>
<?php
$fileName = 'selectfeatures.php';
Modified: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers/Districts.LayerDefinition_CONTENT.xml 2014-07-10 11:54:30 UTC (rev 8299)
@@ -1,4 +1,4 @@
-<?xml version="1.0" encoding="UTF-8"?>
+<?xml version="1.0" encoding="utf-8"?>
<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="1.0.0" xsi:noNamespaceSchemaLocation="LayerDefinition-1.0.0.xsd">
<VectorLayerDefinition>
<ResourceId>Library://Samples/Sheboygan/Data/VotingDistricts.FeatureSource</ResourceId>
@@ -9,13 +9,13 @@
<MinScale>10000</MinScale>
<AreaTypeStyle>
<AreaRule>
- <LegendLabel/>
+ <LegendLabel />
<Label>
<Unit>Points</Unit>
<SizeContext>DeviceUnits</SizeContext>
<SizeX>0</SizeX>
<SizeY>10</SizeY>
- <Text>concat('District ', FeatId)</Text>
+ <Text>concat('District ', ID)</Text>
<FontName>Verdana</FontName>
<ForegroundColor>FF625231</ForegroundColor>
<BackgroundColor>FFFFFFFF</BackgroundColor>
Modified: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml
--- branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml 2014-07-09 14:11:44 UTC (rev 8298)
+++ branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Layers_Advanced/Districts.LayerDefinition_CONTENT.xml 2014-07-10 11:54:30 UTC (rev 8299)
@@ -1,8 +1,8 @@
<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0" xsi:noNamespaceSchemaLocation="LayerDefinition-2.4.0.xsd">
- <Watermarks/>
+ <Watermarks />
<FeatureName>Default:VotingDistricts</FeatureName>
<FeatureNameType>FeatureClass</FeatureNameType>
<Geometry>Geometry</Geometry>
@@ -10,7 +10,7 @@
<CompositeTypeStyle>
<CompositeRule>
- <LegendLabel/>
+ <LegendLabel />
<CompositeSymbolization>
<SymbolInstance>
<SimpleSymbolDefinition>
@@ -192,21 +192,21 @@
</Parameter>
<Parameter>
<Identifier>GHOSTCOLOR</Identifier>
- <DefaultValue/>
+ <DefaultValue />
<DisplayName>Ghost Color</DisplayName>
<Description>Ghost Color</Description>
<DataType>GhostColor</DataType>
</Parameter>
<Parameter>
<Identifier>FRAMELINECOLOR</Identifier>
- <DefaultValue/>
+ <DefaultValue />
<DisplayName>Frame Line Color</DisplayName>
<Description>Frame Line Color</Description>
<DataType>FrameLineColor</DataType>
</Parameter>
<Parameter>
<Identifier>FRAMEFILLCOLOR</Identifier>
- <DefaultValue/>
+ <DefaultValue />
<DisplayName>Frame Fill Color</DisplayName>
<Description>Frame Fill Color</Description>
<DataType>FrameFillColor</DataType>
@@ -259,7 +259,7 @@
<Override>
<SymbolName>MTEXT</SymbolName>
<ParameterIdentifier>CONTENT</ParameterIdentifier>
- <ParameterValue>Concat('District ', FeatId)</ParameterValue>
+ <ParameterValue>Concat('District ', ID)</ParameterValue>
</Override>
<Override>
More information about the mapguide-commits
