[mapguide-commits] r8178 - in sandbox/jng/tiling/Common: MdfModel MdfParser Schema
svn_mapguide at osgeo.org
Mon Jun 2 13:34:20 PDT 2014
Author: jng
Date: 2014-06-02 13:34:20 -0700 (Mon, 02 Jun 2014)
New Revision: 8178
sandbox/jng/tiling/Common/MdfModel/TileStoreParameters.cpp
sandbox/jng/tiling/Common/MdfModel/TileStoreParameters.h
sandbox/jng/tiling/Common/MdfParser/IOBaseMapLayerGroup.cpp
sandbox/jng/tiling/Common/MdfParser/IONameStringPair.cpp
sandbox/jng/tiling/Common/MdfParser/IOTileStoreParameters.cpp
sandbox/jng/tiling/Common/MdfParser/SAX2Parser.cpp
sandbox/jng/tiling/Common/Schema/MapDefinition-3.0.0.xsd
sandbox/jng/tiling/Common/Schema/TileSetDefinition-3.0.0.xsd
MdfModel/MdfParser/Schema updates
- Fix TileSetDefinition not being read by SAX2Parser
- Fix BaseMapLayerGroup instances not being attached to TileSetDefinition
- Fix NameStringPair instances not being attached to TileStoreParameters
- Rename ImageFormat to Format in TileSetDefinition-3.0.0.xsd
- Fix incorrect version in MapDefinition-3.0.0.xsd
Modified: sandbox/jng/tiling/Common/MdfModel/TileStoreParameters.cpp
--- sandbox/jng/tiling/Common/MdfModel/TileStoreParameters.cpp 2014-05-30 15:31:40 UTC (rev 8177)
+++ sandbox/jng/tiling/Common/MdfModel/TileStoreParameters.cpp 2014-06-02 20:34:20 UTC (rev 8178)
@@ -18,7 +18,7 @@
#include "TileStoreParameters.h"
TileStoreParameters::TileStoreParameters()
- : m_imageFormat(L"PNG"),
+ : m_format(L"PNG"),
m_width(300),
m_height(300)
@@ -70,13 +70,13 @@
this->m_height = height;
-// Property : ImageFormat
-const MdfString& TileStoreParameters::GetImageFormat() const
+// Property : Format
+const MdfString& TileStoreParameters::GetFormat() const
- return this->m_imageFormat;
+ return this->m_format;
-void TileStoreParameters::SetImageFormat(const MdfString &imageFormat)
+void TileStoreParameters::SetFormat(const MdfString &format)
- this->m_imageFormat = imageFormat;
+ this->m_format = format;
\ No newline at end of file
Modified: sandbox/jng/tiling/Common/MdfModel/TileStoreParameters.h
--- sandbox/jng/tiling/Common/MdfModel/TileStoreParameters.h 2014-05-30 15:31:40 UTC (rev 8177)
+++ sandbox/jng/tiling/Common/MdfModel/TileStoreParameters.h 2014-06-02 20:34:20 UTC (rev 8178)
@@ -45,9 +45,9 @@
int GetTileHeight() const;
void SetTileHeight(const int &height);
- // Property : ImageFormat
- const MdfString& GetImageFormat() const;
- void SetImageFormat(const MdfString &imageFormat);
+ // Property : Format
+ const MdfString& GetFormat() const;
+ void SetFormat(const MdfString &format);
private:
@@ -58,7 +58,7 @@
int m_width;
int m_height;
MdfString m_provider;
- MdfString m_imageFormat;
+ MdfString m_format;
NameStringPairCollection m_parameters;
Modified: sandbox/jng/tiling/Common/MdfParser/IOBaseMapLayerGroup.cpp
--- sandbox/jng/tiling/Common/MdfParser/IOBaseMapLayerGroup.cpp 2014-05-30 15:31:40 UTC (rev 8177)
+++ sandbox/jng/tiling/Common/MdfParser/IOBaseMapLayerGroup.cpp 2014-06-02 20:34:20 UTC (rev 8178)
@@ -91,7 +91,14 @@
if (this->m_startElemName == name)
this->m_layerGroup->SetUnknownXml(this->m_unknownXml);
- this->m_map->GetBaseMapLayerGroups()->Adopt(static_cast<BaseMapLayerGroup*>(this->m_layerGroup));
+ if (NULL != this->m_map)
+ this->m_map->GetBaseMapLayerGroups()->Adopt(static_cast<BaseMapLayerGroup*>(this->m_layerGroup));
+ else if (NULL != this->m_tileset)
+ this->m_tileset->GetBaseMapLayerGroups()->Adopt(static_cast<BaseMapLayerGroup*>(this->m_layerGroup));
this->m_map = NULL;
this->m_layerGroup = NULL;
this->m_startElemName = L"";
Modified: sandbox/jng/tiling/Common/MdfParser/IONameStringPair.cpp
--- sandbox/jng/tiling/Common/MdfParser/IONameStringPair.cpp 2014-05-30 15:31:40 UTC (rev 8177)
+++ sandbox/jng/tiling/Common/MdfParser/IONameStringPair.cpp 2014-06-02 20:34:20 UTC (rev 8178)
@@ -94,7 +94,7 @@
ParseUnknownXml(name, handlerStack);
- else if (this->m_featureSource)
+ else if (this->m_featureSource || this->m_tileStoreParams)
if (this->m_currElemName == L"Parameter") // NOXLATE
@@ -138,6 +138,8 @@
this->m_layer->GetPropertyMappings()->Adopt(this->m_nameStringPair);
this->m_featureSource->GetParameters()->Adopt(this->m_nameStringPair);
+ else if (this->m_tileStoreParams)
+ this->m_tileStoreParams->GetParameters()->Adopt(this->m_nameStringPair);
this->m_layer = NULL;
this->m_featureSource = NULL;
Modified: sandbox/jng/tiling/Common/MdfParser/IOTileStoreParameters.cpp
--- sandbox/jng/tiling/Common/MdfParser/IOTileStoreParameters.cpp 2014-05-30 15:31:40 UTC (rev 8177)
+++ sandbox/jng/tiling/Common/MdfParser/IOTileStoreParameters.cpp 2014-06-02 20:34:20 UTC (rev 8178)
@@ -72,9 +72,9 @@
int val = wstrToInt(ch);
this->m_params->SetTileHeight(val);
- else if (this->m_currElemName == L"ImageFormat") // NOXLATE
+ else if (this->m_currElemName == L"Format") // NOXLATE
- this->m_params->SetImageFormat(ch);
+ this->m_params->SetFormat(ch);
@@ -109,10 +109,10 @@
fd << IntToStr(params->GetTileHeight());
fd << endStr("TileHeight") << std::endl; //NOXLATE
- // Property: ImageFormat
- fd << tab.tab() << startStr("ImageFormat"); //NOXLATE
- fd << EncodeString(params->GetTileProvider());
- fd << endStr("ImageFormat") << std::endl; //NOXLATE
+ // Property: Format
+ fd << tab.tab() << startStr("Format"); //NOXLATE
+ fd << EncodeString(params->GetFormat());
+ fd << endStr("Format") << std::endl; //NOXLATE
// Property: Parameters
for (int i=0; i<params->GetParameters()->GetCount(); ++i)
Modified: sandbox/jng/tiling/Common/MdfParser/SAX2Parser.cpp
--- sandbox/jng/tiling/Common/MdfParser/SAX2Parser.cpp 2014-05-30 15:31:40 UTC (rev 8177)
+++ sandbox/jng/tiling/Common/MdfParser/SAX2Parser.cpp 2014-06-02 20:34:20 UTC (rev 8178)
@@ -680,6 +680,17 @@
m_handlerStack->push(IO);
IO->StartElement(str.c_str(), m_handlerStack);
+ else if (str == L"TileSetDefinition") // NOXLATE
+ // set the version
+ SetTileSetDefinitionVersion(attributes);
+ _ASSERT(m_map == NULL); // otherwise we leak
+ m_tileset = new TileSetDefinition(L"");
+ IOTileSetDefinition* IO = new IOTileSetDefinition(m_tileset, m_version);
+ m_handlerStack->push(IO);
+ IO->StartElement(str.c_str(), m_handlerStack);
// Otherwise, if the stack has items on it, just pass the event through.
else
Modified: sandbox/jng/tiling/Common/Schema/MapDefinition-3.0.0.xsd
--- sandbox/jng/tiling/Common/Schema/MapDefinition-3.0.0.xsd 2014-05-30 15:31:40 UTC (rev 8177)
+++ sandbox/jng/tiling/Common/Schema/MapDefinition-3.0.0.xsd 2014-06-02 20:34:20 UTC (rev 8178)
@@ -253,7 +253,7 @@
<xs:complexType>
<xs:complexContent>
<xs:extension base="MapDefinitionType">
- <xs:attribute name="version" type="xs:string" use="required" fixed="2.4.0"/>
+ <xs:attribute name="version" type="xs:string" use="required" fixed="3.0.0"/>
</xs:extension>
</xs:complexContent>
</xs:complexType>
Modified: sandbox/jng/tiling/Common/Schema/TileSetDefinition-3.0.0.xsd
--- sandbox/jng/tiling/Common/Schema/TileSetDefinition-3.0.0.xsd 2014-05-30 15:31:40 UTC (rev 8177)
+++ sandbox/jng/tiling/Common/Schema/TileSetDefinition-3.0.0.xsd 2014-06-02 20:34:20 UTC (rev 8178)
@@ -1,6 +1,7 @@
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
- <xs:element name="TileSetDefinition" minOccurs="0">
+ <xs:include schemaLocation="PlatformCommon-1.0.0.xsd"/>
+ <xs:element name="TileSetDefinition">
<xs:annotation>
<xs:documentation>Defines a tile cache</xs:documentation>
</xs:annotation>
@@ -54,9 +55,9 @@
<xs:documentation>The height of tile images in this tile cache</xs:documentation>
</xs:annotation>
</xs:element>
- <xs:element name="ImageFormat" type="xs:string">
+ <xs:element name="Format" type="xs:string">
<xs:annotation>
- <xs:documentation>The image format of tile images in this tile cache</xs:documentation>
+ <xs:documentation>The format of tiles in this tile cache</xs:documentation>
</xs:annotation>
</xs:element>
<xs:element name="Parameter" type="NameValuePairType" minOccurs="0" maxOccurs="unbounded">
More information about the mapguide-commits
