[mapguide-commits] r8188 - in trunk/Tools/Maestro/SDK/Samples: DrawMap DwfInspector MapViewer QueryFeatureSource SchemaViewer StandaloneWebLayoutEditor
svn_mapguide at osgeo.org
Mon Jun 9 06:12:17 PDT 2014
Author: jng
Date: 2014-06-09 06:12:17 -0700 (Mon, 09 Jun 2014)
New Revision: 8188
trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs
trunk/Tools/Maestro/SDK/Samples/DwfInspector/Form1.cs
trunk/Tools/Maestro/SDK/Samples/MapViewer/Form1.cs
trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs
trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs
trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Form1.cs
Fix SDK samples in light of r8187
Modified: trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs 2014-06-09 13:09:04 UTC (rev 8187)
+++ trunk/Tools/Maestro/SDK/Samples/DrawMap/Form1.cs 2014-06-09 13:12:17 UTC (rev 8188)
@@ -112,7 +112,7 @@
//The ResourcePicker class, functions like a file dialog allowing the user
//to easily select a given resource. In our case, we want the user to select
//a Map Definition
- using (var picker = new ResourcePicker(_conn.ResourceService,
+ using (var picker = new ResourcePicker(_conn,
ResourceTypes.MapDefinition.ToString(),
ResourcePickerMode.OpenResource))
Modified: trunk/Tools/Maestro/SDK/Samples/DwfInspector/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/DwfInspector/Form1.cs 2014-06-09 13:09:04 UTC (rev 8187)
+++ trunk/Tools/Maestro/SDK/Samples/DwfInspector/Form1.cs 2014-06-09 13:12:17 UTC (rev 8188)
@@ -96,7 +96,7 @@
//a Drawing Source
ResourceTypes.DrawingSource.ToString(),
Modified: trunk/Tools/Maestro/SDK/Samples/MapViewer/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/MapViewer/Form1.cs 2014-06-09 13:09:04 UTC (rev 8187)
+++ trunk/Tools/Maestro/SDK/Samples/MapViewer/Form1.cs 2014-06-09 13:12:17 UTC (rev 8188)
@@ -71,7 +71,7 @@
//a Map Definition
Modified: trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs 2014-06-09 13:09:04 UTC (rev 8187)
+++ trunk/Tools/Maestro/SDK/Samples/QueryFeatureSource/Form1.cs 2014-06-09 13:12:17 UTC (rev 8188)
@@ -134,7 +134,7 @@
//a Map Definition
ResourceTypes.FeatureSource.ToString(),
Modified: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs 2014-06-09 13:09:04 UTC (rev 8187)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs 2014-06-09 13:12:17 UTC (rev 8188)
@@ -69,7 +69,7 @@
//a Feature Source
Modified: trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Form1.cs 2014-06-09 13:09:04 UTC (rev 8187)
+++ trunk/Tools/Maestro/SDK/Samples/StandaloneWebLayoutEditor/Form1.cs 2014-06-09 13:12:17 UTC (rev 8188)
@@ -80,7 +80,7 @@
//a Feature Source
ResourceTypes.WebLayout.ToString(),
More information about the mapguide-commits
