[mapguide-commits] r8191 - sandbox/jng/tiling/Server/src/Services/Tile
svn_mapguide at osgeo.org
Mon Jun 9 15:57:56 PDT 2014
Author: jng
Date: 2014-06-09 15:57:56 -0700 (Mon, 09 Jun 2014)
New Revision: 8191
Added:
sandbox/jng/tiling/Server/src/Services/Tile/TileCacheXYZProvider.cpp
sandbox/jng/tiling/Server/src/Services/Tile/TileCacheXYZProvider.h
sandbox/jng/tiling/Server/src/Services/Tile/TileCacheDefault.h
Add missing XYZ tile provider source from previous submission and use a cleaner directory structure for XYZ tiles, which is <basepath>/<group>/<z>/<x>/<y>.<format>
Modified: sandbox/jng/tiling/Server/src/Services/Tile/TileCacheDefault.h
--- sandbox/jng/tiling/Server/src/Services/Tile/TileCacheDefault.h 2014-06-09 22:32:06 UTC (rev 8190)
+++ sandbox/jng/tiling/Server/src/Services/Tile/TileCacheDefault.h 2014-06-09 22:57:56 UTC (rev 8191)
@@ -65,6 +65,8 @@
virtual MgByteReader* RenderAndCacheTile(CREFSTRING tilePathname, MgMap* map, INT32 scaleIndex, CREFSTRING baseMapLayerGroupName, INT32 tileColumn, INT32 tileRow);
+ virtual STRING GetTileName(int tileRow, int tileColumn);
MgByteReader* GetTileForResource(MgResourceIdentifier* resource,
INT32 tileColumn,
@@ -95,7 +97,6 @@
STRING GetColumnFolder(int tileColumn);
STRING GetFolder(STRING prefix, int tileIndex, int tilesPerFolder);
- STRING GetTileName(int tileRow, int tileColumn);
STRING GetTileIndexString(int tileIndex, int tilesPerFolder);
MgResourceService* GetResourceServiceForMapDef(MgResourceIdentifier* mapDefinition, CREFSTRING funcName);
Added: sandbox/jng/tiling/Server/src/Services/Tile/TileCacheXYZProvider.cpp
--- sandbox/jng/tiling/Server/src/Services/Tile/TileCacheXYZProvider.cpp (rev 0)
+++ sandbox/jng/tiling/Server/src/Services/Tile/TileCacheXYZProvider.cpp 2014-06-09 22:57:56 UTC (rev 8191)
@@ -0,0 +1,165 @@
+// Copyright (C) 2004-2014 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "MapGuideCommon.h"
+#include "TileCacheXYZProvider.h"
+MgTileCacheXYZProvider::MgTileCacheXYZProvider(MgResourceIdentifier* tileSetId, CREFSTRING path, CREFSTRING format, bool bRenderOnly)
+ m_tilesetId = SAFE_ADDREF(tileSetId);
+ m_path = path;
+ m_format = format;
+ m_renderOnly = bRenderOnly;
+MgTileCacheXYZProvider::~MgTileCacheXYZProvider()
+MgByteReader* MgTileCacheXYZProvider::GetTile(CREFSTRING baseMapLayerGroupName,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 scaleIndex)
+ Ptr<MgByteReader> ret;
+ MG_TRY()
+ ret = GetTileForResource(m_tilesetId, baseMapLayerGroupName, tileColumn, tileRow, scaleIndex);
+ MG_CATCH_AND_THROW(L"MgTileCacheXYZProvider.GetTile")
+ return ret.Detach();
+// render a tile and store it in the cache
+MgByteReader* MgTileCacheXYZProvider::RenderAndCacheTile(CREFSTRING tilePathname, MgMap* map, INT32 scaleIndex,
+ CREFSTRING baseMapLayerGroupName, INT32 tileColumn, INT32 tileRow)
+ Ptr<MgByteReader> img;
+ // get a rendering service instance
+ MgServiceManager* serviceMan = MgServiceManager::GetInstance();
+ assert(NULL != serviceMan);
+ Ptr<MgRenderingService> svcRendering = dynamic_cast<MgRenderingService*>(
+ serviceMan->RequestService(MgServiceType::RenderingService));
+ assert(NULL != svcRendering);
+ if (svcRendering != NULL)
+ // generate the tile
+ img = svcRendering->RenderTileXYZ(map, baseMapLayerGroupName, tileRow, tileColumn, scaleIndex, map->GetDisplayDpi(), m_format);
+ // cache the tile
+ if (!m_renderOnly)
+ Set(img, tilePathname);
+ // rewind the reader since setting the tile advances it to the end
+ if (img)
+ img->Rewind();
+ return img.Detach();
+INT32 MgTileCacheXYZProvider::GetDefaultTileSizeX()
+ return 256; //Always
+INT32 MgTileCacheXYZProvider::GetDefaultTileSizeY()
+STRING MgTileCacheXYZProvider::GetTileFormat()
+ return m_format;
+STRING MgTileCacheXYZProvider::GetBasePath()
+ return GetBasePathFromResourceId(m_tilesetId, m_path);
+STRING MgTileCacheXYZProvider::CreateFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
+ assert(!basePath.empty());
+ STRING fullPath = basePath;
+ // Create base directory if it does not exist.
+ MgFileUtil::CreateDirectory(fullPath, false);
+ // Create group directory if it does not exist.
+ fullPath += L"/";
+ fullPath += group;
+ // Create z directory if it does not exist.
+ fullPath += L"/";
+ STRING sZ;
+ MgUtil::Int32ToString(scaleIndex, sZ);
+ fullPath += sZ;
+ // Create x directory if it does not exist.
+ fullPath += L"/";
+ STRING sX;
+ MgUtil::Int32ToString(tileRow, sX);
+ fullPath += sX;
+ return fullPath;
+// gets the full path to use with the tile cache for the given base path / scale index / group
+STRING MgTileCacheXYZProvider::GetFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow)
+ // Build full path
+ // <fullPath> = <basePath>/<group>/<z>/<x>/<y>.<format>
+ fullPath += L"/";
+ fullPath += L"/";
+ STRING sZ;
+ fullPath += sZ;
+ fullPath += L"/";
+ STRING sX;
+ fullPath += sX;
+ return fullPath;
+// Get the filename corresponding to the specified row and column.
+// No file extension is added.
+STRING MgTileCacheXYZProvider::GetTileName(int tileRow, int tileColumn)
+ //row (x) is already part of the parent directory, so column (y) is the tile name
+ STRING ret;
+ MgUtil::Int32ToString(tileColumn, ret);
+ return ret;
\ No newline at end of file
Added: sandbox/jng/tiling/Server/src/Services/Tile/TileCacheXYZProvider.h
--- sandbox/jng/tiling/Server/src/Services/Tile/TileCacheXYZProvider.h (rev 0)
+++ sandbox/jng/tiling/Server/src/Services/Tile/TileCacheXYZProvider.h 2014-06-09 22:57:56 UTC (rev 8191)
@@ -0,0 +1,61 @@
+#ifndef _MG_TILE_CACHE_XYZ_PROVIDER_H_
+#define _MG_TILE_CACHE_XYZ_PROVIDER_H_
+#include "TileCacheDefault.h"
+class MG_SERVER_TILE_API MgTileCacheXYZProvider : public MgTileCacheDefault
+public:
+ MgTileCacheXYZProvider(MgResourceIdentifier* tileSetId, CREFSTRING path, CREFSTRING format, bool bRenderOnly);
+ virtual ~MgTileCacheXYZProvider();
+ virtual MgByteReader* GetTile(CREFSTRING baseMapLayerGroupName,
+ INT32 tileColumn,
+ INT32 tileRow,
+ INT32 scaleIndex);
+ virtual MgByteReader* RenderAndCacheTile(CREFSTRING tilePathname, MgMap* map, INT32 scaleIndex, CREFSTRING baseMapLayerGroupName, INT32 tileColumn, INT32 tileRow);
+ virtual INT32 GetDefaultTileSizeX();
+ virtual INT32 GetDefaultTileSizeY();
+ virtual STRING GetTileFormat();
+ //Overriding these as we want to use a cleaner directory structure for XYZ tiles
+ virtual STRING GetFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
+ virtual STRING CreateFullPath(CREFSTRING basePath, int scaleIndex, CREFSTRING group, int tileColumn, int tileRow);
+protected:
+ virtual void Dispose()
+ delete this;
+ virtual STRING GetBasePath();
+private:
+ Ptr<MgResourceIdentifier> m_tilesetId;
+ STRING m_path;
+ STRING m_format;
+ bool m_renderOnly;
+#endif
More information about the mapguide-commits
