[mapguide-commits] r8193 - in sandbox/jng/tiling: Server/src/PostBuild Server/src/UnitTesting UnitTest/TestData/TileService
svn_mapguide at osgeo.org
Tue Jun 10 01:16:58 PDT 2014
Author: jng
Date: 2014-06-10 01:16:58 -0700 (Tue, 10 Jun 2014)
New Revision: 8193
Added:
sandbox/jng/tiling/UnitTest/TestData/TileService/UT_XYZ.tsd
sandbox/jng/tiling/Server/src/PostBuild/PostBuild.mak
sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.cpp
sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.h
sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.cpp
sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.h
Add unit tests to cover recent changes.
Modified: sandbox/jng/tiling/Server/src/PostBuild/PostBuild.mak
--- sandbox/jng/tiling/Server/src/PostBuild/PostBuild.mak 2014-06-10 07:39:31 UTC (rev 8192)
+++ sandbox/jng/tiling/Server/src/PostBuild/PostBuild.mak 2014-06-10 08:16:58 UTC (rev 8193)
@@ -165,6 +165,7 @@
..\..\bin\UnitTestFiles\TEST.sdf \
..\..\bin\UnitTestFiles\UT_BaseMap.mdf \
..\..\bin\UnitTestFiles\UT_BaseMap.tsd \
+ ..\..\bin\UnitTestFiles\UT_XYZ.tsd \
..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf \
..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf \
..\..\bin\UnitTestFiles\UT_Parcels.fs \
@@ -436,6 +437,7 @@
@@ -707,6 +709,7 @@
@@ -978,6 +981,7 @@
@@ -1122,6 +1126,7 @@
if EXIST ..\..\bin\UnitTestFiles\TEST.sdf del /F ..\..\bin\UnitTestFiles\TEST.sdf
if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.mdf del /F ..\..\bin\UnitTestFiles\UT_BaseMap.mdf
if EXIST ..\..\bin\UnitTestFiles\UT_BaseMap.tsd del /F ..\..\bin\UnitTestFiles\UT_BaseMap.tsd
+ if EXIST ..\..\bin\UnitTestFiles\UT_XYZ.tsd del /F ..\..\bin\UnitTestFiles\UT_XYZ.tsd
if EXIST ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf del /F ..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf
if EXIST ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf del /F ..\..\bin\UnitTestFiles\UT_StylizationFuncs.mdf
if EXIST ..\..\bin\UnitTestFiles\UT_Parcels.fs del /F ..\..\bin\UnitTestFiles\UT_Parcels.fs
@@ -1261,6 +1266,7 @@
@@ -1400,6 +1406,7 @@
@@ -1537,6 +1544,7 @@
@@ -1801,6 +1809,7 @@
@@ -2065,6 +2074,7 @@
@@ -2329,6 +2339,7 @@
@@ -2593,6 +2604,7 @@
@@ -2730,6 +2742,7 @@
@@ -2862,6 +2875,7 @@
@@ -2994,6 +3008,7 @@
@@ -3124,6 +3139,7 @@
@@ -3261,6 +3277,7 @@
"..\..\..\UnitTest\TestData\MappingService\UT_RotatedPointStyles.ldf" :
"..\..\..\UnitTest\TestData\TileService\UT_BaseMap.mdf" :
"..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" :
+"..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" :
"..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" :
"..\..\..\UnitTest\TestData\TileService\UT_StylizationFuncs.mdf" :
"..\..\..\UnitTest\TestData\TileService\UT_Parcels.fs" :
@@ -3505,6 +3522,10 @@
if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
if EXIST "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_BaseMap.tsd" ..\..\bin\UnitTestFiles\
+..\..\bin\UnitTestFiles\UT_XYZ.tsd : "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd"
+ if NOT EXIST ..\..\bin\UnitTestFiles\nul mkdir ..\..\bin\UnitTestFiles
+ if EXIST "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_XYZ.tsd" ..\..\bin\UnitTestFiles\
..\..\bin\UnitTestFiles\UT_LinkedTileSet.mdf : "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf"
if EXIST "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" xcopy /r /d /y "..\..\..\UnitTest\TestData\TileService\UT_LinkedTileSet.mdf" ..\..\bin\UnitTestFiles\
Modified: sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.cpp
--- sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.cpp 2014-06-10 07:39:31 UTC (rev 8192)
+++ sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.cpp 2014-06-10 08:16:58 UTC (rev 8193)
@@ -83,10 +83,15 @@
Ptr<MgByteReader> mdfrdr4 = mdfsrc4->GetReader();
m_svcResource->SetResource(mdfres4, mdfrdr4, NULL);
- Ptr<MgResourceIdentifier> mdfres5 = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestTileSet.TileSetDefinition");
- Ptr<MgByteSource> mdfsrc5 = new MgByteSource(L"../UnitTestFiles/UT_BaseMap.tsd", false);
- Ptr<MgByteReader> mdfrdr5 = mdfsrc5->GetReader();
- m_svcResource->SetResource(mdfres5, mdfrdr5, NULL);
+ Ptr<MgResourceIdentifier> tsdres5 = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/MdfTestTileSet.TileSetDefinition");
+ Ptr<MgByteSource> tsdsrc5 = new MgByteSource(L"../UnitTestFiles/UT_BaseMap.tsd", false);
+ Ptr<MgByteReader> tsdrdr5 = tsdsrc5->GetReader();
+ m_svcResource->SetResource(tsdres5, tsdrdr5, NULL);
+ Ptr<MgResourceIdentifier> tsdres6 = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/XYZTestTileSet.TileSetDefinition");
+ Ptr<MgByteSource> tsdsrc6 = new MgByteSource(L"../UnitTestFiles/UT_XYZ.tsd", false);
+ Ptr<MgByteReader> tsdrdr6 = tsdsrc6->GetReader();
+ m_svcResource->SetResource(tsdres6, tsdrdr6, NULL);
catch (MgException* e)
@@ -869,7 +874,7 @@
-void TestMdfModel::TestCase_TileSetDefinition()
+void TestMdfModel::TestCase_TileSetDefinitionDefault()
try
@@ -887,7 +892,7 @@
MdfModel::TileStoreParameters* tilesetParams = tileset->GetTileStoreParameters();
CPPUNIT_ASSERT(NULL != tilesetParams);
- CPPUNIT_ASSERT(L"Default" == tilesetParams->GetTileProvider());
+ CPPUNIT_ASSERT(MG_TILE_PROVIDER_DEFAULT == tilesetParams->GetTileProvider());
STRING path;
INT32 width;
@@ -899,23 +904,23 @@
for (INT32 i = 0; i < parameters->GetCount(); i++)
MdfModel::NameStringPair* pair = parameters->GetAt(i);
- if (pair->GetName() == L"TilePath")
+ if (pair->GetName() == MG_TILE_PROVIDER_COMMON_PARAM_TILEPATH)
path = pair->GetValue();
- else if (pair->GetName() == L"TileWidth")
+ else if (pair->GetName() == MG_TILE_PROVIDER_COMMON_PARAM_TILEWIDTH)
width = MgUtil::StringToInt32(pair->GetValue());
- else if (pair->GetName() == L"TileHeight")
+ else if (pair->GetName() == MG_TILE_PROVIDER_COMMON_PARAM_TILEHEIGHT)
height = MgUtil::StringToInt32(pair->GetValue());
- else if (pair->GetName() == L"TileFormat")
+ else if (pair->GetName() == MG_TILE_PROVIDER_COMMON_PARAM_TILEFORMAT)
format = pair->GetValue();
- else if (pair->GetName() == L"FiniteScaleList") //NOXLATE
+ else if (pair->GetName() == MG_TILE_PROVIDER_COMMON_PARAM_FINITESCALELIST)
Ptr<MgStringCollection> values = MgStringCollection::ParseCollection(pair->GetValue(), L","); //NOXLATE
for (INT32 i = 0; i < values->GetCount(); i++)
@@ -980,3 +985,81 @@
CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+void TestMdfModel::TestCase_TileSetDefinitionXYZ()
+ try
+ Ptr<MgResourceIdentifier> tsId = new MgResourceIdentifier(L"Library://UnitTests/MdfModel/XYZTestTileSet.TileSetDefinition");
+ Ptr<MgByteReader> content = m_svcResource->GetResourceContent(tsId);
+ Ptr<MgByteSink> sink = new MgByteSink(content);
+ Ptr<MgByte> bytes = sink->ToBuffer();
+ MdfParser::SAX2Parser parser;
+ parser.ParseString((const char*)bytes->Bytes(), bytes->GetLength());
+ CPPUNIT_ASSERT(parser.GetSucceeded());
+ MdfModel::TileSetDefinition* tileset = parser.DetachTileSetDefinition();
+ CPPUNIT_ASSERT(NULL != tileset);
+ MdfModel::TileStoreParameters* tilesetParams = tileset->GetTileStoreParameters();
+ CPPUNIT_ASSERT(NULL != tilesetParams);
+ CPPUNIT_ASSERT(MG_TILE_PROVIDER_XYZ == tilesetParams->GetTileProvider());
+ STRING path;
+ STRING format;
+ MdfModel::NameStringPairCollection* parameters = tilesetParams->GetParameters();
+ for (INT32 i = 0; i < parameters->GetCount(); i++)
+ MdfModel::NameStringPair* pair = parameters->GetAt(i);
+ path = pair->GetValue();
+ format = pair->GetValue();
+ CPPUNIT_ASSERT(L"PNG" == format);
+ CPPUNIT_ASSERT(MgResourceTag::TileCachePath == path);
+ const MdfModel::Box2D& extents = tileset->GetExtents();
+ CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.79786601383196, extents.GetMinX(), 0.00000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL( 43.686857862181, extents.GetMinY(), 0.000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL(-87.66452777186925, extents.GetMaxX(), 0.00000000000001);
+ CPPUNIT_ASSERT_DOUBLES_EQUAL( 43.8037962206133, extents.GetMaxY(), 0.0000000000001);
+ MdfModel::BaseMapLayerGroupCollection* groups = tileset->GetBaseMapLayerGroups();
+ CPPUNIT_ASSERT(1 == groups->GetCount());
+ CPPUNIT_ASSERT(L"BaseLayers" == groups->GetAt(0)->GetName());
+ CPPUNIT_ASSERT(L"Base Layers" == groups->GetAt(0)->GetLegendLabel());
+ CPPUNIT_ASSERT(groups->GetAt(0)->IsShowInLegend());
+ CPPUNIT_ASSERT(groups->GetAt(0)->IsExpandInLegend());
+ MdfModel::BaseMapLayerCollection* layers = groups->GetAt(0)->GetLayers();
+ CPPUNIT_ASSERT(2 == layers->GetCount());
+ CPPUNIT_ASSERT(L"Parcels" == layers->GetAt(0)->GetName());
+ CPPUNIT_ASSERT(L"Parcels" == layers->GetAt(0)->GetLegendLabel());
+ CPPUNIT_ASSERT(L"Library://UnitTests/Layers/Parcels.LayerDefinition" == layers->GetAt(0)->GetLayerResourceID());
+ CPPUNIT_ASSERT(!layers->GetAt(0)->IsExpandInLegend());
+ CPPUNIT_ASSERT(layers->GetAt(0)->IsShowInLegend());
+ CPPUNIT_ASSERT(layers->GetAt(0)->IsSelectable());
+ CPPUNIT_ASSERT(L"VotingDistricts" == layers->GetAt(1)->GetName());
+ CPPUNIT_ASSERT(L"Voting Districts" == layers->GetAt(1)->GetLegendLabel());
+ CPPUNIT_ASSERT(L"Library://UnitTests/Layers/VotingDistricts.LayerDefinition" == layers->GetAt(1)->GetLayerResourceID());
+ CPPUNIT_ASSERT(!layers->GetAt(1)->IsExpandInLegend());
+ CPPUNIT_ASSERT(layers->GetAt(1)->IsShowInLegend());
+ CPPUNIT_ASSERT(layers->GetAt(1)->IsSelectable());
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
\ No newline at end of file
Modified: sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.h
--- sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.h 2014-06-10 07:39:31 UTC (rev 8192)
+++ sandbox/jng/tiling/Server/src/UnitTesting/TestMdfModel.h 2014-06-10 08:16:58 UTC (rev 8193)
@@ -28,7 +28,8 @@
CPPUNIT_TEST(TestCase_Serialization);
CPPUNIT_TEST(TestCase_Versioning);
- CPPUNIT_TEST(TestCase_TileSetDefinition);
+ CPPUNIT_TEST(TestCase_TileSetDefinitionDefault);
+ CPPUNIT_TEST(TestCase_TileSetDefinitionXYZ);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -44,7 +45,8 @@
void TestCase_Serialization();
void TestCase_Versioning();
- void TestCase_TileSetDefinition();
+ void TestCase_TileSetDefinitionDefault();
+ void TestCase_TileSetDefinitionXYZ();
private:
Ptr<MgResourceService> m_svcResource;
Modified: sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.cpp
--- sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.cpp 2014-06-10 07:39:31 UTC (rev 8192)
+++ sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.cpp 2014-06-10 08:16:58 UTC (rev 8193)
@@ -128,6 +128,11 @@
Ptr<MgByteReader> tsdrdr1 = tsdsrc1->GetReader();
m_svcResource->SetResource(tilesetres1, tsdrdr1, NULL);
+ Ptr<MgResourceIdentifier> tilesetres2 = new MgResourceIdentifier(L"Library://UnitTests/TileSets/XYZ.TileSetDefinition");
+ Ptr<MgByteSource> tsdsrc2 = new MgByteSource(L"../UnitTestFiles/UT_XYZ.tsd", false);
+ Ptr<MgByteReader> tsdrdr2 = tsdsrc2->GetReader();
+ m_svcResource->SetResource(tilesetres2, tsdrdr2, NULL);
// publish the layer definitions
Ptr<MgResourceIdentifier> ldfres1 = new MgResourceIdentifier(L"Library://UnitTests/Layers/RoadCenterLines.LayerDefinition");
Ptr<MgByteSource> ldfsrc1 = new MgByteSource(L"../UnitTestFiles/UT_RoadCenterLines.ldf", false);
@@ -1184,6 +1189,53 @@
+void TestTileService::TestCase_MgMapFromXYZTileSetStrict()
+ try
+ // make a runtime map
+ Ptr<MgResourceIdentifier> tsdres = new MgResourceIdentifier(L"Library://UnitTests/TileSets/XYZ.TileSetDefinition");
+ MgMap* map = new MgMap(m_siteConnection);
+ map->Create(tsdres, L"XYZTileSet");
+ CPPUNIT_FAIL("MgUnsupportedTileProviderException should've been thrown");
+ bool isCorrectException = e->IsOfClass(MapGuide_Exception_MgUnsupportedTileProviderException);
+ SAFE_RELEASE(e);
+ CPPUNIT_ASSERT_MESSAGE(MG_WCHAR_TO_CHAR(message), isCorrectException);
+ catch (...)
+ throw;
+void TestTileService::TestCase_MgMapFromXYZTileSetLoose()
+ try
+ map->Create(m_svcResource, tsdres, L"XYZTileSet", false);
+ CPPUNIT_ASSERT(0 == map->GetFiniteDisplayScaleCount());
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
void TestTileService::TestCase_MgMapFromTileSet()
try
Modified: sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.h
--- sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.h 2014-06-10 07:39:31 UTC (rev 8192)
+++ sandbox/jng/tiling/Server/src/UnitTesting/TestTileService.h 2014-06-10 08:16:58 UTC (rev 8193)
@@ -28,6 +28,8 @@
CPPUNIT_TEST(TestCase_GetTileProviders);
CPPUNIT_TEST(TestCase_MgMap_Inline);
CPPUNIT_TEST(TestCase_MgMap_Linked);
+ CPPUNIT_TEST(TestCase_MgMapFromXYZTileSetStrict);
+ CPPUNIT_TEST(TestCase_MgMapFromXYZTileSetLoose);
CPPUNIT_TEST(TestCase_MgMapFromTileSet);
CPPUNIT_TEST(TestCase_GetTile);
CPPUNIT_TEST(TestCase_SetTile);
@@ -51,6 +53,8 @@
void TestCase_GetTileProviders();
void TestCase_MgMap_Inline();
void TestCase_MgMap_Linked();
+ void TestCase_MgMapFromXYZTileSetStrict();
+ void TestCase_MgMapFromXYZTileSetLoose();
void TestCase_MgMapFromTileSet();
void TestCase_GetTile();
void TestCase_SetTile();
Added: sandbox/jng/tiling/UnitTest/TestData/TileService/UT_XYZ.tsd
--- sandbox/jng/tiling/UnitTest/TestData/TileService/UT_XYZ.tsd (rev 0)
+++ sandbox/jng/tiling/UnitTest/TestData/TileService/UT_XYZ.tsd 2014-06-10 08:16:58 UTC (rev 8193)
@@ -0,0 +1,43 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<TileSetDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="TileSetDefinition-3.0.0.xsd">
+ <TileStoreParameters>
+ <TileProvider>XYZ</TileProvider>
+ <Parameter>
+ <Name>TilePath</Name>
+ <Value>%MG_TILE_CACHE_PATH%</Value>
+ </Parameter>
+ <Parameter>
+ <Name>TileFormat</Name>
+ <Value>PNG</Value>
+ </Parameter>
+ </TileStoreParameters>
+ <Extents>
+ <MinX>-87.79786601383196</MinX>
+ <MaxX>-87.66452777186925</MaxX>
+ <MinY>43.6868578621819</MinY>
+ <MaxY>43.8037962206133</MaxY>
+ </Extents>
+ <BaseMapLayerGroup>
+ <Name>BaseLayers</Name>
+ <Visible>true</Visible>
+ <ShowInLegend>true</ShowInLegend>
+ <ExpandInLegend>true</ExpandInLegend>
+ <LegendLabel>Base Layers</LegendLabel>
+ <BaseMapLayer>
+ <Name>Parcels</Name>
+ <ResourceId>Library://UnitTests/Layers/Parcels.LayerDefinition</ResourceId>
+ <Selectable>true</Selectable>
+ <LegendLabel>Parcels</LegendLabel>
+ <ExpandInLegend>false</ExpandInLegend>
+ </BaseMapLayer>
+ <BaseMapLayer>
+ <Name>VotingDistricts</Name>
+ <ResourceId>Library://UnitTests/Layers/VotingDistricts.LayerDefinition</ResourceId>
+ <LegendLabel>Voting Districts</LegendLabel>
+ </BaseMapLayer>
+ </BaseMapLayerGroup>
+</TileSetDefinition>
More information about the mapguide-commits
