[mapguide-commits] r8222 - sandbox/jng/v30/Common/MapGuideCommon/MapLayer
svn_mapguide at osgeo.org
Sat Jun 14 17:35:50 PDT 2014
Author: jng
Date: 2014-06-14 17:35:49 -0700 (Sat, 14 Jun 2014)
New Revision: 8222
sandbox/jng/v30/Common/MapGuideCommon/MapLayer/Map.h
And now for the MgMap API removal itself. We're not removing the actual methods from MgMap. We're just demoting them from PUBLISHED_API to INTERNAL_API, so that they are still accessible from C++ code where usage is still legitimate.
Modified: sandbox/jng/v30/Common/MapGuideCommon/MapLayer/Map.h
--- sandbox/jng/v30/Common/MapGuideCommon/MapLayer/Map.h 2014-06-15 00:33:59 UTC (rev 8221)
+++ sandbox/jng/v30/Common/MapGuideCommon/MapLayer/Map.h 2014-06-15 00:35:49 UTC (rev 8222)
@@ -70,14 +70,11 @@
/// $site = $siteConnection->GetSite();
/// $sessionID = $site->CreateSession();
/// $user->SetMgSessionId($sessionID);
-/// // Get an instance of the required services.
-/// $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
-/// $mappingService = $siteConnection->CreateService(MgServiceType::MappingService);
/// // Get a runtime map from a map definition
/// $resourceID = new MgResourceIdentifier('Library://Calgary/Maps/Calgary.MapDefinition');
-/// $map = new MgMap();
-/// $map->Create($resourceService, $resourceID, 'Calgary');
+/// $map = new MgMap($site);
+/// $map->Create($resourceID, 'Calgary');
/// // Show information about the map
/// echo "Name of map: '" . $map->GetName() . "'n";
@@ -239,37 +236,6 @@
/// \brief
- /// Constructs an empty un-initialized MgMap object.
- /// \deprecated
- /// This method has been deprecated. Use the following method:
- /// \link MgMap(MgSiteConnection*) MgMap(MgSiteConnection* siteConnection) \endlink.
- /// <!-- Syntax in .Net, Java, and PHP -->
- /// \htmlinclude DotNetSyntaxTop.html
- /// MgMap();
- /// \htmlinclude SyntaxBottom.html
- /// \htmlinclude JavaSyntaxTop.html
- /// MgMap();
- /// \htmlinclude PHPSyntaxTop.html
- /// MgMap();
- /// \remarks
- /// If you use this constructor, the following methods of the associated layer objects
- /// are not available to be used.
- /// \li MgLayerBase::GetClassDefinition()
- /// \li MgLayerBase::SelectFeatures(MgFeatureQueryOptions*)
- /// \li MgLayerBase::SelectAggregate(MgFeatureAggregateOptions*)
- /// \li MgLayerBase::UpdateFeatures(MgFeatureCommandCollection*)
- /// To take advantage of these methods, you must use the following method instead:
- MgMap();
- /// \brief
/// Constructs an MgMap object that takes an MgSiteConnection instance.
/// \remarks
@@ -310,49 +276,6 @@
/// \brief
- /// Initializes a new MgMap object given a resource service, map
- /// definition, and a name for the map. This method is used for
- /// MapGuide Viewers or for offline map production.
- /// \deprecated
- /// \link MgMap::Create(MgResourceIdentifier*,CREFSTRING) Create(MgResourceIdentifier mapDefinition, string mapName) \endlink.
- /// void Create(MgResourceService resourceService, MgResourceIdentifier mapDefinition, string mapName);
- /// void Create(MgResourceService resourceService, MgResourceIdentifier mapDefinition, String mapName);
- /// \param resourceService
- /// An MgResourceService that can be used to
- /// retrieve the map definition.
- /// \param mapDefinition
- /// An MgResourceIdentifier that specifies the
- /// location of the map definition in a resource
- /// repository.
- /// \param mapName
- /// A string that specifies the name of the map.
- /// <!-- Example (PHP) -->
- /// \htmlinclude PHPExampleTop.html
- /// \code
- /// // Assuming the resource service has already been intialized
- /// $resourceID = new MgResourceIdentifier('Library://Calgary/Maps/Calgary.MapDefinition');
- /// $map = new MgMap();
- /// $map->Create($resourceService, $resourceID, 'Calgary');
- /// \endcode
- /// \htmlinclude ExampleBottom.html
- virtual void Create(MgResourceService* resourceService, MgResourceIdentifier* mapDefinition, CREFSTRING mapName);
- /// \brief
/// Initializes a new MgMap object given a map definition
/// and a name for the map. This method is used for
@@ -422,52 +345,6 @@
/// \brief
/// Loads the map object from a session repository.
- /// \deprecated
- /// \link MgMap::Open(CREFSTRING) Open(string mapName) \endlink.
- /// For more information, see \link Maps_and_Layers_Module Maps and Layers \endlink.
- /// virtual void Open(MgResourceService resourceService, string mapName);
- /// virtual void Open(MgResourceService resourceService, String mapName);
- /// An MgResourceService that can be used to retrieve
- /// the map.
- /// A string that specifies the name of the map. This
- /// is the name that was specified when \link MgMapBase::Create Create \endlink
- /// was called to create the map object.
- /// \return
- /// Returns nothing.
- /// \code
- /// // Assuming the resource service has already been initialized
- /// $map->Open($resourceService, 'Calgary');
- /// \endcode
- /// \todo
- /// * [[Job for Philip: If I move that overview to the
- /// Developer's Guide, update the xref here.]]
- virtual void Open(MgResourceService* resourceService, CREFSTRING mapName);
- /// \brief
- /// Loads the map object from a session repository.
/// \remarks
@@ -505,21 +382,6 @@
virtual void Open(CREFSTRING mapName);
- /// \brief
- /// Saves the Map using the specified resource service.
- /// \deprecated
- /// \link Save() Save() \endlink.
- /// This method assumes a valid resource identifier has already
- /// been established via either Open or Save.
- /// Resource service.
- void Save(MgResourceService* resourceService);
/// \brief
/// Saves the Map using the specified resource service and
@@ -552,7 +414,38 @@
INTERNAL_API:
/// \brief
+ /// Constructs an empty un-initialized MgMap object.
+ /// \deprecated
+ /// This method has been deprecated. Use the following method:
+ /// \link MgMap(MgSiteConnection*) MgMap(MgSiteConnection* siteConnection) \endlink.
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// MgMap();
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// MgMap();
+ /// \htmlinclude PHPSyntaxTop.html
+ /// MgMap();
+ /// \remarks
+ /// If you use this constructor, the following methods of the associated layer objects
+ /// are not available to be used.
+ /// \li MgLayerBase::GetClassDefinition()
+ /// \li MgLayerBase::SelectFeatures(MgFeatureQueryOptions*)
+ /// \li MgLayerBase::SelectAggregate(MgFeatureAggregateOptions*)
+ /// \li MgLayerBase::UpdateFeatures(MgFeatureCommandCollection*)
+ /// To take advantage of these methods, you must use the following method instead:
+ MgMap();
+ /// \brief
/// Destruct a MgMap object
/// \return
@@ -562,6 +455,110 @@
/// \brief
+ /// Initializes a new MgMap object given a resource service, map
+ /// definition, and a name for the map. This method is used for
+ /// MapGuide Viewers or for offline map production.
+ /// \deprecated
+ /// \link MgMap::Create(MgResourceIdentifier*,CREFSTRING) Create(MgResourceIdentifier mapDefinition, string mapName) \endlink.
+ /// void Create(MgResourceService resourceService, MgResourceIdentifier mapDefinition, string mapName);
+ /// void Create(MgResourceService resourceService, MgResourceIdentifier mapDefinition, String mapName);
+ /// \param resourceService
+ /// An MgResourceService that can be used to
+ /// retrieve the map definition.
+ /// \param mapDefinition
+ /// An MgResourceIdentifier that specifies the
+ /// location of the map definition in a resource
+ /// repository.
+ /// \param mapName
+ /// A string that specifies the name of the map.
+ /// <!-- Example (PHP) -->
+ /// \htmlinclude PHPExampleTop.html
+ /// \code
+ /// // Assuming the resource service has already been intialized
+ /// $resourceID = new MgResourceIdentifier('Library://Calgary/Maps/Calgary.MapDefinition');
+ /// $map = new MgMap();
+ /// $map->Create($resourceService, $resourceID, 'Calgary');
+ /// \endcode
+ /// \htmlinclude ExampleBottom.html
+ virtual void Create(MgResourceService* resourceService, MgResourceIdentifier* mapDefinition, CREFSTRING mapName);
+ /// \brief
+ /// Loads the map object from a session repository.
+ /// \deprecated
+ /// \link MgMap::Open(CREFSTRING) Open(string mapName) \endlink.
+ /// For more information, see \link Maps_and_Layers_Module Maps and Layers \endlink.
+ /// virtual void Open(MgResourceService resourceService, string mapName);
+ /// virtual void Open(MgResourceService resourceService, String mapName);
+ /// An MgResourceService that can be used to retrieve
+ /// the map.
+ /// A string that specifies the name of the map. This
+ /// is the name that was specified when \link MgMapBase::Create Create \endlink
+ /// was called to create the map object.
+ /// \return
+ /// Returns nothing.
+ /// \code
+ /// // Assuming the resource service has already been initialized
+ /// $map->Open($resourceService, 'Calgary');
+ /// \endcode
+ /// \todo
+ /// * [[Job for Philip: If I move that overview to the
+ /// Developer's Guide, update the xref here.]]
+ virtual void Open(MgResourceService* resourceService, CREFSTRING mapName);
+ /// \brief
+ /// Saves the Map using the specified resource service.
+ /// \deprecated
+ /// \link Save() Save() \endlink.
+ /// This method assumes a valid resource identifier has already
+ /// been established via either Open or Save.
+ /// Resource service.
+ void Save(MgResourceService* resourceService);
+ /// \brief
/// Serialize data to a TCP/IP stream.
/// \param stream
More information about the mapguide-commits
