[mapguide-commits] r8225 - in sandbox/jng/v30: . UnitTest/WebTier/Php
svn_mapguide at osgeo.org
Sun Jun 15 10:30:25 PDT 2014
Author: jng
Date: 2014-06-15 10:30:25 -0700 (Sun, 15 Jun 2014)
New Revision: 8225
Added:
sandbox/jng/v30/UnitTest/WebTier/Php/SQLiteEngine.php
sandbox/jng/v30/UnitTest/WebTier/Php/HtmlPrinter.php
sandbox/jng/v30/UnitTest/WebTier/Php/Run.php
sandbox/jng/v30/UnitTest/WebTier/Php/RunTests.php
sandbox/jng/v30/UnitTest/WebTier/Php/Utils.php
sandbox/jng/v30/UnitTest/WebTier/Php/Validate.php
sandbox/jng/v30/run_tests.bat
PHP test runner improvements:
- Fix PHP warnings in HtmlPrinter
- Add a PHP implementation of SqliteDB and SqliteVM (based on PDO). This is used by run_tests.bat to avoid random access violations that seem to be happening in my test runs. The existing SWIG PHP wrapper is still required for dump file generation/updates.
Modified: sandbox/jng/v30/UnitTest/WebTier/Php/HtmlPrinter.php
--- sandbox/jng/v30/UnitTest/WebTier/Php/HtmlPrinter.php 2014-06-15 11:14:08 UTC (rev 8224)
+++ sandbox/jng/v30/UnitTest/WebTier/Php/HtmlPrinter.php 2014-06-15 17:30:25 UTC (rev 8225)
@@ -19,10 +19,6 @@
require_once("Utils.php");
-if (!defined('SQLITE_ROW')) {
- define('SQLITE_ROW', 100);
//This is a helper class that contains methods that output data in an Html format.
class HtmlPrinter
@@ -149,6 +145,7 @@
print("<table scroll=\"no\" border=\"1\" cellpadding=\"5\">\n");
print("<h3><b>$caption</b></h3>");
+ print("<col width=10><col width=20><col width=40><col width=20><col width=180><col width=180><col>");
print("<tr>\n");
print("<td> </td><th>Param Set</th><th>Operation</th>\n<th>Outcome</th>\n<th>Actual Result</th>\n<th>Expected Result</th>\n");
print("</tr>\n");
Modified: sandbox/jng/v30/UnitTest/WebTier/Php/Run.php
--- sandbox/jng/v30/UnitTest/WebTier/Php/Run.php 2014-06-15 11:14:08 UTC (rev 8224)
+++ sandbox/jng/v30/UnitTest/WebTier/Php/Run.php 2014-06-15 17:30:25 UTC (rev 8225)
@@ -118,7 +118,7 @@
catch (MgException $e)
- print $e->GetExceptionMessage('en');
+ print $e->GetDetails();
return false;
catch (SqliteException $s)
Modified: sandbox/jng/v30/UnitTest/WebTier/Php/RunTests.php
--- sandbox/jng/v30/UnitTest/WebTier/Php/RunTests.php 2014-06-15 11:14:08 UTC (rev 8224)
+++ sandbox/jng/v30/UnitTest/WebTier/Php/RunTests.php 2014-06-15 17:30:25 UTC (rev 8225)
@@ -163,6 +163,7 @@
print $s->GetExceptionMessage();
+ $s->Dispose();
return 1;
Added: sandbox/jng/v30/UnitTest/WebTier/Php/SQLiteEngine.php
--- sandbox/jng/v30/UnitTest/WebTier/Php/SQLiteEngine.php (rev 0)
+++ sandbox/jng/v30/UnitTest/WebTier/Php/SQLiteEngine.php 2014-06-15 17:30:25 UTC (rev 8225)
@@ -0,0 +1,214 @@
+<?php
+// SQLiteEngine.php
+// A PHP-based implementation of SqliteDB and SqliteVM class using PDO instead
+// of the internal SWIG-wrapped SQLite classes in Oem
+// This avoids any access violation issues should our test runner happen to
+// be mis-using any classes in the SWIG wrapper.
+if (!defined('SQLITE_ROW')) {
+ define('SQLITE_ROW', 100);
+if (!extension_loaded("SQLitePhpApi"))
+ //echo "SQLitePhpApi not loaded. Using PHP implementation";
+ class SqliteException extends Exception
+ class CantOpenDbException extends SqliteException
+ class SqliteDB
+ private $dbh;
+ private $dbName;
+ public function __construct()
+ $this->dbh = NULL;
+ $this->dbName = "";
+ public function __destruct()
+ $this->Close();
+ public function Close()
+ if ($this->dbh != NULL)
+ public function GetHandle() { return $this->dbh; }
+ public function Open($dbName)
+ $this->Close();
+ $this->dbh = new PDO("sqlite:$dbName");
+ $this->dbh->setAttribute(PDO::ATTR_ERRMODE, PDO::ERRMODE_EXCEPTION);
+ $this->dbName = $dbName;
+ public function GetName() { return $this->dbName; }
+ public function GenerateDatabase($dumpFilePath, $dbPath)
+ if (php_sapi_name() == 'cli')
+ echo "Generating database from dump: $dumpFilePath\n";
+ else
+ echo "Generating database from dump: $dumpFilePath<br/>";
+ $pdo = new PDO("sqlite:$dbPath");
+ $pdo->setAttribute(PDO::ATTR_ERRMODE, PDO::ERRMODE_EXCEPTION);
+ $sql = file_get_contents($dumpFilePath);
+ $pdo->exec($sql);
+ $pdo = NULL;
+ public function DumpDatabase($path)
+ throw new Exception("Creating database dumps not implemented. Please run this script with the php_SQLitePhpApi extension loaded");
+ class SqliteVM
+ private $db;
+ private $currentStmt;
+ private $currentRow;
+ private $resultLOB;
+ private $nameIndexMap;
+ public function __construct($db)
+ $this->db = $db->GetHandle();
+ $this->currentStmt = NULL;
+ $this->currentRow = NULL;
+ $this->nameIndexMap = array();
+ public function Execute($query)
+ echo "Executing: $query\n";
+ else
+ echo "Executing: $query<br/>";
+ if ($this->currentStmt != NULL)
+ $this->currentStmt->closeCursor();
+ $this->currentStmt = $this->db->prepare($query);
+ try
+ if ($this->currentStmt === FALSE)
+ echo "ERROR: Failed to prepare query: $query\n";
+ else
+ echo "ERROR: Failed to prepare query: $query<br/>";
+ return -1;
+ if (!$this->currentStmt->execute())
+ echo "ERROR: Failed to execute query: $query\n";
+ else
+ echo "ERROR: Failed to execute query: $query<br/>";
+ return -1;
+ catch (PDOException $e)
+ return -1;
+ //Compile name index map for the purposes of column binding below
+ for ($i = 0; $i < $this->currentStmt->columnCount(); $i++)
+ try {
+ $col = $this->currentStmt->getColumnMeta($i);
+ if ($col === FALSE)
+ continue;
+ } catch (PDOException $e) {
+ continue;
+ if (array_key_exists("name", $col))
+ $colName = $col["name"];
+ $this->nameIndexMap[$colName] = $i;
+ //Bind columns, paying special attention to bind Result as BLOB if found
+ $this->currentRow = array();
+ foreach ($this->nameIndexMap as $colName => $index)
+ if ($colName == "Result") {
+ $this->currentStmt->bindColumn(($index+1), $this->currentRow[$colName], PDO::PARAM_LOB);
+ //echo "Bound $colName as BLOB<br/>";
+ } else {
+ $this->currentStmt->bindColumn(($index+1), $this->currentRow[$colName]);
+ try
+ $res = $this->currentStmt->fetch();
+ if ($res === FALSE)
+ return -1;
+ return -1;
+ return SQLITE_ROW;
+ public function GetString($name)
+ if (array_key_exists($name, $this->currentRow))
+ return $this->currentRow[$name];
+ return "";
+ public function GetBlob($name)
+ $str = $this->currentRow[$name];
+ //SqliteBlob in C++ has a MgByteReader-style interface. Since
+ //in PHP if it quacks like a duck ... we'll give them an actual MgByteReader
+ $source = new MgByteSource($str, strlen($str));
+ return $source->GetReader();
+ public function NextRow()
+ $this->currentRow = $this->currentStmt->fetch();
+ if ($this->currentRow === FALSE)
+ return -1;
+ public function SqlFinalize()
\ No newline at end of file
Modified: sandbox/jng/v30/UnitTest/WebTier/Php/Utils.php
--- sandbox/jng/v30/UnitTest/WebTier/Php/Utils.php 2014-06-15 11:14:08 UTC (rev 8224)
+++ sandbox/jng/v30/UnitTest/WebTier/Php/Utils.php 2014-06-15 17:30:25 UTC (rev 8225)
@@ -19,6 +19,8 @@
//Class that defines static methods that are commonly used in the infrastructure
+require_once("SQLiteEngine.php");
if (!defined('WEBCONFIGINI')) {
if (array_key_exists("WEBCONFIGINI", $_SERVER)) {
define("WEBCONFIGINI", $_SERVER["WEBCONFIGINI"]);
@@ -246,7 +248,7 @@
return $dbPath;
public static function CreateDumpFile($db, $overwrite = false)
$dbName = $db->GetName();
Modified: sandbox/jng/v30/UnitTest/WebTier/Php/Validate.php
--- sandbox/jng/v30/UnitTest/WebTier/Php/Validate.php 2014-06-15 11:14:08 UTC (rev 8224)
+++ sandbox/jng/v30/UnitTest/WebTier/Php/Validate.php 2014-06-15 17:30:25 UTC (rev 8225)
@@ -57,6 +57,8 @@
//Get the file extension that will be used for a dump
$actualExtension = ValidateUtils::GetExtension($mimeType);
+ $bAlwaysPass = false;
+ $passReason = "";
//If we have an ALWAYSPASS parameter defined for the operation then skip the whole validation process
//This parameter should only be used for clean up operations that are no related with the tests
if ($this->vm->Execute("Select ParamValue from Params where ParamName=\"ALWAYSPASS\" and ParamSet=$paramSet")!=SQLITE_ROW)
@@ -170,6 +172,11 @@
+ else
+ $bAlwaysPass = true;
+ $passReason = $this->vm->GetString("ParamValue");
if ($_POST['output']=="html")
@@ -181,7 +188,9 @@
else
- HtmlPrinter::AddResultRow($operation, $outcome, $paramSet);
+ HtmlPrinter::AddResultRow($operation, $outcome, $paramSet, $resultData, $expectedResult);
+ //$str = sprintf("\n****ACTUAL RESULT****\n%s\n****EXPECTED RESULT****\n%s\n********\n\n\n", $resultData, $expectedResult);
+ //fwrite($file, $str);
else
@@ -193,6 +202,21 @@
echo $str;
+ else
+ if ($bAlwaysPass)
+ echo "Test (ParamSet: $paramSet) set to ALWAYSPASS: ".$passReason;
+ echo "\n";
+ else
+ echo "<br/>";
return $exitStatus;
@@ -215,6 +239,8 @@
//Get the extension for the dump file based on the content type of the result
$actualExtension = ValidateUtils::GetExtension($contentType);
+ $passReason = "";
//If ALWAYSPASS parameter is defined the the whole validation is skipped.
//This parameter should only be used for clean up operations that are no related to the test
@@ -348,6 +374,11 @@
+ else
@@ -360,6 +391,8 @@
else
else
@@ -371,6 +404,21 @@
echo $str;
+ else
+ if ($bAlwaysPass)
+ echo "\n";
+ else
+ echo "<br/>";
return $exitStatus;
Modified: sandbox/jng/v30/run_tests.bat
--- sandbox/jng/v30/run_tests.bat 2014-06-15 11:14:08 UTC (rev 8224)
+++ sandbox/jng/v30/run_tests.bat 2014-06-15 17:30:25 UTC (rev 8225)
@@ -77,7 +77,7 @@
:start_php_webserver
if "%START_WEBSERVER%" == "1" (
echo [test]: Starting PHP web server. Waiting %MGSERVER_WAIT%s
- start php -n -d display_errors=Off -d upload_max_filesize=20M -d extension_dir="%PHP_EXT_DIR%" -d extension=php_mbstring.dll -d extension=php_curl.dll -d extension=php_MapGuideApi.dll -d extension=php_SQLitePhpApi.dll -S %SERVER_ADDR%:%SERVER_PORT% -t %CD%\UnitTest\WebTier\MapAgent\MapAgentForms %CD%\UnitTest\WebTier\Php\MapAgentShim\index.php
+ start php -n -d display_errors=Off -d upload_max_filesize=20M -d extension_dir="%PHP_EXT_DIR%" -d extension=php_mbstring.dll -d extension=php_curl.dll -d extension=php_MapGuideApi.dll -S %SERVER_ADDR%:%SERVER_PORT% -t %CD%\UnitTest\WebTier\MapAgent\MapAgentForms %CD%\UnitTest\WebTier\Php\MapAgentShim\index.php
ping -n %MGSERVER_WAIT% 127.0.0.1 > NUL
:test_php
@@ -98,7 +98,7 @@
if exist ResourceService\ResourceServiceTest.db del /F ResourceService\ResourceServiceTest.db
popd
pushd UnitTest\WebTier\Php
- php.exe -n -d display_errors=Off -d extension_dir="%PHP_EXT_DIR%" -d extension=php_mbstring.dll -d extension=php_curl.dll -d extension=php_MapGuideApi.dll -d extension=php_SQLitePhpApi.dll RunTests.php
+ php.exe -n -d display_errors=Off -d extension_dir="%PHP_EXT_DIR%" -d extension=php_mbstring.dll -d extension=php_curl.dll -d extension=php_MapGuideApi.dll -d extension=php_pdo_sqlite.dll RunTests.php
popd
:test_dotnet
More information about the mapguide-commits
