[mapguide-commits] r8231 - in branches/2.6/MgDev: . Doc Oem Oem/ACE/ACE_wrappers Oem/ACE/ACE_wrappers/lib Oem/CppUnit-1.9.14 Oem/CppUnit-1.9.14/src Oem/CppUnit-1.9.14/src/cppunit Oem/DWFTK7.1/develop/global Oem/DWFTK7.1/develop/global/build/VS/DWFCore Oem/DWFTK7.1/develop/global/build/VS/DWFEMapToolkit Oem/DWFTK7.1/develop/global/build/VS/DWFToolkit Oem/DWFTK7.1/develop/global/build/VS/W3DToolkit Oem/DWFTK7.1/develop/global/build/VS/WhipToolkit Oem/FDO Oem/LinuxApt Oem/SQLite Oem/SQLite/src/SQLitePhpApi Oem/SQLite/src/SqliteGUI Oem/dbxml Oem/dbxml/db-4.8.26/build_windows Oem/dbxml/dbxml/build_windows Oem/dbxml/xerces-c-src/Build Oem/dbxml/xqilla Oem/gd/build/win32/gd Oem/gd/freetype/objs Oem/gd/jpeg Oem/gd/lpng/projects/vs Oem/geos-2.2.0/VisualStudio Oem/jsoncpp Server Server/src/PostBuild UnitTest/TestData/Samples/Sheboygan UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data Web/src/DotNetApi Web/src/DotNetApi/Foundation Web/src/DotNetApi/Geometry Web/src/DotNetApi/MapG uideCommon Web/src/DotNetApi/PlatformBase Web/src/DotNetApi/Web Web/src/DotNetUnmanagedApi/Foundation Web/src/DotNetUnmanagedApi/Geometry Web/src/DotNetUnmanagedApi/MapGuideCommon Web/src/DotNetUnmanagedApi/PlatformBase Web/src/DotNetUnmanagedApi/Web Web/src/JavaApi Web/src/JavaApi/org/osgeo/mapguide Web/src/JavaApiEx Web/src/JavaApiEx/org/osgeo/mapguide Web/src/PhpApi Web/src/PostBuild Web/src/WEB-INF/lib Web/src/mapadmin Web/src/mapagent Web/src/mapagent64 Web/src/mapviewerphp
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Jun 16 19:54:48 PDT 2014
Author: jng
Date: 2014-06-16 19:54:48 -0700 (Mon, 16 Jun 2014)
New Revision: 8231
   branches/2.6/MgDev/
   branches/2.6/MgDev/Doc/
   branches/2.6/MgDev/Oem/
   branches/2.6/MgDev/Oem/ACE/ACE_wrappers/
   branches/2.6/MgDev/Oem/ACE/ACE_wrappers/lib/
   branches/2.6/MgDev/Oem/CppUnit-1.9.14/
   branches/2.6/MgDev/Oem/CppUnit-1.9.14/src/
   branches/2.6/MgDev/Oem/CppUnit-1.9.14/src/cppunit/
   branches/2.6/MgDev/Oem/DWFTK7.1/develop/global/
   branches/2.6/MgDev/Oem/DWFTK7.1/develop/global/build/VS/DWFCore/
   branches/2.6/MgDev/Oem/DWFTK7.1/develop/global/build/VS/DWFEMapToolkit/
   branches/2.6/MgDev/Oem/DWFTK7.1/develop/global/build/VS/DWFToolkit/
   branches/2.6/MgDev/Oem/DWFTK7.1/develop/global/build/VS/W3DToolkit/
   branches/2.6/MgDev/Oem/DWFTK7.1/develop/global/build/VS/WhipToolkit/
   branches/2.6/MgDev/Oem/FDO/
   branches/2.6/MgDev/Oem/LinuxApt/
   branches/2.6/MgDev/Oem/SQLite/
   branches/2.6/MgDev/Oem/SQLite/src/SQLitePhpApi/
   branches/2.6/MgDev/Oem/SQLite/src/SqliteGUI/
   branches/2.6/MgDev/Oem/dbxml/
   branches/2.6/MgDev/Oem/dbxml/db-4.8.26/build_windows/
   branches/2.6/MgDev/Oem/dbxml/dbxml/build_windows/
   branches/2.6/MgDev/Oem/dbxml/xerces-c-src/Build/
   branches/2.6/MgDev/Oem/dbxml/xqilla/
   branches/2.6/MgDev/Oem/gd/build/win32/gd/
   branches/2.6/MgDev/Oem/gd/freetype/objs/
   branches/2.6/MgDev/Oem/gd/jpeg/
   branches/2.6/MgDev/Oem/gd/lpng/projects/vs/
   branches/2.6/MgDev/Oem/geos-2.2.0/VisualStudio/
   branches/2.6/MgDev/Oem/jsoncpp/
   branches/2.6/MgDev/Server/
   branches/2.6/MgDev/Server/src/PostBuild/
   branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/
   branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data/
   branches/2.6/MgDev/Web/src/DotNetApi/
   branches/2.6/MgDev/Web/src/DotNetApi/Foundation/
   branches/2.6/MgDev/Web/src/DotNetApi/Geometry/
   branches/2.6/MgDev/Web/src/DotNetApi/MapGuideCommon/
   branches/2.6/MgDev/Web/src/DotNetApi/PlatformBase/
   branches/2.6/MgDev/Web/src/DotNetApi/Web/
   branches/2.6/MgDev/Web/src/DotNetUnmanagedApi/Foundation/
   branches/2.6/MgDev/Web/src/DotNetUnmanagedApi/Geometry/
   branches/2.6/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/
   branches/2.6/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/
   branches/2.6/MgDev/Web/src/DotNetUnmanagedApi/Web/
   branches/2.6/MgDev/Web/src/JavaApi/
   branches/2.6/MgDev/Web/src/JavaApi/org/osgeo/mapguide/
   branches/2.6/MgDev/Web/src/JavaApiEx/
   branches/2.6/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide/
   branches/2.6/MgDev/Web/src/PhpApi/
   branches/2.6/MgDev/Web/src/PostBuild/
   branches/2.6/MgDev/Web/src/WEB-INF/lib/
   branches/2.6/MgDev/Web/src/mapadmin/
   branches/2.6/MgDev/Web/src/mapagent/
   branches/2.6/MgDev/Web/src/mapagent64/
   branches/2.6/MgDev/Web/src/mapviewerphp/
Merged revision(s) 8210 from trunk/MgDev:
#2456: Update svn ignore lists of various directories in the MapGuide source tree. The only things not touched are svn external directories and SWIG-generated java and C# source files. I don't think there's an applicable wildcard that will selectively ignore the files we're not interested in due to the unfortunate location these files are generated in.
Property changes on: branches/2.6/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/createruntimemap:7486-7555
/sandbox/rfc94:5099-5163
   + /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8210
Property changes on: branches/2.6/MgDev/Doc
Added: svn:ignore
   + MgOpensource_WebAPIReference
MGOpenSource_run_log.txt
MgOpensource_warn_log.txt
Property changes on: branches/2.6/MgDev/Oem
Added: svn:ignore
   + oem.sdf
*.suo
Property changes on: branches/2.6/MgDev/Oem/ACE/ACE_wrappers
Added: svn:ignore
   + obj
lib64
obj64
Property changes on: branches/2.6/MgDev/Oem/ACE/ACE_wrappers/lib
Added: svn:ignore
   + Release
Property changes on: branches/2.6/MgDev/Oem/CppUnit-1.9.14
Modified: svn:ignore
   - lib
   + lib
lib64
Property changes on: branches/2.6/MgDev/Oem/CppUnit-1.9.14/src
Added: svn:ignore
   + obj
obj64
Property changes on: branches/2.6/MgDev/Oem/CppUnit-1.9.14/src/cppunit
Added: svn:ignore
   + Release
Release64
Property changes on: branches/2.6/MgDev/Oem/DWFTK7.1/develop/global
Added: svn:ignore
   + lib
Property changes on: branches/2.6/MgDev/Oem/DWFTK7.1/develop/global/build/VS/DWFCore
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Oem/DWFTK7.1/develop/global/build/VS/DWFEMapToolkit
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Oem/DWFTK7.1/develop/global/build/VS/DWFToolkit
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Oem/DWFTK7.1/develop/global/build/VS/W3DToolkit
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Oem/DWFTK7.1/develop/global/build/VS/WhipToolkit
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Oem/FDO
Added: svn:ignore
   + Bin
Inc
Lib
Lib64
Property changes on: branches/2.6/MgDev/Oem/LinuxApt
Added: svn:ignore
   + httpd-2.4.9
php-5.5.11
*.tar
Property changes on: branches/2.6/MgDev/Oem/SQLite
Added: svn:ignore
   + bin
lib
obj
Property changes on: branches/2.6/MgDev/Oem/SQLite/src/SQLitePhpApi
Added: svn:ignore
   + language.i
php_SQLitePhpApi.h
SQLitePhpApi.i
SQLitePhpApi.php
SQLitePhpApi_Doc.i
SQLitePhpApi_wrap.cpp
Property changes on: branches/2.6/MgDev/Oem/SQLite/src/SqliteGUI
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Oem/dbxml
Added: svn:ignore
   + bin
include
jar
lib
bin64
jar64
lib64
Property changes on: branches/2.6/MgDev/Oem/dbxml/db-4.8.26/build_windows
Added: svn:ignore
   + Release
Release64
Property changes on: branches/2.6/MgDev/Oem/dbxml/dbxml/build_windows
Added: svn:ignore
   + Release
Release64
Property changes on: branches/2.6/MgDev/Oem/dbxml/xerces-c-src/Build
Added: svn:ignore
   + Release
Release64
Property changes on: branches/2.6/MgDev/Oem/dbxml/xqilla
Added: svn:ignore
   + build
Property changes on: branches/2.6/MgDev/Oem/gd/build/win32/gd
Added: svn:ignore
   + Release
Release64
Property changes on: branches/2.6/MgDev/Oem/gd/freetype/objs
Added: svn:ignore
   + Release
Release64
Property changes on: branches/2.6/MgDev/Oem/gd/jpeg
Added: svn:ignore
   + Release
Release64
Property changes on: branches/2.6/MgDev/Oem/gd/lpng/projects/vs
Added: svn:ignore
   + obj
LIB Release
Release
Release64
Property changes on: branches/2.6/MgDev/Oem/geos-2.2.0/VisualStudio
Added: svn:ignore
   + Release
Release64
Property changes on: branches/2.6/MgDev/Oem/jsoncpp
Added: svn:ignore
   + lib
obj
lib64
obj64
Property changes on: branches/2.6/MgDev/Server
Added: svn:ignore
   + bin
lib
obj
*.suo
Property changes on: branches/2.6/MgDev/Server/src/PostBuild
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan
Added: svn:ignore
   + Sheboygan.mgp
Property changes on: branches/2.6/MgDev/UnitTest/TestData/Samples/Sheboygan/Library/Samples/Sheboygan/Data
Added: svn:ignore
   + BuildingOutlines.FeatureSource_DATA_BuildingOutlines.sdf
CityLimits.FeatureSource_DATA_CityLimits.sdf
HydrographicPolygons.FeatureSource_DATA_HydrographicPolygons.sdf
Parcels.FeatureSource_DATA_Parcels.sdf
Rail.FeatureSource_DATA_Rail.sdf
RoadCenterLines.FeatureSource_DATA_RoadCenterLines.sdf
VotingDistricts.FeatureSource_DATA_VotingDistricts.sdf
Property changes on: branches/2.6/MgDev/Web/src/DotNetApi
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Web/src/DotNetApi/Foundation
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Web/src/DotNetApi/Geometry
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Web/src/DotNetApi/MapGuideCommon
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Web/src/DotNetApi/PlatformBase
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Web/src/DotNetApi/Web
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Web/src/DotNetUnmanagedApi/Foundation
Added: svn:ignore
   + FoundationApi.i
FoundationApi_Doc.i
language.i
MgFoundationApi_wrap.cpp
Property changes on: branches/2.6/MgDev/Web/src/DotNetUnmanagedApi/Geometry
Added: svn:ignore
   + GeometryApi.i
GeometryApi_Doc.i
language.i
MgGeometryApi_wrap.cpp
Property changes on: branches/2.6/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon
Added: svn:ignore
   + language.i
MapGuideCommonApi.i
MapGuideCommonApi_Doc.i
MgMapGuideCommonApi_wrap.cpp
Property changes on: branches/2.6/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase
Added: svn:ignore
   + language.i
MgPlatformBaseApi_wrap.cpp
PlatformBaseApi.i
PlatformBaseApi_Doc.i
Property changes on: branches/2.6/MgDev/Web/src/DotNetUnmanagedApi/Web
Added: svn:ignore
   + language.i
MapGuideApi.i
MgWebApi_wrap.cpp
WebApi_Doc.i
Property changes on: branches/2.6/MgDev/Web/src/JavaApi
Added: svn:ignore
   + language.i
MapGuideApi.i
MapGuideApi_Doc.i
MgApi_wrap.cpp
Property changes on: branches/2.6/MgDev/Web/src/JavaApi/org/osgeo/mapguide
Added: svn:ignore
   + *.class
Property changes on: branches/2.6/MgDev/Web/src/JavaApiEx
Added: svn:ignore
   + language.i
MapGuideApi.i
MapGuideApi_Doc.i
MgApi_wrap.cpp
Property changes on: branches/2.6/MgDev/Web/src/JavaApiEx/org/osgeo/mapguide
Added: svn:ignore
   + *.class
Property changes on: branches/2.6/MgDev/Web/src/PhpApi
Added: svn:ignore
   + constants.php
language.i
MapGuideApi.i
MapGuideApi.php
MapGuideApi_Doc.i
MgApi_wrap.cpp
php_MapGuideApi.h
Property changes on: branches/2.6/MgDev/Web/src/PostBuild
Added: svn:ignore
   + obj
Property changes on: branches/2.6/MgDev/Web/src/WEB-INF/lib
Added: svn:ignore
   + MapGuideApi-sources.jar
MapGuideApi.jar
MapGuideApiEx-sources.jar
MapGuideApiEx.jar
Property changes on: branches/2.6/MgDev/Web/src/mapadmin
   - ProfilingAPI_GUI_part1.patch
   + ProfilingAPI_GUI_part1.patch
constants.php
Property changes on: branches/2.6/MgDev/Web/src/mapagent
Added: svn:ignore
   + Resources
isapi_MapAgent.dll
isapi_MapAgent.pdb
MapAgent.exe
MapAgent.pdb
mod_mgmapagent.exp
mod_mgmapagent.lib
mod_mgmapagent.pdb
Property changes on: branches/2.6/MgDev/Web/src/mapagent64
Added: svn:ignore
   + Resources
isapi_MapAgent.dll
isapi_MapAgent.pdb
MapAgent.exe
MapAgent.pdb
mod_mgmapagent.exp
mod_mgmapagent.lib
mod_mgmapagent.pdb
Property changes on: branches/2.6/MgDev/Web/src/mapviewerphp
Added: svn:ignore
   + constants.php
More information about the mapguide-commits mailing list
