[mapguide-commits] r8236 - in trunk/MgDev: . Doc/devguide/source Doc/samples/dotnetviewersample/findaddress Doc/samples/dotnetviewersample/plot Doc/samples/dotnetviewersample/query/classes Doc/samples/dotnetviewersample/theme/classes Doc/samples/javasamples/hello_map Doc/samples/javasamples/interacting_with_layers Doc/samples/javaviewersample/findaddress Doc/samples/javaviewersample/plot Doc/samples/javaviewersample/query/classes Doc/samples/javaviewersample/theme/classes Doc/samples/phpsamples/analyzing_features Doc/samples/phpsamples/common Doc/samples/phpsamples/custom_output Doc/samples/phpsamples/modifying_maps_and_layers Doc/samples/phpsamples/working_with_feature_data Doc/samples/phpviewersample Doc/samples/phpviewersample/findaddress Doc/samples/phpviewersample/plot Doc/samples/phpviewersample/query/classes Doc/samples/phpviewersample/theme/classes UnitTest/Common/DotNetWrappers UnitTest/WebTier/DotNet/TestMapGuideApi UnitTest/WebTier/Php Web/src/mapadmin Web/src/mapviewerjava Web/src/mapviewernet Web/src/mapviewerphp
svn_mapguide at osgeo.org
Tue Jun 17 03:16:52 PDT 2014
Author: jng
Date: 2014-06-17 03:16:51 -0700 (Tue, 17 Jun 2014)
New Revision: 8236
Added:
trunk/MgDev/Doc/samples/phpviewersample/composer.json
trunk/MgDev/Doc/samples/phpviewersample/vendor/
trunk/MgDev/UnitTest/WebTier/Php/SQLiteEngine.php
trunk/MgDev/UnitTest/WebTier/Php/UpdateDumpFiles.php
Removed:
trunk/MgDev/Doc/samples/phpviewersample/findaddress/kd_xmlrpc.php
trunk/MgDev/
trunk/MgDev/Doc/devguide/source/interacting_with_layers.rst
trunk/MgDev/Doc/devguide/source/introduction.rst
trunk/MgDev/Doc/devguide/source/modifying_maps_and_layers.rst
trunk/MgDev/Doc/samples/dotnetviewersample/findaddress/clearaddressresults.aspx
trunk/MgDev/Doc/samples/dotnetviewersample/findaddress/findaddress.aspx
trunk/MgDev/Doc/samples/dotnetviewersample/findaddress/findaddressmain.aspx
trunk/MgDev/Doc/samples/dotnetviewersample/plot/plot.aspx
trunk/MgDev/Doc/samples/dotnetviewersample/plot/plotmain.aspx
trunk/MgDev/Doc/samples/dotnetviewersample/query/classes/query.aspx
trunk/MgDev/Doc/samples/dotnetviewersample/theme/classes/theme.aspx
trunk/MgDev/Doc/samples/javasamples/hello_map/display_spatial_reference.jsp
trunk/MgDev/Doc/samples/javasamples/interacting_with_layers/layer_visibility.jsp
trunk/MgDev/Doc/samples/javasamples/interacting_with_layers/toggle_roads_label.jsp
trunk/MgDev/Doc/samples/javaviewersample/findaddress/clearaddressresults.jsp
trunk/MgDev/Doc/samples/javaviewersample/findaddress/findaddress.jsp
trunk/MgDev/Doc/samples/javaviewersample/findaddress/findaddressmain.jsp
trunk/MgDev/Doc/samples/javaviewersample/plot/plot.jsp
trunk/MgDev/Doc/samples/javaviewersample/plot/plotmain.jsp
trunk/MgDev/Doc/samples/javaviewersample/query/classes/query.jsp
trunk/MgDev/Doc/samples/javaviewersample/theme/classes/theme.jsp
trunk/MgDev/Doc/samples/phpsamples/analyzing_features/bufferfunctions.php
trunk/MgDev/Doc/samples/phpsamples/common/common.php
trunk/MgDev/Doc/samples/phpsamples/custom_output/createmapimage.php
trunk/MgDev/Doc/samples/phpsamples/custom_output/eplot.php
trunk/MgDev/Doc/samples/phpsamples/custom_output/multiplot.php
trunk/MgDev/Doc/samples/phpsamples/custom_output/property_report.php
trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php
trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php
trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php
trunk/MgDev/Doc/samples/phpviewersample/findaddress/clearaddressresults.php
trunk/MgDev/Doc/samples/phpviewersample/findaddress/findaddress.php
trunk/MgDev/Doc/samples/phpviewersample/findaddress/findaddressfunctions.php
trunk/MgDev/Doc/samples/phpviewersample/findaddress/findaddressmain.php
trunk/MgDev/Doc/samples/phpviewersample/plot/plot.php
trunk/MgDev/Doc/samples/phpviewersample/plot/plotmain.php
trunk/MgDev/Doc/samples/phpviewersample/query/classes/query.php
trunk/MgDev/Doc/samples/phpviewersample/theme/classes/theme.php
trunk/MgDev/UnitTest/Common/DotNetWrappers/CollectionTest.cs
trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs
trunk/MgDev/UnitTest/WebTier/Php/HtmlPrinter.php
trunk/MgDev/UnitTest/WebTier/Php/MapLayerAPI.php
trunk/MgDev/UnitTest/WebTier/Php/Run.php
trunk/MgDev/UnitTest/WebTier/Php/RunTests.php
trunk/MgDev/UnitTest/WebTier/Php/Utils.php
trunk/MgDev/UnitTest/WebTier/Php/Validate.php
trunk/MgDev/UnitTest/WebTier/Php/testAwSelection.php
trunk/MgDev/Web/src/mapadmin/performanceReport_GetResult.php
trunk/MgDev/Web/src/mapviewerjava/buffer.jsp
trunk/MgDev/Web/src/mapviewerjava/legend.jsp
trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp
trunk/MgDev/Web/src/mapviewerjava/measure.jsp
trunk/MgDev/Web/src/mapviewerjava/quickplotgeneratepicture.jsp
trunk/MgDev/Web/src/mapviewerjava/search.jsp
trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp
trunk/MgDev/Web/src/mapviewerjava/setselection.jsp
trunk/MgDev/Web/src/mapviewernet/buffer.aspx
trunk/MgDev/Web/src/mapviewernet/legend.aspx
trunk/MgDev/Web/src/mapviewernet/mapframe.aspx
trunk/MgDev/Web/src/mapviewernet/measure.aspx
trunk/MgDev/Web/src/mapviewernet/quickplotgeneratepicture.aspx
trunk/MgDev/Web/src/mapviewernet/search.aspx
trunk/MgDev/Web/src/mapviewernet/selectwithin.aspx
trunk/MgDev/Web/src/mapviewernet/setselection.aspx
trunk/MgDev/Web/src/mapviewerphp/buffer.php
trunk/MgDev/Web/src/mapviewerphp/legend.php
trunk/MgDev/Web/src/mapviewerphp/mapframe.php
trunk/MgDev/Web/src/mapviewerphp/measure.php
trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php
trunk/MgDev/Web/src/mapviewerphp/search.php
trunk/MgDev/Web/src/mapviewerphp/selectwithin.php
trunk/MgDev/Web/src/mapviewerphp/setselection.php
trunk/MgDev/run_tests.bat
trunk/MgDev/updateversion.vbs
Merged revision(s) 8212, 8214, 8217, 8220-8221, 8223-8225 from sandbox/jng/v30:
Fix updateversion.vbs not version stamping profiling service dll.
Fix updateversion.vbs also not version stamping the enhanced Java wrapper
Fix updateversion.vbs also not version stamping the enhanced Java wrapper for mg-desktop
Now for the big one: MgMap and its family of deprecated APIs.
Before we do the actual API removal from MgMap, this submission includes modifications to various .net/PHP/Java sample code and actual code to no longer use MgMap's set of deprecated API. At the same time, various bits of sample code have been cleaned up to:
- Use the recommended coding patterns when working with layers as suggested by MapGuide RFC9 (ie. Using the convenience methods of MgLayerBase and MgSelectionBase instead of going to the MgFeatureService directly)
- Fix various PHP warnings due to now using PHP 5.5
- Replace the broken kd_xmlrpc.php with fXmlRpc (https://github.com/lstrojny/fxmlrpc) for the PHP address search sample.
Even if the PSC has decided these APIs I'm currently removing in this sandbox should stay, this submission is still worth merging back into trunk and relevant branches as it updates the various sample code to reflect proper API usage.
Update .net test runner to not use deprecated MgMap APIs
Fix HtmlPrinter syntax
PHP test runner updates:
- Add an overwrite flag to Utils::CreateDumpFile()
- Add a new UpdateDumpFiles.php whose sole purpose is to update dump files from their respective dbs. This presents a simpler way of updating test database source without having to run the test runner through the whole suite in "generate" mode.
PHP test runner improvements:
- Fix PHP warnings in HtmlPrinter
- Add a PHP implementation of SqliteDB and SqliteVM (based on PDO). This is used by run_tests.bat to avoid random access violations that seem to be happening in my test runs. The existing SWIG PHP wrapper is still required for dump file generation/updates.
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/createruntimemap:7486-7555
/sandbox/rfc94:5099-5163
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/v30:8212,8214,8217,8220-8221,8223-8225
Modified: trunk/MgDev/Doc/devguide/source/interacting_with_layers.rst
--- trunk/MgDev/Doc/devguide/source/interacting_with_layers.rst 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/devguide/source/interacting_with_layers.rst 2014-06-17 10:16:51 UTC (rev 8236)
@@ -285,9 +285,6 @@
Example
-.. todo::
- Update code samples to not use MgMap() ctor. That is deprecated.
The following example toggles the label of the Roads layer between Roads and
Streets.
@@ -301,10 +298,8 @@
$userInfo = new MgUserInformation($mgSessionId);
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
- $resourceService =
- $siteConnection->CreateService(MgServiceType::ResourceService);
- $map = new MgMap();
- $map->Open($resourceService, $mgMapName);
+ $map = new MgMap($siteConnection);
+ $map->Open($mgMapName);
$layers = $map->GetLayers();
$roadLayer = $layers->GetItem('Roads');
$roadLabel = $roadLayer->GetLegendLabel();
@@ -316,7 +311,7 @@
// You must save the updated map or the
// changes will not be applied
// Also be sure to refresh the map on page load.
- $map->Save($resourceService);
+ $map->Save();
**.net (C#)**
@@ -328,9 +323,8 @@
MgUserInformation userInfo = new MgUserInformation(mgSessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
- MgResourceService resourceService = (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
- MgMap map = new MgMap();
- map.Open(resourceService, mgMapName);
+ MgMap map = new MgMap(siteConnection);
+ map.Open(mgMapName);
MgLayerCollection layers = map.GetLayers();
MgLayer roadLayer = layers.GetItem("Roads");
String roadLabel = roadLayer.GetLegendLabel();
@@ -341,7 +335,7 @@
- map.Save(resourceService);
+ map.Save();
**Java**
@@ -353,9 +347,8 @@
@@ -366,7 +359,6 @@
.. index::
single: Layers; Changing Visibility
Modified: trunk/MgDev/Doc/devguide/source/introduction.rst
--- trunk/MgDev/Doc/devguide/source/introduction.rst 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/devguide/source/introduction.rst 2014-06-17 10:16:51 UTC (rev 8236)
@@ -209,10 +209,15 @@
.. highlight:: php
.. code-block:: php
+ $siteConnection = new MgSiteConnection();
+ $userInfo = new MgUserInformation($sessionId);
+ $siteConnection->Open();
+ $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
$mapDefId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
$mapName = $mapDefId->GetName();
- $map->Create($resourceService, $mapDefId, $mapName);
+ $map->Create($mapDefId, $mapName);
$mapId = new MgResourceIdentifier("Session:$sessionId//$mapName." . MgResourceType::Map);
$map->Save($resourceService, $mapId);
@@ -222,12 +227,16 @@
.. code-block:: csharp
//Note: This code fragment assumes you have imported the OSGeo.MapGuide namespace
+ MgSiteConnection siteConnection = new MgSiteConnection();
+ MgUserInformation userInfo = new MgUserInformation(sessionId);
+ siteConnection.Open(userInfo);
+ MgResourceService resourceService = (MgResourceService)siteConnection.CreateService(MgServiceType::ResourceService);
MgResourceIdentifier mapDefId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
String mapName = mapDefId.GetName();
- map.Create(resourceService, mapDefId, mapName);
- MgResourceIdentifier mapId = new MgResourceIdentifier("Session:$sessionId//$mapName." + MgResourceType.Map);
+ map.Create(mapDefId, mapName);
+ MgResourceIdentifier mapId = new MgResourceIdentifier("Session:" + sessionId + "//" + mapName + "." + MgResourceType.Map);
map.Save(resourceService, mapId);
**Java**
@@ -236,12 +245,16 @@
.. code-block:: java
//Note: This code fragment assumes you have imported the org.osgeo.mapguide package
.. index::
@@ -490,13 +503,9 @@
- // Get an instance of the required service(s).
- $resourceService = $siteConnection->
- CreateService(MgServiceType::ResourceService);
// Display the spatial reference system used for the map.
$srs = $map->GetMapSRS();
echo 'Map <strong>' . $map->GetName() .
'</strong> uses this reference system: <br />' . $srs;
Modified: trunk/MgDev/Doc/devguide/source/modifying_maps_and_layers.rst
--- trunk/MgDev/Doc/devguide/source/modifying_maps_and_layers.rst 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/devguide/source/modifying_maps_and_layers.rst 2014-06-17 10:16:51 UTC (rev 8236)
@@ -92,8 +92,8 @@
// (initialization etc. not shown here)
// Open the map
- $map->Open($resourceService, $mapName);
+ $map->Open($mapName);
// Load a layer from XML, and use the DOM to change it
// Load the prototype layer definition into
Modified: trunk/MgDev/Doc/samples/dotnetviewersample/findaddress/clearaddressresults.aspx
--- trunk/MgDev/Doc/samples/dotnetviewersample/findaddress/clearaddressresults.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/dotnetviewersample/findaddress/clearaddressresults.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -50,20 +50,14 @@
featureService.UpdateFeatures(addressMarkerDataResId, commands, false);
- // Create a ReserviceService object and use it to open the Map
- // object from the sessions repository. Use the Map object to hide
- // the "ParcelMarker" layer and then save the updated Map back to
- // the session.
+ map.Open("Sheboygan");
- MgResourceService resourceService = siteConnection.CreateService(MgServiceType.ResourceService) as MgResourceService;
- map.Open(resourceService, "Sheboygan");
MgLayer layer = GetLayerByName(map, "AddressMarker");
layer.SetVisible(false);
layer.ForceRefresh();
+ map.Save();
catch (MgException mge)
Modified: trunk/MgDev/Doc/samples/dotnetviewersample/findaddress/findaddress.aspx
--- trunk/MgDev/Doc/samples/dotnetviewersample/findaddress/findaddress.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/dotnetviewersample/findaddress/findaddress.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -85,8 +85,8 @@
MgFeatureService featureService = (MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
// Check the map for the AddressMarker layer. If it does not
// exist then create a feature source to store address results
@@ -129,7 +129,7 @@
addressLayer.SetVisible(true);
addressLayer.ForceRefresh();
+ map.Save();
success = true;
Modified: trunk/MgDev/Doc/samples/dotnetviewersample/findaddress/findaddressmain.aspx
--- trunk/MgDev/Doc/samples/dotnetviewersample/findaddress/findaddressmain.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/dotnetviewersample/findaddress/findaddressmain.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -31,12 +31,12 @@
<script language="javascript">
function Submit()
- var addressForm = document.getElementById("addressForm");
- var addressValue = document.getElementById("addressValue");
- var addressInput = document.getElementById("addressInput");
- addressValue.value = addressInput.value;
- addressForm.submit();
+ var addressForm = document.getElementById("addressForm");
+ var addressValue = document.getElementById("addressValue");
+ var addressInput = document.getElementById("addressInput");
+ addressValue.value = addressInput.value;
+ addressForm.submit();
</script>
</head>
@@ -59,13 +59,8 @@
- // determine if the "AddressMarker" layer is visible.
MgLayer addressLayer = GetLayerByName(map, "AddressMarker");
if (addressLayer != null)
Modified: trunk/MgDev/Doc/samples/dotnetviewersample/plot/plot.aspx
--- trunk/MgDev/Doc/samples/dotnetviewersample/plot/plot.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/dotnetviewersample/plot/plot.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -32,13 +32,9 @@
- // Create an instance of ResourceService and use that to open the
- // current map instance stored in session state.
// Now create an instance of MappingService and use it to plot the
// current view of the map.
Modified: trunk/MgDev/Doc/samples/dotnetviewersample/plot/plotmain.aspx
--- trunk/MgDev/Doc/samples/dotnetviewersample/plot/plotmain.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/dotnetviewersample/plot/plotmain.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -87,15 +87,9 @@
- // determine the current scale of the map for display on this
- // page.
viewCenter = map.GetViewCenter();
viewScale = map.GetViewScale();
Modified: trunk/MgDev/Doc/samples/dotnetviewersample/query/classes/query.aspx
--- trunk/MgDev/Doc/samples/dotnetviewersample/query/classes/query.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/dotnetviewersample/query/classes/query.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -61,9 +61,8 @@
public ArrayList GetMapLayerNames()
- MgResourceService resourceService = (MgResourceService)this.site.CreateService(MgServiceType.ResourceService);
- map.Open(resourceService, GetParameter(this.args, "MAPNAME"));
+ MgMap map = new MgMap(this.site);
+ map.Open(GetParameter(this.args, "MAPNAME"));
ArrayList layerNames = new ArrayList();
@@ -86,17 +85,12 @@
public ArrayList GetLayerProperties()
ArrayList properties = new ArrayList();
MgLayer layer = (MgLayer) map.GetLayers().GetItem(GetParameter(this.args, "LAYERNAME"));
- MgFeatureService featureService = (MgFeatureService)this.site.CreateService(MgServiceType.FeatureService);
- MgResourceIdentifier resId = new MgResourceIdentifier(layer.GetFeatureSourceId());
- String[] schemaClass = layer.GetFeatureClassName().Split(new Char[]{':'});
+ MgClassDefinition classDef = layer.GetClassDefinition();
- MgClassDefinition classDef = featureService.GetClassDefinition(resId, schemaClass[0], schemaClass[1]);
for(int i=0; i<classDef.GetProperties().GetCount(); i++)
MgPropertyDefinition propertyDef = classDef.GetProperties().GetItem(i);
@@ -117,9 +111,8 @@
public bool ToggleSpatialFilter()
bool result = true;
if(layers.Contains("_QuerySpatialFilter"))
@@ -130,7 +123,7 @@
else
+ map.Save();
return result;
@@ -146,8 +139,8 @@
MgFeatureCommandCollection updateCommands = new MgFeatureCommandCollection();
MgLayer layer = null;
@@ -207,21 +200,19 @@
public ArrayList Execute()
ArrayList result = new ArrayList();
- String featureClass = layer.GetFeatureClassName();
String featureGeometry = layer.GetFeatureGeometryName();
// Initialize the coordinate system transform
MgGeometricPropertyDefinition geomProp = (MgGeometricPropertyDefinition) classDef.GetProperties().GetItem(featureGeometry);
String spatialContext = geomProp.GetSpatialContextAssociation();
@@ -271,7 +262,7 @@
int count = 0;
MgAgfReaderWriter geometryReaderWriter = new MgAgfReaderWriter();
- MgFeatureReader featureReader = featureService.SelectFeatures(resId, layer.GetFeatureClassName(), queryOptions);
+ MgFeatureReader featureReader = layer.SelectFeatures(queryOptions);
while(featureReader.ReadNext() && (queryMax <= 0 || count < queryMax))
MgByteReader byteReader = featureReader.GetGeometry(featureGeometry);
@@ -289,17 +280,12 @@
public String GetSelectionXML()
MgPropertyCollection properties = new MgPropertyCollection();
MgDataPropertyDefinition dataPropDef = null;
Modified: trunk/MgDev/Doc/samples/dotnetviewersample/theme/classes/theme.aspx
--- trunk/MgDev/Doc/samples/dotnetviewersample/theme/classes/theme.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/dotnetviewersample/theme/classes/theme.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -56,23 +56,19 @@
for(int i=0; i<layers.GetCount(); i++)
- MgLayer layer = (MgLayer) layers.GetItem(i);
+ MgLayer layer = (MgLayer) layers.GetItem(i);
if(!layer.GetName().StartsWith("_") && !layer.GetFeatureSourceId().ToUpper().StartsWith("SESSION"))
MgPropertyDefinition propDef = classDef.GetProperties().GetItem(layer.GetFeatureGeometryName());
if(propDef.GetPropertyType() == MgFeaturePropertyType.GeometricProperty)
@@ -98,16 +94,12 @@
@@ -167,15 +159,10 @@
ArrayList propertyMinMaxCount = new ArrayList();
String minValue = null;
String maxValue = null;
int count = 0;
@@ -183,7 +170,7 @@
MgFeatureQueryOptions queryOptions = new MgFeatureQueryOptions();
queryOptions.AddFeatureProperty(GetParameter(this.args, "PROPERTYNAME"));
while(featureReader.ReadNext())
String value = GetFeaturePropertyValue(featureReader, GetParameter(this.args, "PROPERTYNAME"));
@@ -252,8 +239,8 @@
MgLayer layer = (MgLayer) layers.GetItem(GetParameter(this.args, "LAYERNAME"));
@@ -301,7 +288,7 @@
aggregateOptions.AddFeatureProperty(GetParameter(this.args, "PROPERTYNAME"));
aggregateOptions.SelectDistinct(true);
- MgDataReader dataReader = featureService.SelectAggregate(resId, layer.GetFeatureClassName(), aggregateOptions);
+ MgDataReader dataReader = layer.SelectAggregate(aggregateOptions);
while(dataReader.ReadNext())
value = GetFeaturePropertyValue(dataReader, GetParameter(this.args, "PROPERTYNAME"));
@@ -332,7 +319,7 @@
aggregateOptions.AddComputedProperty("THEME_VALUE",
GetParameter(this.args, "DISTRO") + "(\"" + GetParameter(this.args, "PROPERTYNAME") + "\"," + GetParameter(this.args, "NUMRULES") + "," + GetParameter(this.args, "MINVALUE") + "," + GetParameter(this.args, "MAXVALUE") + ")");
value = GetFeaturePropertyValue(dataReader, "THEME_VALUE");
@@ -382,7 +369,7 @@
newLayer.SetSelectable(layer.GetSelectable());
layers.Insert(layers.IndexOf(layer), newLayer);
+ map.Save();
return uniqueName;
Modified: trunk/MgDev/Doc/samples/javasamples/hello_map/display_spatial_reference.jsp
--- trunk/MgDev/Doc/samples/javasamples/hello_map/display_spatial_reference.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/javasamples/hello_map/display_spatial_reference.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -51,17 +51,13 @@
- MgResourceService resourceService = (MgResourceService) siteConnection.CreateService(MgServiceType.ResourceService);
// Finished basic initialization.
// Query the spatial reference system used for the map.
- map.Open(resourceService, mapName);
+ map.Open(mapName);
String srs = map.GetMapSRS();
// Format it and display it in the task pane.
Modified: trunk/MgDev/Doc/samples/javasamples/interacting_with_layers/layer_visibility.jsp
--- trunk/MgDev/Doc/samples/javasamples/interacting_with_layers/layer_visibility.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/javasamples/interacting_with_layers/layer_visibility.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -47,14 +47,10 @@
MgLayerCollection layers = map.GetLayers(); // Get layer collection
out.println("<p>Layers, in draw order:</p>");
out.println("<table class=\"taskPane\" cellspacing=\"0\">");
Modified: trunk/MgDev/Doc/samples/javasamples/interacting_with_layers/toggle_roads_label.jsp
--- trunk/MgDev/Doc/samples/javasamples/interacting_with_layers/toggle_roads_label.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/javasamples/interacting_with_layers/toggle_roads_label.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -59,13 +59,9 @@
@@ -82,7 +78,7 @@
+ map.Save();
out.println("<p>Layer label has been changed to " + newLabel + ".</p>");
Modified: trunk/MgDev/Doc/samples/javaviewersample/findaddress/clearaddressresults.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/findaddress/clearaddressresults.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/javaviewersample/findaddress/clearaddressresults.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -54,20 +54,14 @@
- // the session.
+ map.Save();
catch (MgException e)
Modified: trunk/MgDev/Doc/samples/javaviewersample/findaddress/findaddress.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/findaddress/findaddress.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/javaviewersample/findaddress/findaddress.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -84,8 +84,8 @@
@@ -128,7 +128,7 @@
+ map.Save();
success = true;
Modified: trunk/MgDev/Doc/samples/javaviewersample/findaddress/findaddressmain.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/findaddress/findaddressmain.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/javaviewersample/findaddress/findaddressmain.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -34,12 +34,12 @@
function Submit()
</script>
</head>
@@ -66,9 +66,8 @@
Modified: trunk/MgDev/Doc/samples/javaviewersample/plot/plot.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/plot/plot.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/javaviewersample/plot/plot.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -39,13 +39,9 @@
Modified: trunk/MgDev/Doc/samples/javaviewersample/plot/plotmain.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/plot/plotmain.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/javaviewersample/plot/plotmain.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -41,8 +41,8 @@
useLayoutValue.value = "true";
else
useLayoutValue.value = "false";
- scaleValue.value = "0";
+ scaleValue.value = "0";
plotForm.submit();
function SubmitAtScale()
@@ -95,9 +95,8 @@
// page.
Modified: trunk/MgDev/Doc/samples/javaviewersample/query/classes/query.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/query/classes/query.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/javaviewersample/query/classes/query.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -67,9 +67,8 @@
public ArrayList<String> GetMapLayerNames() throws MgException
- map.Open(resourceService, this.args.get("MAPNAME"));
+ map.Open(this.args.get("MAPNAME"));
ArrayList<String> layerNames = new ArrayList<String>();
@@ -90,17 +89,12 @@
public ArrayList<Property> GetLayerProperties() throws MgException
ArrayList<Property> properties = new ArrayList<Property>();
MgLayer layer = (MgLayer) map.GetLayers().GetItem(this.args.get("LAYERNAME"));
- String[] schemaClass = layer.GetFeatureClassName().split(":");
@@ -121,9 +115,8 @@
public boolean ToggleSpatialFilter() throws MgException
boolean result = true;
@@ -134,7 +127,7 @@
else
+ map.Save();
return result;
@@ -150,8 +143,8 @@
@@ -200,7 +193,7 @@
// Make the layer visible
layer.SetVisible(true);
+ map.Save();
// Add the geometry to the filter feature source
@@ -221,21 +214,18 @@
public ArrayList<Feature> Execute() throws MgException
ArrayList<Feature> result = new ArrayList<Feature>();
@@ -286,7 +276,7 @@
int count = 0;
String displayValue = null;
@@ -351,18 +341,14 @@
public String GetSelectionXML() throws MgException, JSONException
JSONObject json = new JSONObject(this.args.get("IDLIST"));
Modified: trunk/MgDev/Doc/samples/javaviewersample/theme/classes/theme.jsp
--- trunk/MgDev/Doc/samples/javaviewersample/theme/classes/theme.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/javaviewersample/theme/classes/theme.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -33,92 +33,84 @@
public class Theme
- Map<String, String> args = null;
- private MgSiteConnection site = null;
- private String[] distNameArray = null;
- private String[] distValueArray = null;
- public Theme(Map<String, String> incomingArgs) throws MgException
- this.args = incomingArgs;
- this.site = new MgSiteConnection();
- this.site.Open(new MgUserInformation(this.args.get("SESSION")));
- this.distNameArray = new String[] {"Individual", "Equal", "Standard Deviation", "Quantile", "Jenks (Natural Breaks)"};
- this.distValueArray = new String[] {"INDIV_DIST", "EQUAL_DIST", "STDEV_DIST", "QUANT_DIST", "JENK_DIST"};
- public String getNameArray()
- JSONArray jsonArray = new JSONArray();
- for(int i=0;i<5;i++)
- jsonArray.put(distNameArray[i]);
- return jsonArray.toString();
- public String getValueArray()
- jsonArray.put(distValueArray[i]);
+ Map<String, String> args = null;
+ private MgSiteConnection site = null;
+ private String[] distNameArray = null;
+ private String[] distValueArray = null;
+ public Theme(Map<String, String> incomingArgs) throws MgException
+ this.args = incomingArgs;
+ this.site = new MgSiteConnection();
+ this.site.Open(new MgUserInformation(this.args.get("SESSION")));
+ this.distNameArray = new String[] {"Individual", "Equal", "Standard Deviation", "Quantile", "Jenks (Natural Breaks)"};
+ this.distValueArray = new String[] {"INDIV_DIST", "EQUAL_DIST", "STDEV_DIST", "QUANT_DIST", "JENK_DIST"};
+ public String getNameArray()
+ JSONArray jsonArray = new JSONArray();
+ for(int i=0;i<5;i++)
+ jsonArray.put(distNameArray[i]);
+ return jsonArray.toString();
+ public String getValueArray()
+ jsonArray.put(distValueArray[i]);
- MgLayerCollection layers = map.GetLayers();
- ArrayList<String> layerNames = new ArrayList<String>();
+ MgFeatureService featureService = (MgFeatureService)this.site.CreateService(MgServiceType.FeatureService);
+ MgLayerCollection layers = map.GetLayers();
+ ArrayList<String> layerNames = new ArrayList<String>();
- for(int i=0; i<layers.GetCount(); i++)
- if(!layer.GetName().startsWith("_") && !layer.GetFeatureSourceId().toUpperCase().startsWith("SESSION"))
- MgPropertyDefinition propDef = classDef.GetProperties().GetItem(layer.GetFeatureGeometryName());
- if(propDef.GetPropertyType() == MgFeaturePropertyType.GeometricProperty)
- MgGeometricPropertyDefinition geomPropDef = (MgGeometricPropertyDefinition) propDef;
- if(geomPropDef.GetGeometryTypes() == MgFeatureGeometricType.Surface)
- layerNames.add(layer.GetLegendLabel());
- Collections.sort(layerNames);
+ for(int i=0; i<layers.GetCount(); i++)
+ if(!layer.GetName().startsWith("_") && !layer.GetFeatureSourceId().toUpperCase().startsWith("SESSION"))
+ MgPropertyDefinition propDef = classDef.GetProperties().GetItem(layer.GetFeatureGeometryName());
+ if(propDef.GetPropertyType() == MgFeaturePropertyType.GeometricProperty)
+ MgGeometricPropertyDefinition geomPropDef = (MgGeometricPropertyDefinition) propDef;
+ if(geomPropDef.GetGeometryTypes() == MgFeatureGeometricType.Surface)
+ layerNames.add(layer.GetLegendLabel());
+ Collections.sort(layerNames);
- return layerNames;
+ return layerNames;
- public LayerInfo GetLayerInfo() throws MgException, ParserConfigurationException, IOException, SAXException
+ public LayerInfo GetLayerInfo() throws MgException, ParserConfigurationException, IOException, SAXException
ArrayList<String> scaleRanges = new ArrayList<String>();
@@ -172,14 +164,9 @@
ArrayList<String> propertyMinMaxCount = new ArrayList<String>();
@@ -189,7 +176,7 @@
queryOptions.AddFeatureProperty(this.args.get("PROPERTYNAME"));
String value = this.GetFeaturePropertyValue(featureReader, this.args.get("PROPERTYNAME"));
@@ -256,12 +243,11 @@
public String ApplyTheme() throws MgException, ParserConfigurationException, IOException, SAXException, TransformerConfigurationException, TransformerException
+ MgResourceService resourceService = (MgResourceService)this.site.CreateService(MgServiceType.ResourceService);
MgLayer layer = (MgLayer) layers.GetItem(this.args.get("LAYERNAME"));
@@ -315,7 +301,7 @@
aggregateOptions.AddFeatureProperty(this.args.get("PROPERTYNAME"));
value = this.GetFeaturePropertyValue(dataReader, this.args.get("PROPERTYNAME"));
@@ -349,7 +335,7 @@
this.args.get("DISTRO") + "(\"" + this.args.get("PROPERTYNAME") + "\"," + this.args.get("NUMRULES") + "," + this.args.get("MINVALUE") + "," + this.args.get("MAXVALUE") + ")");
value = this.GetFeaturePropertyValue(dataReader, "THEME_VALUE");
@@ -377,7 +363,7 @@
areaNode = doc.importNode(areaDoc.getDocumentElement(), true);
areaTypeStyle.appendChild(areaNode);
portion = portion + increment;
@@ -409,7 +395,7 @@
+ map.Save();
return uniqueName;
Modified: trunk/MgDev/Doc/samples/phpsamples/analyzing_features/bufferfunctions.php
--- trunk/MgDev/Doc/samples/phpsamples/analyzing_features/bufferfunctions.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpsamples/analyzing_features/bufferfunctions.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -56,7 +56,8 @@
// modify its content to reference the temporary
// feature source.
- $doc = DOMDocument::load('bufferlayerdefinition.xml');
+ $doc = new DOMDocument();
+ $doc->load('bufferlayerdefinition.xml');
$featureSourceNode = $doc->getElementsByTagName('ResourceId')->item(0);
$featureSourceNode->nodeValue = $bufferFeatureResId->ToString();
@@ -125,7 +126,8 @@
// feature source.
- $doc = DOMDocument::load('parcelmarker.xml');
+ $doc->load('parcelmarker.xml');
$featureSourceNode->nodeValue = $parcelMarkerDataResId->ToString();
Modified: trunk/MgDev/Doc/samples/phpsamples/common/common.php
--- trunk/MgDev/Doc/samples/phpsamples/common/common.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpsamples/common/common.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -19,10 +19,10 @@
// Use the following for Windows installations
-$webExtensionsDirectory = 'C:\Program Files\OSGeo\MapGuide\Web\\';
-$MapGuideServerDirectory = 'C:\Program Files\OSGeo\MapGuide\Server\\';
+//$webExtensionsDirectory = 'C:\Program Files\OSGeo\MapGuide\Web\\';
+$webExtensionsDirectory = 'D:\mg-trunk\MgDev\Release\Web\\';
+//$MapGuideServerDirectory = 'C:\Program Files\OSGeo\MapGuide\Server\\';
+$MapGuideServerDirectory = 'D:\mg-trunk\MgDev\Release\Server\\';
$viewerFilesDirectory = $webExtensionsDirectory . 'www\viewerfiles\\';
$schemaDirectory = $MapGuideServerDirectory . 'Schema\\';
Modified: trunk/MgDev/Doc/samples/phpsamples/custom_output/createmapimage.php
--- trunk/MgDev/Doc/samples/phpsamples/custom_output/createmapimage.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpsamples/custom_output/createmapimage.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -43,15 +43,13 @@
// Create the necessary services.
$renderingService = $siteConnection->
CreateService(MgServiceType::RenderingService);
// Open the map and get its SRS
$srsWkt = $map->GetMapSRS();
$coordinateSystemFactory = new MgCoordinateSystemFactory();
$srs = $coordinateSystemFactory->Create($srsWkt);
Modified: trunk/MgDev/Doc/samples/phpsamples/custom_output/eplot.php
--- trunk/MgDev/Doc/samples/phpsamples/custom_output/eplot.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpsamples/custom_output/eplot.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -34,13 +34,9 @@
- $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
$mappingService = $siteConnection->CreateService(MgServiceType::MappingService);
$dwfVersion = new MgDwfVersion("6.01", "1.2");
Modified: trunk/MgDev/Doc/samples/phpsamples/custom_output/multiplot.php
--- trunk/MgDev/Doc/samples/phpsamples/custom_output/multiplot.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpsamples/custom_output/multiplot.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -34,13 +34,9 @@
@@ -61,8 +57,8 @@
// Create a second map for the second sheet in the DWF. This second sheet uses the print layout
// to display a page title and legend.
- $map2 = new MgMap();
- $map2->Create($resourceService, $map->GetMapDefinition(), 'Sheet 2');
+ $map2 = new MgMap($siteConnection);
+ $map2->Create($map->GetMapDefinition(), 'Sheet 2');
$plot2 = new MgMapPlot($map2, $plotSpec, $layout);
$plot2->SetCenterAndScale($map->GetViewCenter()->GetCoordinate(), $map->GetViewScale());
// $plot2 = new MgMapPlot($map2, $map->GetViewCenter()->GetCoordinate(), $map->GetViewScale(), $plotSpec, $layout);
Modified: trunk/MgDev/Doc/samples/phpsamples/custom_output/property_report.php
--- trunk/MgDev/Doc/samples/phpsamples/custom_output/property_report.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpsamples/custom_output/property_report.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -44,12 +44,10 @@
// If any parcels have been selected, recenter the image on the first selected parcel.
if ($xmlSelection != '')
- $featureService = $siteConnection->CreateService(MgServiceType::FeatureService);
$queryOptions = new MgFeatureQueryOptions();
$selection = new MgSelection($map, $xmlSelection);
$layers = $selection->GetLayers();
@@ -65,22 +63,8 @@
if ($layer && $layer->GetName() == 'Parcels')
- // Create a filter containing the IDs of the selected features on this layer
+ $featureReader = $selection->GetSelectedFeatures($layer, $layer->GetFeatureClassName(), false);
- $layerClassName = $layer->GetFeatureClassName();
- $selectionString = $selection->GenerateFilter($layer, $layerClassName);
- // Get the feature resource for the selected layer
- $layerFeatureId = $layer->GetFeatureSourceId();
- $layerFeatureResource = new MgResourceIdentifier($layerFeatureId);
- // Apply the filter to the feature resource for the selected layer. This returns
- // an MgFeatureReader of all the selected features.
- $queryOptions->SetFilter($selectionString);
- $featureReader = $featureService->SelectFeatures($layerFeatureResource, $layerClassName, $queryOptions);
// Create the report details using the first selected parcel. Position the image so the
// centroid of the selected parcel is in the center of the map.
Modified: trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php
--- trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -54,21 +54,21 @@
// Open the map
// Create a new layer
- $factory = new LayerDefinitionFactory();
+ $factory = new LayerDefinitionFactory();
// Create a line rule.
$legendLabel = '';
$filter = '';
$color = 'FF0000FF';
- $lineRule = $factory->CreateLineRule(
- $legendLabel, $filter, $color);
+ $lineRule = $factory->CreateLineRule(
+ $legendLabel, $filter, $color);
// Create a line type style.
$lineTypeStyle = $factory->
@@ -86,9 +86,9 @@
. 'HydrographicLines.FeatureSource';
$featureName = 'SHP_Schema:HydrographicLines';
$geometry = 'SHPGEOM';
- $layerDefinition = $factory->
- CreateLayerDefinition($featureClass, $featureName,
- $geometry, $lineScaleRange);
+ $layerDefinition = $factory->
+ CreateLayerDefinition($featureClass, $featureName,
+ $geometry, $lineScaleRange);
@@ -120,9 +120,9 @@
catch (MgException $e)
- echo "<script language=\"javascript\" type=\"text/javascript\"> \n";
- echo " alert(\" " . $e->GetExceptionMessage() . " \"); \n";
- echo "</script> \n";
+ echo "<script language=\"javascript\" type=\"text/javascript\"> \n";
+ echo " alert(\" " . $e->GetExceptionMessage() . " \"); \n";
+ echo "</script> \n";
Modified: trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php
--- trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/queryfeatures.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -56,13 +56,15 @@
// Get the geometry for the boundaries of District 1
$districtQuery = new MgFeatureQueryOptions();
- $districtQuery->SetFilter("Autogenerated_SDF_ID = 1");
$layer = $map->GetLayers()->GetItem('Districts');
+ $classDef = $layer->GetClassDefinition();
+ $clsIdProps = $classDef->GetIdentityProperties();
+ $idProp = $clsIdProps->GetItem(0);
+ $districtQuery->SetFilter($idProp->GetName()." = 1");
$featureReader = $layer->SelectFeatures($districtQuery);
$featureReader->ReadNext();
- $districtGeometryData = $featureReader->
- GetGeometry('Data');
+ $districtGeometryData = $featureReader->GetGeometry($layer->GetFeatureGeometryName());
// Convert the AGF binary data to MgGeometry.
@@ -99,6 +101,7 @@
+ echo $e->getTraceAsString();
echo $e->GetExceptionMessage();
echo $e->GetDetails();
Modified: trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php
--- trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpsamples/working_with_feature_data/selectfeatures.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -55,13 +55,15 @@
+ $layer = $map->GetLayers()->GetItem('Districts');
- $layer = $map->GetLayers()->GetItem('Districts');
Copied: trunk/MgDev/Doc/samples/phpviewersample/composer.json (from rev 8221, sandbox/jng/v30/Doc/samples/phpviewersample/composer.json)
--- trunk/MgDev/Doc/samples/phpviewersample/composer.json (rev 0)
+++ trunk/MgDev/Doc/samples/phpviewersample/composer.json 2014-06-17 10:16:51 UTC (rev 8236)
@@ -0,0 +1,5 @@
+ "require": {
+ "lstrojny/fxmlrpc": "*"
Modified: trunk/MgDev/Doc/samples/phpviewersample/findaddress/clearaddressresults.php
--- trunk/MgDev/Doc/samples/phpviewersample/findaddress/clearaddressresults.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpviewersample/findaddress/clearaddressresults.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -53,20 +53,14 @@
$featureService->UpdateFeatures($addressMarkerDataResId, $commands, false);
- // the session.
+ $map->Open('Sheboygan');
- $map->Open($resourceService, 'Sheboygan');
$layer = GetLayerByName($map, 'AddressMarker');
$layer->SetVisible(false);
$layer->ForceRefresh();
+ $map->Save();
Modified: trunk/MgDev/Doc/samples/phpviewersample/findaddress/findaddress.php
--- trunk/MgDev/Doc/samples/phpviewersample/findaddress/findaddress.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpviewersample/findaddress/findaddress.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -44,10 +44,8 @@
<?php
include '../utilityfunctions.php';
include 'findaddressfunctions.php';
+ require_once '../vendor/autoload.php';
- // Include the xmlrpc library.
- require_once('kd_xmlrpc.php');
$mgSessionId = ($_SERVER['REQUEST_METHOD'] == "POST")? $_POST['SESSION']: $_GET['SESSION'];
$success = false;
$long = 0; $lat = 0;
@@ -66,8 +64,10 @@
$address = $_GET['address'] . ', Sheboygan, WI';
// Make the request to geocoder.us passing the address.
- list($success, $response) = XMLRPC_request('rpc.geocoder.us', '/service/xmlrpc', 'geocode', array(XMLRPC_prepare($address)));
+ $url = 'http://rpc.geocoder.us/service/xmlrpc';
+ $client = new fXmlRpc\Client($url);
+ $response = $client->call('geocode', array($address, true));
// Stuff the response into a new variable:
$nested_array = $response;
@@ -81,13 +81,13 @@
// we can't use this to check for errors. Instead, we'll check the values in the
// array and deem success or failure based on that.
- if (array_key_exists('lat', $geoarray) && array_key_exists('long', $geoarray))
+ if (NULL != $geoarray && array_key_exists('lat', $geoarray) && array_key_exists('long', $geoarray))
// The geocode successfully returned a location.
$lat = $geoarray['lat'];
$long = $geoarray['long'];
// Build an address1 and address2 variables from the result.
$address1 = $geoarray['number'] . ' '
. (strlen($geoarray['prefix']) > 0 ? $geoarray['prefix'] . ' ' : '')
@@ -98,7 +98,7 @@
$address2 = $geoarray['city']
. ', ' . $geoarray['state']
. ' ' . $geoarray['zip'];
echo '<tr><td><img src="../images/pushpinblue.jpg">';
echo '<a href="gotopoint.php?X=' . $long . '&Y=' . $lat . '&Scale=2000" target="scriptFrame"> ' . $address1 . '</a></td></tr>';
echo '<tr><td>' . $address2 . '</td></tr>';
@@ -113,8 +113,8 @@
@@ -157,7 +157,7 @@
$addressLayer->SetVisible(true);
$addressLayer->ForceRefresh();
+ $map->Save();
$success = true;
Modified: trunk/MgDev/Doc/samples/phpviewersample/findaddress/findaddressfunctions.php
--- trunk/MgDev/Doc/samples/phpviewersample/findaddress/findaddressfunctions.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpviewersample/findaddress/findaddressfunctions.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -101,7 +101,8 @@
// modify it's content to reference the temporary
// feature source.
- $doc = DOMDocument::load(GetXmlPath());
+ $doc->load(GetXmlPath());
$featureSourceNode->nodeValue = $addressMarkerDataResId->ToString();
Modified: trunk/MgDev/Doc/samples/phpviewersample/findaddress/findaddressmain.php
--- trunk/MgDev/Doc/samples/phpviewersample/findaddress/findaddressmain.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpviewersample/findaddress/findaddressmain.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -30,12 +30,12 @@
function Submit()
</script>
</head>
@@ -60,13 +60,8 @@
$addressLayer = GetLayerByName($map, 'AddressMarker');
if ($addressLayer != null)
Deleted: trunk/MgDev/Doc/samples/phpviewersample/findaddress/kd_xmlrpc.php
--- trunk/MgDev/Doc/samples/phpviewersample/findaddress/kd_xmlrpc.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpviewersample/findaddress/kd_xmlrpc.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -1,498 +0,0 @@
-<?php
-An XML-RPC implementation by Keith Devens, version 2.5f.
-http://www.keithdevens.com/software/xmlrpc/
-Release history available at:
-http://www.keithdevens.com/software/xmlrpc/history/
-This code is Open Source, released under terms similar to the Artistic License.
-Read the license at http://www.keithdevens.com/software/license/
-Note: this code requires version 4.1.0 or higher of PHP.
-function & XML_serialize(&$data, $level = 0, $prior_key = NULL){
- #assumes a hash, keys are the variable names
- $xml_serialized_string = "";
- while(list($key, $value) = each($data)){
- $inline = false;
- $numeric_array = false;
- $attributes = "";
- #echo "My current key is '$key', called with prior key '$prior_key'<br>";
- if(!strstr($key, " attr")){ #if it's not an attribute
- if(array_key_exists("$key attr", $data)){
- while(list($attr_name, $attr_value) = each($data["$key attr"])){
- #echo "Found attribute $attribute_name with value $attribute_value<br>";
- $attr_value = &htmlspecialchars($attr_value, ENT_QUOTES);
- $attributes .= " $attr_name=\"$attr_value\"";
- if(is_numeric($key)){
- #echo "My current key ($key) is numeric. My parent key is '$prior_key'<br>";
- $key = $prior_key;
- }else{
- #you can't have numeric keys at two levels in a row, so this is ok
- #echo "Checking to see if a numeric key exists in data.";
- if(is_array($value) and array_key_exists(0, $value)){
- # echo " It does! Calling myself as a result of a numeric array.<br>";
- $numeric_array = true;
- $xml_serialized_string .= XML_serialize($value, $level, $key);
- #echo "<br>";
- if(!$numeric_array){
- $xml_serialized_string .= str_repeat("\t", $level) . "<$key$attributes>";
- if(is_array($value)){
- $xml_serialized_string .= "\r\n" . XML_serialize($value, $level+1);
- }else{
- $inline = true;
- $xml_serialized_string .= htmlspecialchars($value);
- $xml_serialized_string .= (!$inline ? str_repeat("\t", $level) : "") . "</$key>\r\n";
- }else{
- #echo "Skipping attribute record for key $key<bR>";
- if($level == 0){
- $xml_serialized_string = "<?xml version=\"1.0\" ?>\r\n" . $xml_serialized_string;
- return $xml_serialized_string;
- }else{
-class XML {
- var $parser; #a reference to the XML parser
- var $document; #the entire XML structure built up so far
- var $current; #a pointer to the current item - what is this
- var $parent; #a pointer to the current parent - the parent will be an array
- var $parents; #an array of the most recent parent at each level
- var $last_opened_tag;
- function XML($data=null){
- $this->parser = xml_parser_create();
- xml_parser_set_option ($this->parser, XML_OPTION_CASE_FOLDING, 0);
- xml_set_object($this->parser, &$this);
- xml_set_element_handler($this->parser, "open", "close");
- xml_set_character_data_handler($this->parser, "data");
-# register_shutdown_function(array(&$this, 'destruct'));
- function destruct(){
- xml_parser_free($this->parser);
- function parse($data){
- $this->document = array();
- $this->parent = &$this->document;
- $this->parents = array();
- $this->last_opened_tag = NULL;
- xml_parse($this->parser, $data);
- return $this->document;
- function open($parser, $tag, $attributes){
- #echo "Opening tag $tag<br>\n";
- $this->data = "";
- $this->last_opened_tag = $tag; #tag is a string
- if(array_key_exists($tag, $this->parent)){
- #echo "There's already an instance of '$tag' at the current level ($level)<br>\n";
- if(is_array($this->parent[$tag]) and array_key_exists(0, $this->parent[$tag])){ #if the keys are numeric
- #need to make sure they're numeric (account for attributes)
- $key = count_numeric_items($this->parent[$tag]);
- #echo "There are $key instances: the keys are numeric.<br>\n";
- }else{
- #echo "There is only one instance. Shifting everything around<br>\n";
- $temp = &$this->parent[$tag];
- unset($this->parent[$tag]);
- $this->parent[$tag][0] = &$temp;
- if(array_key_exists("$tag attr", $this->parent)){
- #shift the attributes around too if they exist
- $temp = &$this->parent["$tag attr"];
- unset($this->parent["$tag attr"]);
- $this->parent[$tag]["0 attr"] = &$temp;
- $key = 1;
- $this->parent = &$this->parent[$tag];
- }else{
- $key = $tag;
- if($attributes){
- $this->parent["$key attr"] = $attributes;
- $this->parent[$key] = array();
- $this->parent = &$this->parent[$key];
- array_unshift($this->parents, &$this->parent);
- function data($parser, $data){
- #echo "Data is '", htmlspecialchars($data), "'<br>\n";
- if($this->last_opened_tag != NULL){
- $this->data .= $data;
- function close($parser, $tag){
- #echo "Close tag $tag<br>\n";
- if($this->last_opened_tag == $tag){
- $this->parent = $this->data;
- array_shift($this->parents);
- $this->parent = &$this->parents[0];
-function & XML_unserialize(&$xml){
- $xml_parser = new XML();
- $data = &$xml_parser->parse(&$xml);
- $xml_parser->destruct();
- return $data;
-function & XMLRPC_parse(&$request){
- if(defined('XMLRPC_DEBUG') and XMLRPC_DEBUG){
- XMLRPC_debug('XMLRPC_parse', "<p>Received the following raw request:</p>" . XMLRPC_show($request, 'print_r', true));
- $data = &XML_unserialize(&$request);
- XMLRPC_debug('XMLRPC_parse', "<p>Returning the following parsed request:</p>" . XMLRPC_show($data, 'print_r', true));
- return $data;
-function & XMLRPC_prepare($data, $type = NULL){
- if(is_array($data)){
- $num_elements = count($data);
- if((array_key_exists(0, $data) or !$num_elements) and $type != 'struct'){ #it's an array
- if(!$num_elements){ #if the array is empty
- $returnvalue = array('array' => array('data' => NULL));
- }else{
- $returnvalue['array']['data']['value'] = array();
- $temp = &$returnvalue['array']['data']['value'];
- $count = count_numeric_items($data);
- for($n=0; $n<$count; $n++){
- $type = NULL;
- if(array_key_exists("$n type", $data)){
- $type = $data["$n type"];
- $temp[$n] = XMLRPC_prepare(&$data[$n], $type);
- }else{ #it's a struct
- if(!$num_elements){ #if the struct is empty
- $returnvalue = array('struct' => NULL);
- }else{
- $returnvalue['struct']['member'] = array();
- $temp = &$returnvalue['struct']['member'];
- if(substr($key, -5) != ' type'){ #if it's not a type specifier
- $type = NULL;
- if(array_key_exists("$key type", $data)){
- $type = $data["$key type"];
- $temp[] = array('name' => $key, 'value' => XMLRPC_prepare(&$value, $type));
- }else{ #it's a scalar
- if(!$type){
- if(is_int($data)){
- $returnvalue['int'] = $data;
- return $returnvalue;
- }elseif(is_float($data)){
- $returnvalue['double'] = $data;
- }elseif(is_bool($data)){
- $returnvalue['boolean'] = ($data ? 1 : 0);
- }elseif(preg_match('/^\d{8}T\d{2}:\d{2}:\d{2}$/', $data, $matches)){ #it's a date
- $returnvalue['dateTime.iso8601'] = $data;
- }elseif(is_string($data)){
- $returnvalue['string'] = htmlspecialchars($data);
- }else{
- $returnvalue[$type] = htmlspecialchars($data);
-function & XMLRPC_adjustValue(&$current_node){
- if(is_array($current_node)){
- if(isset($current_node['array'])){
- if(!is_array($current_node['array']['data'])){
- #If there are no elements, return an empty array
- return array();
- }else{
- #echo "Getting rid of array -> data -> value<br>\n";
- $temp = &$current_node['array']['data']['value'];
- if(is_array($temp) and array_key_exists(0, $temp)){
- $count = count($temp);
- for($n=0;$n<$count;$n++){
- $temp2[$n] = &XMLRPC_adjustValue(&$temp[$n]);
- $temp = &$temp2;
- }else{
- $temp2 = &XMLRPC_adjustValue(&$temp);
- $temp = array(&$temp2);
- #I do the temp assignment because it avoids copying,
- # since I can put a reference in the array
- #PHP's reference model is a bit silly, and I can't just say:
- # $temp = array(&XMLRPC_adjustValue(&$temp));
- }elseif(isset($current_node['struct'])){
- if(!is_array($current_node['struct'])){
- #If there are no members, return an empty array
- return array();
- }else{
- #echo "Getting rid of struct -> member<br>\n";
- $temp = &$current_node['struct']['member'];
- #echo "Passing name {$temp[$n][name]}. Value is: " . show($temp[$n][value], var_dump, true) . "<br>\n";
- $temp2[$temp[$n]['name']] = &XMLRPC_adjustValue(&$temp[$n]['value']);
- #echo "adjustValue(): After assigning, the value is " . show($temp2[$temp[$n]['name']], var_dump, true) . "<br>\n";
- }else{
- #echo "Passing name $temp[name]<br>\n";
- $temp2[$temp['name']] = &XMLRPC_adjustValue(&$temp['value']);
- $temp = &$temp2;
- }else{
- $types = array('string', 'int', 'i4', 'double', 'dateTime.iso8601', 'base64', 'boolean');
- $fell_through = true;
- foreach($types as $type){
- if(array_key_exists($type, $current_node)){
- #echo "Getting rid of '$type'<br>\n";
- $temp = &$current_node[$type];
- #echo "adjustValue(): The current node is set with a type of $type<br>\n";
- $fell_through = false;
- break;
- if($fell_through){
- $type = 'string';
- #echo "Fell through! Type is $type<br>\n";
- switch ($type){
- case 'int': case 'i4': $temp = (int)$temp; break;
- case 'string': $temp = (string)$temp; break;
- case 'double': $temp = (double)$temp; break;
- case 'boolean': $temp = (bool)$temp; break;
- }else{
- $temp = (string)$current_node;
- return $temp;
-function XMLRPC_getParams($request){
- if(!is_array($request['methodCall']['params'])){
- #If there are no parameters, return an empty array
- return array();
- }else{
- #echo "Getting rid of methodCall -> params -> param<br>\n";
- $temp = &$request['methodCall']['params']['param'];
- for($n = 0; $n < $count; $n++){
- #echo "Serializing parameter $n<br>";
- $temp2[$n] = &XMLRPC_adjustValue(&$temp[$n]['value']);
- }else{
- $temp2[0] = &XMLRPC_adjustValue($temp['value']);
- $temp = &$temp2;
- return $temp;
-function XMLRPC_getMethodName($methodCall){
- #returns the method name
- return $methodCall['methodCall']['methodName'];
-function XMLRPC_request($site, $location, $methodName, $params = NULL, $user_agent = NULL){
- $site = explode(':', $site);
- if(isset($site[1]) and is_numeric($site[1])){
- $port = $site[1];
- }else{
- $port = 80;
- $site = $site[0];
- $data["methodCall"]["methodName"] = $methodName;
- $param_count = count($params);
- if(!$param_count){
- $data["methodCall"]["params"] = NULL;
- }else{
- for($n = 0; $n<$param_count; $n++){
- $data["methodCall"]["params"]["param"][$n]["value"] = $params[$n];
- $data = XML_serialize($data);
- XMLRPC_debug('XMLRPC_request', "<p>Received the following parameter list to send:</p>" . XMLRPC_show($params, 'print_r', true));
- $conn = fsockopen ($site, $port); #open the connection
- if(!$conn){ #if the connection was not opened successfully
- XMLRPC_debug('XMLRPC_request', "<p>Connection failed: Couldn't make the connection to $site.</p>");
- return array(false, array('faultCode'=>10532, 'faultString'=>"Connection failed: Couldn't make the connection to $site."));
- }else{
- $headers =
- "POST $location HTTP/1.0\r\n" .
- "Host: $site\r\n" .
- "Connection: close\r\n" .
- ($user_agent ? "User-Agent: $user_agent\r\n" : '') .
- "Content-Type: text/xml\r\n" .
- "Content-Length: " . strlen($data) . "\r\n\r\n";
- fputs($conn, "$headers");
- fputs($conn, $data);
- XMLRPC_debug('XMLRPC_request', "<p>Sent the following request:</p>\n\n" . XMLRPC_show($headers . $data, 'print_r', true));
- #socket_set_blocking ($conn, false);
- $response = "";
- while(!feof($conn)){
- $response .= fgets($conn, 1024);
- fclose($conn);
- #strip headers off of response
- $responsesubstr = substr($response, strpos($response, "\r\n\r\n")+4);
- $data = XML_unserialize($responsesubstr);
- XMLRPC_debug('XMLRPC_request', "<p>Received the following response:</p>\n\n" . XMLRPC_show($response, 'print_r', true) . "<p>Which was serialized into the following data:</p>\n\n" . XMLRPC_show($data, 'print_r', true));
- if(isset($data['methodResponse']['fault'])){
- $return = array(false, XMLRPC_adjustValue(&$data['methodResponse']['fault']['value']));
- XMLRPC_debug('XMLRPC_request', "<p>Returning:</p>\n\n" . XMLRPC_show($return, 'var_dump', true));
- return $return;
- }else{
- $return = array(true, XMLRPC_adjustValue(&$data['methodResponse']['params']['param']['value']));
- return $return;
-function XMLRPC_response($return_value, $server = NULL){
- $data["methodResponse"]["params"]["param"]["value"] = &$return_value;
- $return = XML_serialize(&$data);
- XMLRPC_debug('XMLRPC_response', "<p>Received the following data to return:</p>\n\n" . XMLRPC_show($return_value, 'print_r', true));
- header("Connection: close");
- header("Content-Length: " . strlen($return));
- header("Content-Type: text/xml");
- header("Date: " . date("r"));
- if($server){
- header("Server: $server");
- XMLRPC_debug('XMLRPC_response', "<p>Sent the following response:</p>\n\n" . XMLRPC_show($return, 'print_r', true));
- echo $return;
-function XMLRPC_error($faultCode, $faultString, $server = NULL){
- $array["methodResponse"]["fault"]["value"]["struct"]["member"] = array();
- $temp = &$array["methodResponse"]["fault"]["value"]["struct"]["member"];
- $temp[0]["name"] = "faultCode";
- $temp[0]["value"]["int"] = $faultCode;
- $temp[1]["name"] = "faultString";
- $temp[1]["value"]["string"] = $faultString;
- $return = XML_serialize($array);
- if($server){
- XMLRPC_debug('XMLRPC_error', "<p>Sent the following error response:</p>\n\n" . XMLRPC_show($return, 'print_r', true));
- echo $return;
-function XMLRPC_convert_timestamp_to_iso8601($timestamp){
- #takes a unix timestamp and converts it to iso8601 required by XMLRPC
- #an example iso8601 datetime is "20010822T03:14:33"
- return date("Ymd\TH:i:s", $timestamp);
-function XMLRPC_convert_iso8601_to_timestamp($iso8601){
- return strtotime($iso8601);
-function count_numeric_items(&$array){
- return is_array($array) ? count(array_filter(array_keys($array), 'is_numeric')) : 0;
-function XMLRPC_debug($function_name, $debug_message){
- $GLOBALS['XMLRPC_DEBUG_INFO'][] = array($function_name, $debug_message);
-function XMLRPC_debug_print(){
- if($GLOBALS['XMLRPC_DEBUG_INFO']){
- echo "<table border=\"1\" width=\"100%\">\n";
- foreach($GLOBALS['XMLRPC_DEBUG_INFO'] as $debug){
- echo "<tr><th style=\"vertical-align: top\">$debug[0]</th><td>$debug[1]</td></tr>\n";
- echo "</table>\n";
- unset($GLOBALS['XMLRPC_DEBUG_INFO']);
- }else{
- echo "<p>No debugging information available yet.</p>";
-function XMLRPC_show($data, $func = "print_r", $return_str = false){
- ob_start();
- $func($data);
- $output = ob_get_contents();
- ob_end_clean();
- if($return_str){
- return "<pre>" . htmlspecialchars($output) . "</pre>\n";
- }else{
- echo "<pre>", htmlspecialchars($output), "</pre>\n";
Modified: trunk/MgDev/Doc/samples/phpviewersample/plot/plot.php
--- trunk/MgDev/Doc/samples/phpviewersample/plot/plot.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpviewersample/plot/plot.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -35,15 +35,9 @@
Modified: trunk/MgDev/Doc/samples/phpviewersample/plot/plotmain.php
--- trunk/MgDev/Doc/samples/phpviewersample/plot/plotmain.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpviewersample/plot/plotmain.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -90,9 +90,8 @@
// page.
$viewCenter = $map->GetViewCenter();
$viewScale = $map->GetViewScale();
Modified: trunk/MgDev/Doc/samples/phpviewersample/query/classes/query.php
--- trunk/MgDev/Doc/samples/phpviewersample/query/classes/query.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpviewersample/query/classes/query.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -27,35 +27,33 @@
class Query
- private $args = null;
- private $site = null;
+ private $args = null;
+ private $site = null;
- public $numOperators;
- public $numExpressions;
- public $strOperators;
- public $strExpressions;
+ public $numOperators;
+ public $numExpressions;
+ public $strOperators;
+ public $strExpressions;
- function __construct($args)
- $this->args = $args;
- $this->site = new MgSiteConnection();
- $this->site->Open(new MgUserInformation($args['SESSION']));
+ function __construct($args)
+ $this->args = $args;
+ $this->site = new MgSiteConnection();
+ $this->site->Open(new MgUserInformation($args['SESSION']));
- $this->numOperators = array('Equal to', 'Not equal to', 'Greater than', 'Greater than or equal to', 'Less than', 'Less than or equal to');
- $this->numExpressions = array(' = %s', ' != %s', ' > %s', ' >= %s', ' < %s', ' <= %s');
+ $this->numOperators = array('Equal to', 'Not equal to', 'Greater than', 'Greater than or equal to', 'Less than', 'Less than or equal to');
+ $this->numExpressions = array(' = %s', ' != %s', ' > %s', ' >= %s', ' < %s', ' <= %s');
- $this->strOperators = array('Begins with', 'Contains', 'Equal to');
- $this->strExpressions = array(" like '%s%%'", " like '%%%s%%'", " = '%s'");
+ $this->strOperators = array('Begins with', 'Contains', 'Equal to');
+ $this->strExpressions = array(" like '%s%%'", " like '%%%s%%'", " = '%s'");
function GetMapLayerNames()
$layerNames = array();
- $resourceService = $this->site->CreateService(MgServiceType::ResourceService);
- $map->Open($resourceService, $this->args['MAPNAME']);
+ $map = new MgMap($this->site);
+ $map->Open($this->args['MAPNAME']);
for ($i = 0; $i < $layers->GetCount(); $i++)
@@ -65,9 +63,9 @@
//TODO: Exclude Raster and Drawing Layers???
if((substr($layer->GetName(), 0, 1) != "_") && (substr(strtoupper($layer->GetFeatureSourceId()), 0, 7) != "SESSION"))
- $layerNames[$layer->GetName()] = $layer->GetLegendLabel();
+ $layerNames[$layer->GetName()] = $layer->GetLegendLabel();
asort($layerNames);
@@ -78,395 +76,382 @@
$properties = array();
$layer = $map->GetLayers()->GetItem($this->args['LAYERNAME']);
- $featureService = $this->site->CreateService(MgServiceType::FeatureService);
- $resId = new MgResourceIdentifier($layer->GetFeatureSourceId());
- $schemaClass = explode(':', $layer->GetFeatureClassName());
+ $clsProps = $classDef->GetProperties();
- $classDef = $featureService->GetClassDefinition($resId, $schemaClass[0], $schemaClass[1]);
- for ($i = 0; $i < $classDef->GetProperties()->GetCount(); $i++)
+ for ($i = 0; $i < $clsProps->GetCount(); $i++)
- $propertyDef = $classDef->GetProperties()->GetItem($i);
+ $propertyDef = $clsProps->GetItem($i);
if ($propertyDef->GetPropertyType() == MgFeaturePropertyType::DataProperty)
- $dataType = $propertyDef->GetDataType();
- if ($this->IsValidDataType($dataType))
- array_push($properties, new Property($propertyDef->GetName(), $dataType == MgPropertyType::String));
+ $dataType = $propertyDef->GetDataType();
+ if ($this->IsValidDataType($dataType))
+ array_push($properties, new Property($propertyDef->GetName(), $dataType == MgPropertyType::String));
return $properties;
- function ToggleSpatialFilter()
- $result = true;
+ function ToggleSpatialFilter()
+ $result = true;
+ $layers = $map->GetLayers();
+ if ($layers->Contains('_QuerySpatialFilter'))
+ $layer = $layers->GetItem('_QuerySpatialFilter');
+ if ($this->args['VISIBLE'] == 'true')
+ $layer->SetVisible(true);
+ else
+ $layer->SetVisible(false);
- $layers = $map->GetLayers();
- if ($layers->Contains('_QuerySpatialFilter'))
- $layer = $layers->GetItem('_QuerySpatialFilter');
- if ($this->args['VISIBLE'] == 'true')
- $layer->SetVisible(true);
- else
- $layer->SetVisible(false);
+ $map->Save();
+ return $result;
- return $result;
+ function ShowSpatialFilter()
+ $result = true;
- function ShowSpatialFilter()
- $result = true;
+ $sdfResId = new MgResourceIdentifier('Session:' . $this->args['SESSION'] . '//Filter.FeatureSource');
- $sdfResId = new MgResourceIdentifier('Session:' . $this->args['SESSION'] . '//Filter.FeatureSource');
+ $resourceService = $this->site->CreateService(MgServiceType::ResourceService);
+ $featureService = $this->site->CreateService(MgServiceType::FeatureService);
$updateCommands = new MgFeatureCommandCollection();
- $layer = null;
+ $layer = null;
$updateCommands->Add(new MgDeleteFeatures('Filter', "ID like '%'"));
- else
- // Create the Feature Source (SDF)
+ else
+ // Create the Feature Source (SDF)
+ $sdfSchema = $this->CreateFilterSchema();
+ $sdfParams = new MgFileFeatureSourceParams('OSGeo.SDF', 'MAPCS', $map->GetMapSRS(), $sdfSchema);
+ $featureService->CreateFeatureSource($sdfResId, $sdfParams);
- $sdfSchema = $this->CreateFilterSchema();
- $sdfParams = new MgCreateSdfParams('MAPCS', $map->GetMapSRS(), $sdfSchema);
- $featureService->CreateFeatureSource($sdfResId, $sdfParams);
+ // Create the Layer
- // Create the Layer
+ $layerResId = new MgResourceIdentifier('Session:' . $this->args['SESSION'] . '//Filter.LayerDefinition');
- $layerResId = new MgResourceIdentifier('Session:' . $this->args['SESSION'] . '//Filter.LayerDefinition');
+ $layerDefinition = file_get_contents("templates/filterlayerdefinition.xml");
+ $layerDefinition = sprintf($layerDefinition, $sdfResId->ToString());
- $layerDefinition = file_get_contents("templates/filterlayerdefinition.xml");
- $layerDefinition = sprintf($layerDefinition, $sdfResId->ToString());
+ $byteSource = new MgByteSource($layerDefinition, strlen($layerDefinition));
+ $resourceService->SetResource($layerResId, $byteSource->GetReader(), null);
- $byteSource = new MgByteSource($layerDefinition, strlen($layerDefinition));
- $resourceService->SetResource($layerResId, $byteSource->GetReader(), null);
+ $layer = new MgLayer($layerResId, $resourceService);
- $layer = new MgLayer($layerResId, $resourceService);
+ $layer->SetName('_QuerySpatialFilter');
+ $layer->SetLegendLabel('_QuerySpatialFilter');
+ $layer->SetDisplayInLegend(false);
+ $layer->SetSelectable(false);
- $layer->SetName('_QuerySpatialFilter');
- $layer->SetLegendLabel('_QuerySpatialFilter');
- $layer->SetDisplayInLegend(false);
- $layer->SetSelectable(false);
+ $layers->Insert(0, $layer);
- $layers->Insert(0, $layer);
+ // Make the layer visible
- // Make the layer visible
+ $map->Save();
+ // Add the geometry to the filter feature source
- // Add the geometry to the filter feature source
+ $polygon = $this->CreatePolygonFromGeomText($this->args['GEOMTEXT']);
+ $agfWriter = new MgAgfReaderWriter();
+ $byteReader = $agfWriter->Write($polygon);
- $polygon = $this->CreatePolygonFromGeomText($this->args['GEOMTEXT']);
- $agfWriter = new MgAgfReaderWriter();
- $byteReader = $agfWriter->Write($polygon);
+ $propertyValues = new MgPropertyCollection();
+ $propertyValues->Add(new MgGeometryProperty('Geometry', $byteReader));
- $propertyValues = new MgPropertyCollection();
- $propertyValues->Add(new MgGeometryProperty('Geometry', $byteReader));
+ $updateCommands->Add(new MgInsertFeatures('Filter', $propertyValues));
- $updateCommands->Add(new MgInsertFeatures('Filter', $propertyValues));
+ $featureService->UpdateFeatures($sdfResId, $updateCommands, false);
- $featureService->UpdateFeatures($sdfResId, $updateCommands, false);
+ return $result;
- return $result;
+ function Execute()
+ $result = array();
- function Execute()
- $result = array();
- $featureClass = $layer->GetFeatureClassName();
- $featureGeometry = $layer->GetFeatureGeometryName();
+ $featureClass = $layer->GetFeatureClassName();
+ $featureGeometry = $layer->GetFeatureGeometryName();
- // Initialize the coordinate system transform
+ // Initialize the coordinate system transform
- $schemaAndClass = explode(":", $featureClass);
- $classDef = $featureService->GetClassDefinition($resId, $schemaAndClass[0], $schemaAndClass[1]);
- $geomProp = $classDef->GetProperties()->GetItem($featureGeometry);
- $spatialContext = $geomProp->GetSpatialContextAssociation();
+ $schemaAndClass = explode(":", $featureClass);
+ $classDef = $featureService->GetClassDefinition($resId, $schemaAndClass[0], $schemaAndClass[1]);
+ $geomProp = $classDef->GetProperties()->GetItem($featureGeometry);
+ $spatialContext = $geomProp->GetSpatialContextAssociation();
- $csTransform = null;
- $csInverseTransform = null;
- $coordSysFactory = new MgCoordinateSystemFactory();
+ $csTransform = null;
+ $csInverseTransform = null;
+ $coordSysFactory = new MgCoordinateSystemFactory();
- $scReader = $featureService->GetSpatialContexts($resId, false);
- while ($scReader->ReadNext() && $csTransform == null)
- if ($scReader->GetName() == $spatialContext)
- $source = $coordSysFactory->Create($scReader->GetCoordinateSystemWkt());
- $target = $coordSysFactory->Create($map->GetMapSRS());
- $csTransform = new MgCoordinateSystemTransform($source, $target);
- $csInverseTransform = new MgCoordinateSystemTransform($target, $source);
- $scReader->Close();
+ $scReader = $featureService->GetSpatialContexts($resId, false);
+ while ($scReader->ReadNext() && $csTransform == null)
+ if ($scReader->GetName() == $spatialContext)
+ $source = $coordSysFactory->Create($scReader->GetCoordinateSystemWkt());
+ $target = $coordSysFactory->Create($map->GetMapSRS());
+ $csTransform = $coordSysFactory->GetTransform($source, $target);
+ $csInverseTransform = $coordSysFactory->GetTransform($target, $source);
+ $scReader->Close();
- // Execute the query
+ // Execute the query
- $queryMax = (int) $this->args['QUERYMAX'];
- $queryOptions = new MgFeatureQueryOptions();
+ $queryMax = (int) $this->args['QUERYMAX'];
+ $queryOptions = new MgFeatureQueryOptions();
- if ($this->args['USEPROPERTYFILTER'] == 'true')
- $propertyFilter = $this->args['PROPERTYNAME'];
- if ($this->args['ISSTRING'] == 'true')
- $propertyFilter .= sprintf($this->strExpressions[$this->args['OPERATOR']], $this->args['VALUE']);
- else
- $propertyFilter .= sprintf($this->numExpressions[$this->args['OPERATOR']], $this->args['VALUE']);
+ if ($this->args['USEPROPERTYFILTER'] == 'true')
+ $propertyFilter = $this->args['PROPERTYNAME'];
+ if ($this->args['ISSTRING'] == 'true')
+ $propertyFilter .= sprintf($this->strExpressions[$this->args['OPERATOR']], $this->args['VALUE']);
+ else
+ $propertyFilter .= sprintf($this->numExpressions[$this->args['OPERATOR']], $this->args['VALUE']);
- $queryOptions->SetFilter($propertyFilter);
+ $queryOptions->SetFilter($propertyFilter);
- if ($this->args['USESPATIALFILTER'] == 'true')
- $polygon = $polygon->Transform($csInverseTransform);
+ if ($this->args['USESPATIALFILTER'] == 'true')
+ $polygon = $polygon->Transform($csInverseTransform);
- $queryOptions->SetSpatialFilter($featureGeometry, $polygon, MgFeatureSpatialOperations::Intersects);
+ $queryOptions->SetSpatialFilter($featureGeometry, $polygon, MgFeatureSpatialOperations::Intersects);
- $count = 0;
- $geometryReaderWriter = new MgAgfReaderWriter();
- $featureReader = $featureService->SelectFeatures($resId, $layer->GetFeatureClassName(), $queryOptions);
- while ($featureReader->ReadNext() && ($queryMax <= 0 || $count < $queryMax))
- $displayValue = $this->GetFeaturePropertyValue($featureReader, $this->args['OUTPUTPROPERTY']);
+ $count = 0;
+ $geometryReaderWriter = new MgAgfReaderWriter();
+ $featureReader = $featureService->SelectFeatures($resId, $layer->GetFeatureClassName(), $queryOptions);
+ while ($featureReader->ReadNext() && ($queryMax <= 0 || $count < $queryMax))
+ $displayValue = $this->GetFeaturePropertyValue($featureReader, $this->args['OUTPUTPROPERTY']);
- $byteReader = $featureReader->GetGeometry($featureGeometry);
+ $byteReader = $featureReader->GetGeometry($featureGeometry);
$geometry = $geometryReaderWriter->Read($byteReader);
$centerPoint = $geometry->GetCentroid();
- $centerPoint = $centerPoint->Transform($csTransform);
+ $centerPoint = $centerPoint->Transform($csTransform);
- $idList = $this->GetFeatureIdList($map, $layer, $featureReader);
+ $idList = $this->GetFeatureIdList($map, $layer, $featureReader);
- array_push($result, new Feature($displayValue, $centerPoint, $idList));
- $count++;
+ array_push($result, new Feature($displayValue, $centerPoint, $idList));
+ $count++;
- return $result;
+ return $result;
- function GetSelectionXML()
- $json = new Services_JSON();
+ function GetSelectionXML()
+ $json = new Services_JSON();
- $map = new MgMap();
- $layer = $map->GetLayers()->GetItem($this->args['LAYERNAME']);
+ $layer = $layers->GetItem($this->args['LAYERNAME']);
- $properties = new MgPropertyCollection();
- $idList = $json->decode($this->args['IDLIST']);
+ $properties = new MgPropertyCollection();
+ $idList = $json->decode($this->args['IDLIST']);
- foreach ($idList as $key => $value)
- switch($classDef->GetProperties()->GetItem($key)->GetDataType())
- case MgPropertyType::Boolean :
- $properties->Add(new MgBooleanProperty($key, $value));
- break;
+ foreach ($idList as $key => $value)
+ switch($classDef->GetProperties()->GetItem($key)->GetDataType())
+ case MgPropertyType::Boolean :
+ $properties->Add(new MgBooleanProperty($key, $value));
+ break;
- case MgPropertyType::Byte :
- $properties->Add(new MgByteProperty($key, $value));
- break;
+ case MgPropertyType::Byte :
+ $properties->Add(new MgByteProperty($key, $value));
+ break;
- case MgPropertyType::Single :
- $properties->Add(new MgSingleProperty($key, $value));
- break;
+ case MgPropertyType::Single :
+ $properties->Add(new MgSingleProperty($key, $value));
+ break;
- case MgPropertyType::Double :
- $properties->Add(new MgDoubleProperty($key, $value));
- break;
+ case MgPropertyType::Double :
+ $properties->Add(new MgDoubleProperty($key, $value));
+ break;
- case MgPropertyType::Int16 :
- $properties->Add(new MgInt16Property($key, $value));
- break;
+ case MgPropertyType::Int16 :
+ $properties->Add(new MgInt16Property($key, $value));
+ break;
- case MgPropertyType::Int32 :
- $properties->Add(new MgInt32Property($key, $value));
- break;
+ case MgPropertyType::Int32 :
+ $properties->Add(new MgInt32Property($key, $value));
+ break;
- case MgPropertyType::Int64 :
- $properties->Add(new MgInt64Property($key, $value));
- break;
+ case MgPropertyType::Int64 :
+ $properties->Add(new MgInt64Property($key, $value));
+ break;
- case MgPropertyType::String :
- $properties->Add(new MgStringProperty($key, $value));
- break;
+ case MgPropertyType::String :
+ $properties->Add(new MgStringProperty($key, $value));
+ break;
- case MgPropertyType::DateTime :
- $properties->Add(new MgDateTimeProperty($key, $value));
- break;
+ case MgPropertyType::DateTime :
+ $properties->Add(new MgDateTimeProperty($key, $value));
+ break;
- case MgPropertyType::Null :
- case MgPropertyType::Blob :
- case MgPropertyType::Clob :
- case MgPropertyType::Feature :
- case MgPropertyType::Geometry :
- case MgPropertyType::Raster :
- break;
+ case MgPropertyType::Null :
+ case MgPropertyType::Blob :
+ case MgPropertyType::Clob :
+ case MgPropertyType::Feature :
+ case MgPropertyType::Geometry :
+ case MgPropertyType::Raster :
+ break;
- $selection = new MgSelection($map);
- $selection->AddFeatureIds($layer, $featureClass, $properties);
+ $selection = new MgSelection($map);
+ $selection->AddFeatureIds($layer, $featureClass, $properties);
- return $selection->ToXml();
+ return $selection->ToXml();
- private function GetFeaturePropertyValue($featureReader, $name)
- $value = '';
- $propertyType = $featureReader->GetPropertyType($name);
- switch($propertyType)
- $value = $featureReader->GetBoolean($name);
- break;
+ private function GetFeaturePropertyValue($featureReader, $name)
+ $value = '';
+ $propertyType = $featureReader->GetPropertyType($name);
+ switch($propertyType)
+ $value = $featureReader->GetBoolean($name);
+ break;
- $value = $featureReader->GetByte($name);
- break;
+ $value = $featureReader->GetByte($name);
+ break;
- $value = $featureReader->GetSingle($name);
- break;
+ $value = $featureReader->GetSingle($name);
+ break;
- $value = $featureReader->GetDouble($name);
- break;
+ $value = $featureReader->GetDouble($name);
+ break;
- $value = $featureReader->GetInt16($name);
- break;
+ $value = $featureReader->GetInt16($name);
+ break;
- $value = $featureReader->GetInt32($name);
- break;
+ $value = $featureReader->GetInt32($name);
+ break;
- $value = $featureReader->GetInt64($name);
- break;
+ $value = $featureReader->GetInt64($name);
+ break;
- $value = $featureReader->GetString($name);
- break;
+ $value = $featureReader->GetString($name);
+ break;
- $value = '[unsupported data type]';
- break;
- return $value;
+ $value = '[unsupported data type]';
+ break;
+ return $value;
- private function GetFeatureIdList($map, $layer, $featureReader)
- $classDef = $featureReader->GetClassDefinition();
- $idProps = $classDef->GetIdentityProperties();
- $idList = array();
+ private function GetFeatureIdList($map, $layer, $featureReader)
+ $classDef = $featureReader->GetClassDefinition();
+ $idProps = $classDef->GetIdentityProperties();
+ $idList = array();
- for ($i = 0; $i < $idProps->GetCount(); $i++)
- $idProp = $idProps->GetItem($i);
+ for ($i = 0; $i < $idProps->GetCount(); $i++)
+ $idProp = $idProps->GetItem($i);
- switch($idProp->GetDataType()) {
- $idList[$idProp->GetName()] = $featureReader->GetBoolean($idProp->GetName());
- break;
+ switch($idProp->GetDataType()) {
+ $idList[$idProp->GetName()] = $featureReader->GetBoolean($idProp->GetName());
+ break;
- $idList[$idProp->GetName()] = $featureReader->GetByte($idProp->GetName());
- break;
+ $idList[$idProp->GetName()] = $featureReader->GetByte($idProp->GetName());
+ break;
- $idList[$idProp->GetName()] = $featureReader->GetSingle($idProp->GetName());
- break;
+ $idList[$idProp->GetName()] = $featureReader->GetSingle($idProp->GetName());
+ break;
- $idList[$idProp->GetName()] = $featureReader->GetDouble($idProp->GetName());
- break;
+ $idList[$idProp->GetName()] = $featureReader->GetDouble($idProp->GetName());
+ break;
- $idList[$idProp->GetName()] = $featureReader->GetInt16($idProp->GetName());
- break;
+ $idList[$idProp->GetName()] = $featureReader->GetInt16($idProp->GetName());
+ break;
- $idList[$idProp->GetName()] = $featureReader->GetInt32($idProp->GetName());
- break;
+ $idList[$idProp->GetName()] = $featureReader->GetInt32($idProp->GetName());
+ break;
- $idList[$idProp->GetName()] = $featureReader->GetInt64($idProp->GetName());
- break;
+ $idList[$idProp->GetName()] = $featureReader->GetInt64($idProp->GetName());
+ break;
- $idList[$idProp->GetName()] = $featureReader->GetString($idProp->GetName());
- break;
+ $idList[$idProp->GetName()] = $featureReader->GetString($idProp->GetName());
+ break;
- $idList[$idProp->GetName()] = $featureReader->GetDateTime($idProp->GetName());
- break;
+ $idList[$idProp->GetName()] = $featureReader->GetDateTime($idProp->GetName());
+ break;
- break;
+ break;
- return $idList;
+ return $idList;
private function IsValidDataType($type)
@@ -475,77 +460,77 @@
switch($type)
case MgPropertyType::Blob:
- $valid = false;
- break;
+ $valid = false;
+ break;
case MgPropertyType::Clob:
- $valid = false;
- break;
+ $valid = false;
+ break;
case MgPropertyType::Byte:
- $valid = false;
- break;
+ $valid = false;
+ break;
case MgPropertyType::Feature:
- $valid = false;
- break;
+ $valid = false;
+ break;
case MgPropertyType::Geometry:
- $valid = false;
- break;
+ $valid = false;
+ break;
case MgPropertyType::Null:
- $valid = false;
- break;
+ $valid = false;
+ break;
return $valid;
- private function CreateFilterSchema()
- $filterSchema = new MgFeatureSchema();
- $filterSchema->SetName('FilterSchema');
+ private function CreateFilterSchema()
+ $filterSchema = new MgFeatureSchema();
+ $filterSchema->SetName('FilterSchema');
- $filterClass = new MgClassDefinition();
- $filterClass->SetName('Filter');
- $properties = $filterClass->GetProperties();
+ $filterClass = new MgClassDefinition();
+ $filterClass->SetName('Filter');
+ $properties = $filterClass->GetProperties();
- $idProperty = new MgDataPropertyDefinition('ID');
- $idProperty->SetDataType(MgPropertyType::Int32);
- $idProperty->SetReadOnly(true);
- $idProperty->SetNullable(false);
- $idProperty->SetAutoGeneration(true);
- $properties->Add($idProperty);
+ $idProperty = new MgDataPropertyDefinition('ID');
+ $idProperty->SetDataType(MgPropertyType::Int32);
+ $idProperty->SetReadOnly(true);
+ $idProperty->SetNullable(false);
+ $idProperty->SetAutoGeneration(true);
+ $properties->Add($idProperty);
- $geometryProperty = new MgGeometricPropertyDefinition('Geometry');
- $geometryProperty->SetGeometryTypes(MgFeatureGeometricType::Surface);
- $geometryProperty->SetHasElevation(false);
- $geometryProperty->SetHasMeasure(false);
- $geometryProperty->SetReadOnly(false);
- $geometryProperty->SetSpatialContextAssociation('MAPCS');
- $properties->Add($geometryProperty);
+ $geometryProperty = new MgGeometricPropertyDefinition('Geometry');
+ $geometryProperty->SetGeometryTypes(MgFeatureGeometricType::Surface);
+ $geometryProperty->SetHasElevation(false);
+ $geometryProperty->SetHasMeasure(false);
+ $geometryProperty->SetReadOnly(false);
+ $geometryProperty->SetSpatialContextAssociation('MAPCS');
+ $properties->Add($geometryProperty);
- $filterClass->GetIdentityProperties()->Add($idProperty);
- $filterClass->SetDefaultGeometryPropertyName('Geometry');
+ $filterClass->GetIdentityProperties()->Add($idProperty);
+ $filterClass->SetDefaultGeometryPropertyName('Geometry');
- $filterSchema->GetClasses()->Add($filterClass);
+ $filterSchema->GetClasses()->Add($filterClass);
- return $filterSchema;
+ return $filterSchema;
- private function CreatePolygonFromGeomText($geomText)
- $geometryFactory = new MgGeometryFactory();
+ private function CreatePolygonFromGeomText($geomText)
+ $geometryFactory = new MgGeometryFactory();
- $vertices = explode(',', $geomText);
- $count = $vertices[0];
+ $vertices = explode(',', $geomText);
+ $count = $vertices[0];
- $coords = new MgCoordinateCollection();
- for ($i = 0; $i < $count; $i++)
- $coord = $geometryFactory->CreateCoordinateXY((double) $vertices[($i * 2) + 1], (double) $vertices[($i * 2) + 2]);
- $coords->Add($coord);
+ $coords = new MgCoordinateCollection();
+ for ($i = 0; $i < $count; $i++)
+ $coord = $geometryFactory->CreateCoordinateXY((double) $vertices[($i * 2) + 1], (double) $vertices[($i * 2) + 2]);
+ $coords->Add($coord);
- $linearRing = $geometryFactory->CreateLinearRing($coords);
- $polygon = $geometryFactory->CreatePolygon($linearRing, null);
+ $linearRing = $geometryFactory->CreateLinearRing($coords);
+ $polygon = $geometryFactory->CreatePolygon($linearRing, null);
- return $polygon;
+ return $polygon;
\ No newline at end of file
Modified: trunk/MgDev/Doc/samples/phpviewersample/theme/classes/theme.php
--- trunk/MgDev/Doc/samples/phpviewersample/theme/classes/theme.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Doc/samples/phpviewersample/theme/classes/theme.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -27,49 +27,47 @@
class Theme
- public $distNameArray = array("Individual", "Equal", "Standard Deviation", "Quantile", "Jenks (Natural Breaks)");
- public $distValueArray = array("INDIV_DIST", "EQUAL_DIST", "STDEV_DIST", "QUANT_DIST", "JENK_DIST");
+ public $distNameArray = array("Individual", "Equal", "Standard Deviation", "Quantile", "Jenks (Natural Breaks)");
+ public $distValueArray = array("INDIV_DIST", "EQUAL_DIST", "STDEV_DIST", "QUANT_DIST", "JENK_DIST");
$layer = $layers->GetItem($i);
+ $resId = new MgResourceIdentifier($layer->GetFeatureSourceId());
+ $schemaClass = explode(':', $layer->GetFeatureClassName());
+ $propDef = $clsProps->GetItem($layer->GetFeatureGeometryName());
- $propDef = $classDef->GetProperties()->GetItem($layer->GetFeatureGeometryName());
- if($propDef->GetPropertyType() == MgFeaturePropertyType::GeometricProperty)
- if ($propDef->GetGeometryTypes() == MgFeatureGeometricType::Surface)
+ if($propDef->GetPropertyType() == MgFeaturePropertyType::GeometricProperty)
+ if ($propDef->GetGeometryTypes() == MgFeatureGeometricType::Surface)
asort($layerNames);
@@ -79,76 +77,71 @@
function GetLayerInfo()
- $scaleRanges = array();
+ $scaleRanges = array();
- // First get a list of all of the Feature Class properties that can be used for theming.
+ // First get a list of all of the Feature Class properties that can be used for theming.
- $distroTypes = $this->GetDistributionsForDataType($dataType);
- if (count($distroTypes) > 0)
- array_push($properties, new Property($propertyDef->GetName(), $dataType, $distroTypes));
+ $distroTypes = $this->GetDistributionsForDataType($dataType);
+ if (count($distroTypes) > 0)
+ array_push($properties, new Property($propertyDef->GetName(), $dataType, $distroTypes));
- // Next get a list of all of the layers scale ranges.
+ // Next get a list of all of the layers scale ranges.
- $layerDefResId = $layer->GetLayerDefinition();
- $byteReader = $resourceService->GetResourceContent($layerDefResId);
+ $layerDefResId = $layer->GetLayerDefinition();
+ $byteReader = $resourceService->GetResourceContent($layerDefResId);
- $doc = DOMDocument::loadXML($byteReader->ToString());
- $nodeList = $doc->getElementsByTagName('VectorScaleRange');
+ $doc->loadXML($byteReader->ToString());
+ $nodeList = $doc->getElementsByTagName('VectorScaleRange');
- foreach ($nodeList as $node)
- $range = null;
+ foreach ($nodeList as $node)
+ $range = null;
- $minNodeList = $node->getElementsByTagName('MinScale');
- if ($minNodeList->length > 0)
- $range = $minNodeList->item(0)->nodeValue;
- else
- $range = '0';
+ $minNodeList = $node->getElementsByTagName('MinScale');
+ if ($minNodeList->length > 0)
+ $range = $minNodeList->item(0)->nodeValue;
+ else
+ $range = '0';
- $maxNodeList = $node->getElementsByTagName('MaxScale');
- if ($maxNodeList->length > 0)
- $range .= ' - ' . $maxNodeList->item(0)->nodeValue;
- else
- $range .= ' - Infinity';
+ $maxNodeList = $node->getElementsByTagName('MaxScale');
+ if ($maxNodeList->length > 0)
+ $range .= ' - ' . $maxNodeList->item(0)->nodeValue;
+ else
+ $range .= ' - Infinity';
- array_push($scaleRanges, $range);
+ array_push($scaleRanges, $range);
return new LayerInfo($properties, $scaleRanges);
- function GetPropertyMinMaxCount()
+ function GetPropertyMinMaxCount()
// Note: Should be able to do this:
@@ -174,249 +167,250 @@
// However due to a bug, Min/Max do not work on string types, so we have to do this:
- unset($minValue);
- unset($maxValue);
- $count = 0;
+ unset($minValue);
+ unset($maxValue);
+ $count = 0;
- $queryOptions->AddFeatureProperty($this->args['PROPERTYNAME']);
+ $queryOptions->AddFeatureProperty($this->args['PROPERTYNAME']);
+ $featureReader = $layer->SelectFeatures($queryOptions);
- while($featureReader->ReadNext())
- $value = $this->GetFeaturePropertyValue($featureReader, $this->args['PROPERTYNAME']);
- if ($value != null)
- if(!isset($maxValue) && !isset($minValue))
- $maxValue = $value;
- $minValue = $value;
- if($value > $maxValue)
- if($value < $minValue)
- $count++;
- $featureReader->Close();
+ while($featureReader->ReadNext())
+ $value = $this->GetFeaturePropertyValue($featureReader, $this->args['PROPERTYNAME']);
+ if ($value != null)
+ if(!isset($maxValue) && !isset($minValue))
+ $maxValue = $value;
+ $minValue = $value;
+ if($value > $maxValue)
+ if($value < $minValue)
+ $count++;
+ $featureReader->Close();
- $maxValue="";
- $minValue="";
+ $maxValue="";
+ $minValue="";
- return array($minValue, $maxValue, $count);
+ return array($minValue, $maxValue, $count);
- function ApplyTheme()
+ function ApplyTheme()
- // Load the Layer Definition and Navigate to the specified <VectorScaleRange>
+ // Load the Layer Definition and Navigate to the specified <VectorScaleRange>
- $vectorScaleRangecElement = $nodeList->item($this->args['SCALERANGEINDEX']);
- $areaTypeStyle = $vectorScaleRangecElement->getElementsByTagName('AreaTypeStyle')->item(0);
+ $vectorScaleRangecElement = $nodeList->item($this->args['SCALERANGEINDEX']);
+ $areaTypeStyle = $vectorScaleRangecElement->getElementsByTagName('AreaTypeStyle')->item(0);
- // Remove any existing <AreaRule> elements.
+ // Remove any existing <AreaRule> elements.
- $areaRuleList = $areaTypeStyle->getElementsByTagName('AreaRule');
- $ruleCount = $areaRuleList->length;
- for($index = 0; $index < $ruleCount; $index++)
- $areaTypeStyle->removeChild($areaRuleList->item(0));
+ $areaRuleList = $areaTypeStyle->getElementsByTagName('AreaRule');
+ $ruleCount = $areaRuleList->length;
+ for($index = 0; $index < $ruleCount; $index++)
+ $areaTypeStyle->removeChild($areaRuleList->item(0));
- // Now create the new <AreaRule> elements.
+ // Now create the new <AreaRule> elements.
- $areaRuleTemplate = file_get_contents("templates/arearuletemplate.xml");
- $aggregateOptions = new MgFeatureAggregateOptions();
+ $areaRuleTemplate = file_get_contents("templates/arearuletemplate.xml");
+ $aggregateOptions = new MgFeatureAggregateOptions();
- $portion = 0.0;
- $increment = ($this->args['NUMRULES'] > 1) ? $increment = 1.0 / ($this->args['NUMRULES'] - 1) : 1.0;
+ $portion = 0.0;
+ $increment = ($this->args['NUMRULES'] > 1) ? $increment = 1.0 / ($this->args['NUMRULES'] - 1) : 1.0;
- if ($this->args['DISTRO'] == 'INDIV_DIST')
- $aggregateOptions->AddFeatureProperty($this->args['PROPERTYNAME']);
- $aggregateOptions->SelectDistinct(true);
+ if ($this->args['DISTRO'] == 'INDIV_DIST')
+ $aggregateOptions->AddFeatureProperty($this->args['PROPERTYNAME']);
+ $aggregateOptions->SelectDistinct(true);
- $dataReader = $featureService->SelectAggregate($resId, $layer->GetFeatureClassName(), $aggregateOptions);
- while ($dataReader->ReadNext())
- $value = $this->GetFeaturePropertyValue($dataReader, $this->args['PROPERTYNAME']);
+ $dataReader = $layer->SelectAggregate($aggregateOptions);
+ while ($dataReader->ReadNext())
+ $value = $this->GetFeaturePropertyValue($dataReader, $this->args['PROPERTYNAME']);
- $filterText = '"' . $this->args['PROPERTYNAME'] . '" = ';
- if ($this->args['DATATYPE'] == MgPropertyType::String)
- $filterText .= "'" . $value . "'";
- else
- $filterText .= $value;
+ $filterText = '"' . $this->args['PROPERTYNAME'] . '" = ';
+ if ($this->args['DATATYPE'] == MgPropertyType::String)
+ $filterText .= "'" . $value . "'";
+ else
+ $filterText .= $value;
- $areaRuleXML = sprintf($areaRuleTemplate,
- $this->args['PROPERTYNAME'] . ': ' . $value,
- $filterText,
- $this->InterpolateColor($portion, $this->args['FILLFROM'], $this->args['FILLTO'], $this->args['FILLTRANS']),
- $this->InterpolateColor($portion, $this->args['LINEFROM'], $this->args['LINETO'], 0));
+ $areaRuleXML = sprintf($areaRuleTemplate,
+ $this->args['PROPERTYNAME'] . ': ' . $value,
+ $filterText,
+ $this->InterpolateColor($portion, $this->args['FILLFROM'], $this->args['FILLTO'], $this->args['FILLTRANS']),
+ $this->InterpolateColor($portion, $this->args['LINEFROM'], $this->args['LINETO'], 0));
- $areaDoc = DOMDocument::loadXML($areaRuleXML);
- $areaNode = $doc->importNode($areaDoc->documentElement, true);
- $areaTypeStyle->appendChild($areaNode);
+ $areaDoc = new DOMDocument();
+ $areaDoc->loadXML($areaRuleXML);
+ $areaNode = $doc->importNode($areaDoc->documentElement, true);
+ $areaTypeStyle->appendChild($areaNode);
- $portion += $increment;
- $dataReader->Close();
- else
- $values = array();
+ $portion += $increment;
+ $dataReader->Close();
+ else
+ $values = array();
- $aggregateOptions->AddComputedProperty('THEME_VALUE',
- $this->args['DISTRO'] . '("' . $this->args['PROPERTYNAME'] . '",' . $this->args['NUMRULES'] . ',' . $this->args['MINVALUE'] . ',' . $this->args['MAXVALUE'] . ')');
+ $aggregateOptions->AddComputedProperty('THEME_VALUE',
+ $this->args['DISTRO'] . '("' . $this->args['PROPERTYNAME'] . '",' . $this->args['NUMRULES'] . ',' . $this->args['MINVALUE'] . ',' . $this->args['MAXVALUE'] . ')');
- $value = $this->GetFeaturePropertyValue($dataReader, 'THEME_VALUE');
- array_push($values, $value);
+ $value = $this->GetFeaturePropertyValue($dataReader, 'THEME_VALUE');
+ array_push($values, $value);
- for ($i = 0; $i < count($values) - 1; $i++)
- $filterText = '"' . $this->args['PROPERTYNAME'] . '" >= ' . $values[$i] . ' AND "' . $this->args['PROPERTYNAME'];
- if ($i == count($values) - 1)
- $filterText .= '" <= ' . $values[$i + 1];
- else
- $filterText .= '" < ' . $values[$i + 1];
+ for ($i = 0; $i < count($values) - 1; $i++)
+ $filterText = '"' . $this->args['PROPERTYNAME'] . '" >= ' . $values[$i] . ' AND "' . $this->args['PROPERTYNAME'];
+ if ($i == count($values) - 1)
+ $filterText .= '" <= ' . $values[$i + 1];
+ else
+ $filterText .= '" < ' . $values[$i + 1];
- $this->args['PROPERTYNAME'] . ': ' . $values[$i] . ' - ' . $values[$i + 1],
- $filterText,
+ $this->args['PROPERTYNAME'] . ': ' . $values[$i] . ' - ' . $values[$i + 1],
+ $filterText,
- // Now save our new layer definition to the session and add it to the map.
+ // Now save our new layer definition to the session and add it to the map.
- $layerDefinition = $doc->saveXML();
- $uniqueName = $this->MakeUniqueLayerName($map, $this->args['LAYERNAME'], $this->args['THEMENAME']);
- $legendLabel = $layer->GetLegendLabel();
- if (strlen(trim($this->args['THEMENAME'])) > 0 )
- $legendLabel .= ' (' . $this->args['THEMENAME'] . ')';
+ $layerDefinition = $doc->saveXML();
+ $uniqueName = $this->MakeUniqueLayerName($map, $this->args['LAYERNAME'], $this->args['THEMENAME']);
+ $legendLabel = $layer->GetLegendLabel();
+ if (strlen(trim($this->args['THEMENAME'])) > 0 )
+ $legendLabel .= ' (' . $this->args['THEMENAME'] . ')';
- $layerResId = new MgResourceIdentifier('Session:' . $this->args['SESSION'] . '//' . $uniqueName . '.LayerDefinition');
+ $layerResId = new MgResourceIdentifier('Session:' . $this->args['SESSION'] . '//' . $uniqueName . '.LayerDefinition');
- $newLayer = new MgLayer($layerResId, $resourceService);
- $newLayer->SetName($uniqueName);
- $newLayer->SetLegendLabel($legendLabel);
- $newLayer->SetDisplayInLegend($layer->GetDisplayInLegend());
- $newLayer->SetVisible(true);
- $newLayer->SetSelectable($layer->GetLegendLabel());
- $layers->Insert($layers->IndexOf($layer), $newLayer);
+ $newLayer = new MgLayer($layerResId, $resourceService);
+ $newLayer->SetName($uniqueName);
+ $newLayer->SetLegendLabel($legendLabel);
+ $newLayer->SetDisplayInLegend($layer->GetDisplayInLegend());
+ $newLayer->SetVisible(true);
+ $newLayer->SetSelectable($layer->GetLegendLabel());
+ $layers->Insert($layers->IndexOf($layer), $newLayer);
- $map->Save($resourceService);
+ $map->Save();
- return $uniqueName;
+ return $uniqueName;
- private function InterpolateColor($portion, $startColor, $endColor, $percentTransparent)
- $result = sprintf("%02x", 255 * (100 - $percentTransparent) / 100);
+ private function InterpolateColor($portion, $startColor, $endColor, $percentTransparent)
+ $result = sprintf("%02x", 255 * (100 - $percentTransparent) / 100);
- if ($startColor == $endColor)
- return $result . $startColor;
+ if ($startColor == $endColor)
+ return $result . $startColor;
- $red = $this->CalculateRGB($portion, substr($startColor, 0, 2), substr($endColor, 0, 2));
- $result = (strlen(dechex($red)) == 1) ? $result . "0" . dechex($red) : $result . dechex($red);
- $green = $this->CalculateRGB($portion, substr($startColor, 2, 2), substr($endColor, 2, 2));
- $result = (strlen(dechex($green)) == 1) ? $result . "0" . dechex($green) : $result . dechex($green);
- $blue = $this->CalculateRGB($portion, substr($startColor, 4, 2), substr($endColor, 4, 2));
- $result = (strlen(dechex($blue)) == 1) ? $result . "0" . dechex($blue) : $result . dechex($blue);
+ $red = $this->CalculateRGB($portion, substr($startColor, 0, 2), substr($endColor, 0, 2));
+ $result = (strlen(dechex($red)) == 1) ? $result . "0" . dechex($red) : $result . dechex($red);
+ $green = $this->CalculateRGB($portion, substr($startColor, 2, 2), substr($endColor, 2, 2));
+ $result = (strlen(dechex($green)) == 1) ? $result . "0" . dechex($green) : $result . dechex($green);
+ $blue = $this->CalculateRGB($portion, substr($startColor, 4, 2), substr($endColor, 4, 2));
+ $result = (strlen(dechex($blue)) == 1) ? $result . "0" . dechex($blue) : $result . dechex($blue);
- return $result;
+ return $result;
- private function CalculateRGB($portion, $startRGB, $endRGB)
- return (hexdec($startRGB) + ($portion * (hexdec($endRGB) - hexdec($startRGB))));
+ private function CalculateRGB($portion, $startRGB, $endRGB)
+ return (hexdec($startRGB) + ($portion * (hexdec($endRGB) - hexdec($startRGB))));
- $value = '';
- break;
+ $value = '';
+ break;
- break;
+ break;
- break;
+ break;
- break;
+ break;
- break;
+ break;
- break;
+ break;
- break;
+ break;
- break;
+ break;
- break;
- return $value;
+ break;
+ return $value;
private function GetDistributionsForDataType($type)
@@ -424,47 +418,47 @@
switch($type)
- case MgPropertyType::String:
- array_push($distros, 0);
- break;
+ case MgPropertyType::String:
+ array_push($distros, 0);
+ break;
- array_push($distros, 0, 1, 2, 3, 4);
- break;
+ array_push($distros, 0, 1, 2, 3, 4);
+ break;
- array_push($distros, 1, 2, 3, 4);
- break;
+ array_push($distros, 1, 2, 3, 4);
+ break;
- case MgPropertyType::Boolean:
- case MgPropertyType::DateTime:
+ case MgPropertyType::Boolean:
+ case MgPropertyType::DateTime:
- break;
+ break;
return $distros;
- private function MakeUniqueLayerName($map, $layerName, $themeName)
- $desiredName = "_" . $layerName . $themeName;
- $uniqueName = $desiredName;
- $index = 1;
+ private function MakeUniqueLayerName($map, $layerName, $themeName)
+ $desiredName = "_" . $layerName . $themeName;
+ $uniqueName = $desiredName;
+ $index = 1;
- while ($map->GetLayers()->Contains($uniqueName))
- $uniqueName = $desiredName . $index;
- $index++;
+ while ($map->GetLayers()->Contains($uniqueName))
+ $uniqueName = $desiredName . $index;
+ $index++;
Modified: trunk/MgDev/UnitTest/Common/DotNetWrappers/CollectionTest.cs
--- trunk/MgDev/UnitTest/Common/DotNetWrappers/CollectionTest.cs 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/UnitTest/Common/DotNetWrappers/CollectionTest.cs 2014-06-17 10:16:51 UTC (rev 8236)
@@ -448,15 +448,16 @@
[Test]
public void MapCollection()
+ MgSiteConnection conn = new MgSiteConnection();
string coordsys = "GEOGCS[\"LL84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9108\"]],AXIS[\"Lat\",NORTH],AXIS[\"Long\",EAST],AUTHORITY[\"EPSG\",\"4326\"]]";
MgEnvelope env = new MgEnvelope(10,10,20,20);
- MgMap map1 = new MgMap();
+ MgMap map1 = new MgMap(conn);
map1.Create(coordsys, env, "map1");
- MgMap map2 = new MgMap();
+ MgMap map2 = new MgMap(conn);
map2.Create(coordsys, env, "map2");
- MgMap map3 = new MgMap();
+ MgMap map3 = new MgMap(conn);
map3.Create(coordsys, env, "map3");
- MgMap map4 = new MgMap();
+ MgMap map4 = new MgMap(conn);
map4.Create(coordsys, env, "map4");
MgMapCollection coll = new MgMapCollection();
@@ -481,15 +482,16 @@
[Test]
public void MapPlotCollection()
MgPlotSpecification spec = new MgPlotSpecification((float)8.0, (float)11.0, "in", (float)0.0, (float)0.0, (float)5.0, (float)5.0);
Modified: trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTestExecutorCollection.cs 2014-06-17 10:16:51 UTC (rev 8236)
@@ -43,7 +43,7 @@
var admin = new MgServerAdmin();
admin.Open(_userInfo);
var wlCreator = new MgWebLayoutCreator(resSvc);
- var creator = new MgMapCreator(resSvc);
+ var creator = new MgMapCreator(_conn, resSvc);
var sessionCreator = new MgSessionCreator(_conn);
var sessionApply = new MgApplySession(_userInfo);
var session = new MgSession();
@@ -210,11 +210,13 @@
class MgMapCreator : Operations.IMapCreator
+ private MgSiteConnection _siteConn;
+ private MgMap _map;
private MgResourceService _resSvc;
- private MgMap _map;
- public MgMapCreator(MgResourceService resSvc)
+ public MgMapCreator(MgSiteConnection siteConn, MgResourceService resSvc)
+ _siteConn = siteConn;
_resSvc = resSvc;
@@ -225,8 +227,8 @@
if (_map != null)
return _map;
- _map = new MgMap();
- _map.Create(_resSvc, resId, resId.GetName());
+ _map = new MgMap(_siteConn);
+ _map.Create(resId, resId.GetName());
return _map;
Modified: trunk/MgDev/UnitTest/WebTier/Php/HtmlPrinter.php
--- trunk/MgDev/UnitTest/WebTier/Php/HtmlPrinter.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/UnitTest/WebTier/Php/HtmlPrinter.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -23,7 +23,7 @@
class HtmlPrinter
- public function PrintHtmlHeader($title)
+ public static function PrintHtmlHeader($title)
print ("<html>\n");
print ("<head>\n");
@@ -33,7 +33,7 @@
print("<h2>$title</h2>\n");
- public function PrintTestCases($testSuite, $dumpFilePath, $testType)
+ public static function PrintTestCases($testSuite, $dumpFilePath, $testType)
try
@@ -72,21 +72,21 @@
self::printTableEnd();
- public function PrintTestTableHeader($caption="", $c1="", $c2="", $c3="")
+ public static function PrintTestTableHeader($caption="", $c1="", $c2="", $c3="")
print("<table border=\"1\" cellpadding=\"5\">\n");
print("<h3><b>$caption</b></h3>");
print("<tr>\n");
- printf("<td> </td>\n<th>%s</th>\n<th>%s</th><th>%s</th>\n", $c1, $c2, $c3);
+ printf("<td> </td>\n<th>%s</th>\n<th>%s</th><th>%s</th><th> </th>\n", $c1, $c2, $c3);
print("</tr>\n");
- public function printTableEnd()
+ public static function printTableEnd()
print("</table><br />\n");
- public function PrintSelectTestMode()
+ public static function PrintSelectTestMode()
print("<h3>Select Test Mode</h3>\n");
print("<p>\n");
@@ -97,7 +97,7 @@
print("</p>\n");
- public function PrintSelectOutput()
+ public static function PrintSelectOutput()
print("<h3>Select Output</h3>\n");
print("<p>\n");
@@ -108,25 +108,25 @@
print("</p>\n");
- public function PrintHtmlFooter()
+ public static function PrintHtmlFooter()
print ("</body>\n");
print ("</html>\n");
- public function PrintFormHeader($target)
+ public static function PrintFormHeader($target)
print ("<form name=\"input\" action=\"$target\" method=\"POST\" id=\"myform\">\n");
- public function PrintFormFooter($requestType, $action)
+ public static function PrintFormFooter($requestType, $action)
print("<td><input type=\"hidden\" name=\"requestType\" value=\"$requestType\"></td>\n");
print ("<input type=\"submit\" value=\"$action\" ID=\"$action\" NAME=\"$action\"> <input type=\"reset\" ID=\"Reset1\" NAME=\"Reset1\">\n");
print ("</form>\n");
- public function AddResultRow($operation, $outcome, $paramSet, $actualResult="", $expectedResult="")
+ public static function AddResultRow($operation, $outcome, $paramSet, $actualResult="", $expectedResult="")
$checkBox="<input type=\"checkbox\" name=$paramSet>";
if ( $outcome=="fail")
@@ -141,16 +141,17 @@
print("</tr>");
- public function PrintResultTableHeader($caption="")
+ public static function PrintResultTableHeader($caption="")
print("<table scroll=\"no\" border=\"1\" cellpadding=\"5\">\n");
+ print("<col width=10><col width=20><col width=40><col width=20><col width=180><col width=180><col>");
print("<tr>\n");
print("<td> </td><th>Param Set</th><th>Operation</th>\n<th>Outcome</th>\n<th>Actual Result</th>\n<th>Expected Result</th>\n");
print("</tr>\n");
- public function PrintGenerateFormHiddenFields()
+ public static function PrintGenerateFormHiddenFields()
$output = $_POST['output'];
$testName = $_POST['testName'];
Modified: trunk/MgDev/UnitTest/WebTier/Php/MapLayerAPI.php
--- trunk/MgDev/UnitTest/WebTier/Php/MapLayerAPI.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/UnitTest/WebTier/Php/MapLayerAPI.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -503,8 +503,8 @@
$mapDefId = new MgResourceIdentifier($mapName);
- $this->map = new MgMap();
- $this->map->Create($this->resSrvc, $mapDefId, $mapDefId->GetName());
+ $this->map = new MgMap($this->site);
+ $this->map->Create($mapDefId, $mapDefId->GetName());
Modified: trunk/MgDev/UnitTest/WebTier/Php/Run.php
--- trunk/MgDev/UnitTest/WebTier/Php/Run.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/UnitTest/WebTier/Php/Run.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -118,7 +118,7 @@
catch (MgException $e)
- print $e->GetExceptionMessage('en');
+ print $e->GetDetails();
return false;
catch (SqliteException $s)
Modified: trunk/MgDev/UnitTest/WebTier/Php/RunTests.php
--- trunk/MgDev/UnitTest/WebTier/Php/RunTests.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/UnitTest/WebTier/Php/RunTests.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -163,6 +163,7 @@
print $s->GetExceptionMessage();
+ $s->Dispose();
return 1;
Copied: trunk/MgDev/UnitTest/WebTier/Php/SQLiteEngine.php (from rev 8225, sandbox/jng/v30/UnitTest/WebTier/Php/SQLiteEngine.php)
--- trunk/MgDev/UnitTest/WebTier/Php/SQLiteEngine.php (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Php/SQLiteEngine.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -0,0 +1,214 @@
+<?php
+// SQLiteEngine.php
+// A PHP-based implementation of SqliteDB and SqliteVM class using PDO instead
+// of the internal SWIG-wrapped SQLite classes in Oem
+// This avoids any access violation issues should our test runner happen to
+// be mis-using any classes in the SWIG wrapper.
+if (!defined('SQLITE_ROW')) {
+ define('SQLITE_ROW', 100);
+if (!extension_loaded("SQLitePhpApi"))
+ //echo "SQLitePhpApi not loaded. Using PHP implementation";
+ class SqliteException extends Exception
+ class CantOpenDbException extends SqliteException
+ class SqliteDB
+ private $dbh;
+ private $dbName;
+ public function __construct()
+ $this->dbh = NULL;
+ $this->dbName = "";
+ public function __destruct()
+ $this->Close();
+ public function Close()
+ if ($this->dbh != NULL)
+ public function GetHandle() { return $this->dbh; }
+ public function Open($dbName)
+ $this->Close();
+ $this->dbh = new PDO("sqlite:$dbName");
+ $this->dbh->setAttribute(PDO::ATTR_ERRMODE, PDO::ERRMODE_EXCEPTION);
+ $this->dbName = $dbName;
+ public function GetName() { return $this->dbName; }
+ public function GenerateDatabase($dumpFilePath, $dbPath)
+ if (php_sapi_name() == 'cli')
+ echo "Generating database from dump: $dumpFilePath\n";
+ else
+ echo "Generating database from dump: $dumpFilePath<br/>";
+ $pdo = new PDO("sqlite:$dbPath");
+ $pdo->setAttribute(PDO::ATTR_ERRMODE, PDO::ERRMODE_EXCEPTION);
+ $sql = file_get_contents($dumpFilePath);
+ $pdo->exec($sql);
+ $pdo = NULL;
+ public function DumpDatabase($path)
+ throw new Exception("Creating database dumps not implemented. Please run this script with the php_SQLitePhpApi extension loaded");
+ class SqliteVM
+ private $db;
+ private $currentStmt;
+ private $currentRow;
+ private $resultLOB;
+ private $nameIndexMap;
+ public function __construct($db)
+ $this->db = $db->GetHandle();
+ $this->currentStmt = NULL;
+ $this->currentRow = NULL;
+ $this->nameIndexMap = array();
+ public function Execute($query)
+ echo "Executing: $query\n";
+ else
+ echo "Executing: $query<br/>";
+ if ($this->currentStmt != NULL)
+ $this->currentStmt->closeCursor();
+ $this->currentStmt = $this->db->prepare($query);
+ try
+ if ($this->currentStmt === FALSE)
+ echo "ERROR: Failed to prepare query: $query\n";
+ else
+ echo "ERROR: Failed to prepare query: $query<br/>";
+ return -1;
+ if (!$this->currentStmt->execute())
+ echo "ERROR: Failed to execute query: $query\n";
+ else
+ echo "ERROR: Failed to execute query: $query<br/>";
+ return -1;
+ catch (PDOException $e)
+ return -1;
+ //Compile name index map for the purposes of column binding below
+ for ($i = 0; $i < $this->currentStmt->columnCount(); $i++)
+ try {
+ $col = $this->currentStmt->getColumnMeta($i);
+ if ($col === FALSE)
+ continue;
+ } catch (PDOException $e) {
+ continue;
+ if (array_key_exists("name", $col))
+ $colName = $col["name"];
+ $this->nameIndexMap[$colName] = $i;
+ //Bind columns, paying special attention to bind Result as BLOB if found
+ $this->currentRow = array();
+ foreach ($this->nameIndexMap as $colName => $index)
+ if ($colName == "Result") {
+ $this->currentStmt->bindColumn(($index+1), $this->currentRow[$colName], PDO::PARAM_LOB);
+ //echo "Bound $colName as BLOB<br/>";
+ } else {
+ $this->currentStmt->bindColumn(($index+1), $this->currentRow[$colName]);
+ try
+ $res = $this->currentStmt->fetch();
+ if ($res === FALSE)
+ return -1;
+ return -1;
+ return SQLITE_ROW;
+ public function GetString($name)
+ if (array_key_exists($name, $this->currentRow))
+ return $this->currentRow[$name];
+ return "";
+ public function GetBlob($name)
+ $str = $this->currentRow[$name];
+ //SqliteBlob in C++ has a MgByteReader-style interface. Since
+ //in PHP if it quacks like a duck ... we'll give them an actual MgByteReader
+ $source = new MgByteSource($str, strlen($str));
+ return $source->GetReader();
+ public function NextRow()
+ $this->currentRow = $this->currentStmt->fetch();
+ if ($this->currentRow === FALSE)
+ return -1;
+ public function SqlFinalize()
Copied: trunk/MgDev/UnitTest/WebTier/Php/UpdateDumpFiles.php (from rev 8225, sandbox/jng/v30/UnitTest/WebTier/Php/UpdateDumpFiles.php)
--- trunk/MgDev/UnitTest/WebTier/Php/UpdateDumpFiles.php (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Php/UpdateDumpFiles.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -0,0 +1,74 @@
+<?php
+// Copyright (C) 2004-2014 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+//Command line script that executes all tests in the given database files
+define('Run_MAIN_METHOD', true);
+require_once("sqlite_constants.php");
+require_once("Utils.php");
+main();
+function main()
+ if (($_SERVER['argc'] >1) && ($_SERVER['argv'][1] == "-help"))
+ ShowUsage();
+ return 1;
+ $updatesFailed = 0;
+ $updatesFailed += UpdateDumpFile("../../TestData/ResourceService/ResourceServiceTest.db");
+ $updatesFailed += UpdateDumpFile("../../TestData/DrawingService/DrawingServiceTest.db");
+ $updatesFailed += UpdateDumpFile("../../TestData/FeatureService/FeatureServiceTest.db");
+ $updatesFailed += UpdateDumpFile("../../TestData/SiteService/SiteServiceTest.db");
+ $updatesFailed += UpdateDumpFile("../../TestData/MappingService/MappingServiceTest.db");
+ $updatesFailed += UpdateDumpFile("../../TestData/ServerAdmin/ServerAdminTest.db");
+ $updatesFailed += UpdateDumpFile("../../TestData/MapLayer/MapLayerTest.db");
+ $updatesFailed += UpdateDumpFile("../../TestData/WebLayout/WebLayoutTest.db");
+ $updatesFailed += UpdateDumpFile("../../TestData/Wfs/WfsTest.db");
+ $updatesFailed += UpdateDumpFile("../../TestData/Wms/WmsTest.db");
+ $updatesFailed += UpdateDumpFile("../../TestData/Unicode/UnicodeTest.db");
+ exit($updatesFailed);
+function UpdateDumpFile($dbName)
+ echo "Checking $dbName\n";
+ $ret = 0;
+ $db = NULL;
+ try {
+ $dbPath = Utils::GetPath($dbName);
+ $db = new SqliteDB();
+ $db->Open($dbPath);
+ Utils::CreateDumpFile($db, true);
+ } catch (SqliteException $ex) {
+ echo $ex->GetExceptionMessage()."\n";
+ $ret = 1;
+ $db = NULL;
+ return $ret;
+function ShowUsage()
+ printf("Usage: php UpdateDumpFiles.php\n");
Modified: trunk/MgDev/UnitTest/WebTier/Php/Utils.php
--- trunk/MgDev/UnitTest/WebTier/Php/Utils.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/UnitTest/WebTier/Php/Utils.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -19,6 +19,8 @@
//Class that defines static methods that are commonly used in the infrastructure
+require_once("SQLiteEngine.php");
if (!defined('WEBCONFIGINI')) {
if (array_key_exists("WEBCONFIGINI", $_SERVER)) {
define("WEBCONFIGINI", $_SERVER["WEBCONFIGINI"]);
@@ -246,28 +248,51 @@
return $dbPath;
- public static function CreateDumpFile($db)
+ public static function CreateDumpFile($db, $overwrite = false)
$dbName = $db->GetName();
$iniFileName = substr($dbName, 0, strpos($dbName, ".db")).".ini";
$dumpFileName = substr($dbName, 0, strpos($dbName, ".db")).".dump";
- //Clear the stat cache as filemtime may not work correctly
- clearstatcache();
- //Check if the file exists and is writable before updating it
- if (!file_exists($dumpFileName) || (is_writable($dumpFileName)&&filemtime($db->GetName())>filemtime($dumpFileName)))
+ if ($overwrite)
+ if (file_exists($dumpFileName))
+ unlink($dumpFileName);
$iniFileContent =".output ".$dumpFileName;
file_put_contents($iniFileName, $iniFileContent);
$db->DumpDatabase($iniFileName);
- printf("<b>Updated dump file <i>%s</i></b>", $dumpFileName);
+ printf("Updated dump file: %s\n", $dumpFileName);
+ else
+ printf("<b>Updated dump file <i>%s</i></b>", $dumpFileName);
unlink($iniFileName);
else
- printf("<b>Dump file <i>%s</i> already exists and is read only or is newer than the database. File has not been updated</b>", $dumpFileName);
+ //Clear the stat cache as filemtime may not work correctly
+ clearstatcache();
+ //Check if the file exists and is writable before updating it
+ if (!file_exists($dumpFileName) || (is_writable($dumpFileName)&&filemtime($db->GetName())>filemtime($dumpFileName)))
+ $iniFileContent =".output ".$dumpFileName;
+ file_put_contents($iniFileName, $iniFileContent);
+ $db->DumpDatabase($iniFileName);
+ else
+ unlink($iniFileName);
+ else
+ printf("Dump file %s already exists and is read only or is newer than the database. File has not been updated\n", $dumpFileName);
+ else
+ printf("<b>Dump file <i>%s</i> already exists and is read only or is newer than the database. File has not been updated</b>", $dumpFileName);
Modified: trunk/MgDev/UnitTest/WebTier/Php/Validate.php
--- trunk/MgDev/UnitTest/WebTier/Php/Validate.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/UnitTest/WebTier/Php/Validate.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -57,6 +57,8 @@
//Get the file extension that will be used for a dump
$actualExtension = ValidateUtils::GetExtension($mimeType);
+ $bAlwaysPass = false;
+ $passReason = "";
//If we have an ALWAYSPASS parameter defined for the operation then skip the whole validation process
//This parameter should only be used for clean up operations that are no related with the tests
if ($this->vm->Execute("Select ParamValue from Params where ParamName=\"ALWAYSPASS\" and ParamSet=$paramSet")!=SQLITE_ROW)
@@ -170,6 +172,11 @@
+ else
+ $bAlwaysPass = true;
+ $passReason = $this->vm->GetString("ParamValue");
if ($_POST['output']=="html")
@@ -181,7 +188,9 @@
else
- HtmlPrinter::AddResultRow($operation, $outcome, $paramSet);
+ HtmlPrinter::AddResultRow($operation, $outcome, $paramSet, $resultData, $expectedResult);
+ //$str = sprintf("\n****ACTUAL RESULT****\n%s\n****EXPECTED RESULT****\n%s\n********\n\n\n", $resultData, $expectedResult);
+ //fwrite($file, $str);
else
@@ -193,6 +202,21 @@
echo $str;
+ else
+ if ($bAlwaysPass)
+ echo "Test (ParamSet: $paramSet) set to ALWAYSPASS: ".$passReason;
+ echo "\n";
+ else
+ echo "<br/>";
return $exitStatus;
@@ -215,6 +239,8 @@
//Get the extension for the dump file based on the content type of the result
$actualExtension = ValidateUtils::GetExtension($contentType);
+ $passReason = "";
//If ALWAYSPASS parameter is defined the the whole validation is skipped.
//This parameter should only be used for clean up operations that are no related to the test
@@ -348,6 +374,11 @@
+ else
@@ -360,6 +391,8 @@
else
else
@@ -371,6 +404,21 @@
echo $str;
+ else
+ if ($bAlwaysPass)
+ echo "\n";
+ else
+ echo "<br/>";
return $exitStatus;
Modified: trunk/MgDev/UnitTest/WebTier/Php/testAwSelection.php
--- trunk/MgDev/UnitTest/WebTier/Php/testAwSelection.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/UnitTest/WebTier/Php/testAwSelection.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -211,8 +211,8 @@
$fsvc->UpdateFeatures($id, $cmdColl, false);
$mapId = new MgResourceIdentifier("Library://TrevorWekel/NewSdf.MapDefinition");
- $map->Create($rsvc, $mapId, "NewMap");
+ $map = new MgMap($site);
+ $map->Create($mapId, "NewMap");
echo "Building Selection from Add()\n";
$sel = new MgSelection($map);
Modified: trunk/MgDev/Web/src/mapadmin/performanceReport_GetResult.php
--- trunk/MgDev/Web/src/mapadmin/performanceReport_GetResult.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapadmin/performanceReport_GetResult.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -198,7 +198,6 @@
$siteConn = new MgSiteConnection();
$siteConn->Open($userInfo);
- $resourceService = $siteConn->CreateService(MgServiceType::ResourceService);
$profilingService = $siteConn->CreateService(MgServiceType::ProfilingService);
//the profiling result is saved as xml file, the file name is unique
@@ -207,8 +206,8 @@
$resourceID = new MgResourceIdentifier($mapResourceId);
// Get a runtime map from a map definition
- $map->Create($resourceService, $resourceID, $newXmlFileId);
+ $map = new MgMap($siteConn);
+ $map->Create($resourceID, $newXmlFileId);
//The result will not show base layers
RemoveBaseLayers($map);
Modified: trunk/MgDev/Web/src/mapviewerjava/buffer.jsp
--- trunk/MgDev/Web/src/mapviewerjava/buffer.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerjava/buffer.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -101,8 +101,8 @@
//load the map runtime state
- MgMap map = new MgMap();
- map.Open(resourceSrvc, mapName);
+ MgMap map = new MgMap(site);
+ map.Open(mapName);
//locate the buffer layer in the map. It might or might not already exist
@@ -351,7 +351,7 @@
// Save the new map state
layer.ForceRefresh();
- map.Save(resourceSrvc);
+ map.Save();
//build report message
String title = MgLocalizer.GetString("BUFFERREPORTTITLE", locale);
Modified: trunk/MgDev/Web/src/mapviewerjava/legend.jsp
--- trunk/MgDev/Web/src/mapviewerjava/legend.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerjava/legend.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -100,8 +100,8 @@
//Load the map runtime state.
int updateType = -1;
Modified: trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp
--- trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerjava/mapframe.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -98,10 +98,10 @@
MgResourceService resourceSrvc = (MgResourceService)site.CreateService(MgServiceType.ResourceService);
MgResourceIdentifier resId = new MgResourceIdentifier(mapDefinition);
String mapName = resId.GetName();
- map.Create(resourceSrvc, resId, mapName);
+ map.Create(resId, mapName);
//create an empty selection object and store it in the session repository
MgSelection sel = new MgSelection(map);
Modified: trunk/MgDev/Web/src/mapviewerjava/measure.jsp
--- trunk/MgDev/Web/src/mapviewerjava/measure.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerjava/measure.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -96,8 +96,8 @@
//load the map runtime state and locate the measure layer
MgLayerCollection layers = map.GetLayers();
srs = GetMapSrs(map);
@@ -242,7 +242,7 @@
if(layer != null)
+ map.Save();
catch(MgException exc)
Modified: trunk/MgDev/Web/src/mapviewerjava/quickplotgeneratepicture.jsp
--- trunk/MgDev/Web/src/mapviewerjava/quickplotgeneratepicture.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerjava/quickplotgeneratepicture.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -110,11 +110,10 @@
MgUserInformation userInfo = new MgUserInformation(sessionId);
MgSiteConnection siteConnection = new MgSiteConnection();
siteConnection.Open(userInfo);
- MgResourceService resourceService = (MgResourceService) siteConnection.CreateService(MgServiceType.ResourceService);
MgRenderingService renderingService = (MgRenderingService) siteConnection.CreateService(MgServiceType.RenderingService);
- map.Open(resourceService, mapName);
+ MgMap map = new MgMap(siteConnection);
MgSelection selection = new MgSelection(map);
Modified: trunk/MgDev/Web/src/mapviewerjava/search.jsp
--- trunk/MgDev/Web/src/mapviewerjava/search.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerjava/search.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -87,13 +87,11 @@
//connect to the site and get a feature service and a resource service instances
MgSiteConnection site = new MgSiteConnection();
site.Open(cred);
- MgFeatureService featureSrvc = (MgFeatureService)site.CreateService(MgServiceType.FeatureService);
- MgResourceService resourceSrvc = (MgResourceService)site.CreateService(MgServiceType.ResourceService);
//Create a temporary map runtime object, locate the layer
int i, j;
MgLayer layer = null;
@@ -119,8 +117,7 @@
MgFeatureQueryOptions opts = new MgFeatureQueryOptions();
opts.SetFilter(filter);
String featureClassName = layer.GetFeatureClassName();
- MgResourceIdentifier srcId = new MgResourceIdentifier(layer.GetFeatureSourceId());
- features = featureSrvc.SelectFeatures(srcId, featureClassName, opts);
+ features = layer.SelectFeatures( opts);
boolean hasResult = features.ReadNext();
if(hasResult)
Modified: trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp
--- trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerjava/selectwithin.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -52,12 +52,11 @@
site.Open(cred);
MgRenderingService renderingSrvc = (MgRenderingService)site.CreateService(MgServiceType.RenderingService);
String[] layersList = layers.split(",");
if(layersList.length > 0)
Modified: trunk/MgDev/Web/src/mapviewerjava/setselection.jsp
--- trunk/MgDev/Web/src/mapviewerjava/setselection.jsp 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerjava/setselection.jsp 2014-06-17 10:16:51 UTC (rev 8236)
@@ -59,8 +59,8 @@
// Create the selection set and save it
Modified: trunk/MgDev/Web/src/mapviewernet/buffer.aspx
--- trunk/MgDev/Web/src/mapviewernet/buffer.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewernet/buffer.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -79,8 +79,8 @@
@@ -333,7 +333,7 @@
+ map.Save();
Modified: trunk/MgDev/Web/src/mapviewernet/legend.aspx
--- trunk/MgDev/Web/src/mapviewernet/legend.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewernet/legend.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -93,8 +93,8 @@
Modified: trunk/MgDev/Web/src/mapviewernet/mapframe.aspx
--- trunk/MgDev/Web/src/mapviewernet/mapframe.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewernet/mapframe.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -103,10 +103,10 @@
Modified: trunk/MgDev/Web/src/mapviewernet/measure.aspx
--- trunk/MgDev/Web/src/mapviewernet/measure.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewernet/measure.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -74,8 +74,8 @@
@@ -221,7 +221,7 @@
if (layer != null)
+ map.Save();
catch (MgException exc)
Modified: trunk/MgDev/Web/src/mapviewernet/quickplotgeneratepicture.aspx
--- trunk/MgDev/Web/src/mapviewernet/quickplotgeneratepicture.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewernet/quickplotgeneratepicture.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -109,11 +109,10 @@
MgUserInformation userInfo = new MgUserInformation(sessionID);
- MgResourceService resourceService = siteConnection.CreateService(MgServiceType.ResourceService) as MgResourceService;
MgRenderingService renderingService = siteConnection.CreateService(MgServiceType.RenderingService) as MgRenderingService;
Modified: trunk/MgDev/Web/src/mapviewernet/search.aspx
--- trunk/MgDev/Web/src/mapviewernet/search.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewernet/search.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -75,12 +75,10 @@
site.Open(cred);
- MgFeatureService featureSrvc = site.CreateService(MgServiceType.FeatureService) as MgFeatureService;
- MgResourceService resourceSrvc = site.CreateService(MgServiceType.ResourceService) as MgResourceService;
int i = 0;
@@ -108,8 +106,7 @@
+ features = layer.SelectFeatures(opts);
bool hasResult = features.ReadNext();
if (hasResult)
Modified: trunk/MgDev/Web/src/mapviewernet/selectwithin.aspx
--- trunk/MgDev/Web/src/mapviewernet/selectwithin.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewernet/selectwithin.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -50,12 +50,11 @@
site.Open(cred);
MgRenderingService renderingSrvc = site.CreateService(MgServiceType.RenderingService) as MgRenderingService;
String [] layersList = layers.Split(',');
if(layersList.Length > 0)
Modified: trunk/MgDev/Web/src/mapviewernet/setselection.aspx
--- trunk/MgDev/Web/src/mapviewernet/setselection.aspx 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewernet/setselection.aspx 2014-06-17 10:16:51 UTC (rev 8236)
@@ -52,8 +52,8 @@
Modified: trunk/MgDev/Web/src/mapviewerphp/buffer.php
--- trunk/MgDev/Web/src/mapviewerphp/buffer.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerphp/buffer.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -69,8 +69,8 @@
- $map->Open($resourceSrvc, $mapName);
+ $map->Open($mapName);
@@ -317,7 +317,7 @@
$layer->ForceRefresh();
- $map->Save($resourceSrvc);
+ $map->Save();
$title = GetLocalizedString( "BUFFERREPORTTITLE", $locale );
Modified: trunk/MgDev/Web/src/mapviewerphp/legend.php
--- trunk/MgDev/Web/src/mapviewerphp/legend.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerphp/legend.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -79,8 +79,8 @@
$layerMap = null;
$tree = BuildLayerTree($map, $resourceSrvc);
Modified: trunk/MgDev/Web/src/mapviewerphp/mapframe.php
--- trunk/MgDev/Web/src/mapviewerphp/mapframe.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerphp/mapframe.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -82,10 +82,10 @@
$resourceSrvc = $site->CreateService(MgServiceType::ResourceService);
$resId = new MgResourceIdentifier($mapDefinition);
$mapName = $resId->GetName();
- $map->Create($resourceSrvc, $resId, $mapName);
+ $map->Create($resId, $mapName);
Modified: trunk/MgDev/Web/src/mapviewerphp/measure.php
--- trunk/MgDev/Web/src/mapviewerphp/measure.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerphp/measure.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -65,8 +65,8 @@
$layers = $map->GetLayers();
$srs = GetMapSrs($map);
@@ -209,7 +209,7 @@
if($layer != null)
+ $map->Save();
catch(MgException $e)
Modified: trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php
--- trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -84,11 +84,10 @@
$userInfo = new MgUserInformation($sessionID);
$siteConnection = new MgSiteConnection();
$siteConnection->Open($userInfo);
- $resourceService = $siteConnection->CreateService(MgServiceType::ResourceService);
$renderingService = $siteConnection->CreateService(MgServiceType::RenderingService);
- $map->Open($resourceService, $mapName);
+ $map = new MgMap($siteConnection);
Property changes on: trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php:6738-6741,6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/adsk/2.4jbeta2/Web/src/mapviewerphp/quickplotgeneratepicture.php:6334-6374
/sandbox/jng/createruntimemap/Web/src/mapviewerphp/quickplotgeneratepicture.php:7486-7555
/sandbox/jng/webtier_upgrade_v2/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php:7817-7861
/sandbox/rfc94/Web/src/mapviewerphp/quickplotgeneratepicture.php:5099-5163
+ /branches/2.4/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php:6738-6741,6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/v30/Web/src/mapviewerphp/quickplotgeneratepicture.php:8220-8221
Modified: trunk/MgDev/Web/src/mapviewerphp/search.php
--- trunk/MgDev/Web/src/mapviewerphp/search.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerphp/search.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -60,11 +60,10 @@
$site = new MgSiteConnection();
$site->Open($cred);
$featureSrvc = $site->CreateService(MgServiceType::FeatureService);
- $resourceSrvc = $site->CreateService(MgServiceType::ResourceService);
$layer = null;
for($i = 0; $i < $layers->GetCount(); $i++)
@@ -107,8 +106,7 @@
$opts = new MgFeatureQueryOptions();
$opts->SetFilter($filter);
$featureClassName = $layer->GetFeatureClassName();
- $srcId = new MgResourceIdentifier($layer->GetFeatureSourceId());
- $features = $featureSrvc->SelectFeatures($srcId, $featureClassName, $opts);
+ $features = $layer->SelectFeatures($opts);
$hasResult = $features->ReadNext();
if($hasResult)
Modified: trunk/MgDev/Web/src/mapviewerphp/selectwithin.php
--- trunk/MgDev/Web/src/mapviewerphp/selectwithin.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerphp/selectwithin.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -42,12 +42,11 @@
$site->Open($cred);
$renderingSrvc = $site->CreateService(MgServiceType::RenderingService);
$layers = explode(",", $layers);
if(count($layers) > 0)
Modified: trunk/MgDev/Web/src/mapviewerphp/setselection.php
--- trunk/MgDev/Web/src/mapviewerphp/setselection.php 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/Web/src/mapviewerphp/setselection.php 2014-06-17 10:16:51 UTC (rev 8236)
@@ -43,8 +43,8 @@
Modified: trunk/MgDev/run_tests.bat
--- trunk/MgDev/run_tests.bat 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/run_tests.bat 2014-06-17 10:16:51 UTC (rev 8236)
@@ -77,7 +77,7 @@
:start_php_webserver
if "%START_WEBSERVER%" == "1" (
echo [test]: Starting PHP web server. Waiting %MGSERVER_WAIT%s
- start php -n -d display_errors=Off -d upload_max_filesize=20M -d extension_dir="%PHP_EXT_DIR%" -d extension=php_mbstring.dll -d extension=php_curl.dll -d extension=php_MapGuideApi.dll -d extension=php_SQLitePhpApi.dll -S %SERVER_ADDR%:%SERVER_PORT% -t %CD%\UnitTest\WebTier\MapAgent\MapAgentForms %CD%\UnitTest\WebTier\Php\MapAgentShim\index.php
+ start php -n -d display_errors=Off -d upload_max_filesize=20M -d extension_dir="%PHP_EXT_DIR%" -d extension=php_mbstring.dll -d extension=php_curl.dll -d extension=php_MapGuideApi.dll -S %SERVER_ADDR%:%SERVER_PORT% -t %CD%\UnitTest\WebTier\MapAgent\MapAgentForms %CD%\UnitTest\WebTier\Php\MapAgentShim\index.php
ping -n %MGSERVER_WAIT% 127.0.0.1 > NUL
:test_php
@@ -98,7 +98,7 @@
if exist ResourceService\ResourceServiceTest.db del /F ResourceService\ResourceServiceTest.db
popd
pushd UnitTest\WebTier\Php
- php.exe -n -d display_errors=Off -d extension_dir="%PHP_EXT_DIR%" -d extension=php_mbstring.dll -d extension=php_curl.dll -d extension=php_MapGuideApi.dll -d extension=php_SQLitePhpApi.dll RunTests.php
+ php.exe -n -d display_errors=Off -d extension_dir="%PHP_EXT_DIR%" -d extension=php_mbstring.dll -d extension=php_curl.dll -d extension=php_MapGuideApi.dll -d extension=php_pdo_sqlite.dll RunTests.php
popd
:test_dotnet
Modified: trunk/MgDev/updateversion.vbs
--- trunk/MgDev/updateversion.vbs 2014-06-17 05:53:52 UTC (rev 8235)
+++ trunk/MgDev/updateversion.vbs 2014-06-17 10:16:51 UTC (rev 8236)
@@ -247,6 +247,7 @@
"/Common/PlatformBase/PlatformBase.rc", _
"/Common/Renderers/Renderers.rc", _
"/Common/Stylization/Stylization.rc", _
+ "/Desktop/DesktopUnmanagedApi/JavaApiEx/JavaApiEx.rc", _
"/Server/src/Common/Base/ServerBase.rc", _
"/Server/src/Common/Cache/ServerCache.rc", _
"/Server/src/Common/Manager/ServerManager.rc", _
@@ -259,6 +260,7 @@
"/Server/src/Services/Feature/ServerFeatureService.rc", _
"/Server/src/Services/Kml/ServerKmlService.rc", _
"/Server/src/Services/Mapping/ServerMappingService.rc", _
+ "/Server/src/Services/Profiling/ServerProfilingService.rc", _
"/Server/src/Services/Rendering/ServerRenderingService.rc", _
"/Server/src/Services/Resource/ServerResourceService.rc", _
"/Server/src/Services/ServerAdmin/ServerAdminService.rc", _
@@ -276,6 +278,7 @@
"/Web/src/HttpHandler/HttpHandler.rc", _
"/Web/src/IsapiAgent/IsapiAgent.rc", _
"/Web/src/JavaApi/JavaApi.rc", _
+ "/Web/src/JavaApiEx/JavaApiEx.rc", _
"/Web/src/PhpApi/PhpApi.rc", _
"/Web/src/WebApp/WebApp.rc" _
More information about the mapguide-commits
