[mapguide-commits] r8241 - trunk/MgDev
svn_mapguide at osgeo.org
Wed Jun 18 01:37:30 PDT 2014
Author: hubu
Date: 2014-06-18 01:37:30 -0700 (Wed, 18 Jun 2014)
New Revision: 8241
trunk/MgDev/build_oem.sh
Fix Linux build.
The make file Oem/CsMap/Source/Library.mak and Oem/CsMap/Dictionaries/Compiler.mak are changed in http://trac.osgeo.org/csmap/changeset/2463. We need to change the build script in build_oem.sh accordingly.
Modified: trunk/MgDev/build_oem.sh
--- trunk/MgDev/build_oem.sh 2014-06-18 07:37:20 UTC (rev 8240)
+++ trunk/MgDev/build_oem.sh 2014-06-18 08:37:30 UTC (rev 8241)
@@ -624,9 +624,9 @@
sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Library64.mak
make -fLibrary64.mak
else
- make -fLibrary.mak
+ make -fLibrary.mak PROCESSOR=x86
fi
- cp CsMap.a ../.libs/libCsmap.a
+ cp ../lib47/Linux$BUILD_CPU/CsMap.a ../.libs/libCsmap.a
popd
pushd Dictionaries
if [ $BUILD_CPU -eq 64 ]; then
@@ -634,9 +634,9 @@
sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Compiler64.mak
make -fCompiler64.mak
else
- make -fCompiler.mak
+ make -fCompiler.mak PROCESSOR=x86
fi
- ./CS_Comp -b . .
popd
check_build
popd
More information about the mapguide-commits
