[mapguide-commits] r8247 - in sandbox/jng/v30: . Common/CoordinateSystem
svn_mapguide at osgeo.org
Thu Jun 19 00:11:10 PDT 2014
Author: jng
Date: 2014-06-19 00:11:10 -0700 (Thu, 19 Jun 2014)
New Revision: 8247
sandbox/jng/v30/
sandbox/jng/v30/Common/CoordinateSystem/CoordSysUtil.h
sandbox/jng/v30/build_oem.sh
Merged revision(s) 8240-8241 from trunk/MgDev:
Fix Linux build.
Change the include file name to "cs_WktObject.hpp" because Linux is case sensitive.
Fix Linux build.
The make file Oem/CsMap/Source/Library.mak and Oem/CsMap/Dictionaries/Compiler.mak are changed in http://trac.osgeo.org/csmap/changeset/2463. We need to change the build script in build_oem.sh accordingly.
Property changes on: sandbox/jng/v30
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/createruntimemap:7486-7555
/sandbox/rfc94:5099-5163
/trunk/MgDev:8229
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8229,8240-8241
Modified: sandbox/jng/v30/Common/CoordinateSystem/CoordSysUtil.h
--- sandbox/jng/v30/Common/CoordinateSystem/CoordSysUtil.h 2014-06-18 19:18:53 UTC (rev 8246)
+++ sandbox/jng/v30/Common/CoordinateSystem/CoordSysUtil.h 2014-06-19 07:11:10 UTC (rev 8247)
@@ -22,7 +22,7 @@
#ifdef min
#undef min
#endif
-#include "CS_wktObject.hpp"
+#include "cs_WktObject.hpp"
#include "cs_wkt.h"
#include "CsmapVersion.h"
Modified: sandbox/jng/v30/build_oem.sh
--- sandbox/jng/v30/build_oem.sh 2014-06-18 19:18:53 UTC (rev 8246)
+++ sandbox/jng/v30/build_oem.sh 2014-06-19 07:11:10 UTC (rev 8247)
@@ -584,9 +584,9 @@
sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Library64.mak
make -fLibrary64.mak
else
- make -fLibrary.mak
+ make -fLibrary.mak PROCESSOR=x86
fi
- cp CsMap.a ../.libs/libCsmap.a
+ cp ../lib47/Linux$BUILD_CPU/CsMap.a ../.libs/libCsmap.a
popd
pushd Dictionaries
if [ $BUILD_CPU -eq 64 ]; then
@@ -594,9 +594,9 @@
sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Compiler64.mak
make -fCompiler64.mak
else
- make -fCompiler.mak
+ make -fCompiler.mak PROCESSOR=x86
fi
- ./CS_Comp -b . .
popd
check_build
popd
More information about the mapguide-commits
