[mapguide-commits] r8262 - sandbox/jng/convenience_apis/Common/PlatformBase/Services
svn_mapguide at osgeo.org
Mon Jun 23 07:31:00 PDT 2014
Author: jng
Date: 2014-06-23 07:31:00 -0700 (Mon, 23 Jun 2014)
New Revision: 8262
sandbox/jng/convenience_apis/Common/PlatformBase/Services/ResourceService.h
Promote MgResourceService::GetResourceModifiedDate() to EXTERNAL_API. There's value in this method being available for web infrastructure as knowing modification dates is critical in being able to apply HTTP caching.
Modified: sandbox/jng/convenience_apis/Common/PlatformBase/Services/ResourceService.h
--- sandbox/jng/convenience_apis/Common/PlatformBase/Services/ResourceService.h 2014-06-23 14:26:11 UTC (rev 8261)
+++ sandbox/jng/convenience_apis/Common/PlatformBase/Services/ResourceService.h 2014-06-23 14:31:00 UTC (rev 8262)
@@ -1848,34 +1848,6 @@
/// \brief
- /// Returns the modified date of the specified resource.
- /// This method only works on "Library" repository.
- /// <!-- Syntax in .Net, Java, and PHP -->
- /// \htmlinclude DotNetSyntaxTop.html
- /// virtual MgDateTime GetResourceModifiedDate(MgResourceIdentifier resource);
- /// \htmlinclude SyntaxBottom.html
- /// \htmlinclude JavaSyntaxTop.html
- /// \htmlinclude PHPSyntaxTop.html
- /// \param resource (MgResourceIdentifier)
- /// Resource to get the modified date for.
- /// \return
- /// An MgDateTime object containing the modified date of the resource.
- /// \exception MgInvalidRepositoryTypeException
- /// \exception MgInvalidResourceTypeException
- virtual MgDateTime* GetResourceModifiedDate(MgResourceIdentifier* resource) = 0;
- /// \brief
/// Enumerate all the parent Map Definition resources of the specified
/// resources.
@@ -1909,6 +1881,34 @@
EXTERNAL_API:
+ /// \brief
+ /// Returns the modified date of the specified resource.
+ /// This method only works on "Library" repository.
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// virtual MgDateTime GetResourceModifiedDate(MgResourceIdentifier resource);
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \param resource (MgResourceIdentifier)
+ /// Resource to get the modified date for.
+ /// \return
+ /// An MgDateTime object containing the modified date of the resource.
+ /// \exception MgInvalidRepositoryTypeException
+ /// \exception MgInvalidResourceTypeException
+ virtual MgDateTime* GetResourceModifiedDate(MgResourceIdentifier* resource) = 0;
/// \brief
/// Sets the Metadata content for an existing resource.
More information about the mapguide-commits
