[mapguide-commits] r8264 - in sandbox/jng/convenience_apis: Common/MapGuideCommon/MapLayer Common/MapGuideCommon/Services Common/PlatformBase/MapLayer Common/PlatformBase/Services Server/src/Services/Feature Server/src/UnitTesting UnitTest/WebTier/DotNet/MgTestRunner UnitTest/WebTier/DotNet/TestCommon UnitTest/WebTier/DotNet/TestCommon/ExternalTests UnitTest/WebTier/DotNet/TestCommon/Properties UnitTest/WebTier/DotNet/TestCommon/Resources UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests
svn_mapguide at osgeo.org
Thu Jun 26 04:37:30 PDT 2014
Author: jng
Date: 2014-06-26 04:37:30 -0700 (Thu, 26 Jun 2014)
New Revision: 8264
Added:
sandbox/jng/convenience_apis/Server/src/Services/Feature/OpDeleteFeatures.cpp
sandbox/jng/convenience_apis/Server/src/Services/Feature/OpDeleteFeatures.h
sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeatures.cpp
sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeatures.h
sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeaturesBatched.cpp
sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeaturesBatched.h
sandbox/jng/convenience_apis/Server/src/Services/Feature/OpUpdateMatchingFeatures.cpp
sandbox/jng/convenience_apis/Server/src/Services/Feature/OpUpdateMatchingFeatures.h
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/ConvenienceTests.cs
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Properties/Resources.Designer.cs
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Properties/Resources.resx
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Resources/
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Resources/TestLayer.txt
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Resources/TestMapDef.txt
sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.cpp
sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.h
sandbox/jng/convenience_apis/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
sandbox/jng/convenience_apis/Common/MapGuideCommon/Services/ProxyFeatureService.h
sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.cpp
sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.h
sandbox/jng/convenience_apis/Common/PlatformBase/Services/FeatureDefs.h
sandbox/jng/convenience_apis/Common/PlatformBase/Services/FeatureService.h
sandbox/jng/convenience_apis/Server/src/Services/Feature/FeatureOperationFactory.cpp
sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.cpp
sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.h
sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.vcxproj
sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.vcxproj.filters
sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureServiceBuild.cpp
sandbox/jng/convenience_apis/Server/src/UnitTesting/TestFeatureService.cpp
sandbox/jng/convenience_apis/Server/src/UnitTesting/TestFeatureService.h
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/CollectionTests.cs
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/PropertiesTest.cs
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/TestCommon.csproj
sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/CollectionTests.cs
Add new convenience APIs to MgFeatureService and MgLayerBase:
* InsertFeatures - Inserts one or more features to the specified feature source
* UpdateMatchingFeatures - Updates one or more features in the specified feature source
* DeleteFeatures - Deletes one or more features in the specified feature source
These APIs are much simpler to use than UpdateFeatures and require less boilerplate and have simpler exception handling logic (all of the above APIs *will* throw exceptions on any error, transactional or not).
Use the external test mechanism introduced in the previous submission to add new .net tests to exercise these new convenience APIs
Modified: sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.cpp
--- sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.cpp 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.cpp 2014-06-26 11:37:30 UTC (rev 8264)
@@ -307,6 +307,23 @@
MG_TRY()
+ Ptr<MgResourceIdentifier> resourceId = new MgResourceIdentifier(m_featureSourceId);
+ STRING providerName = GetProviderName();
+ // Determine if the provider supports transactions.
+ Ptr<MgFeatureService> featureService = dynamic_cast<MgFeatureService*>(
+ GetMap()->GetService(MgServiceType::FeatureService));
+ bool useTransaction = UseTransaction(featureService, providerName);
+ propCol = featureService->UpdateFeatures(resourceId, commands, useTransaction);
+ MG_CATCH_AND_THROW(L"MgLayer.UpdateFeatures")
+ return propCol.Detach();
+STRING MgLayer::GetProviderName()
// Get the content of the feature source.
Ptr<MgResourceService> resourceService = dynamic_cast<MgResourceService*>(
GetMap()->GetService(MgServiceType::ResourceService));
@@ -332,15 +349,14 @@
featureSource.reset(parser.DetachFeatureSource());
// Get the provider name.
- STRING providerName = (STRING)featureSource->GetProvider();
+ return (STRING)featureSource->GetProvider();
- // Determine if the provider supports transactions.
+bool MgLayer::UseTransaction(MgFeatureService* featureService, CREFSTRING providerName)
bool useTransaction = false;
- Ptr<MgFeatureService> featureService = dynamic_cast<MgFeatureService*>(
- GetMap()->GetService(MgServiceType::FeatureService));
- byteReader = featureService->GetCapabilities(providerName);
- xmlContent.clear();
+ Ptr<MgByteReader> byteReader = featureService->GetCapabilities(providerName);
+ std::string xmlContent;
byteReader->ToStringUtf8(xmlContent);
const string openTag = "<SupportsTransactions>"; //NOXLATE
@@ -363,12 +379,7 @@
useTransaction = MgUtil::StringToBoolean(tagValue);
- propCol = featureService->UpdateFeatures(resourceId, commands, useTransaction);
- MG_CATCH_AND_THROW(L"MgLayer.UpdateFeatures")
- return propCol.Detach();
+ return useTransaction;
void MgLayer::ParseFeatureName(MgFeatureService* featureService, REFSTRING className, REFSTRING schemaName)
@@ -423,3 +434,111 @@
m_idProps.push_back(idProp);
+MgFeatureReader* MgLayer::InsertFeatures(MgPropertyCollection* properties)
+ Ptr<MgFeatureReader> ret;
+ Ptr<MgTransaction> trans;
+ MG_TRY()
+ if (UseTransaction(featureService, GetProviderName()))
+ trans = featureService->BeginTransaction(resourceId);
+ ret = featureService->InsertFeatures(resourceId, m_featureName, properties);
+ if (NULL != trans.p)
+ trans->Commit();
+ MG_CATCH(L"MgLayer.InsertFeatures")
+ trans->Rollback();
+ MG_THROW()
+ return ret.Detach();
+MgFeatureReader* MgLayer::InsertFeatures(MgBatchPropertyCollection* properties)
+ MG_TRY()
+ trans->Commit();
+ MG_THROW()
+INT32 MgLayer::UpdateMatchingFeatures(MgPropertyCollection* properties, CREFSTRING filter)
+ INT32 updated = -1;
+ MG_TRY()
+ updated = featureService->UpdateMatchingFeatures(resourceId, m_featureName, properties, filter);
+ trans->Commit();
+ MG_CATCH(L"MgLayer.UpdateMatchingFeatures")
+ MG_THROW()
+ return updated;
+INT32 MgLayer::DeleteFeatures(CREFSTRING filter)
+ INT32 deleted = -1;
+ MG_TRY()
+ deleted = featureService->DeleteFeatures(resourceId, m_featureName, filter);
+ trans->Commit();
+ MG_CATCH(L"MgLayer.DeleteFeatures")
+ MG_THROW()
+ return deleted;
Modified: sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.h
--- sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.h 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.h 2014-06-26 11:37:30 UTC (rev 8264)
@@ -224,6 +224,143 @@
virtual MgPropertyCollection* UpdateFeatures(MgFeatureCommandCollection* commands);
+ /// \brief
+ /// Inserts a new feature into the specified feature class of the specified Feature Source
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// virtual MgFeatureReader InsertFeatures(MgPropertyCollection properties);
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \param properties (MgPropertyCollection)
+ /// The collection of property values to insert
+ /// \return
+ /// Returns a feature reader object that contains the set of properties
+ /// inserted into the datastore by the insert command.
+ /// \remarks
+ /// Transactions will be used internally if the provider supports them.
+ /// Remember to close any feature readers returned by this method, even if you don't intend
+ /// to do anything with them
+ /// \exception MgFeatureServiceException
+ /// \exception MgInvalidArgumentException
+ /// \exception MgInvalidOperationException
+ /// \exception MgFdoException
+ /// \since 3.0
+ virtual MgFeatureReader* InsertFeatures(MgPropertyCollection* properties);
+ /// \brief
+ /// Inserts a set of new features into the specified feature class of the specified Feature Source
+ /// virtual MgFeatureReader InsertFeatures(MgBatchPropertyCollection properties);
+ /// \param properties (MgBatchPropertyCollection)
+ /// The collection of property values to insert. Each MgPropertyCollection within
+ /// this collection represents property values for a single feature to insert
+ /// \return
+ /// \remarks
+ /// \since 3.0
+ virtual MgFeatureReader* InsertFeatures(MgBatchPropertyCollection* properties);
+ /// \brief
+ /// Updates all features that match the given filter with the specified property values
+ /// \remarks
+ /// virtual int UpdateMatchingFeatures(MgPropertyCollection properties, string filter);
+ /// virtual int UpdateMatchingFeatures(MgPropertyCollection properties, String filter);
+ /// The property values to update matching features with
+ /// \param filter (String/string)
+ /// The FDO filter string that detemines what features will be updated
+ /// \return
+ /// Returns the number of features updated by this operation
+ /// \since 3.0
+ virtual INT32 UpdateMatchingFeatures(MgPropertyCollection* properties, CREFSTRING filter);
+ /// \brief
+ /// Deletes all features that match the given filter
+ /// \remarks
+ /// virtual int DeleteFeatures(string filter);
+ /// virtual int DeleteFeatures(String filter);
+ /// The FDO filter string that detemines what features will be deleted
+ /// \return
+ /// Returns the number of features deleted by this operation
+ /// \since 3.0
+ virtual INT32 DeleteFeatures(CREFSTRING filter);
INTERNAL_API:
@@ -308,6 +445,8 @@
private:
+ STRING GetProviderName();
+ bool UseTransaction(MgFeatureService* svcFeature, CREFSTRING providerName);
MgMapBase* GetMap();
Modified: sandbox/jng/convenience_apis/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
--- sandbox/jng/convenience_apis/Common/MapGuideCommon/Services/ProxyFeatureService.cpp 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Common/MapGuideCommon/Services/ProxyFeatureService.cpp 2014-06-26 11:37:30 UTC (rev 8264)
@@ -1897,3 +1897,228 @@
SetWarning(cmd.GetWarningObject());
return cmd.GetReturnValue().val.m_i8;
+MgFeatureReader* MgProxyFeatureService::InsertFeatures(MgResourceIdentifier* resource,
+ CREFSTRING className,
+ MgPropertyCollection* propertyValues)
+ MgCommand cmd;
+ cmd.ExecuteCommand(m_connProp, // Connection
+ MgCommand::knObject, // Return type expected
+ MgFeatureServiceOpId::InsertFeatures, // Command Code
+ 3, // No of arguments
+ Feature_Service, // Service Id
+ BUILD_VERSION(3,0,0), // Operation version
+ MgCommand::knObject, resource, // Argument#1
+ MgCommand::knString, &className, // Argument#2
+ MgCommand::knObject, propertyValues, // Argument#3
+ MgCommand::knNone); // End of argument
+ SetWarning(cmd.GetWarningObject());
+ Ptr<MgProxyFeatureReader> featReader = (MgProxyFeatureReader*)cmd.GetReturnValue().val.m_obj;
+ if (featReader != NULL)
+ featReader->SetService(this); // Feature reader on proxy side would store proxy service to call GetFeatures()
+ return SAFE_ADDREF((MgProxyFeatureReader*)featReader);
+ MgPropertyCollection* propertyValues,
+ MgTransaction* transaction)
+ STRING transactionId = L"";
+ MgProxyFeatureTransaction* proxyTransaction = dynamic_cast<MgProxyFeatureTransaction*>(transaction);
+ if (NULL != proxyTransaction)
+ transactionId = proxyTransaction->GetTransactionId();
+ MgCommand cmd;
+ 4, // No of arguments
+ MgCommand::knString, &transactionId, // Argument#4
+ MgBatchPropertyCollection* batchPropertyValues)
+ MgCommand cmd;
+ MgFeatureServiceOpId::InsertFeatures2, // Command Code
+ MgCommand::knObject, batchPropertyValues, // Argument#3
+ MgBatchPropertyCollection* batchPropertyValues,
+ MgCommand cmd;
+INT32 MgProxyFeatureService::UpdateMatchingFeatures(MgResourceIdentifier* resource,
+ CREFSTRING filter)
+ MgCommand cmd;
+ MgCommand::knInt32, // Return type expected
+ MgFeatureServiceOpId::UpdateMatchingFeatures,// Command Code
+ MgCommand::knString, &filter, // Argument#4
+ return cmd.GetReturnValue().val.m_i32;
+ CREFSTRING filter,
+ MgCommand cmd;
+ 5, // No of arguments
+ MgCommand::knString, &transactionId, // Argument#5
+INT32 MgProxyFeatureService::DeleteFeatures(MgResourceIdentifier* resource,
+ MgCommand cmd;
+ MgFeatureServiceOpId::DeleteFeatures, // Command Code
+ MgCommand::knString, &filter, // Argument#3
+ MgCommand cmd;
\ No newline at end of file
Modified: sandbox/jng/convenience_apis/Common/MapGuideCommon/Services/ProxyFeatureService.h
--- sandbox/jng/convenience_apis/Common/MapGuideCommon/Services/ProxyFeatureService.h 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Common/MapGuideCommon/Services/ProxyFeatureService.h 2014-06-26 11:37:30 UTC (rev 8264)
@@ -659,6 +659,342 @@
MgFeatureCommandCollection* commands,
MgTransaction* transaction);
+ /// \brief
+ /// virtual MgFeatureReader InsertFeatures(MgResourceIdentifier resource, string className, MgPropertyCollection propertyValues);
+ /// virtual MgFeatureReader InsertFeatures(MgResourceIdentifier resource, String className, MgPropertyCollection propertyValues);
+ /// \param resource (MgResourceIdentifier)
+ /// A resource identifier for the feature
+ /// source.
+ /// \param className (String/string)
+ /// The name of the feature class on which
+ /// the insert operation is performed.
+ /// \param propertyValues (MgPropertyCollection)
+ /// \return
+ /// \remarks
+ /// \since 3.0
+ virtual MgFeatureReader* InsertFeatures(MgResourceIdentifier* resource,
+ MgPropertyCollection* propertyValues);
+ /// \brief
+ /// virtual MgFeatureReader InsertFeatures(MgResourceIdentifier resource, string className, MgPropertyCollection propertyValues, MgTransaction trans);
+ /// virtual MgFeatureReader InsertFeatures(MgResourceIdentifier resource, String className, MgPropertyCollection propertyValues, MgTransaction trans);
+ /// source.
+ /// \param trans (MgTransaction)
+ /// The transaction to execute this operation under
+ /// \return
+ /// \remarks
+ /// \since 3.0
+ MgTransaction* trans);
+ /// \brief
+ /// virtual MgFeatureReader InsertFeatures(MgResourceIdentifier resource, string className, MgBatchPropertyCollection batchPropertyValues);
+ /// virtual MgFeatureReader InsertFeatures(MgResourceIdentifier resource, String className, MgBatchPropertyCollection batchPropertyValues);
+ /// source.
+ /// \param batchPropertyValues (MgBatchPropertyCollection)
+ /// \return
+ /// \remarks
+ /// \since 3.0
+ MgBatchPropertyCollection* batchPropertyValues);
+ /// \brief
+ /// virtual MgFeatureReader InsertFeatures(MgResourceIdentifier resource, string className, MgBatchPropertyCollection batchPropertyValues, MgTransaction trans);
+ /// virtual MgFeatureReader InsertFeatures(MgResourceIdentifier resource, String className, MgBatchPropertyCollection batchPropertyValues, MgTransaction trans);
+ /// source.
+ /// \return
+ /// \remarks
+ /// \since 3.0
+ /// \brief
+ /// virtual int UpdateMatchingFeatures(MgResourceIdentifier resource, string className, MgPropertyCollection properties, string filter);
+ /// virtual int UpdateMatchingFeatures(MgResourceIdentifier resource, String className, MgPropertyCollection properties, String filter);
+ /// source.
+ /// the update operation is performed.
+ /// \return
+ /// \since 3.0
+ virtual INT32 UpdateMatchingFeatures(MgResourceIdentifier* resource,
+ MgPropertyCollection* properties,
+ CREFSTRING filter);
+ /// \brief
+ /// virtual int UpdateMatchingFeatures(MgResourceIdentifier resource, string className, MgPropertyCollection properties, string filter, MgTransaction trans);
+ /// virtual int UpdateMatchingFeatures(MgResourceIdentifier resource, String className, MgPropertyCollection properties, String filter, MgTransaction trans);
+ /// source.
+ /// \return
+ /// \since 3.0
+ /// \brief
+ /// virtual int DeleteFeatures(MgResourceIdentifier resource, string className, string filter);
+ /// virtual int DeleteFeatures(MgResourceIdentifier resource, String className, String filter);
+ /// source.
+ /// the delete operation is performed.
+ /// \return
+ /// \since 3.0
+ virtual INT32 DeleteFeatures(MgResourceIdentifier* resource,
+ /// \brief
+ /// virtual int DeleteFeatures(MgResourceIdentifier resource, string className, string filter, MgTransaction trans);
+ /// virtual int DeleteFeatures(MgResourceIdentifier resource, String className, String filter, MgTransaction trans);
+ /// source.
+ /// \return
+ /// \since 3.0
/// \brief
/// Gets the locked features
Modified: sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.cpp
--- sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.cpp 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.cpp 2014-06-26 11:37:30 UTC (rev 8264)
@@ -799,3 +799,27 @@
throw new MgNotImplementedException(L"MgLayerBase.UpdateFeatures",
__LINE__, __WFILE__, NULL, L"", NULL);
+MgFeatureReader* MgLayerBase::InsertFeatures(MgPropertyCollection* properties)
+ throw new MgNotImplementedException(L"MgLayerBase.InsertFeatures",
+ __LINE__, __WFILE__, NULL, L"", NULL);
+MgFeatureReader* MgLayerBase::InsertFeatures(MgBatchPropertyCollection* properties)
+INT32 MgLayerBase::UpdateMatchingFeatures(MgPropertyCollection* properties, CREFSTRING filter)
+ throw new MgNotImplementedException(L"MgLayerBase.UpdateMatchingFeatures",
+INT32 MgLayerBase::DeleteFeatures(CREFSTRING filter)
+ throw new MgNotImplementedException(L"MgLayerBase.DeleteFeatures",
Modified: sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.h
--- sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.h 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Common/PlatformBase/MapLayer/LayerBase.h 2014-06-26 11:37:30 UTC (rev 8264)
@@ -870,6 +870,143 @@
/// \since 1.2
+ /// \brief
+ /// \return
+ /// \remarks
+ /// \since 3.0
+ /// \brief
+ /// \return
+ /// \remarks
+ /// \since 3.0
+ /// \brief
+ /// \remarks
+ /// \return
+ /// \since 3.0
+ /// \brief
+ /// \remarks
+ /// \return
+ /// \since 3.0
INTERNAL_API:
static MdfModel::LayerDefinition* GetLayerDefinition(MgResourceService* svcResource, MgResourceIdentifier* resId);
Modified: sandbox/jng/convenience_apis/Common/PlatformBase/Services/FeatureDefs.h
--- sandbox/jng/convenience_apis/Common/PlatformBase/Services/FeatureDefs.h 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Common/PlatformBase/Services/FeatureDefs.h 2014-06-26 11:37:30 UTC (rev 8264)
@@ -77,6 +77,11 @@
static const int AddSavePoint_Id = 0x1111ED2E;
static const int RollbackSavePoint_Id = 0x1111ED2F;
static const int ReleaseSavePoint_Id = 0x1111ED30;
+ static const int InsertFeatures = 0x1111ED31;
+ static const int InsertFeatures2 = 0x1111ED32;
+ static const int UpdateMatchingFeatures = 0x1111ED33;
+ static const int DeleteFeatures = 0x1111ED34;
/// \endcond
Modified: sandbox/jng/convenience_apis/Common/PlatformBase/Services/FeatureService.h
--- sandbox/jng/convenience_apis/Common/PlatformBase/Services/FeatureService.h 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Common/PlatformBase/Services/FeatureService.h 2014-06-26 11:37:30 UTC (rev 8264)
@@ -982,6 +982,342 @@
MgTransaction* transaction) = 0;
+ /// \brief
+ /// source.
+ /// \return
+ /// \remarks
+ /// \since 3.0
+ MgPropertyCollection* propertyValues) = 0;
+ /// \brief
+ /// source.
+ /// \return
+ /// \remarks
+ /// \since 3.0
+ MgTransaction* trans) = 0;
+ /// \brief
+ /// source.
+ /// \return
+ /// \remarks
+ /// \since 3.0
+ MgBatchPropertyCollection* batchPropertyValues) = 0;
+ /// \brief
+ /// source.
+ /// \return
+ /// \remarks
+ /// \since 3.0
+ /// \brief
+ /// source.
+ /// \return
+ /// \since 3.0
+ CREFSTRING filter) = 0;
+ /// \brief
+ /// source.
+ /// \return
+ /// \since 3.0
+ /// \brief
+ /// source.
+ /// \return
+ /// \since 3.0
+ /// \brief
+ /// source.
+ /// \return
+ /// \since 3.0
/// \brief
Modified: sandbox/jng/convenience_apis/Server/src/Services/Feature/FeatureOperationFactory.cpp
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/FeatureOperationFactory.cpp 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/FeatureOperationFactory.cpp 2014-06-26 11:37:30 UTC (rev 8264)
@@ -36,6 +36,10 @@
#include "OpTestConnection.h"
#include "OpTestFeatureSourceConnection.h"
#include "OpUpdateFeatures.h"
+#include "OpInsertFeatures.h"
+#include "OpInsertFeaturesBatched.h"
+#include "OpUpdateMatchingFeatures.h"
+#include "OpDeleteFeatures.h"
#include "OpGetFeatures.h"
#include "OpCloseFeatureReader.h"
#include "OpGetLongTransactions.h"
@@ -332,6 +336,54 @@
break;
+ case MgFeatureServiceOpId::InsertFeatures:
+ switch (VERSION_NO_PHASE(operationVersion))
+ case VERSION_SUPPORTED(3,0):
+ handler.reset(new MgOpInsertFeatures());
+ break;
+ default:
+ throw new MgInvalidOperationVersionException(
+ L"MgFeatureOperationFactory.GetOperation", __LINE__, __WFILE__, NULL, L"", NULL);
+ break;
+ case MgFeatureServiceOpId::InsertFeatures2:
+ handler.reset(new MgOpInsertFeaturesBatched());
+ break;
+ default:
+ break;
+ case MgFeatureServiceOpId::UpdateMatchingFeatures:
+ handler.reset(new MgOpUpdateMatchingFeatures());
+ break;
+ default:
+ break;
+ case MgFeatureServiceOpId::DeleteFeatures:
+ handler.reset(new MgOpDeleteFeatures());
+ break;
+ default:
+ break;
case MgFeatureServiceOpId::GetFeatures_Id:
Added: sandbox/jng/convenience_apis/Server/src/Services/Feature/OpDeleteFeatures.cpp
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/OpDeleteFeatures.cpp (rev 0)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/OpDeleteFeatures.cpp 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,150 @@
+// Copyright (C) 2004-2014 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "ServerFeatureTransactionPool.h"
+/// <summary>
+/// Constructs the object.
+/// </summary>
+MgOpDeleteFeatures::MgOpDeleteFeatures()
+/// <summary>
+/// Destructs the object.
+/// </summary>
+MgOpDeleteFeatures::~MgOpDeleteFeatures()
+/// <summary>
+/// Executes the operation.
+/// </summary>
+/// <exceptions>
+/// MgException
+/// </exceptions>
+void MgOpDeleteFeatures::Execute()
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpDeleteFeatures::Execute()\n")));
+ MG_LOG_OPERATION_MESSAGE(L"DeleteFeatures");
+ MG_FEATURE_SERVICE_TRY()
+ MG_LOG_OPERATION_MESSAGE_INIT(m_packet.m_OperationVersion, m_packet.m_NumArguments);
+ ACE_ASSERT(m_stream != NULL);
+ if (3 == m_packet.m_NumArguments)
+ Ptr<MgResourceIdentifier> resource = (MgResourceIdentifier*)m_stream->GetObject();
+ STRING className;
+ m_stream->GetString(className);
+ STRING filter;
+ m_stream->GetString(filter);
+ BeginExecution();
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == resource) ? L"MgResourceIdentifier" : resource->ToString().c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(className.c_str());
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(filter.c_str());
+ MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+ Validate();
+ // Execute the operation
+ INT32 result = m_service->DeleteFeatures(resource, className, filter);
+ // Write the response
+ EndExecution(result);
+ if (4 == m_packet.m_NumArguments)
+ STRING className;
+ STRING filter;
+ STRING transactionId;
+ m_stream->GetString(transactionId);
+ BeginExecution();
+ Validate();
+ MgServerFeatureTransactionPool* transactionPool = MgServerFeatureTransactionPool::GetInstance();
+ CHECKNULL(transactionPool, L"MgOpDeleteFeatures.Execute")
+ transactionPool->ValidateTimeout(transactionId);
+ // Get the MgTransaction instance from the pool if one has been started for this resource.
+ Ptr<MgServerFeatureTransaction> transaction = transactionPool->GetTransaction(transactionId);
+ INT32 result = m_service->DeleteFeatures(resource, className, filter, (MgTransaction*)transaction.p);
+ else
+ if (!m_argsRead)
+ throw new MgOperationProcessingException(L"MgOpDeleteFeatures.Execute",
+ // Successful operation
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Success.c_str());
+ MG_FEATURE_SERVICE_CATCH(L"MgOpDeleteFeatures.Execute")
+ if (mgException != NULL)
+ // Failed operation
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
+ // Add access log entry for operation
+ MG_LOG_OPERATION_MESSAGE_ACCESS_ENTRY();
+ MG_FEATURE_SERVICE_THROW()
Added: sandbox/jng/convenience_apis/Server/src/Services/Feature/OpDeleteFeatures.h
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/OpDeleteFeatures.h (rev 0)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/OpDeleteFeatures.h 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,33 @@
+#ifndef MG_OP_DELETE_FEATURES_H
+#define MG_OP_DELETE_FEATURES_H
+#include "FeatureOperation.h"
+class MgOpDeleteFeatures : public MgFeatureOperation
+ public:
+ MgOpDeleteFeatures();
+ virtual ~MgOpDeleteFeatures();
+ public:
+ virtual void Execute();
+#endif
Added: sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeatures.cpp
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeatures.cpp (rev 0)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeatures.cpp 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,150 @@
+/// <summary>
+/// </summary>
+MgOpInsertFeatures::MgOpInsertFeatures()
+/// <summary>
+/// </summary>
+MgOpInsertFeatures::~MgOpInsertFeatures()
+/// <summary>
+/// </summary>
+/// <exceptions>
+/// MgException
+/// </exceptions>
+void MgOpInsertFeatures::Execute()
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpInsertFeatures::Execute()\n")));
+ MG_LOG_OPERATION_MESSAGE(L"InsertFeatures");
+ STRING className;
+ Ptr<MgPropertyCollection> properties = (MgPropertyCollection*)m_stream->GetObject();
+ BeginExecution();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgPropertyCollection");
+ Validate();
+ Ptr<MgFeatureReader> result = m_service->InsertFeatures(resource, className, properties);
+ STRING className;
+ BeginExecution();
+ MG_LOG_OPERATION_MESSAGE_ADD_STRING(transactionId.c_str());
+ Validate();
+ CHECKNULL(transactionPool, L"MgOpInsertFeatures.Execute")
+ Ptr<MgFeatureReader> result = m_service->InsertFeatures(resource, className, properties, (MgTransaction*)transaction.p);
+ else
+ if (!m_argsRead)
+ throw new MgOperationProcessingException(L"MgOpInsertFeatures.Execute",
+ MG_FEATURE_SERVICE_CATCH(L"MgOpInsertFeatures.Execute")
Added: sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeatures.h
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeatures.h (rev 0)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeatures.h 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,33 @@
+#ifndef MG_OP_INSERT_FEATURES_H
+#define MG_OP_INSERT_FEATURES_H
+class MgOpInsertFeatures : public MgFeatureOperation
+ public:
+ MgOpInsertFeatures();
+ virtual ~MgOpInsertFeatures();
+ public:
+#endif
Added: sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeaturesBatched.cpp
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeaturesBatched.cpp (rev 0)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeaturesBatched.cpp 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,150 @@
+/// <summary>
+/// </summary>
+MgOpInsertFeaturesBatched::MgOpInsertFeaturesBatched()
+/// <summary>
+/// </summary>
+MgOpInsertFeaturesBatched::~MgOpInsertFeaturesBatched()
+/// <summary>
+/// </summary>
+/// <exceptions>
+/// MgException
+/// </exceptions>
+void MgOpInsertFeaturesBatched::Execute()
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpInsertFeaturesBatched::Execute()\n")));
+ MG_LOG_OPERATION_MESSAGE(L"InsertFeaturesBatched");
+ STRING className;
+ Ptr<MgBatchPropertyCollection> properties = (MgBatchPropertyCollection*)m_stream->GetObject();
+ BeginExecution();
+ Validate();
+ STRING className;
+ BeginExecution();
+ Validate();
+ CHECKNULL(transactionPool, L"MgOpInsertFeaturesBatched.Execute")
+ else
+ if (!m_argsRead)
+ throw new MgOperationProcessingException(L"MgOpInsertFeaturesBatched.Execute",
+ MG_FEATURE_SERVICE_CATCH(L"MgOpInsertFeaturesBatched.Execute")
Added: sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeaturesBatched.h
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeaturesBatched.h (rev 0)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/OpInsertFeaturesBatched.h 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,33 @@
+#ifndef MG_OP_INSERT_FEATURES_BATCHED_H
+#define MG_OP_INSERT_FEATURES_BATCHED_H
+class MgOpInsertFeaturesBatched : public MgFeatureOperation
+ public:
+ MgOpInsertFeaturesBatched();
+ virtual ~MgOpInsertFeaturesBatched();
+ public:
+#endif
Added: sandbox/jng/convenience_apis/Server/src/Services/Feature/OpUpdateMatchingFeatures.cpp
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/OpUpdateMatchingFeatures.cpp (rev 0)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/OpUpdateMatchingFeatures.cpp 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,158 @@
+/// <summary>
+/// </summary>
+MgOpUpdateMatchingFeatures::MgOpUpdateMatchingFeatures()
+/// <summary>
+/// </summary>
+MgOpUpdateMatchingFeatures::~MgOpUpdateMatchingFeatures()
+/// <summary>
+/// </summary>
+/// <exceptions>
+/// MgException
+/// </exceptions>
+void MgOpUpdateMatchingFeatures::Execute()
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgOpUpdateMatchingFeatures::Execute()\n")));
+ MG_LOG_OPERATION_MESSAGE(L"UpdateMatchingFeatures");
+ STRING className;
+ STRING filter;
+ BeginExecution();
+ Validate();
+ INT32 result = m_service->UpdateMatchingFeatures(resource, className, properties, filter);
+ if (5 == m_packet.m_NumArguments)
+ STRING className;
+ STRING filter;
+ BeginExecution();
+ Validate();
+ CHECKNULL(transactionPool, L"MgOpUpdateMatchingFeatures.Execute")
+ INT32 result = m_service->UpdateMatchingFeatures(resource, className, properties, filter, (MgTransaction*)transaction.p);
+ else
+ if (!m_argsRead)
+ throw new MgOperationProcessingException(L"MgOpUpdateMatchingFeatures.Execute",
+ MG_FEATURE_SERVICE_CATCH(L"MgOpUpdateMatchingFeatures.Execute")
Added: sandbox/jng/convenience_apis/Server/src/Services/Feature/OpUpdateMatchingFeatures.h
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/OpUpdateMatchingFeatures.h (rev 0)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/OpUpdateMatchingFeatures.h 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,33 @@
+#ifndef MG_OP_UPDATE_MATCHING_FEATURES_H
+#define MG_OP_UPDATE_MATCHING_FEATURES_H
+class MgOpUpdateMatchingFeatures : public MgFeatureOperation
+ public:
+ MgOpUpdateMatchingFeatures();
+ virtual ~MgOpUpdateMatchingFeatures();
+ public:
+#endif
Modified: sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.cpp
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.cpp 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.cpp 2014-06-26 11:37:30 UTC (rev 8264)
@@ -637,7 +637,308 @@
return asuf.Execute(resource, commands, transaction);
+MgFeatureReader* MgServerFeatureService::InsertFeatures(MgResourceIdentifier* resource,
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::InsertFeatures()");
+ Ptr<MgInsertFeatures> insert = new MgInsertFeatures(className, propertyValues);
+ Ptr<MgFeatureCommandCollection> cmds = new MgFeatureCommandCollection();
+ cmds->Add(insert);
+ MgServerUpdateFeatures asuf;
+ Ptr<MgPropertyCollection> props = asuf.Execute(resource, cmds, false);
+ if (cmds->GetCount() == 1)
+ INT32 i = 0;
+ Ptr<MgProperty> prop = props->GetItem(i);
+ if (prop->GetPropertyType() == MgPropertyType::String) //FDO error in non-transactional mode
+ MgStringProperty* sp = static_cast<MgStringProperty*>(prop.p);
+ MgStringCollection args;
+ args.Add(sp->GetValue());
+ throw new MgFdoException(L"MgServerFeatureService.InsertFeatures", __LINE__, __WFILE__, &args, L"MgFormatInnerExceptionMessage", NULL);
+ else if (prop->GetPropertyType() == MgPropertyType::Feature) //Insert result
+ MgFeatureProperty* fp = static_cast<MgFeatureProperty*>(prop.p);
+ ret = fp->GetValue();
+ MG_FEATURE_SERVICE_CATCH_AND_THROW_WITH_FEATURE_SOURCE(L"MgServerFeatureService.InsertFeatures", resource)
+ Ptr<MgPropertyCollection> props = asuf.Execute(resource, cmds, trans);
+ INT32 i = 0;
+ Ptr<MgInsertFeatures> insert = new MgInsertFeatures(className, batchPropertyValues);
+ INT32 i = 0;
+ INT32 i = 0;
+INT32 MgServerFeatureService::UpdateMatchingFeatures(MgResourceIdentifier* resource,
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::UpdateMatchingFeatures()");
+ INT32 ret = -1;
+ Ptr<MgUpdateFeatures> update = new MgUpdateFeatures(className, properties, filter);
+ cmds->Add(update);
+ INT32 i = 0;
+ throw new MgFdoException(L"MgServerFeatureService.UpdateMatchingFeatures", __LINE__, __WFILE__, &args, L"MgFormatInnerExceptionMessage", NULL);
+ else if (prop->GetPropertyType() == MgPropertyType::Int32) //Update result
+ MgInt32Property* ip = static_cast<MgInt32Property*>(prop.p);
+ ret = ip->GetValue();
+ MG_FEATURE_SERVICE_CATCH_AND_THROW_WITH_FEATURE_SOURCE(L"MgServerFeatureService.UpdateMatchingFeatures", resource)
+ return ret;
+ INT32 ret = -1;
+ INT32 i = 0;
+ return ret;
+INT32 MgServerFeatureService::DeleteFeatures(MgResourceIdentifier* resource,
+ MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::DeleteFeatures()");
+ INT32 ret = -1;
+ Ptr<MgDeleteFeatures> deleteCmd = new MgDeleteFeatures(className, filter);
+ cmds->Add(deleteCmd);
+ INT32 i = 0;
+ throw new MgFdoException(L"MgServerFeatureService.DeleteFeatures", __LINE__, __WFILE__, &args, L"MgFormatInnerExceptionMessage", NULL);
+ else if (prop->GetPropertyType() == MgPropertyType::Int32) //Delete result
+ return ret;
+ INT32 ret = -1;
+ INT32 i = 0;
+ return ret;
/// <summary>
Modified: sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.h
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.h 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.h 2014-06-26 11:37:30 UTC (rev 8264)
@@ -992,6 +992,44 @@
void CreateFeatureSource(MgResourceIdentifier* resource, MgFeatureSourceParams* sourceParams);
// Feature
MgBatchPropertyCollection* GetFeatures(CREFSTRING featureReader);
bool CloseFeatureReader(CREFSTRING featureReader);
Modified: sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.vcxproj
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.vcxproj 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.vcxproj 2014-06-26 11:37:30 UTC (rev 8264)
@@ -277,6 +277,12 @@
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
</ClCompile>
+ <ClCompile Include="OpDeleteFeatures.cpp">
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+ </ClCompile>
<ClCompile Include="OpDescribeSchema.cpp">
@@ -409,6 +415,18 @@
</ClCompile>
+ <ClCompile Include="OpInsertFeatures.cpp">
+ </ClCompile>
+ <ClCompile Include="OpInsertFeaturesBatched.cpp">
+ </ClCompile>
<ClCompile Include="OpReleaseSavePoint.cpp">
@@ -483,6 +501,12 @@
</ClCompile>
+ <ClCompile Include="OpUpdateMatchingFeatures.cpp">
+ </ClCompile>
<ClCompile Include="OpXmlToSchema.cpp">
@@ -799,6 +823,7 @@
<ClInclude Include="OpCloseSqlReader.h" />
<ClInclude Include="OpCommitTransaction.h" />
<ClInclude Include="OpCreateFeatureSource.h" />
+ <ClInclude Include="OpDeleteFeatures.h" />
<ClInclude Include="OpDescribeSchema.h" />
<ClInclude Include="OpDescribeSchemaAsXml.h" />
<ClInclude Include="OpDescribeWfsFeatureType.h" />
@@ -821,6 +846,8 @@
<ClInclude Include="OpGetSpatialContexts.h" />
<ClInclude Include="OpGetSqlRows.h" />
<ClInclude Include="OpGetWfsFeature.h" />
+ <ClInclude Include="OpInsertFeatures.h" />
+ <ClInclude Include="OpInsertFeaturesBatched.h" />
<ClInclude Include="OpReleaseSavePoint.h" />
<ClInclude Include="OpRollbackSavePoint.h" />
<ClInclude Include="OpRollbackTransaction.h" />
@@ -832,6 +859,7 @@
<ClInclude Include="OpTestFeatureSourceConnection.h" />
<ClInclude Include="OpUpdateFeatures.h" />
<ClInclude Include="OpUpdateFeaturesWithTransaction.h" />
+ <ClInclude Include="OpUpdateMatchingFeatures.h" />
<ClInclude Include="OpXmlToSchema.h" />
<ClInclude Include="BooleanDataReaderCreator.h" />
<ClInclude Include="ByteDataReaderCreator.h" />
Modified: sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.vcxproj.filters
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.vcxproj.filters 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureService.vcxproj.filters 2014-06-26 11:37:30 UTC (rev 8264)
@@ -188,6 +188,18 @@
<ClCompile Include="ServerUpdateFeatures.cpp" />
<ClCompile Include="TransformCache.cpp" />
<ClCompile Include="FdoForcedOneToOneFeatureReader.cpp" />
+ <Filter>Ops</Filter>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
+ </ClCompile>
</ItemGroup>
<ItemGroup>
<ClInclude Include="FeatureOperation.h">
@@ -385,6 +397,18 @@
<ClInclude Include="TransformCache.h" />
<ClInclude Include="UniqueFunction.h" />
<ClInclude Include="FdoForcedOneToOneFeatureReader.h" />
+ <ClInclude Include="OpInsertFeatures.h">
+ </ClInclude>
+ <ClInclude Include="OpUpdateMatchingFeatures.h">
+ </ClInclude>
+ <ClInclude Include="OpDeleteFeatures.h">
+ </ClInclude>
+ <ClInclude Include="OpInsertFeaturesBatched.h">
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="ServerFeatureService.rc" />
Modified: sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureServiceBuild.cpp
--- sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureServiceBuild.cpp 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Server/src/Services/Feature/ServerFeatureServiceBuild.cpp 2014-06-26 11:37:30 UTC (rev 8264)
@@ -107,3 +107,7 @@
#include "OpCommitTransaction.cpp"
#include "OpRollbackTransaction.cpp"
#include "OpUpdateFeaturesWithTransaction.cpp"
+#include "OpInsertFeatures.cpp"
+#include "OpInsertFeaturesBatched.cpp"
+#include "OpUpdateMatchingFeatures.cpp"
+#include "OpDeleteFeatures.cpp"
Modified: sandbox/jng/convenience_apis/Server/src/UnitTesting/TestFeatureService.cpp
--- sandbox/jng/convenience_apis/Server/src/UnitTesting/TestFeatureService.cpp 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Server/src/UnitTesting/TestFeatureService.cpp 2014-06-26 11:37:30 UTC (rev 8264)
@@ -2978,4 +2978,557 @@
throw;
+void TestFeatureService::TestCase_InsertFeatures()
+ try
+ MgServiceManager* serviceManager = MgServiceManager::GetInstance();
+ if(serviceManager == 0)
+ throw new MgNullReferenceException(L"TestFeatureService.TestCase_InsertFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgFeatureService> featSvc = dynamic_cast<MgFeatureService*>(serviceManager->RequestService(MgServiceType::FeatureService));
+ if (featSvc == 0)
+ throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_InsertFeatures",
+ Ptr<MgResourceIdentifier> fsId = new MgResourceIdentifier(L"Library://UnitTests/Data/TestCase_InsertFeatures.FeatureSource");
+ STRING className = CreateTestDataStore(featSvc, L"OSGeo.SDF", fsId);
+ Ptr<MgPropertyCollection> props = new MgPropertyCollection();
+ Ptr<MgStringProperty> nameProp = new MgStringProperty(L"Name", L"");
+ Ptr<MgGeometryProperty> geomProp = new MgGeometryProperty(L"Geometry", NULL);
+ props->Add(nameProp);
+ props->Add(geomProp);
+ MgAgfReaderWriter agfRw;
+ MgWktReaderWriter wktRw;
+ nameProp->SetValue(L"Test");
+ Ptr<MgGeometry> geom = wktRw.Read(L"POINT (1 1)");
+ Ptr<MgByteReader> agf = agfRw.Write(geom);
+ geomProp->SetValue(agf);
+ Ptr<MgReader> fr = featSvc->InsertFeatures(fsId, className, props);
+ INT32 count = 0;
+ while (fr->ReadNext())
+ count++;
+ fr->Close();
+ CPPUNIT_ASSERT(1 == count);
+ Ptr<MgFeatureQueryOptions> query = new MgFeatureQueryOptions();
+ fr = featSvc->SelectFeatures(fsId, className, query);
+ count = 0;
+ while(fr->ReadNext())
+ CPPUNIT_ASSERT(fr->GetString(L"Name") == L"Test");
+ agf = fr->GetGeometry(L"Geometry");
+ geom = agfRw.Read(agf);
+ CPPUNIT_ASSERT(wktRw.Write(geom) == L"POINT (1 1)");
+ count++;
+ fr->Close();
+ catch(MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch(FdoException* e)
+ STRING message = L"FdoException occurred: ";
+ message += e->GetExceptionMessage();
+ FDO_SAFE_RELEASE(e);
+ catch(...)
+ throw;
+void TestFeatureService::TestCase_InsertFeaturesBatch()
+ try
+ if (featSvc == 0)
+ Ptr<MgBatchPropertyCollection> batchProps = new MgBatchPropertyCollection();
+ for (INT32 i = 0; i < 5; i++)
+ STRING str = L"Test";
+ STRING sNum;
+ MgUtil::Int32ToString((i+1), sNum);
+ str += sNum;
+ nameProp->SetValue(str);
+ batchProps->Add(props);
+ Ptr<MgReader> fr = featSvc->InsertFeatures(fsId, className, batchProps);
+ INT32 count = 0;
+ count++;
+ fr->Close();
+ CPPUNIT_ASSERT(5 == count);
+ count = 0;
+ count++;
+ fr->Close();
+ SAFE_RELEASE(e);
+ catch(...)
+ throw;
+void TestFeatureService::TestCase_UpdateMatchingFeatures()
+ try
+ throw new MgNullReferenceException(L"TestFeatureService.TestCase_UpdateMatchingFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
+ if (featSvc == 0)
+ throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_UpdateMatchingFeatures",
+ STRING sNum;
+ str += sNum;
+ INT32 count = 0;
+ count++;
+ fr->Close();
+ Ptr<MgReader> fr = featSvc->SelectFeatures(fsId, className, query);
+ INT32 count = 0;
+ count++;
+ fr->Close();
+ Ptr<MgPropertyCollection> updateProps = new MgPropertyCollection();
+ Ptr<MgStringProperty> newNameProp = new MgStringProperty(L"Name", L"Test3Updated");
+ updateProps->Add(newNameProp);
+ Ptr<MgGeometry> newGeom = wktRw.Read(L"POINT (2 2)");
+ Ptr<MgByteReader> newAgf = agfRw.Write(newGeom);
+ Ptr<MgGeometryProperty> newGeomProp = new MgGeometryProperty(L"Geometry", newAgf);
+ updateProps->Add(newGeomProp);
+ INT32 updated = featSvc->UpdateMatchingFeatures(fsId, className, updateProps, L"Name = 'Test3'");
+ CPPUNIT_ASSERT(1 == updated);
+ query->SetFilter(L"Name = 'Test3'");
+ count = 0;
+ count++;
+ fr->Close();
+ CPPUNIT_ASSERT(0 == count);
+ query->SetFilter(L"Name = 'Test3Updated'");
+ count = 0;
+ count++;
+ fr->Close();
+ SAFE_RELEASE(e);
+ catch(...)
+ throw;
+void TestFeatureService::TestCase_DeleteFeatures()
+ try
+ throw new MgNullReferenceException(L"TestFeatureService.TestCase_DeleteFeatures", __LINE__, __WFILE__, NULL, L"", NULL);
+ if (featSvc == 0)
+ throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_DeleteFeatures",
+ STRING sNum;
+ str += sNum;
+ INT32 count = 0;
+ count++;
+ fr->Close();
+ INT32 count = 0;
+ count++;
+ fr->Close();
+ INT32 deleted = featSvc->DeleteFeatures(fsId, className, L"Name = 'Test3'");
+ CPPUNIT_ASSERT(1 == deleted);
+ count = 0;
+ count++;
+ fr->Close();
+ query = new MgFeatureQueryOptions();
+ count = 0;
+ count++;
+ fr->Close();
+ CPPUNIT_ASSERT(4 == count);
+ SAFE_RELEASE(e);
+ catch(...)
+ throw;
+void TestFeatureService::TestCase_TransactedCrud()
+ try
+ throw new MgNullReferenceException(L"TestFeatureService.TestCase_TransactedCrud", __LINE__, __WFILE__, NULL, L"", NULL);
+ if (featSvc == 0)
+ throw new MgServiceNotAvailableException(L"TestFeatureService.TestCase_TransactedCrud",
+ STRING className = CreateTestDataStore(featSvc, L"OSGeo.SQLite", fsId);
+ STRING sNum;
+ str += sNum;
+ INT32 count = 0;
+ count++;
+ fr->Close();
+ INT32 count = 0;
+ count++;
+ fr->Close();
+ //Do a transacted update
+ Ptr<MgTransaction> trans = featSvc->BeginTransaction(fsId);
+ INT32 updated = featSvc->UpdateMatchingFeatures(fsId, className, updateProps, L"Name = 'Test3'", trans);
+ //This hasn't been commited yet. So roll it back and verify our update never made it
+ count = 0;
+ count++;
+ fr->Close();
+ //Do a transacted update. This time, commit it.
+ trans = featSvc->BeginTransaction(fsId);
+ updateProps = new MgPropertyCollection();
+ newNameProp = new MgStringProperty(L"Name", L"Test3Updated");
+ newGeom = wktRw.Read(L"POINT (2 2)");
+ newAgf = agfRw.Write(newGeom);
+ newGeomProp = new MgGeometryProperty(L"Geometry", newAgf);
+ updated = featSvc->UpdateMatchingFeatures(fsId, className, updateProps, L"Name = 'Test3'", trans);
+ trans->Commit();
+ //Verify the update came through
+ count = 0;
+ count++;
+ fr->Close();
+ SAFE_RELEASE(e);
+ catch(...)
+ throw;
+STRING TestFeatureService::CreateTestDataStore(MgFeatureService* svcFeature, CREFSTRING provider, MgResourceIdentifier* fsId)
+ Ptr<MgCoordinateSystemFactory> csFactory = new MgCoordinateSystemFactory();
+ STRING scName = L"Default";
+ STRING csWkt = csFactory->ConvertCoordinateSystemCodeToWkt(L"LL84");
+ Ptr<MgFeatureSchema> schema = new MgFeatureSchema(L"Default", L"Default Feature Schema");
+ Ptr<MgClassDefinition> klass = new MgClassDefinition();
+ klass->SetName(L"Test");
+ Ptr<MgPropertyDefinitionCollection> clsProps = klass->GetProperties();
+ Ptr<MgPropertyDefinitionCollection> clsIdProps = klass->GetIdentityProperties();
+ Ptr<MgDataPropertyDefinition> id = new MgDataPropertyDefinition(L"ID");
+ id->SetDataType(MgPropertyType::Int32);
+ id->SetAutoGeneration(true);
+ Ptr<MgDataPropertyDefinition> name = new MgDataPropertyDefinition(L"Name");
+ name->SetDataType(MgPropertyType::String);
+ name->SetLength(255);
+ name->SetNullable(true);
+ Ptr<MgGeometricPropertyDefinition> geom = new MgGeometricPropertyDefinition(L"Geometry");
+ geom->SetGeometryTypes(MgFeatureGeometricType::Point);
+ geom->SetSpatialContextAssociation(scName);
+ clsProps->Add(id);
+ clsProps->Add(name);
+ clsProps->Add(geom);
+ clsIdProps->Add(id);
+ klass->SetDefaultGeometryPropertyName(L"Geometry");
+ Ptr<MgClassDefinitionCollection> classes = schema->GetClasses();
+ classes->Add(klass);
+ Ptr<MgFileFeatureSourceParams> fsParams = new MgFileFeatureSourceParams(provider, scName, csWkt, schema);
+ svcFeature->CreateFeatureSource(fsId, fsParams);
+ Ptr<MgFeatureSchemaCollection> schemas = svcFeature->DescribeSchema(fsId, L"");
+ Ptr<MgFeatureSchema> theSchema = schemas->GetItem(0);
+ Ptr<MgClassDefinitionCollection> theClasses = theSchema->GetClasses();
+ Ptr<MgClassDefinition> theClass = theClasses->GetItem(0);
+ STRING qClassName = theSchema->GetName();
+ qClassName += L":";
+ qClassName += theClass->GetName();
+ return qClassName;
Modified: sandbox/jng/convenience_apis/Server/src/UnitTesting/TestFeatureService.h
--- sandbox/jng/convenience_apis/Server/src/UnitTesting/TestFeatureService.h 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/Server/src/UnitTesting/TestFeatureService.h 2014-06-26 11:37:30 UTC (rev 8264)
@@ -41,6 +41,11 @@
CPPUNIT_TEST(TestCase_SelectAggregate);
CPPUNIT_TEST(TestCase_UpdateFeaturesInsert);
CPPUNIT_TEST(TestCase_UpdateFeaturesPartialFailure);
+ CPPUNIT_TEST(TestCase_InsertFeatures);
+ CPPUNIT_TEST(TestCase_InsertFeaturesBatch);
+ CPPUNIT_TEST(TestCase_UpdateMatchingFeatures);
+ CPPUNIT_TEST(TestCase_DeleteFeatures);
+ CPPUNIT_TEST(TestCase_TransactedCrud);
CPPUNIT_TEST(TestCase_ExecuteSqlQuery);
CPPUNIT_TEST(TestCase_ExecuteSqlNonQuery);
CPPUNIT_TEST(TestCase_GetSpatialContexts);
@@ -89,6 +94,11 @@
void TestCase_SelectAggregate();
void TestCase_UpdateFeaturesInsert();
void TestCase_UpdateFeaturesPartialFailure();
+ void TestCase_InsertFeatures();
+ void TestCase_InsertFeaturesBatch();
+ void TestCase_UpdateMatchingFeatures();
+ void TestCase_DeleteFeatures();
+ void TestCase_TransactedCrud();
void TestCase_ExecuteSqlQuery();
void TestCase_ExecuteSqlNonQuery();
void TestCase_GetSpatialContexts();
@@ -110,6 +120,9 @@
void TestCase_JoinFdoFeatures();
void TestCase_BenchmarkSqliteJoin();
void TestCase_BenchmarkSqliteAggregateJoin();
+private:
+ STRING CreateTestDataStore(MgFeatureService* svcFeature, CREFSTRING provider, MgResourceIdentifier* fsId);
#endif // _TESTFEATURESERVICE_H
Modified: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs 2014-06-26 11:37:30 UTC (rev 8264)
@@ -30,11 +30,20 @@
return _siteConn.CreateService(serviceType);
- public MgMapBase CreateMap()
+ public MgMapBase CreateMap(MgResourceIdentifier mapDefinition)
- return new MgMap(_siteConn);
+ var map = new MgMap(_siteConn);
+ map.Create(mapDefinition, mapDefinition.Name);
+ return map;
+ public MgMapBase CreateMap(string coordSys, MgEnvelope env, string name)
+ map.Create(coordSys, env, name);
+ return map;
public MgLayerBase CreateLayer(MgResourceIdentifier resId)
MgResourceService resSvc = (MgResourceService)_siteConn.CreateService(MgServiceType.ResourceService);
Modified: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs 2014-06-26 11:37:30 UTC (rev 8264)
@@ -18,7 +18,8 @@
public interface IPlatformFactory
MgService CreateService(int serviceType);
- MgMapBase CreateMap();
+ MgMapBase CreateMap(MgResourceIdentifier mapDefinition);
+ MgMapBase CreateMap(string coordSys, MgEnvelope env, string name);
MgLayerBase CreateLayer(MgResourceIdentifier resId);
Modified: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/CollectionTests.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/CollectionTests.cs 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/CollectionTests.cs 2014-06-26 11:37:30 UTC (rev 8264)
@@ -807,15 +807,14 @@
string coordsys = "GEOGCS[\"LL84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9108\"]],AXIS[\"Lat\",NORTH],AXIS[\"Long\",EAST],AUTHORITY[\"EPSG\",\"4326\"]]";
MgEnvelope env = new MgEnvelope(10, 10, 20, 20);
- MgMapBase map1 = factory.CreateMap();
- map1.Create(coordsys, env, "map1");
- MgMapBase map2 = factory.CreateMap();
- map2.Create(coordsys, env, "map2");
- MgMapBase map3 = factory.CreateMap();
- map3.Create(coordsys, env, "map3");
- MgMapBase map4 = factory.CreateMap();
- map4.Create(coordsys, env, "map4");
+ MgMapBase map1 = factory.CreateMap(coordsys, env, "map1");
+ MgMapBase map2 = factory.CreateMap(coordsys, env, "map2");
+ MgMapBase map3 = factory.CreateMap(coordsys, env, "map3");
+ MgMapBase map4 = factory.CreateMap(coordsys, env, "map4");
MgMapCollection coll = new MgMapCollection();
coll.Add(map1);
coll.Insert(1, map2);
Added: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/ConvenienceTests.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/ConvenienceTests.cs (rev 0)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/ConvenienceTests.cs 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,470 @@
+using System;
+using System.Collections.Generic;
+using System.Linq;
+using System.Text;
+using System.Threading.Tasks;
+using OSGeo.MapGuide;
+namespace OSGeo.MapGuide.Test.Common.ExternalTests
+ internal class FeatureServiceTestUtil
+ public static string CreateTestDataStore(MgResourceIdentifier fsId, string provider, MgFeatureService featSvc)
+ string scName = "Default";
+ var csFactory = new MgCoordinateSystemFactory();
+ string wkt = csFactory.ConvertCoordinateSystemCodeToWkt("LL84");
+ var schema = new MgFeatureSchema("Default", "Default Schema");
+ var cls = new MgClassDefinition();
+ cls.SetName("Test");
+ var classes = schema.GetClasses();
+ classes.Add(cls);
+ var clsProps = cls.GetProperties();
+ var idProps = cls.GetIdentityProperties();
+ var id = new MgDataPropertyDefinition("ID");
+ id.SetAutoGeneration(true);
+ id.SetDataType(MgPropertyType.Int32);
+ var name = new MgDataPropertyDefinition("Name");
+ name.SetDataType(MgPropertyType.String);
+ name.SetLength(255);
+ name.SetNullable(false);
+ var geom = new MgGeometricPropertyDefinition("Geometry");
+ geom.SetGeometryTypes(MgFeatureGeometricType.Point);
+ geom.SetSpatialContextAssociation(scName);
+ clsProps.Add(id);
+ clsProps.Add(name);
+ clsProps.Add(geom);
+ idProps.Add(id);
+ cls.SetDefaultGeometryPropertyName("Geometry");
+ var fsp = new MgFileFeatureSourceParams(provider, scName, wkt, schema);
+ featSvc.CreateFeatureSource(fsId, fsp);
+ var schemas = featSvc.DescribeSchema(fsId, "");
+ classes = schemas[0].GetClasses();
+ return schemas[0].Name + ":" + classes[0].Name;
+ public class FeatureServiceInsertFeatures : IExternalTest
+ public void Execute(IPlatformFactory factory, ITestLogger logger)
+ MgFeatureService featSvc = (MgFeatureService)factory.CreateService(MgServiceType.FeatureService);
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/InsertFeatures.FeatureSource");
+ string className = FeatureServiceTestUtil.CreateTestDataStore(fsId, "OSGeo.SDF", featSvc);
+ var agfRw = new MgAgfReaderWriter();
+ var wktRw = new MgWktReaderWriter();
+ var props = new MgPropertyCollection();
+ var nameP = new MgStringProperty("Name", "Test");
+ var geom = wktRw.Read("POINT (1 1)");
+ var agf = agfRw.Write(geom);
+ var geomP = new MgGeometryProperty("Geometry", agf);
+ props.Add(nameP);
+ props.Add(geomP);
+ var fr = featSvc.InsertFeatures(fsId, className, props);
+ int count = 0;
+ while (fr.ReadNext())
+ count++;
+ fr.Close();
+ Assert.AreEqual(1, count);
+ public class FeatureServiceInsertFeaturesBatched : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/InsertFeaturesBatched.FeatureSource");
+ var batchProps = new MgBatchPropertyCollection();
+ for (int i = 0; i < 5; i++)
+ var nameP = new MgStringProperty("Name", "Test" + (i + 1));
+ props.Add(nameP);
+ props.Add(geomP);
+ batchProps.Add(props);
+ var fr = featSvc.InsertFeatures(fsId, className, batchProps);
+ int count = 0;
+ count++;
+ fr.Close();
+ Assert.AreEqual(5, count);
+ public class FeatureServiceUpdateFeatures : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/UpdateFeatures.FeatureSource");
+ props.Add(nameP);
+ props.Add(geomP);
+ int count = 0;
+ count++;
+ fr.Close();
+ var updateProps = new MgPropertyCollection();
+ var newName = new MgStringProperty("Name", "Test3Updated");
+ updateProps.Add(newName);
+ int updated = featSvc.UpdateMatchingFeatures(fsId, className, updateProps, "Name = 'Test3'");
+ Assert.AreEqual(1, updated);
+ public class FeatureServiceDeleteFeatures : IExternalTest
+ var fsId = new MgResourceIdentifier("Library://UnitTests/Data/DeleteFeatures.FeatureSource");
+ props.Add(nameP);
+ props.Add(geomP);
+ int count = 0;
+ count++;
+ fr.Close();
+ int deleted = featSvc.DeleteFeatures(fsId, className, "Name = 'Test3'");
+ Assert.AreEqual(1, deleted);
+ var query = new MgFeatureQueryOptions();
+ fr = featSvc.SelectFeatures(fsId, className, query);
+ count = 0;
+ count++;
+ Assert.AreEqual(4, count);
+ query.SetFilter("Name = 'Test3'");
+ count = 0;
+ count++;
+ fr.Close();
+ Assert.AreEqual(0, count);
+ public class LayerInsertFeatures : IExternalTest
+ var resSvc = (MgResourceService)factory.CreateService(MgServiceType.ResourceService);
+ var featSvc = (MgFeatureService)factory.CreateService(MgServiceType.FeatureService);
+ MgCoordinateSystemFactory csFactory = new MgCoordinateSystemFactory();
+ MgMapBase map = factory.CreateMap(csFactory.ConvertCoordinateSystemCodeToWkt("LL84"), new MgEnvelope(-180,-90,180,90), "TestMap");
+ MgLayerCollection layers = map.GetLayers();
+ string layerXml = string.Format(Properties.Resources.TestLayer, fsId.ToString(), className, "Geometry");
+ byte[] bytes = Encoding.UTF8.GetBytes(layerXml);
+ MgByteSource bs = new MgByteSource(bytes, bytes.Length);
+ MgByteReader br = bs.GetReader();
+ var ldfId = new MgResourceIdentifier("Library://UnitTests/Layers/TestLayer.LayerDefinition");
+ resSvc.SetResource(ldfId, br, null);
+ MgLayerBase layer = factory.CreateLayer(ldfId);
+ layers.Insert(0, layer);
+ props.Add(nameP);
+ props.Add(geomP);
+ var fr = layer.InsertFeatures(props);
+ int count = 0;
+ count++;
+ fr.Close();
+ fr = layer.SelectFeatures(query);
+ count = 0;
+ count++;
+ fr.Close();
+ public class LayerInsertFeaturesBatched : IExternalTest
+ MgMapBase map = factory.CreateMap(csFactory.ConvertCoordinateSystemCodeToWkt("LL84"), new MgEnvelope(-180, -90, 180, 90), "TestMap");
+ props.Add(nameP);
+ props.Add(geomP);
+ var fr = layer.InsertFeatures(batchProps);
+ int count = 0;
+ count++;
+ fr.Close();
+ count = 0;
+ count++;
+ fr.Close();
+ public class LayerUpdateFeatures : IExternalTest
+ props.Add(nameP);
+ props.Add(geomP);
+ int count = 0;
+ count++;
+ fr.Close();
+ int updated = layer.UpdateMatchingFeatures(updateProps, "Name = 'Test3'");
+ public class LayerDeleteFeatures : IExternalTest
+ props.Add(nameP);
+ props.Add(geomP);
+ int count = 0;
+ count++;
+ fr.Close();
+ int deleted = layer.DeleteFeatures("Name = 'Test3'");
+ count = 0;
+ count++;
+ count = 0;
+ count++;
+ fr.Close();
Modified: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/PropertiesTest.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/PropertiesTest.cs 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/PropertiesTest.cs 2014-06-26 11:37:30 UTC (rev 8264)
@@ -369,7 +369,7 @@
- MgMapBase mb = factory.CreateMap();
+ MgMapBase mb = new MgMapBase();
Assert.AreEqual("", mb.Name);
Assert.AreEqual("", mb.SessionId);
Assert.IsNull(mb.MapDefinition);
Added: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Properties/Resources.Designer.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Properties/Resources.Designer.cs (rev 0)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Properties/Resources.Designer.cs 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,92 @@
+// <auto-generated>
+// This code was generated by a tool.
+// Runtime Version:4.0.30319.18444
+// Changes to this file may cause incorrect behavior and will be lost if
+// the code is regenerated.
+// </auto-generated>
+namespace OSGeo.MapGuide.Test.Common.Properties {
+ using System;
+ /// <summary>
+ /// A strongly-typed resource class, for looking up localized strings, etc.
+ /// </summary>
+ // This class was auto-generated by the StronglyTypedResourceBuilder
+ // class via a tool like ResGen or Visual Studio.
+ // To add or remove a member, edit your .ResX file then rerun ResGen
+ // with the /str option, or rebuild your VS project.
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "4.0.0.0")]
+ [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
+ [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
+ internal class Resources {
+ private static global::System.Resources.ResourceManager resourceMan;
+ private static global::System.Globalization.CultureInfo resourceCulture;
+ [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
+ internal Resources() {
+ /// <summary>
+ /// Returns the cached ResourceManager instance used by this class.
+ /// </summary>
+ [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
+ internal static global::System.Resources.ResourceManager ResourceManager {
+ get {
+ if (object.ReferenceEquals(resourceMan, null)) {
+ global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("OSGeo.MapGuide.Test.Common.Properties.Resources", typeof(Resources).Assembly);
+ resourceMan = temp;
+ return resourceMan;
+ /// <summary>
+ /// Overrides the current thread's CurrentUICulture property for all
+ /// resource lookups using this strongly typed resource class.
+ /// </summary>
+ internal static global::System.Globalization.CultureInfo Culture {
+ get {
+ return resourceCulture;
+ set {
+ resourceCulture = value;
+ /// <summary>
+ /// Looks up a localized string similar to .
+ /// </summary>
+ internal static string TestLayer {
+ get {
+ return ResourceManager.GetString("TestLayer", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to <?xml version="1.0" encoding="utf-8"?>
+ ///<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0" xsi:noNamespaceSchemaLocation="MapDefinition-2.4.0.xsd">
+ /// <Name>Test Map</Name>
+ /// <CoordinateSystem>{0}</CoordinateSystem>
+ /// <Extents>
+ /// <MinX>{1}</MinX>
+ /// <MaxX>{2}</MaxX>
+ /// <MinY>{3}</MinY>
+ /// <MaxY>{4}</MaxY>
+ /// </Extents>
+ /// <BackgroundColor>ffffffff</BackgroundColor>
+ ///</MapDefinition>.
+ /// </summary>
+ internal static string TestMapDef {
+ get {
+ return ResourceManager.GetString("TestMapDef", resourceCulture);
Added: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Properties/Resources.resx
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Properties/Resources.resx (rev 0)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Properties/Resources.resx 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,127 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="TestLayer" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\TestLayer.txt;System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ </data>
+ <data name="TestMapDef" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\TestMapDef.txt;System.String, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+ </data>
+</root>
Added: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Resources/TestLayer.txt
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Resources/TestLayer.txt (rev 0)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Resources/TestLayer.txt 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,68 @@
+<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="1.0.0" xsi:noNamespaceSchemaLocation="LayerDefinition-1.0.0.xsd">
+ <VectorLayerDefinition>
+ <ResourceId>{0}</ResourceId>
+ <FeatureName>{1}</FeatureName>
+ <FeatureNameType>FeatureClass</FeatureNameType>
+ <Geometry>{2}</Geometry>
+ <VectorScaleRange>
+ <PointTypeStyle>
+ <DisplayAsText>false</DisplayAsText>
+ <AllowOverpost>false</AllowOverpost>
+ <PointRule>
+ <LegendLabel />
+ <PointSymbolization2D>
+ <Mark>
+ <Unit>Points</Unit>
+ <SizeContext>DeviceUnits</SizeContext>
+ <SizeX>10</SizeX>
+ <SizeY>10</SizeY>
+ <Rotation>0</Rotation>
+ <Shape>Square</Shape>
+ <Fill>
+ <FillPattern>Solid</FillPattern>
+ <ForegroundColor>ffffffff</ForegroundColor>
+ <BackgroundColor>ffffffff</BackgroundColor>
+ </Fill>
+ <Edge>
+ <LineStyle>Solid</LineStyle>
+ <Thickness>1</Thickness>
+ <Color>ff000000</Color>
+ </Edge>
+ </Mark>
+ </PointSymbolization2D>
+ </PointRule>
+ </PointTypeStyle>
+ <LineTypeStyle>
+ <LineRule>
+ <LegendLabel />
+ <LineSymbolization2D>
+ </LineSymbolization2D>
+ </LineRule>
+ </LineTypeStyle>
+ <AreaTypeStyle>
+ <AreaRule>
+ <LegendLabel />
+ <AreaSymbolization2D>
+ <Fill>
+ </Fill>
+ <Stroke>
+ </Stroke>
+ </AreaSymbolization2D>
+ </AreaRule>
+ </AreaTypeStyle>
+ </VectorScaleRange>
+ </VectorLayerDefinition>
+</LayerDefinition>
Added: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Resources/TestMapDef.txt
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Resources/TestMapDef.txt (rev 0)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Resources/TestMapDef.txt 2014-06-26 11:37:30 UTC (rev 8264)
@@ -0,0 +1,12 @@
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="2.4.0" xsi:noNamespaceSchemaLocation="MapDefinition-2.4.0.xsd">
+ <Name>Test Map</Name>
+ <CoordinateSystem>{0}</CoordinateSystem>
+ <Extents>
+ <MinX>{1}</MinX>
+ <MaxX>{2}</MaxX>
+ <MinY>{3}</MinY>
+ <MaxY>{4}</MaxY>
+ </Extents>
+</MapDefinition>
Modified: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/TestCommon.csproj
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/TestCommon.csproj 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/TestCommon.csproj 2014-06-26 11:37:30 UTC (rev 8264)
@@ -76,6 +76,7 @@
<Compile Include="CommonTests.cs" />
<Compile Include="ExternalTests\ByteReaderTest.cs" />
<Compile Include="ExternalTests\CollectionTests.cs" />
+ <Compile Include="ExternalTests\ConvenienceTests.cs" />
<Compile Include="ExternalTests\PropertiesTest.cs" />
<Compile Include="FeatureService\Operations.cs" />
<Compile Include="ITestExecutor.cs" />
@@ -86,6 +87,11 @@
<Compile Include="PlatformApiTestExecutor.cs" />
<Compile Include="Properties\AssemblyInfo.cs" />
<Compile Include="FeatureService\FeatureServiceOperationExecutor.cs" />
+ <Compile Include="Properties\Resources.Designer.cs">
+ <AutoGen>True</AutoGen>
+ <DesignTime>True</DesignTime>
+ <DependentUpon>Resources.resx</DependentUpon>
+ </Compile>
<Compile Include="ResourceService\ResourceServiceOperationExecutor.cs" />
<Compile Include="ResourceService\Operations.cs" />
<Compile Include="SqliteException.cs" />
@@ -95,7 +101,18 @@
<Compile Include="UnitTestException.cs" />
<Compile Include="CommonUtility.cs" />
</ItemGroup>
- <ItemGroup />
+ <ItemGroup>
+ <EmbeddedResource Include="Properties\Resources.resx">
+ <Generator>ResXFileCodeGenerator</Generator>
+ <LastGenOutput>Resources.Designer.cs</LastGenOutput>
+ </EmbeddedResource>
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\TestLayer.txt" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\TestMapDef.txt" />
+ </ItemGroup>
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
<PropertyGroup>
<PreBuildEvent>call "$(SolutionDir)prebuild.bat" "$(ConfigurationName)" "$(PlatformName)"</PreBuildEvent>
Modified: sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/CollectionTests.cs
--- sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/CollectionTests.cs 2014-06-25 15:30:06 UTC (rev 8263)
+++ sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/CollectionTests.cs 2014-06-26 11:37:30 UTC (rev 8264)
@@ -13,15 +13,10 @@
- MgMap map1 = (MgMap)factory.CreateMap();
+ MgMap map1 = (MgMap)factory.CreateMap(coordsys, env, "map1");
+ MgMap map2 = (MgMap)factory.CreateMap(coordsys, env, "map2");
+ MgMap map3 = (MgMap)factory.CreateMap(coordsys, env, "map3");
- MgMap map2 = (MgMap)factory.CreateMap();
- MgMap map3 = (MgMap)factory.CreateMap();
MgPlotSpecification spec = new MgPlotSpecification((float)8.0, (float)11.0, "in", (float)0.0, (float)0.0, (float)5.0, (float)5.0);
MgResourceIdentifier resId = new MgResourceIdentifier("Library://test.WebLayout");
MgLayout layout1 = new MgLayout(resId, "Title1", "in");
More information about the mapguide-commits
