[mapguide-commits] r8266 - in sandbox/jng/convenience_apis: Common/MapGuideCommon/MapLayer Server/src/UnitTesting
svn_mapguide at osgeo.org
Thu Jun 26 08:33:51 PDT 2014
Author: jng
Date: 2014-06-26 08:33:51 -0700 (Thu, 26 Jun 2014)
New Revision: 8266
sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.cpp
sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.h
sandbox/jng/convenience_apis/Server/src/UnitTesting/TestMappingService.cpp
sandbox/jng/convenience_apis/Server/src/UnitTesting/TestMappingService.h
This submission adds a series of convenience APIs to MgLayer to simplify the theme icon generation process for a layer without having to do XML processing in .net/PHP/Java to determine the necessary parameters for GenerateLegendImage.
* GetGeometryTypeStyles - Gets the list of geometry type styles for this layer at the specified scale. NULL of there are no applicable styles at this scale
* GetThemeCategoryCount - Gets the number of theme categories for this layer at the specified scale. A number greater than 1 indicates a themed layer
* GenerateLegendImage - Gets the legend image for the layer at the specified scale and geometry type
* An overload of the above 3 methods is provided that takes no scale parameter and uses the map's scale instead.
Modified: sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.cpp
--- sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.cpp 2014-06-26 14:31:04 UTC (rev 8265)
+++ sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.cpp 2014-06-26 15:33:51 UTC (rev 8266)
@@ -17,6 +17,11 @@
#include "MapGuideCommon.h"
#include "FSDSAX2Parser.h"
+#include "AreaTypeStyle.h"
+#include "LineTypeStyle.h"
+#include "PointTypeStyle.h"
+#include "CompositeTypeStyle.h"
+#include <set>
MG_IMPL_DYNCREATE(MgLayer)
@@ -542,3 +547,169 @@
return deleted;
+MgIntCollection* MgLayer::GetGeometryTypeStyles()
+ Ptr<MgIntCollection> ret;
+ MG_TRY()
+ ret = GetGeometryTypeStyles(GetMap()->GetViewScale());
+ MG_CATCH_AND_THROW(L"MgLayer.GetGeometryTypeStyles");
+ return ret.Detach();
+INT32 MgLayer::GetThemeCategoryCount(INT32 geomType)
+ return GetThemeCategoryCount(GetMap()->GetViewScale(), geomType);
+MgByteReader* MgLayer::GenerateLegendImage(INT32 width, INT32 height, CREFSTRING format, INT32 geomType, INT32 themeCategory)
+ Ptr<MgByteReader> ret;
+ MG_TRY()
+ ret = GenerateLegendImage(GetMap()->GetViewScale(), width, height, format, geomType, themeCategory);
+ MG_CATCH_AND_THROW(L"MgLayer.GenerateLegendImage");
+MgIntCollection* MgLayer::GetGeometryTypeStyles(double scale)
+ MG_TRY()
+ Ptr<MgResourceService> resSvc = dynamic_cast<MgResourceService*>(GetMap()->GetService(MgServiceType::ResourceService));
+ std::auto_ptr<MdfModel::LayerDefinition> ldf(MgLayerBase::GetLayerDefinition(resSvc, m_definition));
+ if (ldf.get() != NULL)
+ MdfModel::VectorLayerDefinition* vl = dynamic_cast<MdfModel::VectorLayerDefinition*>(ldf.get());
+ if(vl != NULL)
+ MdfModel::VectorScaleRangeCollection* scaleRanges = vl->GetScaleRanges();
+ if (scaleRanges != NULL)
+ for (INT32 i = 0; i < scaleRanges->GetCount(); i++)
+ MdfModel::VectorScaleRange* vsr = scaleRanges->GetAt(i);
+ if (scale >= vsr->GetMinScale() && scale < vsr->GetMaxScale())
+ MdfModel::FeatureTypeStyleCollection* ftsc = vsr->GetFeatureTypeStyles();
+ ret = new MgIntCollection();
+ for (INT32 j = 0; j < ftsc->GetCount(); j++)
+ MdfModel::PointTypeStyle* pts = dynamic_cast<MdfModel::PointTypeStyle*>(ftsc->GetAt(j));
+ MdfModel::LineTypeStyle* lts = dynamic_cast<MdfModel::LineTypeStyle*>(ftsc->GetAt(j));
+ MdfModel::AreaTypeStyle* ats = dynamic_cast<MdfModel::AreaTypeStyle*>(ftsc->GetAt(j));
+ MdfModel::CompositeTypeStyle* cts = dynamic_cast<MdfModel::CompositeTypeStyle*>(ftsc->GetAt(j));
+ if (pts != NULL)
+ if (ret->IndexOf(1) < 0)
+ ret->Add(1);
+ else if (lts != NULL)
+ if (ret->IndexOf(2) < 0)
+ ret->Add(2);
+ else if (ats != NULL)
+ if (ret->IndexOf(3) < 0)
+ ret->Add(3);
+ else if (cts != NULL)
+ if (ret->IndexOf(4) < 0)
+ ret->Add(4);
+INT32 MgLayer::GetThemeCategoryCount(double scale, INT32 geomType)
+ INT32 ret = -1;
+ if(vl != NULL)
+ if (pts != NULL && geomType == 1)
+ ret = pts->GetRules()->GetCount();
+ break;
+ else if (lts != NULL && geomType == 2)
+ ret = lts->GetRules()->GetCount();
+ break;
+ else if (ats != NULL && geomType == 3)
+ ret = ats->GetRules()->GetCount();
+ break;
+ else if (cts != NULL && geomType == 4)
+ ret = cts->GetRules()->GetCount();
+ break;
+ return ret;
+MgByteReader* MgLayer::GenerateLegendImage(double scale, INT32 width, INT32 height, CREFSTRING format, INT32 geomType, INT32 themeCategory)
+ MG_TRY()
+ Ptr<MgMappingService> svcMapping = dynamic_cast<MgMappingService*>(GetMap()->GetService(MgServiceType::MappingService));
+ ret = svcMapping->GenerateLegendImage(m_definition, scale, width, height, format, geomType, themeCategory);
\ No newline at end of file
Modified: sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.h
--- sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.h 2014-06-26 14:31:04 UTC (rev 8265)
+++ sandbox/jng/convenience_apis/Common/MapGuideCommon/MapLayer/Layer.h 2014-06-26 15:33:51 UTC (rev 8266)
@@ -361,6 +361,216 @@
/// \since 3.0
virtual INT32 DeleteFeatures(CREFSTRING filter);
+ /// \brief
+ /// Gets the list of geometry type styles for this layer at the map's current scale. Returns NULL if there are no applicable geometry types
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// virtual MgIntCollection GetGeometryTypeStyles();
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \remarks
+ /// The map's current scale is used to determine what scale range in the layer definition to search for
+ /// \return
+ /// The list of geometry type styles for this layer at the map's current scale. Returns NULL if there are no applicable geometry types
+ /// \since 3.0
+ MgIntCollection* GetGeometryTypeStyles();
+ /// \brief
+ /// Gets the number of theme categories for this layer at the map's current scale for the given geometry type style. A count greater than 1 indicates a themed layer. Returns -1 if there are no applicable styles at the current scale
+ /// virtual int GetThemeCategoryCount(int geomType);
+ /// \param geomType (int)
+ /// The geometry type
+ /// \remarks
+ /// \return
+ /// The number of theme categories for this layer at the map's current scale for the given geometry type style. A count greater than 1 indicates a themed layer. Returns -1 if there are no applicable styles at the current scale
+ /// \since 3.0
+ INT32 GetThemeCategoryCount(INT32 geomType);
+ /// \brief
+ /// Returns the legend image for the specified geometry type and theme category
+ /// virtual MgByteReader GenerateLegendImage(int width, int height, string format, int geomType, int themeCategory);
+ /// virtual MgByteReader GenerateLegendImage(int width, int height, String format, int geomType, int themeCategory);
+ /// \param resource (MgResourceIdentifier)
+ /// Input
+ /// MgResourceIdentifier object identifying the layer definition resource.
+ /// \param scale (double)
+ /// Input
+ /// The scale at which the symbolization is requested.
+ /// \param width (int)
+ /// Input
+ /// The requested image width in pixels.
+ /// \param height (int)
+ /// Input
+ /// The requested image height in pixels.
+ /// \param format (String/string)
+ /// Input
+ /// Image format, from MgImageFormats. Example: PNG, JPG, PNG8, etc
+ /// Input
+ /// The type of symbolization required: 1=Point, 2=Line, 3=Area, 4=Composite
+ /// \param themeCategory (int)
+ /// Input
+ /// The value indicating which theme category swatch to return.
+ /// Used when there is a theme defined at this scale. An exception will be
+ /// thrown if a requested them category doesn't exist.
+ /// \remarks
+ /// \return
+ /// Returns a stream representing the legend image.
+ /// The default returned image format will be PNG8 unless a different supported
+ /// format is requested. An exception will be thrown if an unsupported image
+ /// \exception MgArgumentOutOfRangeException
+ /// \exception MgInvalidResourceTypeException
+ /// \exception MgNullArgumentException
+ /// \exception MgInvalidImageFormatException
+ /// \since 3.0
+ MgByteReader* GenerateLegendImage(INT32 width, INT32 height, CREFSTRING format, INT32 geomType, INT32 themeCategory);
+ /// \brief
+ /// virtual MgIntCollection GetGeometryTypeStyles(double scale);
+ /// The scale at which to retrive the list of applicable geometry types
+ /// \return
+ /// \since 3.0
+ MgIntCollection* GetGeometryTypeStyles(double scale);
+ /// \brief
+ /// virtual int GetThemeCategoryCount(double scale, int geomType);
+ /// The scale at which to count the number of applicable theme categories
+ /// \return
+ /// \since 3.0
+ INT32 GetThemeCategoryCount(double scale, INT32 geomType);
+ /// \brief
+ /// virtual MgByteReader GenerateLegendImage(double scale, int width, int height, string format, int geomType, int themeCategory);
+ /// virtual MgByteReader GenerateLegendImage(double scale, int width, int height, String format, int geomType, int themeCategory);
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// \return
+ /// \since 3.0
+ MgByteReader* GenerateLegendImage(double scale, INT32 width, INT32 height, CREFSTRING format, INT32 geomType, INT32 themeCategory);
INTERNAL_API:
Modified: sandbox/jng/convenience_apis/Server/src/UnitTesting/TestMappingService.cpp
--- sandbox/jng/convenience_apis/Server/src/UnitTesting/TestMappingService.cpp 2014-06-26 14:31:04 UTC (rev 8265)
+++ sandbox/jng/convenience_apis/Server/src/UnitTesting/TestMappingService.cpp 2014-06-26 15:33:51 UTC (rev 8266)
@@ -1021,6 +1021,229 @@
+void TestMappingService::TestCase_GetLegendImageConvenience()
+ try
+ Ptr<MgResourceIdentifier> mapres = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+ Ptr<MgMap> map = new MgMap(m_siteConnection);
+ map->Create(mapres, L"TestCase_GetLegendImageConvenience");
+ Ptr<MgResourceIdentifier> ldf = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
+ Ptr<MgLayer> layer = new MgLayer(ldf, m_svcResource);
+ layer->SetName(L"TestCase_GetLegendImageConvenience");
+ Ptr<MgLayerCollection> layers = map->GetLayers();
+ layers->Insert(0, layer);
+ Ptr<MgIntCollection> types = layer->GetGeometryTypeStyles(10000.0);
+ CPPUNIT_ASSERT(1 == types->GetCount());
+ CPPUNIT_ASSERT(types->IndexOf(1) < 0);
+ CPPUNIT_ASSERT(types->IndexOf(2) < 0);
+ CPPUNIT_ASSERT(types->IndexOf(3) >= 0);
+ CPPUNIT_ASSERT(types->IndexOf(4) < 0);
+ CPPUNIT_ASSERT(8 == layer->GetThemeCategoryCount(10000.0, 3));
+ CPPUNIT_ASSERT(-1 == layer->GetThemeCategoryCount(10000.0, 1));
+ CPPUNIT_ASSERT(-1 == layer->GetThemeCategoryCount(10000.0, 2));
+ CPPUNIT_ASSERT(-1 == layer->GetThemeCategoryCount(10000.0, 4));
+ types = layer->GetGeometryTypeStyles(14000.0);
+ CPPUNIT_ASSERT(NULL == types.p);
+ CPPUNIT_ASSERT(-1 == layer->GetThemeCategoryCount(14000.0, 3));
+ CPPUNIT_ASSERT(-1 == layer->GetThemeCategoryCount(14000.0, 1));
+ CPPUNIT_ASSERT(-1 == layer->GetThemeCategoryCount(14000.0, 2));
+ CPPUNIT_ASSERT(-1 == layer->GetThemeCategoryCount(14000.0, 4));
+ Ptr<MgByteReader> rdr = layer->GenerateLegendImage(10000.0, 16, 16, MgImageFormats::Png, 3, 0);
+ Ptr<MgByteSink> sink = new MgByteSink(rdr);
+ sink->ToFile(L"../UnitTestFiles/GenerateLegendImageConvenience_Parcels_16x16_PNG.png");
+ rdr = layer->GenerateLegendImage(10000.0, 16, 16, MgImageFormats::Png8, 3, 0);
+ sink = new MgByteSink(rdr);
+ sink->ToFile(L"../UnitTestFiles/GenerateLegendImageConvenience_Parcels_16x16_PNG8.png");
+ rdr = layer->GenerateLegendImage(10000.0, 16, 16, MgImageFormats::Jpeg, 3, 0);
+ sink->ToFile(L"../UnitTestFiles/GenerateLegendImageConvenience_Parcels_16x16_JPG.jpg");
+ rdr = layer->GenerateLegendImage(10000.0, 16, 16, MgImageFormats::Gif, 3, 0);
+ sink->ToFile(L"../UnitTestFiles/GenerateLegendImageConvenience_Parcels_16x16_GIF.gif");
+ catch (MgException* e)
+ STRING message = e->GetDetails(TEST_LOCALE);
+ SAFE_RELEASE(e);
+ CPPUNIT_FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
+void TestMappingService::TestCase_GetLegendImagePointStyleWithConstRotationsConvenience()
+ try
+ Ptr<MgResourceIdentifier> ldfId = new MgResourceIdentifier(L"Library://UnitTests/Layers/RotatedPointStyles.LayerDefinition");
+ Ptr<MgLayer> layer = new MgLayer(ldfId, m_svcResource);
+ layer->SetName(L"TestCase_GetLegendImagePointStyleWithConstRotationsConvenience");
+ Ptr<MgIntCollection> types = layer->GetGeometryTypeStyles(1000.0);
+ CPPUNIT_ASSERT(types->IndexOf(1) >= 0);
+ CPPUNIT_ASSERT(types->IndexOf(3) < 0);
+ CPPUNIT_ASSERT(15 == layer->GetThemeCategoryCount(1000.0, 1));
+ CPPUNIT_ASSERT(-1 == layer->GetThemeCategoryCount(1000.0, 2));
+ CPPUNIT_ASSERT(-1 == layer->GetThemeCategoryCount(1000.0, 3));
+ CPPUNIT_ASSERT(-1 == layer->GetThemeCategoryCount(1000.0, 4));
+ //Do 16x16 icons first. Our common scenario.
+ Ptr<MgByteReader> rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 0);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Square_0_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 1);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Square_45_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 2);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Square_25_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 3);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Star_0_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 4);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Star_45_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 5);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Star_25_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 6);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Triangle_0_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 7);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Triangle_45_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 8);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Triangle_25_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 9);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Cross_0_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 10);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Cross_45_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 11);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Cross_25_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 12);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_XMark_0_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 13);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_XMark_45_16x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 16, 16, MgImageFormats::Png, 1, 14);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_XMark_25_16x16.png");
+ //Now try 32x16 to see if the rotation handling is acceptable with non-square sizes
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 0);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Square_0_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 1);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Square_45_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 2);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Square_25_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 3);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Star_0_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 4);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Star_45_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 5);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Star_25_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 6);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Triangle_0_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 7);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Triangle_45_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 8);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Triangle_25_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 9);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Cross_0_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 10);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Cross_45_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 11);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_Cross_25_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 12);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_XMark_0_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 13);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_XMark_45_32x16.png");
+ rdr = layer->GenerateLegendImage(1000.0, 32, 16, MgImageFormats::Png, 1, 14);
+ sink->ToFile(L"../UnitTestFiles/RotatedPointConvenience_XMark_25_32x16.png");
+ SAFE_RELEASE(e);
+ catch (...)
+ throw;
void TestMappingService::TestCase_QueryFeaturesImageMap()
try
Modified: sandbox/jng/convenience_apis/Server/src/UnitTesting/TestMappingService.h
--- sandbox/jng/convenience_apis/Server/src/UnitTesting/TestMappingService.h 2014-06-26 14:31:04 UTC (rev 8265)
+++ sandbox/jng/convenience_apis/Server/src/UnitTesting/TestMappingService.h 2014-06-26 15:33:51 UTC (rev 8266)
@@ -36,6 +36,8 @@
CPPUNIT_TEST(TestCase_GetLegendPlot);
CPPUNIT_TEST(TestCase_GetLegendImage);
CPPUNIT_TEST(TestCase_GetLegendImagePointStyleWithConstRotations);
+ CPPUNIT_TEST(TestCase_GetLegendImageConvenience);
+ CPPUNIT_TEST(TestCase_GetLegendImagePointStyleWithConstRotationsConvenience);
CPPUNIT_TEST(TestCase_CreateRuntimeMap);
CPPUNIT_TEST(TestCase_DescribeRuntimeMap);
//CPPUNIT_TEST(TestCase_QueryFeaturesImageMap);
@@ -67,6 +69,8 @@
void TestCase_GetLegendPlot();
void TestCase_GetLegendImage();
void TestCase_GetLegendImagePointStyleWithConstRotations();
+ void TestCase_GetLegendImageConvenience();
+ void TestCase_GetLegendImagePointStyleWithConstRotationsConvenience();
void TestCase_QueryFeaturesImageMap();
private:
More information about the mapguide-commits
