[mapguide-commits] r8270 - in trunk/MgDev: . UnitTest/Common UnitTest/WebTier/DotNet/MgTestRunner UnitTest/WebTier/DotNet/TestCommon UnitTest/WebTier/DotNet/TestMapGuideApi
svn_mapguide at osgeo.org
Fri Jun 27 05:11:01 PDT 2014
Author: jng
Date: 2014-06-27 05:11:01 -0700 (Fri, 27 Jun 2014)
New Revision: 8270
Added:
trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/Assert.cs
trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs
trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/ExternalTests/
trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/ExternalTests/
trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs
Removed:
trunk/MgDev/UnitTest/Common/DotNetWrappers/
trunk/MgDev/
trunk/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs
trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/TestCommon.csproj
trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/TestMapGuideApi.csproj
Merged revision(s) 8263 from sandbox/jng/convenience_apis:
Improve DotNet test runner. Add support for external tests outside of the SQLite-defined test suite and integrate the existing common dotnet wrapper tests into it. This removes the need for the DotNetWrappers test project and it has been deleted as a result.
Property changes on: trunk/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/createruntimemap:7486-7555
/sandbox/jng/v30:8212,8214,8217,8220-8221,8223-8225
/sandbox/rfc94:5099-5163
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/convenience_apis:8263
Modified: trunk/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs
--- trunk/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs 2014-06-27 10:57:26 UTC (rev 8269)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/MgTestRunner/Program.cs 2014-06-27 12:11:01 UTC (rev 8270)
@@ -16,6 +16,32 @@
static MgUserInformation userInfo;
static MgSiteConnection siteConn;
+ class PlatformFactory : IPlatformFactory
+ private MgSiteConnection _siteConn;
+ public PlatformFactory(MgSiteConnection siteConn)
+ _siteConn = siteConn;
+ public MgService CreateService(int serviceType)
+ return _siteConn.CreateService(serviceType);
+ public MgMapBase CreateMap()
+ return new MgMap(_siteConn);
+ public MgLayerBase CreateLayer(MgResourceIdentifier resId)
+ MgResourceService resSvc = (MgResourceService)_siteConn.CreateService(MgServiceType.ResourceService);
+ return new MgLayer(resId, resSvc);
//Usage: MgTestRunner.exe <webconfig.ini path> <MENTOR_DICTIONARY_PATH> [test log path]
static void Main(string[] args)
@@ -38,6 +64,8 @@
siteConn = new MgSiteConnection();
siteConn.Open(userInfo);
+ var factory = new PlatformFactory(siteConn);
int testsRun = 0;
bool isEnterprise = false;
failures += ExecuteTest(ApiTypes.Platform, "../../TestData/ResourceService/ResourceServiceTest.dump", ref testsRun, logger, isEnterprise);
@@ -49,6 +77,9 @@
failures += ExecuteTest(ApiTypes.Platform, "../../TestData/MapLayer/MapLayerTest.dump", ref testsRun, logger, isEnterprise);
failures += ExecuteTest(ApiTypes.Platform, "../../TestData/WebLayout/WebLayoutTest.dump", ref testsRun, logger, isEnterprise);
failures += ExecuteTest(ApiTypes.Platform, "../../TestData/Unicode/UnicodeTest.dump", ref testsRun, logger, isEnterprise);
+ //Run auxillary tests not part of the SQLite-defined suite
+ failures += CommonTests.Execute(factory, logger, ref testsRun);
+ failures += MapGuideTests.Execute(factory, logger, ref testsRun);
logger.Write("\n\nTests failed/run: {0}/{1}\n", failures, testsRun);
Console.Write("\n\nTests failed/run: {0}/{1}\n", failures, testsRun);
logger.Write("Run ended: {0}\n\n", DateTime.Now.ToString());
Copied: trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/Assert.cs (from rev 8263, sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/Assert.cs)
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/Assert.cs (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/Assert.cs 2014-06-27 12:11:01 UTC (rev 8270)
@@ -0,0 +1,77 @@
+using System;
+using System.Collections.Generic;
+using System.Linq;
+using System.Text;
+using System.Threading.Tasks;
+namespace OSGeo.MapGuide.Test.Common
+ [Serializable]
+ public class AssertException : Exception
+ public AssertException() { }
+ public AssertException(string message) : base(message) { }
+ public AssertException(string message, Exception inner) : base(message, inner) { }
+ protected AssertException(
+ System.Runtime.Serialization.SerializationInfo info,
+ System.Runtime.Serialization.StreamingContext context)
+ : base(info, context) { }
+ public static void AreBytesEqual(byte[] expected, byte[] actual)
+ byte[] a = expected;
+ byte[] b = actual;
+ if (a.Length != b.Length)
+ throw new AssertException("Expected byte array size of " + a.Length + ", got size of: " + b.Length);
+ for (int i = 0; i < a.Length; i++)
+ if (a[i] != b[i])
+ throw new AssertException("Byte number " + (i + 1) + " in expected byte array does not match byte in actual byte array");
+ public static void AreEqual<T>(T expected, T actual)
+ if (typeof(T) == typeof(byte[]))
+ AreBytesEqual(expected as byte[], actual as byte[]);
+ else if (!EqualityComparer<T>.Default.Equals(expected, actual))
+ throw new AssertException("Expected: " + expected + ", got: " + actual);
+ public static void Greater<T>(T value, T against) where T : IComparable
+ if (value.CompareTo(against) <= 0)
+ throw new AssertException(value + " is not greater than " + against);
+ public static void IsNull(object obj)
+ if (obj != null)
+ throw new AssertException("Reference is not null");
+ public static void IsTrue(bool condition)
+ if (!condition)
+ throw new AssertException("Condition evaluated to false. Expected: true");
+ public static void IsFalse(bool condition)
+ if (condition)
+ throw new AssertException("Condition evaluated to true. Expected: false");
+ public static void IsNaN(double value)
+ if (!double.IsNaN(value))
+ throw new AssertException("Double is a number. Expected: NaN");
Copied: trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs (from rev 8263, sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs)
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/CommonTests.cs 2014-06-27 12:11:01 UTC (rev 8270)
@@ -0,0 +1,63 @@
+using System;
+using System.IO;
+using System.Linq;
+using System.Reflection;
+using System.Text;
+ //Defines tests outside of the SQLite-based test suite
+ public interface IExternalTest
+ void Execute(IPlatformFactory factory, ITestLogger logger);
+ public interface IPlatformFactory
+ MgService CreateService(int serviceType);
+ MgMapBase CreateMap();
+ MgLayerBase CreateLayer(MgResourceIdentifier resId);
+ public class CommonTests
+ public static int Execute(IPlatformFactory factory, ITestLogger logger, ref int testsRun)
+ int failures = 0;
+ var types = typeof(IPlatformFactory).Assembly.GetTypes();
+ foreach (var type in types)
+ if (typeof(IExternalTest).IsAssignableFrom(type) && type.IsClass)
+ var test = (IExternalTest)Activator.CreateInstance(type);
+ try
+ logger.WriteLine("****** Executing platform test: " + type.Name + " *********");
+ Console.WriteLine("Executing external platform test: " + type.Name);
+ test.Execute(factory, logger);
+ catch (AssertException ex)
+ logger.WriteLine("Assertion failure: " + ex.Message);
+ Console.WriteLine("Assertion failure: " + ex.Message);
+ failures++;
+ catch (Exception ex)
+ logger.WriteLine("General failure: " + ex.ToString());
+ Console.WriteLine("General failure: " + ex.ToString());
+ failures++;
+ finally
+ testsRun++;
+ return failures;
Modified: trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/TestCommon.csproj
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/TestCommon.csproj 2014-06-27 10:57:26 UTC (rev 8269)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/TestCommon/TestCommon.csproj 2014-06-27 12:11:01 UTC (rev 8270)
@@ -72,6 +72,11 @@
</ItemGroup>
<ItemGroup>
<Compile Include="ApiTypes.cs" />
+ <Compile Include="Assert.cs" />
+ <Compile Include="CommonTests.cs" />
+ <Compile Include="ExternalTests\ByteReaderTest.cs" />
+ <Compile Include="ExternalTests\CollectionTests.cs" />
+ <Compile Include="ExternalTests\PropertiesTest.cs" />
<Compile Include="FeatureService\Operations.cs" />
<Compile Include="ITestExecutor.cs" />
<Compile Include="ITestExecutorCollection.cs" />
Copied: trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs (from rev 8263, sandbox/jng/convenience_apis/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs)
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/MapGuideTests.cs 2014-06-27 12:11:01 UTC (rev 8270)
@@ -0,0 +1,49 @@
+using OSGeo.MapGuide.Test.Common;
+using System;
+using System.Linq;
+using System.Text;
+namespace OSGeo.MapGuide.Test.Web
+ public class MapGuideTests
+ int failures = 0;
+ var types = typeof(MapGuideTests).Assembly.GetTypes();
+ try
+ logger.WriteLine("****** Executing MapGuide test: " + type.Name + " *********");
+ Console.WriteLine("Executing external MapGuide test: " + type.Name);
+ failures++;
+ failures++;
+ finally
+ testsRun++;
+ return failures;
Modified: trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/TestMapGuideApi.csproj
--- trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/TestMapGuideApi.csproj 2014-06-27 10:57:26 UTC (rev 8269)
+++ trunk/MgDev/UnitTest/WebTier/DotNet/TestMapGuideApi/TestMapGuideApi.csproj 2014-06-27 12:11:01 UTC (rev 8270)
@@ -79,6 +79,8 @@
<ItemGroup>
<Compile Include="DrawingService\DrawingServiceOperationExecutor.cs" />
<Compile Include="DrawingService\Operations.cs" />
+ <Compile Include="MapGuideTests.cs" />
<Compile Include="MappingService\MappingServiceOperationExecutor.cs" />
<Compile Include="Properties\AssemblyInfo.cs" />
<Compile Include="MapGuideTestExecutorCollection.cs" />
More information about the mapguide-commits
