[mapguide-commits] r8000 - trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Mar 29 11:02:39 PDT 2014
Author: jng
Date: 2014-03-29 11:02:39 -0700 (Sat, 29 Mar 2014)
New Revision: 8000
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor/RuleGridView.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor/RuleGridView.cs
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor/VectorScaleRangeGrid.cs
#2418: Add support for overpost and text display options for point styles. Also update offsets when loading a composite style grid as theme generation may have changed the offsets.
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor/RuleGridView.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor/RuleGridView.Designer.cs	2014-03-29 17:50:27 UTC (rev 7999)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor/RuleGridView.Designer.cs	2014-03-29 18:02:39 UTC (rev 8000)
@@ -40,6 +40,8 @@
             this.btnAutoRefresh = new System.Windows.Forms.ToolStripButton();
             this.btnShowInLegend = new System.Windows.Forms.ToolStripButton();
             this.grdRules = new System.Windows.Forms.DataGridView();
+            this.btnDisplayAsText = new System.Windows.Forms.ToolStripButton();
+            this.btnAllowOverpost = new System.Windows.Forms.ToolStripButton();
             this.toolStrip1.SuspendLayout();
             ((System.ComponentModel.ISupportInitialize)(this.grdRules)).BeginInit();
             this.SuspendLayout();
@@ -55,7 +57,9 @@
             this.toolStripSeparator1,
             this.btnRefreshStylePreviews,
             this.btnAutoRefresh,
-            this.btnShowInLegend});
+            this.btnShowInLegend,
+            this.btnDisplayAsText,
+            this.btnAllowOverpost});
             this.toolStrip1.Location = new System.Drawing.Point(0, 0);
             this.toolStrip1.Name = "toolStrip1";
             this.toolStrip1.Size = new System.Drawing.Size(785, 25);
@@ -118,8 +122,8 @@
             this.btnRefreshStylePreviews.Image = global::Maestro.Editors.Properties.Resources.arrow_circle_135;
             this.btnRefreshStylePreviews.ImageTransparentColor = System.Drawing.Color.Magenta;
             this.btnRefreshStylePreviews.Name = "btnRefreshStylePreviews";
-            this.btnRefreshStylePreviews.Size = new System.Drawing.Size(143, 22);
-            this.btnRefreshStylePreviews.Text = "Refresh Style Previews";
+            this.btnRefreshStylePreviews.Size = new System.Drawing.Size(115, 22);
+            this.btnRefreshStylePreviews.Text = "Refresh Previews";
             this.btnRefreshStylePreviews.Click += new System.EventHandler(this.btnRefreshStylePreviews_Click);
             // btnAutoRefresh
@@ -160,6 +164,26 @@
             this.grdRules.Scroll += new System.Windows.Forms.ScrollEventHandler(this.grdRules_Scroll);
             this.grdRules.SelectionChanged += new System.EventHandler(this.grdRules_SelectionChanged);
+            // btnDisplayAsText
+            this.btnDisplayAsText.CheckOnClick = true;
+            this.btnDisplayAsText.Image = global::Maestro.Editors.Properties.Resources.tick;
+            this.btnDisplayAsText.ImageTransparentColor = System.Drawing.Color.Magenta;
+            this.btnDisplayAsText.Name = "btnDisplayAsText";
+            this.btnDisplayAsText.Size = new System.Drawing.Size(106, 22);
+            this.btnDisplayAsText.Text = "Display As Text";
+            this.btnDisplayAsText.Click += new System.EventHandler(this.btnDisplayAsText_Click);
+            // btnAllowOverpost
+            this.btnAllowOverpost.CheckOnClick = true;
+            this.btnAllowOverpost.Image = global::Maestro.Editors.Properties.Resources.tick;
+            this.btnAllowOverpost.ImageTransparentColor = System.Drawing.Color.Magenta;
+            this.btnAllowOverpost.Name = "btnAllowOverpost";
+            this.btnAllowOverpost.Size = new System.Drawing.Size(108, 20);
+            this.btnAllowOverpost.Text = "Allow Overpost";
+            this.btnAllowOverpost.Click += new System.EventHandler(this.btnAllowOverpost_Click);
             // RuleGridView
             this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
@@ -189,5 +213,7 @@
         private System.Windows.Forms.ToolStripButton btnShowInLegend;
         private System.Windows.Forms.ToolStripButton btnRefreshStylePreviews;
         private System.Windows.Forms.ToolStripButton btnAutoRefresh;
+        private System.Windows.Forms.ToolStripButton btnDisplayAsText;
+        private System.Windows.Forms.ToolStripButton btnAllowOverpost;
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor/RuleGridView.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor/RuleGridView.cs	2014-03-29 17:50:27 UTC (rev 7999)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor/RuleGridView.cs	2014-03-29 18:02:39 UTC (rev 8000)
@@ -132,6 +132,18 @@
                         btnShowInLegend.Checked = c2.ShowInLegend;
+                var pts = style as IPointVectorStyle;
+                if (pts != null)
+                    btnAllowOverpost.Checked = pts.AllowOverpost;
+                    btnDisplayAsText.Checked = pts.DisplayAsText;
+                else
+                    btnAllowOverpost.Visible =
+                        btnDisplayAsText.Visible = false;
                 InitGrid(style is ICompositeTypeStyle);
                 _editedLayer = (ILayerDefinition)_edSvc.GetEditedResource();
                 _parentScaleRange = parentRange;
@@ -848,5 +860,19 @@
             else if (c2 != null)
                 c2.ShowInLegend = btnShowInLegend.Checked;
+        private void btnDisplayAsText_Click(object sender, EventArgs e)
+            var pts = _style as IPointVectorStyle;
+            if (pts != null)
+                pts.DisplayAsText = btnDisplayAsText.Checked;
+        private void btnAllowOverpost_Click(object sender, EventArgs e)
+            if (pts != null)
+                pts.AllowOverpost = btnAllowOverpost.Checked;
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor/VectorScaleRangeGrid.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor/VectorScaleRangeGrid.cs	2014-03-29 17:50:27 UTC (rev 7999)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/GridEditor/VectorScaleRangeGrid.cs	2014-03-29 18:02:39 UTC (rev 8000)
@@ -269,19 +269,19 @@
                 if (!_compositeRuleGrids.ContainsKey(style))
                     var grid = new RuleGridView();
+                    grid.Init(_parent.EditorService, _vsr, style);
+                    _compositeRuleGrids[style] = grid;
-                    if (lstStyles.SelectedIndex >= 0)
+                //Update offset
+                if (lstStyles.SelectedIndex >= 0)
+                    int offset = 0;
+                    for (int i = 0; i < lstStyles.SelectedIndex; i++)
-                        int offset = 0;
-                        for (int i = 0; i < lstStyles.SelectedIndex; i++)
-                            offset += _cts[i].RuleCount;
-                        grid.ThemeIndexOffest = offset;
+                        offset += _cts[i].RuleCount;
-                    grid.Init(_parent.EditorService, _vsr, style);
-                    _compositeRuleGrids[style] = grid;
+                    _compositeRuleGrids[style].ThemeIndexOffest = offset;
                 SetActiveControl(_compositeRuleGrids[style]);
More information about the mapguide-commits mailing list
