[mapguide-commits] r8106 - branches/2.6/MgDev
svn_mapguide at osgeo.org
Sat May 3 10:39:14 PDT 2014
Author: jng
Date: 2014-05-03 10:39:14 -0700 (Sat, 03 May 2014)
New Revision: 8106
branches/2.6/MgDev/build_oem.sh
Merge r8105 to 2.6
Modified: branches/2.6/MgDev/build_oem.sh
--- branches/2.6/MgDev/build_oem.sh 2014-05-03 17:28:43 UTC (rev 8105)
+++ branches/2.6/MgDev/build_oem.sh 2014-05-03 17:39:14 UTC (rev 8106)
@@ -14,6 +14,7 @@
INSTALLDIR=/usr/local/mapguideopensource
CLEAN_FLAG=0
BUILD_CPU=32
+BUILD_CONFIG=release
while [ $# -gt 0 ]; do # Until you run out of parameters...
case "$1" in
-prefix|--prefix)
@@ -28,12 +29,17 @@
BUILD_CPU=$2
shift
+ -config|--config)
+ BUILD_CONFIG=$2
+ shift
-help|--help)
echo "Usage: $0 (options)"
echo "Options:"
echo " --prefix [installation directory]"
echo " --clean [clean all objects and binaries in Oem]"
echo " --build [32(default)|64]"
+ echo " --config [release(default)|debug]"
echo " --help [Display usage]"
exit
@@ -122,7 +128,11 @@
libtoolize --copy --force
automake --add-missing --copy
autoconf
- sh ./configure --enable-optimized --prefix="${INSTALLDIR}"
+ if [ $BUILD_CONFIG = "debug" ]; then
+ sh ./configure --disable-optimized --enable-silent-rules --prefix="${INSTALLDIR}"
+ else
+ sh ./configure --enable-optimized --enable-silent-rules --prefix="${INSTALLDIR}"
+ fi
make
check_build
popd
@@ -158,7 +168,11 @@
autoconf
+ else
+ fi
make
check_build
popd
@@ -194,7 +208,11 @@
autoconf
+ else
+ fi
make
check_build
popd
@@ -221,6 +239,10 @@
build_geos()
pushd geos-2.2.0
+ aclocal
+ libtoolize --copy --force
+ automake --add-missing --copy
+ autoconf
if [ $BUILD_CPU -eq 64 ]; then
sh ./configure --with-pic --prefix="${INSTALLDIR}"
else
@@ -322,7 +344,7 @@
autoconf
automake --add-missing --copy --force-missing
# -ldl is to prevent undefined reference to dlsym/dlopen/dlclose
- sh ./configure --prefix="${INSTALLDIR}" LDFLAGS="-ldl"
+ sh ./configure --enable-silent-rules --prefix="${INSTALLDIR}" LDFLAGS="-ldl"
make
check_build
popd
@@ -503,10 +525,14 @@
build_gd()
pushd gd/gd
+ aclocal
+ autoconf
- sh ./configure --enable-static --disable-shared --without-fontconfig --with-pic
+ sh ./configure --enable-static --disable-shared --without-fontconfig --enable-silent-rules --with-pic
else
fi
make
check_build
More information about the mapguide-commits
