[mapguide-commits] r8111 - in trunk/Tools/Maestro/Maestro.Editors: . Common Common/Expression
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 6 13:00:53 PDT 2014
Author: jng
Date: 2014-05-06 13:00:53 -0700 (Tue, 06 May 2014)
New Revision: 8111
Added:
   trunk/Tools/Maestro/Maestro.Editors/Common/Expression/LookupExpressionBuilder.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Common/Expression/LookupExpressionBuilder.cs
   trunk/Tools/Maestro/Maestro.Editors/Common/Expression/LookupExpressionBuilder.resx
   trunk/Tools/Maestro/Maestro.Editors/Common/Expression/RangeExpressionBuilder.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Common/Expression/RangeExpressionBuilder.cs
   trunk/Tools/Maestro/Maestro.Editors/Common/Expression/RangeExpressionBuilder.resx
   trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs
   trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.resx
   trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.cs
   trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.resx
   trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
#2438: Add specialized builders for the following stylization functions in the Expression Editor:
 - LOOKUP
 - RANGE
 - ARGB
 - HTMLCOLOR
Added: trunk/Tools/Maestro/Maestro.Editors/Common/Expression/LookupExpressionBuilder.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/Expression/LookupExpressionBuilder.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/Expression/LookupExpressionBuilder.Designer.cs	2014-05-06 20:00:53 UTC (rev 8111)
@@ -0,0 +1,143 @@
+namespace Maestro.Editors.Common.Expression
+    partial class LookupExpressionBuilder
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Windows Form Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(LookupExpressionBuilder));
+            this.grdRangeItems = new System.Windows.Forms.DataGridView();
+            this.label1 = new System.Windows.Forms.Label();
+            this.cmbProperty = new System.Windows.Forms.ComboBox();
+            this.label2 = new System.Windows.Forms.Label();
+            this.txtDefaultValue = new System.Windows.Forms.TextBox();
+            this.groupBox1 = new System.Windows.Forms.GroupBox();
+            this.txtPreview = new System.Windows.Forms.TextBox();
+            this.btnRefresh = new System.Windows.Forms.Button();
+            this.btnOK = new System.Windows.Forms.Button();
+            this.btnCancel = new System.Windows.Forms.Button();
+            ((System.ComponentModel.ISupportInitialize)(this.grdRangeItems)).BeginInit();
+            this.groupBox1.SuspendLayout();
+            this.SuspendLayout();
+            // grdRangeItems
+            resources.ApplyResources(this.grdRangeItems, "grdRangeItems");
+            this.grdRangeItems.ColumnHeadersHeightSizeMode = System.Windows.Forms.DataGridViewColumnHeadersHeightSizeMode.AutoSize;
+            this.grdRangeItems.Name = "grdRangeItems";
+            // label1
+            resources.ApplyResources(this.label1, "label1");
+            this.label1.Name = "label1";
+            // cmbProperty
+            this.cmbProperty.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+            this.cmbProperty.FormattingEnabled = true;
+            resources.ApplyResources(this.cmbProperty, "cmbProperty");
+            this.cmbProperty.Name = "cmbProperty";
+            // label2
+            resources.ApplyResources(this.label2, "label2");
+            this.label2.Name = "label2";
+            // txtDefaultValue
+            resources.ApplyResources(this.txtDefaultValue, "txtDefaultValue");
+            this.txtDefaultValue.Name = "txtDefaultValue";
+            // groupBox1
+            resources.ApplyResources(this.groupBox1, "groupBox1");
+            this.groupBox1.Controls.Add(this.txtPreview);
+            this.groupBox1.Name = "groupBox1";
+            this.groupBox1.TabStop = false;
+            // txtPreview
+            resources.ApplyResources(this.txtPreview, "txtPreview");
+            this.txtPreview.Name = "txtPreview";
+            // btnRefresh
+            resources.ApplyResources(this.btnRefresh, "btnRefresh");
+            this.btnRefresh.Name = "btnRefresh";
+            this.btnRefresh.UseVisualStyleBackColor = true;
+            this.btnRefresh.Click += new System.EventHandler(this.btnRefresh_Click);
+            // btnOK
+            resources.ApplyResources(this.btnOK, "btnOK");
+            this.btnOK.Name = "btnOK";
+            this.btnOK.UseVisualStyleBackColor = true;
+            this.btnOK.Click += new System.EventHandler(this.btnOK_Click);
+            // btnCancel
+            resources.ApplyResources(this.btnCancel, "btnCancel");
+            this.btnCancel.Name = "btnCancel";
+            this.btnCancel.UseVisualStyleBackColor = true;
+            this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+            // LookupExpressionBuilder
+            resources.ApplyResources(this, "$this");
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.ControlBox = false;
+            this.Controls.Add(this.btnRefresh);
+            this.Controls.Add(this.btnCancel);
+            this.Controls.Add(this.btnOK);
+            this.Controls.Add(this.groupBox1);
+            this.Controls.Add(this.txtDefaultValue);
+            this.Controls.Add(this.label2);
+            this.Controls.Add(this.cmbProperty);
+            this.Controls.Add(this.label1);
+            this.Controls.Add(this.grdRangeItems);
+            this.Name = "LookupExpressionBuilder";
+            ((System.ComponentModel.ISupportInitialize)(this.grdRangeItems)).EndInit();
+            this.groupBox1.ResumeLayout(false);
+            this.groupBox1.PerformLayout();
+            this.ResumeLayout(false);
+            this.PerformLayout();
+        #endregion
+        private System.Windows.Forms.DataGridView grdRangeItems;
+        private System.Windows.Forms.Label label1;
+        private System.Windows.Forms.ComboBox cmbProperty;
+        private System.Windows.Forms.Label label2;
+        private System.Windows.Forms.TextBox txtDefaultValue;
+        private System.Windows.Forms.GroupBox groupBox1;
+        private System.Windows.Forms.TextBox txtPreview;
+        private System.Windows.Forms.Button btnRefresh;
+        private System.Windows.Forms.Button btnOK;
+        private System.Windows.Forms.Button btnCancel;
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Editors/Common/Expression/LookupExpressionBuilder.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/Expression/LookupExpressionBuilder.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/Expression/LookupExpressionBuilder.cs	2014-05-06 20:00:53 UTC (rev 8111)
@@ -0,0 +1,82 @@
+#region Disclaimer / License
+// Copyright (C) 2014, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Globalization;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+    internal partial class LookupExpressionBuilder : Form
+        class LookupItem
+            public string Key { get; set; }
+            public string Value { get; set; }
+        private BindingList<LookupItem> _items;
+        private LookupExpressionBuilder()
+            InitializeComponent();
+            _items = new BindingList<LookupItem>();
+            grdRangeItems.DataSource = _items;
+        public LookupExpressionBuilder(string[] propertyNames)
+            : this()
+            cmbProperty.DataSource = propertyNames;
+        public string GetExpression()
+            StringBuilder sb = new StringBuilder();
+            sb.Append("LOOKUP(" + cmbProperty.Text + ", " + txtDefaultValue.Text);
+            foreach (var item in _items)
+                sb.Append(", " + item.Key + ", " + item.Value);
+            sb.Append(")");
+            return sb.ToString();
+        private void btnRefresh_Click(object sender, EventArgs e)
+            txtPreview.Text = this.GetExpression();
+        private void btnOK_Click(object sender, EventArgs e)
+            this.DialogResult = System.Windows.Forms.DialogResult.OK;
+        private void btnCancel_Click(object sender, EventArgs e)
+            this.DialogResult = System.Windows.Forms.DialogResult.Cancel;
Added: trunk/Tools/Maestro/Maestro.Editors/Common/Expression/LookupExpressionBuilder.resx
--- trunk/Tools/Maestro/Maestro.Editors/Common/Expression/LookupExpressionBuilder.resx	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/Expression/LookupExpressionBuilder.resx	2014-05-06 20:00:53 UTC (rev 8111)
@@ -0,0 +1,405 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="grdRangeItems.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Top, Left, Right</value>
+  </data>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <data name="grdRangeItems.Location" type="System.Drawing.Point, System.Drawing">
+    <value>12, 37</value>
+  </data>
+  <data name="grdRangeItems.Size" type="System.Drawing.Size, System.Drawing">
+    <value>503, 141</value>
+  </data>
+  <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="grdRangeItems.TabIndex" type="System.Int32, mscorlib">
+    <value>0</value>
+  </data>
+  <data name=">>grdRangeItems.Name" xml:space="preserve">
+    <value>grdRangeItems</value>
+  </data>
+  <data name=">>grdRangeItems.Type" xml:space="preserve">
+    <value>System.Windows.Forms.DataGridView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>grdRangeItems.Parent" xml:space="preserve">
+    <value>$this</value>
+  </data>
+  <data name=">>grdRangeItems.ZOrder" xml:space="preserve">
+    <value>8</value>
+  </data>
+  <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+    <value>True</value>
+  </data>
+  <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+    <value>12, 13</value>
+  </data>
+  <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+    <value>46, 13</value>
+  </data>
+  <data name="label1.TabIndex" type="System.Int32, mscorlib">
+    <value>1</value>
+  </data>
+  <data name="label1.Text" xml:space="preserve">
+    <value>Property</value>
+  </data>
+  <data name=">>label1.Name" xml:space="preserve">
+    <value>label1</value>
+  </data>
+  <data name=">>label1.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>label1.Parent" xml:space="preserve">
+  </data>
+  <data name=">>label1.ZOrder" xml:space="preserve">
+    <value>7</value>
+  </data>
+  <data name="cmbProperty.Location" type="System.Drawing.Point, System.Drawing">
+    <value>76, 10</value>
+  </data>
+  <data name="cmbProperty.Size" type="System.Drawing.Size, System.Drawing">
+    <value>121, 21</value>
+  </data>
+  <data name="cmbProperty.TabIndex" type="System.Int32, mscorlib">
+    <value>2</value>
+  </data>
+  <data name=">>cmbProperty.Name" xml:space="preserve">
+    <value>cmbProperty</value>
+  </data>
+  <data name=">>cmbProperty.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ComboBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>cmbProperty.Parent" xml:space="preserve">
+  </data>
+  <data name=">>cmbProperty.ZOrder" xml:space="preserve">
+    <value>6</value>
+  </data>
+  <data name="label2.AutoSize" type="System.Boolean, mscorlib">
+  </data>
+  <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
+    <value>214, 13</value>
+  </data>
+  <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+    <value>71, 13</value>
+  </data>
+  <data name="label2.TabIndex" type="System.Int32, mscorlib">
+    <value>3</value>
+  </data>
+  <data name="label2.Text" xml:space="preserve">
+    <value>Default Value</value>
+  </data>
+  <data name=">>label2.Name" xml:space="preserve">
+    <value>label2</value>
+  </data>
+  <data name=">>label2.Type" xml:space="preserve">
+  </data>
+  <data name=">>label2.Parent" xml:space="preserve">
+  </data>
+  <data name=">>label2.ZOrder" xml:space="preserve">
+    <value>5</value>
+  </data>
+  <data name="txtDefaultValue.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+  </data>
+  <data name="txtDefaultValue.Location" type="System.Drawing.Point, System.Drawing">
+    <value>291, 11</value>
+  </data>
+  <data name="txtDefaultValue.Size" type="System.Drawing.Size, System.Drawing">
+    <value>224, 20</value>
+  </data>
+  <data name="txtDefaultValue.TabIndex" type="System.Int32, mscorlib">
+    <value>4</value>
+  </data>
+  <data name=">>txtDefaultValue.Name" xml:space="preserve">
+    <value>txtDefaultValue</value>
+  </data>
+  <data name=">>txtDefaultValue.Type" xml:space="preserve">
+    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>txtDefaultValue.Parent" xml:space="preserve">
+  </data>
+  <data name=">>txtDefaultValue.ZOrder" xml:space="preserve">
+    <value>4</value>
+  </data>
+  <data name="groupBox1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Top, Bottom, Left, Right</value>
+  </data>
+  <data name="txtPreview.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+    <value>Fill</value>
+  </data>
+  <data name="txtPreview.Font" type="System.Drawing.Font, System.Drawing">
+    <value>Courier New, 14.25pt</value>
+  </data>
+  <data name="txtPreview.Location" type="System.Drawing.Point, System.Drawing">
+    <value>3, 16</value>
+  </data>
+  <data name="txtPreview.Multiline" type="System.Boolean, mscorlib">
+  </data>
+  <data name="txtPreview.Size" type="System.Drawing.Size, System.Drawing">
+    <value>497, 160</value>
+  </data>
+  <data name="txtPreview.TabIndex" type="System.Int32, mscorlib">
+    <value>0</value>
+  </data>
+  <data name=">>txtPreview.Name" xml:space="preserve">
+    <value>txtPreview</value>
+  </data>
+  <data name=">>txtPreview.Type" xml:space="preserve">
+  </data>
+  <data name=">>txtPreview.Parent" xml:space="preserve">
+    <value>groupBox1</value>
+  </data>
+  <data name=">>txtPreview.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
+  <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
+    <value>12, 185</value>
+  </data>
+  <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
+    <value>503, 179</value>
+  </data>
+  <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
+    <value>5</value>
+  </data>
+  <data name="groupBox1.Text" xml:space="preserve">
+    <value>Preview</value>
+  </data>
+  <data name=">>groupBox1.Name" xml:space="preserve">
+  </data>
+  <data name=">>groupBox1.Type" xml:space="preserve">
+    <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>groupBox1.Parent" xml:space="preserve">
+  </data>
+  <data name=">>groupBox1.ZOrder" xml:space="preserve">
+    <value>3</value>
+  </data>
+  <data name="btnRefresh.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Bottom, Left</value>
+  </data>
+  <data name="btnRefresh.Location" type="System.Drawing.Point, System.Drawing">
+    <value>18, 370</value>
+  </data>
+  <data name="btnRefresh.Size" type="System.Drawing.Size, System.Drawing">
+    <value>75, 23</value>
+  </data>
+  <data name="btnRefresh.TabIndex" type="System.Int32, mscorlib">
+    <value>1</value>
+  </data>
+  <data name="btnRefresh.Text" xml:space="preserve">
+    <value>Refresh</value>
+  </data>
+  <data name=">>btnRefresh.Name" xml:space="preserve">
+    <value>btnRefresh</value>
+  </data>
+  <data name=">>btnRefresh.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>btnRefresh.Parent" xml:space="preserve">
+  </data>
+  <data name=">>btnRefresh.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
+  <data name="btnOK.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+    <value>Bottom, Right</value>
+  </data>
+  <data name="btnOK.Location" type="System.Drawing.Point, System.Drawing">
+    <value>359, 370</value>
+  </data>
+  <data name="btnOK.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="btnOK.TabIndex" type="System.Int32, mscorlib">
+    <value>6</value>
+  </data>
+  <data name="btnOK.Text" xml:space="preserve">
+    <value>OK</value>
+  </data>
+  <data name=">>btnOK.Name" xml:space="preserve">
+    <value>btnOK</value>
+  </data>
+  <data name=">>btnOK.Type" xml:space="preserve">
+  </data>
+  <data name=">>btnOK.Parent" xml:space="preserve">
+  </data>
+  <data name=">>btnOK.ZOrder" xml:space="preserve">
+    <value>2</value>
+  </data>
+  <data name="btnCancel.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+  </data>
+  <data name="btnCancel.Location" type="System.Drawing.Point, System.Drawing">
+    <value>440, 370</value>
+  </data>
+  <data name="btnCancel.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="btnCancel.TabIndex" type="System.Int32, mscorlib">
+    <value>7</value>
+  </data>
+  <data name="btnCancel.Text" xml:space="preserve">
+    <value>Cancel</value>
+  </data>
+  <data name=">>btnCancel.Name" xml:space="preserve">
+    <value>btnCancel</value>
+  </data>
+  <data name=">>btnCancel.Type" xml:space="preserve">
+  </data>
+  <data name=">>btnCancel.Parent" xml:space="preserve">
+  </data>
+  <data name=">>btnCancel.ZOrder" xml:space="preserve">
+    <value>1</value>
+  </data>
+  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+  </metadata>
+  <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
+    <value>6, 13</value>
+  </data>
+  <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+    <value>527, 405</value>
+  </data>
+  <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+    <value>CenterParent</value>
+  </data>
+  <data name="$this.Text" xml:space="preserve">
+    <value>Lookup Expression Builder</value>
+  </data>
+  <data name=">>$this.Name" xml:space="preserve">
+    <value>LookupExpressionBuilder</value>
+  </data>
+  <data name=">>$this.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+</root>
Added: trunk/Tools/Maestro/Maestro.Editors/Common/Expression/RangeExpressionBuilder.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/Expression/RangeExpressionBuilder.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/Expression/RangeExpressionBuilder.Designer.cs	2014-05-06 20:00:53 UTC (rev 8111)
@@ -0,0 +1,143 @@
+    partial class RangeExpressionBuilder
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+            System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(RangeExpressionBuilder));
+            // grdRangeItems
+            // label1
+            // cmbProperty
+            // label2
+            // groupBox1
+            // txtPreview
+            // btnRefresh
+            // btnOK
+            // btnCancel
+            // RangeExpressionBuilder
+            this.Name = "RangeExpressionBuilder";
+        #endregion
Added: trunk/Tools/Maestro/Maestro.Editors/Common/Expression/RangeExpressionBuilder.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/Expression/RangeExpressionBuilder.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/Expression/RangeExpressionBuilder.cs	2014-05-06 20:00:53 UTC (rev 8111)
@@ -0,0 +1,83 @@
+#endregion
+using System;
+using System.Data;
+using System.Linq;
+using System.Text;
+    internal partial class RangeExpressionBuilder : Form
+        class LookupItem
+            public double Min { get; set; }
+            public double Max { get; set; }
+        private RangeExpressionBuilder()
+        public RangeExpressionBuilder(string[] propertyNames)
+            : this()
+            sb.Append("RANGE(" + cmbProperty.Text + ", " + txtDefaultValue.Text);
+                sb.Append(", " + item.Min.ToString(CultureInfo.InvariantCulture) + ", " + item.Max.ToString(CultureInfo.InvariantCulture) + ", " + item.Value);
+            sb.Append(")");
Added: trunk/Tools/Maestro/Maestro.Editors/Common/Expression/RangeExpressionBuilder.resx
--- trunk/Tools/Maestro/Maestro.Editors/Common/Expression/RangeExpressionBuilder.resx	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/Expression/RangeExpressionBuilder.resx	2014-05-06 20:00:53 UTC (rev 8111)
@@ -0,0 +1,405 @@
+<root>
+    Version 2.0
+    Example:
+    </data>
+    </data>
+    name/value pairs.
+    mimetype set.
+      <xsd:complexType>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+  </resheader>
+  </resheader>
+  </resheader>
+  </resheader>
+  </data>
+  </data>
+  </data>
+    <value>0</value>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>8</value>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>1</value>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>7</value>
+  </data>
+  </data>
+  </data>
+    <value>2</value>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>6</value>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>3</value>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>5</value>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>4</value>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>4</value>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>0</value>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>0</value>
+  </data>
+  </data>
+  </data>
+    <value>5</value>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>3</value>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>1</value>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>0</value>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>6</value>
+  </data>
+    <value>OK</value>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>2</value>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>7</value>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+    <value>1</value>
+  </data>
+  </metadata>
+  </data>
+  </data>
+  </data>
+    <value>Range Expression Builder</value>
+  </data>
+    <value>RangeExpressionBuilder</value>
+  </data>
+  </data>
+</root>
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs	2014-05-06 19:17:12 UTC (rev 8110)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs	2014-05-06 20:00:53 UTC (rev 8111)
@@ -97,7 +97,7 @@
                 m_featureSource = featuresSourceId;
                 _caps = caps;
-                insertThemeExpressionToolStripMenuItem.Enabled = attachStylizationFunctions;
+                btnTools.Enabled = attachStylizationFunctions;
                 SortedList<string, PropertyDefinition> sortedCols = new SortedList<string, PropertyDefinition>();
                 foreach (var col in _cls.Properties)
@@ -432,5 +432,61 @@
             this.InsertText(text);
+        private void insertARGBColorExpressionToolStripMenuItem_Click(object sender, EventArgs e)
+            using (var picker = new ColorDialog())
+                if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+                    var c = picker.Color;
+                    this.InsertText(string.Format("ARGB({0}, {1}, {2}, {3})", c.A, c.R, c.G, c.B));
+        private void insertHTMLCOLORExpressionToolStripMenuItem_Click(object sender, EventArgs e)
+                    this.InsertText(string.Format("HTMLCOLOR({0}, {1}, {2})", c.R, c.G, c.B));
+        private void buildAndInsertLOOKUPExpressionToolStripMenuItem_Click(object sender, EventArgs e)
+            List<string> propNames = new List<string>();
+            foreach (var prop in _cls.Properties)
+                propNames.Add(prop.Name);
+            using (var picker = new LookupExpressionBuilder(propNames.ToArray()))
+                    this.InsertText(picker.GetExpression());
+        private void buildAndInsertRANGEExpressionToolStripMenuItem_Click(object sender, EventArgs e)
+            using (var picker = new RangeExpressionBuilder(propNames.ToArray()))
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.designer.cs	2014-05-06 19:17:12 UTC (rev 8110)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.designer.cs	2014-05-06 20:00:53 UTC (rev 8111)
@@ -44,10 +44,14 @@
             this.ColumnValue = new System.Windows.Forms.ToolStripComboBox();
             this.LookupValues = new System.Windows.Forms.ToolStripButton();
             this.ColumnName = new System.Windows.Forms.ToolStripComboBox();
+            this.btnTools = new System.Windows.Forms.ToolStripDropDownButton();
+            this.insertThemeExpressionToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
             this._autoCompleteTooltip = new System.Windows.Forms.ToolTip(this.components);
             this.ExpressionText = new ICSharpCode.TextEditor.TextEditorControl();
-            this.btnTools = new System.Windows.Forms.ToolStripDropDownButton();
-            this.insertThemeExpressionToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+            this.insertARGBColorExpressionToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+            this.insertHTMLCOLORExpressionToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+            this.buildAndInsertLOOKUPExpressionToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+            this.buildAndInsertRANGEExpressionToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
             this.panel1.SuspendLayout();
             this.toolStrip1.SuspendLayout();
@@ -160,18 +164,14 @@
             this.ColumnName.SelectedIndexChanged += new System.EventHandler(this.ColumnName_SelectedIndexChanged);
             this.ColumnName.Click += new System.EventHandler(this.ColumnName_Click);
-            // ExpressionText
-            resources.ApplyResources(this.ExpressionText, "ExpressionText");
-            this.ExpressionText.IsReadOnly = false;
-            this.ExpressionText.Name = "ExpressionText";
-            this.ExpressionText.ShowLineNumbers = false;
-            this.ExpressionText.ShowVRuler = false;
             // btnTools
             this.btnTools.DropDownItems.AddRange(new System.Windows.Forms.ToolStripItem[] {
-            this.insertThemeExpressionToolStripMenuItem});
+            this.insertThemeExpressionToolStripMenuItem,
+            this.insertARGBColorExpressionToolStripMenuItem,
+            this.insertHTMLCOLORExpressionToolStripMenuItem,
+            this.buildAndInsertLOOKUPExpressionToolStripMenuItem,
+            this.buildAndInsertRANGEExpressionToolStripMenuItem});
             this.btnTools.Image = global::Maestro.Editors.Properties.Resources.gear;
             resources.ApplyResources(this.btnTools, "btnTools");
             this.btnTools.Name = "btnTools";
@@ -182,6 +182,38 @@
             resources.ApplyResources(this.insertThemeExpressionToolStripMenuItem, "insertThemeExpressionToolStripMenuItem");
             this.insertThemeExpressionToolStripMenuItem.Click += new System.EventHandler(this.insertThemeExpressionToolStripMenuItem_Click);
+            // ExpressionText
+            resources.ApplyResources(this.ExpressionText, "ExpressionText");
+            this.ExpressionText.IsReadOnly = false;
+            this.ExpressionText.Name = "ExpressionText";
+            this.ExpressionText.ShowLineNumbers = false;
+            this.ExpressionText.ShowVRuler = false;
+            // insertARGBColorExpressionToolStripMenuItem
+            this.insertARGBColorExpressionToolStripMenuItem.Name = "insertARGBColorExpressionToolStripMenuItem";
+            resources.ApplyResources(this.insertARGBColorExpressionToolStripMenuItem, "insertARGBColorExpressionToolStripMenuItem");
+            this.insertARGBColorExpressionToolStripMenuItem.Click += new System.EventHandler(this.insertARGBColorExpressionToolStripMenuItem_Click);
+            // insertHTMLCOLORExpressionToolStripMenuItem
+            this.insertHTMLCOLORExpressionToolStripMenuItem.Name = "insertHTMLCOLORExpressionToolStripMenuItem";
+            resources.ApplyResources(this.insertHTMLCOLORExpressionToolStripMenuItem, "insertHTMLCOLORExpressionToolStripMenuItem");
+            this.insertHTMLCOLORExpressionToolStripMenuItem.Click += new System.EventHandler(this.insertHTMLCOLORExpressionToolStripMenuItem_Click);
+            // buildAndInsertLOOKUPExpressionToolStripMenuItem
+            this.buildAndInsertLOOKUPExpressionToolStripMenuItem.Name = "buildAndInsertLOOKUPExpressionToolStripMenuItem";
+            resources.ApplyResources(this.buildAndInsertLOOKUPExpressionToolStripMenuItem, "buildAndInsertLOOKUPExpressionToolStripMenuItem");
+            this.buildAndInsertLOOKUPExpressionToolStripMenuItem.Click += new System.EventHandler(this.buildAndInsertLOOKUPExpressionToolStripMenuItem_Click);
+            // buildAndInsertRANGEExpressionToolStripMenuItem
+            this.buildAndInsertRANGEExpressionToolStripMenuItem.Name = "buildAndInsertRANGEExpressionToolStripMenuItem";
+            resources.ApplyResources(this.buildAndInsertRANGEExpressionToolStripMenuItem, "buildAndInsertRANGEExpressionToolStripMenuItem");
+            this.buildAndInsertRANGEExpressionToolStripMenuItem.Click += new System.EventHandler(this.buildAndInsertRANGEExpressionToolStripMenuItem_Click);
             // ExpressionEditor
             this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
@@ -219,5 +251,9 @@
         private ICSharpCode.TextEditor.TextEditorControl ExpressionText;
         private System.Windows.Forms.ToolStripDropDownButton btnTools;
         private System.Windows.Forms.ToolStripMenuItem insertThemeExpressionToolStripMenuItem;
+        private System.Windows.Forms.ToolStripMenuItem insertARGBColorExpressionToolStripMenuItem;
+        private System.Windows.Forms.ToolStripMenuItem insertHTMLCOLORExpressionToolStripMenuItem;
+        private System.Windows.Forms.ToolStripMenuItem buildAndInsertLOOKUPExpressionToolStripMenuItem;
+        private System.Windows.Forms.ToolStripMenuItem buildAndInsertRANGEExpressionToolStripMenuItem;
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.resx
--- trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.resx	2014-05-06 19:17:12 UTC (rev 8110)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.resx	2014-05-06 20:00:53 UTC (rev 8111)
@@ -256,11 +256,35 @@
     <value>Select the column to read values from</value>
   </data>
   <data name="insertThemeExpressionToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
-    <value>201, 22</value>
+    <value>307, 22</value>
   </data>
   <data name="insertThemeExpressionToolStripMenuItem.Text" xml:space="preserve">
-    <value>Insert Theme Expression</value>
+    <value>Insert Theme Expression (via Theme Builder)</value>
   </data>
+  <data name="insertARGBColorExpressionToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="insertARGBColorExpressionToolStripMenuItem.Text" xml:space="preserve">
+    <value>Insert ARGB color expression</value>
+  </data>
+  <data name="insertHTMLCOLORExpressionToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="insertHTMLCOLORExpressionToolStripMenuItem.Text" xml:space="preserve">
+    <value>Insert HTMLCOLOR expression</value>
+  </data>
+  <data name="buildAndInsertLOOKUPExpressionToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="buildAndInsertLOOKUPExpressionToolStripMenuItem.Text" xml:space="preserve">
+    <value>Build and Insert LOOKUP expression</value>
+  </data>
+  <data name="buildAndInsertRANGEExpressionToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="buildAndInsertRANGEExpressionToolStripMenuItem.Text" xml:space="preserve">
+    <value>Build and Insert RANGE expression</value>
+  </data>
   <data name="btnTools.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
     <value>Magenta</value>
   </data>
@@ -295,19 +319,19 @@
     <value>1</value>
   </data>
   <data name="btnCondition.Size" type="System.Drawing.Size, System.Drawing">
-    <value>152, 22</value>
+    <value>127, 22</value>
   </data>
   <data name="btnCondition.Text" xml:space="preserve">
     <value>Condition</value>
   </data>
   <data name="btnSpatial.Size" type="System.Drawing.Size, System.Drawing">
   </data>
   <data name="btnSpatial.Text" xml:space="preserve">
     <value>Spatial</value>
   </data>
   <data name="btnDistance.Size" type="System.Drawing.Size, System.Drawing">
   </data>
   <data name="btnDistance.Text" xml:space="preserve">
     <value>Distance</value>
@@ -414,12 +438,6 @@
   <data name=">>ColumnName.Type" xml:space="preserve">
     <value>System.Windows.Forms.ToolStripComboBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
-  <data name=">>_autoCompleteTooltip.Name" xml:space="preserve">
-    <value>_autoCompleteTooltip</value>
-  </data>
-  <data name=">>_autoCompleteTooltip.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
-  </data>
   <data name=">>btnTools.Name" xml:space="preserve">
     <value>btnTools</value>
   </data>
@@ -432,6 +450,36 @@
   <data name=">>insertThemeExpressionToolStripMenuItem.Type" xml:space="preserve">
     <value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
+  <data name=">>_autoCompleteTooltip.Name" xml:space="preserve">
+    <value>_autoCompleteTooltip</value>
+  </data>
+  <data name=">>_autoCompleteTooltip.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>insertARGBColorExpressionToolStripMenuItem.Name" xml:space="preserve">
+    <value>insertARGBColorExpressionToolStripMenuItem</value>
+  </data>
+  <data name=">>insertARGBColorExpressionToolStripMenuItem.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name=">>insertHTMLCOLORExpressionToolStripMenuItem.Name" xml:space="preserve">
+    <value>insertHTMLCOLORExpressionToolStripMenuItem</value>
+  </data>
+  <data name=">>insertHTMLCOLORExpressionToolStripMenuItem.Type" xml:space="preserve">
+  </data>
+  <data name=">>buildAndInsertLOOKUPExpressionToolStripMenuItem.Name" xml:space="preserve">
+    <value>buildAndInsertLOOKUPExpressionToolStripMenuItem</value>
+  </data>
+  <data name=">>buildAndInsertLOOKUPExpressionToolStripMenuItem.Type" xml:space="preserve">
+  </data>
+  <data name=">>buildAndInsertRANGEExpressionToolStripMenuItem.Name" xml:space="preserve">
+    <value>buildAndInsertRANGEExpressionToolStripMenuItem</value>
+  </data>
+  <data name=">>buildAndInsertRANGEExpressionToolStripMenuItem.Type" xml:space="preserve">
+  </data>
     <value>ExpressionEditor</value>
   </data>
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.Designer.cs	2014-05-06 19:17:12 UTC (rev 8110)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.Designer.cs	2014-05-06 20:00:53 UTC (rev 8111)
@@ -45,10 +45,14 @@
             this.ExpressionText = new System.Windows.Forms.TextBox();
@@ -167,18 +171,14 @@
-            // ExpressionText
-            this.ExpressionText.HideSelection = false;
-            this.ExpressionText.KeyDown += new System.Windows.Forms.KeyEventHandler(this.ExpressionText_KeyDown);
-            this.ExpressionText.KeyUp += new System.Windows.Forms.KeyEventHandler(this.ExpressionText_KeyUp);
             // btnTools
@@ -189,6 +189,38 @@
+            // ExpressionText
+            this.ExpressionText.HideSelection = false;
+            this.ExpressionText.KeyDown += new System.Windows.Forms.KeyEventHandler(this.ExpressionText_KeyDown);
+            this.ExpressionText.KeyUp += new System.Windows.Forms.KeyEventHandler(this.ExpressionText_KeyUp);
             // MonoCompatibleExpressionEditor
@@ -228,5 +260,9 @@
         private System.Windows.Forms.ToolStripDropDownButton btnFunctions;
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.cs	2014-05-06 19:17:12 UTC (rev 8110)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.cs	2014-05-06 20:00:53 UTC (rev 8111)
@@ -31,6 +31,7 @@
 using Maestro.Shared.UI;
 using OSGeo.MapGuide.MaestroAPI.Schema;
 using Maestro.Editors.LayerDefinition.Vector.Thematics;
+using Maestro.Editors.Common.Expression;
@@ -1128,6 +1129,62 @@
     // ImageListBoxItem class
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.resx
--- trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.resx	2014-05-06 19:17:12 UTC (rev 8110)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/MonoCompatibleExpressionEditor.resx	2014-05-06 20:00:53 UTC (rev 8111)
@@ -174,21 +174,6 @@
   <data name=">>CancelBtn.ZOrder" xml:space="preserve">
     <value>1</value>
   </data>
-  <data name="lblHint.AutoSize" type="System.Boolean, mscorlib">
-    <value>True</value>
-  </data>
-  <data name="lblHint.Location" type="System.Drawing.Point, System.Drawing">
-    <value>12, 11</value>
-  </data>
-  <data name="lblHint.Size" type="System.Drawing.Size, System.Drawing">
-    <value>202, 13</value>
-  </data>
-  <data name="lblHint.TabIndex" type="System.Int32, mscorlib">
-    <value>4</value>
-  </data>
-  <data name="lblHint.Text" xml:space="preserve">
-    <value>Press Alt + Right to invoke auto-complete</value>
-  </data>
   <data name=">>lblHint.Name" xml:space="preserve">
     <value>lblHint</value>
   </data>
@@ -225,6 +210,33 @@
   <data name=">>panel1.ZOrder" xml:space="preserve">
     <value>2</value>
   </data>
+  <data name="lblHint.AutoSize" type="System.Boolean, mscorlib">
+  </data>
+  <data name="lblHint.Location" type="System.Drawing.Point, System.Drawing">
+    <value>12, 11</value>
+  </data>
+  <data name="lblHint.Size" type="System.Drawing.Size, System.Drawing">
+    <value>202, 13</value>
+  </data>
+  <data name="lblHint.TabIndex" type="System.Int32, mscorlib">
+    <value>4</value>
+  </data>
+  <data name="lblHint.Text" xml:space="preserve">
+    <value>Press Alt + Right to invoke auto-complete</value>
+  </data>
+  <data name=">>lblHint.Name" xml:space="preserve">
+    <value>lblHint</value>
+  </data>
+  <data name=">>lblHint.Type" xml:space="preserve">
+  </data>
+  <data name=">>lblHint.Parent" xml:space="preserve">
+    <value>panel1</value>
+  </data>
+  <data name=">>lblHint.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
   <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
     <value>17, 17</value>
   </metadata>
@@ -246,24 +258,6 @@
   <data name="btnFunctions.Text" xml:space="preserve">
     <value>Functions</value>
   </data>
-  <data name="btnCondition.Size" type="System.Drawing.Size, System.Drawing">
-    <value>127, 22</value>
-  </data>
-  <data name="btnCondition.Text" xml:space="preserve">
-    <value>Condition</value>
-  </data>
-  <data name="btnSpatial.Size" type="System.Drawing.Size, System.Drawing">
-  </data>
-  <data name="btnSpatial.Text" xml:space="preserve">
-    <value>Spatial</value>
-  </data>
-  <data name="btnDistance.Size" type="System.Drawing.Size, System.Drawing">
-  </data>
-  <data name="btnDistance.Text" xml:space="preserve">
-    <value>Distance</value>
-  </data>
   <data name="btnFilter.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
   </data>
@@ -301,11 +295,35 @@
   </data>
   </data>
   </data>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
   </data>
@@ -339,6 +357,24 @@
   <data name=">>toolStrip1.ZOrder" xml:space="preserve">
     <value>1</value>
   </data>
+  <data name="btnCondition.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="btnCondition.Text" xml:space="preserve">
+    <value>Condition</value>
+  </data>
+  <data name="btnSpatial.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="btnSpatial.Text" xml:space="preserve">
+    <value>Spatial</value>
+  </data>
+  <data name="btnDistance.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="btnDistance.Text" xml:space="preserve">
+    <value>Distance</value>
+  </data>
   <data name="ExpressionText.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
     <value>Fill</value>
   </data>
@@ -447,12 +483,6 @@
   </data>
-  </data>
-  </data>
   </data>
@@ -465,6 +495,36 @@
   </data>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
+  </data>
     <value>MonoCompatibleExpressionEditor</value>
   </data>
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj	2014-05-06 19:17:12 UTC (rev 8110)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj	2014-05-06 20:00:53 UTC (rev 8111)
@@ -120,7 +120,19 @@
     <Compile Include="Common\ExpressionEditor.designer.cs">
       <DependentUpon>ExpressionEditor.cs</DependentUpon>
     </Compile>
+    <Compile Include="Common\Expression\LookupExpressionBuilder.cs">
+      <SubType>Form</SubType>
+    </Compile>
+    <Compile Include="Common\Expression\LookupExpressionBuilder.Designer.cs">
+      <DependentUpon>LookupExpressionBuilder.cs</DependentUpon>
+    </Compile>
     <Compile Include="Common\Expression\FdoExpressionCompletionDataProvider.cs" />
+    <Compile Include="Common\Expression\RangeExpressionBuilder.cs">
+    </Compile>
+    <Compile Include="Common\Expression\RangeExpressionBuilder.Designer.cs">
+      <DependentUpon>RangeExpressionBuilder.cs</DependentUpon>
+    </Compile>
     <Compile Include="Common\FindReplaceDialog.cs">
     </Compile>
@@ -1313,6 +1325,12 @@
       <SubType>Designer</SubType>
     </EmbeddedResource>
+    <EmbeddedResource Include="Common\Expression\LookupExpressionBuilder.resx">
+    </EmbeddedResource>
+    <EmbeddedResource Include="Common\Expression\RangeExpressionBuilder.resx">
     <EmbeddedResource Include="Common\FindReplaceDialog.resx">
       <DependentUpon>FindReplaceDialog.cs</DependentUpon>
     </EmbeddedResource>
More information about the mapguide-commits mailing list
