[mapguide-commits] r8127 - in trunk/Tools/JenkinsCI: home/slave_win/jobs home/slave_win/jobs/FDO 3.9 x64 home/slave_win/jobs/FDO 3.9 x86 home/slave_win/jobs/FDO x64 home/slave_win/jobs/FDO x86 home/slave_win/jobs/Maestro 5.0.x home/slave_win/jobs/Maestro trunk home/slave_win/jobs/MapGuide Open Source 2.6 x64 home/slave_win/jobs/MapGuide Open Source 2.6 x86 home/slave_win/jobs/MapGuide Open Source x64 home/slave_win/jobs/MapGuide Open Source x86 tools
svn_mapguide at osgeo.org
Mon May 12 05:31:52 PDT 2014
Author: jng
Date: 2014-05-12 05:31:52 -0700 (Mon, 12 May 2014)
New Revision: 8127
Added:
trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 3.9 x64/
trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 3.9 x64/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 3.9 x86/
trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 3.9 x86/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x64/
trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x64/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x86/
trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x86/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x86/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro 5.0.x/
trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/
trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/config.xml
trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/config.xml
trunk/Tools/JenkinsCI/tools/setrevnums.bat
trunk/Tools/JenkinsCI/tools/svnupdate.bat
This is the Jenkins configuration used to produce the MapGuide 2.6 beta 1 release and Maestro 6.0a1 release.
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 3.9 x64
___________________________________________________________________
Added: svn:ignore
+ builds
lastStable
lastSuccessful
nextBuildNumber
workspace
Added: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 3.9 x64/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 3.9 x64/config.xml (rev 0)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 3.9 x64/config.xml 2014-05-12 12:31:52 UTC (rev 8127)
@@ -0,0 +1,185 @@
+<?xml version='1.0' encoding='UTF-8'?>
+<project>
+ <actions/>
+ <description></description>
+ <logRotator class="hudson.tasks.LogRotator">
+ <daysToKeep>-1</daysToKeep>
+ <numToKeep>1</numToKeep>
+ <artifactDaysToKeep>-1</artifactDaysToKeep>
+ <artifactNumToKeep>-1</artifactNumToKeep>
+ </logRotator>
+ <keepDependencies>false</keepDependencies>
+ <properties>
+ <hudson.model.ParametersDefinitionProperty>
+ <parameterDefinitions>
+ <hudson.model.StringParameterDefinition>
+ <name>FDO_BUILD_SRC64</name>
+ <description>FDO Source directory</description>
+ <defaultValue>C:\working\sources\fdo-3.9</defaultValue>
+ </hudson.model.StringParameterDefinition>
+ <name>FDO_VERSION64</name>
+ <description>FDO Version Number (major.minor.rev)</description>
+ <defaultValue>3.9.0</defaultValue>
+ <hudson.model.BooleanParameterDefinition>
+ <name>CLEAR_WORKING_AREA</name>
+ <defaultValue>true</defaultValue>
+ </hudson.model.BooleanParameterDefinition>
+ <name>FDO_STAMP_FILE_SOURCE64</name>
+ <defaultValue>C:\working\sources\fdo_39_revision.txt</defaultValue>
+ <name>FDO_RUN_UNIT_TESTS64</name>
+ </parameterDefinitions>
+ </hudson.model.ParametersDefinitionProperty>
+ </properties>
+ <scm class="hudson.scm.NullSCM"/>
+ <canRoam>true</canRoam>
+ <disabled>false</disabled>
+ <blockBuildWhenDownstreamBuilding>false</blockBuildWhenDownstreamBuilding>
+ <blockBuildWhenUpstreamBuilding>false</blockBuildWhenUpstreamBuilding>
+ <jdk>(Default)</jdk>
+ <triggers/>
+ <concurrentBuild>false</concurrentBuild>
+ <builders>
+ <hudson.tasks.BatchFile>
+ <command>@echo off
+SET FDOMYSQL=%MG_LIB_ROOT%\fdo_rdbms_thirdparty\mysql_x64
+SET FDOORACLE=%MG_LIB_ROOT%\fdo_rdbms_thirdparty\oracle_x64\instantclient\11.2\sdk
+SET FDOPOSTGRESQL=%MG_LIB_ROOT%\fdo_rdbms_thirdparty\pgsql
+SET FDO_BUILD_OUTPUT64=%MG_BUILD_ARTIFACT_PATH%\fdo\%FDO_VERSION64%\x64
+SET FDO_BIN_EXTRAS64=%MG_LIB_ROOT%\fdo_extras\%FDO_VERSION64%\x64
+SET REVNUM_FILE64=%MG_TOOL_PATH%\revnum.pl
+SET FDO_STAMP_FILE64=%MG_BUILD_ARTIFACT_PATH%\last_fdo_%FDO_VERSION64%_revision_x64.txt
+SET FDO_WORKING_AREA64=%MG_BUILD_AREA%\FDO\%FDO_VERSION64%\x64
+echo ============ Env Vars for FDO Build =====================
+echo FDOMYSQL = %FDOMYSQL%
+echo FDOORACLE = %FDOORACLE%
+echo FDOPOSTGRESQL = %FDOPOSTGRESQL%
+echo FDO_BUILD_OUTPUT64 = %FDO_BUILD_OUTPUT64%
+echo FDO_BIN_EXTRAS64 = %FDO_BIN_EXTRAS64%
+echo REVNUM_FILE64 = %REVNUM_FILE64%
+echo FDO_STAMP_FILE64 = %FDO_STAMP_FILE64%
+echo FDO_WORKING_AREA64 = %FDO_WORKING_AREA64%
+echo =========================================================
+REM Pre-build checks, nuke artifact dir and working area
+echo [prepare]: Clean out build area and build artifacts
+if exist %FDO_BUILD_OUTPUT64% rd /S /Q %FDO_BUILD_OUTPUT64%
+if "%CLEAR_WORKING_AREA%"=="false" (
+ echo [prepare]: Skip cleaning build area
+ goto build_fdo
+if exist %FDO_WORKING_AREA64% rd /S /Q %FDO_WORKING_AREA64%
+if not exist %FDO_WORKING_AREA64% mkdir %FDO_WORKING_AREA64%
+REM Need to supply --force otherwise it won't export into the dir we made
+echo [prepare]: Exporting SVN working copy to build area
+SET BUILD_ACTION=Exporting SVN working copy to build area
+svn export %FDO_BUILD_SRC64% %FDO_WORKING_AREA64% --force
+if "%errorlevel%"=="1" goto error
+REM Copy non-UAC UpdateVersion
+echo [prepare]: Copy non UAC-gimped UpdateVersion
+SET BUILD_ACTION=Copy non UAC-gimped UpdateVersion
+copy /Y %MG_TOOL_PATH%\UpdateVersion.exe %FDO_WORKING_AREA64%\Thirdparty\util\UpdateVersion\bin
+:build_fdo
+echo [prepare]: Noting SVN revision
+set /p REVISION= < "%FDO_STAMP_FILE_SOURCE64%"
+copy /Y "%FDO_STAMP_FILE_SOURCE64%" "%FDO_STAMP_FILE64%"
+REM Need to use x86_amd64 because the 64-bit compiler in VS 2012 express is a cross-compiler
+pushd %FDO_WORKING_AREA64%
+echo [build]: Set env vars
+call setenvironment.bat x86_amd64
+echo [build]: build thirdparty
+SET BUILD_ACTION=Build FDO Thirdparty
+call build_thirdparty.bat -p=x64 -a=buildinstall -o=%FDO_BUILD_OUTPUT64%
+echo [build]: build core and providers
+SET BUILD_ACTION=Build FDO core/providers
+call build.bat -p=x64 -a=buildinstall -o=%FDO_BUILD_OUTPUT64%
+if not exist %FDO_BIN_EXTRAS64% goto pack
+echo [build]: Overlaying FDO extras to build artifacts
+pushd %FDO_BIN_EXTRAS64%
+copy /Y *.* %FDO_BUILD_OUTPUT64%\Fdo\Bin
+popd
+:pack
+echo [build]: Pack files
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=fdo -b=%REVISION% -r=%FDO_VERSION_64%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=shp -b=%REVISION% -r=%FDO_VERSION_64%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=sdf -b=%REVISION% -r=%FDO_VERSION_64%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=wfs -b=%REVISION% -r=%FDO_VERSION_64%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=wms -b=%REVISION% -r=%FDO_VERSION_64%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=rdbms -b=%REVISION% -r=%FDO_VERSION_64%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=mysql -b=%REVISION% -r=%FDO_VERSION_64%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=odbc -b=%REVISION% -r=%FDO_VERSION_64%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=sqlspatial -b=%REVISION% -r=%FDO_VERSION_64%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=gdal -b=%REVISION% -r=%FDO_VERSION_64%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=kingoracle -b=%REVISION% -r=%FDO_VERSION_64%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=ogr -b=%REVISION% -r=%FDO_VERSION_64%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT64%\Fdo -o=%FDO_BUILD_OUTPUT64%\dist -w=sqlite -b=%REVISION% -r=%FDO_VERSION_64%
+popd
+if "%FDO_RUN_UNIT_TESTS64%"=="false" goto end
+:fdo_unit_tests
+pushd %FDO_WORKING_AREA64%\Fdo\Unmanaged\Bin\Win64\Release
+UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\fdocore_unittest.log
+popd
+pushd %FDO_WORKING_AREA64%\Providers\SHP\Src\UnitTest
+..\..\Bin\Win64\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT64%\shp_unittest.log
+popd
+pushd %FDO_WORKING_AREA64%\Providers\SDF\Src\UnitTest
+..\..\Bin\Win64\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT64%\sdf_unittest.log
+popd
+pushd %FDO_WORKING_AREA64%\Providers\SQLite\Src\UnitTest
+..\..\Bin\Win64\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT64%\sqlite_unittest.log
+popd
+pushd %FDO_WORKING_AREA64%\Providers\GDAL\Src\UnitTest
+..\..\Bin\Win64\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT64%\gdal_unittest.log
+popd
+pushd %FDO_WORKING_AREA64%\Providers\WMS\Src\UnitTest
+..\..\Bin\Win64\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT64%\wms_unittest.log
+popd
+goto end
+:error
+echo An error occurred while building FDO: %BUILD_ACTION%
+exit /b 1
+:end
+exit /b 0</command>
+ </hudson.tasks.BatchFile>
+ </builders>
+ <publishers>
+ <hudson.plugins.textfinder.TextFinderPublisher plugin="text-finder at 1.10">
+ <regexp>!!!FAILURES!!!</regexp>
+ <succeedIfFound>false</succeedIfFound>
+ <unstableIfFound>true</unstableIfFound>
+ <alsoCheckConsoleOutput>true</alsoCheckConsoleOutput>
+ </hudson.plugins.textfinder.TextFinderPublisher>
+ <hudson.tasks.BuildTrigger>
+ <childProjects>MapGuide Open Source 2.6 x64</childProjects>
+ <threshold>
+ <name>UNSTABLE</name>
+ <ordinal>1</ordinal>
+ <color>YELLOW</color>
+ <completeBuild>true</completeBuild>
+ </threshold>
+ </hudson.tasks.BuildTrigger>
+ </publishers>
+ <buildWrappers/>
+</project>
\ No newline at end of file
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 3.9 x86
Added: svn:ignore
+ builds
lastStable
lastSuccessful
nextBuildNumber
workspace
Added: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 3.9 x86/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 3.9 x86/config.xml (rev 0)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO 3.9 x86/config.xml 2014-05-12 12:31:52 UTC (rev 8127)
@@ -0,0 +1,185 @@
+<project>
+ <actions/>
+ </logRotator>
+ <properties>
+ <name>FDO_BUILD_SRC</name>
+ <name>FDO_VERSION</name>
+ <name>FDO_STAMP_FILE_SOURCE</name>
+ <name>FDO_RUN_UNIT_TESTS</name>
+ </properties>
+ <triggers/>
+ <builders>
+SET FDOORACLE=%MG_LIB_ROOT%\fdo_rdbms_thirdparty\oracle\instantclient\11.2\sdk
+SET FDO_BUILD_OUTPUT=%MG_BUILD_ARTIFACT_PATH%\fdo\%FDO_VERSION%\x86
+SET FDO_BIN_EXTRAS=%MG_LIB_ROOT%\fdo_extras\%FDO_VERSION%\x86
+SET REVNUM_FILE=%MG_TOOL_PATH%\revnum.pl
+SET FDO_STAMP_FILE=%MG_BUILD_ARTIFACT_PATH%\last_fdo_%FDO_VERSION%_revision_x86.txt
+SET FDO_WORKING_AREA=%MG_BUILD_AREA%\FDO\%FDO_VERSION%\x86
+echo FDO_BUILD_OUTPUT = %FDO_BUILD_OUTPUT%
+echo FDO_BIN_EXTRAS = %FDO_BIN_EXTRAS%
+echo REVNUM_FILE = %REVNUM_FILE%
+echo FDO_STAMP_FILE = %FDO_STAMP_FILE%
+echo FDO_WORKING_AREA = %FDO_WORKING_AREA%
+if exist %FDO_BUILD_OUTPUT% rd /S /Q %FDO_BUILD_OUTPUT%
+ goto build_fdo
+if exist %FDO_WORKING_AREA% rd /S /Q %FDO_WORKING_AREA%
+if not exist %FDO_WORKING_AREA% mkdir %FDO_WORKING_AREA%
+svn export %FDO_BUILD_SRC% %FDO_WORKING_AREA% --force
+copy /Y %MG_TOOL_PATH%\UpdateVersion.exe %FDO_WORKING_AREA%\Thirdparty\util\UpdateVersion\bin
+:build_fdo
+set /p REVISION= < "%FDO_STAMP_FILE_SOURCE%"
+copy /Y "%FDO_STAMP_FILE_SOURCE%" "%FDO_STAMP_FILE%"
+pushd %FDO_WORKING_AREA%
+call build_thirdparty.bat -p=Win32 -a=buildinstall -o=%FDO_BUILD_OUTPUT%
+call build.bat -p=Win32 -a=buildinstall -o=%FDO_BUILD_OUTPUT%
+if not exist %FDO_BIN_EXTRAS% goto pack
+pushd %FDO_BIN_EXTRAS%
+copy /Y *.* %FDO_BUILD_OUTPUT%\Fdo\Bin
+popd
+:pack
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=fdo -b=%REVISION% -r=%FDO_VERSION%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=shp -b=%REVISION% -r=%FDO_VERSION%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=sdf -b=%REVISION% -r=%FDO_VERSION%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=wfs -b=%REVISION% -r=%FDO_VERSION%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=wms -b=%REVISION% -r=%FDO_VERSION%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=rdbms -b=%REVISION% -r=%FDO_VERSION%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=mysql -b=%REVISION% -r=%FDO_VERSION%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=odbc -b=%REVISION% -r=%FDO_VERSION%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=sqlspatial -b=%REVISION% -r=%FDO_VERSION%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=gdal -b=%REVISION% -r=%FDO_VERSION%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=kingoracle -b=%REVISION% -r=%FDO_VERSION%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=ogr -b=%REVISION% -r=%FDO_VERSION%
+rem call createtarzipbinfiles.bat -i=%FDO_BUILD_OUTPUT%\Fdo -o=%FDO_BUILD_OUTPUT%\dist -w=sqlite -b=%REVISION% -r=%FDO_VERSION%
+popd
+if "%FDO_RUN_UNIT_TESTS%"=="false" goto end
+:fdo_unit_tests
+pushd %FDO_WORKING_AREA%\Fdo\Unmanaged\Bin\Win32\Release
+popd
+pushd %FDO_WORKING_AREA%\Providers\SHP\Src\UnitTest
+..\..\Bin\Win32\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\shp_unittest.log
+popd
+pushd %FDO_WORKING_AREA%\Providers\SDF\Src\UnitTest
+..\..\Bin\Win32\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\sdf_unittest.log
+popd
+pushd %FDO_WORKING_AREA%\Providers\SQLite\Src\UnitTest
+..\..\Bin\Win32\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\sqlite_unittest.log
+popd
+pushd %FDO_WORKING_AREA%\Providers\GDAL\Src\UnitTest
+..\..\Bin\Win32\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\gdal_unittest.log
+popd
+pushd %FDO_WORKING_AREA%\Providers\WMS\Src\UnitTest
+..\..\Bin\Win32\Release\UnitTest.exe -NoWAIT > %FDO_BUILD_OUTPUT%\wms_unittest.log
+popd
+goto end
+:error
+exit /b 1
+:end
+ </builders>
+ <publishers>
+ <childProjects>MapGuide Open Source 2.6 x86</childProjects>
+ <threshold>
+ </threshold>
+ </publishers>
+ <buildWrappers/>
+</project>
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/config.xml 2014-05-12 12:28:54 UTC (rev 8126)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x64/config.xml 2014-05-12 12:31:52 UTC (rev 8127)
@@ -20,7 +20,7 @@
- <defaultValue>3.9.0</defaultValue>
+ <defaultValue>3.10.0</defaultValue>
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x86/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x86/config.xml 2014-05-12 12:28:54 UTC (rev 8126)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/FDO x86/config.xml 2014-05-12 12:31:52 UTC (rev 8127)
@@ -20,7 +20,7 @@
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro 5.0.x
Modified: svn:ignore
- builds
lastStable
lastSuccessful
nextBuildNumber
scm-polling.log
svnexternals.txt
+ builds
lastStable
lastSuccessful
nextBuildNumber
scm-polling.log
svnexternals.txt
workspace
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk
- builds
lastStable
lastSuccessful
nextBuildNumber
scm-polling.log
svnexternals.txt
+ builds
lastStable
lastSuccessful
nextBuildNumber
scm-polling.log
svnexternals.txt
workspace
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml 2014-05-12 12:28:54 UTC (rev 8126)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/Maestro trunk/config.xml 2014-05-12 12:31:52 UTC (rev 8127)
@@ -15,15 +15,21 @@
<name>VersionLabel</name>
<description>The release version label</description>
- <defaultValue>5.1</defaultValue>
+ <defaultValue>6.0a2</defaultValue>
+ <name>BASE_VERSION</name>
+ <defaultValue>6.0.0</defaultValue>
</properties>
- <scm class="hudson.scm.SubversionSCM" plugin="subversion at 1.48">
+ <scm class="hudson.scm.SubversionSCM" plugin="subversion at 2.3">
<locations>
<hudson.scm.SubversionSCM_-ModuleLocation>
<remote>http://svn.osgeo.org/mapguide/trunk/Tools/Maestro</remote>
+ <credentialsId></credentialsId>
<local>.</local>
<depthOption>infinity</depthOption>
<ignoreExternalsOption>false</ignoreExternalsOption>
@@ -43,7 +49,7 @@
- <triggers class="vector">
+ <triggers>
<hudson.triggers.SCMTrigger>
<spec>15 * * * *</spec>
<ignorePostCommitHooks>false</ignorePostCommitHooks>
@@ -56,18 +62,19 @@
rd /S /Q out
popd
pushd "%WORKSPACE%\Properties"
-%MG_TOOL_PATH%\SetAssemblyVersion.exe -set:5.1.0.%SVN_REVISION% GlobalAssemblyInfo.cs
+%MG_TOOL_PATH%\SetAssemblyVersion.exe -set:%BASE_VERSION%.%SVN_REVISION% GlobalAssemblyInfo.cs
popd
pushd "%WORKSPACE%\SDK"
rd /S /Q bin
popd</command>
- <hudson.plugins.msbuild.MsBuildBuilder plugin="msbuild at 1.17">
+ <hudson.plugins.msbuild.MsBuildBuilder plugin="msbuild at 1.21">
<msBuildName>MSBUILD 4.0 x86</msBuildName>
<msBuildFile>Maestro\Maestro_All.sln</msBuildFile>
<cmdLineArgs>/p:Configuration=Release</cmdLineArgs>
<buildVariablesAsProperties>true</buildVariablesAsProperties>
<continueOnBuildFailure>false</continueOnBuildFailure>
+ <unstableIfWarnings>false</unstableIfWarnings>
</hudson.plugins.msbuild.MsBuildBuilder>
<command>pushd "%WORKSPACE%\out\Release\AddIns"
@@ -103,12 +110,13 @@
7z a -tzip -mx9 "%MG_BUILD_ARTIFACT_PATH%\maestro\MapGuideMaestro-%VersionLabel%-Release.zip" .
popd</command>
<msBuildFile>Doc\MaestroAPI.shfbproj</msBuildFile>
<cmdLineArgs></cmdLineArgs>
<command>pushd "%WORKSPACE%\Doc\Help"
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x64
Added: svn:ignore
+ builds
lastStable
lastSuccessful
nextBuildNumber
workspace
Added: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x64/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x64/config.xml (rev 0)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x64/config.xml 2014-05-12 12:31:52 UTC (rev 8127)
@@ -0,0 +1,322 @@
+<project>
+ <actions/>
+ </logRotator>
+ <properties>
+ <name>RELEASE_LABEL64</name>
+ <defaultValue>Beta1</defaultValue>
+ <name>WITH_ARCSDE</name>
+ <defaultValue>yes</defaultValue>
+ <name>MG_VER_MAJOR</name>
+ <defaultValue>2</defaultValue>
+ <name>MG_VER_MINOR</name>
+ <defaultValue>6</defaultValue>
+ <name>MG_VER_BUILD</name>
+ <defaultValue>0</defaultValue>
+ <name>MG_BUILD_SRC64</name>
+ <defaultValue>C:\working\sources\mg-2.6</defaultValue>
+ <name>FDO_SRC64</name>
+ <defaultValue>C:\builds\fdo\3.9.0\x64\Fdo</defaultValue>
+ <name>INSTANT_SETUP_SRC</name>
+ <defaultValue>C:\working\sources\MgInstantSetup</defaultValue>
+ <name>MG_STAMP_FILE_SOURCE64</name>
+ <defaultValue>C:\working\sources\mapguide_26_revision.txt</defaultValue>
+ <name>MG_RUN_UNIT_TESTS64</name>
+ </properties>
+ <jdk>JDK6 64-bit</jdk>
+ <triggers/>
+ <builders>
+SET BUILD_ACTION=Setting Visual Studio env vars
+SET VCBEXTENSION=_vs12
+SET VC_COMPILER=vc110
+SET ACTIVENAMECHECK="Microsoft Visual Studio 11"
+SET ACTIVEPATHCHECK="C:\Program Files\Microsoft Visual Studio 11.0\VC"
+if exist %ACTIVEPATHCHECK% goto VSExist
+SET ACTIVEPATHCHECK="C:\Program Files (x86)\Microsoft Visual Studio 11.0\VC"
+goto error
+REM Use x86_amd64 because 64-bit compiler in VS2012 express is a cross-compiler
+:VSExist
+call %ACTIVEPATHCHECK%\vcvarsall.bat x86_amd64
+REM Sigh! We can't seem to reference this from Jenkins
+SET MSBUILD_NET40=C:\Windows\Microsoft.NET\Framework\v4.0.30319\msbuild.exe
+SET MG_VER_MAJOR_MINOR=%MG_VER_MAJOR%.%MG_VER_MINOR%
+SET MG_VER_MAJOR_MINOR_BUILD=%MG_VER_MAJOR_MINOR%.%MG_VER_BUILD%
+SET MG_BUILD_OUTPUT_ROOT64=%MG_BUILD_ARTIFACT_PATH%\mapguide
+SET MG_BUILD_OUTPUT64=%MG_BUILD_OUTPUT_ROOT64%\%MG_VER_MAJOR_MINOR_BUILD%\x64\release
+SET MG_BUILD_AREA64=%MG_BUILD_AREA%\mapguide\%MG_VER_MAJOR_MINOR_BUILD%\x64
+SET MG_STAMP_FILE64=%MG_BUILD_ARTIFACT_PATH%\last_mapguide_%MG_VER_MAJOR_MINOR_BUILD%_revision_x64.txt
+SET BUILD_ACTION=
+echo =================== Env Vars for MapGuide =============================
+echo MG_VER_MAJOR_MINOR = %MG_VER_MAJOR_MINOR%
+echo MG_VER_MAJOR_MINOR_BUILD = %MG_VER_MAJOR_MINOR_BUILD%
+echo MG_BUILD_OUTPUT_ROOT64 = %MG_BUILD_OUTPUT_ROOT64%
+echo MG_BUILD_OUTPUT64 = %MG_BUILD_OUTPUT64%
+echo MG_BUILD_AREA64 = %MG_BUILD_AREA64%
+echo MG_STAMP_FILE64 = %MG_STAMP_FILE64%
+echo INSTANT_SETUP_SRC = %INSTANT_SETUP_SRC%
+echo JAVA_HOME = %JAVA_HOME%
+echo ANT_HOME = %ANT_HOME%
+echo MG_RUN_UNIT_TESTS64 = %MG_RUN_UNIT_TESTS64%
+echo =======================================================================
+echo [prepare]: Cleaning out build artifacts
+if exist %MG_BUILD_OUTPUT64% rd /S /Q %MG_BUILD_OUTPUT64%
+set /p MG_REVISION64= < "%MG_STAMP_FILE_SOURCE64%"
+copy /Y "%MG_STAMP_FILE_SOURCE64%" "%MG_STAMP_FILE64%"
+ goto build_mapguide
+echo [prepare]: Cleaning out build area
+if exist %MG_BUILD_AREA64% rd /S /Q %MG_BUILD_AREA64%
+echo [prepare]: Re-creating output directories
+if not exist %MG_BUILD_AREA64%\Installer mkdir %MG_BUILD_AREA64%\Installer
+if not exist %MG_BUILD_AREA64%\MgDev mkdir %MG_BUILD_AREA64%\MgDev
+if not exist %MG_BUILD_ARTIFACT_PATH%\mg-desktop mkdir %MG_BUILD_ARTIFACT_PATH%\mg-desktop
+echo [prepare]: Exporting SVN working copy to build area (Installer)
+SET BUILD_ACTION=Exporting SVN working copy to build area (Installer)
+svn export %MG_BUILD_SRC64%\Installer %MG_BUILD_AREA64%\Installer --force -q
+echo [prepare]: Copying SVN working copy to build area (MgDev)
+SET BUILD_ACTION=Copying SVN working copy to build area (MgDev)
+svn export %MG_BUILD_SRC64%\MgDev %MG_BUILD_AREA64%\MgDev --force -q
+echo [prepare]: Setup FDO in Oem
+cd %MG_BUILD_AREA64%\MgDev\Oem\FDO
+xcopy /S /Y /I %FDO_SRC64%\Inc Inc
+xcopy /S /Y /I %FDO_SRC64%\Lib Lib64
+xcopy /S /Y /I %FDO_SRC64%\Bin Bin\Release64
+xcopy /S /Y /I %FDO_SRC64%\Bin\com\*.* Bin\Release64\com
+REM For release we don't want pdbs and .net assemblies
+cd %MG_BUILD_AREA64%\MgDev\Oem\FDO\Bin\Release64
+del /Q OSGeo.FDO.*
+del /Q *.pdb
+:build_mapguide
+echo [build]: Stamp version numbers
+SET BUILD_ACTION=Stamp version numbers
+cscript updateversion.vbs /major:%MG_VER_MAJOR% /minor:%MG_VER_MINOR% /point:%MG_VER_BUILD% /build:%MG_REVISION64%
+call stampassemblies.bat %MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%
+REM ========================================= MapGuide ====================================================
+call setenvironment64.bat
+echo [build]: build oem/server/web
+SET BUILD_ACTION=build oem/server/web
+call build.bat
+echo [build]: install files to build artifact directory
+SET BUILD_ACTION=install files to build artifact directory
+call build.bat -a=install -o=%MG_BUILD_OUTPUT64%
+REM Move fusion-selfbuild tools out of staging area
+pushd %MG_BUILD_OUTPUT64%\fusion-selfbuild
+move /Y fusion-buildtools.zip %MG_BUILD_OUTPUT_ROOT64%
+popd
+rd /S /Q fusion-selfbuild
+popd
+REM ========================================= mg-desktop ====================================================
+:build_mgdesktop
+REM HACK: mg-desktop batch files not aware of new output dir so set old one
+SET MG_OUTPUT=%MG_BUILD_AREA64%\MgDev\Release64
+pushd %MG_BUILD_AREA64%\MgDev
+echo [build]: mg-desktop
+SET BUILD_ACTION=Build mg-desktop
+call build_desktop.bat x64
+popd
+pushd %MG_BUILD_AREA64%\MgDev\nuget
+echo [clean]: Nuget package temp files
+call package_clean.bat
+popd
+echo [build]: Nuget packages
+call nuget_prepare.bat %MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64% x64
+SET BUILD_ACTION=Nuget packages
+call nuget_pack.bat x64
+popd
+echo [build]: Copy mg-desktop build artifacts (NuGet packages)
+set BUILD_ACTION=Copy mg-desktop build artifacts (NuGet packages)
+move *.nupkg %MG_BUILD_ARTIFACT_PATH%\mg-desktop
+popd
+pushd %MG_BUILD_AREA64%\MgDev\Release64
+echo [build]: Copy mg-desktop build artifacts (zip dist)
+SET BUILD_ACTION=Copy mg-desktop build artifacts (zip dist)
+7z a -mx9 %MG_BUILD_ARTIFACT_PATH%\mg-desktop\mg-desktop-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%-net40-vc11-x64.zip Desktop DesktopSamples
+popd
+REM ========================================= Instant Setup =========================================================
+pushd %MG_BUILD_AREA64%\Installer
+echo [build]: Prepare artifact directory
+SET BUILD_ACTION=Prepare artifact directory
+call build.bat -a=prepare -source=%MG_BUILD_OUTPUT64%
+popd
+if not exist %INSTANT_SETUP_SRC% goto checkout_instantsetup
+goto update_instantsetup
+:checkout_instantsetup
+echo [build]: svn checkout MgInstantSetup
+SET BUILD_ACTION=svn checkout MgInstantSetup
+svn co %INSTANT_SETUP_SVN_URL% %INSTANT_SETUP_SRC%
+goto build_instantsetup
+:update_instantsetup
+REM We'll allow this to fail
+echo [build]: svn update MgInstantSetup
+pushd %INSTANT_SETUP_SRC%
+svn update
+popd
+:build_instantsetup
+echo [build]: MgInstantSetup
+SET BUILD_ACTION=Building MgInstantSetup
+%MSBUILD_NET40% /p:Configuration=Release;Platform="Any CPU" MgInstantSetup.sln
+popd
+:copy_instantsetup_build_artifacts
+echo [build]: Copy MgInstantSetup build artifacts
+if not exist %MG_BUILD_OUTPUT64%\Setup mkdir %MG_BUILD_OUTPUT64%\Setup
+pushd %INSTANT_SETUP_SRC%\InstantSetup\bin\release
+copy /Y *.exe %MG_BUILD_OUTPUT64%\Setup
+copy /Y *.pdb %MG_BUILD_OUTPUT64%\Setup
+copy /Y *.dll %MG_BUILD_OUTPUT64%\Setup
+copy /Y *.config %MG_BUILD_OUTPUT64%\Setup
+popd
+:zip_mginstantsetup
+7z a %MG_BUILD_OUTPUT_ROOT64%\MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%-InstantSetup-x64.exe -mmt -mx5 -sfx7z.sfx .
+popd
+REM ========================================= MapGuide Installer ====================================================
+:build_installer
+echo [build]: Generate installer file listings
+SET BUILD_ACTION=Generate installer file listings
+call build.bat -a=generate -source=%MG_BUILD_OUTPUT64%
+echo [build]: Build the installer
+SET BUILD_ACTION=Build the installer
+call build.bat -source=%MG_BUILD_OUTPUT64% -version=%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64% -name=MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%-%RELEASE_LABEL64%-x64 -title="MapGuide Open Source %MG_VER_MAJOR_MINOR_BUILD% %RELEASE_LABEL64%"
+move /Y Output\en-US\MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION64%-%RELEASE_LABEL64%-x64.exe %MG_BUILD_OUTPUT_ROOT64%
+popd
+if "%MG_RUN_UNIT_TESTS64%"=="false" goto end
+:server_unit_test
+pushd %MG_BUILD_AREA64%\MgDev\Server\bin\Release64
+mgserver.exe test
+popd
+goto end
+:error
+echo An error occurred while building MapGuide: %BUILD_ACTION%
+exit /b 1
+:end
+ </builders>
+ <publishers>
+ </publishers>
+ <buildWrappers/>
+</project>
Property changes on: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x86
Added: svn:ignore
+ builds
lastStable
lastSuccessful
nextBuildNumber
workspace
Added: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x86/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x86/config.xml (rev 0)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source 2.6 x86/config.xml 2014-05-12 12:31:52 UTC (rev 8127)
@@ -0,0 +1,322 @@
+<project>
+ <actions/>
+ </logRotator>
+ <properties>
+ <name>RELEASE_LABEL</name>
+ <name>MG_BUILD_SRC</name>
+ <name>FDO_SRC</name>
+ <defaultValue>C:\builds\fdo\3.9.0\x86\Fdo</defaultValue>
+ <name>MG_STAMP_FILE_SOURCE</name>
+ <name>MG_RUN_UNIT_TESTS</name>
+ </properties>
+ <jdk>JDK6 32-bit</jdk>
+ <triggers/>
+ <builders>
+goto error
+:VSExist
+SET MG_BUILD_OUTPUT_ROOT=%MG_BUILD_ARTIFACT_PATH%\mapguide
+SET MG_BUILD_OUTPUT=%MG_BUILD_OUTPUT_ROOT%\%MG_VER_MAJOR_MINOR_BUILD%\x86\release
+SET MG_BUILD_AREA=%MG_BUILD_AREA%\mapguide\%MG_VER_MAJOR_MINOR_BUILD%\x86
+SET MG_STAMP_FILE=%MG_BUILD_ARTIFACT_PATH%\last_mapguide_%MG_VER_MAJOR_MINOR_BUILD%_revision_x86.txt
+SET BUILD_ACTION=
+echo MG_BUILD_OUTPUT_ROOT = %MG_BUILD_OUTPUT_ROOT%
+echo MG_BUILD_OUTPUT = %MG_BUILD_OUTPUT%
+echo MG_BUILD_AREA = %MG_BUILD_AREA%
+echo MG_STAMP_FILE = %MG_STAMP_FILE%
+echo MG_RUN_UNIT_TESTS = %MG_RUN_UNIT_TESTS%
+if exist %MG_BUILD_OUTPUT% rd /S /Q %MG_BUILD_OUTPUT%
+set /p MG_REVISION= < "%MG_STAMP_FILE_SOURCE%"
+copy /Y "%MG_STAMP_FILE_SOURCE%" "%MG_STAMP_FILE%"
+if exist %MG_BUILD_AREA% rd /S /Q %MG_BUILD_AREA%
+if not exist %MG_BUILD_AREA%\Installer mkdir %MG_BUILD_AREA%\Installer
+if not exist %MG_BUILD_AREA%\MgDev mkdir %MG_BUILD_AREA%\MgDev
+svn export %MG_BUILD_SRC%\Installer %MG_BUILD_AREA%\Installer --force -q
+svn export %MG_BUILD_SRC%\MgDev %MG_BUILD_AREA%\MgDev --force -q
+cd %MG_BUILD_AREA%\MgDev\Oem\FDO
+xcopy /S /Y /I %FDO_SRC%\Inc Inc
+xcopy /S /Y /I %FDO_SRC%\Lib Lib
+xcopy /S /Y /I %FDO_SRC%\Bin Bin\Release
+xcopy /S /Y /I %FDO_SRC%\Bin\com\*.* Bin\Release\com
+cd %MG_BUILD_AREA%\MgDev\Oem\FDO\Bin\Release
+del /Q OSGeo.FDO.*
+del /Q *.pdb
+:build_mapguide
+cscript updateversion.vbs /major:%MG_VER_MAJOR% /minor:%MG_VER_MINOR% /point:%MG_VER_BUILD% /build:%MG_REVISION%
+call stampassemblies.bat %MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%
+call build.bat
+call build.bat -a=install -o=%MG_BUILD_OUTPUT%
+pushd %MG_BUILD_OUTPUT%\fusion-selfbuild
+move /Y fusion-buildtools.zip %MG_BUILD_OUTPUT_ROOT%
+popd
+popd
+:build_mgdesktop
+SET MG_OUTPUT=%MG_BUILD_AREA%\MgDev\Release
+pushd %MG_BUILD_AREA%\MgDev
+call build_desktop.bat x86
+popd
+pushd %MG_BUILD_AREA%\MgDev\nuget
+popd
+call nuget_prepare.bat %MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION% x86
+call nuget_pack.bat x86
+popd
+popd
+pushd %MG_BUILD_AREA%\MgDev\Release
+7z a -mx9 %MG_BUILD_ARTIFACT_PATH%\mg-desktop\mg-desktop-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%-net40-vc11-x86.zip Desktop DesktopSamples
+popd
+pushd %MG_BUILD_AREA%\Installer
+call build.bat -a=prepare -source=%MG_BUILD_OUTPUT%
+popd
+svn update
+popd
+popd
+if not exist %MG_BUILD_OUTPUT%\Setup mkdir %MG_BUILD_OUTPUT%\Setup
+copy /Y *.exe %MG_BUILD_OUTPUT%\Setup
+copy /Y *.pdb %MG_BUILD_OUTPUT%\Setup
+copy /Y *.dll %MG_BUILD_OUTPUT%\Setup
+copy /Y *.config %MG_BUILD_OUTPUT%\Setup
+popd
+7z a %MG_BUILD_OUTPUT_ROOT%\MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%-InstantSetup-x86.exe -mmt -mx5 -sfx7z.sfx .
+popd
+:build_installer
+call build.bat -a=generate -source=%MG_BUILD_OUTPUT%
+call build.bat -source=%MG_BUILD_OUTPUT% -version=%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION% -name=MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%-%RELEASE_LABEL%-x86 -title="MapGuide Open Source %MG_VER_MAJOR_MINOR_BUILD% %RELEASE_LABEL%"
+move /Y Output\en-US\MapGuideOpenSource-%MG_VER_MAJOR_MINOR_BUILD%.%MG_REVISION%-%RELEASE_LABEL%-x86.exe %MG_BUILD_OUTPUT_ROOT%
+popd
+if "%MG_RUN_UNIT_TESTS%"=="false" goto end
+:server_unit_test
+pushd %MG_BUILD_AREA%\MgDev\Server\bin\Release
+mgserver.exe test
+popd
+goto end
+:error
+exit /b 1
+:end
+ </builders>
+ <publishers>
+ </publishers>
+ <buildWrappers/>
+</project>
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/config.xml 2014-05-12 12:28:54 UTC (rev 8126)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x64/config.xml 2014-05-12 12:31:52 UTC (rev 8127)
@@ -30,7 +30,7 @@
- <defaultValue>6</defaultValue>
+ <defaultValue>7</defaultValue>
@@ -45,7 +45,7 @@
- <defaultValue>C:\builds\fdo\3.9.0\x64\Fdo</defaultValue>
+ <defaultValue>C:\builds\fdo\3.10.0\x64\Fdo</defaultValue>
Modified: trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/config.xml
--- trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/config.xml 2014-05-12 12:28:54 UTC (rev 8126)
+++ trunk/Tools/JenkinsCI/home/slave_win/jobs/MapGuide Open Source x86/config.xml 2014-05-12 12:31:52 UTC (rev 8127)
@@ -30,7 +30,7 @@
@@ -45,7 +45,7 @@
- <defaultValue>C:\builds\fdo\3.9.0\x86\Fdo</defaultValue>
+ <defaultValue>C:\builds\fdo\3.10.0\x86\Fdo</defaultValue>
Modified: trunk/Tools/JenkinsCI/tools/setrevnums.bat
--- trunk/Tools/JenkinsCI/tools/setrevnums.bat 2014-05-12 12:28:54 UTC (rev 8126)
+++ trunk/Tools/JenkinsCI/tools/setrevnums.bat 2014-05-12 12:31:52 UTC (rev 8127)
@@ -1,6 +1,6 @@
@echo off
SET MG_SOURCES_DIR=C:\working\sources
-svn info "%MG_SOURCES_DIR%\fdo-3.8" | perl revnum.pl > "%MG_SOURCES_DIR%\fdo_38_revision.txt"
+svn info "%MG_SOURCES_DIR%\fdo-3.9" | perl revnum.pl > "%MG_SOURCES_DIR%\fdo_39_revision.txt"
svn info "%MG_SOURCES_DIR%\fdo-trunk" | perl revnum.pl > "%MG_SOURCES_DIR%\fdo_trunk_revision.txt"
-svn info "%MG_SOURCES_DIR%\mg-2.5\MgDev" | perl revnum.pl > "%MG_SOURCES_DIR%\mapguide_25_revision.txt"
+svn info "%MG_SOURCES_DIR%\mg-2.6\MgDev" | perl revnum.pl > "%MG_SOURCES_DIR%\mapguide_26_revision.txt"
svn info "%MG_SOURCES_DIR%\mg-trunk\MgDev" | perl revnum.pl > "%MG_SOURCES_DIR%\mapguide_trunk_revision.txt"
Modified: trunk/Tools/JenkinsCI/tools/svnupdate.bat
--- trunk/Tools/JenkinsCI/tools/svnupdate.bat 2014-05-12 12:28:54 UTC (rev 8126)
+++ trunk/Tools/JenkinsCI/tools/svnupdate.bat 2014-05-12 12:31:52 UTC (rev 8127)
@@ -1,8 +1,9 @@
+ at echo off
-svn update "%MG_SOURCES_DIR%\fdo-3.8"
+svn update "%MG_SOURCES_DIR%\fdo-3.9"
svn update "%MG_SOURCES_DIR%\fdo-trunk"
-svn update "%MG_SOURCES_DIR%\mg-2.5\Installer"
-svn update "%MG_SOURCES_DIR%\mg-2.5\MgDev"
+svn update "%MG_SOURCES_DIR%\mg-2.6\Installer"
+svn update "%MG_SOURCES_DIR%\mg-2.6\MgDev"
svn update "%MG_SOURCES_DIR%\mg-trunk\Installer"
svn update "%MG_SOURCES_DIR%\mg-trunk\MgDev"
svn update "%MG_SOURCES_DIR%\MgInstantSetup"
More information about the mapguide-commits
