[mapguide-commits] r8130 - in trunk/Tools/Maestro/Maestro.Editors: . LayerDefinition/Vector/Scales
svn_mapguide at osgeo.org
Mon May 12 12:39:07 PDT 2014
Author: jng
Date: 2014-05-12 12:39:07 -0700 (Mon, 12 May 2014)
New Revision: 8130
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/CompositeStyleListCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/Condition.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionList.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ItemStyle.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.resx
#2447: Theme offset was also not applied to the classic editor for composite styles.
Also display the proper unsupported message when attempting to theme a composite style with the classic editor.
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/CompositeStyleListCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/CompositeStyleListCtrl.cs 2014-05-12 19:16:57 UTC (rev 8129)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/CompositeStyleListCtrl.cs 2014-05-12 19:39:07 UTC (rev 8130)
@@ -95,6 +95,18 @@
_controls[style].AddRule();
+ //Update offset
+ if (lstStyles.SelectedIndex >= 0)
+ int offset = 0;
+ for (int i = 0; i < lstStyles.SelectedIndex; i++)
+ var cs = (ICompositeTypeStyle)lstStyles.Items[i];
+ offset += cs.RuleCount;
+ _controls[style].SetThemeOffset(offset);
SetActiveControl(_controls[style]);
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/Condition.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/Condition.cs 2014-05-12 19:16:57 UTC (rev 8129)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/Condition.cs 2014-05-12 19:39:07 UTC (rev 8130)
@@ -262,5 +262,10 @@
this.Focus();
+ internal void SetThemeOffset(int offset)
+ FeatureStyle.SetThemeOffset(offset);
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionList.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionList.cs 2014-05-12 19:16:57 UTC (rev 8129)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionList.cs 2014-05-12 19:39:07 UTC (rev 8130)
@@ -400,5 +400,16 @@
return minHeight;
+ foreach (var c in this.Controls)
+ var cond = c as Condition;
+ if (cond == null)
+ continue;
+ cond.SetThemeOffset(offset);
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.cs 2014-05-12 19:16:57 UTC (rev 8129)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ConditionListButtons.cs 2014-05-12 19:39:07 UTC (rev 8130)
@@ -177,7 +177,15 @@
owner = m_line;
else if (m_area != null)
owner = m_area;
+ else if (m_comp != null)
+ owner = m_comp;
+ if (owner is ICompositeTypeStyle)
+ MessageBox.Show(Strings.CannotCreateThemeForCompositeStyleClassicEditor);
+ return;
ILayerDefinition layer = (ILayerDefinition)m_owner.Editor.GetEditedResource();
IVectorLayerDefinition vl = (IVectorLayerDefinition)layer.SubLayer;
if (string.IsNullOrEmpty(vl.FeatureName))
@@ -355,5 +363,10 @@
Utility.ExplodeThemeIntoFilteredLayers(options, cb);
return true;
+ conditionList.SetThemeOffset(offset);
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ItemStyle.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ItemStyle.cs 2014-05-12 19:16:57 UTC (rev 8129)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/ItemStyle.cs 2014-05-12 19:39:07 UTC (rev 8130)
@@ -181,7 +181,7 @@
80,
40,
"PNG", //NOXLATE
- this.ThemeCategory);
+ _themeOffset + this.ThemeCategory);
//TODO: This is obviously a mess and could do with some future cleanup, but the idea here should be
//easy to understand. Each primitive basic style (that's not a label) has 3 actions.
@@ -409,5 +409,12 @@
EditButton_Click(sender, e);
+ private int _themeOffset = 0;
+ _themeOffset = offset;
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2014-05-12 19:16:57 UTC (rev 8129)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2014-05-12 19:39:07 UTC (rev 8130)
@@ -124,6 +124,15 @@
/// <summary>
+ /// Looks up a localized string similar to Theming composite styles with this editor is not supported.
+ /// </summary>
+ internal static string CannotCreateThemeForCompositeStyleClassicEditor {
+ get {
+ return ResourceManager.GetString("CannotCreateThemeForCompositeStyleClassicEditor", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Creating themes from a Composite Rule with a Compound Symbol is not supported.
/// </summary>
internal static string CannotCreateThemeFromCompoundSymbolInstance {
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.resx
--- trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2014-05-12 19:16:57 UTC (rev 8129)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2014-05-12 19:39:07 UTC (rev 8130)
@@ -1608,4 +1608,7 @@
<data name="LayerEditorHasErrors" xml:space="preserve">
<value>Found errors in the Layer Definition. Please check any errors flagged in the editor.</value>
</data>
+ <data name="CannotCreateThemeForCompositeStyleClassicEditor" xml:space="preserve">
+ <value>Theming composite styles with this editor is not supported</value>
+ </data>
</root>
\ No newline at end of file
More information about the mapguide-commits
