[mapguide-commits] r8142 - trunk/MgDev/Common/MapGuideCommon/Services
svn_mapguide at osgeo.org
Wed May 21 00:34:44 PDT 2014
Author: jng
Date: 2014-05-21 00:34:44 -0700 (Wed, 21 May 2014)
New Revision: 8142
trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h
Merge r8141 to trunk
Modified: trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h 2014-05-21 07:07:10 UTC (rev 8141)
+++ trunk/MgDev/Common/MapGuideCommon/Services/RenderingService.h 2014-05-21 07:34:44 UTC (rev 8142)
@@ -39,10 +39,13 @@
/// \brief
- /// Returns the specified base map tile for the given map. If a cached tile
- /// image exists it will return it, otherwise the tile is rendered and added
- /// to the cache.
+ /// Returns the specified base map tile for the given map.
+ /// \remarks
+ /// This method only renders the given tile. No tile caching is performed
+ /// by this method. To render and cache the tile, use the
+ /// \link MgTileService::GetTile GetTile \endlink method instead
/// \param map
/// Input
/// map object containing current state of map.
More information about the mapguide-commits
