[mapguide-commits] r8379 - trunk/MgDev/UnitTest/WebTier/Java
svn_mapguide at osgeo.org
Sat Oct 4 06:12:12 PDT 2014
Author: jng
Date: 2014-10-04 06:12:12 -0700 (Sat, 04 Oct 2014)
New Revision: 8379
Added:
trunk/MgDev/UnitTest/WebTier/Java/README.txt
trunk/MgDev/UnitTest/WebTier/Java/build.xml
Add README for this test suite.
Added: trunk/MgDev/UnitTest/WebTier/Java/README.txt
--- trunk/MgDev/UnitTest/WebTier/Java/README.txt (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/README.txt 2014-10-04 13:12:12 UTC (rev 8379)
@@ -0,0 +1,23 @@
+Java Unit Test README
+This is the test suite for the Java bindings to the MapGuide API.
+This test suite exercises the enhanced Java wrapper (MapGuideApiEx.jar) and not the original (MapGuideApi.jar)
+Requirements
+ - You must have already built the Oem/Server/Web components of MapGuide
+ - Apache Ant
+ - ant-contrib 1.0b2 or higher
+Running the tests
+ 1. Start the MapGuide Server process
+ 2. Run the following ant command: ant check
+Unit tests results will be logged to unittest.log
+The default ant build.xml properties is configured for 64-bit release configuration of MapGuide. Where applicable, you should override these properties to match your specific build configuration.
\ No newline at end of file
Modified: trunk/MgDev/UnitTest/WebTier/Java/build.xml
--- trunk/MgDev/UnitTest/WebTier/Java/build.xml 2014-10-04 13:00:45 UTC (rev 8378)
+++ trunk/MgDev/UnitTest/WebTier/Java/build.xml 2014-10-04 13:12:12 UTC (rev 8379)
@@ -2,6 +2,7 @@
<project name="MgUnitTest" default="dist" basedir=".">
<description>MgUnitTest project file</description>
+ <!-- Must install ant-contrib 1.0b2 or higher -->
<taskdef resource="net/sf/antcontrib/antcontrib.properties"/>
<!-- set global properties for this build -->
More information about the mapguide-commits
