[mapguide-commits] r8383 - in trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test: . mapguide platform
svn_mapguide at osgeo.org
Mon Oct 6 02:02:45 PDT 2014
Author: jng
Date: 2014-10-06 02:02:45 -0700 (Mon, 06 Oct 2014)
New Revision: 8383
Added:
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/ReadOnlyLayerCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LayerCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LayerGroupCollectionTest.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/CommonTests.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTests.java
trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/Program.java
#2307: Add tests for MgLayerCollection/MgLayerGroupCollection/MgReadOnlyLayerCollection. Also load the Sheboygan dataset before executing tests.
Modified: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/CommonTests.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/CommonTests.java 2014-10-04 13:57:16 UTC (rev 8382)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/CommonTests.java 2014-10-06 09:02:45 UTC (rev 8383)
@@ -26,6 +26,8 @@
tests.add(new FeatureSchemaCollectionTest());
tests.add(new GeometryCollectionTest());
tests.add(new IntCollectionTest());
+ tests.add(new LayerCollectionTest());
+ tests.add(new LayerGroupCollectionTest());
tests.add(new LinearRingCollectionTest());
tests.add(new LineStringCollectionTest());
tests.add(new MapCollectionTest());
Modified: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTests.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTests.java 2014-10-04 13:57:16 UTC (rev 8382)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/MapGuideTests.java 2014-10-06 09:02:45 UTC (rev 8383)
@@ -2,13 +2,20 @@
import java.util.*;
+import org.osgeo.mapguide.*;
import org.osgeo.mapguide.test.common.*;
+import org.osgeo.mapguide.test.mapguide.*;
public class MapGuideTests
public static int Execute(IPlatformFactory factory, ITestLogger logger, MutableInteger testsRun) {
int failures = 0;
Vector<IExternalTest> tests = new Vector<IExternalTest>();
+ //--------------- BEGIN Test Registration -----------------//
+ tests.add(new ReadOnlyLayerCollectionTest());
+ //--------------- END Test Registration -------------------//
for (IExternalTest test : tests)
try
Modified: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/Program.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/Program.java 2014-10-04 13:57:16 UTC (rev 8382)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/Program.java 2014-10-06 09:02:45 UTC (rev 8383)
@@ -25,12 +25,20 @@
try (ITestLogger logger = new TestLoggerFile(logFile)) {
logger.WriteLine(String.format("Run started: %s", new Date().toString()));
MapGuideJavaApiEx.MgInitializeWebTier(webConfigPath);
- Console.WriteLine("MapGuide Initialized. Running tests");
userInfo = new MgUserInformation("Administrator", "admin");
siteConn = new MgSiteConnection();
siteConn.open(userInfo);
+ //Load the Sheboygan sample data set required by some tests
+ Console.WriteLine("Loading Sheboygan sample data package");
+ MgByteSource bs = new MgByteSource("../../TestData/Samples/Sheboygan/Sheboygan.mgp");
+ MgByteReader rdr = bs.getReader();
+ MgResourceService resSvc = (MgResourceService)siteConn.createService(MgServiceType.ResourceService);
+ resSvc.applyResourcePackage(rdr);
+ Console.WriteLine("MapGuide Initialized. Running tests");
IPlatformFactory factory = new PlatformFactory(siteConn);
MutableInteger testsRun = new MutableInteger(0);
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/ReadOnlyLayerCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/ReadOnlyLayerCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/mapguide/ReadOnlyLayerCollectionTest.java 2014-10-06 09:02:45 UTC (rev 8383)
@@ -0,0 +1,78 @@
+package org.osgeo.mapguide.test.mapguide;
+import java.io.*;
+import java.util.*;
+import org.osgeo.mapguide.test.common.*;
+public class ReadOnlyLayerCollectionTest implements IExternalTest
+ public void Execute(IPlatformFactory factory, ITestLogger logger)
+ MgFeatureQueryOptions query1 = new MgFeatureQueryOptions();
+ query1.setFilter("Autogenerated_SDF_ID < 4");
+ MgFeatureQueryOptions query2 = new MgFeatureQueryOptions();
+ query2.setFilter("Autogenerated_SDF_ID < 4");
+ MgMap map = (MgMap)factory.createMap();
+ MgResourceService resSvc = (MgResourceService)factory.createService(MgServiceType.ResourceService);
+ MgResourceIdentifier mdfId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
+ map.create(mdfId, "Test");
+ map.save();
+ MgLayerCollection layers = map.getLayers();
+ MgLayerBase item1 = layers.getItem("Parcels");
+ MgLayerBase item2 = layers.getItem("Buildings");
+ MgFeatureReader fr1 = item1.selectFeatures(query1);
+ MgFeatureReader fr2 = item2.selectFeatures(query2);
+ MgSelection sel = new MgSelection(map);
+ try {
+ sel.fromXml(""); //Clear
+ sel.addFeatures(item1, fr1, 0);
+ sel.addFeatures(item2, fr2, 0);
+ } finally{
+ fr1.close();
+ fr2.close();
+ //Now we can test the collection
+ MgReadOnlyLayerCollection items = sel.getLayers();
+ Assert.IsTrue(items.getCount() == 2, "Expected 2 items");
+ //NOTE: Possible bug in ordering of MgReadOnlyLayerCollection here (I had to reverse the order of layers
+ //being tested) Nevertheless, were testing that the ordering (whether correct or not) is the same when iterated
+ //in both the classical and iterative methods
+ int i = 0;
+ //Looping the classic way
+ for (i = 0; i < items.getCount(); i++) {
+ switch (i){
+ case 0:
+ Assert.IsTrue(items.getItem(i).getName().equals("Buildings"), "Expected item #" + (i+1) + " to be Buildings");
+ break;
+ case 1:
+ Assert.IsTrue(items.getItem(i).getName().equals("Parcels"), "Expected item #" + (i+1) + " to be Parcels");
+ break;
+ //Looping the iterative way
+ i = 0;
+ for (MgLayerBase item : items) {
+ String itemName = item.getName();
+ switch (i){
+ case 0:
+ Assert.IsTrue(itemName.equals("Buildings"), "Expected item #" + (i+1) + " to be Buildings");
+ break;
+ case 1:
+ Assert.IsTrue(itemName.equals("Parcels"), "Expected item #" + (i+1) + " to be Parcels");
+ break;
+ i++;
\ No newline at end of file
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LayerCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LayerCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LayerCollectionTest.java 2014-10-06 09:02:45 UTC (rev 8383)
@@ -0,0 +1,162 @@
+package org.osgeo.mapguide.test.platform;
+import java.io.*;
+public class LayerCollectionTest implements IExternalTest
+ MgMapBase map = factory.createMap();
+ String coordsys = "GEOGCS[\"LL84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9108\"]],AXIS[\"Lat\",NORTH],AXIS[\"Long\",EAST],AUTHORITY[\"EPSG\",\"4326\"]]";
+ MgEnvelope env = new MgEnvelope(10, 10, 20, 20);
+ map.create(coordsys, env, "Test");
+ MgLayerCollection items = map.getLayers();
+ items.clear();
+ MgResourceIdentifier ldfId = new MgResourceIdentifier("Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition");
+ MgLayerBase item1 = new MgLayer(ldfId, resSvc);
+ item1.setName("Item1");
+ MgLayerBase item2 = new MgLayer(ldfId, resSvc);
+ item2.setName("Item2");
+ MgLayerBase item3 = new MgLayer(ldfId, resSvc);
+ item3.setName("Item3");
+ MgLayerBase item4 = new MgLayer(ldfId, resSvc);
+ item4.setName("Item4");
+ //Items inserted the MapGuide API way
+ items.addItem(item1);
+ items.addItem(item2);
+ items.addItem(item3);
+ Assert.IsTrue(items.getCount() == 3, "Expected 3 items");
+ Assert.IsTrue(!items.isEmpty(), "Expected non-empty item collection");
+ int i = 0;
+ switch (i){
+ case 0:
+ Assert.IsTrue(items.getItem(i).getName().equals("Item1"), "Expected item #" + (i+1) + " to be Item1");
+ break;
+ case 1:
+ Assert.IsTrue(items.getItem(i).getName().equals("Item2"), "Expected item #" + (i+1) + " to be Item2");
+ break;
+ case 2:
+ Assert.IsTrue(items.getItem(i).getName().equals("Item3"), "Expected item #" + (i+1) + " to be Item3");
+ break;
+ i = 0;
+ switch (i){
+ case 0:
+ Assert.IsTrue(itemName.equals("Item1"), "Expected item #" + (i+1) + " to be Item1");
+ break;
+ case 1:
+ Assert.IsTrue(itemName.equals("Item2"), "Expected item #" + (i+1) + " to be Item2");
+ break;
+ case 2:
+ Assert.IsTrue(itemName.equals("Item3"), "Expected item #" + (i+1) + " to be Item3");
+ break;
+ i++;
+ items.clear();
+ Assert.IsTrue(items.getCount() == 0, "Expected empty item collection");
+ Assert.IsTrue(items.isEmpty(), "Expected empty item collection");
+ //Now test through java.util.Collection facade
+ Collection<MgLayerBase> facade = items;
+ //add()
+ Assert.IsTrue(facade.add(item1), "Could not add item1 the java.util.Collection way");
+ Assert.IsTrue(facade.add(item2), "Could not add item2 the java.util.Collection way");
+ Assert.IsTrue(facade.add(item3), "Could not add item3 the java.util.Collection way");
+ Assert.IsTrue(facade.size() == 3, "Expected 3 items");
+ Assert.IsTrue(!facade.isEmpty(), "Expected non-empty item collection");
+ //contains()
+ Assert.IsTrue(facade.contains(item1), "item1 should exist");
+ Assert.IsTrue(facade.contains(item2), "item2 should exist");
+ Assert.IsTrue(facade.contains(item3), "item3 should exist");
+ ArrayList<MgLayerBase> testCollection = new ArrayList<MgLayerBase>();
+ testCollection.add(item1);
+ testCollection.add(item2);
+ testCollection.add(item3);
+ //containsAll()
+ Assert.IsTrue(facade.containsAll(testCollection), "All items in test collection should match");
+ testCollection.clear();
+ testCollection.add(item4);
+ Assert.IsTrue(!facade.containsAll(testCollection), "Should not have matched test collection");
+ facade.clear();
+ Assert.IsTrue(facade.size() == 0, "Expected 0 items");
+ Assert.IsTrue(facade.isEmpty(), "Expected empty item collection");
+ //addAll()
+ Assert.IsTrue(facade.addAll(testCollection), "Expected addAll() success");
+ //remove()
+ Assert.IsTrue(!facade.remove(item4), "Expected remove() of non-existent item to return false");
+ Assert.IsTrue(!facade.remove(new MgFeatureSchema()), "Expected remove() of different type to return false");
+ Assert.IsTrue(facade.remove(item2), "Expected remove() of item2 to return true");
+ //removeAll()
+ testCollection.remove(item2);
+ Assert.IsTrue(facade.removeAll(testCollection), "Expected removeAll() to succeed");
+ //retainAll()
+ Assert.IsTrue(facade.size() == 3, "Expected 3 schemas");
+ Assert.IsTrue(!facade.isEmpty(), "Expected non-empty schema collection");
+ Assert.IsTrue(facade.retainAll(testCollection), "Expected retainAll() to succeed");
+ Assert.IsTrue(facade.contains(item1), "Expected item1 to exist");
+ Assert.IsTrue(!facade.contains(item2), "Expected item2 to not exist");
+ Assert.IsTrue(facade.contains(item3), "Expected item3 to exist");
+ //toArray()
+ Object[] itemArray = facade.toArray();
+ Assert.IsTrue(itemArray != null, "Expected non-null item array");
+ Assert.IsTrue(itemArray.length == 2, "Expected 2 item array");
+ for (Object o : itemArray) {
+ Assert.IsTrue(o instanceof MgLayerBase, "Expected item to be MgLayerBase");
+ MgLayerBase[] fitems = facade.toArray(new MgLayerBase[0]);
+ Assert.IsTrue(fitems != null, "Expected non-null item array");
+ Assert.IsTrue(fitems.length == 2, "Expected 2 item array");
+ fitems = facade.toArray(new MgLayerBase[1]);
+ fitems = facade.toArray(new MgLayerBase[3]);
+ Assert.IsTrue(fitems.length == 3, "Expected 3 item array");
+ Assert.IsTrue(fitems[0] != null, "Expected non-null item #1");
+ Assert.IsTrue(fitems[1] != null, "Expected non-null item #2");
+ Assert.IsTrue(fitems[2] == null, "Expected null item #3");
Added: trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LayerGroupCollectionTest.java
--- trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LayerGroupCollectionTest.java (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/Java/src/org/osgeo/mapguide/test/platform/LayerGroupCollectionTest.java 2014-10-06 09:02:45 UTC (rev 8383)
@@ -0,0 +1,157 @@
+import java.io.*;
+public class LayerGroupCollectionTest implements IExternalTest
+ MgLayerGroupCollection items = map.getLayerGroups();
+ items.clear();
+ MgLayerGroup item1 = new MgLayerGroup("Item1");
+ MgLayerGroup item2 = new MgLayerGroup("Item2");
+ MgLayerGroup item3 = new MgLayerGroup("Item3");
+ MgLayerGroup item4 = new MgLayerGroup("Item4");
+ int i = 0;
+ switch (i){
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ i = 0;
+ for (MgLayerGroup item : items) {
+ switch (i){
+ case 0:
+ break;
+ case 1:
+ break;
+ case 2:
+ break;
+ i++;
+ items.clear();
+ Collection<MgLayerGroup> facade = items;
+ //add()
+ //contains()
+ ArrayList<MgLayerGroup> testCollection = new ArrayList<MgLayerGroup>();
+ //containsAll()
+ facade.clear();
+ //addAll()
+ //remove()
+ //removeAll()
+ //retainAll()
+ //toArray()
+ Assert.IsTrue(o instanceof MgLayerGroup, "Expected item to be MgLayerBase");
+ MgLayerGroup[] fitems = facade.toArray(new MgLayerGroup[0]);
+ fitems = facade.toArray(new MgLayerGroup[1]);
+ fitems = facade.toArray(new MgLayerGroup[3]);
More information about the mapguide-commits
