[mapguide-commits] r8393 - in branches/2.6/MgDev: . Server/src/Core
svn_mapguide at osgeo.org
Tue Oct 7 02:31:27 PDT 2014
Author: jng
Date: 2014-10-07 02:31:27 -0700 (Tue, 07 Oct 2014)
New Revision: 8393
branches/2.6/MgDev/
branches/2.6/MgDev/Server/src/Core/ClientAcceptor.cpp
Merged revision(s) 8392 from trunk/MgDev:
#2492: Reclaim any dangling sockets on server restart. The allows for immediate server restart on Linux when it dies due to segfault. No observable side-effects on Windows.
Property changes on: branches/2.6/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/createruntimemap:7486-7555
/sandbox/rfc94:5099-5163
/trunk/MgDev:8209-8210,8230,8313,8333,8359,8388
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8209-8210,8230,8313,8333,8359,8388,8392
Modified: branches/2.6/MgDev/Server/src/Core/ClientAcceptor.cpp
--- branches/2.6/MgDev/Server/src/Core/ClientAcceptor.cpp 2014-10-07 09:29:39 UTC (rev 8392)
+++ branches/2.6/MgDev/Server/src/Core/ClientAcceptor.cpp 2014-10-07 09:31:27 UTC (rev 8393)
@@ -55,7 +55,14 @@
// Set a large backlog so INET will not block connections
// so often. It takes time to clean the port up and
// make it available for other connections.
- if (m_SockAcceptor.open(m_Addr, 0, PF_INET, 32) != -1)
+ // Also set reuse_addr = 1 to avoid the case where the mgserver
+ // process dies by segfault and we have to wait several minutes for
+ // the dangling sockets to be cleared out by the system before mgserver
+ // can be started again (dangling sockets will cause a "port already in
+ // use" error when restarting mgserver). With reuse_addr = 1, mgserver
+ // will reclaim these dangling sockets when this method is called
+ if (m_SockAcceptor.open(m_Addr, 1 /* reuse_addr */, PF_INET, 32) != -1)
MgLogManager* pMan = MgLogManager::GetInstance();
if(pMan->IsTraceLogEnabled())
More information about the mapguide-commits
