[mapguide-commits] r8396 - trunk/MgDev
svn_mapguide at osgeo.org
Tue Oct 7 18:46:36 PDT 2014
Author: jng
Date: 2014-10-07 18:46:36 -0700 (Tue, 07 Oct 2014)
New Revision: 8396
trunk/MgDev/run_tests.bat
Update run_tests.bat to:
- Assume a prepared staging area install path as the default location where PHP is installed
- Clean out .net test runner binaries/intermediate files before building
- Call updated ant target (checkwin) when running Java tests
Modified: trunk/MgDev/run_tests.bat
--- trunk/MgDev/run_tests.bat 2014-10-08 01:41:34 UTC (rev 8395)
+++ trunk/MgDev/run_tests.bat 2014-10-08 01:46:36 UTC (rev 8396)
@@ -11,12 +11,12 @@
SET SERVER_ADDR=localhost
SET WEBCONFIGINI=%CD%\UnitTest\webconfig.ini
SET SERVER_PORT=8018
-SET PATH=D:\mg-trunk\MgDev\Release\Web\Php;%PATH%;
+SET PATH=%CD%\%CONF%\Web\Php;%PATH%;
REM SET WEBCONFIGINI=C:\Program Files\OSGeo\MapGuide\Web\www\webconfig.ini
REM SET SERVER_PORT=80
SET PHP_TEST_CWD=%CD%\Web\src\mapagent
REM SET PHP_EXT_DIR=C:\Program Files\OSGeo\MapGuide\Web\Php\ext
-SET PHP_EXT_DIR=D:\mg-trunk\MgDev\Release\Web\Php\ext
+SET PHP_EXT_DIR=%CD%\%CONF%\Web\Php\ext
SET START_MGSERVER=1
SET START_WEBSERVER=1
@@ -52,7 +52,10 @@
if "%RUN_DOTNET_TESTS%" == "1" (
echo [build]: DotNet test runner
SET TEST_COMPONENT=Build DotNet test runner
+ if exist UnitTest\WebTier\DotNet_x64 rd /S /Q UnitTest\WebTier\DotNet_x64
+ if exist UnitTest\WebTier\DotNet_x86 rd /S /Q UnitTest\WebTier\DotNet_x86
pushd UnitTest\WebTier\DotNet
+ if exist Libs rd /S /Q Libs
msbuild /p:Configuration=%CONFIG%;Platform=%PLAT% /fl /flp:logfile=build.log DotNet.sln
if "%ERRORLEVEL%" == "1" (
set RETURN_CODE=%ERRORLEVEL%
@@ -150,7 +153,7 @@
if exist ResourceService\ResourceServiceTest.db del /F ResourceService\ResourceServiceTest.db
popd
pushd UnitTest\WebTier\Java
- call ant check
+ call ant checkwin
if %ERRORLEVEL% neq 0 echo [test]: Java test runner had one or more test failures. Check log files for more information
popd
More information about the mapguide-commits
