[mapguide-commits] r8398 - trunk/MgDev/Desktop/MgDesktop/MapLayer
svn_mapguide at osgeo.org
Thu Oct 9 07:00:51 PDT 2014
Author: jng
Date: 2014-10-09 07:00:51 -0700 (Thu, 09 Oct 2014)
New Revision: 8398
trunk/MgDev/Desktop/MgDesktop/MapLayer/Layer.cpp
trunk/MgDev/Desktop/MgDesktop/MapLayer/Layer.h
mg-desktop: Port over legend icon convenience APIs
Modified: trunk/MgDev/Desktop/MgDesktop/MapLayer/Layer.cpp
--- trunk/MgDev/Desktop/MgDesktop/MapLayer/Layer.cpp 2014-10-08 01:53:06 UTC (rev 8397)
+++ trunk/MgDev/Desktop/MgDesktop/MapLayer/Layer.cpp 2014-10-09 14:00:51 UTC (rev 8398)
@@ -17,6 +17,12 @@
#include "Layer.h"
#include "FSDSAX2Parser.h"
+#include "AreaTypeStyle.h"
+#include "LineTypeStyle.h"
+#include "PointTypeStyle.h"
+#include "CompositeTypeStyle.h"
+#include "VectorScaleRange.h"
+#include "VectorLayerDefinition.h"
#include "Services/ServiceFactory.h"
#include "Services/ScrollableFeatureReader.h"
@@ -616,6 +622,216 @@
return false;
+MgIntCollection* MgdLayer::GetGeometryTypeStyles()
+ Ptr<MgIntCollection> ret;
+ MG_TRY()
+ ret = GetGeometryTypeStyles(GetMap()->GetViewScale());
+ MG_CATCH_AND_THROW(L"MgdLayer.GetGeometryTypeStyles");
+ return ret.Detach();
+INT32 MgdLayer::GetThemeCategoryCount(INT32 geomType)
+ return GetThemeCategoryCount(GetMap()->GetViewScale(), geomType);
+MgByteReader* MgdLayer::GenerateLegendImage(INT32 width, INT32 height, CREFSTRING format, INT32 geomType, INT32 themeCategory)
+ Ptr<MgByteReader> ret;
+ MG_TRY()
+ ret = GenerateLegendImage(GetMap()->GetViewScale(), width, height, format, geomType, themeCategory);
+ MG_CATCH_AND_THROW(L"MgdLayer.GenerateLegendImage");
+MgIntCollection* MgdLayer::GetGeometryTypeStyles(double scale)
+ MG_TRY()
+ Ptr<MgResourceService> resSvc = dynamic_cast<MgResourceService*>(GetMap()->GetService(MgServiceType::ResourceService));
+ std::auto_ptr<MdfModel::LayerDefinition> ldf(MgLayerBase::GetLayerDefinition(resSvc, m_definition));
+ if (ldf.get() != NULL)
+ MdfModel::VectorLayerDefinition* vl = dynamic_cast<MdfModel::VectorLayerDefinition*>(ldf.get());
+ if(vl != NULL)
+ MdfModel::VectorScaleRangeCollection* scaleRanges = vl->GetScaleRanges();
+ if (scaleRanges != NULL)
+ for (INT32 i = 0; i < scaleRanges->GetCount(); i++)
+ MdfModel::VectorScaleRange* vsr = scaleRanges->GetAt(i);
+ if (scale >= vsr->GetMinScale() && scale < vsr->GetMaxScale())
+ MdfModel::FeatureTypeStyleCollection* ftsc = vsr->GetFeatureTypeStyles();
+ ret = new MgIntCollection();
+ for (INT32 j = 0; j < ftsc->GetCount(); j++)
+ MdfModel::PointTypeStyle* pts = dynamic_cast<MdfModel::PointTypeStyle*>(ftsc->GetAt(j));
+ MdfModel::LineTypeStyle* lts = dynamic_cast<MdfModel::LineTypeStyle*>(ftsc->GetAt(j));
+ MdfModel::AreaTypeStyle* ats = dynamic_cast<MdfModel::AreaTypeStyle*>(ftsc->GetAt(j));
+ MdfModel::CompositeTypeStyle* cts = dynamic_cast<MdfModel::CompositeTypeStyle*>(ftsc->GetAt(j));
+ if (pts != NULL)
+ if (ret->IndexOf(1) < 0)
+ ret->Add(1);
+ else if (lts != NULL)
+ if (ret->IndexOf(2) < 0)
+ ret->Add(2);
+ else if (ats != NULL)
+ if (ret->IndexOf(3) < 0)
+ ret->Add(3);
+ else if (cts != NULL)
+ ret->Add(4);
+INT32 MgdLayer::GetThemeCategoryCount(double scale, INT32 geomType)
+ INT32 ret = -1;
+ if(vl != NULL)
+ if (pts != NULL && geomType == 1)
+ ret = pts->GetRules()->GetCount();
+ break;
+ else if (lts != NULL && geomType == 2)
+ ret = lts->GetRules()->GetCount();
+ break;
+ else if (ats != NULL && geomType == 3)
+ ret = ats->GetRules()->GetCount();
+ break;
+ else if (cts != NULL && geomType == 4)
+ ret = cts->GetRules()->GetCount();
+ break;
+ return ret;
+INT32 MgdLayer::GetCompositeThemeCategoryCount(INT32 compositeOffset)
+ return GetCompositeThemeCategoryCount(GetMap()->GetViewScale(), compositeOffset);
+INT32 MgdLayer::GetCompositeThemeCategoryCount(double scale, INT32 compositeOffset)
+ INT32 ret = -1;
+ if(vl != NULL)
+ //NOTE: If a Layer Definition has basic and composite types, then this offset will probably be wrong
+ //but such layers are technically illegal and we shouldn't try to be catering to such layers
+ if (compositeOffset < ftsc->GetCount())
+ MdfModel::CompositeTypeStyle* cts = dynamic_cast<MdfModel::CompositeTypeStyle*>(ftsc->GetAt(compositeOffset));
+ if (cts != NULL)
+ break;
+ return ret;
+MgByteReader* MgdLayer::GenerateLegendImage(double scale, INT32 width, INT32 height, CREFSTRING format, INT32 geomType, INT32 themeCategory)
+ MG_TRY()
+ Ptr<MgdMappingService> svcMapping = dynamic_cast<MgdMappingService*>(GetMap()->GetService(MgServiceType::MappingService));
+ ret = svcMapping->GenerateLegendImage(m_definition, scale, width, height, format, geomType, themeCategory);
bool MgdLayer::HasTooltips()
return MgLayerBase::HasTooltips();
Modified: trunk/MgDev/Desktop/MgDesktop/MapLayer/Layer.h
--- trunk/MgDev/Desktop/MgDesktop/MapLayer/Layer.h 2014-10-08 01:53:06 UTC (rev 8397)
+++ trunk/MgDev/Desktop/MgDesktop/MapLayer/Layer.h 2014-10-09 14:00:51 UTC (rev 8398)
@@ -47,6 +47,276 @@
virtual MgSpatialContextReader* GetSpatialContexts(bool active);
+ /// \brief
+ /// Gets the list of geometry type styles for this layer at the map's current scale. Returns NULL if there are no applicable geometry types
+ /// <!-- Syntax in .Net, Java, and PHP -->
+ /// \htmlinclude DotNetSyntaxTop.html
+ /// virtual MgIntCollection GetGeometryTypeStyles();
+ /// \htmlinclude SyntaxBottom.html
+ /// \htmlinclude JavaSyntaxTop.html
+ /// \htmlinclude PHPSyntaxTop.html
+ /// \remarks
+ /// The map's current scale is used to determine what scale range in the layer definition to search for.
+ /// For a scale range with multiple composite styles, multiple instances of (4 = composite) will be in the resulting collection
+ /// \return
+ /// The list of geometry type styles for this layer at the map's current scale. Returns NULL if there are no applicable geometry types
+ /// \since 3.0
+ MgIntCollection* GetGeometryTypeStyles();
+ /// \brief
+ /// Gets the number of theme categories for this layer at the map's current scale for the given geometry type style. A count greater than 1 indicates a themed layer. Returns -1 if there are no applicable styles at the current scale
+ /// virtual int GetThemeCategoryCount(int geomType);
+ /// \param geomType (int)
+ /// The geometry type
+ /// \remarks
+ /// When geomType = 4, it will only count the number of the theme categories for the first composite style it finds. For a scale range
+ /// with multiple composite type styles, you should use GetCompositeThemeCategoryCount() instead
+ /// \return
+ /// The number of theme categories for this layer at the map's current scale for the given geometry type style. A count greater than 1 indicates a themed layer. Returns -1 if there are no applicable styles at the current scale
+ /// \since 3.0
+ INT32 GetThemeCategoryCount(INT32 geomType);
+ /// \brief
+ /// Gets the number of composite theme categories for this layer at the map's current scale for the given composite style. A count greater than 1 indicates a themed layer. Returns -1 if there are no applicable styles at the current scale
+ /// virtual int GetThemeCategoryCount(double scale, int geomType);
+ /// \param compositeOffset (int)
+ /// The zero-based index denoting the particular composite style to count from. 0 = 1st composite style, 1 = 2nd composite style
+ /// \return
+ /// The number of theme categories for this layer at the map's current scale for the given composite style. A count greater than 1 indicates a themed layer. Returns -1 if there are no applicable styles at the current scale
+ /// \since 3.0
+ INT32 GetCompositeThemeCategoryCount(INT32 compositeOffset);
+ /// \brief
+ /// Returns the legend image for the specified geometry type and theme category
+ /// virtual MgByteReader GenerateLegendImage(int width, int height, string format, int geomType, int themeCategory);
+ /// virtual MgByteReader GenerateLegendImage(int width, int height, String format, int geomType, int themeCategory);
+ /// \param resource (MgResourceIdentifier)
+ /// Input
+ /// MgResourceIdentifier object identifying the layer definition resource.
+ /// \param scale (double)
+ /// Input
+ /// The scale at which the symbolization is requested.
+ /// \param width (int)
+ /// Input
+ /// The requested image width in pixels.
+ /// \param height (int)
+ /// Input
+ /// The requested image height in pixels.
+ /// \param format (String/string)
+ /// Input
+ /// Image format, from MgImageFormats. Example: PNG, JPG, PNG8, etc
+ /// Input
+ /// The type of symbolization required: 1=Point, 2=Line, 3=Area, 4=Composite
+ /// \param themeCategory (int)
+ /// Input
+ /// The value indicating which theme category swatch to return.
+ /// Used when there is a theme defined at this scale. An exception will be
+ /// thrown if a requested them category doesn't exist.
+ /// \remarks
+ /// \return
+ /// Returns a stream representing the legend image.
+ /// The default returned image format will be PNG8 unless a different supported
+ /// format is requested. An exception will be thrown if an unsupported image
+ /// \exception MgArgumentOutOfRangeException
+ /// \exception MgInvalidResourceTypeException
+ /// \exception MgNullArgumentException
+ /// \exception MgInvalidImageFormatException
+ /// \since 3.0
+ MgByteReader* GenerateLegendImage(INT32 width, INT32 height, CREFSTRING format, INT32 geomType, INT32 themeCategory);
+ /// \brief
+ /// virtual MgIntCollection GetGeometryTypeStyles(double scale);
+ /// The scale at which to retrive the list of applicable geometry types
+ /// \remarks
+ /// \return
+ /// \since 3.0
+ MgIntCollection* GetGeometryTypeStyles(double scale);
+ /// \brief
+ /// The scale at which to count the number of applicable theme categories
+ /// \remarks
+ /// \return
+ /// \since 3.0
+ INT32 GetThemeCategoryCount(double scale, INT32 geomType);
+ /// \brief
+ /// \return
+ /// \since 3.0
+ INT32 GetCompositeThemeCategoryCount(double scale, INT32 compositeOffset);
+ /// \brief
+ /// virtual MgByteReader GenerateLegendImage(double scale, int width, int height, string format, int geomType, int themeCategory);
+ /// virtual MgByteReader GenerateLegendImage(double scale, int width, int height, String format, int geomType, int themeCategory);
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// Input
+ /// \return
+ /// \since 3.0
+ MgByteReader* GenerateLegendImage(double scale, INT32 width, INT32 height, CREFSTRING format, INT32 geomType, INT32 themeCategory);
INTERNAL_API:
More information about the mapguide-commits
