[mapguide-commits] r8410 - trunk/MgDev
svn_mapguide at osgeo.org
Fri Oct 17 03:49:11 PDT 2014
Author: jng
Date: 2014-10-17 03:49:11 -0700 (Fri, 17 Oct 2014)
New Revision: 8410
trunk/MgDev/run_tests.sh
#2493: More fixes for PHP test execution/preparation. Also report overall unit test status at the end.
Modified: trunk/MgDev/run_tests.sh
--- trunk/MgDev/run_tests.sh 2014-10-17 09:38:28 UTC (rev 8409)
+++ trunk/MgDev/run_tests.sh 2014-10-17 10:49:11 UTC (rev 8410)
@@ -4,15 +4,22 @@
# run_tests.sh
# Simple wrapper script to execute all applicable tests on Linux
SERVER_FAST_SUBSET=1
-MG_INST=/usr/local/mapguideopensource
+MG_INST=/usr/local/mapguideopensource-3.0.0
PHP_CMD=$MG_INST/webserverextensions/php/bin/php
+USE_LOCAL_SERVER=1
TEST_SERVER=1
-TEST_PHP=0
+TEST_PHP=1
TEST_JAVA=1
LOG_PATH=~
TEST_COMPONENT=
MG_SERVER_PID=
+MG_SERVER_WAIT=30
+WEB_SERVER_PID=
+WEB_SERVER_ADDR=localhost
+WEB_SERVER_PORT=8018
+WEB_SERVER_WAIT=15
check_test()
@@ -20,26 +27,46 @@
if [ $error -ne 0 ]; then
echo "[warning]: ${TEST_COMPONENT} - Test returned non-zero result ($error)"
echo "[warning]: ${TEST_COMPONENT} - Test returned non-zero result ($error)" >> $LOG_PATH/unit_test_status.log
+ else
+ echo "[test]: ${TEST_COMPONENT} - Test returned exit code ($error)"
fi
+start_php_web_server()
+ echo "[web server]: Starting (with ${WEB_SERVER_WAIT}s wait)"
+ $PHP_CMD -d upload_max_filesize=20M -S "$WEB_SERVER_ADDR:$WEB_SERVER_PORT" -t UnitTest/WebTier/MapAgent/MapAgentForms UnitTest/WebTier/Php/MapAgentShim/index.php > $LOG_PATH/php_web_server.log 2>&1 &
+ WEB_SERVER_PID=$!
+ # Give some time for the mgserver to actually fully initialize
+ sleep $WEB_SERVER_WAIT
+ echo "[web server]: Started ($WEB_SERVER_PID)"
+stop_php_web_server()
+ echo "[web server]: Stopping"
+ kill $WEB_SERVER_PID
+ echo "[web server]: Stopped ($WEB_SERVER_PID)"
+ WEB_SERVER_PID=
start_mapguide_server()
pushd Server/src/Core > /dev/null
- echo "[test]: Start mgserver (with 30s wait)"
+ echo "[mgserver]: Starting (with ${MG_SERVER_WAIT}s wait)"
./mgserver run > $LOG_PATH/mapguide_server_run.log 2>&1 &
MG_SERVER_PID=$!
- sleep 30
- echo "[test]: mgserver started ($MG_SERVER_PID)"
+ sleep $MG_SERVER_WAIT
+ echo "[mgserver]: Started ($MG_SERVER_PID)"
popd > /dev/null
stop_mapguide_server()
- echo "[test]: Stop mgserver"
+ echo "[mgserver]: Stopping"
kill $MG_SERVER_PID
- echo "[test]: mgserver stopped ($MG_SERVER_PID)"
+ echo "[mgserver]: Stopped ($MG_SERVER_PID)"
MG_SERVER_PID=
@@ -48,13 +75,16 @@
echo "[build]: Server unit tests"
pushd Server/src/UnitTesting > /dev/null
-make libMgUnitTesting.la
+make libMgUnitTesting.la 2>&1 > /dev/null
popd > /dev/null
-make unittest.sh
+make unittest.sh 2>&1 > /dev/null
popd > /dev/null
+# Clear existing status log file
+rm -f $LOG_PATH/unit_test_status.log
if [ $TEST_SERVER -eq 1 ]; then
if [ $SERVER_FAST_SUBSET -eq 1 ]; then
@@ -91,12 +121,30 @@
rm -rf DrawingService/DrawingServiceTest.db
rm -rf ResourceService/ResourceServiceTest.db
popd > /dev/null
- pushd UnitTest\WebTier\Php > /dev/null
+ if [ $USE_LOCAL_SERVER -eq 1 ]; then
+ start_mapguide_server
+ start_php_web_server
+ fi
+ pushd UnitTest > /dev/null
+ TEST_COMPONENT="Prepare PHP test suite"
+ echo "[test]: $TEST_COMPONENT"
+ $PHP_CMD prepare.php
+ check_test
+ popd > /dev/null
+ pushd UnitTest/WebTier/Php > /dev/null
TEST_COMPONENT="PHP Web Tier Tests"
- $PHP_CMD RunTests.php
+ # Inject these vars into $_SERVER in PHP CLI
+ export SERVER_ADDR=$WEB_SERVER_ADDR
+ export SERVER_PORT=$WEB_SERVER_PORT
+ export WEBCONFIGINI=$PWD/../../webconfig.ini
+ $PHP_CMD RunTests.php 2>&1 | tee $LOG_PATH/php_test.log
check_test
popd > /dev/null
+ stop_mapguide_server
+ stop_php_web_server
+ fi
fi
if [ $TEST_JAVA -eq 1 ]; then
@@ -114,12 +162,24 @@
popd > /dev/null
- start_mapguide_server
+ fi
pushd UnitTest/WebTier/Java > /dev/null
TEST_COMPONENT="Java Web Tier Tests"
- ant checkunix 2>&1 | tee $LOG_PATH/java_test_output.log
+ ant checkunix -l $LOG_PATH/java_test_output.log
check_test
popd > /dev/null
- stop_mapguide_server
+ fi
fi
+if [ -f "$LOG_PATH/unit_test_status.log" ]; then
+ echo "[warning]: One or more tests did not fully pass. Overall status results shown below:"
+ cat $LOG_PATH/unit_test_status.log
+ echo "[warning]: Check $LOG_PATH for additional logs and test results"
+else
+ echo "[test]: No overall warnings logged. Tests look OK. Check logged files in $LOG_PATH for more information"
+fi
More information about the mapguide-commits
