[mapguide-commits] r8412 - trunk/MgDev/Server/src/Core
svn_mapguide at osgeo.org
Fri Oct 17 04:23:24 PDT 2014
Author: jng
Date: 2014-10-17 04:23:23 -0700 (Fri, 17 Oct 2014)
New Revision: 8412
trunk/MgDev/Server/src/Core/serverconfig.ini
Add default LinuxFontDirectories with known msttcorefonts paths to the default serverconfig.ini. If the user has msttcorefonts installed on Linux, then a default MapGuide install should be able to find these fonts.
Modified: trunk/MgDev/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2014-10-17 11:02:34 UTC (rev 8411)
+++ trunk/MgDev/Server/src/Core/serverconfig.ini 2014-10-17 11:23:23 UTC (rev 8412)
@@ -47,6 +47,8 @@
# FdoPath Path where FDO is installed
# LicenseServerPath The path to the License server (not used by MapGuide Open Source)
# 0 <= Length <= 255
+# LinuxFontDirectories A colon-separated (:) list of directories to search for additional fonts on Linux
+# Has no effect on Windows
# Locale The server's locale. If left blank it will default to the operating system locale
# Format : lang[_country_region.code_page]
@@ -90,6 +92,7 @@
DisplayName =
FdoPath = FDO/
LicenseServerPath = @localhost
+LinuxFontDirectories = /usr/share/fonts/truetype/msttcorefonts:/usr/share/fonts/msttcore
Locale =
LogsDelimiter = \t
LogsDetail =
More information about the mapguide-commits
