[mapguide-commits] r8430 - in trunk/MgDev: . Oem/LinuxApt
svn_mapguide at osgeo.org
Tue Oct 21 08:23:53 PDT 2014
Author: jng
Date: 2014-10-21 08:23:52 -0700 (Tue, 21 Oct 2014)
New Revision: 8430
Added:
trunk/MgDev/Oem/LinuxApt/apache-tomcat-7.0.56.tar.gz
trunk/MgDev/Oem/LinuxApt/apr-1.5.1.tar.bz2
trunk/MgDev/Oem/LinuxApt/apr-util-1.5.4.tar.bz2
trunk/MgDev/Oem/LinuxApt/httpd-2.4.10.tar.bz2
trunk/MgDev/Oem/LinuxApt/php-5.5.17.tar.bz2
trunk/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.40-src.tar.gz
Removed:
trunk/MgDev/Oem/LinuxApt/apache-tomcat-7.0.42.tar.gz
trunk/MgDev/Oem/LinuxApt/apr-1.4.8.tar.bz2
trunk/MgDev/Oem/LinuxApt/apr-util-1.5.2.tar.bz2
trunk/MgDev/Oem/LinuxApt/httpd-2.4.9.tar.bz2
trunk/MgDev/Oem/LinuxApt/php-5.5.11.tar.bz2
trunk/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.37-src.tar.gz
trunk/MgDev/Oem/LinuxApt/build_apt.sh
trunk/MgDev/prepare_webtier_components.bat
trunk/MgDev/setenvironment.bat
trunk/MgDev/setenvironment64.bat
RFC 147: Update Apache, Tomcat and PHP tarballs in LinuxApt. Update our windows batch files to match these updated versions. This may or may not break the linux build. Will follow up after this submission.
Deleted: trunk/MgDev/Oem/LinuxApt/apache-tomcat-7.0.42.tar.gz
(Binary files differ)
Added: trunk/MgDev/Oem/LinuxApt/apache-tomcat-7.0.56.tar.gz
Property changes on: trunk/MgDev/Oem/LinuxApt/apache-tomcat-7.0.56.tar.gz
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Deleted: trunk/MgDev/Oem/LinuxApt/apr-1.4.8.tar.bz2
Added: trunk/MgDev/Oem/LinuxApt/apr-1.5.1.tar.bz2
Property changes on: trunk/MgDev/Oem/LinuxApt/apr-1.5.1.tar.bz2
Deleted: trunk/MgDev/Oem/LinuxApt/apr-util-1.5.2.tar.bz2
Added: trunk/MgDev/Oem/LinuxApt/apr-util-1.5.4.tar.bz2
Property changes on: trunk/MgDev/Oem/LinuxApt/apr-util-1.5.4.tar.bz2
Modified: trunk/MgDev/Oem/LinuxApt/build_apt.sh
--- trunk/MgDev/Oem/LinuxApt/build_apt.sh 2014-10-21 15:09:59 UTC (rev 8429)
+++ trunk/MgDev/Oem/LinuxApt/build_apt.sh 2014-10-21 15:23:52 UTC (rev 8430)
@@ -15,8 +15,8 @@
INSTALLDIR=/usr/local/mapguideopensource
-HTTPD_VER=2.4.9
-PHP_VER=5.5.11
+HTTPD_VER=2.4.10
+PHP_VER=5.5.17
PORT=8008
TOMCAT=0
TOMCAT_PORT=8009
@@ -144,12 +144,12 @@
echo "Apache Httpd build started"
tar -jxf httpd-$HTTPD_VER.tar.bz2
if [ ! -d "httpd-$HTTPD_VER/srclib/apr" ]; then
- tar -jxf apr-1.4.8.tar.bz2
- mv apr-1.4.8 httpd-$HTTPD_VER/srclib/apr
+ tar -jxf apr-1.5.1.tar.bz2
+ mv apr-1.5.1 httpd-$HTTPD_VER/srclib/apr
fi
if [ ! -d "httpd-$HTTPD_VER/srclib/aprutil" ]; then
- tar -jxf apr-util-1.5.2.tar.bz2
- mv apr-util-1.5.2 httpd-$HTTPD_VER/srclib/apr-util
+ tar -jxf apr-util-1.5.4.tar.bz2
+ mv apr-util-1.5.4 httpd-$HTTPD_VER/srclib/apr-util
fi
pushd httpd-$HTTPD_VER
./configure --prefix=$INSTALLWEB/apache2 --enable-mods-shared=all \
@@ -255,8 +255,8 @@
if [ "$TOMCAT" = "1" ]; then
echo "Tomcat connector build/install started"
-tar -zxf tomcat-connectors-1.2.37-src.tar.gz
-pushd tomcat-connectors-1.2.37-src/native
+tar -zxf tomcat-connectors-1.2.40-src.tar.gz
+pushd tomcat-connectors-1.2.40-src/native
./configure --with-apxs=$INSTALLWEB/apache2/bin/apxs
check_tomcat_build
@@ -274,10 +274,10 @@
echo "Tomcat install started"
-tar -zxf apache-tomcat-7.0.42.tar.gz -C $INSTALLWEB
+tar -zxf apache-tomcat-7.0.56.tar.gz -C $INSTALLWEB
check_tomcat_install
pushd $INSTALLWEB
-mv apache-tomcat-7.0.42 tomcat
+mv apache-tomcat-7.0.56 tomcat
popd
echo "Tomcat install completed"
Added: trunk/MgDev/Oem/LinuxApt/httpd-2.4.10.tar.bz2
Property changes on: trunk/MgDev/Oem/LinuxApt/httpd-2.4.10.tar.bz2
Deleted: trunk/MgDev/Oem/LinuxApt/httpd-2.4.9.tar.bz2
Deleted: trunk/MgDev/Oem/LinuxApt/php-5.5.11.tar.bz2
Added: trunk/MgDev/Oem/LinuxApt/php-5.5.17.tar.bz2
Property changes on: trunk/MgDev/Oem/LinuxApt/php-5.5.17.tar.bz2
Deleted: trunk/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.37-src.tar.gz
Added: trunk/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.40-src.tar.gz
Property changes on: trunk/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.40-src.tar.gz
Modified: trunk/MgDev/prepare_webtier_components.bat
--- trunk/MgDev/prepare_webtier_components.bat 2014-10-21 15:09:59 UTC (rev 8429)
+++ trunk/MgDev/prepare_webtier_components.bat 2014-10-21 15:23:52 UTC (rev 8430)
@@ -1,7 +1,7 @@
@echo off
SET SEVENZ=%CD%\BuildTools\WebTools\7-zip\7z.exe
-SET HTTPD_VER=2.4.9
-SET PHP_VER=5.5.11
+SET HTTPD_VER=2.4.10
+SET PHP_VER=5.5.17
pushd Oem\LinuxApt
:check_httpd
if not exist httpd-%HTTPD_VER% goto unpack_httpd
Modified: trunk/MgDev/setenvironment.bat
--- trunk/MgDev/setenvironment.bat 2014-10-21 15:09:59 UTC (rev 8429)
+++ trunk/MgDev/setenvironment.bat 2014-10-21 15:23:52 UTC (rev 8430)
@@ -99,9 +99,9 @@
call prepare_webtier_components.bat
rem Set the env vars that VS will reference
-SET PHP_SRC=%MG_OEM%\LinuxApt\php-5.5.11
+SET PHP_SRC=%MG_OEM%\LinuxApt\php-5.5.17
SET PHP_LIB=%MG_OEM%\php\Release_TS
-SET HTTPD_SRC=%MG_OEM%\LinuxApt\httpd-2.4.9
+SET HTTPD_SRC=%MG_OEM%\LinuxApt\httpd-2.4.10
SET HTTPD_LIB=%MG_OEM%\httpd\lib
rem Sanity checks
if not exist "%PHP_SRC%" echo Environment variable PHP_SRC does not point to a valid directory (%PHP_SRC%). Please edit setenvironment64.bat to ensure PHP_SRC points to a valid directory
Modified: trunk/MgDev/setenvironment64.bat
--- trunk/MgDev/setenvironment64.bat 2014-10-21 15:09:59 UTC (rev 8429)
+++ trunk/MgDev/setenvironment64.bat 2014-10-21 15:23:52 UTC (rev 8430)
@@ -104,9 +104,9 @@
SET PHP_LIB=%MG_OEM%\php\x64\Release_TS
SET HTTPD_LIB=%MG_OEM%\httpd\lib64
rem Sanity checks
More information about the mapguide-commits
