[mapguide-commits] r8435 - in sandbox/adsk/2.5k/Web/src: CgiAgent IsapiAgent
svn_mapguide at osgeo.org
Wed Oct 29 17:19:01 PDT 2014
Author: hubu
Date: 2014-10-29 17:19:00 -0700 (Wed, 29 Oct 2014)
New Revision: 8435
sandbox/adsk/2.5k/Web/src/CgiAgent/CgiPostParser.cpp
sandbox/adsk/2.5k/Web/src/IsapiAgent/IsapiPostParser.cpp
#2199, merge r7257 to adsk/2.5k branch.
Modified: sandbox/adsk/2.5k/Web/src/CgiAgent/CgiPostParser.cpp
--- sandbox/adsk/2.5k/Web/src/CgiAgent/CgiPostParser.cpp 2014-10-24 17:22:48 UTC (rev 8434)
+++ sandbox/adsk/2.5k/Web/src/CgiAgent/CgiPostParser.cpp 2014-10-30 00:19:00 UTC (rev 8435)
@@ -122,26 +122,33 @@
string content = contentType;
DumpMessage("Content type: %s", content.c_str());
+ if (content.empty())
+ params->SetXmlPostData("");
if (content.find(MapAgentStrings::UrlEncoded) == 0)
- m_buf[nBytes] = '\0';
+ if (nBytes > 0)
+ m_buf[nBytes] = '\0';
- // Here's another case of interoperability "Forgiveness
- // and Tolerance": degree, among other clients, sends along
- // a POST with xml contents, but fails to correctly set the
- // mime type. You guessed it: it says it's url-encoded.
- // If we got here, but determine that the contents look
- // and feel like XML, it's a safe bet that it should
- // be treated like XML. Otherwise, we assume the
- // content-type is probably correct. (Note that
- // the IsXmlPi should conveniently fail if it really IS
- // url-encoded, since the question mark in <?xml...?>
- // should itself be url-encoded: <%3Fxml... )
- if(IsXmlPi(m_buf))
- params->SetXmlPostData(m_buf);
- else
- MapAgentGetParser::Parse(m_buf, params);
+ // Here's another case of interoperability "Forgiveness
+ // and Tolerance": degree, among other clients, sends along
+ // a POST with xml contents, but fails to correctly set the
+ // mime type. You guessed it: it says it's url-encoded.
+ // If we got here, but determine that the contents look
+ // and feel like XML, it's a safe bet that it should
+ // be treated like XML. Otherwise, we assume the
+ // content-type is probably correct. (Note that
+ // the IsXmlPi should conveniently fail if it really IS
+ // url-encoded, since the question mark in <?xml...?>
+ // should itself be url-encoded: <%3Fxml... )
+ if(IsXmlPi(m_buf))
+ params->SetXmlPostData(m_buf);
+ else
+ MapAgentGetParser::Parse(m_buf, params);
else if (content.find(MapAgentStrings::MultiPartForm) != content.npos)
Modified: sandbox/adsk/2.5k/Web/src/IsapiAgent/IsapiPostParser.cpp
--- sandbox/adsk/2.5k/Web/src/IsapiAgent/IsapiPostParser.cpp 2014-10-24 17:22:48 UTC (rev 8434)
+++ sandbox/adsk/2.5k/Web/src/IsapiAgent/IsapiPostParser.cpp 2014-10-30 00:19:00 UTC (rev 8435)
@@ -117,26 +117,33 @@
string content = m_pECB->lpszContentType;
- m_pBuffer[dwTotalBytes] = '\0'; // null terminate
+ if (dwTotalBytes > 0)
+ m_pBuffer[dwTotalBytes] = '\0'; // null terminate
- if (MapAgentCommon::IsXmlPi((char *)m_pBuffer))
- params->SetXmlPostData((char *)m_pBuffer);
- else
- MapAgentGetParser::Parse((char *)m_pBuffer, params);
+ if (MapAgentCommon::IsXmlPi((char *)m_pBuffer))
+ params->SetXmlPostData((char *)m_pBuffer);
+ else
+ MapAgentGetParser::Parse((char *)m_pBuffer, params);
More information about the mapguide-commits
