[mapguide-commits] r8370 - in trunk/Tools/Vagrant: . centos/x64 centos/x86 scripts sources/patches sources/patches/fdo/Thirdparty sources/patches/mapguide/Oem support ubuntu/x64 ubuntu/x86
svn_mapguide at osgeo.org
Tue Sep 30 04:37:11 PDT 2014
Author: jng
Date: 2014-09-30 04:37:11 -0700 (Tue, 30 Sep 2014)
New Revision: 8370
Added:
trunk/Tools/Vagrant/scripts/csmap_optimize.sh
trunk/Tools/Vagrant/scripts/dpkgfdo.sh
trunk/Tools/Vagrant/scripts/dpkgfdocore.sh
trunk/Tools/Vagrant/scripts/dpkgfdoprovider.sh
trunk/Tools/Vagrant/scripts/mapguidecommon_excludes.txt
trunk/Tools/Vagrant/scripts/mginstallcentos.sh
trunk/Tools/Vagrant/scripts/mginstallubuntu.sh
trunk/Tools/Vagrant/scripts/mguninstallubuntu.sh
trunk/Tools/Vagrant/scripts/platformbase_excludes.txt
trunk/Tools/Vagrant/scripts/prepare_dpkg_fdo.sh
Removed:
trunk/Tools/Vagrant/scripts/build_oem_ubuntu.sh
trunk/Tools/Vagrant/sources/patches/fdo/Thirdparty/boost/
trunk/Tools/Vagrant/sources/patches/mapguide/Oem/CsMap/
trunk/Tools/Vagrant/build.bat
trunk/Tools/Vagrant/centos/x64/Vagrantfile
trunk/Tools/Vagrant/centos/x86/Vagrantfile
trunk/Tools/Vagrant/clean.bat
trunk/Tools/Vagrant/scripts/build.sh
trunk/Tools/Vagrant/scripts/build_fdo.sh
trunk/Tools/Vagrant/scripts/dpkgbuild.sh
trunk/Tools/Vagrant/scripts/dpkgmapguide.sh
trunk/Tools/Vagrant/sources/patches/patchinfo.txt
trunk/Tools/Vagrant/support/apt_list.txt
trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile
trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile
Sync vagrant configurations to match trunk
Modified: trunk/Tools/Vagrant/build.bat
--- trunk/Tools/Vagrant/build.bat 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/build.bat 2014-09-30 11:37:11 UTC (rev 8370)
@@ -1,4 +1,12 @@
@echo off
+rem build.bat
+rem
+rem Builds MapGuide/FDO in CentOS and Ubuntu VMs all driven by vagrant
+rem
+rem NOTE: CentOS builds must *always* precede the Ubuntu builds as Ubuntu builds may depend
+rem on the package FDO SDK tarball produced by the CentOS build
SET BUILD_UBUNTU_32=1
SET BUILD_UBUNTU_64=0
SET BUILD_CENTOS_32=1
@@ -9,16 +17,45 @@
SET TEARDOWN_CENTOS_64=0
SET ROOT=%CD%
SET COMPONENT=
+echo **************** Build Summary *********************
+echo Building Ubuntu (32-bit): %BUILD_UBUNTU_32% (teardown=%TEARDOWN_UBUNTU_32%)
+echo Building Ubuntu (64-bit): %BUILD_UBUNTU_64% (teardown=%TEARDOWN_UBUNTU_64%)
+echo Building CentOS (32-bit): %BUILD_CENTOS_32% (teardown=%TEARDOWN_CENTOS_32%)
+echo Building CentOS (64-bit): %BUILD_CENTOS_64% (teardown=%TEARDOWN_CENTOS_64%)
+echo ****************************************************
:prepare
echo [build]: Prepare scripts for provisioning
-if %BUILD_CENTOS_32% == 1 copy /Y scripts\*.* %ROOT%\centos\x86
-if %BUILD_UBUNTU_32% == 1 copy /Y scripts\*.* %ROOT%\ubuntu\x86
-if %BUILD_CENTOS_64% == 1 copy /Y scripts\*.* %ROOT%\centos\x64
-if %BUILD_UBUNTU_64% == 1 copy /Y scripts\*.* %ROOT%\ubuntu\x64
+if %BUILD_CENTOS_32% == 1 xcopy /S /Y /I scripts\* %ROOT%\centos\x86
+if %BUILD_UBUNTU_32% == 1 xcopy /S /Y /I scripts\* %ROOT%\ubuntu\x86
+if %BUILD_CENTOS_64% == 1 xcopy /S /Y /I scripts\* %ROOT%\centos\x64
+if %BUILD_UBUNTU_64% == 1 xcopy /S /Y /I scripts\* %ROOT%\ubuntu\x64
+:check_centos_32
+echo [build]: Checking if we're building for CentOS 32-bit
+if %BUILD_CENTOS_32% == 1 goto build_centos_32
+goto check_ubuntu_32
+:build_centos_32
+pushd centos\x86
+SET COMPONENT=CentOS Build 32-bit
+echo [build]: MapGuide CentOS build 32-bit
+if exist build rd /S /Q build
+call vagrant up
+echo [build]: vagrant returned %errorlevel%
+if "%errorlevel%"=="1" goto error
+if %TEARDOWN_CENTOS_32% == 1 (
+ echo [build]: Tearing down CentOS 32 VM
+ goto destroy_centos_32
+) else (
+ echo [build]: Not tearing down CentOS 32 VM
+ goto centos_32_done
+:destroy_centos_32
+call vagrant destroy -f
+:centos_32_done
+popd
:check_ubuntu_32
echo [build]: Checking if we're building for Ubuntu 32-bit
if %BUILD_UBUNTU_32% == 1 goto build_ubuntu_32
-goto check_centos_32
+goto check_centos_64
:build_ubuntu_32
pushd ubuntu\x86
SET COMPONENT=Ubuntu Build 32-bit
@@ -38,33 +75,33 @@
:ubuntu_32_done
popd
-:check_centos_32
-echo [build]: Checking if we're building for CentOS 32-bit
-if %BUILD_CENTOS_32% == 1 goto build_centos_32
+:check_centos_64
+echo [build]: Checking if we're building for CentOS 64-bit
+if %BUILD_CENTOS_64% == 1 goto build_centos_64
goto check_ubuntu_64
-:build_centos_32
-pushd centos\x86
-SET COMPONENT=CentOS Build 32-bit
-echo [build]: MapGuide CentOS build 32-bit
+:build_centos_64
+pushd centos\x64
+SET COMPONENT=CentOS Build 64-bit
+echo [build]: MapGuide CentOS build 64-bit
call vagrant up
-if %TEARDOWN_CENTOS_32% == 1 (
- echo [build]: Tearing down CentOS 32 VM
- goto destroy_centos_32
+if %TEARDOWN_CENTOS_64% == 1 (
+ echo [build]: Tearing down CentOS 64 VM
+ goto destroy_centos_64
) else (
- echo [build]: Not tearing down CentOS 32 VM
- goto centos_32_done
+ echo [build]: Not tearing down CentOS 64 VM
+ goto centos_64_done
-:destroy_centos_32
+:destroy_centos_64
-:centos_32_done
+:centos_64_done
popd
:check_ubuntu_64
echo [build]: Checking if we're building for Ubuntu 64-bit
if %BUILD_UBUNTU_64% == 1 goto build_ubuntu_64
-goto check_centos_64
+goto quit
:build_ubuntu_64
pushd ubuntu\x64
SET COMPONENT=Ubuntu Build 64-bit
@@ -84,30 +121,7 @@
:ubuntu_64_done
popd
-:check_centos_64
-echo [build]: Checking if we're building for CentOS 64-bit
-if %BUILD_CENTOS_64% == 1 goto build_centos_64
goto quit
-:build_centos_64
-pushd centos\x64
-SET COMPONENT=CentOS Build 64-bit
-echo [build]: MapGuide CentOS build 64-bit
-if exist build rd /S /Q build
-call vagrant up
-echo [build]: vagrant returned %errorlevel%
-if "%errorlevel%"=="1" goto error
-if %TEARDOWN_CENTOS_64% == 1 (
- echo [build]: Tearing down CentOS 64 VM
- goto destroy_centos_64
-) else (
- echo [build]: Not tearing down CentOS 64 VM
- goto centos_64_done
-:destroy_centos_64
-call vagrant destroy -f
-:centos_64_done
-popd
-goto quit
:error
echo [ERROR]: There was an error building the component %COMPONENT%
exit /B 1
Modified: trunk/Tools/Vagrant/centos/x64/Vagrantfile
--- trunk/Tools/Vagrant/centos/x64/Vagrantfile 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/centos/x64/Vagrantfile 2014-09-30 11:37:11 UTC (rev 8370)
@@ -126,6 +126,14 @@
exit $error
fi
+check_test()
+ error=$?
+ if [ $error -ne 0 ]; then
+ echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)"
+ echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)" >> ~/unit_test_status.log
+ fi
if hash scons 2>/dev/null; then
echo [provision]: We have scons
else
@@ -139,13 +147,22 @@
HAVE_FDO=0
HAVE_FDO_LIBS=0
HAVE_MAPGUIDE=0
-MG_UNIT_TEST=0
+MG_UNIT_TEST=1
+FDO_UNIT_TEST=1
+MAKE_FDO_SDK=0
SCRIPT_ROOT=~/scripts
FDO_SRC_ROOT=~/fdo
-FDO_SRC=$FDO_SRC_ROOT/trunk
+FDO_VER_MM=3.9
+FDO_VER_FULL=${FDO_VER_MM}.0
+MG_VER_MM=3.0
+MG_VER_FULL=${MG_VER_MM}.0
+FDO_SRC_DIR=trunk
+FDO_SRC=$FDO_SRC_ROOT/$FDO_SRC_DIR
FDO_LIB_SRC=~/fdo_rdbms_thirdparty
MG_SRC_ROOT=~/mapguide/trunk
MG_SRC=$MG_SRC_ROOT/MgDev
+FDO_TARBALL=fdo-checkout.tar.gz
+MG_TARBALL=mapguide-checkout.tar.gz
if [ -d $FDO_SRC ];
then
HAVE_FDO=1
@@ -158,12 +175,25 @@
then
HAVE_MAPGUIDE=1
fi
-echo [provision]: Checking all tools and libs are in place
-yum install -y gcc-* gd-* automake bison byacc flex doxygen expat expat-devel libtool libjpeg-devel libpng libpng-devel libxml2 libxml2-devel openssl curl curl-devel libxslt libxslt-devel subversion java-1.7.0-openjdk java-1.7.0-openjdk-devel ant dos2unix openssh-server openldap-devel alsa-lib-devel pcre-devel unixODBC-devel libcom_err-devel krb5-devel openssl-devel mysql-devel postgresql-devel unixODBC
+if [ -f /usr/include/asm/atomic.h ];
+then
+ echo [provision]: atomic.h exists. Doing nothing
+else
+ echo [provision]: Copy atomic.h
+ sudo mkdir -p /usr/include/asm
+ sudo cp /mapguide_sources/atomic.h /usr/include/asm
+fi
+#echo [provision]: Checking all tools and libs are in place
+#yum install -y gcc-* gd-* automake bison byacc flex doxygen expat expat-devel libtool libjpeg-devel libpng libpng-devel libxml2 libxml2-devel openssl curl curl-devel libxslt libxslt-devel subversion java-1.7.0-openjdk java-1.7.0-openjdk-devel ant dos2unix openssh-server openldap-devel alsa-lib-devel pcre-devel unixODBC-devel libcom_err-devel krb5-devel openssl-devel mysql-devel postgresql-devel unixODBC
+echo [provision]: Clean line endings
+sudo dos2unix /vagrant/*.sh
+sudo dos2unix /vagrant/*.pl
+sudo dos2unix /vagrant/*.txt
echo [provision]: Copying shell scripts
mkdir -p $SCRIPT_ROOT
cp -f /vagrant/*.sh $SCRIPT_ROOT
cp -f /vagrant/*.pl $SCRIPT_ROOT
+cp -f /vagrant/*.txt $SCRIPT_ROOT
echo [provision]: Flip Ubuntu switch
cd $SCRIPT_ROOT
sed -i 's/UBUNTU=1/UBUNTU=0/g' build.sh
@@ -179,15 +209,15 @@
fi
if [ $HAVE_FDO -eq 0 ];
then
- echo [provision]: Extracting FDO trunk working copy
- mkdir -p ~/fdo
- tar -zxf /mapguide_sources/fdo-checkout.tar.gz -C ~/fdo
+ echo [provision]: Extracting FDO working copy
+ mkdir -p $FDO_SRC_ROOT
+ tar -zxf /mapguide_sources/$FDO_TARBALL -C $FDO_SRC_ROOT
fi
if [ $HAVE_MAPGUIDE -eq 0 ];
then
- echo [provision]: Extracting MapGuide trunk working copy
+ echo [provision]: Extracting MapGuide working copy
mkdir -p $MG_SRC_ROOT
- tar -zxf /mapguide_sources/mapguide-checkout.tar.gz -C $MG_SRC_ROOT
+ tar -zxf /mapguide_sources/$MG_TARBALL -C $MG_SRC_ROOT
fi
echo [provision]: svn update FDO
BUILD_COMPONENT="svn update FDO"
@@ -207,6 +237,8 @@
echo [provision]: Applying MapGuide source patches
cp -R /mapguide_sources/patches/mapguide/* $MG_SRC
fi
+echo [provision]: Making sure swig is executable
+chmod +x $MG_SRC/Oem/SWIGEx/Linux/swig
cd ~/scripts
BUILD_COMPONENT="FDO"
sudo -E ./build_fdo.sh 2>&1 | tee ~/fdo_build.log
@@ -214,27 +246,99 @@
BUILD_COMPONENT="MapGuide"
sudo -E ./build.sh 2>&1 | tee ~/mapguide_build.log
check_build
+FDO_REV=`svn info $FDO_SRC | perl revnum.pl`
+MG_REV=`svn info $MG_SRC | perl revnum.pl`
+> ~/unit_test_status.log
+if [ $FDO_UNIT_TEST -eq 1 ];
+then
+ export NLSPATH=/usr/local/fdo-${FDO_VER_FULL}/nls/%N
+ echo [provision]: Unit test FDO
+ BUILD_COMPONENT="Unit Test FDO Core"
+ cd $SCRIPT_ROOT/fdo_build_area/Fdo/UnitTest
+ sudo -E ./UnitTest 2>&1 | tee ~/fdo_core_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test SHP Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/SHP/Src/UnitTest
+ sudo -E ./UnitTest 2>&1 | tee ~/fdo_shp_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test SDF Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/SDF/Src/UnitTest
+ sudo -E ./UnitTest 2>&1 | tee ~/fdo_sdf_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test SQLite Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/SQLite/Src/UnitTest
+ sudo -E ./UnitTest 2>&1 | tee ~/fdo_sqlite_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test GDAL Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/GDAL/Src/UnitTest
+ sudo -E ./UnitTest 2>&1 | tee ~/fdo_gdal_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test WMS Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/WMS/Src/UnitTest
+ sudo -E ./UnitTest 2>&1 | tee ~/fdo_wms_unit_test.log
+ check_test
+fi
if [ $MG_UNIT_TEST -eq 1 ];
then
echo [provision]: Unit test MapGuide
- cd $SCRIPT_ROOT/mgdev
- sudo make check 2>&1 | tee ~/mapguide_unit_test.log
+ BUILD_COMPONENT="Unit Test MapGuide Server"
+ # HACK: Tile and Resource Service tests are known to freeze our VMs when driven by vagrant (why? who knows?
+ # All we know is that those tests involve threads)
+ # So test everything *but* the above services. If required, this can be tested under a manually controlled
+ # VM
+ # build the individual targets that would comprise "make check" sans execution of unittest.sh
+ cd $SCRIPT_ROOT/mgdev/Server/src/UnitTesting
+ sudo make libMgUnitTesting.la
+ cd $SCRIPT_ROOT/mgdev/Server/src/Core
+ sudo make unittest.sh
+ # Run the test suites individually except for TileService/ResourceService for reasons already stated
+ for comp in CoordinateSystem FeatureService Geometry KmlService LogManager MdfModel Misc RenderingService ServerAdminService ServerManager ServiceManager SiteManager SiteService ProfilingService TransformMesh
+ do
+ sudo -E ./mgserver test $comp UnitTestResults_${comp}.xml 2>&1 | tee ~/mapguide_${comp}_unit_test.log
+ check_test
+ if [ -f UnitTestResults_${comp}.xml ]; then
+ sudo mv UnitTestResults_${comp}.xml ~/UnitTestResults_${comp}.xml
+ fi
+ done
fi
cd $SCRIPT_ROOT
+echo [provision]: Make output dir
sudo mkdir -p /vagrant/build
+echo [provision]: Copy log files to output dir
sudo mv -f ~/*.log /vagrant/build
+echo [provision]: Copy tarballs to output dir
sudo cp bin/*.tar.gz /vagrant/build
-sudo cp fdosdk*.tar.gz /vagrant/build
+sudo cp fdosdk-centos6-i386-${FDO_VER_FULL}_${FDO_REV}.tar.gz /vagrant/build
+if [ $MAKE_FDO_SDK -eq 1 ]; then
+ echo [provision]: Copy FDO SDK for Ubuntu builds
+ # Copy SDK also to sources, so Ubuntu can pick it up
+ sudo rm -f /mapguide_sources/fdosdk*.tar.gz
+ sudo cp fdosdk-centos6-amd64-${FDO_VER_FULL}_${FDO_REV}.tar.gz /mapguide_sources
+ # Record file name so Ubuntu knows what tarball to extract from
+ sudo echo fdosdk-centos6-amd64-${FDO_VER_FULL}_${FDO_REV}.tar.gz > /mapguide_sources/fdosdk_filename
+ sudo echo ${FDO_REV} > /mapguide_sources/fdosdk_rev
+ # Export filelist to Ubuntu can deb package this SDK if needed
+ sudo cp -R $SCRIPT_ROOT/fdo_build_area/install/filelist /mapguide_sources
+fi
+echo [provision]: Copy unit test logs to output dir
+sudo mv ~/unit_test_status.log /vagrant/build/unit_test_status.log
+sudo mv ~/fdo_*_unit_test.log /vagrant/build
+sudo mv ~/UnitTestResults_*.xml /vagrant/build
+echo [provision]: Copy install/uninstall scripts to output dir
+sudo cp /vagrant/mginstallcentos.sh /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/FDOVER_REV=0/FDOVER_REV='"$FDO_REV"'/g' /vagrant/build/mginstallcentos.sh
+sudo sed -i 's/MGVER_REV=0/MGVER_REV='"$MG_REV"'/g' /vagrant/build/mginstallcentos.sh
if [ ! -d /mapguide_sources/updated ]; then
sudo mkdir -p /mapguide_sources/updated
- cd ~/mapguide/trunk
+ cd $MG_SRC_ROOT
echo [provision]: Updating mapguide source tarball
- tar -zcf mapguide-checkout.tar.gz MgDev
- sudo mv mapguide-checkout.tar.gz /mapguide_sources/updated
- cd ~/fdo
+ tar -zcf $MG_TARBALL MgDev
+ sudo mv $MG_TARBALL /mapguide_sources/updated
+ cd $FDO_SRC_ROOT
echo [provision]: Updating fdo source tarball
- tar -zcf fdo-checkout.tar.gz trunk
- sudo mv fdo-checkout.tar.gz /mapguide_sources/updated
+ tar -zcf $FDO_TARBALL $FDO_SRC_DIR
+ sudo mv $FDO_TARBALL /mapguide_sources/updated
else
echo [provision]: Updated tarballs already exist. Doing nothing
fi
Modified: trunk/Tools/Vagrant/centos/x86/Vagrantfile
--- trunk/Tools/Vagrant/centos/x86/Vagrantfile 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/centos/x86/Vagrantfile 2014-09-30 11:37:11 UTC (rev 8370)
exit $error
fi
+check_test()
+ error=$?
+ fi
else
HAVE_FDO=0
HAVE_FDO_LIBS=0
HAVE_MAPGUIDE=0
-MG_UNIT_TEST=0
+MG_UNIT_TEST=1
+FDO_UNIT_TEST=1
+MAKE_FDO_SDK=0
FDO_SRC_ROOT=~/fdo
+FDO_VER_MM=3.9
+MG_VER_MM=3.0
+FDO_SRC_DIR=trunk
if [ -d $FDO_SRC ];
then
HAVE_FDO=1
then
HAVE_MAPGUIDE=1
fi
+then
+else
+fi
cd $SCRIPT_ROOT
fi
then
- mkdir -p ~/fdo
fi
then
fi
@@ -207,6 +237,8 @@
fi
cd ~/scripts
check_build
+then
+ check_test
+ check_test
+ check_test
+ check_test
+ check_test
+ check_test
+fi
then
+ # VM
+ do
+ check_test
+ fi
+ done
fi
cd $SCRIPT_ROOT
+ sudo cp fdosdk-centos6-i386-${FDO_VER_FULL}_${FDO_REV}.tar.gz /mapguide_sources
+ sudo echo fdosdk-centos6-i386-${FDO_VER_FULL}_${FDO_REV}.tar.gz > /mapguide_sources/fdosdk_filename
+fi
+ cd $MG_SRC_ROOT
- cd ~/fdo
+ cd $FDO_SRC_ROOT
else
fi
Modified: trunk/Tools/Vagrant/clean.bat
--- trunk/Tools/Vagrant/clean.bat 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/clean.bat 2014-09-30 11:37:11 UTC (rev 8370)
@@ -1,36 +1,51 @@
@echo off
SET ROOT=%CD%
SET COMPONENT=
+pushd sources
+if exist updated rd /S /Q updated
+if exist filelist rd /S /Q filelist
+if exist fdosdk_filename del /F fdosdk_filename
+if exist fdosdk_rev del /F fdosdk_rev
+del /F fdosdk*.tar.gz
+popd
pushd ubuntu\x86
echo [clean]: MapGuide Ubuntu build 32-bit
if exist *.sh del *.sh
if exist *.pl del *.pl
+if exist *.txt del *.txt
popd
pushd centos\x86
echo [clean]: MapGuide CentOS build 32-bit
popd
pushd ubuntu\x64
echo [clean]: MapGuide Ubuntu build 64-bit
popd
pushd centos\x64
echo [clean]: MapGuide CentOS build 64-bit
popd
goto quit
Modified: trunk/Tools/Vagrant/scripts/build.sh
--- trunk/Tools/Vagrant/scripts/build.sh 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/scripts/build.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -1,10 +1,11 @@
#!/bin/bash
# Global vars for this script. Modify as necessary
-APIVERSION=2.6
+APIVERSION=3.0
BUILDNUM=${APIVERSION}.0
BUILDROOT=`pwd`
MGCPUPLATFORM=i386
+MGDEBUG=0
INSTALLROOT=/usr/local/mapguideopensource-${BUILDNUM}
#INSTALLROOT=/usr/local/mapguideopensource-trunk
LOCKFILEDIR=/var/lock/mgserver
@@ -26,6 +27,7 @@
echo " SVN Source is: ${SVNROOT}${SVNRELPATH}"
echo " Make Options: ${MY_MAKE_OPTS}"
echo " Is Ubuntu?: ${UBUNTU}"
+echo " Debug Build?: ${MGDEBUG}"
echo " Preserving the build dir?: ${PRESERVE_BUILD_ROOT}"
echo " JAVA_HOME: ${JAVA_HOME}"
echo "******************************************************************"
@@ -61,7 +63,7 @@
then
if [ ! -d ${MGSOURCE} ];
then
- echo "Build root ${MGSOURCE} does not exist. Doing svn export"
+ echo "Build root ${MGSOURCE} does not exist. Doing svn export"
fi
echo "Exporting svn revision ${REVISION}"
if [ ${LOCALSVN} -eq 1 ]
@@ -69,15 +71,53 @@
echo "Making local SVN copy of ${SVNROOT}${SVNRELPATH} to ${MGSOURCE}"
cp -R ${SVNROOT}${SVNRELPATH} ${MGSOURCE}
echo "Cleaning out .svn directories"
- pushd ${MGSOURCE}
+ pushd ${MGSOURCE}
find . -name .svn -exec rm -rf {} \;
- popd
+ popd
else
echo "Performing fresh SVN export of ${SVNROOT}${SVNRELPATH} (r${REVISION}) to ${MGSOURCE}"
svn export -q -r ${REVISION} ${SVNROOT}${SVNRELPATH} ${MGSOURCE}
fi
fi
+if [ ${UBUNTU} -eq 1 ];
+then
+ echo "[info]: Performing Ubuntu-specific modifications"
+ # GCC 4.8 is causing too much instability, so downgrade one version
+ #GCCVER=4.7
+ #export GCCVER
+ #CC=gcc-$GCCVER
+ #export CC
+ #CXX=g++-$GCCVER
+ #export CXX
+ #echo "[info]: Using GCC $GCCVER for Ubuntu"
+ # Patch some build scripts and makefiles to accept our chosen compiler
+ # CS-Map Dictionary Compiler
+ #echo "[info]: Patch CS-Map compiler makefile"
+ #sed -i 's/gcc \$/'"$CC"' \$/g' ${MGSOURCE}/Oem/CsMap/Dictionaries/Compiler.mak
+ #sed -i 's/gcc -v/'"$CC"' -v/g' ${MGSOURCE}/Oem/CsMap/Dictionaries/Compiler.mak
+ # libpng makefile
+ #echo "[info]: Patch libpng makefile"
+ #sed -i 's/CC=cc/CC='"$CC"'/g' ${MGSOURCE}/Oem/gd/lpng/scripts/makefile.std
+ # AGG 2.4 Linux Makefile
+ #echo "[info]: Replace agg-2.4 makefile"
+ #echo "AGGLIBS= -lagg " > ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+ #echo "AGGCXXFLAGS = -O3 -I/usr/X11R6/include -L/usr/X11R6/lib" >> ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+ #echo "CXX = $CXX" >> ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+ #echo "C = $CC" >> ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+ #echo "LIB = ar cr" >> ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+ #echo "" >> ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+ #echo ".PHONY : clean" >> ${MGSOURCE}/Oem/agg-2.4/Makefile.in.Linux
+else
+ echo "[info]: Performing CentOS-specific modifications"
+ #sed -i 's/sh .\/buildall.sh/sh .\/buildall.sh --with-xerces-conf=--enable-transcoder-iconv/g' ${MGSOURCE}/build_oem.sh
+ #sed -i 's/sh .\/buildall.sh --with-xerces-conf=--enable-transcoder-iconv --clean/sh .\/buildall.sh --clean/g' ${MGSOURCE}/build_oem.sh
+fi
start_time=`date +%s`
echo "Building Revision ${BUILDNUM}.${REVISION}"
@@ -89,6 +129,7 @@
echo 'const STRING ApiVersion = L"'${APIVERSION}'";' >> ${VERFILE}
echo '#endif' >> ${VERFILE}
+# Note: Remove for trunk as this has been included into build_oem.sh
echo "Building LinuxApt"
pushd ${MGSOURCE}/Oem/LinuxApt
BUILD_COMPONENT="LinuxApt"
@@ -98,9 +139,25 @@
echo "Building Oem"
BUILD_COMPONENT="Oem"
-./build_oem.sh --prefix ${INSTALLROOT}
-check_build
+if [ $(uname -m) = "x86_64" ]; then
+ if [ ${MGDEBUG} -eq 1 ]; then
+ ./build_oem.sh --prefix ${INSTALLROOT} --build 64 --config debug
+ check_build
+ else
+ check_build
+ fi
+else
+ ./build_oem.sh --prefix ${INSTALLROOT} --config debug
+ check_build
+ else
+ check_build
+ fi
+fi
echo "Building Fusion"
pushd ${MGSOURCE}/Oem/fusion
BUILD_COMPONENT="Fusion"
@@ -117,10 +174,18 @@
autoconf
MGCPUPLATFORM=amd64
- ./configure --enable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT}
+ ./configure --disable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT}
+ else
+ ./configure --enable-optimized --enable-silent-rules --enable-64bit --prefix=${INSTALLROOT}
+ fi
else
MGCPUPLATFORM=i386
- ./configure --enable-optimized --enable-silent-rules --prefix=${INSTALLROOT}
+ ./configure --disable-optimized --enable-silent-rules --prefix=${INSTALLROOT}
+ else
+ ./configure --enable-optimized --enable-silent-rules --prefix=${INSTALLROOT}
+ fi
fi
make $MY_MAKE_OPTS
check_build
Modified: trunk/Tools/Vagrant/scripts/build_fdo.sh
--- trunk/Tools/Vagrant/scripts/build_fdo.sh 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/scripts/build_fdo.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -7,6 +7,8 @@
# Modify setenvironment.sh to point to the correct Oracle, MySQL and PostgreSQL paths
# before building
+FDO_DEBUG=0
FDO_BUILD_COMPONENT=
# FDO version. Make sure this matches your FDO build source
@@ -14,6 +16,14 @@
FDO_VER_MINOR=9
FDO_VER_REV=0
+# Extra flags to pass to FDO build scripts
+FDO_BUILD_FLAGS=
+if [ $FDO_DEBUG -eq 1 ]; then
+ FDO_BUILD_FLAGS="--config debug"
+else
+ FDO_BUILD_FLAGS="--config release"
+fi
UBUNTU=0
FDO_CPU=x86
FDO_PLATFORM=32
@@ -26,65 +36,65 @@
check_build()
- error=$?
- if [ $error -ne 0 ]; then
- echo "[error]: ${FDO_BUILD_COMPONENT} - Error build failed ($error)"
- exit $error
- fi
+ error=$?
+ echo "[error]: ${FDO_BUILD_COMPONENT} - Error build failed ($error)"
+ exit $error
+ fi
check_fdo_lib()
- libname=$1-${FDO_VER_FULL}.so
- libpath=${FDO_INST}/lib/${libname}
- if [ ! -e ${libpath} ]; then
- echo "[error]: Error building ${libname}"
- exit 1
- fi
+ libname=$1-${FDO_VER_FULL}.so
+ libpath=${FDO_INST}/lib/${libname}
+ if [ ! -e ${libpath} ]; then
+ echo "[error]: Error building ${libname}"
+ exit 1
+ fi
save_current_file_list()
- echo "[info]: Saving current FDO dir file list"
- pushd $FDO_INST
- # For lazy folks who build from svn working copies instead of svn exports, we need to weed out any .svn dirs before compiling the file-list
- find . -name .svn -exec rm -rf {} \;
- find . -type f -print > ${FDO_FILELIST}/temp.lst
- find . -type l -print >> ${FDO_FILELIST}/temp.lst
- sort ${FDO_FILELIST}/temp.lst > ${FDO_FILELIST}/orig.lst
- find . -type d -print | sort > ${FDO_FILELIST}/origdir.lst
- popd
+ echo "[info]: Saving current FDO dir file list"
+ pushd $FDO_INST
+ # For lazy folks who build from svn working copies instead of svn exports, we need to weed out any .svn dirs before compiling the file-list
+ find . -name .svn -exec rm -rf {} \;
+ find . -type f -print > ${FDO_FILELIST}/temp.lst
+ find . -type l -print >> ${FDO_FILELIST}/temp.lst
+ sort ${FDO_FILELIST}/temp.lst > ${FDO_FILELIST}/orig.lst
+ find . -type d -print | sort > ${FDO_FILELIST}/origdir.lst
+ popd
update_fdocore_file_list()
- echo "[info]: Updating FDO core file list for deb packaging"
- pushd $FDO_INST
- sort ${FDO_FILELIST}/temp.lst > ${FDO_FILELIST}/fdocore.lst
- find . -type d -print | sort > ${FDO_FILELIST}/fdocoredir.lst
- popd
+ echo "[info]: Updating FDO core file list for deb packaging"
+ pushd $FDO_INST
+ sort ${FDO_FILELIST}/temp.lst > ${FDO_FILELIST}/fdocore.lst
+ find . -type d -print | sort > ${FDO_FILELIST}/fdocoredir.lst
+ popd
update_provider_file_list()
- PROVIDER=$1
- echo "[info]: Updating $PROVIDER file list for deb packaging"
- pushd $FDO_INST
- #mkdir -p $BUILDLIST
- cat ${FDO_FILELIST}/orig.lst >> ${FDO_FILELIST}/temp.lst
- sort ${FDO_FILELIST}/temp.lst | uniq -u > ${FDO_FILELIST}/${PROVIDER}.lst
- find . -type d -print | sort > ${FDO_FILELIST}/temp.lst
- cat ${FDO_FILELIST}/origdir.lst >> ${FDO_FILELIST}/temp.lst
- sort ${FDO_FILELIST}/temp.lst | uniq -u > ${FDO_FILELIST}/${PROVIDER}dir.lst
- popd
+ PROVIDER=$1
+ echo "[info]: Updating $PROVIDER file list for deb packaging"
+ pushd $FDO_INST
+ #mkdir -p $BUILDLIST
+ cat ${FDO_FILELIST}/orig.lst >> ${FDO_FILELIST}/temp.lst
+ sort ${FDO_FILELIST}/temp.lst | uniq -u > ${FDO_FILELIST}/${PROVIDER}.lst
+ find . -type d -print | sort > ${FDO_FILELIST}/temp.lst
+ cat ${FDO_FILELIST}/origdir.lst >> ${FDO_FILELIST}/temp.lst
+ sort ${FDO_FILELIST}/temp.lst | uniq -u > ${FDO_FILELIST}/${PROVIDER}dir.lst
+ popd
BUILDROOT=`pwd`
@@ -93,16 +103,16 @@
PRESERVE_BUILD_ROOT=1
CMAKE=0
-FDO_SRC=/home/vagrant/fdo/trunk
+MY_HOME_DIR=/home/vagrant
+FDO_SRC=${MY_HOME_DIR}/fdo/trunk
#FDO_SRC=http://svn.osgeo.org/fdo/trunk
FDO_BUILD_AREA=${BUILDROOT}/fdo_build_area
FDO_FILELIST=${FDO_BUILD_AREA}/install/filelist
shim_thirdparty_lib_paths()
+ # Note: This is an Ubuntu-only code path
echo "[info]: Shimming include/lib paths"
- # Note:
# FDO assumes you're going to be linking against an SDK whose directory structure
# is different from how system dev libraries are installed on Ubuntu, so we leverage the
# power of symlinks to set up the expected directory structure that points to the system
@@ -113,41 +123,47 @@
# libmysqlclient-dev libpq-dev
- mkdir -p ~/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU
+ mkdir -p ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU
# PostgreSQL include path
- if [ ! -d ~/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/include ];
+ if [ ! -d ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/include ];
then
- ln -s /usr/include/postgresql ~/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/include
+ ln -s /usr/include/postgresql ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/include
echo "[info]: Symlinked PostgreSQL include path"
else
echo "[info]: PostgreSQL include path already symlinked"
fi
# PostgreSQL lib path
- if [ ! -d ~/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/$LIB_DIRNAME ];
+ if [ ! -d ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/$LIB_DIRNAME ];
then
- ln -s /usr/lib ~/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/$LIB_DIRNAME
- echo "[info]: Symlinked PostgreSQL lib path"
+ if [ ${FDO_PLATFORM} -eq 32 ];
+ then
+ ln -s /usr/lib ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/$LIB_DIRNAME
+ echo "[info]: Symlinked PostgreSQL lib path (x86)"
+ else
+ ln -s /usr/lib64 ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/pgsql/$FDO_CPU/$LIB_DIRNAME
+ echo "[info]: Symlinked PostgreSQL lib path (x64)"
+ fi
else
echo "[info]: PostgreSQL lib path already symlinked"
fi
- mkdir -p ~/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU
+ mkdir -p ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU
# MySQL include path
- if [ ! -d ~/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/include ];
+ if [ ! -d ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/include ];
then
- ln -s /usr/include/mysql ~/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/include
+ ln -s /usr/include/mysql ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/include
echo "[info]: Symlinked MySQL include path"
else
echo "[info]: MySQL include path already symlinked"
fi
# MySQL lib path
- if [ ! -d ~/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$LIB_DIRNAME ];
+ if [ ! -d ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$LIB_DIRNAME ];
then
then
- ln -s /usr/lib/i386-linux-gnu ~/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$LIB_DIRNAME
+ ln -s /usr/lib/i386-linux-gnu ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$LIB_DIRNAME
echo "[info]: Symlinked MySQL lib path (x86)"
else
- ln -s /usr/lib/x86_64-linux-gnu ~/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$LIB_DIRNAME
+ ln -s /usr/lib/x86_64-linux-gnu ${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/$FDO_CPU/$LIB_DIRNAME
echo "[info]: Symlinked MySQL lib path (x64)"
fi
else
@@ -157,24 +173,228 @@
modify_sdk_paths()
+ rm -f $FDO_BUILD_AREA/setenvironment.sh
then
- echo "[info]: Updating setenvironment.sh"
- sed -i 's/export FDOMYSQL=$FDOTHIRDPARTY\/mysql\/rhlinux/export FDOMYSQL=\/home\/vagrant\/fdo_rdbms_thirdparty_system\/mysql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
- sed -i 's/export FDOPOSTGRESQL=$FDOTHIRDPARTY\/pgsql/export FDOPOSTGRESQL=\/home\/vagrant\/fdo_rdbms_thirdparty_system\/pgsql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
+ #GCCVER=4.7
+ #export GCCVER
+ #CC=gcc-$GCCVER
+ #export CC
+ #CXX=g++-$GCCVER
+ #export CXX
+ shim_thirdparty_lib_paths
+ # Nuke the existing copies of openssl and libcurl and replace them with directories
+ # that symlink to system-installed headers/libs
+ rm -rf $FDO_BUILD_AREA/Thirdparty/openssl
+ rm -rf $FDO_BUILD_AREA/Thirdparty/libcurl
+ # symlink libcurl to system installed copy
+ mkdir -p $FDO_BUILD_AREA/Thirdparty/libcurl/include
+ if [ ! -e $FDO_BUILD_AREA/Thirdparty/libcurl/include/curl ];
+ then
+ ln -s /usr/include/curl $FDO_BUILD_AREA/Thirdparty/libcurl/include/curl
+ fi
+ # Stub build.sh for libcurl
+ echo "#!/bin/bash" > $FDO_BUILD_AREA/Thirdparty/libcurl/build.sh
+ echo "exit 0" >> $FDO_BUILD_AREA/Thirdparty/libcurl/build.sh
+ mkdir -p $FDO_BUILD_AREA/Thirdparty/libcurl/lib
+ if [ ! -e $FDO_BUILD_AREA/Thirdparty/libcurl/lib/linux ];
+ then
+ ln -s /usr/lib/i386-linux-gnu $FDO_BUILD_AREA/Thirdparty/libcurl/lib/linux
+ fi
+ # symlink openssl to system installed copy
+ mkdir -p $FDO_BUILD_AREA/Thirdparty/openssl/include
+ if [ ! -e $FDO_BUILD_AREA/Thirdparty/openssl/include/openssl ];
+ then
+ ln -s /usr/include/openssl $FDO_BUILD_AREA/Thirdparty/openssl/include/openssl
+ fi
+ # Stub openssl for libcurl
+ echo "#!/bin/bash" > $FDO_BUILD_AREA/Thirdparty/openssl/build.sh
+ echo "exit 0" >> $FDO_BUILD_AREA/Thirdparty/openssl/build.sh
+ mkdir -p $FDO_BUILD_AREA/Thirdparty/openssl/lib
+ if [ ! -e $FDO_BUILD_AREA/Thirdparty/openssl/lib/linux ];
+ then
+ ln -s /usr/lib/i386-linux-gnu $FDO_BUILD_AREA/Thirdparty/openssl/lib/linux
+ fi
+ echo "[info]: Replace internal openssl/libcurl with symlinks to Ubuntu-installed copies"
+ fi
+ # Rather than going through the hassle of modifying setenvironment.sh
+ # Let's just inline the logic here and make the distro-specific changes
+ echo "[info]: Setting environment variables for FDO"
+ # Fully-qualfied location of the FDO files
+ export FDO=$FDO_BUILD_AREA/Fdo
+ if test ! -e "$FDO"; then
+ echo ""
+ echo "Invalid FDO path provided. "
+ echo "The setenvironment script sets the default value to: "
+ echo "$FDO"
+ echo "Please modify the setenvironment.sh script with a valid path."
+ echo ""
+ fi
+ # Fully-qualfied location of the FDO Utility files
+ export FDOUTILITIES=$FDO_BUILD_AREA/Utilities
+ if test ! -e "$FDOUTILITIES"; then
+ echo ""
+ echo "Invalid FDO Utilities path provided. "
+ echo "$FDOUTILITIES"
+ echo ""
+ fi
+ # Fully-qualfied location of the FDO Thirdparty files
+ # Note: This value is completely disregarded and rewritten by FDO's configure script
+ # but we still set it here as it forms the basis of other env vars below
+ export FDOTHIRDPARTY=$FDO_BUILD_AREA/Thirdparty
+ if test ! -e "$FDOTHIRDPARTY"; then
+ echo ""
+ echo "Invalid FDO Thirdparty path provided. "
+ echo "$FDOTHIRDPARTY"
+ echo ""
+ fi
+ # Fully-qualfied location of the ESRI ArcSDE SDK
+ export SDEHOME=$FDOTHIRDPARTY/ESRI/ArcSDEClient931/Linux
+ if test ! -e "$SDEHOME"; then
+ echo ""
+ echo "NOTE: The default location for the ArcSDE client SDK files"
+ echo "was not found. The setenvironment script sets the default value to: "
+ echo "$FDOTHIRDPARTY/ESRI/ArcSDEClient91/Linux. "
+ echo ""
+ fi
+ # Fully-qualfied location of the GDAL Installation
+ export FDOGDAL=$FDOTHIRDPARTY/gdal
+ echo ""
+ echo "NOTE: The setenvironment.sh script sets the installation location for "
+ echo "the GDAL SDK files to $FDOTHIRDPARTY/gdal. "
+ echo "If this value remains unchanged, the FDO build process will"
+ echo "build the version of GDAL located in Thirdparty/gdal and will "
+ echo "install the resulting libraries in /usr/local/fdo-3.9.0. The FDO build"
+ echo "process will then use that location when building the GDAL and"
+ echo "WMS providers. If you wish to build the FDO GDAL or WMS Providers"
+ echo "using a previously installed version of GDAL, modify the setenvironment.sh "
+ echo "script and set FDOGDAL to point to the existing GDAL installation."
+ echo "For example: /user/local (The default GDAL installation path)."
+ echo ""
+ # Fully-qualfied location of the ODBC SDK
+ export FDOODBC=/usr
+ if test ! -e "$FDOODBC"; then
+ echo ""
+ echo "NOTE: The default path for the ODBC SDK files was not found. "
+ echo "$FDOODBC"
+ echo ""
+ fi
+ # Location of the PYTHON lib files. Typically in /usr/lib/pythonXXX
+ export PYTHON_LIB_PATH=/usr/lib/python2.4
+ if test ! -e "$PYTHON_LIB_PATH"; then
+ echo ""
+ echo "NOTE: The default path for the Python SDK lib files was not found. "
+ echo "$PYTHON_LIB_PATH"
+ echo "lib files."
+ echo ""
+ fi
+ # Location of the PYTHON include files. Typically in /usr/include/pythonXXX
+ export PYTHON_INCLUDE_PATH=/usr/include/python2.4
+ if test ! -e "$PYTHON_INCLUDE_PATH"; then
+ echo ""
+ echo "NOTE: The default path for the Python SDK header files was not found. "
+ echo "$PYTHON_INCLUDE_PATH"
+ echo "include files."
+ echo ""
+ fi
+ # Buildbot hack (mloskot): if the script is called with single dummy
+ # parameter no installation directory is created, ie.:
+ # $ source ./setenvironment.sh --noinstall
+ if test ! $# -eq 1; then
+ mkdir -p "/usr/local/fdo-${FDO_VER_FULL}/lib"
+ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/fdo-${FDO_VER_FULL}/lib:$SDEHOME/lib
+ fi
+ export XERCESCROOT=$FDOTHIRDPARTY/apache/xerces
+ export XALANCROOT=$FDOTHIRDPARTY/apache/xalan
+ export NLSDIR=$XALANCROOT/src/xalanc/NLS
+ export FDOORACLE=${MY_HOME_DIR}/fdo_rdbms_thirdparty/oracle/${FDO_CPU}/instantclient_11_2/sdk
+ # Depending on distro, MySQL and PostgreSQL take different paths here
+ if [ ${UBUNTU} -eq 1 ];
+ then
+ export FDOMYSQL=${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/mysql/${FDO_CPU}
+ export FDOPOSTGRESQL=${MY_HOME_DIR}/fdo_rdbms_thirdparty_system/pgsql/${FDO_CPU}
+ # Also need to patch some FDO thirdparty build scripts to accept our non-default compiler
+ #echo "[info]: Patching mkcatdefs build script"
+ #sed -i 's/gcc -DLINUX -g/'"$CC"' -DLINUX -g/g' ${FDO_BUILD_AREA}/Thirdparty/linux/mkcatdefs/src/build
+ #echo "[info]: Patching xalan/xerces build script"
+ #sed -i 's/.\/runConfigure -p linux -P/.\/runConfigure -p linux -c '"$CC"' -x '"$CXX"' -P/g' ${FDO_BUILD_AREA}/Thirdparty/apache/build2.sha
+ #echo "[info]: Patching boost build script"
+ #sed -i 's/# using gcc : 3.2 : g++-3.2 ;/using gcc : '"$GCCVER"' : '"$CXX"' ;/g' ${FDO_BUILD_AREA}/Thirdparty/boost/tools/build/v2/user-config.jam
+ #sed -i 's/.\/b2 toolset=gcc/.\/b2 toolset='"$CC"'/g' ${FDO_BUILD_AREA}/Thirdparty/boost/build.sh
else
- # Note: Change your paths here if they're different
- sed -i 's/export FDOMYSQL=$FDOTHIRDPARTY\/mysql\/rhlinux/export FDOMYSQL=\/home\/vagrant\/fdo_rdbms_thirdparty\/mysql\/'"$FDO_CPU"'/g' ${FDO_BUILD_AREA}/setenvironment.sh
- sed -i 's/export FDOPOSTGRESQL=$FDOTHIRDPARTY\/pgsql/export FDOPOSTGRESQL=\/home\/vagrant\/fdo_rdbms_thirdparty\/pgsql/g' ${FDO_BUILD_AREA}/setenvironment.sh
+ # Note: Change your paths here if they're different
+ export FDOMYSQL=${MY_HOME_DIR}/fdo_rdbms_thirdparty/mysql/${FDO_CPU}
+ export FDOPOSTGRESQL=${MY_HOME_DIR}/fdo_rdbms_thirdparty/pgsql
fi
- echo "export FDOORACLE=/home/vagrant/fdo_rdbms_thirdparty/oracle/${FDO_CPU}/instantclient_11_2/sdk" >> ${FDO_BUILD_AREA}/setenvironment.sh
+ # Check MySQL path
+ if test ! -e "$FDOMYSQL"; then
+ echo ""
+ echo "NOTE: The default location for the MySQL SDK files "
+ echo "$FDOTHIRDPARTY/mysql/rhlinux "
+ echo "Your configured path was: $FDOMYSQL"
+ echo ""
+ fi
+ # Check PostgreSQL path
+ if test ! -e "$FDOPOSTGRESQL"; then
+ echo ""
+ echo "NOTE: The default path for the PostgreSQL SDK files was not found. "
+ echo "$FDOPOSTGRESQL"
+ echo "Your configured path was: $FDOPOSTGRESQL"
+ echo ""
+ fi
+ echo "******* Environment variable summary *********"
+ echo "FDO: $FDO"
+ echo "FDOUTILITIES: $FDOUTILITIES"
+ echo "FDOTHIRDPARTY: $FDOTHIRDPARTY"
+ echo "SDEHOME: $SDEHOME"
+ echo "FDOGDAL: $FDOGDAL"
+ echo "FDOODBC: $FDOODBC"
+ echo "PYTHON_LIB_PATH: $PYTHON_LIB_PATH"
+ echo "PYTHON_INCLUDE_PATH: $PYTHON_INCLUDE_PATH"
+ echo "XERCESCROOT: $XERCESCROOT"
+ echo "XALANCROOT: $XALANCROOT"
+ echo "NLSDIR: $NLSDIR"
+ echo "FDOORACLE: $FDOORACLE"
+ echo "FDOMYSQL: $FDOMYSQL"
+ echo "FDOPOSTGRESQL: $FDOPOSTGRESQL"
+ echo "**********************************************"
+ echo ""
# Must have root
if [[ $EUID -ne 0 ]]; then
- echo "[error]: You must run this script with superuser privileges"
- exit 1
+ echo "[error]: You must run this script with superuser privileges"
+ exit 1
fi
echo "***********************************************************"
@@ -184,99 +404,90 @@
echo " FDO CPU Target: ${FDO_BUILD_CPU}"
echo " CMake build: ${CMAKE}"
+echo " Debug build: ${FDO_DEBUG}"
echo " Export from local SVN checkout: ${LOCALSVN}"
echo " Re-use previous build area: ${PRESERVE_BUILD_ROOT}"
REVISION=`svn info ${FDO_SRC} | perl revnum.pl`
-if [ ${UBUNTU} -eq 1 ];
-then
- shim_thirdparty_lib_paths
-fi
if [ -d ${FDO_INST} ];
then
- echo "[info]: Deleting directory ${FDO_INST} before build"
- rm -rf ${FDO_INST}
+ echo "[info]: Deleting directory ${FDO_INST} before build"
+ rm -rf ${FDO_INST}
else
- echo "[info]: ${FDO_INST} doesn't exist. Continuing build"
+ echo "[info]: ${FDO_INST} doesn't exist. Continuing build"
fi
if [ ${CMAKE} -eq 1 ];
then
- echo "[error]: CMake build of FDO not supported yet"
- exit 1
+ echo "[error]: CMake build of FDO not supported yet"
+ exit 1
else
- echo "[info]: Using automake build"
- if [ -d ${FDO_BUILD_AREA} ];
- then
- if [ ${PRESERVE_BUILD_ROOT} -eq 1 ];
- then
- echo "[info]: FDO build area ${FDO_BUILD_AREA} exists. Going straight to build"
- modify_sdk_paths
- else
- echo "[info]: Removing old FDO build area at ${FDO_BUILD_AREA}"
- rm -rf ${FDO_BUILD_AREA}
- if [ ${LOCALSVN} -eq 1 ]
- then
- svn export -q ${FDO_SRC} ${FDO_BUILD_AREA}
- modify_sdk_paths
- else
- echo "[info]: Performing fresh SVN export of ${FDO_SRC} (r${REVISION}) to ${FDO_BUILD_AREA}"
- svn export -q -r ${REVISION} ${FDO_SRC} ${FDO_BUILD_AREA}
- modify_sdk_paths
- fi
- fi
- else
- echo "[info]: FDO build area ${FDO_BUILD_AREA} does not exist. Doing svn export"
- echo "[info]: Exporting svn revision ${REVISION}"
- then
- modify_sdk_paths
- else
- modify_sdk_paths
- fi
- fi
+ echo "[info]: Using automake build"
+ if [ -d ${FDO_BUILD_AREA} ];
+ then
+ if [ ${PRESERVE_BUILD_ROOT} -eq 1 ];
+ then
+ echo "[info]: FDO build area ${FDO_BUILD_AREA} exists. Going straight to build"
+ modify_sdk_paths
+ else
+ echo "[info]: Removing old FDO build area at ${FDO_BUILD_AREA}"
+ rm -rf ${FDO_BUILD_AREA}
+ if [ ${LOCALSVN} -eq 1 ]
+ then
+ svn export -q ${FDO_SRC} ${FDO_BUILD_AREA}
+ modify_sdk_paths
+ else
+ echo "[info]: Performing fresh SVN export of ${FDO_SRC} (r${REVISION}) to ${FDO_BUILD_AREA}"
+ svn export -q -r ${REVISION} ${FDO_SRC} ${FDO_BUILD_AREA}
+ modify_sdk_paths
+ fi
+ fi
+ else
+ echo "[info]: FDO build area ${FDO_BUILD_AREA} does not exist. Doing svn export"
+ echo "[info]: Exporting svn revision ${REVISION}"
+ then
+ modify_sdk_paths
+ else
+ modify_sdk_paths
+ fi
+ fi
fi
echo "[info]: Building FDO (${FDO_VER_MAJOR}.${FDO_VER_MINOR}.${FDO_VER_REV}) rev (${REVISION})"
cd ${FDO_BUILD_AREA}
-source ./setenvironment.sh
-if [ ! -d ${FDO_INST} ];
-then
- echo "[error]: FDO install directory ${FDO_INST} doesn't exist. setenvironment.sh should've created this directory. Ensure the FDO version number in this script is correct"
- exit 1;
-fi
FDO_BUILD_COMPONENT="FDO Thirdparty"
-./build_thirdparty.sh -b ${FDO_PLATFORM}
+./build_thirdparty.sh -b ${FDO_PLATFORM} ${FDO_BUILD_FLAGS}
check_build
then
- FDO_BUILD_COMPONENT="FDO (cmake)"
- exit 1;
+ FDO_BUILD_COMPONENT="FDO (cmake)"
+ exit 1;
else
- #NOTE: We never build ArcSDE provider because we haven't paid the ESRI tax for their ArcSDE SDK
- for comp in fdocore fdo utilities
- do
- FDO_BUILD_COMPONENT="$comp (automake)"
- ./build_linux.sh --w $comp --p ${FDO_INST} --b ${FDO_PLATFORM}
- update_fdocore_file_list
- check_build
- done
- for comp in shp sqlite gdal ogr wfs wms rdbms kingoracle sdf
- do
- save_current_file_list
- update_provider_file_list $comp
- check_build
- done
+ #NOTE: We never build ArcSDE provider because we haven't paid the ESRI tax for their ArcSDE SDK
+ for comp in fdocore fdo utilities
+ do
+ FDO_BUILD_COMPONENT="$comp (automake)"
+ ./build_linux.sh --w $comp --p ${FDO_INST} --b ${FDO_PLATFORM} ${FDO_BUILD_FLAGS}
+ update_fdocore_file_list
+ check_build
+ done
+ for comp in shp sqlite gdal ogr wfs wms rdbms kingoracle sdf
+ do
+ save_current_file_list
+ update_provider_file_list $comp
+ check_build
+ done
fi
check_fdo_lib libFDO
check_fdo_lib libExpressionEngine
@@ -302,33 +513,38 @@
end_time=`date +%s`
-FDO_BUILD_COMPONENT="Remove .la files from ${FDO_INST}"
-# Remove .la files from lib directory
-rm -f ${FDO_INST}/lib/*.la
-check_build
+if [ $FDO_DEBUG -eq 0 ];
+then
+ FDO_BUILD_COMPONENT="Remove .la files from ${FDO_INST}"
+ # Remove .la files from lib directory
+ rm -f ${FDO_INST}/lib/*.la
+ check_build
-FDO_BUILD_COMPONENT="Strip so symbols and remove execute flag"
-# Remove unneeded symbols from files in the lib directory
-# and make them non-executable
-for file in `find ${FDO_INST}/lib/lib*.so* -type f -print`
-do
- strip --strip-unneeded ${file}
- chmod a-x ${file}
-done
-check_build
+ FDO_BUILD_COMPONENT="Strip so symbols and remove execute flag"
+ # Remove unneeded symbols from files in the lib directory
+ # and make them non-executable
+ for file in `find ${FDO_INST}/lib/lib*.so* -type f -print`
+ do
+ strip --strip-unneeded ${file}
+ chmod a-x ${file}
+ done
+ check_build
-cd $BUILDROOT
-FDO_BUILD_COMPONENT="Make tarball"
-# Create a binary tar ball for FDO
-tar -zcf fdosdk-centos6-${FDO_BUILD_CPU}-${FDO_VER_FULL}_${REVISION}.tar.gz ${FDO_INST}
-check_build
+ FDO_BUILD_COMPONENT="Make tarball"
+ # Create a binary tar ball for FDO
+ cd ${FDO_INST}
+ tar -zcf ${BUILDROOT}/fdosdk-centos6-${FDO_BUILD_CPU}-${FDO_VER_FULL}_${REVISION}.tar.gz *
+ check_build
-then
-cd ${FDO_BUILD_AREA}/install
-dos2unix *
-./dpkgall.sh ${FDO_BUILD_CPU} ${REVISION}
+ then
+ cd ${FDO_BUILD_AREA}/install
+ dos2unix *
+ ./dpkgall.sh ${FDO_BUILD_CPU} ${REVISION}
+ fi
+else
+ echo "[info]: Not packaging FDO in debug mode"
fi
echo "[info]: FDO build complete!"
-echo Main build execution time: `expr $end_time - $start_time` s
+echo Main build execution time: `expr $end_time - $start_time` s
\ No newline at end of file
Deleted: trunk/Tools/Vagrant/scripts/build_oem_ubuntu.sh
--- trunk/Tools/Vagrant/scripts/build_oem_ubuntu.sh 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/scripts/build_oem_ubuntu.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -1,653 +0,0 @@
-#! /bin/bash
-# MapGuide Open Source build script (tweaked for Ubuntu)
-# Initialization
-echo "MapGuide Open Source build script for OEM components"
-INSTALLDIR=/usr/local/mapguideopensource
-MY_MAKE_OPTS="-j 2"
-CLEAN_FLAG=0
-while [ $# -gt 0 ]; do # Until you run out of parameters...
- case "$1" in
- -prefix|--prefix)
- INSTALLDIR="$2"
- shift
- -clean|--clean)
- CLEAN_FLAG=1
- shift
- -help|--help)
- echo "Usage: $0 (options)"
- echo "Options:"
- echo " --prefix [installation directory]"
- echo " --clean [clean all objects and binaries in Oem]"
- echo " --help [Display usage]"
- exit
- esac
- shift # Check next set of parameters.
-done
-echo "OEM Build Initialization ............................"
-echo "Oem Libraries will be installed at: ${INSTALLDIR}"
-LIB_NAME=""
-# Generic Functions
-check_build()
- error=$?
- echo "$LIB_NAME: Error build failed ($error)................."
- exit $error
- fi
-check_clean()
- error=$?
- echo "$LIB_NAME: Error clean failed ($error)................."
- exit $error
- fi
-# Build ACE 5.7
-# Notes: none
-init_ace()
- LIB_NAME="ACE 5.7"
-build_ace()
- pushd ACE/ACE_wrappers
- ACE_PATH="${PWD}"
- pushd ace
- env ACE_ROOT="${ACE_PATH}" make $MY_MAKE_OPTS
- check_build
- popd
- popd
-clean_ace()
- ACE_PATH="${PWD}"
- pushd ace
- env ACE_ROOT="${ACE_PATH}" make clean
- check_clean
- popd
- popd
-# Build DWFCORE 1.0
-# Notes: none
-init_dwfcore()
- LIB_NAME="DWFCORE 1.0"
- pushd DWFTK7.1/develop/global/build/gnu/dwfcore
- sh ./build_setup.sh
- popd
-build_dwfcore()
- pushd DWFTK7.1/develop/global/src/dwfcore
- sh ./configure --enable-optimized --prefix="${INSTALLDIR}"
- make $MY_MAKE_OPTS
- check_build
- popd
-clean_dwfcore()
- make clean
- check_clean
- popd
-# Build DWFTOOLKIT 7.1
-# Notes: none
-init_dwftk()
- LIB_NAME="DWFTK 7.1"
- pushd DWFTK7.1/develop/global/build/gnu/dwftoolkit
- popd
-build_dwftk()
- check_build
- popd
-clean_dwftk()
- make clean
- check_clean
- popd
-# Build DWFEMAP 1.0
-# Notes: none
-init_dwfemap()
- LIB_NAME="DWFEMAP 1.0"
- pushd DWFTK7.1/develop/global/build/gnu/dwfemap
- popd
-build_dwfemap()
- pushd DWFTK7.1/develop/global/src/dwfemap
- check_build
- popd
-clean_dwfemap()
- make clean
- check_clean
- popd
-# Build GEOS 2.2.0
-# Notes: none
-init_geos()
- LIB_NAME="GEOS 2.2.0"
-build_geos()
- pushd geos-2.2.0
- # Force regen to take into account our modified configure.in
- aclocal -I macros
- libtoolize --copy --force
- autoconf
- automake --add-missing --copy --force-missing
- if [ $(uname -m) = "x86_64" ]; then
- sh ./configure --with-pic --prefix="${INSTALLDIR}"
- else
- sh ./configure --prefix="${INSTALLDIR}"
- fi
- # The check build is disabled as the build will fail with automake version < 2.59
- # check_build
- popd
-clean_geos()
- pushd geos-2.2.0
- make clean
- check_clean
- popd
-# Build PHP 5.5.11
-# Notes: Configure PHP source tree for building PHP extension
-init_php()
- LIB_NAME="PHP 5.5.11"
-build_php()
- # Nothing to do here. build_apt.sh builds PHP
- pushd LinuxApt/php-5.5.11
- popd
-clean_php()
- make distclean
- check_clean
- popd
-# Build SWIGEx 1.0
-# Notes: none
-init_swigex()
- LIB_NAME="SWIGEx 1.0"
-build_swigex()
- pushd SWIGEx
- mkdir -p Linux/obj/release
- check_build
- popd
-clean_swigex()
- pushd SWIGEx
- # Note: the qmake system is required to regenerate the Makefile.
- # This is disabled.
- # make clean
- # check_clean
- popd
-# Build BDBXML
-# Notes: none
-init_bdbxml()
- LIB_NAME="BDBXML"
-build_bdbxml()
- # Need to force regen of the correct xerces config header before building dbxml proper
- pushd dbxml/xerces-c-src
- sh ./configure
- popd
- # Also need to check and set executable flag for s_paths
- pushd dbxml/dbxml/dist
- chmod +x s_paths
- popd
- pushd dbxml
- sh ./buildall.sh
- check_build
- popd
-clean_bdbxml()
- pushd dbxml
- sh ./buildall.sh --clean
- check_clean
- popd
-# Build CPPUNIT 1.9.14
-# Notes: none
-init_cppunit()
- LIB_NAME="CPPUNIT 1.9.14"
-build_cppunit()
- pushd CppUnit-1.9.14
- # the configure script as-is is incompatible with ubuntu, so regen it
- aclocal -I config
- autoconf
- # -ldl is to prevent undefined reference to dlsym/dlopen/dlclose
- sh ./configure --prefix="${INSTALLDIR}" LDFLAGS="-ldl"
- check_build
- popd
-clean_cppunit()
- make clean
- check_clean
- popd
-# Build IMake 1.0
-# Notes: none
-init_imake()
- LIB_NAME="IMake 1.0"
-build_imake()
- pushd ../BuildTools/WebTools/IMake
- mkdir -p Linux/obj/debug
- check_build
- popd
-clean_imake()
- # Note: does not support clean as qmake is needed to regenerate the Makefile.
- # make clean
- # check_clean
- popd
-# Build ZLIB 1.2.3
-# Notes: none
-init_zlib()
- LIB_NAME="ZLIB 1.2.3"
-build_zlib()
- pushd gd/zlib
- sh ./configure
- check_build
- popd
-clean_zlib()
- pushd gd/zlib
- make clean
- check_clean
- popd
-# Build LIBPNG 1.2.8
-# Notes: none
-init_libpng()
- LIB_NAME="LIBPNG 1.2.8"
-build_libpng()
- pushd gd/lpng
- cp scripts/makefile.std makefile
- #Inject -fPIC to CFLAGS for 64-bit
- sed 's/^CFLAGS=/CFLAGS= -fPIC /g' makefile > makefile64
- make -fmakefile64 $MY_MAKE_OPTS
- else
- fi
- check_build
- popd
-clean_libpng()
- pushd gd/lpng
- make clean
- check_clean
- popd
-# Build JPEG 6b
-# Notes: none
-init_jpeg()
- LIB_NAME="JPEG 6b"
-build_jpeg()
- pushd gd/jpeg
- sh ./configure --enable-static --disable-shared
- #--with-pic does nothing (probably ancient configure script), so do some sed trickery
- #to inject this flag. Know a better way? Enlighten us :)
- sed 's/^CFLAGS=/CFLAGS= -fPIC/g' Makefile > Makefile64
- make -fMakefile64 $MY_MAKE_OPTS
- else
- fi
- check_build
- popd
-clean_jpeg()
- pushd gd/jpeg
- make clean
- check_clean
- popd
-# Build FREETYPE 2.1.10
-# Notes: none
-init_freetype()
- LIB_NAME="FREETYPE 2.1.10"
-build_freetype()
- pushd gd/freetype
- sh ./configure --enable-static --disable-shared --with-pic
- else
- fi
- check_build
- popd
-clean_freetype()
- pushd gd/freetype
- make clean
- check_clean
- popd
-# Build GD 2.0.33
-# Notes: none
-init_gd()
- LIB_NAME="GD 2.0.33"
-build_gd()
- pushd gd/gd
- sh ./configure --enable-static --disable-shared --without-fontconfig --with-pic
- else
- fi
- check_build
- popd
-clean_gd()
- pushd gd/gd
- make clean
- check_clean
- popd
-# Build AGG 2.4
-# Notes: none
-init_agg()
- LIB_NAME="AGG 2.4"
-build_agg()
- pushd agg-2.4
- make $MY_MAKE_OPTS EXTRACXXFLAGS=-fPIC
- else
- fi
- check_build
- popd
-clean_agg()
- pushd agg-2.4
- make clean
- check_clean
- popd
-# Build JSON
-# Notes: none
-init_json()
- LIB_NAME="JSON"
-build_json()
- pushd jsoncpp
- #Use the scons installed by apt-get
- scons platform=linux-gcc
- popd
-clean_json()
- pushd jsoncpp
- rm -rf lib buildscons dist
- popd
-# Build CSMAP
-# Notes: none
-init_csmap()
- LIB_NAME="CSMAP"
-build_csmap()
- pushd CsMap
- mkdir -p .libs
- pushd Source
- #Need to build CS-Map with -fPIC because linking libraries will be built with -fPIC
- sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Library64.mak
- make -fLibrary64.mak $MY_MAKE_OPTS
- else
- make -fLibrary.mak $MY_MAKE_OPTS
- fi
- cp CsMap.a ../.libs/libCsmap.a
- popd
- pushd Dictionaries
- if [ $(uname -m) = "x86_x64" ]; then
- sed 's/^C_FLG =/C_FLG = -fPIC/g' Library.mak | sed 's/CPP_FLG =/CPP_FLG = -fPIC/g' > Compiler64.mak
- make -fCompiler64.mak $MY_MAKE_OPTS
- else
- make -fCompiler.mak $MY_MAKE_OPTS
- fi
- ./CS_Comp -b . .
- popd
- check_build
- popd
-clean_csmap()
- pushd CsMap
- make clean
- check_clean
- popd
-# Script loop
-pushd Oem
-for lib in ace dwfcore dwftk dwfemap geos php swigex bdbxml cppunit imake zlib libpng jpeg freetype gd agg json csmap;
-do
- echo "$lib: Initialization..........................."
- init_"$lib"
- if test "$CLEAN_FLAG" = "1"; then
- echo "$lib: Clean ....................................."
- clean_"$lib"
- echo "$lib: Clean Successful .........................."
- else
- echo "$lib: Configure/Build ..........................."
- build_"$lib"
- echo "$lib: Build Successful .........................."
- fi
-done
-popd
Added: trunk/Tools/Vagrant/scripts/csmap_optimize.sh
--- trunk/Tools/Vagrant/scripts/csmap_optimize.sh (rev 0)
+++ trunk/Tools/Vagrant/scripts/csmap_optimize.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -0,0 +1,65 @@
+#!/bin/bash
+# csmap_optimize.sh
+# This script optimizes the size of CS-Map dictionary files by removing references
+# to all country-specific grid files which represents the bulk of the distribution
+# size
+# This script is meant to be called from within dpkgmapguide.sh
+EXCLUDEFILE=
+PACKAGENAME=mapguideopensource-coordsys-lite
+PACKAGEDIR=mapguidecoordsyslite
+ROOT=${BUILDROOT}/debian/mapguidecoordsyslite
+TREE=${BUILDROOT}/debian
+CPROOT=${ROOT}/${MGINST}
+DIRLIST="share"
+REMOVELIST="\.a\$ \.la\$ \.c\$ \.o\$ \.mak\$ \.nmk\$"
+STRIPLIST="\.so\$"
+CSMAP_OUT=/tmp/csmap_build_area/share/gis/coordsys
+if [ ! -d /tmp/csmap_build_area ]; then
+ mkdir -p /tmp/csmap_build_area
+fi
+comment_gdc()
+ GDCFILE=$1
+ sed -i 's/.\\Australia/#.\\Australia/g' $GDCFILE
+ sed -i 's/.\\Canada/#.\\Canada/g' $GDCFILE
+ sed -i 's/.\\France/#.\\France/g' $GDCFILE
+ sed -i 's/.\\Germany/#.\\Germany/g' $GDCFILE
+ sed -i 's/.\\Japan/#.\\Japan/g' $GDCFILE
+ sed -i 's/.\\NewZealand/#.\\NewZealand/g' $GDCFILE
+ sed -i 's/.\\Spain/#.\\Spain/g' $GDCFILE
+ sed -i 's/.\\Switzerland/#.\\Switzerland/g' $GDCFILE
+ sed -i 's/.\\Usa/#.\\Usa/g' $GDCFILE
+ sed -i 's/.\\WW15MGH.GRD/#.\\WW15MGH.GRD/g' $GDCFILE
+ echo "Commented out grid file references in $GDCFILE"
+# Copy CS-Map files to build area. We rely on the fact that the MapGuide build system
+# also leaves a copy of the CS_Comp executable in this directory which we'll use to
+# re-compile our dictionary files after some modifications
+cp -R /${MGINST}/share/gis/coordsys/* /tmp/csmap_build_area
+pushd /tmp/csmap_build_area
+ # Comment out grid file entries in all gdc files
+ for gdcf in *.gdc
+ do
+ comment_gdc $gdcf
+ done
+ # Re-compile
+ ./CS_Comp -b . .
+ if [ ! -d $CSMAP_OUT ]; then
+ mkdir -p $CSMAP_OUT
+ fi
+ # Copy output
+ cp *.CSD $CSMAP_OUT
+ cp NameMapper.csv $CSMAP_OUT
+ cp OSTN02._02 $CSMAP_OUT
+ cp OSTN97._nt $CSMAP_OUT
+popd
+MGINST=tmp/csmap_build_area
+source ./dpkgbuild.sh
+rm -rf /tmp/csmap_build_area
Modified: trunk/Tools/Vagrant/scripts/dpkgbuild.sh
--- trunk/Tools/Vagrant/scripts/dpkgbuild.sh 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/scripts/dpkgbuild.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -14,7 +14,13 @@
for dirname in ${DIRLIST}
do
mkdir -p ${CPROOT}/${dirname}
- cp -ar /${MGINST}/${dirname} ${CPROOT}
+ #cp -ar /${MGINST}/${dirname} ${CPROOT}
+ echo "[rsync] From: /${MGINST}/${dirname}/ To: ${CPROOT}/${dirname}/"
+ if [ -z ${EXCLUDEFILE} ]; then
+ rsync -a /${MGINST}/${dirname}/ ${CPROOT}/${dirname}/
+ else
+ rsync -a --exclude-from=${EXCLUDEFILE} /${MGINST}/${dirname}/ ${CPROOT}/${dirname}/
+ fi
done
# Remove all files in the REMOVELIST
@@ -46,9 +52,10 @@
# Shared library symlinks point back to install directory
# Add install directory to path to compensate
# Also add FDO libs to path
-export LD_LIBRARY_PATH=/usr/local/fdo-3.5.0/lib:${CPROOT}/lib:/${MGINST}/lib
+export LD_LIBRARY_PATH=/usr/local/fdo-${FDOBUILD}/lib:${CPROOT}/lib:/${MGINST}/lib
+echo "Using LD_LIBRARY_PATH of $LD_LIBRARY_PATH"
dpkg-shlibdeps -p${PACKAGEDIR} --ignore-missing-info ${CPROOT}/lib/*.so
-dpkg-gensymbols -p"${PACKAGENAME}" -P"debian/${PACKAGEDIR}"
+dpkg-gensymbols -q -p"${PACKAGENAME}" -P"debian/${PACKAGEDIR}"
# Now generate a filled in control file for the binary package
@@ -57,7 +64,7 @@
# Build binary package from ROOT
# And move resulting debian package and lintian results to build directory
-dpkg-deb --build ${ROOT}
+dpkg-deb -Zlzma --build ${ROOT}
lintian -i debian/${PACKAGEDIR}.deb > tmp/${PACKAGEDIR}.lintian
mv debian/${PACKAGEDIR}.deb bin/${PACKAGENAME}_${MGBUILD}-${BUILDNUM}_${ARCH}.deb
popd
Added: trunk/Tools/Vagrant/scripts/dpkgfdo.sh
--- trunk/Tools/Vagrant/scripts/dpkgfdo.sh (rev 0)
+++ trunk/Tools/Vagrant/scripts/dpkgfdo.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -0,0 +1,20 @@
+#!/bin/bash
+#ARCH=`arch`
+#REPO=http://svn.osgeo.org/fdo/branches/3.5
+#BUILDNUM=`svn info ${REPO} | awk '/Changed Rev/ {print $4}'`
+ARCH="$1"
+BUILDNUM="$2"
+echo Building FDO arch=${ARCH} buildnum=${BUILDNUM}
+./dpkgfdocore.sh $ARCH $BUILDNUM
+./dpkgfdoprovider.sh $ARCH $BUILDNUM sdf
+./dpkgfdoprovider.sh $ARCH $BUILDNUM shp
+./dpkgfdoprovider.sh $ARCH $BUILDNUM wfs
+./dpkgfdoprovider.sh $ARCH $BUILDNUM wms
+# ArcSDE provider currently disabled due to missing libraries
+#./dpkgfdoprovider.sh $ARCH $BUILDNUM arcsde
+./dpkgfdoprovider.sh $ARCH $BUILDNUM rdbms
+./dpkgfdoprovider.sh $ARCH $BUILDNUM gdal
+./dpkgfdoprovider.sh $ARCH $BUILDNUM ogr
+./dpkgfdoprovider.sh $ARCH $BUILDNUM postgis
+./dpkgfdoprovider.sh $ARCH $BUILDNUM kingoracle
+./dpkgfdoprovider.sh $ARCH $BUILDNUM sqlite
Added: trunk/Tools/Vagrant/scripts/dpkgfdocore.sh
--- trunk/Tools/Vagrant/scripts/dpkgfdocore.sh (rev 0)
+++ trunk/Tools/Vagrant/scripts/dpkgfdocore.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -0,0 +1,225 @@
+#!/bin/bash
+# Build directory structure underneath directory of this script
+# debian/ - common build directory for all packages
+# control - generated all packages control file with subst params
+# changelog - generated changelog file
+# substvars - subst params created by dpkg-shlibdeps
+# fdocore/ - directory to build FDO Base libs package
+# usr/local/fdo-3.9.0/ - copied tree for core fdo libs
+# DEBIAN/
+# control - control file generated from dpkg-gencontrol
+# symbols - symbols file generated from dpkg-gensymbols
+BUILDROOT=`pwd`
+FDOBUILD=3.9.0
+FDO=usr/local/fdo-${FDOBUILD}
+ROOT=${BUILDROOT}/debian/fdocore
+CPROOT=${ROOT}/${FDO}
+# Create output directory structure and ignore errors
+if [ ! -d tmp ]; then
+ mkdir tmp >& /dev/null
+ mkdir bin >& /dev/null
+ mkdir debian >& /dev/null
+else
+# clean out existing build tree
+ rm -rf tmp/*
+ rm -rf bin/*
+ rm -rf debian/*
+fi
+# Read and validate command line parameters
+ARCH="$1"
+BUILDNUM="$2"
+if test -z ${ARCH}; then
+ echo Usage: dpkgfdocore.sh [i386/amd64] svnChangeNum
+ exit -1
+fi
+if test -z ${BUILDNUM}; then
+ exit -1
+fi
+case $ARCH in
+i386)
+ echo Setting architecture to i386.
+amd64)
+ echo Setting architecture to amd64.
+ echo Invalid architecture. Please specify i386 or amd64.
+ exit -1
+esac
+# Create control file
+cat > debian/control <<END-OF-CONTROL
+Source: fdo-src
+Maintainer: FDO Internals Mail List <fdo-internals at lists.osgeo.org>
+Section: misc
+Priority: optional
+Homepage: http://fdo.osgeo.org
+Package: fdo-core
+Architecture: ${ARCH}
+Section: misc
+Priority: optional
+Depends: \${fdocore:Depends}
+Description: OSGeo FDO ${FDOBUILD} base libraries
+Package: fdo-sdf
+Section: misc
+Priority: optional
+Depends: \${fdosdf:Depends}
+Description: OSGeo FDO ${FDOBUILD} SDF Provider
+Package: fdo-shp
+Section: misc
+Priority: optional
+Depends: \${fdoshp:Depends}
+Description: OSGeo FDO ${FDOBUILD} SHP Provider
+Package: fdo-wfs
+Section: misc
+Priority: optional
+Depends: \${fdowfs:Depends}
+Description: OSGeo FDO ${FDOBUILD} WFS Provider
+Package: fdo-wms
+Section: misc
+Priority: optional
+Depends: \${fdowms:Depends}
+Description: OSGeo FDO ${FDOBUILD} WMS Provider
+Package: fdo-arcsde
+Section: misc
+Priority: optional
+Depends: \${fdoarcsde:Depends}
+Description: OSGeo FDO ${FDOBUILD} ArcSDE Provider
+Package: fdo-rdbms
+Section: misc
+Priority: optional
+Depends: \${fdordbms:Depends}
+Description: OSGeo FDO ${FDOBUILD} Providers for ODBC, MySQL and PostgreSQL
+Package: fdo-gdal
+Section: misc
+Priority: optional
+Depends: \${fdogdal:Depends}
+Description: OSGeo FDO ${FDOBUILD} GDAL Provider
+Package: fdo-ogr
+Section: misc
+Priority: optional
+Depends: \${fdoogr:Depends}
+Description: OSGeo FDO ${FDOBUILD} OGR Provider
+Package: fdo-kingoracle
+Section: misc
+Priority: optional
+Depends: \${fdokingoracle:Depends}
+Description: OSGeo FDO ${FDOBUILD} King Oracle Provider
+Package: fdo-sqlite
+Section: misc
+Priority: optional
+Depends: \${fdosqlite:Depends}
+Description: OSGeo FDO ${FDOBUILD} SQLite Provider
+END-OF-CONTROL
+# Create changelog file
+# TODO: pull revision history from Subversion
+CURRTIME=`date -R`
+cat > debian/changelog <<END-OF-CHANGELOG
+fdo-src (${FDOBUILD}-${BUILDNUM}) experimental; urgency=low
+ * Pre-release build.
+ -- FDO Internals Mail List <fdo-internals at lists.osgeo.org> ${CURRTIME}
+END-OF-CHANGELOG
+# Pull copyright file from Subversion vault
+wget http://svn.osgeo.org/fdo/branches/3.8/License_README.txt -O tmp/copyright
+iconv -f ISO-8859-1 -t UTF-8 tmp/copyright > debian/copyright
+# Blow away old build directory
+rm -rf ${ROOT}
+# Create and populate documentation directory for fdo-core
+mkdir -p ${ROOT}/usr/share/doc/fdo-core
+cp debian/copyright ${ROOT}/usr/share/doc/fdo-core
+cp debian/changelog ${ROOT}/usr/share/doc/fdo-core/changelog.Debian
+gzip -9 ${ROOT}/usr/share/doc/fdo-core/changelog.Debian
+# Create directories for binary package build and copy
+# install image into build directory
+for file in `cat filelist/fdocoredir.lst`
+do
+ mkdir -p ${CPROOT}/${file}
+done
+for file in `cat filelist/fdocore.lst`
+do
+ cp -a /${FDO}/${file} ${CPROOT}/${file}
+done
+# Remove any .la files in the lib directory since
+# lintian complains about them
+rm -f ${CPROOT}/lib/*.la
+# Remove unneeded symbols from files in the lib directory
+# and remove their executable status to clean up some lintian errors
+for file in `find ${CPROOT}/lib/lib*.so* -type f -print`
+do
+ chmod a-x ${file}
+done
+# Call dpkg-shlibdeps to build out library dependencies
+# This will create the substvars file
+# LD_LIBRARY_PATH must be set to find private libs
+mkdir -p ${ROOT}/DEBIAN
+pushd ${BUILDROOT}
+# Fdo build creates full path symlinks for third party libs
+# Add install directory to path to compensate
+#export LD_LIBRARY_PATH=${CPROOT}/lib
+export LD_LIBRARY_PATH=${CPROOT}/lib:/${FDO}/lib
+dpkg-shlibdeps -pfdocore --ignore-missing-info ${CPROOT}/lib/*.so
+dpkg-gensymbols -q -p"fdo-core" -P"debian/fdocore"
+# Now generate a filled in control file for the binary package
+# using information from control, changelog, and substvars
+dpkg-gencontrol -p"fdo-core" -P"debian/fdocore"
+# Build binary package from ROOT
+# And move resulting debian package and lintian results to build directory
+lintian -i debian/fdocore.deb > tmp/fdocore.lintian
+mv debian/fdocore.deb bin/fdo-core_${FDOBUILD}-${BUILDNUM}_${ARCH}.deb
+popd
Added: trunk/Tools/Vagrant/scripts/dpkgfdoprovider.sh
--- trunk/Tools/Vagrant/scripts/dpkgfdoprovider.sh (rev 0)
+++ trunk/Tools/Vagrant/scripts/dpkgfdoprovider.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -0,0 +1,142 @@
+#!/bin/bash
+# fdo[provider]/ - directory to build FDO Provider
+# DEBIAN/
+ARCH="$1"
+BUILDNUM="$2"
+PROVIDER="$3"
+ echo Usage: dpkgfdoprovider.sh [i386/amd64] svnChangeNum provider
+ exit -1
+fi
+ exit -1
+fi
+case $ARCH in
+i386)
+amd64)
+ exit -1
+esac
+case $PROVIDER in
+sdf) ;;
+shp) ;;
+wms) ;;
+wfs) ;;
+arcsde) ;;
+rdbms) ;;
+gdal) ;;
+ogr) ;;
+kingoracle) ;;
+sqlite) ;;
+ echo Invalid provider. Please specify one of the following providers:
+ echo sdf,shp,wms,wfs,arcsde,rdbms,gdal,ogr,postgis,kingoracle,sqlite
+ exit -1
+esac
+BUILDROOT=`pwd`
+FDOBUILD=3.9.0
+ROOT=${BUILDROOT}/debian/fdo${PROVIDER}
+# Create output directory structure and eat error messag
+fi
+rm -rf ${ROOT}
+# Create and populate documentation directory for provider
+mkdir -p ${ROOT}/usr/share/doc/fdo-${PROVIDER}
+cp debian/copyright ${ROOT}/usr/share/doc/fdo-${PROVIDER}
+cp debian/changelog ${ROOT}/usr/share/doc/fdo-${PROVIDER}/changelog.Debian
+gzip -9 ${ROOT}/usr/share/doc/fdo-${PROVIDER}/changelog.Debian
+# Create directories for binary package build and copy install image
+# into build directory. Also include fdocore directories for completeness
+do
+done
+for file in `cat filelist/${PROVIDER}dir.lst`
+do
+done
+for file in `cat filelist/${PROVIDER}.lst`
+do
+done
+do
+ chmod a-x ${file}
+done
+pushd ${BUILDROOT}
+dpkg-shlibdeps --ignore-missing-info -pfdo${PROVIDER} ${CPROOT}/lib/*.so
+dpkg-gensymbols -q -p"fdo-${PROVIDER}" -P"debian/fdo${PROVIDER}"
+dpkg-gencontrol -p"fdo-${PROVIDER}" -P"debian/fdo${PROVIDER}"
+lintian -i debian/fdo${PROVIDER}.deb > tmp/fdo${PROVIDER}.lintian
+mv debian/fdo${PROVIDER}.deb bin/fdo-${PROVIDER}_${FDOBUILD}-${BUILDNUM}_${ARCH}.deb
+popd
Modified: trunk/Tools/Vagrant/scripts/dpkgmapguide.sh
--- trunk/Tools/Vagrant/scripts/dpkgmapguide.sh 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/scripts/dpkgmapguide.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -5,38 +5,53 @@
+# mapguideplatformbase/ - packaging directory for common MapGuide components
+# usr/local/mapguideopensource-3.0.0/ - copied tree for common components
+# DEBIAN/
# mapguidecommon/ - packaging directory for common MapGuide components
-# usr/local/mapguideopensource-2.4.0/ - copied tree for common components
# DEBIAN/
+# mapguidecoordsys/ - packaging directory for CS-Map coordinate system dictionaries
+# DEBIAN/
+# mapguidecoordsyslite/ - packaging directory for CS-Map coordinate system dictionaries
+# DEBIAN/
# mapguideserver/ - packaging directory for MapGuide Server
-# usr/local/mapguideopensource-2.4.0/ - copied tree for Server
+# usr/local/mapguideopensource-3.0.0/ - copied tree for Server
# DEBIAN/
# mapguidewebextensions/ - packaging directory for Web Extensions
-# usr/local/mapguideopensource-2.4.0/ - copied tree for Web Extensions
+# usr/local/mapguideopensource-3.0.0/ - copied tree for Web Extensions
# DEBIAN/
# mapguidehttpd/ - packaging directory for Apache Bundle
-# usr/local/mapguideopensource-2.4.0/ - copied tree for Apache bundle
+# usr/local/mapguideopensource-3.0.0/ - copied tree for Apache bundle
# DEBIAN/
-# Make sure setvars.sh is called first before running this script
BUILDROOT=`pwd`
-MGBUILD=2.6.0
+MGBUILD=3.0.0
+FDOBUILD=3.9.0
MGINST=usr/local/mapguideopensource-${MGBUILD}
-ROOT=${BUILDROOT}/debian/mapguidecommon
-TREE=${BUILDROOT}/debian
@@ -90,13 +105,34 @@
Priority: optional
Homepage: http://mapguide.osgeo.org
+Package: mapguideopensource-platformbase
+Section: misc
+Priority: optional
+Depends: \${mapguideplatformbase:Depends}
+Description: Base platform components for OSGeo MapGuide ${MGBUILD}
Package: mapguideopensource-common
Section: misc
Priority: optional
Depends: \${mapguidecommon:Depends}
-Description: OSGeo MapGuide ${MGBUILD} common components
+Description: OSGeo MapGuide ${MGBUILD} server-specific common components
+Package: mapguideopensource-coordsys
+Section: msic
+Priority: optional
+Depends: \${mapguidecoordsys:Depends}
+Description: CS-Map Coordinate System Dictionary data files
+Package: mapguideopensource-coordsys-lite
+Section: msic
+Priority: optional
+Description: CS-Map Coordinate System Dictionary data files. Lite version. Excludes country-specific grid files
Package: mapguideopensource-server
Section: misc
@@ -137,14 +173,46 @@
wget -N http://svn.osgeo.org/mapguide/trunk/MgDev/License.txt -O tmp/copyright
+MGINST=usr/local/mapguideopensource-${MGBUILD}
+PACKAGENAME=mapguideopensource-platformbase
+PACKAGEDIR=mapguideplatformbase
+ROOT=${BUILDROOT}/debian/mapguideplatformbase
+DIRLIST="lib"
+REMOVELIST="\.a\$ \.la\$"
+STRIPLIST="\.so\$ libdwf"
+EXCLUDEFILE=platformbase_excludes.txt
PACKAGENAME=mapguideopensource-common
PACKAGEDIR=mapguidecommon
-DIRLIST="lib share"
+ROOT=${BUILDROOT}/debian/mapguidecommon
+DIRLIST="lib"
+EXCLUDEFILE=mapguidecommon_excludes.txt
+EXCLUDEFILE=
+DIRLIST="share"
+STRIPLIST="\.so\$"
+source ./csmap_optimize.sh
MGINST=usr/local/mapguideopensource-${MGBUILD}/server
ROOT=${BUILDROOT}/debian/mapguideserver
Added: trunk/Tools/Vagrant/scripts/mapguidecommon_excludes.txt
--- trunk/Tools/Vagrant/scripts/mapguidecommon_excludes.txt (rev 0)
+++ trunk/Tools/Vagrant/scripts/mapguidecommon_excludes.txt 2014-09-30 11:37:11 UTC (rev 8370)
@@ -0,0 +1,27 @@
+libACE.so
+libACE.so.5.8.0
+libdwfcore-1.1.1.so
+libdwfemap-1.0.0.so
+libdwftk-7.1.1.so
+libMgFoundation-3.0.0.so
+libMgFoundation.so
+libMgGeometry-3.0.0.so
+libMgGeometry.so
+libMgGwsCommon-3.0.0.so
+libMgGwsCommon.so
+libMgGwsQueryEngine-3.0.0.so
+libMgGwsQueryEngine.so
+libMgGwsResource-3.0.0.so
+libMgGwsResource.so
+libMgMdfModel-3.0.0.so
+libMgMdfModel.so
+libMgMdfParser-3.0.0.so
+libMgMdfParser.so
+libMgPlatformBase-3.0.0.so
+libMgPlatformBase.so
+libMgRenderers-3.0.0.so
+libMgRenderers.so
+libMgStylization-3.0.0.so
+libMgStylization.so
+libxerces-c-3.1.so
+libxerces-c.so
Added: trunk/Tools/Vagrant/scripts/mginstallcentos.sh
--- trunk/Tools/Vagrant/scripts/mginstallcentos.sh (rev 0)
+++ trunk/Tools/Vagrant/scripts/mginstallcentos.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -0,0 +1,93 @@
+#!/bin/bash
+URL="http://download.osgeo.org/mapguide/releases/3.0.0/Release"
+#URL="http://192.168.0.4/downloads"
+FDOVER_MAJOR_MINOR=3.9
+FDOVER_POINT=0
+FDOVER_REV=0
+FDO_ARCH=i386
+FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.${FDOVER_POINT}
+FDOVER=${FDOVER_MAJOR_MINOR_REV}_${FDOVER_REV}
+MGVER_MAJOR_MINOR=3.0
+MGVER_POINT=0
+MGVER_REV=0
+MG_ARCH=i386
+MGVER_MAJOR_MINOR_REV=${MGVER_MAJOR_MINOR}.${MGVER_POINT}
+MGVER=${MGVER_MAJOR_MINOR_REV}.${MGVER_REV}
+FDO_TARBALL=fdosdk-centos6-${FDO_ARCH}-${FDOVER}.tar.gz
+MG_TARBALL=mapguideopensource-${MGVER}.${MG_ARCH}.tar.gz
+MG_URL=${URL}/${MG_TARBALL}
+FDO_URL=${URL}/${FDO_TARBALL}
+# Must have root
+if [[ $EUID -ne 0 ]]; then
+ echo "You must run this script with superuser privileges"
+ exit 1
+fi
+if [ ! -f ${FDO_TARBALL} ]; then
+wget -N ${FDO_URL}
+fi
+#tar -C / -zxvf ${FDO_TARBALL}
+mkdir -p /usr/local/fdo-${FDOVER_MAJOR_MINOR_REV}
+echo "[install]: Extracting FDO"
+tar -C /usr/local/fdo-${FDOVER_MAJOR_MINOR_REV}/ -zxf ${FDO_TARBALL}
+if [ ! -f ${MG_TARBALL} ]; then
+wget -N ${MG_URL}
+fi
+echo "[install]: Extracting MapGuide"
+tar -C / -zxf ${MG_TARBALL}
+# All of this is to make SELinux happy
+pushd /usr/local/fdo-${FDOVER_MAJOR_MINOR_REV}/lib
+echo "[config]: Making binaries SELinux compatible"
+chcon -t textrel_shlib_t *.so
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/bin
+chcon -t textrel_shlib_t mgserver
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/lib
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/lib
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/lib
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/apache2/lib
+popd
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/apache2/modules
+popd
+echo "[config]: Fixing permissions for certain folders"
+chmod 777 /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/www/TempDir
+pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/apache2/bin
+echo "[install]: Starting httpd"
+./apachectl start
+popd
+echo "[install]: Starting mgserver"
+./mgserverd.sh
+popd
+echo DONE
Added: trunk/Tools/Vagrant/scripts/mginstallubuntu.sh
--- trunk/Tools/Vagrant/scripts/mginstallubuntu.sh (rev 0)
+++ trunk/Tools/Vagrant/scripts/mginstallubuntu.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -0,0 +1,499 @@
+#!/bin/bash
+TEMPDIR=/tmp/build_mapguide
+URL="http://download.osgeo.org/mapguide/releases/3.0.0/Release/ubuntu12"
+#URL="http://192.168.0.5/downloads/ubuntu12"
+FDOVER_MAJOR_MINOR_REV=${FDOVER_MAJOR_MINOR}.0
+FDOBUILD=0
+FDOARCH=i386
+FDOVER=${FDOVER_MAJOR_MINOR_REV}-${FDOBUILD}_${FDOARCH}
+MGVER_MAJOR_MINOR_REV=${MGVER_MAJOR_MINOR}.0
+MGBUILD=0
+MGARCH=i386
+MGVER=${MGVER_MAJOR_MINOR_REV}-${MGBUILD}_${MGARCH}
+INSTALLER_TITLE="MapGuide Open Source Ubuntu installer"
+DEFAULT_SERVER_IP="127.0.0.1"
+DEFAULT_ADMIN_PORT=2810
+DEFAULT_CLIENT_PORT=2811
+DEFAULT_SITE_PORT=2812
+DEFAULT_HTTPD_PORT=8008
+DEFAULT_TOMCAT_PORT=8009
+csmap_choice="full"
+server_ip="127.0.0.1"
+webtier_server_ip="127.0.0.1"
+admin_port=2810
+client_port=2811
+site_port=2812
+httpd_port=8008
+tomcat_port=8009
+# Must have root
+ exit 1
+fi
+# Install required packages
+apt-get -y install dialog libexpat1 libssl1.0.0 odbcinst unixodbc libcurl3 libxslt1.1
+DIALOG=${DIALOG=dialog}
+main()
+ dialog_welcome
+ dialog_fdo_provider
+ dialog_server
+ dialog_webtier
+ #dialog_coordsys
+ #dump_configuration
+ install_fdo
+ install_mapguide_packages
+ post_install
+set_server_vars()
+ set -- $(<$1)
+ server_ip=$1
+ admin_port=$2
+ client_port=$3
+ site_port=$4
+set_webtier_vars()
+ set -- $(<$1)
+ webtier_server_ip=$1
+ httpd_port=$2
+ tomcat_port=$3
+dump_configuration()
+ echo "********* Configuration Summary ************"
+ echo " Default Ports (Server)"
+ echo " Admin: ${DEFAULT_ADMIN_PORT}"
+ echo " Client: ${DEFAULT_CLIENT_PORT}"
+ echo " Site: ${DEFAULT_SITE_PORT}"
+ echo " Default Ports (WebTier)"
+ echo " Apache: ${DEFAULT_HTTPD_PORT}"
+ echo " Tomcat: ${DEFAULT_TOMCAT_PORT}"
+ echo " Configured Ports (Server)"
+ echo " Admin: ${admin_port}"
+ echo " Client: ${client_port}"
+ echo " Site: ${site_port}"
+ echo " Configured Ports (WebTier)"
+ echo " Apache: ${httpd_port}"
+ echo " Tomcat: ${tomcat_port}"
+ echo " Other choices"
+ echo " FDO: ${fdo_provider_choice}"
+ echo " CS-Map: ${csmap_choice}"
+ echo " Server IP: ${server_ip}"
+ echo "********************************************"
+dialog_welcome()
+ $DIALOG --backtitle "$INSTALLER_TITLE" \
+ --title "Welcome" --clear \
+ --yesno "Welcome to the MapGuide Open Source Ubuntu installer. Would you like to proceed?" 10 30
+ case $? in
+ 1)
+ echo "Cancelled"
+ exit 1;;
+ 255)
+ echo "Cancelled"
+ exit 255;;
+ esac
+dialog_fdo_provider()
+ tempfile=`tempfile 2>/dev/null` || tempfile=/tmp/test$$
+ trap "rm -f $tempfile" 0 1 2 5 15
+ #arcsde "OSGeo FDO Provider for ArcSDE" off \
+ # Disable RDBMS provider selection by default
+ --title "FDO Providers" --clear \
+ --checklist "Check the FDO Providers you want to install" 20 61 5 \
+ sdf "OSGeo FDO Provider for SDF" ON \
+ shp "OSGeo FDO Provider for SHP" ON \
+ sqlite "OSGeo FDO Provider for SQLite" ON \
+ gdal "OSGeo FDO Provider for GDAL" ON \
+ ogr "OSGeo FDO Provider for OGR" ON \
+ kingoracle "OSGeo FDO Provider for Oracle" off \
+ rdbms "RDBMS FDO Providers (ODBC, MySQL, PostgreSQL)" off \
+ wfs "OSGeo FDO Provider for WFS" ON \
+ wms "OSGeo FDO Provider for WMS" ON 2> $tempfile
+ fdo_provider_choice=`cat $tempfile | sed s/\"//g`
+ case $? in
+ 1)
+ echo "Cancelled"
+ exit 1;;
+ 255)
+ echo "Cancelled"
+ exit 255;;
+ esac
+dialog_server()
+ dialog --backtitle "$INSTALLER_TITLE" --title "Server Configuration" \
+ --form "\nSet the port numbers that the MapGuide Server will listen on" 25 60 16 \
+ "Server IP:" 1 1 "${DEFAULT_SERVER_IP}" 1 25 25 30 \
+ "Admin Port:" 2 1 "${DEFAULT_ADMIN_PORT}" 2 25 25 30 \
+ "Client Port:" 3 1 "${DEFAULT_CLIENT_PORT}" 3 25 25 30 \
+ "Site Port:" 4 1 "${DEFAULT_SITE_PORT}" 4 25 25 30 2>/tmp/form.$$
+ case $? in
+ 1)
+ echo "Cancelled"
+ exit 1;;
+ 255)
+ echo "Cancelled"
+ exit 255;;
+ esac
+ set_server_vars "/tmp/form.$$"
+ rm /tmp/form.$$
+dialog_webtier()
+ dialog --backtitle "$INSTALLER_TITLE" --title "Web Tier Configuration" \
+ --form "\nSet the port numbers that Apache/Tomcat will listen on" 25 60 16 \
+ "Connect to Server IP:" 1 1 "${DEFAULT_SERVER_IP}" 1 25 25 30 \
+ "Apache Port:" 2 1 "${DEFAULT_HTTPD_PORT}" 2 25 25 30 \
+ "Tomcat Port:" 3 1 "${DEFAULT_TOMCAT_PORT}" 3 25 25 30 2>/tmp/form.$$
+ case $? in
+ 1)
+ echo "Cancelled"
+ exit 1;;
+ 255)
+ echo "Cancelled"
+ exit 255;;
+ esac
+ set_webtier_vars "/tmp/form.$$"
+ rm /tmp/form.$$
+dialog_coordsys()
+ dialog --backtitle "$INSTALLER_TITLE" \
+ --title "Coordinate System Configuration" --clear \
+ --radiolist "Choose the CS-Map profile you want for this MapGuide Installation" 20 80 5 \
+ "full" "Download/Install the full set of data files" ON \
+ "lite" "Download/Install the lite configuration (no grid files)" off 2> $tempfile
+ csmap_choice=`cat $tempfile`
+ case $? in
+ 1)
+ echo "Cancelled"
+ exit 1;;
+ 255)
+ echo "Cancelled"
+ exit 255;;
+ esac
+install_fdo()
+ # set initial registration state
+ arcsde_registered=0
+ gdal_registered=0
+ kingoracle_registered=0
+ rdbms_registered=0
+ ogr_registered=0
+ sdf_registered=0
+ shp_registered=0
+ sqlite_registered=0
+ wfs_registered=0
+ wms_registered=0
+ # Include core and rdbms packages regardless of choice.
+ fdo_provider_choice="core rdbms $fdo_provider_choice"
+ # Download and install Ubuntu packages for FDO
+ for file in $fdo_provider_choice
+ do
+ #echo "Downloading ${URL}/fdo-${file}_${FDOVER}.deb"
+ wget -N ${URL}/fdo-${file}_${FDOVER}.deb
+ #echo "Installing fdo-${file}_${FDOVER}.deb"
+ dpkg -E -G --install fdo-${file}_${FDOVER}.deb
+ done
+ # Nuke the old providers.xml, we're rebuiding it
+ providersxml=/usr/local/fdo-${FDOVER_MAJOR_MINOR_REV}/lib/providers.xml
+ echo -ne "<?xml version=\"1.0\" encoding=\"utf-8\" standalone=\"no\" ?>" > ${providersxml}
+ echo -ne "\n<FeatureProviderRegistry>" >> ${providersxml}
+ do
+ case $file in
+ arcsde)
+ if [ $arcsde_registered -eq 1 ];
+ then
+ continue
+ fi
+ echo "Registering ArcSDE Provider"
+ echo -ne "\n <FeatureProvider>" >> ${providersxml}
+ echo -ne "\n <Name>OSGeo.ArcSDE.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo -ne "\n <DisplayName>OSGeo FDO Provider for ArcSDE</DisplayName>" >> ${providersxml}
+ echo -ne "\n <Description>Read/write access to an ESRI ArcSDE-based data store, using Oracle and SQL Server</Description>" >> ${providersxml}
+ echo -ne "\n <IsManaged>False</IsManaged>" >> ${providersxml}
+ echo -ne "\n <Version>${FDOVER_MAJOR_MINOR_REV}.0</Version>" >> ${providersxml}
+ echo -ne "\n <FeatureDataObjectsVersion>${FDOVER_MAJOR_MINOR_REV}.0</FeatureDataObjectsVersion>" >> ${providersxml}
+ echo -ne "\n <LibraryPath>libArcSDEProvider.so</LibraryPath>" >> ${providersxml}
+ echo -ne "\n </FeatureProvider>" >> ${providersxml}
+ arcsde_registered=1
+ gdal)
+ if [ $gdal_registered -eq 1 ];
+ then
+ continue
+ fi
+ echo "Registering GDAL Provider"
+ echo -ne "\n <Name>OSGeo.Gdal.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo -ne "\n <DisplayName>OSGeo FDO Provider for GDAL</DisplayName>" >> ${providersxml}
+ echo -ne "\n <Description>FDO Provider for GDAL</Description>" >> ${providersxml}
+ echo -ne "\n <LibraryPath>libGRFPProvider.so</LibraryPath>" >> ${providersxml}
+ gdal_registered=1
+ kingoracle)
+ if [ $kingoracle_registered -eq 1 ];
+ then
+ continue
+ fi
+ echo "Registering King Oracle Provider"
+ echo -ne "\n <Name>OSGeo.KingOracle.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo -ne "\n <DisplayName>OSGeo FDO Provider for Oracle</DisplayName>" >> ${providersxml}
+ echo -ne "\n <Description>Read/write access to spatial and attribute data in Oracle Spatial</Description>" >> ${providersxml}
+ echo -ne "\n <LibraryPath>libKingOracleProvider.so</LibraryPath>" >> ${providersxml}
+ kingoracle_registered=1
+ rdbms)
+ if [ $rdbms_registered -eq 1 ];
+ then
+ continue
+ fi
+ echo "Registering ODBC Provider"
+ echo -ne "\n <Name>OSGeo.ODBC.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo -ne "\n <DisplayName>OSGeo FDO Provider for ODBC</DisplayName>" >> ${providersxml}
+ echo -ne "\n <Description>FDO Provider for ODBC</Description>" >> ${providersxml}
+ echo -ne "\n <LibraryPath>libFdoODBC.so</LibraryPath>" >> ${providersxml}
+ echo "Registering PostgreSQL Provider"
+ echo -ne "\n <Name>OSGeo.PostgreSQL.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo -ne "\n <DisplayName>OSGeo FDO Provider for PostgreSQL</DisplayName>" >> ${providersxml}
+ echo -ne "\n <Description>Read/write access to PostgreSQL/PostGIS-based data store. Supports spatial data types and spatial query operations</Description>" >> ${providersxml}
+ echo -ne "\n <LibraryPath>libFdoPostgreSQL.so</LibraryPath>" >> ${providersxml}
+ echo "Registering MySQL Provider"
+ echo -ne "\n <Name>OSGeo.MySQL.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo -ne "\n <DisplayName>OSGeo FDO Provider for MySQL</DisplayName>" >> ${providersxml}
+ echo -ne "\n <Description>FDO Provider for MySQL</Description>" >> ${providersxml}
+ echo -ne "\n <LibraryPath>libFdoMySQL.so</LibraryPath>" >> ${providersxml}
+ rdbms_registered=1
+ ogr)
+ if [ $ogr_registered -eq 1 ];
+ then
+ continue
+ fi
+ echo "Registering OGR Provider"
+ echo -ne "\n <Name>OSGeo.OGR.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo -ne "\n <DisplayName>OSGeo FDO Provider for OGR</DisplayName>" >> ${providersxml}
+ echo -ne "\n <Description>FDO Access to OGR Data Sources</Description>" >> ${providersxml}
+ echo -ne "\n <LibraryPath>libOGRProvider.so</LibraryPath>" >> ${providersxml}
+ ogr_registered=1
+ sdf)
+ if [ $sdf_registered -eq 1 ];
+ then
+ continue
+ fi
+ echo "Registering SDF Provider"
+ echo -ne "\n <Name>OSGeo.SDF.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo -ne "\n <DisplayName>OSGeo FDO Provider for SDF</DisplayName>" >> ${providersxml}
+ echo -ne "\n <Description>Read/write access to Autodesk's spatial database format, a file-based geodatabase that supports multiple features/attributes, spatial indexing and file-locking</Description>" >> ${providersxml}
+ echo -ne "\n <LibraryPath>libSDFProvider.so</LibraryPath>" >> ${providersxml}
+ sdf_registered=1
+ shp)
+ if [ $shp_registered -eq 1 ];
+ then
+ continue
+ fi
+ echo "Registering SHP Provider"
+ echo -ne "\n <Name>OSGeo.SHP.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo -ne "\n <DisplayName>OSGeo FDO Provider for SHP</DisplayName>" >> ${providersxml}
+ echo -ne "\n <Description>Read/write access to spatial and attribute data in an ESRI SHP file</Description>" >> ${providersxml}
+ echo -ne "\n <LibraryPath>libSHPProvider.so</LibraryPath>" >> ${providersxml}
+ shp_registered=1
+ sqlite)
+ if [ $sqlite_registered -eq 1 ];
+ then
+ continue
+ fi
+ echo "Registering SQLite Provider"
+ echo -ne "\n <Name>OSGeo.SQLite.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo -ne "\n <DisplayName>OSGeo FDO Provider for SQLite</DisplayName>" >> ${providersxml}
+ echo -ne "\n <Description>Read/write access to feature data in a SQLite file</Description>" >> ${providersxml}
+ echo -ne "\n <LibraryPath>libSQLiteProvider.so</LibraryPath>" >> ${providersxml}
+ sqlite_registered=1
+ wfs)
+ if [ $wfs_registered -eq 1 ];
+ then
+ continue
+ fi
+ echo "Registering WFS Provider"
+ echo -ne "\n <Name>OSGeo.WFS.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo -ne "\n <DisplayName>OSGeo FDO Provider for WFS</DisplayName>" >> ${providersxml}
+ echo -ne "\n <Description>Read access to OGC WFS-based data store</Description>" >> ${providersxml}
+ echo -ne "\n <LibraryPath>libWFSProvider.so</LibraryPath>" >> ${providersxml}
+ wfs_registered=1
+ wms)
+ if [ $wms_registered -eq 1 ];
+ then
+ continue
+ fi
+ echo "Registering WMS Provider"
+ echo -ne "\n <Name>OSGeo.WMS.${FDOVER_MAJOR_MINOR}</Name>" >> ${providersxml}
+ echo -ne "\n <DisplayName>OSGeo FDO Provider for WMS</DisplayName>" >> ${providersxml}
+ echo -ne "\n <Description>Read access to OGC WMS-based data store</Description>" >> ${providersxml}
+ echo -ne "\n <LibraryPath>libWMSProvider.so</LibraryPath>" >> ${providersxml}
+ wms_registered=1
+ esac
+ done
+ echo -ne "\n</FeatureProviderRegistry>" >> ${providersxml}
+install_mapguide_packages()
+ # Download Ubuntu packages for MapGuide
+ mapguide_packages="platformbase coordsys common server webextensions httpd"
+ if [ $csmap_choice = "lite" ]; then
+ mapguide_packages="platformbase coordsys-lite common server webextensions httpd"
+ fi
+ for file in $mapguide_packages
+ do
+ echo "[download]: ${URL}/mapguideopensource-${file}_${MGVER}.deb"
+ wget -N ${URL}/mapguideopensource-${file}_${MGVER}.deb
+ echo "[install]: mapguideopensource-${file}_${MGVER}.deb"
+ dpkg -E -G --install mapguideopensource-${file}_${MGVER}.deb
+ done
+post_install()
+ echo "[config]: Updating serverconfig.ini with configuration choices"
+ sed -i 's/MachineIp.*= '"${DEFAULT_SERVER_IP}"'/MachineIp = '"${server_ip}"'/g' /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/bin/serverconfig.ini
+ sed -i 's/IpAddress.*= '"${DEFAULT_SERVER_IP}"'/IpAddress = '"${server_ip}"'/g' /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/bin/serverconfig.ini
+ sed -i 's/Port.*= '"${DEFAULT_ADMIN_PORT}"'/Port = '"${admin_port}"'/g' /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/bin/serverconfig.ini
+ sed -i 's/Port.*= '"${DEFAULT_CLIENT_PORT}"'/Port = '"${client_port}"'/g' /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/bin/serverconfig.ini
+ sed -i 's/Port.*= '"${DEFAULT_SITE_PORT}"'/Port = '"${site_port}"'/g' /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/bin/serverconfig.ini
+ echo "[config]: Updating webconfig.ini with configuration choices"
+ sed -i 's/IpAddress.*= '"${DEFAULT_SERVER_IP}"'/IpAddress = '"${webtier_server_ip}"'/g' /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/www/webconfig.ini
+ sed -i 's/Port.*= '"${DEFAULT_ADMIN_PORT}"'/Port = '"${admin_port}"'/g' /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/www/webconfig.ini
+ sed -i 's/Port.*= '"${DEFAULT_CLIENT_PORT}"'/Port = '"${client_port}"'/g' /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/www/webconfig.ini
+ sed -i 's/Port.*= '"${DEFAULT_SITE_PORT}"'/Port = '"${site_port}"'/g' /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/www/webconfig.ini
+ echo "[config]: Updating httpd.conf with configuration choices"
+ sed -i 's/Listen '"${DEFAULT_HTTPD_PORT}"'/Listen '"${httpd_port}"'/g' /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/apache2/conf/httpd.conf
+ sed -i 's/worker.worker1.port='"${DEFAULT_TOMCAT_PORT}"'/worker.worker1.port='"${tomcat_port}"'/g' /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/apache2/conf/workers.properties
+ sed -i 's/Connector port=\"'"${DEFAULT_TOMCAT_PORT}"'\"/Connector port=\"'"${tomcat_port}"'\"/g' /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/tomcat/conf/server.xml
+ echo "[config]: Updating tomcat configs with configuration choices"
+ echo "[config]: Fixing permissions for certain folders"
+ chmod 777 /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/www/TempDir
+ echo "Creating lock file directory for MapGuide Server"
+ # Create lock file directory for Server
+ if [ ! -d /var/lock/mgserver ]; then
+ mkdir /var/lock/mgserver
+ fi
+ echo "Starting httpd"
+ pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/apache2/bin
+ ./apachectl start
+ popd
+ echo "Starting tomcat"
+ pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/webserverextensions/tomcat/bin
+ sh ./startup.sh
+ popd
+ echo "Starting mgserver"
+ pushd /usr/local/mapguideopensource-${MGVER_MAJOR_MINOR_REV}/server/bin
+ ./mgserverd.sh
+ popd
+ echo "DONE!"
+# Create temporary download directory
+mkdir -p ${TEMPDIR}
+pushd ${TEMPDIR}
+main
+popd
Added: trunk/Tools/Vagrant/scripts/mguninstallubuntu.sh
--- trunk/Tools/Vagrant/scripts/mguninstallubuntu.sh (rev 0)
+++ trunk/Tools/Vagrant/scripts/mguninstallubuntu.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -0,0 +1,21 @@
+#!/bin/bash
+# Must have root
+ exit 1
+fi
+# Remove Ubuntu packages for MapGuide
+for file in server webextensions httpd coordsys coordsys-lite common platformbase
+do
+ dpkg --remove mapguideopensource-${file}
+done
+# Remove Ubuntu packages for FDO
+for file in gdal kingoracle ogr rdbms sdf shp sqlite wfs wms arcsde core
+do
+ dpkg --remove fdo-${file}
+done
Added: trunk/Tools/Vagrant/scripts/platformbase_excludes.txt
--- trunk/Tools/Vagrant/scripts/platformbase_excludes.txt (rev 0)
+++ trunk/Tools/Vagrant/scripts/platformbase_excludes.txt 2014-09-30 11:37:11 UTC (rev 8370)
@@ -0,0 +1,13 @@
+libdb-4.8.so
+libdb-4.so
+libdb_cxx-4.8.so
+libdb_cxx-4.so
+libdb_cxx.so
+libdbxml-2.5.so
+libdbxml.so
+liblib_json.so
+libMgMapGuideCommon-3.0.0.so
+libMgMapGuideCommon.so
+libxqilla.so
+libxqilla.so.5
+libxqilla.so.5.0.4
Added: trunk/Tools/Vagrant/scripts/prepare_dpkg_fdo.sh
--- trunk/Tools/Vagrant/scripts/prepare_dpkg_fdo.sh (rev 0)
+++ trunk/Tools/Vagrant/scripts/prepare_dpkg_fdo.sh 2014-09-30 11:37:11 UTC (rev 8370)
@@ -0,0 +1,56 @@
+#!/bin/bash
+# prepare_dpkg_fdo.sh
+# Creates deb files from CentOS SDK files
+save_current_file_list()
+ echo "[info]: Saving current FDO dir file list"
+ pushd $FDO_INST
+ # For lazy folks who build from svn working copies instead of svn exports, we need to weed out any .svn dirs before compiling the file-list
+ find . -name .svn -exec rm -rf {} \;
+ find . -type f -print > ${FDO_FILELIST}/temp.lst
+ find . -type l -print >> ${FDO_FILELIST}/temp.lst
+ sort ${FDO_FILELIST}/temp.lst > ${FDO_FILELIST}/orig.lst
+ find . -type d -print | sort > ${FDO_FILELIST}/origdir.lst
+ popd
+update_fdocore_file_list()
+ echo "[info]: Updating FDO core file list for deb packaging"
+ pushd $FDO_INST
+ sort ${FDO_FILELIST}/temp.lst > ${FDO_FILELIST}/fdocore.lst
+ find . -type d -print | sort > ${FDO_FILELIST}/fdocoredir.lst
+ popd
+update_provider_file_list()
+ PROVIDER=$1
+ echo "[info]: Updating $PROVIDER file list for deb packaging"
+ pushd $FDO_INST
+ #mkdir -p $BUILDLIST
+ cat ${FDO_FILELIST}/orig.lst >> ${FDO_FILELIST}/temp.lst
+ sort ${FDO_FILELIST}/temp.lst | uniq -u > ${FDO_FILELIST}/${PROVIDER}.lst
+ find . -type d -print | sort > ${FDO_FILELIST}/temp.lst
+ cat ${FDO_FILELIST}/origdir.lst >> ${FDO_FILELIST}/temp.lst
+ sort ${FDO_FILELIST}/temp.lst | uniq -u > ${FDO_FILELIST}/${PROVIDER}dir.lst
+ popd
+for comp in shp sqlite gdal ogr wfs wms rdbms kingoracle sdf
+do
+done
Modified: trunk/Tools/Vagrant/sources/patches/patchinfo.txt
--- trunk/Tools/Vagrant/sources/patches/patchinfo.txt 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/sources/patches/patchinfo.txt 2014-09-30 11:37:11 UTC (rev 8370)
@@ -1,2 +1 @@
-http://trac.osgeo.org/csmap/ticket/172
-http://trac.osgeo.org/fdo/ticket/888
+No custom patches required
Modified: trunk/Tools/Vagrant/support/apt_list.txt
--- trunk/Tools/Vagrant/support/apt_list.txt 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/support/apt_list.txt 2014-09-30 11:37:11 UTC (rev 8370)
@@ -10,4 +10,4 @@
Need atomic.h copied to /usr/include/asm/atomic.h
-build-essential bison automake libtool libpng-dev libjpeg62-dev libxslt-dev libfreetype6-dev libpcre3-dev openjdk-7-jdk subversion lintian ant scons dos2unix libldap-dev libssl-dev libcurl4-openssl-dev libexpat-dev libmysqlclient-dev unixODBC-dev python-dev libpq-dev libcppunit-dev
+build-essential bison automake libtool libc6-dev libpng-dev libjpeg62-dev libxslt-dev libfreetype6-dev libpcre3-dev openjdk-7-jdk subversion lintian ant scons dos2unix libldap-dev libssl-dev libcurl4-openssl-dev libexpat-dev libmysqlclient-dev unixODBC-dev python-dev libpq-dev libcppunit-dev
Modified: trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/ubuntu/x64/Vagrantfile 2014-09-30 11:37:11 UTC (rev 8370)
@@ -10,7 +10,7 @@
# please see the online documentation at vagrantup.com.
# Every Vagrant virtual environment requires a box to build off of.
- config.vm.box = "vagrant-trusty64"
+ config.vm.box = "vagrant-precise64"
# The url from where the 'config.vm.box' box will be fetched if it
# doesn't already exist on the user's system.
@@ -126,19 +126,41 @@
exit $error
fi
+check_test()
+ error=$?
+ if [ $error -ne 0 ]; then
+ echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)"
+ echo "[warning]: ${BUILD_COMPONENT} - Unit Tests failed ($error)" >> ~/unit_test_status.log
+ fi
cd ~
echo [provision]: Home directory is `pwd`
echo [provision]: Checking directories
HAVE_FDO=0
HAVE_FDO_LIBS=0
HAVE_MAPGUIDE=0
-MG_UNIT_TEST=0
+MG_UNIT_TEST=1
+FDO_UNIT_TEST=1
SCRIPT_ROOT=~/scripts
FDO_SRC_ROOT=~/fdo
-FDO_SRC=$FDO_SRC_ROOT/trunk
+FDO_VER_MM=3.9
+FDO_VER_FULL=${FDO_VER_MM}.0
+MG_VER_MM=3.0
+MG_VER_FULL=${MG_VER_MM}.0
+FDO_SRC_DIR=trunk
+FDO_SRC=$FDO_SRC_ROOT/$FDO_SRC_DIR
FDO_LIB_SRC=~/fdo_rdbms_thirdparty
MG_SRC_ROOT=~/mapguide/trunk
MG_SRC=$MG_SRC_ROOT/MgDev
+FDO_TARBALL=fdo-checkout.tar.gz
+MG_TARBALL=mapguide-checkout.tar.gz
+HAVE_FDO_SDK=0
+FDO_SDK_PKG_PATH=~/fdosdk
+FDO_SDK_TARBALL=
+FDO_INST=/usr/local/fdo-${FDO_VER_FULL}
if [ -d $FDO_SRC ];
then
HAVE_FDO=1
@@ -151,6 +173,21 @@
then
HAVE_MAPGUIDE=1
fi
+if [ -f /mapguide_sources/fdosdk_filename ] && [ -f /mapguide_sources/fdosdk_rev ] && [ -d /mapguide_sources/filelist ];
+then
+ FDO_SDK_TARBALL=`cat /mapguide_sources/fdosdk_filename`
+ FDO_REV=`cat /mapguide_sources/fdosdk_rev`
+ if [ -f /mapguide_sources/$FDO_SDK_TARBALL ];
+ then
+ sudo mkdir -p ${FDO_INST}
+ sudo tar -zxf /mapguide_sources/$FDO_SDK_TARBALL -C ${FDO_INST}
+ HAVE_FDO_SDK=1
+ FDO_UNIT_TEST=0
+ echo [provision]: Using FDO SDK. Not building from source. Not running FDO unit tests.
+ fi
+else
+ echo [provision]: FDO SDK not found. Building FDO from source.
+fi
if [ -f /usr/include/asm/atomic.h ];
then
echo [provision]: atomic.h exists. Doing nothing
@@ -159,12 +196,27 @@
sudo mkdir -p /usr/include/asm
sudo cp /mapguide_sources/atomic.h /usr/include/asm
fi
-echo [provision]: Checking libraries
-sudo apt-get install -y libpq-dev libmysqlclient-dev
+#echo [provision]: Checking libraries
+#sudo apt-get install -y libpq-dev libmysqlclient-dev
+echo [provision]: Clean line endings
+sudo dos2unix /vagrant/*.sh
+sudo dos2unix /vagrant/*.pl
+sudo dos2unix /vagrant/*.txt
echo [provision]: Copying shell scripts
mkdir -p $SCRIPT_ROOT
+if [ $HAVE_FDO_SDK -eq 1 ];
+then
+ echo [provision]: Prepare package build area for FDO SDK
+ mkdir -p $FDO_SDK_PKG_PATH
+ cp -R /mapguide_sources/filelist $FDO_SDK_PKG_PATH
+ cp -f /vagrant/dpkgfdo.sh $FDO_SDK_PKG_PATH
+ cp -f /vagrant/dpkgfdocore.sh $FDO_SDK_PKG_PATH
+ cp -f /vagrant/dpkgfdoprovider.sh $FDO_SDK_PKG_PATH
+ cp -f /vagrant/revnum.pl $FDO_SDK_PKG_PATH
+fi
cp -f /vagrant/*.sh $SCRIPT_ROOT
cp -f /vagrant/*.pl $SCRIPT_ROOT
+cp -f /vagrant/*.txt $SCRIPT_ROOT
echo [provision]: Flip Ubuntu switch
cd $SCRIPT_ROOT
sed -i 's/UBUNTU=0/UBUNTU=1/g' build.sh
@@ -173,39 +225,52 @@
sed -i 's/FDO_CPU=x86/FDO_CPU=x64/g' build_fdo.sh
sed -i 's/FDO_BUILD_CPU=i386/FDO_BUILD_CPU=amd64/g' build_fdo.sh
sed -i 's/LIB_DIRNAME=lib/LIB_DIRNAME=lib64/g' build_fdo.sh
-if [ $HAVE_FDO_LIBS -eq 0 ];
+if [ $HAVE_FDO_SDK -eq 0 ];
then
- echo [provision]: Extracting FDO thirdparty libs
- tar -zxf /mapguide_sources/fdo_rdbms_thirdparty.tar.gz -C ~
+ if [ $HAVE_FDO_LIBS -eq 0 ];
+ then
+ echo [provision]: Extracting FDO thirdparty libs
+ tar -zxf /mapguide_sources/fdo_rdbms_thirdparty.tar.gz -C ~
+ fi
+ if [ $HAVE_FDO -eq 0 ];
+ then
+ echo [provision]: Extracting FDO working copy
+ mkdir -p $FDO_SRC_ROOT
+ tar -zxf /mapguide_sources/$FDO_TARBALL -C $FDO_SRC_ROOT
+ fi
fi
-if [ $HAVE_FDO -eq 0 ];
-then
- echo [provision]: Extracting FDO trunk working copy
- mkdir -p ~/fdo
- tar -zxf /mapguide_sources/fdo-checkout.tar.gz -C ~/fdo
-fi
if [ $HAVE_MAPGUIDE -eq 0 ];
then
- echo [provision]: Extracting MapGuide trunk working copy
+ echo [provision]: Extracting MapGuide working copy
mkdir -p $MG_SRC_ROOT
- tar -zxf /mapguide_sources/mapguide-checkout.tar.gz -C $MG_SRC_ROOT
+ tar -zxf /mapguide_sources/$MG_TARBALL -C $MG_SRC_ROOT
fi
-echo [provision]: svn update FDO
-BUILD_COMPONENT="svn update FDO"
-# Only for this VM, svn is 1.8 so we have to upgrade the WC first before it can be updated
-svn upgrade $FDO_SRC
-svn update $FDO_SRC
-check_build
+then
+ echo [provision]: svn update FDO
+ BUILD_COMPONENT="svn update FDO"
+ # Only for Ubuntu 14.04 VM, svn is 1.8 so we have to upgrade the WC first before it can be updated
+ #svn upgrade $FDO_SRC
+ svn update $FDO_SRC
+ check_build
+else
+ echo [provision]: Using FDO SDK. No svn update of source required.
+fi
echo [provision]: svn update MapGuide
BUILD_COMPONENT="svn update MapGuide"
-svn upgrade $MG_SRC
+# Only for Ubuntu 14.04 VM, svn is 1.8 so we have to upgrade the WC first before it can be updated
+#svn upgrade $MG_SRC
svn update $MG_SRC
check_build
-if [ -d /mapguide_sources/patches/fdo ];
then
- echo [provision]: Applying FDO source patches
- cp -R /mapguide_sources/patches/fdo/* $FDO_SRC
+ if [ -d /mapguide_sources/patches/fdo ];
+ then
+ echo [provision]: Applying FDO source patches
+ cp -R /mapguide_sources/patches/fdo/* $FDO_SRC
+ fi
+else
+ echo [provision]: Using FDO SDK. No source patches to apply
fi
if [ -d /mapguide_sources/patches/mapguide ];
then
@@ -215,27 +280,96 @@
echo [provision]: Making sure swig is executable
chmod +x $MG_SRC/Oem/SWIGEx/Linux/swig
cd ~/scripts
-BUILD_COMPONENT="FDO"
-sudo -E ./build_fdo.sh 2>&1 | tee ~/fdo_build.log
-check_build
+then
+ BUILD_COMPONENT="FDO"
+ sudo -E ./build_fdo.sh 2>&1 | tee ~/fdo_build.log
+ check_build
+ FDO_REV=`svn info $FDO_SRC | perl revnum.pl`
+else
+ echo [provision]: Re-packaging FDO SDK r$FDO_REV as debs
+ FDO_FILELIST=$FDO_SDK_PKG_PATH/filelist
+ pushd $FDO_SDK_PKG_PATH
+ ./dpkgfdo.sh amd64 $FDO_REV 2>&1 | tee ~/dpkg_fdo.log
+ popd
+fi
BUILD_COMPONENT="MapGuide"
sudo -E ./build.sh 2>&1 | tee ~/mapguide_build.log
check_build
MG_REV=`svn info $MG_SRC | perl revnum.pl`
BUILD_COMPONENT="MapGuide deb packages"
-sudo ./dpkgmapguide.sh amd64 $MG_REV
+./dpkgmapguide.sh amd64 $MG_REV 2>&1 | tee ~/dpkg_mapguide.log
check_build
+> ~/unit_test_status.log
+if [ $FDO_UNIT_TEST -eq 1 ];
+then
+ export NLSPATH=/usr/local/fdo-${FDO_VER_FULL}/nls/%N
+ echo [provision]: Unit test FDO
+ BUILD_COMPONENT="Unit Test FDO Core"
+ cd $SCRIPT_ROOT/fdo_build_area/Fdo/UnitTest
+ sudo -E ./UnitTest 2>&1 | tee ~/fdo_core_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test SHP Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/SHP/Src/UnitTest
+ sudo -E ./UnitTest 2>&1 | tee ~/fdo_shp_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test SDF Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/SDF/Src/UnitTest
+ sudo -E ./UnitTest 2>&1 | tee ~/fdo_sdf_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test SQLite Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/SQLite/Src/UnitTest
+ sudo -E ./UnitTest 2>&1 | tee ~/fdo_sqlite_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test GDAL Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/GDAL/Src/UnitTest
+ sudo -E ./UnitTest 2>&1 | tee ~/fdo_gdal_unit_test.log
+ check_test
+ BUILD_COMPONENT="Unit Test WMS Provider"
+ cd $SCRIPT_ROOT/fdo_build_area/Providers/WMS/Src/UnitTest
+ sudo -E ./UnitTest 2>&1 | tee ~/fdo_wms_unit_test.log
+ check_test
+fi
if [ $MG_UNIT_TEST -eq 1 ];
then
echo [provision]: Unit test MapGuide
- cd $SCRIPT_ROOT/mgdev
- sudo make check 2>&1 | tee ~/mapguide_unit_test.log
+ BUILD_COMPONENT="Unit Test MapGuide Server"
+ # HACK: Tile and Resource Service tests are known to freeze our VMs when driven by vagrant (why? who knows?
+ # All we know is that those tests involve threads)
+ # So test everything *but* the above services. If required, this can be tested under a manually controlled
+ # VM
+ # build the individual targets that would comprise "make check" sans execution of unittest.sh
+ cd $SCRIPT_ROOT/mgdev/Server/src/UnitTesting
+ sudo make libMgUnitTesting.la
+ cd $SCRIPT_ROOT/mgdev/Server/src/Core
+ sudo make unittest.sh
+ # Run the test suites individually except for TileService for reasons already stated
+ for comp in CoordinateSystem FeatureService Geometry KmlService LogManager MdfModel Misc RenderingService ServerAdminService ServerManager ServiceManager SiteManager SiteService ProfilingService TransformMesh
+ do
+ sudo -E ./mgserver test $comp UnitTestResults_${comp}.xml 2>&1 | tee ~/mapguide_${comp}_unit_test.log
+ check_test
+ if [ -f UnitTestResults_${comp}.xml ]; then
+ sudo mv UnitTestResults_${comp}.xml ~/UnitTestResults_${comp}.xml
+ fi
+ done
fi
cd $SCRIPT_ROOT
sudo mkdir -p /vagrant/build
sudo mv -f ~/*.log /vagrant/build
-sudo cp fdo_build_area/install/bin/*.deb /vagrant/build
+then
+ sudo cp fdo_build_area/install/bin/*.deb /vagrant/build
+ sudo cp ~/fdo_*_unit_test.log /vagrant/build
+else
+ sudo cp $FDO_SDK_PKG_PATH/bin/*.deb /vagrant/build
+fi
sudo cp bin/*.deb /vagrant/build
+sudo cp ~/UnitTestResults_*.xml /vagrant/build
+sudo cp /vagrant/mginstallubuntu.sh /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/FDOBUILD=0/FDOBUILD='"$FDO_REV"'/g' /vagrant/build/mginstallubuntu.sh
+sudo sed -i 's/MGBUILD=0/MGBUILD='"$MG_REV"'/g' /vagrant/build/mginstallubuntu.sh
# Do not update the working copy tarballs. Ubuntu 14.04 uses svn 1.8 which will break
# the working copy if copied over to a CentOS VM (which is still on 1.6)
@@ -243,14 +377,14 @@
#if [ ! -d /mapguide_sources/updated ]; then
# sudo mkdir -p /mapguide_sources/updated
-# cd ~/mapguide/trunk
+# cd $MG_SRC_ROOT
# echo [provision]: Updating mapguide source tarball
-# tar -zcf mapguide-checkout.tar.gz MgDev
-# sudo mv mapguide-checkout.tar.gz /mapguide_sources/updated
-# cd ~/fdo
+# tar -zcf $MG_TARBALL MgDev
+# sudo mv $MG_TARBALL /mapguide_sources/updated
+# cd $FDO_SRC_ROOT
# echo [provision]: Updating fdo source tarball
-# tar -zcf fdo-checkout.tar.gz trunk
-# sudo mv fdo-checkout.tar.gz /mapguide_sources/updated
+# tar -zcf $FDO_TARBALL $FDO_SRC_DIR
+# sudo mv $FDO_TARBALL /mapguide_sources/updated
#else
# echo [provision]: Updated tarballs already exist. Doing nothing
#fi
Modified: trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile
--- trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile 2014-09-29 13:58:02 UTC (rev 8369)
+++ trunk/Tools/Vagrant/ubuntu/x86/Vagrantfile 2014-09-30 11:37:11 UTC (rev 8370)
@@ -10,7 +10,7 @@
- config.vm.box = "vagrant-trusty32"
+ config.vm.box = "vagrant-precise32"
exit $error
fi
+check_test()
+ error=$?
+ fi
cd ~
HAVE_FDO=0
HAVE_FDO_LIBS=0
HAVE_MAPGUIDE=0
-MG_UNIT_TEST=0
+MG_UNIT_TEST=1
+FDO_UNIT_TEST=1
FDO_SRC_ROOT=~/fdo
+FDO_VER_MM=3.9
+MG_VER_MM=3.0
+FDO_SRC_DIR=trunk
+HAVE_FDO_SDK=0
+FDO_SDK_TARBALL=
if [ -d $FDO_SRC ];
then
HAVE_FDO=1
then
HAVE_MAPGUIDE=1
fi
+then
+ then
+ HAVE_FDO_SDK=1
+ FDO_UNIT_TEST=0
+ fi
+else
+fi
then
fi
+then
+fi
cd $SCRIPT_ROOT
sed -i 's/FDO_CPU=x64/FDO_CPU=x86/g' build_fdo.sh
sed -i 's/FDO_BUILD_CPU=amd64/FDO_BUILD_CPU=i386/g' build_fdo.sh
sed -i 's/LIB_DIRNAME=lib64/LIB_DIRNAME=lib/g' build_fdo.sh
then
+ then
+ fi
+ then
+ fi
fi
-then
- mkdir -p ~/fdo
-fi
then
fi
-check_build
+then
+ check_build
+else
+fi
svn update $MG_SRC
check_build
then
+ then
+ fi
+else
fi
then
cd ~/scripts
-check_build
+then
+ check_build
+else
+ ./dpkgfdo.sh i386 $FDO_REV 2>&1 | tee ~/dpkg_fdo.log
+ popd
+fi
check_build
-sudo ./dpkgmapguide.sh i386 $MG_REV
+./dpkgmapguide.sh i386 $MG_REV 2>&1 | tee ~/dpkg_mapguide.log
check_build
+then
+ check_test
+ check_test
+ check_test
+ check_test
+ check_test
+ check_test
+fi
then
+ # VM
+ do
+ check_test
+ fi
+ done
fi
cd $SCRIPT_ROOT
+then
+else
+fi
+# cd $MG_SRC_ROOT
-# cd ~/fdo
+# cd $FDO_SRC_ROOT
#else
#fi
More information about the mapguide-commits
