[mapguide-commits] r8740 - in trunk/Tools/Maestro: Maestro.Editors/Generic/XmlEditor/AutoCompletion Maestro.Editors/LayerDefinition/Vector Maestro.MapViewer Maestro.Packaging OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Commands OSGeo.MapGuide.MaestroAPI/Mapping OSGeo.MapGuide.MaestroAPI.Local OSGeo.MapGuide.MaestroAPI.Tests OSGeo.MapGuide.MaestroAPI.Tests/CrossConnection OSGeo.MapGuide.ObjectModels OSGeo.MapGuide.ObjectModels/Common OSGeo.MapGuide.ObjectModels/RuntimeMap/v2_6_0 Properties Thirdparty/SharpDevelop
svn_mapguide at osgeo.org
Tue Aug 11 10:09:38 PDT 2015
Author: jng
Date: 2015-08-11 10:09:38 -0700 (Tue, 11 Aug 2015)
New Revision: 8740
trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditor/AutoCompletion/XmlSchemaCompletionDataCollection.cs
trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerStyleSectionCtrl.cs
trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs
trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs
trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs
trunk/Tools/Maestro/Maestro.Packaging/PackageProgress.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalRuntimeMap.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/CrossConnection/ResourceMigratorTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/MiscTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/CreateRuntimeMap.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Enums.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/Common/IEnvelope.cs
trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/ResourceContentVersionChecker.cs
trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/v2_6_0/RuntimeMapImpl.cs
trunk/Tools/Maestro/Properties/CodeAnalysisRules.cs
trunk/Tools/Maestro/Thirdparty/SharpDevelop/GlobalAssemblyInfo.cs
#2565: The RES-instigated cleanup continues. This one having emphasis on using epsilon-based comparison for floats and doubles when comparing equality and testing if a value is zero or not.
Modified: trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditor/AutoCompletion/XmlSchemaCompletionDataCollection.cs
--- trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditor/AutoCompletion/XmlSchemaCompletionDataCollection.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/Maestro.Editors/Generic/XmlEditor/AutoCompletion/XmlSchemaCompletionDataCollection.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -316,7 +316,10 @@
// remove previous segment
int j;
- for (j = result.Length - 1; j >= 0 && result[j] != outputSeparator; j--) ;
+ for (j = result.Length - 1; j >= 0 && result[j] != outputSeparator; j--)
if (j > 0)
result.Length = j;
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerStyleSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerStyleSectionCtrl.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/VectorLayerStyleSectionCtrl.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -206,9 +206,9 @@
double minY = vy.MinScale.HasValue ? vy.MinScale.Value : 0;
double maxY = vy.MaxScale.HasValue ? vy.MaxScale.Value : double.MaxValue;
- if (minX == minY)
+ if (Math.Abs(minX - minY) < double.Epsilon)
- if (maxX == maxY)
+ if (Math.Abs(maxX - maxY) < double.Epsilon)
return 0;
else
return maxX > maxY ? 1 : -1;
Modified: trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/Maestro.MapViewer/LegendPresenter.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -193,8 +193,8 @@
type = LAYER_RASTER;
- String[] typeStyles = new String[] { "PointTypeStyle", "LineTypeStyle", "AreaTypeStyle", "CompositeTypeStyle" };
- String[] ruleNames = new String[] { "PointRule", "LineRule", "AreaRule", "CompositeRule" };
+ string[] typeStyles = { "PointTypeStyle", "LineTypeStyle", "AreaTypeStyle", "CompositeTypeStyle" };
+ string[] ruleNames = { "PointRule", "LineRule", "AreaRule", "CompositeRule" };
node.ToolTipText = string.Format(Properties.Resources.DefaultLayerTooltip, Environment.NewLine, layer.Name, layer.FeatureSourceID, layer.QualifiedClassName);
//Do this if not cached already from a previous run
Modified: trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -468,7 +468,7 @@
ApplyPaintTranslateTransform(e);
- if (mouseWheelSx.HasValue && mouseWheelSy.HasValue && mouseWheelSx.Value != 0.0 && mouseWheelSy.Value != 0.0)
+ if (mouseWheelSx.HasValue && mouseWheelSy.HasValue && !mouseWheelSx.Value.IsZero() && !mouseWheelSy.Value.IsZero())
e.Graphics.ScaleTransform(mouseWheelSx.Value, mouseWheelSy.Value);
@@ -1166,7 +1166,7 @@
_extX2 = _orgX2 = env.MaxX;
_extY1 = _orgY1 = env.MaxY;
- if ((_orgX1 - _orgX2) == 0 || (_orgY1 - _orgY2) == 0)
+ if ((_orgX1 - _orgX2).IsZero() || (_orgY1 - _orgY2).IsZero())
_extX1 = _orgX1 = -.1;
_extY2 = _orgX2 = .1;
@@ -1807,7 +1807,7 @@
var oldScale = _map.ViewScale;
_map.ViewScale = newScale;
- if (oldScale != _map.ViewScale)
+ if (Math.Abs(oldScale - _map.ViewScale) > double.Epsilon)
var handler = this.MapScaleChanged;
if (handler != null)
@@ -1844,7 +1844,7 @@
index = i;
bestDiff = scaleDiff;
- if (bestDiff == 0)
+ if (bestDiff.IsZero())
//perfect match
break;
Modified: trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs
--- trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -132,7 +132,7 @@
public PackageBuilder(IServerConnection connection)
if (connection == null)
- throw new ArgumentNullException("connection"); //NOXLATE
+ throw new ArgumentNullException(nameof(connection)); //NOXLATE
m_connection = connection;
Modified: trunk/Tools/Maestro/Maestro.Packaging/PackageProgress.cs
--- trunk/Tools/Maestro/Maestro.Packaging/PackageProgress.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/Maestro.Packaging/PackageProgress.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -318,7 +318,7 @@
case ProgressType.Uploading:
HideTotal();
- if (pg == total)
+ if (Math.Abs(pg - total) < double.Epsilon)
OperationLabel.Text = Strings.ProgressWaitingForServer;
CurrentProgress.Style = ProgressBarStyle.Marquee;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/CreateRuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/CreateRuntimeMap.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/CreateRuntimeMap.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -21,6 +21,7 @@
#endregion Disclaimer / License
using OSGeo.MapGuide.ObjectModels.RuntimeMap;
+using System;
namespace OSGeo.MapGuide.MaestroAPI.Commands
@@ -78,6 +79,7 @@
/// A bitmask that defines what information to include in a CreateRuntimeMap or DescribeRuntimeMap
/// response.
/// </summary>
+ [Flags]
public enum RuntimeMapRequestedFeatures : int
/// <summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Enums.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Enums.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Enums.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -125,6 +125,7 @@
/// <summary>
/// Flags that can be used for the QueryMapFeatures operation
/// </summary>
+ [Flags]
public enum QueryMapFeaturesLayerAttributes : int
/// <summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -242,7 +242,7 @@
var orgX2 = ext.MaxX;
var orgY1 = ext.MaxY;
- if ((orgX1 - orgX2) == 0 || (orgY1 - orgY2) == 0)
+ if ((orgX1 - orgX2).IsZero() || (orgY1 - orgY2).IsZero())
orgX1 = -.1;
orgX2 = .1;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -53,6 +53,16 @@
/// </summary>
public static class Utility
+ public static bool IsZero(this float val)
+ return Math.Abs(val) < float.Epsilon;
+ public static bool IsZero(this double val)
+ return Math.Abs(val) < double.Epsilon;
/// <summary>
/// Creates the polygon WKT for the given bounding box
/// </summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalRuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalRuntimeMap.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalRuntimeMap.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -248,7 +248,7 @@
public override void SetViewCenter(double x, double y)
var center = this.ViewCenter;
- if (center.X != x || center.Y != y)
+ if (Math.Abs(center.X - x) > double.Epsilon || Math.Abs(center.Y - y) > double.Epsilon)
_impl.SetViewCenterXY(x, y);
OnPropertyChanged(nameof(ViewCenter));
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/CrossConnection/ResourceMigratorTests.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/CrossConnection/ResourceMigratorTests.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/CrossConnection/ResourceMigratorTests.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -64,8 +64,7 @@
var emptyDataList = new ResourceDataList() { ResourceData = new System.ComponentModel.BindingList<ResourceDataListResourceData>() };
- string [] resources = new string[]
+ string [] resources = {
"Library://Test/Data.FeatureSource",
"Library://Test/Data1.FeatureSource",
"Library://Test/Data2.FeatureSource",
@@ -133,8 +132,7 @@
- string[] resources = new string[]
+ string[] resources = {
@@ -211,8 +209,7 @@
@@ -286,8 +283,7 @@
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/MiscTests.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/MiscTests.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Tests/MiscTests.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -1,23 +1,23 @@
-#region Disclaimer / License
-// Copyright (C) 2014, Jackie Ng
-// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of the GNU Lesser General Public
-// License as published by the Free Software Foundation; either
-// version 2.1 of the License, or (at your option) any later version.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#region Disclaimer / License
+// Copyright (C) 2014, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
using NUnit.Framework;
using OSGeo.MapGuide.MaestroAPI.Internal;
@@ -75,7 +75,7 @@
[Test]
public void TestArgParser()
- string[] args = new string[] { "-foo", "-bar:snafu", "-whatever:" };
+ string[] args = { "-foo", "-bar:snafu", "-whatever:" };
var parser = new ArgumentParser(args);
Assert.IsFalse(parser.IsDefined("snafu"));
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/Common/IEnvelope.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/Common/IEnvelope.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/Common/IEnvelope.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -63,6 +63,16 @@
/// </summary>
public static class EnvelopeExtensions
+ static bool IsZero(this float val)
+ static bool IsZero(this double val)
/// <summary>
/// Gets whether the given instance is empty
/// </summary>
@@ -71,10 +81,10 @@
public static bool IsEmpty(this IEnvelope env)
return env == null ||
- (Math.Abs(env.MaxX) < double.Epsilon &&
- Math.Abs(env.MaxY) < double.Epsilon &&
- Math.Abs(env.MinX) < double.Epsilon &&
- Math.Abs(env.MinY) < double.Epsilon);
+ (env.MaxX.IsZero() &&
+ env.MaxY.IsZero() &&
+ env.MinX.IsZero() &&
+ env.MinY.IsZero());
/// <summary>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/ResourceContentVersionChecker.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/ResourceContentVersionChecker.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/ResourceContentVersionChecker.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -37,8 +37,8 @@
/// </summary>
public sealed class ResourceContentVersionChecker : IDisposable
- private XmlReader _reader;
- private Stream _stream;
+ private readonly XmlReader _reader;
+ private readonly Stream _stream;
/// <summary>
/// Constructor
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/v2_6_0/RuntimeMapImpl.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/v2_6_0/RuntimeMapImpl.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/RuntimeMap/v2_6_0/RuntimeMapImpl.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -136,22 +136,16 @@
: IReadOnlyCollection<TInterface>
where TImpl : TInterface
- private IList<TImpl> _list;
+ private readonly IList<TImpl> _list;
protected ReadOnlyCollectionWrapper(IList<TImpl> list)
_list = list;
- public int Count
- get { return _list.Count; }
+ public int Count => _list.Count;
- public TInterface this[int index]
- get { return _list[index]; }
+ public TInterface this[int index] => _list[index];
private class Enumerator : IEnumerator<TInterface>
@@ -164,19 +158,13 @@
_innerList = list;
- public TInterface Current
- get { return _innerList[_pos]; }
+ public TInterface Current => _innerList[_pos];
public void Dispose()
- object System.Collections.IEnumerator.Current
+ object System.Collections.IEnumerator.Current => _innerList[_pos];
public bool MoveNext()
@@ -184,34 +172,19 @@
return _pos <= _innerList.Count - 1;
- public void Reset()
- _pos = -1;
+ public void Reset() => _pos = -1;
- public IEnumerator<TInterface> GetEnumerator()
- return new Enumerator(_list);
+ public IEnumerator<TInterface> GetEnumerator() => new Enumerator(_list);
- System.Collections.IEnumerator System.Collections.IEnumerable.GetEnumerator()
- return _list.GetEnumerator();
+ System.Collections.IEnumerator System.Collections.IEnumerable.GetEnumerator() => _list.GetEnumerator();
partial class RuntimeMapLayer : IRuntimeLayerInfo
- int IRuntimeLayerInfo.LayerType
- get { return Convert.ToInt32(this.Type); }
+ int IRuntimeLayerInfo.LayerType => Convert.ToInt32(this.Type);
- IFeatureSourceInfo IRuntimeLayerInfo.FeatureSource
- get { return this.FeatureSource; }
+ IFeatureSourceInfo IRuntimeLayerInfo.FeatureSource => this.FeatureSource;
private ScaleRangeCollection _roScales;
@@ -229,41 +202,23 @@
- string IRuntimeMapLegendElement.ObjectID
- get { return this.ObjectId; }
+ string IRuntimeMapLegendElement.ObjectID => this.ObjectId;
- string IRuntimeMapLegendElement.ParentID
- get { return this.ParentId; }
+ string IRuntimeMapLegendElement.ParentID => this.ParentId;
partial class FeatureSourceInfo : IFeatureSourceInfo
- string IFeatureSourceInfo.ResourceID
- get { return this.ResourceId; }
+ string IFeatureSourceInfo.ResourceID => this.ResourceId;
partial class RuntimeMapGroup : IRuntimeLayerGroupInfo
- int IRuntimeLayerGroupInfo.GroupType
+ int IRuntimeLayerGroupInfo.GroupType => Convert.ToInt32(this.Type);
internal class ReadOnlyLayerCollection : ReadOnlyCollectionWrapper<IRuntimeLayerInfo, RuntimeMapLayer>,
@@ -332,10 +287,7 @@
partial class FeatureStyleInfo : IFeatureStyleInfo
- int IFeatureStyleInfo.Type
+ int IFeatureStyleInfo.Type => Convert.ToInt32(this.Type);
private RuleInfoCollection _roRules;
@@ -359,10 +311,7 @@
partial class RuleInfo : IRuleInfo
- string IRuleInfo.IconBase64
- get { return this.Icon; }
+ string IRuleInfo.IconBase64 => this.Icon;
partial class CoordinateSystemType : ICoordinateSystemInfo
Modified: trunk/Tools/Maestro/Properties/CodeAnalysisRules.cs
--- trunk/Tools/Maestro/Properties/CodeAnalysisRules.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/Properties/CodeAnalysisRules.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -37,6 +37,9 @@
[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Redundancies in Code", "RECS0071", Justification = "This is just plain pedantry")]
[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Redundancies in Code", "RECS0138", Justification = "The author prefers to be explicit")]
[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Redundancies in Symbol Declarations", "RECS0004", Justification = "If one is specified, it's to satisfy an XML serialization contract")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Potential Code Quality Issues", "RECS0022", Justification = "If I'm swallowing up an exception, it is intentional")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Language Usage Opportunities", "RECS0011", Justification = "It's if/else because it's more readable that a single long ternary expression")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Common Practices and Code Improvements", "RECS0030", Justification = "<Pending>")]
//TODO: Review these ones as we get further clarity about what string comparisons should be culture-sensitive and which ones shouldn't be
[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Common Practices and Code Improvements", "RECS0060", Justification = "To be reviewed at a later time")]
Modified: trunk/Tools/Maestro/Thirdparty/SharpDevelop/GlobalAssemblyInfo.cs
--- trunk/Tools/Maestro/Thirdparty/SharpDevelop/GlobalAssemblyInfo.cs 2015-08-11 16:22:58 UTC (rev 8739)
+++ trunk/Tools/Maestro/Thirdparty/SharpDevelop/GlobalAssemblyInfo.cs 2015-08-11 17:09:38 UTC (rev 8740)
@@ -36,6 +36,22 @@
[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Virtual member call in constructor", "RECS0021")]
[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Use 'var' keyword", "RECS0091")]
[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Nullable type can be simplified", "RECS0013")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Replace with '|='", "RECS0033", Justification = "The author prefers clarity of code")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Replace with '&='", "RECS0093", Justification = "The author prefers clarity of code")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Not implemented", "RECS0083", Justification = "A NotImplementedException is thrown for a reason")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Potential Code Quality Issues", "RECS0029", Justification = "Needed to satisfy an XML serialization contract")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Redundancies in Symbol Declarations", "RECS0001", Justification = "Other parts may exist in the future")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Redundancies in Code", "RECS0071", Justification = "This is just plain pedantry")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Redundancies in Code", "RECS0138", Justification = "The author prefers to be explicit")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Redundancies in Symbol Declarations", "RECS0004", Justification = "If one is specified, it's to satisfy an XML serialization contract")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Common Practices and Code Improvements", "RECS0060", Justification = "To be reviewed at a later time")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Common Practices and Code Improvements", "RECS0061", Justification = "To be reviewed at a later time")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Common Practices and Code Improvements", "RECS0062", Justification = "To be reviewed at a later time")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Common Practices and Code Improvements", "RECS0063", Justification = "To be reviewed at a later time")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Language", "CSE0001", Justification = "<Pending>")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Potential Code Quality Issues", "RECS0163", Justification = "<Pending>")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Common Practices and Code Improvements", "RECS0092", Justification = "<Pending>")]
+[assembly: System.Diagnostics.CodeAnalysis.SuppressMessage("Language Usage Opportunities", "RECS0011", Justification = "<Pending>")]
internal static class RevisionClass
More information about the mapguide-commits
