[mapguide-commits] r8743 - in trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition: v1_0_0 v1_1_0
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Aug 13 05:42:13 PDT 2015
Author: jng
Date: 2015-08-13 05:42:13 -0700 (Thu, 13 Aug 2015)
New Revision: 8743
   trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_0_0/GridLayerDefinitionImpl.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_0_0/VectorLayerDefinitionImpl.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_1_0/GridLayerDefinitionImpl.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_1_0/VectorLayerDefinitionImpl.cs
Remove various ifdefs in some of our Layer Definition partials. This was used so that multiple ObjectModel projects could link to the same file and define the appropriate token to define the appropriate partials. But since all the ObjectModel projects have been unified, these ifdef'd sections are no longer used.
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_0_0/GridLayerDefinitionImpl.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_0_0/GridLayerDefinitionImpl.cs	2015-08-13 09:31:47 UTC (rev 8742)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_0_0/GridLayerDefinitionImpl.cs	2015-08-13 12:42:13 UTC (rev 8743)
@@ -27,27 +27,13 @@
 using System.Linq;
 using System.Text;
 using System.Xml;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using System.Xml.Serialization;
 #pragma warning disable 1591, 0114, 0108
-#if LDF_110
-namespace OSGeo.MapGuide.ObjectModels.LayerDefinition.v1_1_0
-#elif LDF_120
-namespace OSGeo.MapGuide.ObjectModels.LayerDefinition.v1_2_0
-#elif LDF_130
-namespace OSGeo.MapGuide.ObjectModels.LayerDefinition.v1_3_0
-#elif LDF_230
-namespace OSGeo.MapGuide.ObjectModels.LayerDefinition.v2_3_0
-#elif LDF_240
-namespace OSGeo.MapGuide.ObjectModels.LayerDefinition.v2_4_0
-#else
 namespace OSGeo.MapGuide.ObjectModels.LayerDefinition.v1_0_0
-#endif
-    using OSGeo.MapGuide.ObjectModels.LayerDefinition;
-    using System.Xml.Serialization;
     partial class GridLayerDefinitionType : IRasterLayerDefinition
         [XmlIgnore]
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_0_0/VectorLayerDefinitionImpl.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_0_0/VectorLayerDefinitionImpl.cs	2015-08-13 09:31:47 UTC (rev 8742)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_0_0/VectorLayerDefinitionImpl.cs	2015-08-13 12:42:13 UTC (rev 8743)
@@ -27,68 +27,18 @@
 using System.Linq;
 using System.Text;
 using System.Xml;
+using OSGeo.MapGuide.ObjectModels.SymbolDefinition;
-#if LDF_110
-#elif LDF_120
-#elif LDF_130
-#elif LDF_230
-#elif LDF_240
-#else
-#endif
-    using OSGeo.MapGuide.ObjectModels.SymbolDefinition;
     abstract partial class BaseLayerDefinitionType : ISubLayerDefinition
-#if LDF_230 || LDF_240
-, ISubLayerDefinition2
-#endif
         [XmlIgnore]
         public abstract LayerType LayerType { get; }
-        [XmlIgnore]
-        IEnumerable<IWatermark> IWatermarkCollection.Watermarks
-            get
-                foreach (var wm in this.Watermarks)
-                    yield return wm;
-        IWatermark IWatermarkCollection.AddWatermark(IWatermarkDefinition watermark)
-            return WatermarkCollectionUtil.AddWatermark(this.Watermarks, watermark);
-        void IWatermarkCollection.RemoveWatermark(IWatermark watermark)
-            WatermarkCollectionUtil.RemoveWatermark(this.Watermarks, watermark);
-        [XmlIgnore]
-        int IWatermarkCollection.WatermarkCount
-            get { return this.Watermarks.Count; }
-#endif
     partial class NameStringPairType : INameStringPair
@@ -121,9 +71,6 @@
     partial class VectorScaleRangeType : IVectorScaleRange
-#if !LDF_100
-, IVectorScaleRange2
-#endif
         #region Missing generated stuff
@@ -288,145 +235,9 @@
             return VectorScaleRangeType.Deserialize(this.Serialize());
-#if LDF_110 || LDF_120
-        [XmlIgnore]
-        public IEnumerable<ICompositeTypeStyle> CompositeStyle
-            get
-                foreach (var item in this.itemsField)
-                    if (typeof(ICompositeTypeStyle).IsAssignableFrom(item.GetType()))
-                        yield return (ICompositeTypeStyle)item;
-            set
-                //Clear old ones
-                var remove = new List<object>();
-                        remove.Add(item);
-                foreach (var obj in remove)
-                    this.itemsField.Remove(obj);
-                //Put the new ones in if it is not null
-                if (value != null)
-                    foreach (var item in value)
-                        if (!typeof(ICompositeTypeStyle).IsAssignableFrom(item.GetType()))
-                            throw new InvalidOperationException(Strings.ErrorObjectNotICompositeTypeStyle);
-                        this.itemsField.Add(item);
-#elif LDF_130 || LDF_230 || LDF_240
-        [XmlIgnore]
-            get
-                    if (typeof(ICompositeTypeStyle2).IsAssignableFrom(item.GetType()))
-                        yield return (ICompositeTypeStyle2)item;
-            set
-                //Clear old ones
-                        remove.Add(item);
-                        if (!typeof(ICompositeTypeStyle2).IsAssignableFrom(item.GetType()))
-#endif
-#if LDF_100
-#else
-        IElevationSettings IVectorScaleRange2.ElevationSettings
-            get { return this.ElevationSettings; }
-            set { this.ElevationSettings = (ElevationSettingsType)value; }
-        IElevationSettings IVectorScaleRange2.Create(string zOffset, string zExtrusion, ElevationTypeType zOffsetType, LengthUnitType unit)
-            return new ElevationSettingsType()
-                ZOffset = zOffset,
-                ZOffsetType = zOffsetType,
-                ZExtrusion = zExtrusion,
-                Unit = unit
-        [XmlIgnore]
-        int IVectorScaleRange2.CompositeStyleCount
-            get
-                int count = 0;
-                        count++;
-                return count;
-#endif
-#if LDF_100
-#else
-    partial class ElevationSettingsType : IElevationSettings { }
-#endif
-#if LDF_100
     partial class StrokeType : IStroke
-#else
-    partial class StrokeType : IStroke, IStroke2
-#endif
         internal StrokeType()
@@ -436,16 +247,6 @@
             return StrokeType.Deserialize(this.Serialize());
-#if LDF_100
-#else
-        IStroke2 ICloneableLayerElement<IStroke2>.Clone()
-            return StrokeType.Deserialize(this.Serialize());
-#endif
     partial class FillType : IFill
@@ -461,9 +262,6 @@
     partial class AreaTypeStyleType : IAreaVectorStyle
-#if LDF_130 || LDF_230 || LDF_240
-, IAreaVectorStyle2
-#endif
         [XmlIgnore]
         IEnumerable<IAreaRule> IAreaVectorStyle.Rules
@@ -653,9 +451,6 @@
     partial class PointTypeStyleType : IPointVectorStyle
-, IPointVectorStyle2
-#endif
         [XmlIgnore]
         public IEnumerable<IPointRule> Rules
@@ -811,9 +606,6 @@
     partial class LineTypeStyleType : ILineVectorStyle
-, ILineVectorStyle2
-#endif
         [XmlIgnore]
         public IEnumerable<ILineRule> Rules
@@ -1669,20 +1461,7 @@
     partial class LayerDefinition : ILayerDefinition
         //internal LayerDefinition() { }
-#if LDF_110
-        private static readonly Version RES_VERSION = new Version(1, 1, 0);
-#elif LDF_120
-        private static readonly Version RES_VERSION = new Version(1, 2, 0);
-#elif LDF_130
-        private static readonly Version RES_VERSION = new Version(1, 3, 0);
-#elif LDF_230
-        private static readonly Version RES_VERSION = new Version(2, 3, 0);
-#elif LDF_240
-        private static readonly Version RES_VERSION = new Version(2, 4, 0);
-#else
         private static readonly Version RES_VERSION = new Version(1, 0, 0);
-#endif
         private string _resId;
@@ -1733,19 +1512,7 @@
         [XmlAttribute("noNamespaceSchemaLocation", Namespace = "http://www.w3.org/2001/XMLSchema-instance")] //NOXLATE
         public string ValidatingSchema
-#if LDF_110
-            get { return "LayerDefinition-1.1.0.xsd"; } //NOXLATE
-#elif LDF_120
-            get { return "LayerDefinition-1.2.0.xsd"; } //NOXLATE
-#elif LDF_130
-            get { return "LayerDefinition-1.3.0.xsd"; } //NOXLATE
-#elif LDF_230
-            get { return "LayerDefinition-2.3.0.xsd"; } //NOXLATE
-#elif LDF_240
-            get { return "LayerDefinition-2.4.0.xsd"; } //NOXLATE
-#else
             get { return ResourceTypes.LayerDefinition.ToString() + "-" + this.ResourceVersion.ToString() + ".xsd"; } //NOXLATE
-#endif
             set { }
@@ -1784,9 +1551,6 @@
     partial class VectorLayerDefinitionType : IVectorLayerDefinition
-#if LDF_240
-, IVectorLayerDefinition2
-#endif
         [XmlIgnore]
         public override LayerType LayerType
@@ -1818,35 +1582,8 @@
         [XmlIgnore]
         string IVectorLayerDefinition.Url
-#if LDF_240
-            get
-                if (this.urlDataField == null)
-                    return string.Empty;
-                else
-                    return this.urlDataField.Content;
-            set
-                if (!string.IsNullOrEmpty(value))
-                        this.urlDataField = new URLDataType();
-                    this.urlDataField.Content = value;
-                    OnPropertyChanged(nameof(Url));
-                else
-                    //NOTE: None of the other URLData properties seem to be used atm
-                    //hence why we are nulling this
-                    this.urlDataField = null;
-#else
             get { return this.Url; }
             set { this.Url = value; }
-#endif
         [XmlIgnore]
@@ -2006,463 +1743,13 @@
             get
-#if LDF_110
-                return new Version(1, 0, 0);
-#elif LDF_120 || LDF_130 || LDF_230
-                return new Version(1, 1, 0);
-#elif LDF_240
-                return new Version(2, 4, 0);
-#else
                 return null;
-#endif
-#if LDF_240
-        [XmlIgnore]
-        IUrlData IVectorLayerDefinition2.UrlData
-            get
-                return this.UrlData;
-            set
-                this.UrlData = (URLDataType)value;
-#endif
         void IVectorLayerDefinition.ClearPropertyMappings()
             propertyMappingField.Clear();
-    #region Composite Symbolization
-#if !LDF_100
-    partial class CompositeRule : ICompositeRule
-        [XmlIgnore]
-        ICompositeSymbolization ICompositeRule.CompositeSymbolization
-            get
-                return this.CompositeSymbolization;
-            set
-                this.CompositeSymbolization = (CompositeSymbolization)value;
-    partial class CompositeSymbolization : ICompositeSymbolization
-        [XmlIgnore]
-        IEnumerable<ISymbolInstance> ICompositeSymbolization.SymbolInstance
-            get
-                foreach (var sym in this.SymbolInstance)
-                    yield return sym;
-        public string ToXml()
-            return this.Serialize();
-        public void UpdateFromXml(string xml)
-            var compsym = CompositeSymbolization.Deserialize(xml);
-            this.SymbolInstance.Clear();
-            foreach (var sym in compsym.SymbolInstance)
-                this.AddSymbolInstance(sym);
-        public void AddSymbolInstance(ISymbolInstance inst)
-            var sym = inst as SymbolInstance;
-            if (sym != null)
-                this.SymbolInstance.Add(sym);
-        public void RemoveSymbolInstance(ISymbolInstance inst)
-            if (sym != null)
-                this.SymbolInstance.Remove(sym);
-        public void RemoveAllSymbolInstances()
-        public ISymbolInstance CreateSymbolReference(string resourceId)
-            return new SymbolInstance()
-                Item = resourceId,
-                ParameterOverrides = new ParameterOverrides()
-                    Override = new BindingList<Override>()
-        public ISymbolInstance CreateInlineSimpleSymbol(ISimpleSymbolDefinition symDef)
-#if LDF_110
-                Item = (OSGeo.MapGuide.ObjectModels.SymbolDefinition.v1_0_0.SimpleSymbolDefinition)symDef,
-                Item = (OSGeo.MapGuide.ObjectModels.SymbolDefinition.v1_1_0.SimpleSymbolDefinition)symDef,
-#else
-                Item = (OSGeo.MapGuide.ObjectModels.SymbolDefinition.v2_4_0.SimpleSymbolDefinition)symDef,
-#endif
-        public ISymbolInstance CreateInlineCompoundSymbol(ICompoundSymbolDefinition compDef)
-#if LDF_110
-                Item = (OSGeo.MapGuide.ObjectModels.SymbolDefinition.v1_0_0.CompoundSymbolDefinition)compDef,
-                Item = (OSGeo.MapGuide.ObjectModels.SymbolDefinition.v1_1_0.CompoundSymbolDefinition)compDef,
-#else
-                Item = (OSGeo.MapGuide.ObjectModels.SymbolDefinition.v2_4_0.CompoundSymbolDefinition)compDef,
-#endif
-    partial class SymbolInstance : ISymbolInstance
-#if LDF_100 || LDF_110
-#else
-, ISymbolInstance2
-#endif
-        [XmlIgnore]
-        IParameterOverrideCollection ISymbolInstance.ParameterOverrides
-            get { return this.ParameterOverrides; }
-        [XmlIgnore]
-        public ISymbolInstanceReference Reference
-            get
-                var libId = this.Item as string;
-#if LDF_110
-                var simpSym = this.Item as OSGeo.MapGuide.ObjectModels.SymbolDefinition.v1_0_0.SimpleSymbolDefinition;
-                var compSym = this.Item as OSGeo.MapGuide.ObjectModels.SymbolDefinition.v1_0_0.CompoundSymbolDefinition;
-                var simpSym = this.Item as OSGeo.MapGuide.ObjectModels.SymbolDefinition.v1_1_0.SimpleSymbolDefinition;
-                var compSym = this.Item as OSGeo.MapGuide.ObjectModels.SymbolDefinition.v1_1_0.CompoundSymbolDefinition;
-#else
-                var simpSym = this.Item as OSGeo.MapGuide.ObjectModels.SymbolDefinition.v2_4_0.SimpleSymbolDefinition;
-                var compSym = this.Item as OSGeo.MapGuide.ObjectModels.SymbolDefinition.v2_4_0.CompoundSymbolDefinition;
-#endif
-                if (libId != null)
-                    return new SymbolInstanceLibrary() { ResourceId = libId };
-                else if (simpSym != null)
-                    return new SymbolInstanceInline() { SymbolDefinition = simpSym };
-                else if (compSym != null)
-                    return new SymbolInstanceInline() { SymbolDefinition = compSym };
-                return null;
-            set
-                var sr = value as ISymbolInstanceReferenceLibrary;
-                var ir = value as ISymbolInstanceReferenceInline;
-                if (sr != null)
-                    this.Item = sr.ResourceId;
-                else if (ir != null)
-#if LDF_110
-                    if (ir.SymbolDefinition.Type == SymbolDefinitionType.Simple)
-                        this.Item = (OSGeo.MapGuide.ObjectModels.SymbolDefinition.v1_0_0.SimpleSymbolDefinition)ir.SymbolDefinition;
-                    else if (ir.SymbolDefinition.Type == SymbolDefinitionType.Compound)
-                        this.Item = (OSGeo.MapGuide.ObjectModels.SymbolDefinition.v1_0_0.CompoundSymbolDefinition)ir.SymbolDefinition;
-                        this.Item = (OSGeo.MapGuide.ObjectModels.SymbolDefinition.v1_1_0.SimpleSymbolDefinition)ir.SymbolDefinition;
-                        this.Item = (OSGeo.MapGuide.ObjectModels.SymbolDefinition.v1_1_0.CompoundSymbolDefinition)ir.SymbolDefinition;
-#else
-                        this.Item = (OSGeo.MapGuide.ObjectModels.SymbolDefinition.v2_4_0.SimpleSymbolDefinition)ir.SymbolDefinition;
-                        this.Item = (OSGeo.MapGuide.ObjectModels.SymbolDefinition.v2_4_0.CompoundSymbolDefinition)ir.SymbolDefinition;
-#endif
-                this.Item = null;
-    partial class SymbolInstanceLibrary : ISymbolInstanceReferenceLibrary
-        [EditorBrowsable(EditorBrowsableState.Never)]
-        private string _resId;
-        [XmlIgnore]
-        public string ResourceId
-            get { return _resId; }
-            set
-                if (_resId == value) return;
-                _resId = value;
-                OnPropertyChanged(nameof(ResourceId));
-        [XmlIgnore]
-        public SymbolInstanceType Type
-            get { return SymbolInstanceType.Reference; }
-        public event PropertyChangedEventHandler PropertyChanged;
-        private void OnPropertyChanged(string name)
-            var handler = this.PropertyChanged;
-            if (handler != null)
-                handler(this, new PropertyChangedEventArgs(name));
-    partial class SymbolInstanceInline : ISymbolInstanceReferenceInline
-        [XmlIgnore]
-        public ISymbolDefinitionBase SymbolDefinition
-            get;
-            set;
-        [XmlIgnore]
-            get { return SymbolInstanceType.Inline; }
-    partial class ParameterOverrides : IParameterOverrideCollection
-        [XmlIgnore]
-        IEnumerable<IParameterOverride> IParameterOverrideCollection.Override
-            get
-                foreach (var ov in this.Override)
-                    yield return ov;
-        [XmlIgnore]
-        public int Count
-            get { return this.Override.Count; }
-        [XmlIgnore]
-        public IParameterOverride this[int index]
-            get
-                if (index >= this.Override.Count)
-                    throw new ArgumentOutOfRangeException();
-                return this.Override[index];
-        public void AddOverride(IParameterOverride ov)
-            var o = ov as Override;
-            if (o != null)
-                this.Override.Add(o);
-        public void RemoveOverride(IParameterOverride ov)
-            if (o != null)
-                this.Override.Remove(o);
-        public IParameterOverride CreateParameterOverride(string symbol, string name)
-            return new Override()
-                ParameterIdentifier = name,
-                SymbolName = symbol
-    partial class Override : IParameterOverride
-    partial class CompositeTypeStyle : ICompositeTypeStyle
-, ICompositeTypeStyle2
-#endif
-        [XmlIgnore]
-        string ICompositeTypeStyle.DisplayString
-            get
-                return Strings.CompositeStyleDisplayString;
-        [XmlIgnore]
-        IEnumerable<ICompositeRule> ICompositeTypeStyle.CompositeRule
-            get
-                foreach (var cr in this.CompositeRule)
-                    yield return cr;
-        public void AddCompositeRule(ICompositeRule compRule)
-            var cr = compRule as CompositeRule;
-            if (cr != null)
-                this.CompositeRule.Add(cr);
-        public void RemoveCompositeRule(ICompositeRule compRule)
-            if (cr != null)
-                this.CompositeRule.Remove(cr);
-        [XmlIgnore]
-        public StyleType StyleType
-            get { return StyleType.Composite; }
-        [XmlIgnore]
-        public int RuleCount
-            get { return this.CompositeRule.Count; }
-    #region IRuleCollection<ICompositeRule> Members
-        public int IndexOfRule(ICompositeRule rule)
-            var cr = rule as CompositeRule;
-            if (cr != null)
-                return this.CompositeRule.IndexOf(cr);
-            return -1;
-        public ICompositeRule GetRuleAt(int index)
-            return this.CompositeRule[index];
-        public bool MoveUp(ICompositeRule rule)
-            if (cr != null)
-                return CollectionUtil.MoveUp(this.CompositeRule, cr);
-            return false;
-        public bool MoveDown(ICompositeRule rule)
-            if (cr != null)
-                return CollectionUtil.MoveDown(this.CompositeRule, cr);
-            return false;
-    #endregion IRuleCollection<ICompositeRule> Members
-    #region IRuleCollection Members
-        public int IndexOfRule(IVectorRule rule)
-            if (cr != null)
-            return -1;
-        IVectorRule IRuleCollection.GetRuleAt(int index)
-        public bool MoveUp(IVectorRule rule)
-            if (cr != null)
-            return false;
-        public bool MoveDown(IVectorRule rule)
-            if (cr != null)
-            return false;
-    #endregion IRuleCollection Members
-#endif
-    #endregion Composite Symbolization
-#if LDF_240
-    partial class URLDataType : IUrlData
-#endif
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_1_0/GridLayerDefinitionImpl.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_1_0/GridLayerDefinitionImpl.cs	2015-08-13 09:31:47 UTC (rev 8742)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_1_0/GridLayerDefinitionImpl.cs	2015-08-13 12:42:13 UTC (rev 8743)
@@ -27,28 +27,13 @@
 using System.Linq;
 using System.Text;
 using System.Xml;
-#if LDF_110
-#elif LDF_120
-#elif LDF_130
-#elif LDF_230
-#elif LDF_240
-#else
-namespace OSGeo.MapGuide.ObjectModels.LayerDefinition.v1_0_0
-#endif
         [XmlIgnore]
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_1_0/VectorLayerDefinitionImpl.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_1_0/VectorLayerDefinitionImpl.cs	2015-08-13 09:31:47 UTC (rev 8742)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.ObjectModels/LayerDefinition/v1_1_0/VectorLayerDefinitionImpl.cs	2015-08-13 12:42:13 UTC (rev 8743)
@@ -27,68 +27,18 @@
 using System.Linq;
 using System.Text;
 using System.Xml;
-#if LDF_110
-#elif LDF_120
-#elif LDF_130
-#elif LDF_230
-#elif LDF_240
-#else
-#endif
-#endif
         [XmlIgnore]
-        [XmlIgnore]
-            get
-                    yield return wm;
-        [XmlIgnore]
-#endif
@@ -120,10 +70,7 @@
-    partial class VectorScaleRangeType : IVectorScaleRange
-#if !LDF_100
-#endif
+    partial class VectorScaleRangeType : IVectorScaleRange, IVectorScaleRange2
@@ -288,9 +235,7 @@
         [XmlIgnore]
@@ -331,53 +276,6 @@
-        [XmlIgnore]
-            get
-            set
-                //Clear old ones
-                        remove.Add(item);
-#endif
-#if LDF_100
-#else
@@ -409,24 +307,11 @@
                 return count;
-#endif
-#if LDF_100
-#else
-#endif
-#if LDF_100
-#else
-#endif
@@ -437,15 +322,10 @@
-#if LDF_100
-#else
-#endif
@@ -461,9 +341,6 @@
-#endif
         [XmlIgnore]
@@ -653,9 +530,6 @@
-#endif
         [XmlIgnore]
@@ -811,9 +685,6 @@
-#endif
         [XmlIgnore]
@@ -1668,21 +1539,8 @@
-        //internal LayerDefinition() { }
-#if LDF_110
+        //internal LayerDefinition() { }
-#elif LDF_120
-#elif LDF_130
-#elif LDF_230
-#elif LDF_240
-#else
-        private static readonly Version RES_VERSION = new Version(1, 0, 0);
-#endif
@@ -1733,19 +1591,7 @@
-#if LDF_110
-#elif LDF_120
-#elif LDF_130
-#elif LDF_230
-#elif LDF_240
-#else
-#endif
             set { }
@@ -1784,9 +1630,6 @@
-#if LDF_240
-#endif
         [XmlIgnore]
@@ -1818,35 +1661,8 @@
         [XmlIgnore]
-#if LDF_240
-            get
-                else
-            set
-                else
-#else
-#endif
         [XmlIgnore]
@@ -2006,35 +1822,10 @@
             get
-#if LDF_110
-#elif LDF_240
-#else
-                return null;
-#endif
-#if LDF_240
-        [XmlIgnore]
-            get
-            set
-#endif
@@ -2042,9 +1833,7 @@
-#if !LDF_100
         [XmlIgnore]
@@ -2165,13 +1954,7 @@
-#if LDF_110
-#else
-#endif
@@ -2183,13 +1966,7 @@
-#if LDF_110
-#else
-#endif
@@ -2199,10 +1976,6 @@
-#else
-, ISymbolInstance2
-#endif
         [XmlIgnore]
@@ -2216,16 +1989,8 @@
             get
-#if LDF_110
-#else
-#endif
                 if (libId != null)
@@ -2244,22 +2009,14 @@
-#if LDF_110
-#else
-#endif
                 this.Item = null;
@@ -2376,9 +2133,6 @@
-#endif
         [XmlIgnore]
@@ -2427,7 +2181,7 @@
+        #region IRuleCollection<ICompositeRule> Members
@@ -2458,9 +2212,9 @@
             return false;
+        #endregion IRuleCollection<ICompositeRule> Members
+        #region IRuleCollection Members
@@ -2491,18 +2245,8 @@
             return false;
+        #endregion IRuleCollection Members
-#endif
-#if LDF_240
-#endif
+    #endregion
More information about the mapguide-commits mailing list
