[mapguide-commits] r8749 - in trunk/Tools/Maestro: Maestro.AddIn.Scripting/Lang/Python Maestro.Packaging OSGeo.MapGuide.MaestroAPI/Feature
svn_mapguide at osgeo.org
Tue Aug 18 06:46:44 PDT 2015
Author: jng
Date: 2015-08-18 06:46:44 -0700 (Tue, 18 Aug 2015)
New Revision: 8749
trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsole.cs
trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsoleCompletionDataProvider.cs
trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs
trunk/Tools/Maestro/Maestro.Packaging/PackageProgress.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Feature/FeatureReaderBase.cs
#2565: Code cleanup
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsole.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsole.cs 2015-08-18 12:04:55 UTC (rev 8748)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsole.cs 2015-08-18 13:46:44 UTC (rev 8749)
@@ -401,8 +401,10 @@
private void ShowCompletionWindow()
- PythonConsoleCompletionDataProvider completionProvider = new PythonConsoleCompletionDataProvider(this);
- textEditor.ShowCompletionWindow(completionProvider);
+ using (var completionProvider = new PythonConsoleCompletionDataProvider(this))
+ textEditor.ShowCompletionWindow(completionProvider);
/// <summary>
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsoleCompletionDataProvider.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsoleCompletionDataProvider.cs 2015-08-18 12:04:55 UTC (rev 8748)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsoleCompletionDataProvider.cs 2015-08-18 13:46:44 UTC (rev 8749)
@@ -44,7 +44,7 @@
/// <summary>
/// Provides code completion for the Python Console window.
/// </summary>
- internal class PythonConsoleCompletionDataProvider : ICompletionDataProvider
+ internal class PythonConsoleCompletionDataProvider : ICompletionDataProvider, IDisposable
private IMemberProvider memberProvider;
@@ -110,7 +110,7 @@
return textArea.Document.GetText(lineSegment);
- public System.Windows.Forms.ImageList ImageList { get; }
+ public System.Windows.Forms.ImageList ImageList { get; private set; }
public string PreSelection { get; }
@@ -153,5 +153,11 @@
return data.InsertAction(textArea, key);
+ public void Dispose()
+ this.ImageList?.Dispose();
+ this.ImageList = null;
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs
--- trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs 2015-08-18 12:04:55 UTC (rev 8748)
+++ trunk/Tools/Maestro/Maestro.Packaging/PackageBuilder.cs 2015-08-18 13:46:44 UTC (rev 8749)
@@ -109,12 +109,32 @@
/// <summary>
/// A delegate for reporting package creation progress
/// </summary>
- /// <param name="type">The progress type that is currently running</param>
- /// <param name="maxValue">The max value, meaning that when value equals maxValue, progress is equal to 100%</param>
- /// <param name="value">The current item being progressed</param>
- /// <param name="resourceId">The name of the resource being processed, if any</param>
- public delegate void ProgressDelegate(ProgressType type, string resourceId, int maxValue, double value);
+ /// <param name="args">Package progress</param>
+ public delegate void ProgressDelegate(ProgressEventArgs args);
+ public class ProgressEventArgs : EventArgs
+ /// <summary>
+ /// The progress type that is currently running
+ /// </summary>
+ public ProgressType Type { get; set; }
+ /// <summary>
+ /// The max value, meaning that when value equals maxValue, progress is equal to 100%
+ /// </summary>
+ public string ResourceId { get; set; }
+ /// <summary>
+ /// The current item being progressed
+ /// </summary>
+ public int MaxValue { get; set; }
+ /// <summary>
+ /// The name of the resource being processed, if any
+ /// </summary>
+ public double Value { get; set; }
/// <summary>
/// A class to create MapGuide data packages
/// </summary>
@@ -146,20 +166,21 @@
/// </summary>
private long m_lastPg = -1;
+ private void SignalProgress(ProgressType type, string file, int maxValue, double value)
+ => this.Progress?.Invoke(new ProgressEventArgs() { Type = type, ResourceId = file, MaxValue = maxValue, Value = value });
/// <summary>
/// Uploads a package to the server
/// </summary>
/// <param name="sourceFile"></param>
public void UploadPackage(string sourceFile)
- if (Progress != null)
- Progress(ProgressType.Uploading, sourceFile, 100, 0);
+ SignalProgress(ProgressType.Uploading, sourceFile, 100, 0);
m_lastPg = -1;
m_connection.ResourceService.UploadPackage(sourceFile, new Utility.StreamCopyProgressDelegate(ProgressCallback_Upload));
- Progress(ProgressType.Uploading, sourceFile, 100, 100);
+ SignalProgress(ProgressType.Uploading, sourceFile, 100, 100);
/// <summary>
@@ -180,11 +201,9 @@
ProgressDelegate progress = this.Progress;
- if (progress == null)
- progress = (type, file, a, b) => { };
double step = 0.0;
- progress(ProgressType.ListingFiles, sourceFile, 100, step);
+ SignalProgress(ProgressType.ListingFiles, sourceFile, 100, step);
//Process overview:
@@ -241,7 +260,7 @@
using (var s = package.GetInputStream(contentEntry))
m_connection.ResourceService.SetResourceXmlData(op.ResourceId, s);
- progress(ProgressType.SetResource, op.ResourceId, 100, step);
+ SignalProgress(ProgressType.SetResource, op.ResourceId, 100, step);
if (headerEntry != null)
@@ -252,7 +271,7 @@
ResourceDocumentHeaderType header = ResourceDocumentHeaderType.Deserialize(sr.ReadToEnd());
m_connection.ResourceService.SetResourceHeader(op.ResourceId, header);
@@ -280,7 +299,7 @@
using (var s = package.GetInputStream(dataEntry))
m_connection.ResourceService.SetResourceData(sop.ResourceId, sop.DataName, sop.DataType, s);
- progress(ProgressType.SetResourceData, sop.ResourceId, 100, step);
+ SignalProgress(ProgressType.SetResourceData, sop.ResourceId, 100, step);
result.Successful.Add(op);
@@ -346,7 +365,7 @@
if (m_lastPg < 0 || remain == 0 || copied - m_lastPg > 1024 * 50)
- Progress(ProgressType.Uploading, string.Empty, (int)(total / 1024), (int)(copied / 1024));
+ SignalProgress(ProgressType.Uploading, string.Empty, (int)(total / 1024), (int)(copied / 1024));
m_lastPg = copied;
@@ -362,8 +381,7 @@
/// <param name="alternateTargetResourceId">An optional target folder resourceId, use null or an empty string to restore the files at the original locations</param>
public void CreatePackage(string folderResourceId, string zipfilename, IEnumerable<ResourceTypes> allowedExtensions, bool removeExistingFiles, string alternateTargetResourceId)
- Progress(ProgressType.ReadingFileList, folderResourceId, 100, 0);
+ SignalProgress(ProgressType.ReadingFileList, folderResourceId, 100, 0);
ResourceList items = m_connection.ResourceService.GetRepositoryResources(folderResourceId);
@@ -380,8 +398,7 @@
public void CreatePackage(IEnumerable<string> resourceIdsToPack, string zipfilename, IEnumerable<ResourceTypes> allowedExtensions, bool removeExistingFiles, string alternateTargetResourceId)
- Progress(ProgressType.ReadingFileList, string.Empty, 100, 0);
+ SignalProgress(ProgressType.ReadingFileList, string.Empty, 100, 0);
var resourceIds = new List<string>(resourceIdsToPack);
string folderId = GetCommonParent(resourceIds);
@@ -468,35 +485,29 @@
- Progress(ProgressType.ReadingFileList, folderResourceId, 100, 100);
- Progress(ProgressType.PreparingFolder, string.Empty, files.Count + folders.Count + 1, 0);
+ SignalProgress(ProgressType.ReadingFileList, folderResourceId, 100, 100);
+ SignalProgress(ProgressType.PreparingFolder, string.Empty, files.Count + folders.Count + 1, 0);
- string temppath = System.IO.Path.Combine(System.IO.Path.GetTempPath(), System.IO.Path.GetRandomFileName());
+ string temppath = Path.Combine(Path.GetTempPath(), Path.GetRandomFileName());
//All files have random names on disk, but a full path in the zip file
List<KeyValuePair<string, string>> filemap = new List<KeyValuePair<string, string>>();
try
- System.IO.Directory.CreateDirectory(temppath);
+ Directory.CreateDirectory(temppath);
int opno = 1;
foreach (var folder in folders)
- Progress(ProgressType.PreparingFolder, folder, files.Count + folders.Count + 1, opno);
+ SignalProgress(ProgressType.PreparingFolder, folder, files.Count + folders.Count + 1, opno);
AddFolderResource(manifest, temppath, folder, removeExistingFiles, m_connection, filemap);
- Progress(ProgressType.PreparingFolder, folder, files.Count + folders.Count + 1, opno++);
+ SignalProgress(ProgressType.PreparingFolder, folder, files.Count + folders.Count + 1, opno++);
foreach (var doc in files)
- Progress(ProgressType.PreparingFolder, doc, files.Count + folders.Count + 1, opno);
+ SignalProgress(ProgressType.PreparingFolder, doc, files.Count + folders.Count + 1, opno);
string filebase = CreateFolderForResource(doc, temppath);
resourceData[doc] = new List<ResourceDataListResourceData>();
@@ -506,8 +517,8 @@
int itemCount = resourceData[doc].Count + 1;
- filemap.Add(new KeyValuePair<string, string>(filebase + "_CONTENT.xml", System.IO.Path.Combine(temppath, Guid.NewGuid().ToString()))); //NOXLATE
- using (System.IO.FileStream fs = new System.IO.FileStream(filemap[filemap.Count - 1].Value, System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ filemap.Add(new KeyValuePair<string, string>(filebase + "_CONTENT.xml", Path.Combine(temppath, Guid.NewGuid().ToString()))); //NOXLATE
+ using (FileStream fs = new FileStream(filemap[filemap.Count - 1].Value, FileMode.Create, FileAccess.Write, FileShare.None))
using (var s = m_connection.ResourceService.GetResourceXmlData(doc))
@@ -520,9 +531,9 @@
foreach (ResourceDataListResourceData rd in rdl.ResourceData)
- filemap.Add(new KeyValuePair<string, string>(filebase + "_DATA_" + EncodeFilename(rd.Name), System.IO.Path.Combine(temppath, Guid.NewGuid().ToString())));
- System.IO.FileInfo fi = new System.IO.FileInfo(filemap[filemap.Count - 1].Value);
- using (System.IO.FileStream fs = new System.IO.FileStream(fi.FullName, System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ filemap.Add(new KeyValuePair<string, string>(filebase + "_DATA_" + EncodeFilename(rd.Name), Path.Combine(temppath, Guid.NewGuid().ToString())));
+ FileInfo fi = new FileInfo(filemap[filemap.Count - 1].Value);
+ using (FileStream fs = new FileStream(fi.FullName, FileMode.Create, FileAccess.Write, FileShare.None))
Utility.CopyStream(m_connection.ResourceService.GetResourceData(doc, rd.Name), fs);
@@ -530,50 +541,45 @@
AddResourceData(manifest, temppath, doc, fi, filemap[filemap.Count - 1].Key, rd, m_connection);
- Progress(ProgressType.PreparingFolder, doc, files.Count + folders.Count + 1, opno++);
+ SignalProgress(ProgressType.PreparingFolder, doc, files.Count + folders.Count + 1, opno++);
- Progress(ProgressType.PreparingFolder, Strings.ProgressDone, files.Count + folders.Count + 1, files.Count + folders.Count + 1);
+ SignalProgress(ProgressType.PreparingFolder, Strings.ProgressDone, files.Count + folders.Count + 1, files.Count + folders.Count + 1);
if (!string.IsNullOrEmpty(alternateTargetResourceId))
- Progress(ProgressType.MovingResources, Strings.ProgressUpdatingReferences, 100, 0);
+ SignalProgress(ProgressType.MovingResources, Strings.ProgressUpdatingReferences, 100, 0);
RemapFiles(m_connection, manifest, temppath, folderResourceId, alternateTargetResourceId, filemap);
- Progress(ProgressType.MovingResources, Strings.ProgressUpdatedReferences, 100, 100);
+ SignalProgress(ProgressType.MovingResources, Strings.ProgressUpdatedReferences, 100, 100);
- filemap.Add(new KeyValuePair<string, string>(System.IO.Path.Combine(temppath, "MgResourcePackageManifest.xml"), System.IO.Path.Combine(temppath, Guid.NewGuid().ToString()))); //NOXLATE
- using (System.IO.FileStream fs = new System.IO.FileStream(filemap[filemap.Count - 1].Value, System.IO.FileMode.CreateNew, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ filemap.Add(new KeyValuePair<string, string>(Path.Combine(temppath, "MgResourcePackageManifest.xml"), Path.Combine(temppath, Guid.NewGuid().ToString()))); //NOXLATE
+ using (FileStream fs = new FileStream(filemap[filemap.Count - 1].Value, FileMode.CreateNew, FileAccess.Write, FileShare.None))
m_connection.ResourceService.SerializeObject(manifest, fs);
- Progress(ProgressType.MovingResources, zipfilename, filemap.Count, 0);
+ SignalProgress(ProgressType.MovingResources, zipfilename, filemap.Count, 0);
ZipDirectory(zipfilename, temppath, "MapGuide Package created by Maestro", filemap); //NOXLATE
- Progress(ProgressType.MovingResources, zipfilename, filemap.Count, filemap.Count);
- Progress(ProgressType.Done, "", filemap.Count, filemap.Count);
+ SignalProgress(ProgressType.MovingResources, zipfilename, filemap.Count, filemap.Count);
+ SignalProgress(ProgressType.Done, "", filemap.Count, filemap.Count);
finally
try
- if (System.IO.Directory.Exists(temppath))
- System.IO.Directory.Delete(temppath, true);
+ if (Directory.Exists(temppath))
+ Directory.Delete(temppath, true);
catch
- private void AddResourceData(ResourcePackageManifest manifest, string temppath, string docResourceId, System.IO.FileInfo fi, string resourcePath, ResourceDataListResourceData rd, IServerConnection connection)
+ private void AddResourceData(ResourcePackageManifest manifest, string temppath, string docResourceId, FileInfo fi, string resourcePath, ResourceDataListResourceData rd, IServerConnection connection)
string contentType = "application/octet-stream"; //NOXLATE
@@ -628,8 +634,8 @@
string filebase = CreateFolderForResource(docResourceId, temppath);
- filemap.Add(new KeyValuePair<string, string>(filebase + "_HEADER.xml", System.IO.Path.Combine(temppath, Guid.NewGuid().ToString()))); //NOXLATE
+ filemap.Add(new KeyValuePair<string, string>(filebase + "_HEADER.xml", Path.Combine(temppath, Guid.NewGuid().ToString()))); //NOXLATE
connection.ResourceService.SerializeObject(connection.ResourceService.GetResourceHeader(docResourceId), fs);
string headerpath = RelativeName(filemap[filemap.Count - 1].Key, temppath).Replace('\\', '/'); //NOXLATE
@@ -685,14 +691,14 @@
private void AddFolderResource(ResourcePackageManifest manifest, string temppath, string folderResId, bool eraseFirst, IServerConnection connection, List<KeyValuePair<string, string>> filemap)
- string filebase = System.IO.Path.GetDirectoryName(CreateFolderForResource(folderResId + "dummy.xml", temppath)); //NOXLATE
+ string filebase = Path.GetDirectoryName(CreateFolderForResource(folderResId + "dummy.xml", temppath)); //NOXLATE
- filemap.Add(new KeyValuePair<string, string>(System.IO.Path.Combine(filebase, "_HEADER.xml"), System.IO.Path.Combine(temppath, Guid.NewGuid().ToString()))); //NOXLATE
+ filemap.Add(new KeyValuePair<string, string>(Path.Combine(filebase, "_HEADER.xml"), Path.Combine(temppath, Guid.NewGuid().ToString()))); //NOXLATE
connection.ResourceService.SerializeObject(connection.ResourceService.GetFolderHeader(folderResId), fs);
- if (!filebase.EndsWith(System.IO.Path.DirectorySeparatorChar.ToString()))
- filebase += System.IO.Path.DirectorySeparatorChar;
+ if (!filebase.EndsWith(Path.DirectorySeparatorChar.ToString()))
+ filebase += Path.DirectorySeparatorChar;
string headerpath = RelativeName(filebase + "_HEADER.xml", temppath).Replace('\\', '/'); //NOXLATE
@@ -745,8 +751,8 @@
if (!filebase.StartsWith(temppath))
throw new Exception(string.Format(Strings.FilenameRelationInternalError, filebase, temppath));
- if (!temppath.EndsWith(System.IO.Path.DirectorySeparatorChar.ToString()))
- temppath += System.IO.Path.DirectorySeparatorChar;
+ if (!temppath.EndsWith(Path.DirectorySeparatorChar.ToString()))
+ temppath += Path.DirectorySeparatorChar;
return filebase.Substring(temppath.Length);
@@ -787,10 +793,10 @@
folder = folder.Substring(0, folder.Length - filebase.Length);
filebase += resourceId.Substring(resourceId.LastIndexOf('.')); //NOXLATE
- folder = folder.Replace('/', System.IO.Path.DirectorySeparatorChar); //NOXLATE
- folder = System.IO.Path.Combine(temppath, folder);
+ folder = folder.Replace('/', Path.DirectorySeparatorChar); //NOXLATE
+ folder = Path.Combine(temppath, folder);
- return System.IO.Path.Combine(folder, filebase);
+ return Path.Combine(folder, filebase);
private void RemapFiles(IServerConnection connection, ResourcePackageManifest manifest, string tempdir, string origpath, string newpath, List<KeyValuePair<string, string>> filemap)
@@ -809,18 +815,18 @@
op.Parameters.SetParameterValue("RESOURCEID", newpath + op.Parameters.GetParameterValue("RESOURCEID").Substring(origpath.Length)); //NOXLATE
if (op.Parameters.GetParameterValue("CONTENT") != null) //NOXLATE
- string path = System.IO.Path.Combine(tempdir, op.Parameters.GetParameterValue("CONTENT").Replace('/', System.IO.Path.DirectorySeparatorChar)); //NOXLATE
- System.Xml.XmlDocument doc = new System.Xml.XmlDocument();
+ string path = Path.Combine(tempdir, op.Parameters.GetParameterValue("CONTENT").Replace('/', Path.DirectorySeparatorChar)); //NOXLATE
+ XmlDocument doc = new XmlDocument();
doc.Load(lookup[path]);
((PlatformConnectionBase)connection).UpdateResourceReferences(doc, origpath, newpath, true);
- System.IO.MemoryStream ms = new System.IO.MemoryStream();
+ MemoryStream ms = new MemoryStream();
doc.Save(ms);
- System.IO.MemoryStream ms2 = Utility.RemoveUTF8BOM(ms);
+ MemoryStream ms2 = Utility.RemoveUTF8BOM(ms);
if (ms2 != ms)
ms.Dispose();
ms2.Position = 0;
- using (System.IO.FileStream fs = new System.IO.FileStream(lookup[path], System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ using (FileStream fs = new FileStream(lookup[path], FileMode.Create, FileAccess.Write, FileShare.None))
Utility.CopyStream(ms2, fs);
@@ -831,9 +837,9 @@
private void ZipDirectory(string zipfile, string folder, string comment, List<KeyValuePair<string, string>> filemap)
- ICSharpCode.SharpZipLib.Zip.ZipConstants.DefaultCodePage = System.Text.Encoding.UTF8.CodePage;
+ ZipConstants.DefaultCodePage = System.Text.Encoding.UTF8.CodePage;
ICSharpCode.SharpZipLib.Checksums.Crc32 crc = new ICSharpCode.SharpZipLib.Checksums.Crc32();
- using (System.IO.FileStream ofs = new System.IO.FileStream(zipfile, System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ using (FileStream ofs = new FileStream(zipfile, FileMode.Create, FileAccess.Write, FileShare.None))
using (ICSharpCode.SharpZipLib.Zip.ZipOutputStream zip = new ICSharpCode.SharpZipLib.Zip.ZipOutputStream(ofs))
try
@@ -846,19 +852,17 @@
foreach (KeyValuePair<string, string> f in filemap)
- Progress(ProgressType.Compressing, f.Key, filemap.Count, i);
+ SignalProgress(ProgressType.Compressing, f.Key, filemap.Count, i);
- System.IO.FileInfo fi = new System.IO.FileInfo(f.Value);
+ FileInfo fi = new FileInfo(f.Value);
ICSharpCode.SharpZipLib.Zip.ZipEntry ze = new ICSharpCode.SharpZipLib.Zip.ZipEntry(RelativeName(f.Key, folder).Replace('\\', '/'));
ze.DateTime = fi.LastWriteTime;
ze.Size = fi.Length;
zip.PutNextEntry(ze);
- using (System.IO.FileStream fs = new System.IO.FileStream(fi.FullName, System.IO.FileMode.Open, System.IO.FileAccess.Read, System.IO.FileShare.None))
+ using (FileStream fs = new FileStream(fi.FullName, FileMode.Open, FileAccess.Read, FileShare.None))
Utility.CopyStream(fs, zip);
- Progress(ProgressType.Compressing, f.Key, filemap.Count, i++);
+ SignalProgress(ProgressType.Compressing, f.Key, filemap.Count, i++);
zip.Finish();
@@ -893,43 +897,39 @@
/// <param name="targetfile">The output package filename</param>
public void RebuildPackage(string sourcePackageFile, List<ResourceItem> items, string targetfile, bool insertEraseCommands)
- string tempfolder = System.IO.Path.GetTempPath();
+ string tempfolder = Path.GetTempPath();
int opno = 1;
try
- Progress(ProgressType.ReadingFileList, sourcePackageFile, 100, 0);
+ SignalProgress(ProgressType.ReadingFileList, sourcePackageFile, 100, 0);
//Step 1: Create the file system layout
- if (!System.IO.Directory.Exists(tempfolder))
- System.IO.Directory.CreateDirectory(tempfolder);
+ if (!Directory.Exists(tempfolder))
+ Directory.CreateDirectory(tempfolder);
string zipfilecomment;
- using (ICSharpCode.SharpZipLib.Zip.ZipFile zipfile = new ICSharpCode.SharpZipLib.Zip.ZipFile(sourcePackageFile))
+ using (ZipFile zipfile = new ZipFile(sourcePackageFile))
zipfilecomment = zipfile.ZipFileComment;
- Progress(ProgressType.ReadingFileList, sourcePackageFile, 100, 100);
+ SignalProgress(ProgressType.ReadingFileList, sourcePackageFile, 100, 100);
- Progress(ProgressType.PreparingFolder, string.Empty, items.Count, 0);
+ SignalProgress(ProgressType.PreparingFolder, string.Empty, items.Count, 0);
foreach (ResourceItem ri in items)
- Progress(ProgressType.PreparingFolder, ri.ResourcePath, items.Count, opno);
+ SignalProgress(ProgressType.PreparingFolder, ri.ResourcePath, items.Count, opno);
string filebase;
if (ri.IsFolder)
- filebase = System.IO.Path.GetDirectoryName(MapResourcePathToFolder(tempfolder, ri.ResourcePath + "dummy.xml")); //NOXLATE
+ filebase = Path.GetDirectoryName(MapResourcePathToFolder(tempfolder, ri.ResourcePath + "dummy.xml")); //NOXLATE
else
filebase = MapResourcePathToFolder(tempfolder, ri.ResourcePath);
@@ -941,8 +941,8 @@
if (string.IsNullOrEmpty(ri.Headerpath))
- filemap.Add(new KeyValuePair<string, string>(headerpath, System.IO.Path.Combine(tempfolder, ri.GenerateUniqueName())));
+ filemap.Add(new KeyValuePair<string, string>(headerpath, Path.Combine(tempfolder, ri.GenerateUniqueName())));
byte[] data = System.Text.Encoding.UTF8.GetBytes(DEFAULT_HEADER);
fs.Write(data, 0, data.Length);
@@ -961,8 +961,8 @@
@@ -974,8 +974,8 @@
if (index < 0)
throw new Exception(string.Format(Strings.FileMissingError, ri.Headerpath));
Utility.CopyStream(zipfile.GetInputStream(index), fs);
@@ -985,8 +985,8 @@
if (index < 0)
throw new Exception(string.Format(Strings.FileMissingError, ri.Contentpath));
- filemap.Add(new KeyValuePair<string, string>(contentpath, System.IO.Path.Combine(tempfolder, ri.GenerateUniqueName())));
+ filemap.Add(new KeyValuePair<string, string>(contentpath, Path.Combine(tempfolder, ri.GenerateUniqueName())));
@@ -999,7 +999,7 @@
string targetpath = filebase + "_DATA_" + EncodeFilename(rdi.ResourceName); //NOXLATE
if (rdi.EntryType == EntryTypeEnum.Added)
- var tempFilePath = System.IO.Path.Combine(tempfolder, ri.GenerateUniqueName());
+ var tempFilePath = Path.Combine(tempfolder, ri.GenerateUniqueName());
filemap.Add(new KeyValuePair<string, string>(targetpath, tempFilePath));
if (File.Exists(rdi.Filename))
File.Copy(rdi.Filename, tempFilePath);
@@ -1010,15 +1010,14 @@
if (index < 0)
throw new Exception(string.Format(Strings.FileMissingError, rdi.Filename));
- filemap.Add(new KeyValuePair<string, string>(targetpath, System.IO.Path.Combine(tempfolder, ri.GenerateUniqueName())));
+ filemap.Add(new KeyValuePair<string, string>(targetpath, Path.Combine(tempfolder, ri.GenerateUniqueName())));
rdi.Filename = targetpath;
- Progress(ProgressType.PreparingFolder, ri.ResourcePath, items.Count, opno++);
+ SignalProgress(ProgressType.PreparingFolder, ri.ResourcePath, items.Count, opno++);
@@ -1031,8 +1030,7 @@
//Step 2: Repoint all resources with respect to the update
- Progress(ProgressType.MovingResources, Strings.ProgressUpdatingResources, items.Count, i);
+ SignalProgress(ProgressType.MovingResources, Strings.ProgressUpdatingResources, items.Count, i);
if (ri.OriginalResourcePath != ri.ResourcePath)
@@ -1040,17 +1038,17 @@
if (!rix.IsFolder)
doc.Load(filemap_lookup[rix.Contentpath]);
((PlatformConnectionBase)m_connection).UpdateResourceReferences(doc, ri.OriginalResourcePath, ri.ResourcePath, ri.IsFolder);
doc.Save(ms);
if (ms2 != ms)
ms.Dispose();
ms2.Position = 0;
- using (System.IO.FileStream fs = new System.IO.FileStream(filemap_lookup[rix.Contentpath], System.IO.FileMode.Create, System.IO.FileAccess.Write, System.IO.FileShare.None))
+ using (FileStream fs = new FileStream(filemap_lookup[rix.Contentpath], FileMode.Create, FileAccess.Write, FileShare.None))
@@ -1058,12 +1056,10 @@
- Progress(ProgressType.MovingResources, Strings.ProgressUpdatingResources, items.Count, i++);
+ SignalProgress(ProgressType.MovingResources, Strings.ProgressUpdatingResources, items.Count, i++);
- Progress(ProgressType.MovingResources, Strings.ProgressUpdatedResources, items.Count, items.Count);
+ SignalProgress(ProgressType.MovingResources, Strings.ProgressUpdatedResources, items.Count, items.Count);
//Step 3: Create an updated definition file
ResourcePackageManifest manifest = new ResourcePackageManifest();
@@ -1099,32 +1095,30 @@
rdi.DataType,
rdi.ResourceName,
RelativeName(rdi.Filename, tempfolder).Replace('\\', '/'), //NOXLATE
- new System.IO.FileInfo(filemap_lookup[rdi.Filename]).Length);
+ new FileInfo(filemap_lookup[rdi.Filename]).Length);
- filemap.Add(new KeyValuePair<string, string>(System.IO.Path.Combine(tempfolder, "MgResourcePackageManifest.xml"), System.IO.Path.Combine(tempfolder, Guid.NewGuid().ToString()))); //NOXLATE
+ filemap.Add(new KeyValuePair<string, string>(Path.Combine(tempfolder, "MgResourcePackageManifest.xml"), Path.Combine(tempfolder, Guid.NewGuid().ToString()))); //NOXLATE
- Progress(ProgressType.Compressing, Strings.ProgressCompressing, 100, 0);
+ SignalProgress(ProgressType.Compressing, Strings.ProgressCompressing, 100, 0);
//Step 4: Create the zip file
ZipDirectory(targetfile, tempfolder, zipfilecomment, filemap);
- Progress(ProgressType.Compressing, Strings.ProgressCompressed, 100, 100);
+ SignalProgress(ProgressType.Compressing, Strings.ProgressCompressed, 100, 100);
finally
- try { System.IO.Directory.Delete(tempfolder, true); }
+ try { Directory.Delete(tempfolder, true); }
catch { }
- private int FindZipEntry(ICSharpCode.SharpZipLib.Zip.ZipFile file, string path)
+ private int FindZipEntry(ZipFile file, string path)
string p = path.Replace('\\', '/'); //NOXLATE
foreach (ICSharpCode.SharpZipLib.Zip.ZipEntry ze in file)
@@ -1141,14 +1135,13 @@
/// <returns>A dictionary of items, the key is the resourceId</returns>
public Dictionary<string, ResourceItem> ListPackageContents(string packageFile)
- Progress(ProgressType.ListingFiles, packageFile, 100, 0);
+ SignalProgress(ProgressType.ListingFiles, packageFile, 100, 0);
Dictionary<string, ResourceItem> resourceList = new Dictionary<string, ResourceItem>();
ResourcePackageManifest manifest;
- using (ICSharpCode.SharpZipLib.Zip.ZipFile zipfile = new ICSharpCode.SharpZipLib.Zip.ZipFile(packageFile))
+ using (ZipFile zipfile = new ZipFile(packageFile))
int index = FindZipEntry(zipfile, "MgResourcePackageManifest.xml"); //NOXLATE
if (index < 0)
@@ -1158,14 +1151,12 @@
int i = 0;
- Progress(ProgressType.ListingFiles, packageFile, manifest.Operations.Operation.Count, i);
+ SignalProgress(ProgressType.ListingFiles, packageFile, manifest.Operations.Operation.Count, i);
//TODO: Much of this assumes that the package is correctly constructed, ea.: no SETRESOURCEDATA, before a SETRESOURCE and so on.
foreach (ResourcePackageManifestOperationsOperation op in manifest.Operations.Operation)
- Progress(ProgressType.ListingFiles, packageFile, manifest.Operations.Operation.Count, i++);
+ SignalProgress(ProgressType.ListingFiles, packageFile, manifest.Operations.Operation.Count, i++);
if (op.Name.ToLower().Equals("setresource")) //NOXLATE
Modified: trunk/Tools/Maestro/Maestro.Packaging/PackageProgress.cs
--- trunk/Tools/Maestro/Maestro.Packaging/PackageProgress.cs 2015-08-18 12:04:55 UTC (rev 8748)
+++ trunk/Tools/Maestro/Maestro.Packaging/PackageProgress.cs 2015-08-18 13:46:44 UTC (rev 8749)
@@ -66,7 +66,7 @@
/// <returns>A DialogResult object that indicates the upload result</returns>
public static DialogResult UploadPackage(Form owner, IServerConnection con)
- OpenFileDialog dlg = Maestro.Shared.UI.DialogFactory.OpenFile();
+ OpenFileDialog dlg = DialogFactory.OpenFile();
//Mono does NOT like this one
//dlg.AutoUpgradeEnabled = true;
dlg.CheckFileExists = true;
@@ -288,12 +288,17 @@
- private delegate void SetCurrentProgressDelegate(ProgressType type, string resource, int total, double pg);
- private void SetCurrentProgress(ProgressType type, string resource, int total, double pg)
+ private void SetCurrentProgress(ProgressEventArgs args)
+ ProgressType type = args.Type;
+ string resource = args.ResourceId;
+ int total = args.MaxValue;
+ double pg = args.Value;
if (this.InvokeRequired)
- this.Invoke(new SetCurrentProgressDelegate(SetCurrentProgress), new object[] { type, resource, total, pg });
+ Action<ProgressEventArgs> action = SetCurrentProgress;
+ this.Invoke(action, new object[] { args });
else
int span = this.CurrentProgress.Maximum - this.CurrentProgress.Minimum;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Feature/FeatureReaderBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Feature/FeatureReaderBase.cs 2015-08-18 12:04:55 UTC (rev 8748)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Feature/FeatureReaderBase.cs 2015-08-18 13:46:44 UTC (rev 8749)
@@ -46,7 +46,7 @@
/// only a subset of the class properties (as specified in the filter text), the class
/// definition reflects what the user has requested, rather than the full class definition.
/// </summary>
- public OSGeo.MapGuide.MaestroAPI.Schema.ClassDefinition ClassDefinition
+ public ClassDefinition ClassDefinition
get { return _cls; }
protected set
More information about the mapguide-commits
