[mapguide-commits] r8852 - sandbox/jng/aspnet50/UnitTest/TestData/FeatureService
svn_mapguide at osgeo.org
Thu Dec 3 08:06:45 PST 2015
Author: jng
Date: 2015-12-03 08:06:44 -0800 (Thu, 03 Dec 2015)
New Revision: 8852
sandbox/jng/aspnet50/UnitTest/TestData/FeatureService/FeatureServiceTest.dump
Update test data. Our checking code should probably strip out the FDO version number in these expected responses, so these tests won't break every yearly release cycle.
This reduces the failure count to 9/696. Though the 9 failures I strongly suspect is due to my MapGuide Server not being in a pristine state when running this test suite against.
Modified: sandbox/jng/aspnet50/UnitTest/TestData/FeatureService/FeatureServiceTest.dump
--- sandbox/jng/aspnet50/UnitTest/TestData/FeatureService/FeatureServiceTest.dump 2015-12-03 16:00:12 UTC (rev 8851)
+++ sandbox/jng/aspnet50/UnitTest/TestData/FeatureService/FeatureServiceTest.dump 2015-12-03 16:06:44 UTC (rev 8852)
@@ -521,7 +521,7 @@
INSERT INTO "HttpTestResults" VALUES('GetSpatialContexts on a SDF resource', 8010, 'text/xml; charset=utf-8', '
<FdoSpatialContextList>
- <ProviderName>OSGeo.SDF.3.9</ProviderName>
+ <ProviderName>OSGeo.SDF.4.0</ProviderName>
<SpatialContext>
<CoordinateSystemName>GEOGCS["LL84",DATUM["WGS 84",SPHEROID["WGS 84",6378137,0],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",0.01745329252]]</CoordinateSystemName>
<CoordinateSystemWkt>GEOGCS["LL84",DATUM["WGS 84",SPHEROID["WGS 84",6378137,0],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["Degrees",0.01745329252]]</CoordinateSystemWkt>
@@ -544,7 +544,7 @@
</FdoSpatialContextList>');
INSERT INTO "HttpTestResults" VALUES('GetSpatialContexts on a SDF resource', 8011, 'text/xml; charset=utf-8', '
<SpatialContext>
@@ -1851,7 +1851,7 @@
INSERT INTO "ApiTestResults" VALUES('GetSpatialContexts on a SDF resource when resource data is not set yet', 8009, 'text/plain', 'mgapplicationexception');
INSERT INTO "ApiTestResults" VALUES('GetSpatialContexts on a SDF resource', 8010, 'text/xml', '
<SpatialContext>
@@ -1874,7 +1874,7 @@
INSERT INTO "ApiTestResults" VALUES('GetSpatialContexts on a SDF resource', 8011, 'text/xml', '
<SpatialContext>
More information about the mapguide-commits
