[mapguide-commits] r8865 - in sandbox/jng/aspnet50/Oem/SWIGEx: . Source/Modules
svn_mapguide at osgeo.org
Sat Dec 12 06:54:32 PST 2015
Author: jng
Date: 2015-12-12 06:54:32 -0800 (Sat, 12 Dec 2015)
New Revision: 8865
Added:
sandbox/jng/aspnet50/Oem/SWIGEx/SwigEx.vcxproj
Removed:
sandbox/jng/aspnet50/Oem/SWIGEx/SwigEx.vcproj
sandbox/jng/aspnet50/Oem/SWIGEx/Source/Modules/csharp.cxx
sandbox/jng/aspnet50/Oem/SWIGEx/SwigEx.sln
- Upgrade SWIG project to VS 2015
- Un-tabify csharp.cxx
Modified: sandbox/jng/aspnet50/Oem/SWIGEx/Source/Modules/csharp.cxx
--- sandbox/jng/aspnet50/Oem/SWIGEx/Source/Modules/csharp.cxx 2015-12-11 02:11:34 UTC (rev 8864)
+++ sandbox/jng/aspnet50/Oem/SWIGEx/Source/Modules/csharp.cxx 2015-12-12 14:54:32 UTC (rev 8865)
@@ -244,7 +244,7 @@
variable_wrapper_flag(false),
wrapping_member_flag(false),
global_variable_flag(false),
- emitExCount(0),
+ emitExCount(0),
imclass_name(NULL),
module_class_name(NULL),
@@ -346,7 +346,7 @@
i++;
else
- Swig_arg_error();
+ Swig_arg_error();
} else if ((strcmp(argv[i],"-noproxy") == 0)) {
Swig_mark_arg(i);
proxy_flag = false;
@@ -460,12 +460,12 @@
Printf(f_wrappers,"extern \"C\" {\n");
Printf(f_wrappers,"#endif\n\n");
- emitThrowFunction(f_wrappers);
+ emitThrowFunction(f_wrappers);
if(getIdFilename)
- Swig_insert_file(getIdFilename, f_wrappers);
+ Swig_insert_file(getIdFilename, f_wrappers);
if(catchAllCodeFilename)
- Swig_insert_file(catchAllCodeFilename, f_wrappers);
+ Swig_insert_file(catchAllCodeFilename, f_wrappers);
/* Emit code */
Language::top(n);
@@ -512,7 +512,7 @@
// Add main polymorphism support code
String* mapInitCode = NewString("");
for(map<string, int>::const_iterator it = clsIds.begin(); it != clsIds.end(); it++)
if(namespaceName != NULL)
Printf(mapInitCode, " classMap[%d] = Type.GetType(\"%s.%s\");\n", it->second, namespaceName, it->first.c_str());
@@ -523,7 +523,7 @@
Printf(mapInitCode, " classMap[%d] = Type.GetType(\"%s\");\n", it->second, it->first.c_str());
Printf(mapInitCode, " classNameMap[%d] = \"%s\";\n", it->second, it->first.c_str());
char* pmapInitCode = Char(mapInitCode);
char* pimclass_class_code = Char(imclass_class_code);
Replaceall(imclass_class_code, "$initMap", mapInitCode);
@@ -659,54 +659,54 @@
void emitCatchSequence(File* f, ExceptionClass* e)
- if(e->derivedClasses.size() > 0)
- list<ExceptionClass*>::const_iterator iter = e->derivedClasses.begin();
- while(iter != e->derivedClasses.end())
- emitCatchSequence(f, *iter);
- iter++;
+ if(e->derivedClasses.size() > 0)
+ list<ExceptionClass*>::const_iterator iter = e->derivedClasses.begin();
+ while(iter != e->derivedClasses.end())
+ emitCatchSequence(f, *iter);
+ iter++;
if(rethrowCode)
- Printf(f, "\tcatch(%s*)\n", e->name.c_str());
+ Printf(f, "\tcatch(%s*)\n", e->name.c_str());
else
- if(this->emitExCount++ == 0)
- Printf(f, "\tif(typeid(*e) == typeid(%s))\n", e->name.c_str());
- else
- Printf(f, "\telse if(typeid(*e) == typeid(%s))\n", e->name.c_str());
+ if(this->emitExCount++ == 0)
+ Printf(f, "\tif(typeid(*e) == typeid(%s))\n", e->name.c_str());
+ else
+ Printf(f, "\telse if(typeid(*e) == typeid(%s))\n", e->name.c_str());
- Printf(f, "\t{\n");
+ Printf(f, "\t{\n");
- Printf(f, "\t\texName = \"%s.%s\";\n", namespaceName, e->name.c_str());
+ Printf(f, "\t\texName = \"%s.%s\";\n", namespaceName, e->name.c_str());
else
- Printf(f, "\t\texName = \"%s\";\n", e->name.c_str());
- Printf(f, "\t}\n");
+ Printf(f, "\t\texName = \"%s\";\n", e->name.c_str());
+ Printf(f, "\t}\n");
void emitBaseExceptionCatchSequence(File* f)
- if(baseException == NULL)
- return;
+ if(baseException == NULL)
+ return;
if(rethrowCode)
- Printf(f, "\tcatch(%s* e)\n", baseException);
+ Printf(f, "\tcatch(%s* e)\n", baseException);
else
- Printf(f, "\tif(typeid(*e) == typeid(%s))\n", baseException);
- else
- Printf(f, "\telse if(typeid(*e) == typeid(%s))\n", baseException);
+ Printf(f, "\tif(typeid(*e) == typeid(%s))\n", baseException);
+ else
+ Printf(f, "\telse if(typeid(*e) == typeid(%s))\n", baseException);
Printf(f, "\t\tchar* multibyteExName = e->GetMultiByteClassName();\n");
Printf(f, "\t\tchar* multibyteNameSpaceName = e->GetNameSpace();\n");
@@ -727,23 +727,23 @@
Printf(f, "\t\t}\n");
Printf(f, "\t\tif (!bFound) exNames.push_back(exName);\n");
- void emitThrowFunction(File* f)
- return;
+ void emitThrowFunction(File* f)
+ return;
- Printf(f, "#if !defined(__GNUC__)\n");
- Printf(f, "#pragma warning( disable: 4715)\n");
- Printf(f, "#else\n");
- Printf(f, "//see if GNU compiler issues a warning for function all path not returning a value, and generate the code to suppress it here\n");
- Printf(f, "#endif\n\n");
+ Printf(f, "#if !defined(__GNUC__)\n");
+ Printf(f, "#pragma warning( disable: 4715)\n");
+ Printf(f, "#else\n");
+ Printf(f, "//see if GNU compiler issues a warning for function all path not returning a value, and generate the code to suppress it here\n");
+ Printf(f, "#endif\n\n");
- Printf(f, "void ThrowDotNetExceptionWrapper(%s* e)\n{\n", baseException);
- Printf(f, "\tstatic list<char*> exNames;\n");
- Printf(f, "\tchar* exName = NULL;\n");
+ Printf(f, "void ThrowDotNetExceptionWrapper(%s* e)\n{\n", baseException);
+ Printf(f, "\tstatic list<char*> exNames;\n");
+ Printf(f, "\tchar* exName = NULL;\n");
if(rethrowCode)
Printf(f, "\ttry\n\t{\n");
@@ -752,15 +752,15 @@
else
- this->emitExCount = 0;
+ this->emitExCount = 0;
emitBaseExceptionCatchSequence(f);
- Printf(f, "\tcustom_exceptions_callback(exName, e);\n");
+ Printf(f, "\tcustom_exceptions_callback(exName, e);\n");
- Printf(f, "}\n");
+ Printf(f, "}\n");
* emitBanner()
@@ -1029,11 +1029,11 @@
// Now write code to make the function call
if(!native_function_flag)
- if(!wrappingConstant && baseException)
- //put function call withing try/catch statement
- Printf(f->code, "try\n{\n");
+ if(!wrappingConstant && baseException)
+ //put function call withing try/catch statement
+ Printf(f->code, "try\n{\n");
emit_action(n,f);
if(!wrappingConstant && proxy_class_name && disposeCode)
@@ -1093,11 +1093,11 @@
if(!is_void_return)
Printv(f->code, " return jresult;\n", NIL);
- if(!wrappingConstant && !native_function_flag && baseException)
- Printf(f->code, "}\ncatch(%s* e)\n{\nThrowDotNetExceptionWrapper(e);\n}\n", baseException);
- Printf(f->code, "\tcatch(...) { onCatchAll(\"%s\"); }\n", overloaded_name);
+ if(!wrappingConstant && !native_function_flag && baseException)
+ Printf(f->code, "}\ncatch(%s* e)\n{\nThrowDotNetExceptionWrapper(e);\n}\n", baseException);
+ Printf(f->code, "\tcatch(...) { onCatchAll(\"%s\"); }\n", overloaded_name);
Printf(f->code, "}\n");
@@ -1857,8 +1857,8 @@
bool returnObject = false;
- int td = SwigType_type(t);
- returnObject = (td == T_USER || td == T_POINTER);
+ int td = SwigType_type(t);
+ returnObject = (td == T_USER || td == T_POINTER);
/* Attach the non-standard typemaps to the parameter list */
Swig_typemap_attach_parms("in", l, NULL);
@@ -1971,15 +1971,15 @@
// Transform return type used in PInvoke function (in intermediary class) to type used in C# wrapper function (in proxy class)
if ((tm = Swig_typemap_lookup_new("csout",n,"",0))) {
addThrows(n, "tmap:csout", n);
- if(returnObject)
+ if(returnObject)
String* createObject = NewString("");
Printf(createObject, "($csclassname)$module.createObject($module.getClassId(cPtr), $module.getNameSpace(cPtr), $module.getClassName(cPtr), cPtr, true)");
- Replaceall(tm, "new $csclassname(cPtr, $owner)", createObject);
- Replaceall(tm, "$module", imclass_name);
+ Replaceall(tm, "new $csclassname(cPtr, $owner)", createObject);
+ Replaceall(tm, "$module", imclass_name);
Delete(createObject);
if (Getattr(n,"feature:new"))
Replaceall(tm,"$owner","true");
else
Modified: sandbox/jng/aspnet50/Oem/SWIGEx/SwigEx.sln
--- sandbox/jng/aspnet50/Oem/SWIGEx/SwigEx.sln 2015-12-11 02:11:34 UTC (rev 8864)
+++ sandbox/jng/aspnet50/Oem/SWIGEx/SwigEx.sln 2015-12-12 14:54:32 UTC (rev 8865)
@@ -1,6 +1,8 @@
-Microsoft Visual Studio Solution File, Format Version 10.00
-# Visual Studio 2008
-Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SwigEx", "SwigEx.vcproj", "{18F8AE78-14F3-4C6A-9768-CF5A1A5194D7}"
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio 14
+VisualStudioVersion = 14.0.24720.0
+MinimumVisualStudioVersion = 10.0.40219.1
+Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "SwigEx", "SwigEx.vcxproj", "{18F8AE78-14F3-4C6A-9768-CF5A1A5194D7}"
EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Deleted: sandbox/jng/aspnet50/Oem/SWIGEx/SwigEx.vcproj
--- sandbox/jng/aspnet50/Oem/SWIGEx/SwigEx.vcproj 2015-12-11 02:11:34 UTC (rev 8864)
+++ sandbox/jng/aspnet50/Oem/SWIGEx/SwigEx.vcproj 2015-12-12 14:54:32 UTC (rev 8865)
@@ -1,471 +0,0 @@
-<?xml version="1.0" encoding="Windows-1252"?>
-<VisualStudioProject
- ProjectType="Visual C++"
- Version="9.00"
- Name="SwigEx"
- ProjectGUID="{18F8AE78-14F3-4C6A-9768-CF5A1A5194D7}"
- Keyword="Win32Proj"
- TargetFrameworkVersion="131072"
- <Platforms>
- <Platform
- Name="Win32"
- </Platforms>
- <ToolFiles>
- </ToolFiles>
- <Configurations>
- <Configuration
- Name="Debug|Win32"
- OutputDirectory="Win32"
- IntermediateDirectory="Debug"
- ConfigurationType="1"
- CharacterSet="2"
- <Tool
- Name="VCPreBuildEventTool"
- <Tool
- Name="VCCustomBuildTool"
- <Tool
- Name="VCXMLDataGeneratorTool"
- <Tool
- Name="VCWebServiceProxyGeneratorTool"
- <Tool
- Name="VCMIDLTool"
- <Tool
- Name="VCCLCompilerTool"
- Optimization="0"
- AdditionalIncludeDirectories="Source\Swig;Source\DOH;Source\Include;Source\Preprocessor;Source\Modules"
- PreprocessorDefinitions="WIN32;_DEBUG;_CONSOLE"
- MinimalRebuild="true"
- BasicRuntimeChecks="3"
- RuntimeLibrary="1"
- UsePrecompiledHeader="0"
- WarningLevel="3"
- Detect64BitPortabilityProblems="false"
- DebugInformationFormat="4"
- <Tool
- Name="VCManagedResourceCompilerTool"
- <Tool
- Name="VCResourceCompilerTool"
- <Tool
- Name="VCPreLinkEventTool"
- <Tool
- Name="VCLinkerTool"
- OutputFile="$(OutDir)/Swig.exe"
- LinkIncremental="2"
- GenerateDebugInformation="true"
- ProgramDatabaseFile="$(OutDir)/SwigEx.pdb"
- SubSystem="1"
- RandomizedBaseAddress="1"
- DataExecutionPrevention="0"
- TargetMachine="1"
- <Tool
- Name="VCALinkTool"
- <Tool
- Name="VCManifestTool"
- <Tool
- Name="VCXDCMakeTool"
- <Tool
- Name="VCBscMakeTool"
- <Tool
- Name="VCFxCopTool"
- <Tool
- Name="VCAppVerifierTool"
- <Tool
- Name="VCPostBuildEventTool"
- </Configuration>
- <Configuration
- Name="Release|Win32"
- IntermediateDirectory="Release"
- CharacterSet="2"
- <Tool
- <Tool
- <Tool
- <Tool
- <Tool
- Name="VCMIDLTool"
- <Tool
- PreprocessorDefinitions="WIN32;NDEBUG;_CONSOLE"
- RuntimeLibrary="0"
- WarningLevel="3"
- DebugInformationFormat="3"
- <Tool
- <Tool
- <Tool
- <Tool
- LinkIncremental="1"
- SubSystem="1"
- OptimizeReferences="2"
- EnableCOMDATFolding="2"
- TargetMachine="1"
- <Tool
- <Tool
- <Tool
- <Tool
- <Tool
- <Tool
- <Tool
- </Configuration>
- </Configurations>
- <References>
- </References>
- <Files>
- <Filter
- Name="Source Files"
- Filter="cpp;c;cxx;def;odl;idl;hpj;bat;asm;asmx"
- UniqueIdentifier="{4FC737F1-C7A5-4376-A066-2A32D752A2FF}"
- <Filter
- Name="CParse"
- <File
- RelativePath=".\Source\CParse\cscanner.c"
- </File>
- <File
- RelativePath=".\Source\CParse\parser.c"
- </File>
- <File
- RelativePath=".\Source\CParse\templ.c"
- </File>
- <File
- RelativePath=".\Source\CParse\util.c"
- </File>
- </Filter>
- <Filter
- Name="DOH"
- <File
- RelativePath=".\Source\Doh\base.c"
- </File>
- <File
- RelativePath=".\Source\Doh\doh.h"
- </File>
- <File
- RelativePath=".\Source\Doh\dohint.h"
- </File>
- <File
- RelativePath=".\Source\Doh\file.c"
- </File>
- <File
- RelativePath=".\Source\Doh\fio.c"
- </File>
- <File
- RelativePath=".\Source\Doh\hash.c"
- </File>
- <File
- RelativePath=".\Source\Doh\list.c"
- </File>
- <File
- RelativePath=".\Source\Doh\memory.c"
- </File>
- <File
- RelativePath=".\Source\Doh\string.c"
- </File>
- <File
- RelativePath=".\Source\Doh\void.c"
- </File>
- </Filter>
- <Filter
- Name="Swig"
- <File
- RelativePath=".\Source\Swig\cwrap.c"
- </File>
- <File
- RelativePath=".\Source\Swig\error.c"
- </File>
- <File
- RelativePath=".\Source\Swig\fragment.c"
- </File>
- <File
- RelativePath=".\Source\Swig\getopt.c"
- </File>
- <File
- RelativePath=".\Source\Swig\include.c"
- </File>
- <File
- RelativePath=".\Source\Swig\misc.c"
- </File>
- <File
- RelativePath=".\Source\Swig\naming.c"
- </File>
- <File
- RelativePath=".\Source\Swig\parms.c"
- </File>
- <File
- RelativePath=".\Source\Swig\scanner.c"
- </File>
- <File
- RelativePath=".\Source\Swig\stype.c"
- </File>
- <File
- RelativePath=".\Source\Swig\swig.h"
- </File>
- <File
- RelativePath=".\Source\Swig\symbol.c"
- </File>
- <File
- RelativePath=".\Source\Swig\tree.c"
- </File>
- <File
- RelativePath=".\Source\Swig\typemap.c"
- </File>
- <File
- RelativePath=".\Source\Swig\typeobj.c"
- </File>
- <File
- RelativePath=".\Source\Swig\typesys.c"
- </File>
- <File
- RelativePath=".\Source\Swig\warn.c"
- </File>
- <File
- RelativePath=".\Source\Swig\wrapfunc.c"
- </File>
- </Filter>
- <Filter
- Name="Modules"
- <File
- RelativePath=".\Source\Modules\allocate.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\browser.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\chicken.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\contract.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\csharp.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\directors.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\emit.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\ExceptionClass.h"
- </File>
- <File
- RelativePath=".\Source\Modules\guile.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\java.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\lang.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\main.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\module.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\mzscheme.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\ocaml.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\overload.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\perl5.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\php4.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\php5.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\pike.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\python.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\ruby.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\s-exp.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\swigmain.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\tcl8.cxx"
- <FileConfiguration
- <Tool
- GeneratePreprocessedFile="0"
- </FileConfiguration>
- </File>
- <File
- RelativePath=".\Source\Modules\typepass.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\utils.cxx"
- </File>
- <File
- RelativePath=".\Source\Modules\xml.cxx"
- </File>
- </Filter>
- <Filter
- Name="Preprocessor"
- <File
- RelativePath=".\Source\Preprocessor\cpp.c"
- </File>
- <File
- RelativePath=".\Source\Preprocessor\expr.c"
- </File>
- </Filter>
- </Filter>
- <Filter
- Name="Header Files"
- Filter="h;hpp;hxx;hm;inl;inc;xsd"
- UniqueIdentifier="{93995380-89BD-4b04-88EB-625FBE52EBFB}"
- </Filter>
- <Filter
- Name="Resource Files"
- Filter="rc;ico;cur;bmp;dlg;rc2;rct;bin;rgs;gif;jpg;jpeg;jpe;resx"
- UniqueIdentifier="{67DA6AB6-F800-4c08-8B7A-83BB121AAD01}"
- </Filter>
- </Files>
- <Globals>
- </Globals>
-</VisualStudioProject>
Added: sandbox/jng/aspnet50/Oem/SWIGEx/SwigEx.vcxproj
--- sandbox/jng/aspnet50/Oem/SWIGEx/SwigEx.vcxproj (rev 0)
+++ sandbox/jng/aspnet50/Oem/SWIGEx/SwigEx.vcxproj 2015-12-12 14:54:32 UTC (rev 8865)
@@ -0,0 +1,171 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project DefaultTargets="Build" ToolsVersion="14.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <ItemGroup Label="ProjectConfigurations">
+ <ProjectConfiguration Include="Debug|Win32">
+ <Configuration>Debug</Configuration>
+ <Platform>Win32</Platform>
+ </ProjectConfiguration>
+ <ProjectConfiguration Include="Release|Win32">
+ <Configuration>Release</Configuration>
+ </ItemGroup>
+ <PropertyGroup Label="Globals">
+ <ProjectGuid>{18F8AE78-14F3-4C6A-9768-CF5A1A5194D7}</ProjectGuid>
+ <Keyword>Win32Proj</Keyword>
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.Default.props" />
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="Configuration">
+ <ConfigurationType>Application</ConfigurationType>
+ <PlatformToolset>v140</PlatformToolset>
+ <CharacterSet>MultiByte</CharacterSet>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="Configuration">
+ </PropertyGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.props" />
+ <ImportGroup Label="ExtensionSettings">
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'" Label="PropertySheets">
+ <Import Project="$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props" Condition="exists('$(UserRootDir)\Microsoft.Cpp.$(Platform).user.props')" Label="LocalAppDataPlatform" />
+ </ImportGroup>
+ <ImportGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'" Label="PropertySheets">
+ </ImportGroup>
+ <PropertyGroup Label="UserMacros" />
+ <PropertyGroup>
+ <_ProjectFileVersion>14.0.24720.0</_ProjectFileVersion>
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+ <OutDir>Win32\</OutDir>
+ <IntDir>Debug\</IntDir>
+ <LinkIncremental>true</LinkIncremental>
+ <CodeAnalysisRuleSet>MinimumRecommendedRules.ruleset</CodeAnalysisRuleSet>
+ <CodeAnalysisRules />
+ <CodeAnalysisRuleAssemblies />
+ </PropertyGroup>
+ <PropertyGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+ <IntDir>Release\</IntDir>
+ <LinkIncremental>false</LinkIncremental>
+ </PropertyGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
+ <ClCompile>
+ <Optimization>Disabled</Optimization>
+ <AdditionalIncludeDirectories>Source\Swig;Source\DOH;Source\Include;Source\Preprocessor;Source\Modules;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+ <PreprocessorDefinitions>WIN32;_DEBUG;_CONSOLE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <MinimalRebuild>true</MinimalRebuild>
+ <BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
+ <RuntimeLibrary>MultiThreadedDebug</RuntimeLibrary>
+ <PrecompiledHeader />
+ <WarningLevel>Level3</WarningLevel>
+ <DebugInformationFormat>EditAndContinue</DebugInformationFormat>
+ </ClCompile>
+ <Link>
+ <OutputFile>$(OutDir)Swig.exe</OutputFile>
+ <GenerateDebugInformation>true</GenerateDebugInformation>
+ <ProgramDatabaseFile>$(OutDir)SwigEx.pdb</ProgramDatabaseFile>
+ <SubSystem>Console</SubSystem>
+ <RandomizedBaseAddress>false</RandomizedBaseAddress>
+ <DataExecutionPrevention />
+ <TargetMachine>MachineX86</TargetMachine>
+ </Link>
+ </ItemDefinitionGroup>
+ <ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
+ <ClCompile>
+ <PreprocessorDefinitions>WIN32;NDEBUG;_CONSOLE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <RuntimeLibrary>MultiThreaded</RuntimeLibrary>
+ <DebugInformationFormat>ProgramDatabase</DebugInformationFormat>
+ </ClCompile>
+ <Link>
+ <OptimizeReferences>true</OptimizeReferences>
+ <EnableCOMDATFolding>true</EnableCOMDATFolding>
+ </Link>
+ <ItemGroup>
+ <ClCompile Include="Source\CParse\cscanner.c" />
+ <ClCompile Include="Source\CParse\parser.c" />
+ <ClCompile Include="Source\CParse\templ.c" />
+ <ClCompile Include="Source\CParse\util.c" />
+ <ClCompile Include="Source\Doh\base.c" />
+ <ClCompile Include="Source\Doh\file.c" />
+ <ClCompile Include="Source\Doh\fio.c" />
+ <ClCompile Include="Source\Doh\hash.c" />
+ <ClCompile Include="Source\Doh\list.c" />
+ <ClCompile Include="Source\Doh\memory.c" />
+ <ClCompile Include="Source\Doh\string.c" />
+ <ClCompile Include="Source\Doh\void.c" />
+ <ClCompile Include="Source\Modules\allocate.cxx" />
+ <ClCompile Include="Source\Modules\browser.cxx" />
+ <ClCompile Include="Source\Modules\chicken.cxx" />
+ <ClCompile Include="Source\Modules\contract.cxx" />
+ <ClCompile Include="Source\Modules\csharp.cxx" />
+ <ClCompile Include="Source\Modules\directors.cxx" />
+ <ClCompile Include="Source\Modules\emit.cxx" />
+ <ClCompile Include="Source\Modules\guile.cxx" />
+ <ClCompile Include="Source\Modules\java.cxx" />
+ <ClCompile Include="Source\Modules\lang.cxx" />
+ <ClCompile Include="Source\Modules\main.cxx" />
+ <ClCompile Include="Source\Modules\module.cxx" />
+ <ClCompile Include="Source\Modules\mzscheme.cxx" />
+ <ClCompile Include="Source\Modules\ocaml.cxx" />
+ <ClCompile Include="Source\Modules\overload.cxx" />
+ <ClCompile Include="Source\Modules\perl5.cxx" />
+ <ClCompile Include="Source\Modules\php4.cxx" />
+ <ClCompile Include="Source\Modules\php5.cxx" />
+ <ClCompile Include="Source\Modules\pike.cxx" />
+ <ClCompile Include="Source\Modules\python.cxx" />
+ <ClCompile Include="Source\Modules\ruby.cxx" />
+ <ClCompile Include="Source\Modules\s-exp.cxx" />
+ <ClCompile Include="Source\Modules\swigmain.cxx" />
+ <ClCompile Include="Source\Modules\tcl8.cxx">
+ <PreprocessToFile Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">false</PreprocessToFile>
+ <PreprocessSuppressLineNumbers Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">false</PreprocessSuppressLineNumbers>
+ </ClCompile>
+ <ClCompile Include="Source\Modules\typepass.cxx" />
+ <ClCompile Include="Source\Modules\utils.cxx" />
+ <ClCompile Include="Source\Modules\xml.cxx" />
+ <ClCompile Include="Source\Preprocessor\cpp.c" />
+ <ClCompile Include="Source\Preprocessor\expr.c" />
+ <ClCompile Include="Source\Swig\cwrap.c" />
+ <ClCompile Include="Source\Swig\error.c" />
+ <ClCompile Include="Source\Swig\fragment.c" />
+ <ClCompile Include="Source\Swig\getopt.c" />
+ <ClCompile Include="Source\Swig\include.c" />
+ <ClCompile Include="Source\Swig\misc.c" />
+ <ClCompile Include="Source\Swig\naming.c" />
+ <ClCompile Include="Source\Swig\parms.c" />
+ <ClCompile Include="Source\Swig\scanner.c" />
+ <ClCompile Include="Source\Swig\stype.c" />
+ <ClCompile Include="Source\Swig\symbol.c" />
+ <ClCompile Include="Source\Swig\tree.c" />
+ <ClCompile Include="Source\Swig\typemap.c" />
+ <ClCompile Include="Source\Swig\typeobj.c" />
+ <ClCompile Include="Source\Swig\typesys.c" />
+ <ClCompile Include="Source\Swig\warn.c" />
+ <ClCompile Include="Source\Swig\wrapfunc.c" />
+ </ItemGroup>
+ <ItemGroup>
+ <ClInclude Include="Source\Doh\doh.h" />
+ <ClInclude Include="Source\Doh\dohint.h" />
+ <ClInclude Include="Source\Modules\ExceptionClass.h" />
+ <ClInclude Include="Source\Swig\swig.h" />
+ </ItemGroup>
+ <Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
+ <ImportGroup Label="ExtensionTargets">
+ </ImportGroup>
+</Project>
\ No newline at end of file
More information about the mapguide-commits
