[mapguide-commits] r8529 - in trunk/MgDev: Common/Foundation/Data Common/Foundation/System Common/MapGuideCommon/MapLayer Common/MapGuideCommon/Services Common/PlatformBase/Services Server/src/Common/Manager Server/src/Core Server/src/Services/Drawing Server/src/Services/Feature Server/src/Services/Mapping Server/src/Services/Resource Server/src/Services/ServerAdmin
svn_mapguide at osgeo.org
Tue Feb 3 06:30:27 PST 2015
Author: jng
Date: 2015-02-03 06:30:27 -0800 (Tue, 03 Feb 2015)
New Revision: 8529
trunk/MgDev/Common/Foundation/Data/ByteSink.cpp
trunk/MgDev/Common/Foundation/System/ByteSourceStreamImpl.cpp
trunk/MgDev/Common/Foundation/System/Util.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ServerInformation.cpp
trunk/MgDev/Common/PlatformBase/Services/Resource.cpp
trunk/MgDev/Server/src/Common/Manager/PackageManager.cpp
trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp
trunk/MgDev/Server/src/Core/TimedEventHandler.cpp
trunk/MgDev/Server/src/Services/Drawing/ServerDrawingService.cpp
trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.cpp
trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp
trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
trunk/MgDev/Server/src/Services/Resource/RepositoryManager.cpp
trunk/MgDev/Server/src/Services/Resource/ResourceDatabase.cpp
trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.cpp
#2524: This submission replaces most areas in the code base where manual null pointer check and throwing of MgNullReferenceException is done with the CHECKNULL macro.
Modified: trunk/MgDev/Common/Foundation/Data/ByteSink.cpp
--- trunk/MgDev/Common/Foundation/Data/ByteSink.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Common/Foundation/Data/ByteSink.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -142,11 +142,7 @@
MgByte* MgByteSink::ToBuffer()
- if (0 == m_reader)
- throw new MgNullReferenceException(L"MgByteSink.ToBuffer",
- __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(m_reader, L"MgByteSink.ToBuffer");
Ptr<MgByte> bytes;
Modified: trunk/MgDev/Common/Foundation/System/ByteSourceStreamImpl.cpp
--- trunk/MgDev/Common/Foundation/System/ByteSourceStreamImpl.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Common/Foundation/System/ByteSourceStreamImpl.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -29,11 +29,7 @@
ByteSourceMgStreamImpl::ByteSourceMgStreamImpl(MgStream* stream)
- if (stream == NULL)
- throw new MgNullReferenceException(L"ByteSourceMgStreamImpl.ByteSourceMgStreamImpl",
+ CHECKARGUMENTNULL(stream, L"ByteSourceMgStreamImpl.ByteSourceMgStreamImpl");
m_stream = SAFE_ADDREF(stream);
Modified: trunk/MgDev/Common/Foundation/System/Util.cpp
--- trunk/MgDev/Common/Foundation/System/Util.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Common/Foundation/System/Util.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -62,16 +62,10 @@
MgObject* MgUtil::CreateMgObject(INT32 classId)
MgClassFactory* factory = MgClassFactory::GetInstance();
- if (NULL == factory)
- throw new MgNullReferenceException(L"CreateMgObject", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(factory, L"MgUtil.CreateMgObject");
MgObject* obj = factory->CreateMgObject(classId);
- if (NULL == obj)
+ CHECKNULL(obj, L"MgUtil.CreateMgObject");
return obj;
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -90,11 +90,7 @@
baseMap = m_layers->GetMap();
- if (NULL == baseMap)
- throw new MgNullReferenceException(L"MgLayer.GetMap",
+ CHECKNULL(baseMap, L"MgLayer.GetMap");
return baseMap;
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -69,11 +69,7 @@
else if (NULL == m_resourceService.p)
- if (NULL == m_siteConnection.p)
- throw new MgNullReferenceException(L"MgMap.InitializeResourceService",
+ CHECKNULL(m_siteConnection.p, L"MgMap.InitializeResourceService");
m_resourceService = dynamic_cast<MgResourceService*>(
m_siteConnection->CreateService(MgServiceType::ResourceService));
@@ -88,11 +84,7 @@
MgService* MgMap::GetService(INT32 serviceType)
- throw new MgNullReferenceException(L"MgMap.GetService",
+ CHECKNULL(m_siteConnection.p, L"MgMap.GetService");
if (MgServiceType::ResourceService == serviceType)
@@ -921,11 +913,7 @@
InitializeResourceService(resourceService);
- if (NULL == m_resId.p)
- throw new MgNullReferenceException(L"MgMap.Save",
+ CHECKNULL(m_resId.p, L"MgMap.Save");
m_inSave = true;
@@ -963,11 +951,7 @@
m_resId = SAFE_ADDREF(resourceId);
m_inSave = true;
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerInformation.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerInformation.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerInformation.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -395,11 +395,7 @@
INT32 MgServerInformation::ToServiceFlags(MgPropertyCollection* hostProps,
INT32 initialFlags)
- if (NULL == hostProps)
- L"MgServerInformation.ToServiceFlags", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKARGUMENTNULL(hostProps, L"MgServerInformation.ToServiceFlags");
INT32 serviceFlags = initialFlags;
Modified: trunk/MgDev/Common/PlatformBase/Services/Resource.cpp
--- trunk/MgDev/Common/PlatformBase/Services/Resource.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Common/PlatformBase/Services/Resource.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -60,8 +60,7 @@
void MgResource::Save(MgResourceService* resourceService)
- if(m_resId == (MgResourceIdentifier*)NULL)
- throw new MgNullReferenceException(L"MgResource.Save", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(m_resId.p, L"MgResource.Save");
SerializeToRepository(resourceService, false);
@@ -71,8 +70,7 @@
void MgResource::Save(MgResourceService* resourceService, MgResourceIdentifier* resourceId)
SerializeToRepository(resourceService, true);
Modified: trunk/MgDev/Server/src/Common/Manager/PackageManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/PackageManager.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Server/src/Common/Manager/PackageManager.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -89,12 +89,7 @@
MgConfiguration* configuration = MgConfiguration::GetInstance();
ACE_ASSERT(NULL != configuration);
- if (NULL == configuration)
- L"MgPackageManager.GetPackagePath",
+ CHECKNULL(configuration, L"MgPackageManager.GetPackagePath");
configuration->GetStringValue(
MgConfigProperties::ResourceServicePropertiesSection,
Modified: trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -281,10 +281,7 @@
MG_LOG_TRACE_ENTRY(L"MgServerManager::GetConfigurationProperties()");
MgConfiguration* pConfiguration = MgConfiguration::GetInstance();
- if (NULL == pConfiguration)
- throw new MgNullReferenceException(L"MgServerManager::GetConfigurationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(pConfiguration, L"MgServerManager::GetConfigurationProperties");
// Retrieve the properties
pProperties = pConfiguration->GetProperties(propertySection);
Modified: trunk/MgDev/Server/src/Core/TimedEventHandler.cpp
--- trunk/MgDev/Server/src/Core/TimedEventHandler.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Server/src/Core/TimedEventHandler.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -47,11 +47,7 @@
MgServerManager* serverManager = MgServerManager::GetInstance();
ACE_ASSERT(NULL != serverManager);
- if (NULL == serverManager)
- throw new MgNullReferenceException(L"MgTimedEventHandler.Create",
+ CHECKNULL(serverManager, L"MgTimedEventHandler.Create");
auto_ptr<MgTimedEventHandler> eventHandler;
bool isSiteServer = serverManager->IsSiteServer();
Modified: trunk/MgDev/Server/src/Services/Drawing/ServerDrawingService.cpp
--- trunk/MgDev/Server/src/Services/Drawing/ServerDrawingService.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Server/src/Services/Drawing/ServerDrawingService.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -435,24 +435,15 @@
piResources = NULL;
- if (0 == pResource)
- throw new MgNullReferenceException(L"MgServerDrawingService.EnumerateLayers", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(pResource, L"MgServerDrawingService.EnumerateLayers");
DWFInputStream* pStream = pResource->getInputStream();
- if (0 == pStream)
+ CHECKNULL(pStream, L"MgServerDrawingService.EnumerateLayers");
size_t nBytes = pStream->available();
char* pBuffer = DWFCORE_ALLOC_MEMORY( char, nBytes );
pStream->read(pBuffer, nBytes);
DWFCORE_FREE_OBJECT(pStream);
- if (0 == pBuffer)
+ CHECKNULL(pBuffer, L"MgServerDrawingService.EnumerateLayers");
// Write the memory buffer to a temporary file
m_tempW2dFileName = MgFileUtil::GenerateTempFileName(false, /*NOXLATE*/ L"MGDS");
@@ -588,24 +579,15 @@
piResources = NULL;
- if (0 == pStream)
- throw new MgNullReferenceException(L"MgServerDrawingService.GetLayer", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(pStream, L"MgServerDrawingService.GetLayer");
- if (0 == pBuffer)
+ CHECKNULL(pBuffer, L"MgServerDrawingService.GetLayer");
Modified: trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.cpp
--- trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -30,10 +30,7 @@
ByteSourceRasterStreamImpl::ByteSourceRasterStreamImpl(FdoIStreamReaderTmpl<FdoByte>* stream)
- throw new MgNullReferenceException(L"ByteSourceRasterStreamImpl", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKARGUMENTNULL(stream, L"ByteSourceRasterStreamImpl.ctor");
m_stream = FDO_SAFE_ADDREF(stream);
Modified: trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp
--- trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -365,22 +365,13 @@
for (int nMapPlotIndex = 0; nMapPlotIndex < mapPlots->GetCount(); nMapPlotIndex++)
Ptr<MgMapPlot> mapPlot = mapPlots->GetItem(nMapPlotIndex);
- if (NULL == mapPlot)
- throw new MgNullReferenceException(L"MgServerMappingService.GenerateMultiPlot", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL((MgMapPlot*)mapPlot, L"MgServerMappingService.GenerateMultiPlot");
Ptr<MgMap> map = mapPlot->GetMap();
- if (NULL == map)
+ CHECKNULL((MgMap*)map, L"MgServerMappingService.GenerateMultiPlot");
Ptr<MgPlotSpecification> plotSpec = mapPlot->GetPlotSpecification();
- if (NULL == plotSpec)
+ CHECKNULL((MgPlotSpecification*)plotSpec, L"MgServerMappingService.GenerateMultiPlot");
Ptr<MgLayout> layout = mapPlot->GetLayout();
@@ -400,17 +391,12 @@
// request extenst
Ptr<MgEnvelope> env = map->GetDataExtent();
- if (env == NULL)
+ CHECKNULL((MgEnvelope*)env, L"MgServerMappingService.GenerateMultiPlot");
Ptr<MgCoordinate> ll = env->GetLowerLeftCoordinate();
Ptr<MgCoordinate> ur = env->GetUpperRightCoordinate();
- if (ll == NULL || ur == NULL)
+ CHECKNULL((MgCoordinate*)ll, L"MgServerMappingService.GenerateMultiPlot");
+ CHECKNULL((MgCoordinate*)ur, L"MgServerMappingService.GenerateMultiPlot");
RS_Bounds b(ll->GetX(), ll->GetY(), ur->GetX(), ur->GetY());
//if requested data extent is not valid, use map definition extent
@@ -418,17 +404,12 @@
if (!b.IsValid())
Ptr<MgEnvelope> env2 = map->GetMapExtent();
- if (env2 == NULL)
+ CHECKNULL((MgEnvelope*)env2, L"MgServerMappingService.GenerateMultiPlot");
Ptr<MgCoordinate> ll2 = env2->GetLowerLeftCoordinate();
Ptr<MgCoordinate> ur2 = env2->GetUpperRightCoordinate();
- if (ll2 == NULL || ur2 == NULL)
+ CHECKNULL((MgCoordinate*)ll2, L"MgServerMappingService.GenerateMultiPlot");
+ CHECKNULL((MgCoordinate*)ur2, L"MgServerMappingService.GenerateMultiPlot");
b.minx = ll2->GetX();
b.miny = ll2->GetY();
@@ -438,10 +419,7 @@
// Create a simple print layout containing only the map
Ptr<MgPrintLayout> printLayout = new MgPrintLayout();
- if (printLayout == NULL)
+ CHECKNULL((MgPrintLayout*)printLayout, L"MgServerMappingService.GenerateMultiPlot");
if (NULL != layout)
@@ -491,10 +469,8 @@
double dMapScale = 0.0;
Ptr<MgCoordinate> center = new MgCoordinateXY(0, 0);
Ptr<MgEnvelope> extents = map->GetMapExtent();
- if (center == NULL || extents == NULL)
+ CHECKNULL((MgCoordinate*)center, L"MgServerMappingService.GenerateMultiPlot");
+ CHECKNULL((MgEnvelope*)extents, L"MgServerMappingService.GenerateMultiPlot");
switch (mapPlot->GetMapPlotInstruction())
@@ -504,10 +480,7 @@
if (dMapScale <= 0)
Ptr<MgEnvelope> extents = map->GetDataExtent();
- if (extents == NULL)
printLayout->ComputeMapOffsetAndSize(dMapScale, extents, metersPerUnit, dr.mapOffsetX(), dr.mapOffsetY(), dr.mapWidth(), dr.mapHeight());
double mapWidth = dr.mapWidth();
double mapHeight = dr.mapHeight();
@@ -539,10 +512,9 @@
//...plotCenter
Ptr<MgCoordinate> plotll = extents->GetLowerLeftCoordinate();
Ptr<MgCoordinate> plotur = extents->GetUpperRightCoordinate();
- if (plotll == NULL || plotur == NULL)
+ CHECKNULL((MgCoordinate*)plotll, L"MgServerMappingService.GenerateMultiPlot");
+ CHECKNULL((MgCoordinate*)plotur, L"MgServerMappingService.GenerateMultiPlot");
double minX = plotll->GetX();
double minY = plotll->GetY();
double maxX = plotur->GetX();
@@ -566,15 +538,9 @@
map->SetViewScale(dMapScale);
center = new MgCoordinateXY(centerX, centerY);
- if (center == NULL)
Ptr<MgPoint> centerpt = new MgPoint(center);
- if (centerpt == NULL)
+ CHECKNULL((MgPoint*)centerpt, L"MgServerMappingService.GenerateMultiPlot");
map->SetViewCenter(centerpt);
break;
@@ -650,10 +616,7 @@
dr.StartMap(&mapInfo, b, dMapScale, dpi, metersPerUnit);
Ptr<MgLayerCollection> layers = map->GetLayers();
- if (layers == NULL)
+ CHECKNULL((MgLayerCollection*)layers, L"MgServerMappingService.GenerateMultiPlot");
// Define a polygon to represent the map extents and fill it with the map background color
dr.StartLayer(NULL, NULL);
@@ -759,16 +722,11 @@
// request extenst
- if (env == NULL)
- if (ll == NULL|| ur == NULL)
// get a temporary file to write out EPlot DWF to
Modified: trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp
--- trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Server/src/Services/Resource/ApplicationRepositoryManager.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -212,16 +212,8 @@
MgResourceHeaderManager* resourceHeaderMan = GetResourceHeaderManager();
- if (NULL == resourceHeaderMan)
- L"MgApplicationRepositoryManager.UpdateRepository",
- else
- resourceHeaderMan->UpdateRepository(resourceInfo, headerDoc);
+ CHECKNULL(resourceHeaderMan, L"MgApplicationRepositoryManager.UpdateRepository");
+ resourceHeaderMan->UpdateRepository(resourceInfo, headerDoc);
// Update the content document.
Modified: trunk/MgDev/Server/src/Services/Resource/RepositoryManager.cpp
--- trunk/MgDev/Server/src/Services/Resource/RepositoryManager.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Server/src/Services/Resource/RepositoryManager.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -664,15 +664,8 @@
- L"MgRepositoryManager.UpdateResource", __LINE__, __WFILE__, NULL, L"", NULL);
- else
- resourceHeaderMan->UpdateResource(resourceInfo, headerDoc);
+ CHECKNULL(resourceHeaderMan, L"MgRepositoryManager.UpdateResource");
+ resourceHeaderMan->UpdateResource(resourceInfo, headerDoc);
Modified: trunk/MgDev/Server/src/Services/Resource/ResourceDatabase.cpp
--- trunk/MgDev/Server/src/Services/Resource/ResourceDatabase.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Server/src/Services/Resource/ResourceDatabase.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -127,11 +127,7 @@
m_db.get_dbname(&fileName, &dbName);
- if (NULL == fileName)
- throw new MgNullReferenceException(L"MgResourceDatabase.GetName",
+ CHECKNULL(fileName, L"MgResourceDatabase.GetName");
name = fileName;
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.cpp
--- trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.cpp 2015-02-03 11:41:32 UTC (rev 8528)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.cpp 2015-02-03 14:30:27 UTC (rev 8529)
@@ -137,10 +137,7 @@
MG_LOG_TRACE_ENTRY(L"MgServerAdminService::ClearLog()");
MgLogManager* pMan = MgLogManager::GetInstance();
- if (NULL == pMan)
- throw new MgNullReferenceException(L"MgServerAdminService::ClearLog", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(pMan, L"MgServerAdminService::ClearLog");
if (log == MgLogFileType::Access)
@@ -231,10 +228,7 @@
MG_LOG_TRACE_ENTRY(L"MgServerAdminService::GetLog()");
- if (NULL == pMan)
- throw new MgNullReferenceException(L"MgServerAdminService::GetLog", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(pMan, L"MgServerAdminService::GetLog");
@@ -293,10 +287,7 @@
- if (NULL == pMan)
@@ -355,10 +346,7 @@
- if (NULL == pMan)
@@ -417,10 +405,7 @@
MG_LOG_TRACE_ENTRY(L"MgServerAdminService::GetLogFile()");
- if (NULL == pMan)
- throw new MgNullReferenceException(L"MgServerAdminService::GetLogFile", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(pMan, L"MgServerAdminService::GetLogFile");
byteReader = pMan->GetLogFile( logFile );
@@ -443,10 +428,7 @@
MG_LOG_TRACE_ENTRY(L"MgServerAdminService::EnumerateLogs()");
- if (NULL == pMan)
logs = pMan->EnumerateLogs();
@@ -469,10 +451,7 @@
MG_LOG_TRACE_ENTRY(L"MgServerAdminService::GetConfigurationProperties()");
MgServerManager* pMan = MgServerManager::GetInstance();
- if (NULL == pMan)
- throw new MgNullReferenceException(L"MgServerAdminService::GetConfigurationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(pMan, L"MgServerAdminService::GetConfigurationProperties");
pProperties = pMan->GetConfigurationProperties(propertySection);
@@ -492,10 +471,7 @@
MG_LOG_TRACE_ENTRY(L"MgServerAdminService::SetConfigurationProperties()");
- if (NULL == pMan)
- throw new MgNullReferenceException(L"MgServerAdminService::SetConfigurationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(pMan, L"MgServerAdminService::SetConfigurationProperties");
pMan->SetConfigurationProperties(propertySection, properties);
@@ -514,10 +490,7 @@
- if (NULL == pMan)
pMan->RemoveConfigurationProperties(propertySection, properties);
@@ -538,10 +511,7 @@
MG_LOG_TRACE_ENTRY(L"MgServerAdminService::GetInformationProperties()");
- if (NULL == pMan)
- throw new MgNullReferenceException(L"MgServerAdminService::GetInformationProperties", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(pMan, L"MgServerAdminService::GetInformationProperties");
pProperties = pMan->GetInformationProperties();
@@ -563,10 +533,7 @@
MG_LOG_TRACE_ENTRY(L"MgServerAdminService::GetSiteVersion()");
- if (NULL == pMan)
- throw new MgNullReferenceException(L"MgServerAdminService::GetSiteVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(pMan, L"MgServerAdminService::GetSiteVersion");
version = pMan->GetSiteVersion();
@@ -589,10 +556,7 @@
MG_LOG_TRACE_ENTRY(L"MgServerAdminService::GetSiteStatus()");
- if (NULL == pMan)
- throw new MgNullReferenceException(L"MgServerAdminService::GetSiteStatus", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(pMan, L"MgServerAdminService.GetSiteStatus");
pProperties = pMan->GetSiteStatus();
@@ -995,10 +959,7 @@
MG_LOG_TRACE_ENTRY(L"MgServerAdminService::SetDocument()");
- if (NULL == pMan)
- throw new MgNullReferenceException(L"MgServerAdminService::SetDocument", __LINE__, __WFILE__, NULL, L"", NULL);
+ CHECKNULL(pMan, L"MgServerAdminService::SetDocument");
pMan->SetDocument(identifier, data);
More information about the mapguide-commits
