[mapguide-commits] r8531 - trunk/MgDev
svn_mapguide at osgeo.org
Wed Feb 4 06:02:07 PST 2015
Author: jng
Date: 2015-02-04 06:02:07 -0800 (Wed, 04 Feb 2015)
New Revision: 8531
trunk/MgDev/run_tests.bat
#2533: Support the built-in PHP web server option and allow specifying the server test scope.
Modified: trunk/MgDev/run_tests.bat
--- trunk/MgDev/run_tests.bat 2015-02-04 13:42:08 UTC (rev 8530)
+++ trunk/MgDev/run_tests.bat 2015-02-04 14:02:07 UTC (rev 8531)
@@ -35,6 +35,8 @@
if "%1"=="-wp" goto get_webserverport
+if "%1"=="-sts" goto get_servertestscope
if "%1"=="-p" goto get_platform
if "%1"=="-platform" goto get_platform
@@ -80,6 +82,10 @@
SET SERVER_PORT=%2
goto next_param
+:get_servertestscope
+SET SERVER_TEST_SCOPE=%2
+goto next_param
:get_test
SET TEST_SUITE=%2
if "%2"=="server" goto next_param
@@ -118,12 +124,19 @@
echo CS-Map Path: %CS_MAP_PATH%
echo Web Server Name: %SERVER_ADDR%
echo Web Server Port: %SERVER_PORT%
+echo Server Test Scope: %SERVER_TEST_SCOPE%
echo ********* Paths to check ***********************
echo PHP executable %WEB_ROOT%\..\Php\php.exe
echo .net Assemblies %WEB_ROOT%\mapviewernet\bin
echo Java jars %WEB_ROOT%\WEB-INF\lib
echo ************************************************
+SET WEBCONFIGINI=%WEB_ROOT%\webconfig.ini
SET PATH=%WEB_ROOT%\..\Php;%PATH%
+if "%PHP_WEB_SERVER%" == "1" (
+ echo [prepare]: Starting PHP web server. Waiting %MGSERVER_WAIT%s
+ start php -n -d display_errors=Off -d upload_max_filesize=20M -d extension_dir="%PHP_EXT_DIR%" -d extension=php_mbstring.dll -d extension=php_curl.dll -d extension=php_MapGuideApi.dll -S %SERVER_ADDR%:%SERVER_PORT% -t "%CURRENT_DIR%\UnitTest\WebTier\MapAgent\MapAgentForms" "%CURRENT_DIR%\UnitTest\WebTier\Php\MapAgentShim\index.php"
+ ping -n %MGSERVER_WAIT% 127.0.0.1 > NUL
:check_dotnet
echo [check]: .net
if not exist "%WEB_ROOT%\mapviewernet\bin\*.dll" goto no_dotnet
@@ -342,6 +355,11 @@
SET ERRORMSG=
SET PATH=%OLDPATH%
popd
+ echo [cleanup]: Terminating PHP web server
+ REM We're naturally assuming the only php.exe that is running is the one this script started
+ taskkill /im php.exe
exit /B 1
:custom_error
@@ -356,6 +374,7 @@
echo [-m=MapAgent]
echo [-w=WebRoot]
echo [-s=ServerPath]
+echo [-sts=ServerTestScope]
echo [-ws=WebServerName]
echo [-wp=WebServerPort]
echo [-iw=UsePHPWebServer]
@@ -377,4 +396,9 @@
:quit
SET PATH=%OLDPATH%
SET TYPEACTION=
popd
\ No newline at end of file
More information about the mapguide-commits
