[mapguide-commits] r8534 - trunk/MgDev
svn_mapguide at osgeo.org
Thu Feb 5 03:46:41 PST 2015
Author: jng
Date: 2015-02-05 03:46:41 -0800 (Thu, 05 Feb 2015)
New Revision: 8534
trunk/MgDev/run_tests.bat
#2533: Fix incorrect parameter order for taskkill.exe invocations
Modified: trunk/MgDev/run_tests.bat
--- trunk/MgDev/run_tests.bat 2015-02-05 10:33:32 UTC (rev 8533)
+++ trunk/MgDev/run_tests.bat 2015-02-05 11:46:41 UTC (rev 8534)
@@ -254,7 +254,7 @@
if exist "%SERVER_PATH%" (
echo [test]: Terminating mgserver.exe
REM We're naturally assuming the only mgserver.exe that is running is the one this script started
- taskkill /im /f mgserver.exe
+ taskkill /f /im mgserver.exe
if "%TEST_SUITE%" == "php" goto quit
:test_dotnet
@@ -307,7 +307,7 @@
if "%TEST_SUITE%" == "dotnet" goto quit
:test_java
@@ -346,7 +346,7 @@
if "%TEST_SUITE%" == "all" goto quit
if "%TEST_SUITE%" == "java" goto quit
@@ -363,7 +363,7 @@
if "%PHP_WEB_SERVER%" == "1" (
echo [cleanup]: Terminating PHP web server
REM We're naturally assuming the only php.exe that is running is the one this script started
- taskkill /im /f php.exe
+ taskkill /f /im php.exe
exit /B 1
@@ -404,6 +404,6 @@
popd
\ No newline at end of file
More information about the mapguide-commits
