[mapguide-commits] r8554 - trunk/Tools/Vagrant/scripts
svn_mapguide at osgeo.org
Fri Feb 27 06:08:13 PST 2015
Author: jng
Date: 2015-02-27 06:08:13 -0800 (Fri, 27 Feb 2015)
New Revision: 8554
Added:
trunk/Tools/Vagrant/scripts/build.ps1
Add initial cut of powershell build script for Windows. The motivation for a powershell version of the Windows build scripts is to allow for applying the same vagrant build workflow (copy scripts / vagrant up / check back a few hours later) for windows-based vagrant configurations (yet to be checked in). Windows-based vagrantfiles use powershell for shell-based provisioning which necessitates a powershell-based build process for MapGuide and FDO.
Added: trunk/Tools/Vagrant/scripts/build.ps1
--- trunk/Tools/Vagrant/scripts/build.ps1 (rev 0)
+++ trunk/Tools/Vagrant/scripts/build.ps1 2015-02-27 14:08:13 UTC (rev 8554)
@@ -0,0 +1,993 @@
+.SYNOPSIS
+ Builds the MapGuide Open Source codebase
+.DESCRIPTION
+ This PowerShell script will build the entire MapGuide Open Source codebase, which consists of
+ - Oem components
+ - Server tier
+ - Web tier
+ - Documentation
+ - Windows Installer
+ - mg-desktop
+ This script requires PowerShell Community Extensions installed
+.EXAMPLE
+ C:\PS> .\build.ps1 -platform x64 -build_root 'D:\mg-trunk\MgDev' -java_home 'C:\Program Files\Java\jdk1.7.0_71' -output '.\Release64'
+ Build the full source (located at D:\mg-trunk\MgDev) for 64-bit using the JDK at (C:\Program Files\Java\jdk1.7.0_71). The build output will be at (.\Release64)
+.EXAMPLE
+ C:\PS> .\build.ps1 -platform x86 -build_root 'D:\mg-trunk\MgDev' -java_home 'C:\Program Files (x86)\Java\jdk1.7.0_71' -output '.\Release'
+ Build the full source (located at D:\mg-trunk\MgDev) for 32-bit using the JDK at (C:\Program Files (x86)\Java\jdk1.7.0_71). The build output will be at (.\Release64)
+.LINK
+ Project Home: http://mapguide.osgeo.org
+ PowerShell Community Extensions: https://pscx.codeplex.com/
+.NOTES
+ Author: Jackie Ng
+param (
+ [Parameter(HelpMessage = "The CPU platform to build for")]
+ [ValidateSet("x86", "x64")]
+ [Alias("p")]
+ [string]
+ $platform = "x86",
+ [Parameter(HelpMessage = "The build configuration to build for")]
+ [ValidateSet("Debug", "Release")]
+ [Alias("c")]
+ [string]
+ $config = "Release",
+ [Parameter(HelpMessage = "The action to perform")]
+ [ValidateSet("build", "install", "buildinstall", "clean", "installprepare")]
+ [Alias("a")]
+ [string]
+ $action = "buildinstall",
+ [Parameter(HelpMessage = "The components to build")]
+ [ValidateSet("all", "oem", "server", "web", "installer", "desktop", "doc")]
+ [Alias("w")]
+ [string]
+ $component = "all",
+ [Parameter(HelpMessage = "The directory where compiled binaries will be copied to. If relative, the path will be relative to the build root")]
+ [Alias("o")]
+ [string]
+ $output = ".\Release",
+ [Parameter(HelpMessage = "The directory where the MapGuide source resides in")]
+ [string]
+ $build_root = ".\",
+ [Parameter(HelpMessage = "The directory where the MapGuide Installer source resides in")]
+ [string]
+ $install_root = "..\Installer",
+ [Parameter(HelpMessage = "The path to the Java SDK required for building the Java API bindings. If not specified, the value of the JAVA_HOME environment variable will be used")]
+ [Alias("j")]
+ [string]
+ $java_home = "",
+ [string]
+ $doxygen_path = "C:\Program Files\doxygen\bin",
+ [string]
+ $ant_path = "C:\apache-ant\bin",
+ [string]
+ $graphviz_path = "C:\Program Files (x86)\Graphviz2.30\bin",
+ [string]
+ $log_path = ".\logs",
+ [int]
+ $major = 3,
+ [int]
+ $minor = 0,
+ [int]
+ $build = 0,
+ [int]
+ $svnrev = 0,
+ [string]
+ $label = "Release"
+Function EnvSetup([string]$plat, [string]$phpVer, [string]$apacheVer)
+ Try
+ pushd .\Oem\LinuxApt
+ # If any of these files don't exist, we unpack the httpd source
+ $apacheParts = @(
+ "include",
+ "include\httpd.h",
+ "include\http_config.h",
+ "include\ap_config.h",
+ "include\http_log.h",
+ "include\http_protocol.h",
+ "include\http_main.h",
+ "include\util_script.h",
+ "include\http_core.h",
+ "include\apr_strings.h",
+ "include\apr_tables.h"
+ # If any of these files don't exist, we unpack the php source
+ $phpParts = @(
+ "ext",
+ "ext\standard",
+ "ext\standard\info.h",
+ "main",
+ "main\php.h",
+ "main\php_ini.h",
+ "main\config.w32.h",
+ "main\win95nt.h",
+ "TSRM",
+ "TSRM\readdir.h",
+ "Zend",
+ "Zend\zend.h",
+ "Zend\zend_exceptions.h",
+ "Zend\zend_API.h"
+ Write-Host "Checking if we need to unpack httpd source"
+ foreach ($part in $apacheParts) {
+ $path = [System.IO.Path]::Combine(".\httpd-$apacheVer", $part)
+ if (-Not(Test-Path $path)) {
+ if (-Not(Test-Path "httpd-$apacheVer.tar")) {
+ & sz x "httpd-$apacheVer.tar.bz2"
+ & sz x -y "httpd-$apacheVer.tar"
+ break
+ Write-Host "Checking if we need to unpack php source"
+ foreach ($part in $phpParts) {
+ $path = [System.IO.Path]::Combine(".\php-$phpVer", $part)
+ if (-Not(Test-Path "php-$phpVer.tar")) {
+ & sz x "php-$phpVer.tar.bz2"
+ & sz x -y "php-$phpVer.tar"
+ break
+ Write-Host "Patching PHP headers for Windows"
+ Copy-Item -Force -Path "..\php\main\*.h" "php-$phpVer\main"
+ Copy-Item -Force -Path "..\php\TSRM\*.h" "php-$phpVer\TSRM"
+ Write-Host "Patching HTTPD headers for Windows"
+ Copy-Item -Force -Path "..\httpd\include\*.h" "httpd-$apacheVer\include"
+ Finally
+ popd
+Function CheckStatus([string]$action, [int]$status)
+ Write-Host "Status for action ($action) is: $status"
+ if (-Not $status) {
+ $msg = "Action ($action) failed"
+ throw $msg
+Function MsBuildAction([string]$comp, [string]$conf, [string]$plat, [string]$action)
+ $uplat = $plat
+ # x86 has to be coerced to Win32
+ if ($plat.Equals("x86")) {
+ $uplat = "Win32"
+ $solutions = @{
+ "oem" = ".\Oem\oem.sln";
+ "csmap" = ".\Oem\CsMap\VC110\OpenSource.sln";
+ "server" = ".\Server\Server.sln";
+ "web" = ".\Web\src\WebTier.sln";
+ "desktop" = ".\Desktop\MgDesktopApi.sln";
+ "desktop_viewer" = ".\Desktop\MgDesktopDotNet.sln";
+ #$msbParams = "/m /p:Configuration=$conf;Platform=$plat /v:n /t:$action"
+ Write-Host "Action ($action) on $comp ($conf|$plat)"
+ switch ($comp) {
+ "oem" {
+ msbuild /m /p:Configuration=$conf /p:Platform=$uplat /v:n /t:$action $solutions["oem"]
+ CheckStatus "$action $comp" $LASTEXITCODE
+ msbuild /m /p:Configuration=$conf /p:Platform=$uplat /v:n /t:$action $solutions["csmap"]
+ "server" {
+ msbuild /m /p:Configuration=$conf /p:Platform=$uplat /v:n /t:$action $solutions["server"]
+ "web" {
+ msbuild /m /p:Configuration=$conf /p:Platform=$uplat /v:n /t:$action $solutions["web"]
+ "desktop" {
+ msbuild /m /p:Configuration=$conf /p:Platform=$uplat /v:n /t:$action $solutions["desktop"]
+ msbuild /m /p:Configuration=$conf /p:Platform=$plat /v:n /t:$action $solutions["desktop_viewer"]
+ "installer" {
+ $installerName="MapGuideOpenSource-$major.$minor.$build.$svnrev-$label-$plat";
+ $installerCulture="en-US";
+ $installerTitle="MapGuide Open Source $major.$minor.$build ($label - $plat)";
+ $installerVersion="$major.$minor.$build";
+ $installerRegKey="Software\OSGeo\MapGuide\$major.$minor.$build.$svnrev";
+ $installerArcSde="no";
+ if (Test-Path ("$output\Server\FDO\ArcSdeProvider.dll")) {
+ $installerArcSde="yes";
+ Write-Host "============ Installer Summary ================="
+ Write-Host "Name: $installerName"
+ Write-Host "Culture: $installerCulture"
+ Write-Host "Title: $installerTitle"
+ Write-Host "Version: $installerVersion"
+ Write-Host "Reg Key: $installerRegKey"
+ Write-Host "ArcSDE?: $installerArcSde"
+ Write-Host "================================================"
+ Try {
+ pushd $installerSrcRoot
+ Write-Host "Entering $installerSrcRoot"
+ $wix_server="$installerSrcRoot\Libraries\MapGuide Server\FileIncludes"
+ $wix_web="$installerSrcRoot\Libraries\MapGuide Web Extensions\FileIncludes"
+ $wix_csmap="$installerSrcRoot\Libraries\CS Map\FileIncludes"
+ # These paraffin mappings are to be process flat (-norecurse)
+ $flatMappings = @(
+ "desc" = "Server - binaries";
+ "dirPart" = "Server\bin";
+ "custom" = "SRVBINFILES";
+ "dirref" = "SERVERROOTLOCATION";
+ "output" = "$wix_server\incBinFiles.wxs";
+ "desc" = "Server - RepositoryAdmin";
+ "dirPart" = "Server\RepositoryAdmin";
+ "custom" = "SRVREPADMINFILES";
+ "output" = "$wix_server\incRepositoryAdminFiles.wxs";
+ "desc" = "Server - resources";
+ "dirPart" = "Server\Resources";
+ "custom" = "SRVRESOURCESFILES";
+ "output" = "$wix_server\incResourcesFiles.wxs";
+ "desc" = "Server - Schema";
+ "dirPart" = "Server\Schema";
+ "custom" = "SRVSCHEMAFILES";
+ "output" = "$wix_server\incSchemaFiles.wxs";
+ "desc" = "Server - wms";
+ "dirPart" = "Server\wms";
+ "custom" = "SRVWMSFILES";
+ "output" = "$wix_server\incWmsFiles.wxs";
+ "desc" = "Server - wfs";
+ "dirPart" = "Server\wfs";
+ "custom" = "SRVWFSFILES";
+ "output" = "$wix_server\incWfsFiles.wxs";
+ "desc" = "Web - wwwroot";
+ "dirPart" = "Web\www";
+ "custom" = "WEBROOTFILES";
+ "dirref" = "WEBEXTENSIONSLOCATION";
+ "output" = "$wix_web\incWebRootFiles.wxs";
+ # These paraffin mappings are to be processed recursively
+ $recurseMappings = @(
+ "desc" = "CS-Map - dictionaries";
+ "dirPart" = "CS-Map\Dictionaries";
+ "custom" = "CSMAPDICTFILES";
+ "dirref" = "CSMAPLOCATION";
+ "output" = "$wix_csmap\incCSMapDictionaryFiles.wxs";
+ "desc" = "Web - Apache";
+ "dirPart" = "Web\Apache24";
+ "custom" = "APACHEFILES";
+ "output" = "$wix_web\incApacheFiles.wxs";
+ "desc" = "Web - Php TS";
+ "dirPart" = "Web\Php";
+ "custom" = "PHPFILES";
+ "output" = "$wix_web\incPhpFiles.wxs";
+ "desc" = "Web - Tomcat";
+ "dirPart" = "Web\Tomcat";
+ "custom" = "TOMCATFILES";
+ "output" = "$wix_web\incTomcatFiles.wxs";
+ "desc" = "Web - Help";
+ "dirPart" = "Web\www\help";
+ "custom" = "HELPFILES";
+ "dirref" = "WEBROOTLOCATION";
+ "output" = "$wix_web\incHelpFiles.wxs";
+ "desc" = "Web - DevGuide Samples (PHP)";
+ "dirPart" = "Web\www\phpsamples";
+ "custom" = "PHPDEVGUIDEFILES";
+ "output" = "$wix_web\incPhpDevGuideFiles.wxs";
+ "desc" = "Web - DevGuide Samples (Java)";
+ "dirPart" = "Web\www\javasamples";
+ "custom" = "JAVADEVGUIDEFILES";
+ "output" = "$wix_web\incJavaDevGuideFiles.wxs";
+ "desc" = "Web - DevGuide Samples (.net)";
+ "dirPart" = "Web\www\dotnetsamples";
+ "custom" = "DOTNETDEVGUIDEFILES";
+ "output" = "$wix_web\incDotNetDevGuideFiles.wxs";
+ "desc" = "Web - Viewer Samples (PHP)";
+ "dirPart" = "Web\www\phpviewersample";
+ "custom" = "PHPVIEWERSAMPLEFILES";
+ "output" = "$wix_web\incPhpViewerSampleFiles.wxs";
+ "desc" = "Web - Viewer Samples (Java)";
+ "dirPart" = "Web\www\javaviewersample";
+ "custom" = "JAVAVIEWERSAMPLEFILES";
+ "output" = "$wix_web\incJavaViewerSampleFiles.wxs";
+ "desc" = "Web - Viewer Samples (.net)";
+ "dirPart" = "Web\www\dotnetviewersample";
+ "custom" = "DOTNETVIEWERSAMPLEFILES";
+ "output" = "$wix_web\incDotNetViewerSampleFiles.wxs";
+ "desc" = "Web - OpenLayers Samples";
+ "dirPart" = "Web\www\ol2samples";
+ "custom" = "OPENLAYERSSAMPLEFILES";
+ "output" = "$wix_web\incOpenLayersSampleFiles.wxs";
+ "desc" = "Web - mapagent";
+ "dirPart" = "Web\www\mapagent";
+ "custom" = "MAPAGENTFILES";
+ "output" = "$wix_web\incMapAgentFiles.wxs";
+ "desc" = "Web - mapviewernet";
+ "dirPart" = "Web\www\mapviewernet";
+ "custom" = "MAPVIEWERASPXFILES";
+ "output" = "$wix_web\incMapViewerAspxFiles.wxs";
+ "desc" = "Web - mapviewerphp";
+ "dirPart" = "Web\www\mapviewerphp";
+ "custom" = "MAPVIEWERPHPFILES";
+ "output" = "$wix_web\incMapViewerPhpFiles.wxs";
+ "desc" = "Web - mapviewerjava";
+ "dirPart" = "Web\www\mapviewerjava";
+ "custom" = "MAPVIEWERJSPFILES";
+ "output" = "$wix_web\incMapViewerJspFiles.wxs";
+ "desc" = "Web - fusion";
+ "dirPart" = "Web\www\fusion";
+ "custom" = "FUSIONFILES";
+ "output" = "$wix_web\incFusionFiles.wxs";
+ "desc" = "Web - viewerfiles";
+ "dirPart" = "Web\www\viewerfiles";
+ "custom" = "MAPVIEWERFILES";
+ "output" = "$wix_web\incMapViewerFiles.wxs";
+ "desc" = "Web - stdicons";
+ "dirPart" = "Web\www\stdicons";
+ "custom" = "MAPVIEWERSTDICONFILES";
+ "output" = "$wix_web\incMapViewerStdiconFiles.wxs";
+ "desc" = "Web - schemareport";
+ "dirPart" = "Web\www\schemareport";
+ "custom" = "MAPVIEWERSCHEMAREPORTFILES";
+ "output" = "$wix_web\incMapViewerSchemareportFiles.wxs";
+ "desc" = "Web - mapadmin";
+ "dirPart" = "Web\www\mapadmin";
+ "custom" = "MAPVIEWERMAPADMINFILES";
+ "output" = "$wix_web\incMapViewerMapAdminFiles.wxs";
+ "desc" = "Web - localized";
+ "dirPart" = "Web\www\localized";
+ "custom" = "MAPVIEWERLOCALIZEDFILES";
+ "output" = "$wix_web\incMapViewerLocalizedFiles.wxs";
+ "desc" = "Web - WEB-INF";
+ "dirPart" = "Web\www\WEB-INF";
+ "custom" = "WEBINFFILES";
+ "output" = "$wix_web\incWebInfFiles.wxs";
+ if ($plat.Equals("x64")) {
+ foreach ($map in $flatMappings) {
+ Write-Host ("Generating: " + $map["desc"])
+ if (-Not (Test-Path ("$output\" + $map["dirPart"]))) {
+ throw ("No such directory " + ("$output\" + $map["dirPart"]))
+ .\Paraffin.exe -Win64 -guids -dir ("$output\" + $map["dirPart"]) -alias ('$(var.MgSource)\' + $map["dirPart"]) -custom $map["custom"] -dirref $map["dirref"] -norecurse ($map["output"])
+ foreach ($map in $recurseMappings) {
+ .\Paraffin.exe -Win64 -guids -dir ("$output\" + $map["dirPart"]) -alias ('$(var.MgSource)\' + $map["dirPart"]) -custom $map["custom"] -dirref $map["dirref"] ($map["output"])
+ } else {
+ .\Paraffin.exe -guids -dir ("$output\" + $map["dirPart"]) -alias ('$(var.MgSource)\' + $map["dirPart"]) -custom $map["custom"] -dirref $map["dirref"] -norecurse ($map["output"])
+ .\Paraffin.exe -guids -dir ("$output\" + $map["dirPart"]) -alias ('$(var.MgSource)\' + $map["dirPart"]) -custom $map["custom"] -dirref $map["dirref"] ($map["output"])
+ msbuild /m /p:Configuration=$conf /p:Platform=$plat /v:n /t:$action "/p:OutputName=$installerName;MgSource=$output;MgCulture=$installerCulture;MgTitle=$installerTitle;MgVersion=$installerVersion;MgRegKey=$installerRegKey;MgPlatform=$plat;Have_ArcSde=$installerArcSde" InstallerWix.sln
+ Copy-Item "Bootstrapper\vcredist_2012_$plat.exe" -Destination "Output\$installerCulture\vcredist_2012_$plat.exe" -Force
+ } Finally {
+ popd
+ Try {
+ pushd $installerSrcRoot\Bootstrapper
+ Write-Host "Entering $installerSrcRoot\Bootstrapper"
+ makensis /DMAXCOMPRESSION /DCPU=$plat /DINSTALLER_ROOT=$installerSrcRoot "/DNSISDIR=$installerSrcRoot\Support\NSIS" /DOUTNAME=$installerName /DCULTURE=$installerCulture "/DMG_VERSION=$major.$minor.$build.$svnrev" Setup.nsi
+ } Finally {
+ popd
+ "doc" {
+ Try {
+ pushd "Doc"
+ MakeDirIfNotExists "MgOpensource_WebAPIReference"
+ Copy-Item -Path "css\doxygen.css" -Destination "MgOpensource_WebAPIReference" -Force
+ MakeDirIfNotExists "MgOpensource_WebAPIReference\xml_schemas"
+ Copy-Item -Path "xml_schemas\*" -Destination "MgOpensource_WebAPIReference\xml_schemas" -Force -Recurse
+ doxygen MgOpenSource_Doxyfile | Tee-Object MGOpenSource_run_log.txt
+ perl -w PostProcessor/post_process.MgOpenSource.pl
+ } Finally {
+ popd
+ Try {
+ pushd "Doc\devguide"
+ Invoke-BatchFile make.bat html
+ } Finally {
+ popd
+ Try {
+ pushd "UnitTest\TestData\Samples\Sheboygan"
+ if (Test-Path "Sheboygan.mgp") {
+ Remove-Item -Force "Sheboygan.mgp"
+ Copy-Item -Path "..\..\FeatureService\SDF\Sheboygan_BuildingOutlines.sdf" -Destination "Library\Samples\Sheboygan\Data\BuildingOutlines.FeatureSource_DATA_BuildingOutlines.sdf" -Force
+ Copy-Item -Path "..\..\FeatureService\SDF\Sheboygan_CityLimits.sdf" -Destination "Library\Samples\Sheboygan\Data\CityLimits.FeatureSource_DATA_CityLimits.sdf" -Force
+ Copy-Item -Path "..\..\FeatureService\SDF\Sheboygan_Parcels.sdf" -Destination "Library\Samples\Sheboygan\Data\Parcels.FeatureSource_DATA_CityLimits.sdf" -Force
+ Copy-Item -Path "..\..\FeatureService\SDF\Sheboygan_VotingDistricts.sdf" -Destination "Library\Samples\Sheboygan\Data\VotingDistricts.FeatureSource_DATA_CityLimits.sdf" -Force
+ Copy-Item -Path "..\..\MappingService\UT_HydrographicPolygons.sdf" -Destination "Library\Samples\Sheboygan\Data\HydrographicPolygons.FeatureSource_DATA_CityLimits.sdf" -Force
+ Copy-Item -Path "..\..\MappingService\UT_Rail.sdf" -Destination "Library\Samples\Sheboygan\Data\Rail.FeatureSource_DATA_CityLimits.sdf" -Force
+ Copy-Item -Path "..\..\TileService\UT_RoadCenterLines.sdf" -Destination "Library\Samples\Sheboygan\Data\RoadCenterLines.FeatureSource_DATA_CityLimits.sdf" -Force
+ & sz a -tzip Sheboygan.mgp Library/ MgResourcePackageManifest.xml
+ } Finally {
+ popd
+ "all" {
+ foreach ($sln in $solutions.GetEnumerator())
+ if ($sln.Key -eq "desktop_viewer") {
+ msbuild /m /p:Configuration=$conf /p:Platform=$plat /v:n /t:$action $sln.Value
+ } else {
+ msbuild /m /p:Configuration=$conf /p:Platform=$uplat /v:n /t:$action $sln.Value
+ CheckStatus ("$action " + $sln.Key) $LASTEXITCODE
+ #$status = Invoke-MsBuild -Path $sln.Value -ShowBuildWindow -MsBuildParameters $msbParams
+ #CheckStatus ("Building " + $sln.Key) $status
+Function BuildAction([string]$comp, [string]$conf, [string]$plat)
+ MsBuildAction $comp $conf $plat "Build"
+Function CleanAction([string]$comp, [string]$conf, [string]$plat)
+ MsBuildAction $comp $conf $plat "Clean"
+Function MakeDirIfNotExists([string]$dir) {
+ if (-Not(Test-Path $dir)) {
+ New-Item -ItemType directory -Path $dir
+Function InstallAction([string]$comp, [string]$conf, [string]$plat, [string]$outDir)
+ Write-Host "Installing $comp ($conf|$plat) to $outDir"
+ MakeDirIfNotExists $outDir
+ $typebuild = $conf
+ $typebuild += "64"
+ $exclude = @(".svn\*", "_svn\*", "Logs", "Packages", "Repositories", "Temp", "*.c", "OSTN02.txt", "OSTN97.txt", "cs-map.*", "*.par", "*.mrt", "*.asc", "Compiler.mak", "Compiler.nmk", "UnitTestResults.xml")
+ if ($conf.Equals("Release")) {
+ $exclude += "*.pdb"
+ $exclude += "*.exp"
+ $exclude += "*.lib"
+ switch ($comp) {
+ "server" {
+ $mappings = @{
+ "Server\bin\$typebuild\*" = "Server";
+ "Server\RepositoryAdmin\*" = "Server\RepositoryAdmin";
+ "Oem\CsMap\Dictionaries\*" = "CS-Map\Dictionaries";
+ $mappings.Add("Oem\dbxml\bin64\$conf\*.exe", "Server\bin");
+ } else {
+ $mappings.Add("Oem\dbxml\bin\$conf\*.exe", "Server\bin");
+ foreach ($map in $mappings.GetEnumerator()) {
+ $key = $map.Key
+ $value = $map.Value
+ if (-Not ($map.Value -is [array])) {
+ $value = @($map.Value)
+ foreach ($val in $value) {
+ $outPath = [System.IO.Path]::Combine($outDir, $val)
+ MakeDirIfNotExists $outPath
+ Copy-Item ($key) -Destination "$outPath" -Recurse -Force -Exclude $exclude
+ $outPath = [System.IO.Path]::Combine($outDir, "Server\bin")
+ $srcPath = [System.IO.Path]::Combine($outDir, "Server", "*.*")
+ Move-Item -Path "$srcPath" -Destination "$outPath" -Force
+ "web" {
+ $mappings = @{
+ "Web\src\localized\*" = "Web\www\localized";
+ "Web\src\mapadmin\*" = "Web\www\mapadmin";
+ "Web\src\stdicons\*" = "Web\www\stdicons";
+ "Web\src\viewerfiles\*" = "Web\www\viewerfiles";
+ "Web\src\schemareport\*" = "Web\www\schemareport";
+ "Web\src\mapviewerphp\*" = "Web\www\mapviewerphp";
+ "Web\src\mapviewernet\*" = "Web\www\mapviewernet";
+ "Web\src\mapagent\*" = "Web\www\mapagent";
+ "Web\bin\$typebuild\OSGeo.MapGuide.*" = @(
+ "Web\www\mapviewernet\bin",
+ "Web\www\dotnetsamples\bin",
+ "Web\www\dotnetviewersample\bin"
+ "Web\bin\$typebuild\Mg*.dll" = @(
+ "Web\www\mapagent",
+ "Web\Php",
+ "Web\Php\ext",
+ "Web\Tomcat\bin",
+ "Web\bin\$typebuild\ACE.dll" = @(
+ "Web\Php",
+ "Web\Tomcat\bin",
+ "Web\bin\$typebuild\GEOS.dll" = @(
+ "Web\Php",
+ "Web\Php\ext",
+ "Web\Tomcat\bin",
+ "Web\bin\$typebuild\lib_json.dll" = @(
+ "Web\Php",
+ "Web\Php\ext",
+ "Web\Tomcat\bin",
+ "Web\bin\$typebuild\MapGuideJavaApi*" = "Web\Tomcat\bin";
+ "Web\bin\$typebuild\*UnmanagedApi.dll" = "Web\www\mapviewernet\bin";
+ "Web\bin\$typebuild\xerces*.dll" = @(
+ "Web\Php",
+ "Web\Php\ext",
+ "Web\src\mapviewerjava\*" = "Web\www\mapviewerjava";
+ "Web\src\WEB-INF\*" = "Web\www\WEB-INF";
+ $mappings.Add("Web\src\mapagent64\isapi_MapAgent*", "Web\www\mapagent");
+ $mappings.Add("Web\src\mapagent64\mapagent*", "Web\www\mapagent");
+ $mappings.Add("Web\src\mapagent64\mod_mgmapagent*", "Web\Apache24\modules");
+ } else {
+ $mappings.Add("Web\src\mapagent\isapi_MapAgent*", "Web\www\mapagent");
+ $mappings.Add("Web\src\mapagent\mapagent*", "Web\www\mapagent");
+ $mappings.Add("Web\src\mapagent\mod_mgmapagent*", "Web\Apache24\modules");
+ $key = $map.Key
+ # Fusion
+ MakeDirIfNotExists "$outDir\Web\www\fusion"
+ Try {
+ pushd "Oem\fusion"
+ ant clean -f build.xml
+ ant docs -f build.xml
+ ant deploy -f build.xml "-Ddeploy.home=$outDir\Web\www\fusion"
+ ant selfbuild -f build.xml "-Dselfbuild.home=$outDir\fusion-selfbuild"
+ } Finally {
+ popd
+ # Fusion templates
+ Copy-Item "Oem\fusionMG\*" -Destination "$outDir\Web\www\fusion" -Recurse -Force -Exclude $exclude
+ "doc" {
+ $mappings = @{
+ "Doc\MgOpensource_WebAPIReference\*" = "Web\www\help\webapi";
+ "Doc\devguide\build\html\*" = "Web\www\help\devguide";
+ "Doc\samples\*" = "Web\www";
+ "Doc\viewerapi\*" = "Web\www\help\viewerapi";
+ "UnitTest\TestData\Samples\Sheboygan\Sheboygan.mgp" = "";
+ $key = $map.Key
+ "desktop" {
+ $exclude += "Backup"
+ $exclude += "MgMapGuideCommon*"
+ $exclude += "OSGeo.MapGuide.Commmon*"
+ $mappings = @{
+ "Desktop\bin\$typebuild\*" = "mg-desktop\Desktop";
+ "Desktop\Samples\*" = "mg-desktop\DesktopSamples";
+ $key = $map.Key
+Function PrepareInstallerStagingArea([string]$output, [string]$conf, [string]$plat, [string]$installerSupport, [string]$buildRoot, [string]$phpDist, [string]$apacheDist, [string]$tomcatDist)
+ $uplat = $plat
+ $uplat = "Win32"
+ Write-Host "Preparing staging area at: $output"
+ # Put our Apache/Tomcat/PHP binaries into the output
+ MakeDirIfNotExists $output
+ MakeDirIfNotExists "$output\Web\Php"
+ MakeDirIfNotExists "$output\Web\Tomcat"
+ MakeDirIfNotExists "$output\Web\Apache24"
+ & sz x $apacheDist -y "-o$output\Web"
+ & sz x $phpDist -y "-o$output\Web\Php"
+ Copy-Item "$installerSupport\mod_jk.so" -Destination "$output\Web\Apache24\modules" -Force
+ Try {
+ & sz x "$tomcatDist" -y "-o$output\Web"
+ pushd $output\Web
+ $tomcatName = [System.IO.Path]::GetFileNameWithoutExtension($tomcatDist);
+ if (Test-Path $tomcatName) {
+ & sz x $tomcatName -y
+ Remove-Item $tomcatName -Force
+ $dirToRename = Get-ChildItem 'apache-tomcat-*' | ForEach-Object {$_.FullName} | Select-Object -First 1
+ $dirToRename = [System.IO.Path]::GetFullPath($dirToRename)
+ Copy-Item -Path "$dirToRename\*" -Destination "Tomcat" -Force -Recurse
+ Remove-Item $dirToRename -Force -Recurse
+ } else {
+ throw "Expected $tomcatName to exist"
+ } Finally {
+ popd
+ Copy-Item "$installerSupport\configs\Tomcat\*" -Destination "$output\Web\Tomcat" -Recurse -Force
+ Copy-Item "$installerSupport\configs\Php\*" -Destination "$output\Web\Php" -Recurse -Force
+ Copy-Item "$installerSupport\configs\Apache2\*" -Destination "$output\Web\Apache24" -Recurse -Force
+ Copy-Item "$installerSupport\configs\FDO\providers.xml" -Destination "$output\Server\FDO" -Force
+ Copy-Item "$output\Web\Php\libpq.dll" -Destination "$output\Server\FDO" -Force
+ Copy-Item "$output\Web\Php\libeay32.dll" -Destination "$output\Server\FDO" -Force
+ Copy-Item "$output\Web\Php\ssleay32.dll" -Destination "$output\Server\FDO" -Force
+ msbuild /m /p:Configuration=$conf /p:Platform=$uplat "$installerSrcRoot\InstallerPreReq.sln"
+ Copy-Item "$installerSrcRoot\FdoRegUtil\$typebuild\FdoRegUtil.exe" -Destination "$output\Server\FDO" -Force
+Try
+ Import-Module Pscx
+ #Import-Module -Name ".\Invoke-MsBuild.psm1"
+ $haveMsBuild = (Get-Command msbuild -errorAction SilentlyContinue)
+ $haveNmake = (Get-Command nmake -errorAction SilentlyContinue)
+ If (-Not $haveMsBuild -or -Not $haveNmake) {
+ Write-Host "Could not find msbuild or nmake. Running VS command prompt"
+ $vscmd = "$env:VS110COMNTOOLS" + "VsDevCmd.bat"
+ Write-Host "Running: $vscmd"
+ Invoke-BatchFile $vscmd
+ if (-Not $?) {
+ throw "Failure invoking VsDevCmd.bat"
+ } Else {
+ Write-Host "msbuild and nmake exist. Proceeding with build"
+ $cwd = (Get-Item -Path ".\" -Verbose).FullName
+ if (-Not [System.IO.Path]::IsPathRooted($log_path)) {
+ $log_path = [System.IO.Path]::GetFullPath((Join-Path $cwd $log_path));
+ MakeDirIfNotExists $log_path
+ $cwd = (Get-Item -Path "$build_root" -Verbose).FullName
+ pushd $cwd
+ $phpVersion = "5.5.17"
+ $apacheVersion = "2.4.10"
+ $tomcatVersion = "7.0.56"
+ if (-Not [System.IO.Path]::IsPathRooted($install_root)) {
+ $installerSrcRoot = [System.IO.Path]::GetFullPath((Join-Path $cwd $install_root));
+ } else {
+ $installerSrcRoot = $install_root
+ $installerSupport = [System.IO.Path]::Combine($installerSrcRoot, "Support\Web\$platform")
+ $phpDist = [System.IO.Path]::Combine($installerSupport, "php-$phpVersion-$platform-VC11.zip")
+ $apacheDist = [System.IO.Path]::Combine($installerSupport, "httpd-$apacheVersion-$platform-VC11.zip")
+ $tomcatDist = [System.IO.Path]::Combine($cwd, "Oem\LinuxApt", "apache-tomcat-$tomcatVersion.tar.gz")
+ # Alias 7-zip for easy invocation
+ set-alias sz "$cwd\BuildTools\WebTools\7-Zip\7z.exe"
+ if (-Not (Get-Command sz -errorAction SilentlyContinue)) {
+ throw "7-Zip command not found"
+ # Check doxygen
+ Write-Host "Checking for doxygen"
+ if (-Not (Get-Command doxygen -errorAction SilentlyContinue)) {
+ # Retry
+ set-alias doxygen "$doxygen_path\doxygen.exe"
+ if (-Not (Get-Commamnd doxygen -errorAction SilentlyContinue)) {
+ throw "Doxygen not found"
+ # Check graphviz
+ Write-Host "Checking for graphviz"
+ if (-Not (Get-Command dot -errorAction SilentlyContinue)) {
+ throw "dot not found. Ensure graphviz bin directory is in your PATH environment variable"
+ # Check perl
+ Write-Host "Checking for perl"
+ if (-Not (Get-Command perl -errorAction SilentlyContinue)) {
+ throw "perl not found. Ensure perl bin directory is in your PATH environment variable"
+ # Check sphinx-build
+ Write-Host "Checking for sphinx-build"
+ if (-Not (Get-Command sphinx-build -errorAction SilentlyContinue)) {
+ throw "sphinx-build not found. Ensure Python is installed and you have this sphinx package installed (http://sphinx.pocoo.org)"
+ # Check and unpack the PHP and HTTPD sources
+ EnvSetup $platform $phpVersion $apacheVersion
+ $env:PHP_SRC = "$cwd\Oem\LinuxApt\php-$phpVersion"
+ $env:HTTPD_SRC = "$cwd\Oem\LinuxApt\httpd-$apacheVersion"
+ if ($platform.Equals("x64")) {
+ if ($java_home.Length > 0) {
+ $env:JAVA_HOME = $java_home
+ } else {
+ $env:JAVA_HOME = "C:\Program Files\Java\jdk1.7.0_71"
+ $env:PHP_LIB = "$cwd\Oem\php\x64\Release_TS"
+ $env:HTTPD_LIB = "$cwd\Oem\httpd\lib64"
+ } else {
+ } else {
+ $env:JAVA_HOME = "C:\Program Files (x86)\Java\jdk1.7.0_71"
+ $env:PHP_LIB = "$cwd\Oem\php\Release_TS"
+ $env:HTTPD_LIB = "$cwd\Oem\httpd\lib"
+ # JAVA_HOME must check out
+ Write-Host "Checking for JAVA_HOME"
+ if (-Not (Test-Path $env:JAVA_HOME)) {
+ throw "JAVA_HOME ($env:JAVA_HOME) path does not exist"
+ # Check ant
+ Write-Host "Checking for ant"
+ if (-Not (Get-Command ant -errorAction SilentlyContinue)) {
+ # Retry
+ set-alias ant "$ant_path\ant.bat"
+ throw "ant not found. Please check that ant is in your PATH environment variable or that you passed in a valid path for -ant_path"
+ # Check makensis
+ Write-Host "Checking for makensis"
+ if (-Not (Get-Command makensis -errorAction SilentlyContinue)) {
+ # Retry
+ set-alias makensis "$installerSrcRoot\Support\NSIS\makensis.exe"
+ throw "makensis not found. Please check that you provided a valid path for -install_root"
+ # Normalize the output path
+ if (-Not [System.IO.Path]::IsPathRooted($output)) {
+ $output = [System.IO.Path]::GetFullPath((Join-Path $cwd $output));
+ Write-Host "========= Action Summary ============"
+ Write-Host "Platform: $platform"
+ Write-Host "Configuration: $config"
+ Write-Host "Action: $action"
+ Write-Host "Component: $component"
+ Write-Host "Output Dir: $output"
+ Write-Host "Build Root: $build_root"
+ Write-Host "Version (major): $major"
+ Write-Host "Version (minor): $minor"
+ Write-Host "Version (build): $build"
+ Write-Host "=== Environment Variable Summary ===="
+ Write-Host "PHP_SRC: $env:PHP_SRC"
+ Write-Host "PHP_LIB: $env:PHP_LIB"
+ Write-Host "HTTPD_SRC: $env:HTTPD_SRC"
+ Write-Host "HTTPD_LIB: $env:HTTPD_LIB"
+ Write-Host "JAVA_HOME: $env:JAVA_HOME"
+ Write-Host "====================================="
+ switch($action) {
+ "clean" {
+ CleanAction $component $config $platform
+ "build" {
+ BuildAction $component $config $platform
+ "buildinstall" {
+ if ($component.Equals("all")) {
+ BuildAction "oem" $config $platform
+ InstallAction "oem" $config $platform $output
+ BuildAction "server" $config $platform
+ InstallAction "server" $config $platform $output
+ BuildAction "web" $config $platform
+ InstallAction "web" $config $platform $output
+ PrepareInstallerStagingArea $output $config $platform $installerSupport $cwd $phpDist $apacheDist $tomcatDist
+ BuildAction "installer" $config $platform
+ BuildAction "desktop" $config $platform
+ InstallAction "desktop" $config $platform $output
+ } else {
+ InstallAction $component $config $platform $output
+ "install" {
+ InstallAction "doc" $config $platform $output
+ } else {
+ "installprepare" {
+Finally
+ popd
\ No newline at end of file
More information about the mapguide-commits
