[mapguide-commits] r8497 - in branches/2.6/MgDev: . Server/src/Services/Drawing
svn_mapguide at osgeo.org
Sun Jan 11 04:38:10 PST 2015
Author: jng
Date: 2015-01-11 04:38:10 -0800 (Sun, 11 Jan 2015)
New Revision: 8497
branches/2.6/MgDev/
branches/2.6/MgDev/Server/src/Services/Drawing/ServerDrawingServiceUtil.cpp
branches/2.6/MgDev/run_tests.bat
branches/2.6/MgDev/setenvironment.bat
Merged revision(s) 8443 from trunk/MgDev:
#1727: Force uniqueness on the MgStringCollection returned by MgDrawingService::EnumerateLayers()
Property changes on: branches/2.6/MgDev
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/sandbox/jng/createruntimemap:7486-7555
/sandbox/rfc94:5099-5163
/trunk/MgDev:8209-8210,8230,8313,8333,8359,8388,8392
+ /branches/2.4/MgDev:6749-6756,6777-6783,6785-6787,6789,6791-6794,6796-6801,6954-6962,6986-7006
/trunk/MgDev:8209-8210,8230,8313,8333,8359,8388,8392,8443
Modified: branches/2.6/MgDev/Server/src/Services/Drawing/ServerDrawingServiceUtil.cpp
--- branches/2.6/MgDev/Server/src/Services/Drawing/ServerDrawingServiceUtil.cpp 2015-01-11 12:17:26 UTC (rev 8496)
+++ branches/2.6/MgDev/Server/src/Services/Drawing/ServerDrawingServiceUtil.cpp 2015-01-11 12:38:10 UTC (rev 8497)
@@ -80,7 +80,8 @@
if (layerName)
wchar_t* name = WT_String::to_wchar(layerName.length(), layerName.unicode());
- layerList->Add(name);
+ if (layerList->IndexOf(name) < 0)
+ layerList->Add(name);
delete [] name;
Modified: branches/2.6/MgDev/run_tests.bat
--- branches/2.6/MgDev/run_tests.bat 2015-01-11 12:17:26 UTC (rev 8496)
+++ branches/2.6/MgDev/run_tests.bat 2015-01-11 12:38:10 UTC (rev 8497)
@@ -11,15 +11,16 @@
SET SERVER_ADDR=localhost
SET WEBCONFIGINI=%CD%\UnitTest\webconfig.ini
SET SERVER_PORT=8018
+SET PATH=D:\mg-2.6\MgDev\Release\Web\Php;%PATH%;
REM SET WEBCONFIGINI=C:\Program Files\OSGeo\MapGuide\Web\www\webconfig.ini
REM SET SERVER_PORT=80
SET PHP_TEST_CWD=%CD%\Web\src\mapagent
-SET PHP_EXT_DIR=C:\Program Files\OSGeo\MapGuide\Web\Php\ext
+SET PHP_EXT_DIR=D:\mg-2.6\MgDev\Release\Web\Php\ext
SET START_MGSERVER=1
SET START_WEBSERVER=1
-SET RUN_SERVER_TESTS=1
-SET RUN_PHP_TESTS=1
+SET RUN_SERVER_TESTS=0
+SET RUN_PHP_TESTS=0
SET RUN_DOTNET_TESTS=1
SET RETURN_CODE=0
Modified: branches/2.6/MgDev/setenvironment.bat
--- branches/2.6/MgDev/setenvironment.bat 2015-01-11 12:17:26 UTC (rev 8496)
+++ branches/2.6/MgDev/setenvironment.bat 2015-01-11 12:38:10 UTC (rev 8497)
@@ -83,7 +83,7 @@
rem running
rem ==================================================
-IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files\Java\jdk1.6.0_31
+IF "%JAVA_HOME%" == "" SET JAVA_HOME=C:\Program Files (x86\Java\jdk1.6.0_33
IF "%DOXYGEN%" == "" SET DOXYGEN=%MG_DEV%\BuildTools\doxygen
IF "%GNUWIN32%" == "" SET GNUWIN32=C:\Program Files (x86)\GnuWin32\bin
IF "%SEVENZ%" == "" SET SEVENZ=%MG_DEV%\BuildTools\WebTools\7-Zip
More information about the mapguide-commits
