[mapguide-commits] r8512 - in trunk/Tools/Maestro: Maestro/packages MaestroAPITests OSGeo.MapGuide.MaestroAPI
svn_mapguide at osgeo.org
Tue Jan 20 06:26:46 PST 2015
Author: jng
Date: 2015-01-20 06:26:46 -0800 (Tue, 20 Jan 2015)
New Revision: 8512
Removed:
trunk/Tools/Maestro/MaestroAPITests/ExpressionTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Expression/
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/packages.config
trunk/Tools/Maestro/Maestro/packages/repositories.config
trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
#2528: Remove FLEE-based expression engine. Doing feature queries with computed properties achieves the same effect, making these classes somewhat redundant.
Modified: trunk/Tools/Maestro/Maestro/packages/repositories.config
--- trunk/Tools/Maestro/Maestro/packages/repositories.config 2015-01-20 13:46:10 UTC (rev 8511)
+++ trunk/Tools/Maestro/Maestro/packages/repositories.config 2015-01-20 14:26:46 UTC (rev 8512)
@@ -10,10 +10,9 @@
<repository path="..\..\MaestroAPITestRunner\packages.config" />
<repository path="..\..\MaestroAPITests\packages.config" />
<repository path="..\..\MpuCalc\packages.config" />
- <repository path="..\..\OSGeo.MapGuide.MaestroAPI.Expressions\packages.config" />
+ <repository path="..\..\OSGeo.FDO.Expressions\packages.config" />
<repository path="..\..\OSGeo.MapGuide.MaestroAPI.Local\packages.config" />
<repository path="..\..\OSGeo.MapGuide.MaestroAPI.Tests\packages.config" />
- <repository path="..\..\OSGeo.MapGuide.MaestroAPI\packages.config" />
<repository path="..\..\OSGeo.MapGuide.ObjectModel.Tests\packages.config" />
<repository path="..\packages.config" />
</repositories>
\ No newline at end of file
Deleted: trunk/Tools/Maestro/MaestroAPITests/ExpressionTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/ExpressionTests.cs 2015-01-20 13:46:10 UTC (rev 8511)
+++ trunk/Tools/Maestro/MaestroAPITests/ExpressionTests.cs 2015-01-20 14:26:46 UTC (rev 8512)
@@ -1,1050 +0,0 @@
-#region Disclaimer / License
-// Copyright (C) 2010, Jackie Ng
-// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of the GNU Lesser General Public
-// License as published by the Free Software Foundation; either
-// version 2.1 of the License, or (at your option) any later version.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
-#endregion Disclaimer / License
-using NUnit.Framework;
-using OSGeo.MapGuide.MaestroAPI.Exceptions;
-using OSGeo.MapGuide.MaestroAPI.Expression;
-using OSGeo.MapGuide.MaestroAPI.Http;
-using System;
-using System.Diagnostics;
-using System.IO;
-using System.Text;
-using System.Threading;
-namespace MaestroAPITests
- // Test data schema (for reference in these unit tests)
- // ID (int32) | Name(string) | URL(string)
- // 1 | Foobar | http://foobar.com
- // 2 | snafu | (null)
- // 2 | (null) | (null)
- [TestFixture]
- public class ExpressionTests
- [TestFixtureSetUp]
- public void Setup()
- if (TestControl.IgnoreExpressionTests)
- Assert.Ignore("Skipping ExpressionTests because TestControl.IgnoreExpressionTests = true");
- [Test]
- public void TestMismatch()
- //Simulate post-#708 SELECTFEATURES output and test our expression engine reader
- var bytes = Encoding.UTF8.GetBytes(Properties.Resources.SelectFeatureSample);
- var reader = new XmlFeatureReader(new MemoryStream(bytes));
- Assert.NotNull(reader.ClassDefinition);
- Assert.AreEqual(3, reader.FieldCount);
- Assert.AreEqual(3, reader.ClassDefinition.Properties.Count);
- Assert.NotNull(reader.ClassDefinition.FindProperty("ID"));
- Assert.NotNull(reader.ClassDefinition.FindProperty("Name"));
- Assert.NotNull(reader.ClassDefinition.FindProperty("URL"));
- var exprReader = new ExpressionFeatureReader(reader);
- Assert.IsTrue(exprReader.ReadNext());
- Assert.Catch<ExpressionException>(() => exprReader.Evaluate<bool>("CurrentDate()"));
- Assert.Catch<ExpressionException>(() => exprReader.Evaluate<bool>("'Foobar'"));
- Assert.Catch<ExpressionException>(() => exprReader.Evaluate<bool>("Power(2, 4)"));
- Assert.Catch<ExpressionException>(() => exprReader.Evaluate<string>("Foobar"));
- var dt = exprReader.Evaluate<DateTime>("CurrentDate()");
- var str = exprReader.Evaluate<string>("'Foobar'");
- var num = exprReader.Evaluate<int>("Power(2, 4)");
- var num2 = exprReader.Evaluate<float>("Power(2, 4)");
- exprReader.Close();
- [Test]
- public void TestCurrentDateAndAddMonths()
- //TODO: Know how to calculate diffs between 2 DateTimes in months?
- var dtNow = DateTime.Now;
- Thread.Sleep(50);
- var dt1 = exprReader.Evaluate("CurrentDate()");
- Assert.NotNull(dt1);
- Trace.WriteLine("dt1: " + dt1.ToString());
- Assert.AreEqual(typeof(DateTime), dt1.GetType());
- Assert.IsTrue((DateTime)dt1 > dtNow);
- var fut1 = exprReader.Evaluate("AddMonths(CurrentDate(), 3)");
- Assert.NotNull(fut1);
- Trace.WriteLine("fut1: " + fut1.ToString());
- var past1 = exprReader.Evaluate("AddMonths(CurrentDate(), -3)");
- Assert.NotNull(past1);
- Trace.WriteLine("past1: " + past1.ToString());
- Thread.Sleep(50);
- var dt2 = exprReader.Evaluate("CurrentDate()");
- Assert.NotNull(dt2);
- Trace.WriteLine("dt2: " + dt2.ToString());
- Assert.AreEqual(typeof(DateTime), dt2.GetType());
- Assert.IsTrue((DateTime)dt2 > (DateTime)dt1);
- var fut2 = exprReader.Evaluate("AddMonths(CurrentDate(), 3)");
- Assert.NotNull(fut2);
- Trace.WriteLine("fut2: " + fut2.ToString());
- var past2 = exprReader.Evaluate("AddMonths(CurrentDate(), -3)");
- Assert.NotNull(past2);
- Trace.WriteLine("past2: " + past2.ToString());
- Thread.Sleep(50);
- var dt3 = exprReader.Evaluate("CurrentDate()");
- Assert.NotNull(dt3);
- Trace.WriteLine("dt2: " + dt3.ToString());
- Assert.AreEqual(typeof(DateTime), dt3.GetType());
- Assert.IsTrue((DateTime)dt3 > (DateTime)dt2);
- var fut3 = exprReader.Evaluate("AddMonths(CurrentDate(), 3)");
- Assert.NotNull(fut3);
- Trace.WriteLine("fut3: " + fut3.ToString());
- var past3 = exprReader.Evaluate("AddMonths(CurrentDate(), -3)");
- Assert.NotNull(past3);
- Trace.WriteLine("past3: " + past3.ToString());
- Thread.Sleep(50);
- Assert.IsFalse(exprReader.ReadNext()); //end of stream
- [Test]
- public void TestNullValue()
- Assert.IsTrue(!exprReader.IsNull("URL"));
- var url = exprReader["URL"];
- var value = exprReader.Evaluate("NullValue(URL, 'http://www.snafu.com')");
- Assert.NotNull(url);
- Assert.NotNull(value);
- Assert.AreEqual(url.ToString(), value.ToString());
- var value2 = exprReader.Evaluate("NullValue(URL, 'http://www.foo.com')");
- Assert.NotNull(value2);
- Assert.AreEqual("http://www.foo.com", value2);
- var value3 = exprReader.Evaluate("NullValue(URL, 'http://www.bar.com')");
- Assert.NotNull(value3);
- Assert.AreEqual("http://www.bar.com", value3);
- [Test]
- public void TestMathAbs()
- var orig = (int)exprReader["ID"];
- var value = Convert.ToInt32(exprReader.Evaluate("Abs(-ID)"));
- Assert.AreEqual(orig, value);
- var orig2 = (int)exprReader["ID"];
- var value2 = Convert.ToInt32(exprReader.Evaluate("Abs(-ID)"));
- Assert.AreEqual(orig2, value2);
- var orig3 = (int)exprReader["ID"];
- var value3 = Convert.ToInt32(exprReader.Evaluate("Abs(-ID)"));
- Assert.AreEqual(orig3, value3);
- [Test]
- public void TestMathAcos()
- //The numbers in this sample are way too large for Acos() so trim them down to size
- var value = Convert.ToDouble(exprReader.Evaluate("Acos(ID * 0.1)"));
- Assert.AreEqual(Math.Acos(orig * 0.1), value);
- var value2 = Convert.ToDouble(exprReader.Evaluate("Acos(ID * 0.1)"));
- Assert.AreEqual(Math.Acos(orig2 * 0.1), value2);
- var value3 = Convert.ToDouble(exprReader.Evaluate("Acos(ID * 0.1)"));
- Assert.AreEqual(Math.Acos(orig3 * 0.1), value3);
- [Test]
- public void TestMathAsin()
- //The numbers in this sample are way too large for Asin() so trim them down to size
- var value = Convert.ToDouble(exprReader.Evaluate("Asin(ID * 0.1)"));
- Assert.AreEqual(Math.Asin(orig * 0.1), value);
- var value2 = Convert.ToDouble(exprReader.Evaluate("Asin(ID * 0.1)"));
- Assert.AreEqual(Math.Asin(orig2 * 0.1), value2);
- var value3 = Convert.ToDouble(exprReader.Evaluate("Asin(ID * 0.1)"));
- Assert.AreEqual(Math.Asin(orig3 * 0.1), value3);
- public void TestMathAtan2()
- [Test]
- public void TestMathCos()
- var value = Convert.ToDouble(exprReader.Evaluate("Cos(ID)"));
- Assert.AreEqual(Math.Cos(orig), value);
- var value2 = Convert.ToDouble(exprReader.Evaluate("Cos(ID)"));
- Assert.AreEqual(Math.Cos(orig2), value2);
- var value3 = Convert.ToDouble(exprReader.Evaluate("Cos(ID)"));
- Assert.AreEqual(Math.Cos(orig3), value3);
- [Test]
- public void TestMathExp()
- var value = Convert.ToDouble(exprReader.Evaluate("Exp(ID)"));
- Assert.AreEqual(Math.Exp(orig), value);
- var value2 = Convert.ToDouble(exprReader.Evaluate("Exp(ID)"));
- Assert.AreEqual(Math.Exp(orig2), value2);
- var value3 = Convert.ToDouble(exprReader.Evaluate("Exp(ID)"));
- Assert.AreEqual(Math.Exp(orig3), value3);
- [Test]
- public void TestMathLn()
- var value = Convert.ToDouble(exprReader.Evaluate("Ln(ID)"));
- Assert.AreEqual(Math.Log(orig), value);
- var value2 = Convert.ToDouble(exprReader.Evaluate("Ln(ID)"));
- Assert.AreEqual(Math.Log(orig2), value2);
- var value3 = Convert.ToDouble(exprReader.Evaluate("Ln(ID)"));
- Assert.AreEqual(Math.Log(orig3), value3);
- [Test]
- public void TestMathLog()
- public void TestMathMod()
- [Test]
- public void TestMathPower()
- var value = Convert.ToDouble(exprReader.Evaluate("Power(ID, 2)"));
- Assert.AreEqual(Math.Pow(orig, 2), value);
- var value2 = Convert.ToDouble(exprReader.Evaluate("Power(ID, 4)"));
- Assert.AreEqual(Math.Pow(orig2, 4), value2);
- var value3 = Convert.ToDouble(exprReader.Evaluate("Power(ID, 8)"));
- Assert.AreEqual(Math.Pow(orig3, 8), value3);
- public void TestMathRemainder()
- public void TestMathSin()
- public void TestMathSqrt()
- public void TestMathTan()
- public void TestMathCeil()
- public void TestMathFloor()
- public void TestMathRound()
- public void TestMathSign()
- public void TestMathTrunc()
- [Test]
- public void TestConcat()
- //Test nested and variadic forms of Concat()
- var orig = exprReader["Name"].ToString();
- var value = exprReader.Evaluate("Concat(Concat(Name, 'Foo'), 'Bar')");
- var valueV = exprReader.Evaluate("Concat(Name, 'Foo', 'Bar', 'Snafu')");
- Assert.AreEqual(orig + "FooBar", value);
- Assert.AreEqual(orig + "FooBarSnafu", valueV);
- var orig2 = exprReader["Name"].ToString();
- var value2 = exprReader.Evaluate("Concat(Concat(Name, 'Foo'), 'Bar')");
- var valueV2 = exprReader.Evaluate("Concat(Name, 'Foo', 'Bar', 'Snafu')");
- Assert.AreEqual(orig2 + "FooBar", value2);
- Assert.AreEqual(orig2 + "FooBarSnafu", valueV2);
- var value3 = exprReader.Evaluate("Concat(Concat(Name, 'Foo'), 'Bar')");
- var valueV3 = exprReader.Evaluate("Concat(Name, 'Foo', 'Bar', 'Snafu')");
- Assert.AreEqual("FooBar", value3);
- Assert.AreEqual("FooBarSnafu", valueV3);
- public void TestInstr()
- public void TestLength()
- public void TestLower()
- public void TestLpad()
- public void TestLtrim()
- public void TestRpad()
- public void TestRtrim()
- public void TestSoundex()
- public void TestSubstr()
- public void TestTranslate()
- public void TestTrim()
- public void TestUpper()
Modified: trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
--- trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj 2015-01-20 13:46:10 UTC (rev 8511)
+++ trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj 2015-01-20 14:26:46 UTC (rev 8512)
@@ -82,7 +82,6 @@
<Link>SignedAssemblyInfo.cs</Link>
</Compile>
<Compile Include="ConnectionTestBase.cs" />
- <Compile Include="ExpressionTests.cs" />
<Compile Include="FeatureReaderTests.cs" />
<Compile Include="HttpConnectionTests.cs" />
<Compile Include="HttpSiteTests.cs" />
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2015-01-20 13:46:10 UTC (rev 8511)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2015-01-20 14:26:46 UTC (rev 8512)
@@ -61,10 +61,6 @@
<Prefer32Bit>false</Prefer32Bit>
</PropertyGroup>
<ItemGroup>
- <Reference Include="Ciloci.Flee, Version=0.9.27.0, Culture=neutral, PublicKeyToken=fc11e355737f8b7f, processorArchitecture=MSIL">
- <SpecificVersion>False</SpecificVersion>
- <HintPath>..\Maestro\packages\fleesharp.0.9.27-pre\lib\net40\Ciloci.Flee.dll</HintPath>
- </Reference>
<Reference Include="NetTopologySuite.Merged, Version=1.8.0.0, Culture=neutral, PublicKeyToken=f580a05016ebada1, processorArchitecture=MSIL">
<HintPath>..\Thirdparty\NTS\NetTopologySuite.Merged.dll</HintPath>
@@ -115,11 +111,6 @@
<Compile Include="Exceptions\SerializationException.cs" />
<Compile Include="Exceptions\UnsupportedResourceTypeException.cs" />
<Compile Include="Exceptions\UnsupportedServiceTypeException.cs" />
- <Compile Include="Expression\ExpressionEngine.cs" />
- <Compile Include="Expression\ExpressionFeatureReader.cs" />
- <Compile Include="Expression\FdoFunctionNamespace.cs" />
- <Compile Include="Expression\MgFunctionNamespace.cs" />
- <Compile Include="Expression\NsDoc.cs" />
<Compile Include="ExtensionMethods.cs" />
<Compile Include="Feature\ClrFdoTypeMap.cs" />
<Compile Include="Feature\FeatureBase.cs" />
@@ -245,7 +236,6 @@
<Compile Include="XmlValidator.cs" />
</ItemGroup>
<ItemGroup>
- <None Include="packages.config" />
<None Include="Schemas\ApplicationDefinition-1.0.0.xsd">
</None>
<None Include="Schemas\ApplicationDefinitionInfo-1.0.0.xsd">
Deleted: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/packages.config
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/packages.config 2015-01-20 13:46:10 UTC (rev 8511)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/packages.config 2015-01-20 14:26:46 UTC (rev 8512)
@@ -1,4 +0,0 @@
-<?xml version="1.0" encoding="utf-8"?>
-<packages>
- <package id="fleesharp" version="0.9.27-pre" targetFramework="net40-Client" />
-</packages>
More information about the mapguide-commits
