[mapguide-commits] r8518 - trunk/MgDev/Server/src/UnitTesting
svn_mapguide at osgeo.org
Tue Jan 27 05:09:03 PST 2015
Author: jng
Date: 2015-01-27 05:09:03 -0800 (Tue, 27 Jan 2015)
New Revision: 8518
trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
#2531: Fix unit test failures on Coordinate System test suite. The issue is that the MgFileUtil::CreateDirectory() is non-recursive, meaning if any parent part of the path doesn't exist, the whole call fails and derails the test case as a result. The fix is to create this directory recursively.
Modified: trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2015-01-26 11:54:48 UTC (rev 8517)
+++ trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2015-01-27 13:09:03 UTC (rev 8518)
@@ -470,6 +470,8 @@
bool TestCoordinateSystem::SetDefaultUserDictionaryDir()
+ MG_TRY()
MgCoordinateSystemFactory mgCsFactory;
Ptr<MgCoordinateSystemCatalog> pCsCatalog = mgCsFactory.GetCatalog();
@@ -485,9 +487,18 @@
//create the directory to make sure, [SetUserDictionaryDir]
//can succeed
- MgFileUtil::CreateDirectory(defUserDictionaryDir);
+ if (!MgFileUtil::PathnameExists(defUserDictionaryDir))
+ MgFileUtil::CreateDirectory(defUserDictionaryDir, false, true);
pCsCatalog->SetUserDictionaryDir(defUserDictionaryDir);
+ MG_CATCH(L"TestCoordinateSystem.SetDefaultUserDictionaryDir")
+ if (NULL != mgException.p)
+ STRING errDetails = mgException->GetDetails();
+ ACE_DEBUG((LM_INFO, ACE_TEXT("Exception setting user dictionary dir: %W"), errDetails.c_str()));
+ return false;
return true;
More information about the mapguide-commits
