[mapguide-commits] r8524 - in trunk/Tools/Maestro: Maestro Maestro.Editors/MapDefinition OSGeo.MapGuide.MaestroAPI
svn_mapguide at osgeo.org
Wed Jan 28 07:25:38 PST 2015
Author: jng
Date: 2015-01-28 07:25:38 -0800 (Wed, 28 Jan 2015)
New Revision: 8524
Added:
trunk/Tools/Maestro/Maestro/mono.txt
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
trunk/Tools/Maestro/Maestro/changelog.txt
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
This submission includes the following changes:
- Fix NRE trying to edit the base map section of a pre-3.0.0 Map Definition. This was due to recent changes to support the v3.0.0 schema
- Add mono workarounds to allow the property grid to work in the Map Definition editor (Mono doesn't like objects being assigned to a detached PropertyGrid)
- Use Stream.CopyTo for Utility.CopyStream
- Add a small text file documenting some gotchas when running Maestro under Mono.
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt 2015-01-28 11:49:12 UTC (rev 8523)
+++ trunk/Tools/Maestro/Maestro/changelog.txt 2015-01-28 15:25:38 UTC (rev 8524)
@@ -1,11 +1,30 @@
- - Drag/Drop now properly handles cases where multiple handlers could handle a given file drop
+ 6.0a4
+ - Updated to target .net Framework 4.5
+ - Expression Editor now supports parsing/validation of FDO Filters and Expressions
+ - Structure of an FDO filter or expression can be viewed under the tools menu
+ - MapGuide Open Source 3.0 support
+ - Support for editing v3.0.0 Map Definition resources
+ - Support for local resource previews in 3.0
+ - Stamed tile layer options in Fusion editor
+ - Fix: Don't show debug watermarks when previewing watermarks
+ - Fix: Divide by zero errors in Text Editor component
+ - Fix: Incorrect MgCooker tile calculations
+ - Fix: Add missing "Left" and "Right" horizontal text alignment options
+ - Fix: Avoid XML content error in Layer Definition by preventing the ability to deleting style rule if there's only one
+ 6.0a3
+ - Drag/Drop now properly handles cases where multiple handlers could handle a given file drop
- Future-proofing
- - Maestro can now work with unknown resource types
- - Map Definitions, Web Layouts and Application Definitions of unknown schema versions can be previewed
- - Files of unknown extensions will be loaded as XML content when drag/dropped in the Site Explorer
+ - Maestro can now work with unknown resource types
+ - Map Definitions, Web Layouts and Application Definitions of unknown schema versions can be previewed
+ - Files of unknown extensions will be loaded as XML content when drag/dropped in the Site Explorer
- Fusion editor changes
- Map Group editor re-designed to better reflect its logical structure in the Map Definition
- - New Generic XML editor option allowing for custom layer types to be added
+ - New Generic XML editor option allowing for custom layer types to be added
6.0a2
@@ -18,14 +37,14 @@
- Added specialized builder support for LOOKUP() and RANGE() expression functions in Expression Editor
- Added support for customizing border colors when theming
- Improve the usability of the Composite Symbolization dialog
- - Moved the inline Symbol Definition editor off to a separate dialog
- - Symbol name now shown along side type for each component symbol in Symbolization Components list
- - New button to show more information about a selected symbol parameter
- - "Edit Instance Properties" button moved into Symbolization Components list toolbar
- - Editing symbol parameter values can now be done via
- - Editing the cell
- - Using a specialized editor (that falls back to the Expression Editor if no specialized editor is found)
- - Using the Expression Editor
+ - Moved the inline Symbol Definition editor off to a separate dialog
+ - Symbol name now shown along side type for each component symbol in Symbolization Components list
+ - New button to show more information about a selected symbol parameter
+ - "Edit Instance Properties" button moved into Symbolization Components list toolbar
+ - Editing symbol parameter values can now be done via
+ - Editing the cell
+ - Using a specialized editor (that falls back to the Expression Editor if no specialized editor is found)
+ - Using the Expression Editor
- Fix: Negative index exception in grid-based editor when selecting row header
- Fix: XML diff false positives
- Fix: Wrong previews in Composite Symbolization dialog when multiple composite styles defined
@@ -198,9 +217,9 @@
- New "address bar" for Resource IDs, allowing for quick navigation and identiifcation of Resource IDs.
- Layer Definition editor improvements:
- - Add support for "exploding" themes into individual filtered sub-layers.
- - Theme generation now considers active layer filter when generating rules
- - Use GETLEGENDIMAGE for layer style previews
+ - Add support for "exploding" themes into individual filtered sub-layers.
+ - Theme generation now considers active layer filter when generating rules
+ - Use GETLEGENDIMAGE for layer style previews
- Symbol Definitions can now be previewed (via the GETLEGENDIMAGE API)
- Resource IDs references in the Resource Properties Dialog can now be copied to the clipboard
- New specialized error dialog for XML content errors, that shows the offending XML contnent.
@@ -271,8 +290,8 @@
- MgCooker tiling classes now part of the MaestroAPI
- Better handling of large Feature Sources
- ODBC Editor enhancements
- - Supports creating ODBC configuration documents with a filtered logical schema. When creating/resetting a configuration document, the user is prompted for the feature classes to include in the configuration document
- - Supports specifying the coordinate system for the default spatial context
+ - Supports creating ODBC configuration documents with a filtered logical schema. When creating/resetting a configuration document, the user is prompted for the feature classes to include in the configuration document
+ - Supports specifying the coordinate system for the default spatial context
- Fix: Maestro/MaestroAPI creates invalid ODBC configuration documents
- Fix: Potentially long running tasks are now done on background threads with busy dialogs
- Fix: Non-working expression buttons for some color pickers
@@ -571,9 +590,9 @@
- Remaining missing functionality:
- Add/Remove/Edit containers
- Widget set configuration
- - Add new widget from WidgetInfo
- - Edit widget parameters
- - Remove widget from widget set
+ - Add new widget from WidgetInfo
+ - Edit widget parameters
+ - Remove widget from widget set
Test Build 3
@@ -599,8 +618,8 @@
- Resource Dialog fixes and UX enhancements
- Mono fixes related to XML and UI sizing.
- Added inter-server migration tools
- - Move/Copy resources to a folder on another server with option to overwrite existing resources
- - Copy selected resource (and its dependencies) to the same path on another server, with choices of which dependent resources to copy and whether to overwrite existing resources.
+ - Move/Copy resources to a folder on another server with option to overwrite existing resources
+ - Copy selected resource (and its dependencies) to the same path on another server, with choices of which dependent resources to copy and whether to overwrite existing resources.
Test Build 1
@@ -608,44 +627,44 @@
First public preview release of Maestro 3.0.
- Redesigned User Interface
- - Now driven by the SharpDevelop Core framework
- - Allows for easy customization of user interfaces.
- - AddIn infrastructure allows for easy addition of new functionality.
- - Site Explorer now uses the TreeViewAdv control, allowing for multiple selections and commands that operate on multiple selected resources. This control is compatible with Mono.
- - Some example commands which were previously not possible.
- - Delete selected resources
- - Validate selected resources
- - Package selected resources
+ - Now driven by the SharpDevelop Core framework
+ - Allows for easy customization of user interfaces.
+ - AddIn infrastructure allows for easy addition of new functionality.
+ - Site Explorer now uses the TreeViewAdv control, allowing for multiple selections and commands that operate on multiple selected resources. This control is compatible with Mono.
+ - Some example commands which were previously not possible.
+ - Delete selected resources
+ - Validate selected resources
+ - Package selected resources
- Rewritten resource editor infrastructure
- - One editor per resource type / version
- - Uses the INotifyPropertyChanged databinding infrastructure
- - Allow for upgrades to newer versions of a resource type (eg. LayerDefinition 1.0.0 to LayerDefinition 1.3.0). Upgrades are manual and explicit, with a firefox-style notification bar to indicate whether a resource can be upgraded.
- - Resources types and/or versions without a specialized editor default to the XML editor.
- - Support for browsing Symbol Libraries
- - Flexible new resource templates
- - New specialized editors for
- - Drawing Source
- - Print Layout
- - Enhancements to existing specialized editors
- - Web Layout
- - Support for importing/exporting custom commands.
- - Editor library can be used outside of Maestro.exe as long as you implement the core service interfaces (IResourceService, IFeatureService)
+ - One editor per resource type / version
+ - Uses the INotifyPropertyChanged databinding infrastructure
+ - Allow for upgrades to newer versions of a resource type (eg. LayerDefinition 1.0.0 to LayerDefinition 1.3.0). Upgrades are manual and explicit, with a firefox-style notification bar to indicate whether a resource can be upgraded.
+ - Resources types and/or versions without a specialized editor default to the XML editor.
+ - Support for browsing Symbol Libraries
+ - Flexible new resource templates
+ - New specialized editors for
+ - Drawing Source
+ - Print Layout
+ - Enhancements to existing specialized editors
+ - Web Layout
+ - Support for importing/exporting custom commands.
+ - Editor library can be used outside of Maestro.exe as long as you implement the core service interfaces (IResourceService, IFeatureService)
- Redesigned core API
- - ServerConnectionI -> IServerConnection
- - Connection interface is now separated into service specific sub-interfaces
- - IResourceService
- - IFeatureService
- - etc.
- - Cleaner resource object model
- - All top-level resource classes implement a common IResource interface
- - Base library includes resource classes generated from v1.0.0 xsd schemas.
- - Classes generated from newer xsd schemas reside in their own separate assembly.
- - New connections capabilities API
- - Allows interrogation of supported features/commands depending on implementation and mapguide server version.
- - Custom command API
- - Allows for custom functionality which may only work for newer versions of MapGuide.
+ - ServerConnectionI -> IServerConnection
+ - Connection interface is now separated into service specific sub-interfaces
+ - IResourceService
+ - IFeatureService
+ - etc.
+ - Cleaner resource object model
+ - All top-level resource classes implement a common IResource interface
+ - Base library includes resource classes generated from v1.0.0 xsd schemas.
+ - Classes generated from newer xsd schemas reside in their own separate assembly.
+ - New connections capabilities API
+ - Allows interrogation of supported features/commands depending on implementation and mapguide server version.
+ - Custom command API
+ - Allows for custom functionality which may only work for newer versions of MapGuide.
- Other New Features and Changes
- - Load Procedure validation support
- - API and UI support for listening to outbound requests. You can now view outbound requests of your MapGuide Server connections
- - Validation no longer logs redundant messages. All errors, warnings and other messages are unique for each resource being validated. You won't get repeats
+ - Load Procedure validation support
+ - API and UI support for listening to outbound requests. You can now view outbound requests of your MapGuide Server connections
+ - Validation no longer logs redundant messages. All errors, warnings and other messages are unique for each resource being validated. You won't get repeats
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro/mono.txt
--- trunk/Tools/Maestro/Maestro/mono.txt (rev 0)
+++ trunk/Tools/Maestro/Maestro/mono.txt 2015-01-28 15:25:38 UTC (rev 8524)
@@ -0,0 +1,25 @@
+Mono Gotchas
+This document is a compilation of known gotchas when using Maestro within a Mono environment
+Suggestions for code-based workarounds or alternatives would be much appreciated.
+Notes are based on running the current Maestro trunk against Mono 3.12 on Ubuntu 14.04 (from Xamarin's repo)
+General
+ - Where possible, run the latest and greatest version of Mono.
+ - Maestro may randomly core dump on startup. Workaround is just to restart again.
+ - Editors may be "shrunk" when opened when Maestro is not fully maximized. Workaround is to resize the Maestro main window or maximize it.
+Layer Editor
+ - Style rule previews do not render. Either Mono's DataGridView cannot support image-based cells or the Image property of our rule models do not bind properly to image-based cells
+Map Editor
+ - You cannot batch edit multiple groups and layers. Mono's PropertyGrid does not properly handle editing properties multiple selected objects
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs 2015-01-28 11:49:12 UTC (rev 8523)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs 2015-01-28 15:25:38 UTC (rev 8524)
@@ -158,6 +158,7 @@
if (mdf3 == null)
tabs.TabPages.Remove(TAB_TILE_SET);
+ InitInlineModel();
else
@@ -285,10 +286,8 @@
btnMoveLayerOrGroupDown.Enabled = true;
btnConvertLayerGroupToBaseGroup.Enabled = true;
- propertiesPanel.Controls.Clear();
- var item = CreateGroupControl(group);
_activeLayer = null;
- propertiesPanel.Controls.Add(item);
+ AddGroupControl(group);
private class LocalizedDisplayNameAttribute : DisplayNameAttribute
@@ -459,15 +458,15 @@
#endregion Designer Attributes
- private Control CreateGroupControl(GroupItem group)
+ private void AddGroupControl(GroupItem group)
+ propertiesPanel.Controls.Clear();
Control ctrl = new Control();
CommonPropertyCtrl commCtrl = new CommonPropertyCtrl();
commCtrl.Dock = DockStyle.Fill;
- commCtrl.SelectedObject = new GroupItemDesigner(group);
var item = new GroupPropertiesCtrl(_map, group.Tag);
//item.GroupChanged += (s, evt) => { OnResourceChanged(); };
item.GroupChanged += WeakEventHandler.Wrap((s, evt) => OnResourceChanged(), (eh) => item.GroupChanged -= eh);
@@ -478,13 +477,17 @@
ctrl.Dock = DockStyle.Fill;
- return ctrl;
+ propertiesPanel.Controls.Add(ctrl);
+ commCtrl.SelectedObject = new GroupItemDesigner(group);
#region Control Factories
- private Control CreateMultiControl(System.Collections.ObjectModel.ReadOnlyCollection<TreeNodeAdv> nodes)
+ private void AddMultiControl(System.Collections.ObjectModel.ReadOnlyCollection<TreeNodeAdv> nodes)
@@ -513,19 +516,20 @@
+ propertiesPanel.Controls.Add(commCtrl);
commCtrl.SelectedObjects = values.ToArray();
- return commCtrl;
- private Control CreateBaseGroupControl(BaseLayerGroupItem group)
+ private void AddBaseGroupControl(BaseLayerGroupItem group)
- commCtrl.SelectedObject = new BaseGroupItemDesigner(group);
@@ -536,18 +540,20 @@
- return ctrl;
+ commCtrl.SelectedObject = new BaseGroupItemDesigner(group);
- private Control CreateBaseLayerControl(BaseLayerItem layer)
+ private void AddBaseLayerControl(BaseLayerItem layer)
- commCtrl.SelectedObject = new BaseLayerItemDesigner(layer);
var item = new LayerPropertiesCtrl(layer.Tag, _edSvc);
//item.LayerChanged += (s, evt) => { OnResourceChanged(); };
item.LayerChanged += WeakEventHandler.Wrap((s, evt) => OnResourceChanged(), (eh) => item.LayerChanged -= eh);
@@ -558,18 +564,20 @@
- return ctrl;
+ commCtrl.SelectedObject = new BaseLayerItemDesigner(layer);
- private Control CreateLayerControl(LayerItem layer)
+ private void AddLayerControl(LayerItem layer)
- commCtrl.SelectedObject = new LayerItemDesigner(layer);
@@ -580,7 +588,9 @@
- return ctrl;
+ commCtrl.SelectedObject = new LayerItemDesigner(layer);
#endregion Control Factories
@@ -593,11 +603,8 @@
btnMoveLayerOrGroupUp.Enabled = true; //TODO: Disable if layer is top of its group
btnMoveLayerOrGroupDown.Enabled = true; //TODO: Disable if layer is bottom of its group
- var item = CreateLayerControl(layer);
_activeLayer = layer.Tag;
+ AddLayerControl(layer);
private static bool AllLayers(System.Collections.ObjectModel.ReadOnlyCollection<TreeNodeAdv> nodes)
@@ -671,11 +678,8 @@
btnRemoveBaseLayerGroup.Enabled = bAllBaseGroups;
btnBaseLayerGroupToRegular.Enabled = bAllBaseGroups;
- var item = CreateMultiControl(nodes);
+ AddMultiControl(nodes);
private IMapLayer _activeLayer;
@@ -688,11 +692,8 @@
btnDLMoveLayerUp.Enabled =
btnDLRemoveLayer.Enabled = true;
private void btnAddGroup_Click(object sender, EventArgs e)
@@ -1469,9 +1470,8 @@
//var item = new GroupPropertiesCtrl(_map, group.Tag);
//item.Dock = DockStyle.Fill;
- var item = CreateBaseGroupControl(group);
+ AddBaseGroupControl(group);
private void OnBaseLayerItemSelected(BaseLayerItem layer)
@@ -1481,13 +1481,11 @@
btnMoveBaseLayerUp.Enabled = true;
btnBaseLayerGroupToRegular.Enabled = false;
//var item = new LayerPropertiesCtrl(layer.Tag, _edSvc.ResourceService, _edSvc);
- var item = CreateBaseLayerControl(layer);
+ AddBaseLayerControl(layer);
private void trvBaseLayers_MouseDoubleClick(object sender, MouseEventArgs e)
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2015-01-28 11:49:12 UTC (rev 8523)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2015-01-28 15:25:38 UTC (rev 8524)
@@ -346,11 +346,14 @@
// throw new InvalidOperationException("Could not rewind the source stream. Most likely the source stream does not support seeking or rewinding"); //LOCALIZEME
+ source.CopyTo(target);
do
r = source.Read(buf, 0, buf.Length);
target.Write(buf, 0, r);
} while (r > 0);
/// <summary>
More information about the mapguide-commits
