[mapguide-commits] r8526 - in trunk/Tools/MgInstantSetup: InstantSetup.Core InstantSetupCmd
svn_mapguide at osgeo.org
Sat Jan 31 08:47:06 PST 2015
Author: jng
Date: 2015-01-31 08:47:06 -0800 (Sat, 31 Jan 2015)
New Revision: 8526
trunk/Tools/MgInstantSetup/InstantSetup.Core/AbstractSetupConfigurationProcess.cs
trunk/Tools/MgInstantSetup/InstantSetup.Core/ApacheSetupConfigurationProcess.cs
trunk/Tools/MgInstantSetup/InstantSetup.Core/FdoProviderRegistration.cs
trunk/Tools/MgInstantSetup/InstantSetup.Core/IISSetupConfigurationProcess.cs
trunk/Tools/MgInstantSetup/InstantSetupCmd/Options.cs
trunk/Tools/MgInstantSetup/InstantSetupCmd/Program.cs
InstantSetup: Add FDO registration and print a configuration summary before doing the configuration
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/AbstractSetupConfigurationProcess.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/AbstractSetupConfigurationProcess.cs 2015-01-29 15:18:40 UTC (rev 8525)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/AbstractSetupConfigurationProcess.cs 2015-01-31 16:47:06 UTC (rev 8526)
@@ -31,6 +31,8 @@
DotNet
+ public delegate void FormatLineWriter(string msg, params object [] args);
/// <summary>
/// Base configuration setup process
/// </summary>
@@ -49,6 +51,31 @@
this.ServerSitePort = 2822;
+ public virtual void WriteSummary(FormatLineWriter writer)
+ writer("Backup config files: {0}", this.BackupConfigFiles);
+ writer("Backup config path: {0}", this.BackupConfigPath);
+ writer("Batch file output dir: {0}", this.BatchFileOutputDirectory);
+ writer("Source directory: {0}", this.BuildOutputPath);
+ writer("CS-Map directory: {0}", this.CsMapDictionaryDir);
+ writer("Default Viewer: {0}", this.DefaultViewer);
+ writer("Enable PHP: {0}", this.EnablePhp);
+ writer("Install Services: {0}", this.InstallServices);
+ writer("64-bit MapGuide: {0}", this.Is64BitMapGuide);
+ writer("MapGuide Service Name: {0}", this.MapGuideServiceName);
+ writer("Server Admin Port: {0}", this.ServerAdminPort);
+ writer("Server Client Port: {0}", this.ServerClientPort);
+ writer("Server Site Port: {0}", this.ServerSitePort);
+ writer("Server root dir: {0}", this.ServerRootDir);
+ writer("Server bin dir: {0}", this.ServerBinDir);
+ writer("Virtual Directory: {0}", this.VirtualDirectoryName);
+ writer("Map Agent directory: {0}", this.WebTierMapAgentDir);
+ writer("PHP directory: {0}", this.WebTierPhpDir);
+ writer("Web tier public dir: {0}", this.WebTierPublicDir);
+ writer("Web tier root dir: {0}", this.WebTierRootDir);
+ writer("Write MENTOR_DICTIONARY_PATH: {0}", this.WriteMentorDictionaryPath);
/// <summary>
/// Gets or sets whether the installation of MapGuide to be configured is 64-bit
/// </summary>
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/ApacheSetupConfigurationProcess.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/ApacheSetupConfigurationProcess.cs 2015-01-29 15:18:40 UTC (rev 8525)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/ApacheSetupConfigurationProcess.cs 2015-01-31 16:47:06 UTC (rev 8526)
@@ -38,6 +38,20 @@
this.ApacheDirName = "Apache24";
+ public override void WriteSummary(FormatLineWriter writer)
+ writer("================ Summary ==================");
+ base.WriteSummary(writer);
+ writer("============= Apache Summary ==============");
+ writer("Apache dir name: {0}", this.ApacheDirName);
+ writer("Apache port: {0}", this.ApachePortNumber);
+ writer("Enable Java: {0}", this.EnableJava);
+ writer("Apache service name: {0}", this.HttpdServiceName);
+ writer("Tomcat port: {0}", this.TomcatPortNumber);
+ writer("Apache dir: {0}", this.ApacheDirName);
+ writer("Tomcat dir: {0}", this.WebTierTomcatDir);
public bool EnableJava { get; set; }
/// <summary>
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/FdoProviderRegistration.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/FdoProviderRegistration.cs 2015-01-29 15:18:40 UTC (rev 8525)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/FdoProviderRegistration.cs 2015-01-31 16:47:06 UTC (rev 8526)
@@ -36,6 +36,17 @@
_providerDllPaths = providerDllPaths;
+ public void WriteSummary(FormatLineWriter writer)
+ writer("=============== FDO Summary =================");
+ writer("FdoRegUtil path: {0}", _fdoRegUtilPath);
+ writer("The following providers will be registered:");
+ foreach (var path in _providerDllPaths)
+ writer(" - {0}", path);
public FdoRegistrationResult[] Execute()
var providersXmlPath = Path.Combine(Path.GetDirectoryName(_fdoRegUtilPath), "providers.xml");
Modified: trunk/Tools/MgInstantSetup/InstantSetup.Core/IISSetupConfigurationProcess.cs
--- trunk/Tools/MgInstantSetup/InstantSetup.Core/IISSetupConfigurationProcess.cs 2015-01-29 15:18:40 UTC (rev 8525)
+++ trunk/Tools/MgInstantSetup/InstantSetup.Core/IISSetupConfigurationProcess.cs 2015-01-31 16:47:06 UTC (rev 8526)
@@ -38,6 +38,17 @@
this.EnablePhp = false;
+ writer("============== IIS Summary ================");
+ writer("appcmd path: {0}", this.AppCmdPath);
+ writer("Application Pool: {0}", this.ApplicationPool);
+ writer("Enable .net: {0}", this.EnableDotNet);
+ writer("Web Site Name: {0}", this.WebSiteName);
public bool EnableDotNet { get; set; }
/// <summary>
Modified: trunk/Tools/MgInstantSetup/InstantSetupCmd/Options.cs
--- trunk/Tools/MgInstantSetup/InstantSetupCmd/Options.cs 2015-01-29 15:18:40 UTC (rev 8525)
+++ trunk/Tools/MgInstantSetup/InstantSetupCmd/Options.cs 2015-01-31 16:47:06 UTC (rev 8526)
@@ -22,10 +22,10 @@
[Option("admin-port", DefaultValue = 2820, HelpText = "The port to listen on for admin connections")]
public int ServerAdminPort { get; set; }
- [Option("client-port", DefaultValue = 2820, HelpText = "The port to listen on for client connections")]
+ [Option("client-port", DefaultValue = 2821, HelpText = "The port to listen on for client connections")]
public int ServerClientPort { get; set; }
- [Option("site-port", DefaultValue = 2820, HelpText = "The port to listen on for site connections")]
+ [Option("site-port", DefaultValue = 2822, HelpText = "The port to listen on for site connections")]
public int ServerSitePort { get; set; }
[Option("write-mentor-dictionary-path", DefaultValue = false, HelpText = "Write code to set up MENTOR_DICTIONARY_PATH on batch scripts. Only applicable for MGOS 2.2 or older")]
@@ -49,10 +49,10 @@
[Option("backup-path", HelpText = "The directory where backups of configuration files will be copied to")]
public string BackupConfigPath { get; set; }
- [Option("backup-files", DefaultValue = true, HelpText = "If true, will create backups of existing configuration files before overwriting")]
+ [Option("backup-files", DefaultValue = false, HelpText = "If true, will create backups of existing configuration files before overwriting")]
public bool BackupConfigFiles { get; set; }
- [Option("source-dir", HelpText = "The root path of the MapGuide installation (where InstantSetupCmd will do its configuration)")]
+ [Option("source-dir", Required = true, HelpText = "The root path of the MapGuide installation (where InstantSetupCmd will do its configuration)")]
public string SourceRootDir { get; set; }
[Option("virtual-dir", DefaultValue = "mapguide", HelpText = "The name of the mapguide virtual directory to create on IIS/Apache")]
@@ -61,6 +61,9 @@
[Option("webtier-config", Required = true, DefaultValue = MapGuideWebConfiguration.Apache, HelpText = "The web tier configuration to use (IIS / Apache)")]
public MapGuideWebConfiguration WebTierConfig { get; set; }
+ [OptionArray("fdo-providers", Required = true, HelpText = "The list of FDO providers to register (eg: SDF SHP SQLite)")]
+ public string[] FdoProviders { get; set; }
#region Apache-specific
[Option("enable-java", DefaultValue = false, HelpText = "Enables Java for this MapGuide installation")]
Modified: trunk/Tools/MgInstantSetup/InstantSetupCmd/Program.cs
--- trunk/Tools/MgInstantSetup/InstantSetupCmd/Program.cs 2015-01-29 15:18:40 UTC (rev 8525)
+++ trunk/Tools/MgInstantSetup/InstantSetupCmd/Program.cs 2015-01-31 16:47:06 UTC (rev 8526)
@@ -1,6 +1,7 @@
using InstantSetup.Core;
using System;
using System.Collections.Generic;
+using System.IO;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
@@ -30,6 +31,19 @@
if (proc != null)
+ proc.WriteSummary(Console.WriteLine);
+ //Do FDO registration first
+ var fdoPath = Path.Combine(options.SourceRootDir, "Server", "FDO");
+ var regUtil = Path.Combine(fdoPath, "FdoRegUtil.exe");
+ var reg = new FdoProviderRegistration(regUtil, options.FdoProviders.Select(n => Path.Combine(fdoPath, n + "Provider.dll")));
+ reg.WriteSummary(Console.WriteLine);
+ var results = reg.Execute();
+ foreach (var res in results)
+ Console.WriteLine("FdoRegUtil - {0} returned {1}", res.DllPath, res.ReturnCode);
proc.Execute();
Console.WriteLine("Batch scripts saved to: {0}", options.BatchFileOutputDirectory);
Environment.Exit(0);
More information about the mapguide-commits
